* 'linux-next' of git://git.infradead.org/ubifs-2.6: (32 commits)
MAINTAINERS: change e-mail of Adrian Hunter
UBIFS: fix master node recovery
UBIFS: improve power cut emulation testing
UBIFS: rename recovery testing variables
UBIFS: remove custom list of superblocks
UBIFS: stop re-defining UBI operations
UBIFS: switch to I/O helpers
UBIFS: switch to ubifs_leb_write
UBIFS: switch to ubifs_leb_read
UBIFS: introduce more I/O helpers
UBIFS: always print stacktrace when switching to R/O mode
UBIFS: remove unused and unneeded debugging function
UBIFS: add global debugfs knobs
UBIFS: introduce debugfs helpers
UBIFS: re-arrange debugging code a bit
UBIFS: be more informative in failure mode
UBIFS: switch self-check knobs to debugfs
UBIFS: lessen amount of debugging check types
UBIFS: introduce helper functions for debugging checks and tests
UBIFS: amend debugging inode size check function prototype
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
... he does not work in Nokia any longer.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Chris Ball <cjb@laptop.org>
o Add entry for MIPS patchworks
o Reorder entries for readability.
Update the OMAP HSMMC entry from the MAINTAINERS file as I will
no longer be able to maintain this driver.
Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com>
[khilman@ti.com: change to Orphan rather than complete removal]
Signed-off-by: Kevin Hilman <khilman@ti.com>
Acked-by: Venkatraman S <svenkatr@ti.com>
Kalle Valo has asked me to take over the maintenance of the wl1251
driver. Thanks Kalle for all his work on the wl1251 driver, I'll try
to keep up with his good work from now on.
At the same time, update the Web URL to something more specific.
There's not much in that page, but we will try to update it soon.
Signed-off-by: Luciano Coelho <coelho@ti.com>
Acked-by: Kalle Valo <kvalo@adurom.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
net/bluetooth/l2cap_core.c
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@qlogic.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Signed-off-by: Barry Song <baohua.song@csr.com>
Update my email address
Signed-off-by: Josh Boyer <jwboyer@gmail.com>
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6994/1: smp_twd: Fix typo in 'twd_timer_rate' printing
ARM: 6987/1: l2x0: fix disabling function to avoid deadlock
ARM: 6966/1: ep93xx: fix inverted RTS/DTR signals on uart1
ARM: 6980/1: mmci: use StartBitErr to detect bad connections
ARM: 6979/1: mach-vt8500: add forgotten irq_data conversion
ARM: move memory layout sanity checking before meminfo initialization
ARM: 6990/1: MAINTAINERS: add entry for ARM PMU profiling and debugging
ARM: 6989/1: perf: do not start the PMU when no events are present
ARM: dmabounce: fix map_single() error return value
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Michael Buesch <m@bues.ch>
Move location of quilt series for kernel-doc patches.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (46 commits)
[media] rc: call input_sync after scancode reports
[media] imon: allow either proto on unknown 0xffdc
[media] imon: auto-config ffdc 7e device
[media] saa7134: fix raw IR timeout value
[media] rc: fix ghost keypresses with certain hw
[media] [staging] lirc_serial: allocate irq at init time
[media] lirc_zilog: fix spinning rx thread
[media] keymaps: fix table for pinnacle pctv hd devices
[media] ite-cir: 8709 needs to use pnp resource 2
[media] V4L: mx1-camera: fix uninitialized variable
[media] omap_vout: Added check in reqbuf & mmap for buf_size allocation
[media] OMAP_VOUT: Change hardcoded device node number to -1
[media] OMAP_VOUTLIB: Fix wrong resizer calculation
[media] uvcvideo: Disable the queue when failing to start
[media] uvcvideo: Remove buffers from the queues when freeing
[media] uvcvideo: Ignore entities for terminals with no supported format
[media] v4l: Don't access media entity after is has been destroyed
[media] media: omap3isp: fix a potential NULL deref
[media] media: vb2: fix allocation failure check
[media] media: vb2: reset queued_count value during queue reinitialization
Fix up trivial conflict in MAINTAINERS as per Mauro
Add the staging entries from various TODO files
to MAINTAINERS. Add a few web links as well.
Miscellaneous staging typo section header fix.
Commit b287db119edb ("se401: remove last V4L1 driver")
removed the files, remove the entry.
cc: Hans Verkuil <hverkuil@xs4all.nl>
cc: Mauro Carvalho Chehab <mchehab@redhat.com>
This handles the merge conflicts with the
drivers/staging/brcm80211/Kconfig file due to changes on the two
different branches.
Following a request from Russell King:
http://lists.infradead.org/pipermail/linux-arm-kernel/2011-June/055031.html
Add myself as the ARM PMU profiling and debugging maintainer. This
covers the ARM implementations of perf, oprofile and hw_breakpoint along
with the glue for this to work on different platforms.
Cc: Jean Pihet <j-pihet@ti.com>
Acked-by: Jamie Iles <jamie@jamieiles.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits)
usbnet: Remove over-broad module alias from zaurus.
MAINTAINERS: drop Michael from bfin_mac driver
net/can: activate bit-timing calculation and netlink based drivers by default
rionet: fix NULL pointer dereference in rionet_remove
net+crypto: Use vmalloc for zlib inflate buffers.
netfilter: Fix ip_route_me_harder triggering ip_rt_bug
ipv4: Fix IPsec slowpath fragmentation problem
ipv4: Fix packet size calculation in __ip_append_data
cxgb3: skb_record_rx_queue now records the queue index relative to the net_device.
bridge: Only flood unregistered groups to routers
qlge: Add maintainer.
MAINTAINERS: mark socketcan-core lists as subscribers-only
MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCED
r8169: fix wrong register use.
net/usb/kalmia: signedness bug in kalmia_bind()
net/usb: kalmia: Various fixes for better support of non-x86 architectures.
rtl8192cu: Fix missing firmware load
udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packet
ipv6/udp: Use the correct variable to determine non-blocking condition
netconsole: fix build when CONFIG_NETCONSOLE_DYNAMIC is turned on
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6:
MAINTAINERS: update AVR32 and AT32AP maintainers
Signed-off-by: James Morris <jmorris@namei.org>
This alters the maintenance of the AVR32 architecture and the AT32AP machine
code to be shared between Haavard Skinnemoen and me. The status is also changed
to maintained, as we no longer are being paid to look after this architecture.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
We want people to just use the list now rather than hitting up people
who are no longer responsible for it.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Update MAINTAINERS to refelect new people working on myri10ge
Signed-off-by: Jon Mason <mason@myri.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
MAINTAINERS: add myself as maintainer of USB/IP
usb: r8a66597-hcd: fix cannot detect low/full speed device
USB: ehci-ath79: fix a NULL pointer dereference
USB: Add new FT232H chip to drivers/usb/serial/ftdi_sio.c
usb/isp1760: Fix bug preventing the unlinking of control urbs
USB: Fix up URB error codes to reflect implementation.
xhci: Always set urb->status to zero for isoc endpoints.
xhci: Add reset on resume quirk for asrock p67 host
xHCI 1.0: Incompatible Device Error
USB: don't let errors prevent system sleep
USB: don't let the hub driver prevent system sleep
USB: change maintainership of ohci-hcd and ehci-hcd
xHCI 1.0: Force Stopped Event(FSE)
xhci: Don't warn about zeroed bMaxBurst descriptor field.
USB: Free bandwidth when usb_disable_device is called.
xhci: Reject double add of active endpoints.
USB: TI 3410/5052 USB Serial Driver: Fix mem leak when firmware is too big.
usb: musb: gadget: clear TXPKTRDY flag when set FLUSHFIFO
usb: musb: host: compare status for negative error values
This patch adds support for the Analog Devices ADAV801 and ADAV803 audio codec.
Acked-by: Liam Girdwood <lrg@ti.com>
Signed-off-by: matt mooney <mfm@muteddisk.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com>
