path: root/MAINTAINERS
2006-06-26Merge master.kernel.org:/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: Input: iforce - remove some pointless casts Input: psmouse - add support for Intellimouse 4.0 Input: atkbd - fix HANGEUL/HANJA keys Input: fix misspelling of Hangeul key Input: via-pmu - add input device support Input: rearrange exports Input: fix formatting to better follow CodingStyle Input: reset name, phys and uniq when unregistering Input: return correct size when reading modalias attribute Input: change my e-mail address in MAINTAINERS file Input: fix potential overflows in driver/input/keyboard Input: fix potential overflows in driver/input/touchscreen Input: fix potential overflows in driver/input/joystick Input: fix potential overflows in driver/input/mouse Input: fix accuracy of fixp-arith.h Input: iforce - use ENOSPC instead of ENOMEM Input: constify drivers/char/keyboard.c
2006-06-26[PATCH] Add new generic HW RNG coreMichael Buesch
Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26Input: change my e-mail address in MAINTAINERS fileDmitry Torokhov
2006-06-22[PATCH] add b44 to maintainersGary Zambrano
Add b44 to the MAINTAINERS file. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-22[PATCH] i2c-ocores: Minor cleanupsPeter Korsgaard
Minor cleanup to the i2c-ocores driver. Peter Korsgaard will maintain the i2c-ocores driver. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] abituguru: New hardware monitoring driverHans de Goede
New hardware monitoring driver for the Abit uGuru Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] hwmon: Drop some maintainers entriesJean Delvare
I no more wish to be listed as the maintainer for the smsc47m1 and w83l785ts drivers. I have no test device, and people will fallback to me as the general hardware monitoring maintainer anyway. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21Merge git://oss.sgi.com:8090/xfs-2.6Linus Torvalds
* git://oss.sgi.com:8090/xfs-2.6: (43 commits) [XFS] Remove files from the build that are now unused. [XFS] Fix a Makefile issue related to exports.o handling. [XFS] Remove version 1 directory code. Never functioned on Linux, just [XFS] Map EFSCORRUPTED to an actual error code, not just a made up one [XFS] Kill direct access to ->count in valusema(); all we ever use it for [XFS] Remove unneeded conditional code on NFS export interface related [XFS] Remove an incorrect use of unlikely() on a relatively likely code [XFS] Push some common code out of write path into core XFS code for [XFS] Remove unnecessary local from open_exec dmapi path. [XFS] Minor XFS documentation updates. [XFS] Fix broken const use inside local suffix_strtoul routine. [XFS] Fix nused counter. It's currently getting set to -1 rather than [XFS] Fix mismerge of the fs_writable cleanup patch causing a freeze/thaw [XFS] Fix up debug code so that bulkstat wont generate thousands of [XFS] Remove unused parameter from di2xflags routine. [XFS] Cleanup a missed porting conversion, and freezing. [XFS] Resolve a namespace collision on remaining vtypes for FreeBSD [XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters. [XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters. [XFS] statvfs component of directory/project quota support, code ...
2006-06-21Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (85 commits) [SCSI] 53c700: remove reliance on deprecated cmnd fields [SCSI] hptiop: don't use cmnd->bufflen [SCSI] hptiop: HighPoint RocketRAID 3xxx controller driver [SCSI] aacraid: small misc. cleanups [SCSI] aacraid: Update supported product information [SCSI] aacraid: Fix return code interpretation [SCSI] scsi_transport_sas: fix panic in sas_free_rphy [SCSI] remove RQ_SCSI_* flags [SCSI] remove scsi_request infrastructure [SCSI] mptfusion: change driver revision to 3.03.10 [SCSI] mptfc: abort of board reset leaves port dead requiring reboot [SCSI] mptfc: fix fibre channel infinite request/response loop [SCSI] mptfc: set fibre channel fw target missing timers to one second [SCSI] mptfusion: move fc event/reset handling to mptfc [SCSI] spi transport: don't allow dt to be set on SE or HVD buses [SCSI] aic7xxx: expose the bus setting to sysfs [SCSI] scsi: remove Documentation/scsi/cpqfc.txt [SCSI] drivers/scsi: Use ARRAY_SIZE macro [SCSI] Remove last page_address from dc395x.c [SCSI] hptiop: HighPoint RocketRAID 3xxx controller driver ... Fixed up conflicts in drivers/message/fusion/mptbase.c manually (due to the sparc interrupt cleanups)
2006-06-20Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (199 commits) [MTD] NAND: Fix breakage all over the place [PATCH] NAND: fix remaining OOB length calculation [MTD] NAND Fixup NDFC merge brokeness [MTD NAND] S3C2410 driver cleanup [MTD NAND] s3c24x0 board: Fix clock handling, ensure proper initialisation. [JFFS2] Check CRC32 on dirent and data nodes each time they're read [JFFS2] When retiring nextblock, allocate a node_ref for the wasted space [JFFS2] Mark XATTR support as experimental, for now [JFFS2] Don't trust node headers before the CRC is checked. [MTD] Restore MTD_ROM and MTD_RAM types [MTD] assume mtd->writesize is 1 for NOR flashes [MTD NAND] Fix s3c2410 NAND driver so it at least _looks_ like it compiles [MTD] Prepare physmap for 64-bit-resources [JFFS2] Fix more breakage caused by janitorial meddling. [JFFS2] Remove stray __exit from jffs2_compressors_exit() [MTD] Allow alternate JFFS2 mount variant for root filesystem. [MTD] Disconnect struct mtd_info from ABI [MTD] replace MTD_RAM with MTD_GENERIC_TYPE [MTD] replace MTD_ROM with MTD_GENERIC_TYPE [MTD] remove a forgotten MTD_XIP ...
2006-06-20Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] Add (MMC) to entry in MAINTAINERS file [MMC] sdhci truncated pointer fix
2006-06-20Merge HEAD from ../linux-2.6 Nathan Scott
2006-06-15[MMC] Add (MMC) to entry in MAINTAINERS fileRussell King
Juha Yrjola suggests that adding the string "MMC" to the maintainers file entry will make it easier to find. Add it to the file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-13[XFS] Minor XFS documentation updates.Nathan Scott
Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-10Merge ../linux-2.6James Bottomley
2006-06-10[SCSI] hptiop: HighPoint RocketRAID 3xxx controller driverHighPoint Linux Team
HighPoint RocketRAID 3220/3320 series 8 channel PCI-X SATA RAID Host Adapters. Fixes from original submission: Merge Andrew Morton's patches: - Provide locking for global list - Fix debug printks - uninline function with multiple callsites - coding style fixups - remove unneeded casts of void* - kfree(NULL) is legal - Don't "succeed" if register_chrdev() failed - otherwise we'll later unregister a not-registered chrdev. - Don't return from hptiop_do_ioctl() with the spinlock held. - uninline __hpt_do_ioctl() Update for Arjan van de Ven's comments: - put all asm/ includes after the linux/ ones - replace mdelay with msleep - add pci posting flush - do not set pci command reqister in map_pci_bar - do not try merging sg elements in hptiop_buildsgl() - remove unused outstandingcommands member from hba structure - remove unimplemented hptiop_abort() handler - remove typedef u32 hpt_id_t Other updates: - fix endianess Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-08Merge branch 'master' into upstreamJeff Garzik
2006-06-05Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] Prevent au1xmmc.c breakage on non-Au1200 Alchemy [MMC] Add maintainers entry for MMC subsystem
2006-06-05[PATCH] MAINTAINERS: Add entries for BNX2 and TG3Michael Chan
From: "Michael Chan" <mchan@broadcom.com> Add maintainer entries for Broadcom BNX2 and TG3 drivers. Signed-off-by: Michael Chan <mchan@broadcom.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-04[MMC] Add maintainers entry for MMC subsystemRussell King
2006-05-28Merge branch 'velocity' of ↵Jeff Garzik
git://electric-eye.fr.zoreil.com/home/romieu/linux-2.6 into upstream
2006-05-27Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [PATCH] powerpc: fix RTC/NVRAM accesses on Maple [PATCH] ppc32 CPM_UART: various fixes for pq2 uart users [PATCH] powerpc: linuxppc64.org no more
2006-05-26Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-05-26[PATCH] powerpc: linuxppc64.org no moreArthur Othieno
http://linuxppc64.org has long been a redirect to the canonical http://penguinppc.org/ppc64/ -- update all instances accordingly, as ACKed by Hollis: On Wed, Jan 18, 2006 at 09:48:08AM -0600, Hollis Blanchard wrote: > On Wed, 2006-01-18 at 13:07 +0100, Olaf Hering wrote: > > On Wed, Jan 18, Arthur Othieno wrote: > > > > > > What about the s/linuxppc64\.org/penguinppc\.org/g case? Or is > > > penguinppc64.org preferable? Or am I just taking it too far? ;) > > > > They are redirected on DNS or HTTP level. > > HTTP level, but that doesn't answer his question. > > As the maintainer of that site, I would prefer to remove the > linuxppc64.org reference. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-25[MAINTAINERS]: Add entry for netemStephen Hemminger
It gets enough reports, that there ought to be a MAINTAINER entry. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-23Merge branch 'master' into upstreamJeff Garzik
2006-05-21[PATCH] Update ext2/ext3/jbd MAINTAINERS entriesTheodore Tso
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] Clarify maintainers and include linux-security infoAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] Kdump maintainer info updateVivek Goyal
Update MAINTAINERS file for info regarding kdump maintainership. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-20Merge branch 'master' into upstreamJeff Garzik
2006-05-16[PATCH] SPI: Add David as the SPI subsystem maintainerKumar Gala
Add David as the SPI subsystem maintainer Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-05-15[PATCH] LED: Add maintainer entry for the LED subsystemRichard Purdie
Add a MAINTAINERS entry for the LED subsystem. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] Marcelo has movedMarcelo Tosatti
Signed-off-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-09[IRDA]: New maintainer.Samuel Ortiz
As agreed with Jean Tourrilhes, I am taking over IrDA maintainership. Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03Merge branch 'master' of ↵David Woodhouse
2006-04-26Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-04-24[PATCH] bcm43xx: add to MAINTAINERSMichael Buesch
2006-04-21[PARISC] MAINTAINERSKyle McMartin
Add myself to maintainers and add the parisc trees. Acked-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-04-20Merge branch 'master'Jeff Garzik
2006-04-20[PATCH] IPMI maintainerCorey Minyard
Add myself as the IPMI maintainer. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[MAINTAINERS] The ham radio code now has website at http://www.linux-ax25.org.Ralf Baechle
2006-04-17Merge with git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2006-04-14Merge branch '7.0.38-k2' of git://66.93.40.222/srv/git/netdev-2.6Jeff Garzik
2006-04-14{e100{,0},ixgb}: Add Auke Kok as new patch maintainer for e{100,1000} and ixgbAuke Kok
This adds Auke Kok to the list of maintainers for the Intel NICs. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: John Ronciak <john.ronciak@intel.com>
2006-04-11[WAN]: Remove broken and unmaintained Sangoma drivers.Adrian Bunk
The in-kernel Sangoma drivers are both not compiling and marked as BROKEN since at least kernel 2.6.0. Sangoma offers out-of-tree drivers, and David Mandelstam told me Sangoma does no longer maintain the in-kernel drivers and prefers to provide them as a separate installation package. This patch therefore removes these drivers. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11New MTD git tree in MAINTAINERSDavid Woodhouse
2006-04-11[PATCH] kexec: update MAINTAINERSRandy Dunlap
Eric is the kexec maintainer. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31IB/ipath: kbuild infrastructureBryan O'Sullivan
Integrate the ipath core and OpenIB drivers into the kernel build infrastructure. Add entry to MAINTAINERS. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-28[NET]: Kill Documentation/networking/TODODavid S. Miller
Sorely out of date. Add the linux-net wiki web site to the NETWORKING maintainers entry, on which we maintain the current networking TODO list. Noticed by Randy Dunlap. Signed-off-by: David S. Miller <davem@davemloft.net>
