This driver supports Freescale NFC (NAND flash controller) found on
Vybrid (VF610), MPC5125, MCF54418 and Kinetis K70. The driver has
been tested on 8-bit and 16-bit NAND interface and supports ONFI
parameter page reading.
Limitations:
- DMA and pipelining not used
- Pages larger than 2k are not supported
- No hardware ECC
The driver has only been tested on Vybrid (VF610).
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"Resource management
- Fix IOV sorting by alignment (Wei Yang)
- Preserve resource size during alignment reordering (Yinghai Lu)
Miscellaneous
- MAINTAINERS: Add Pratyush for SPEAr13xx and DesignWare PCIe (Pratyush Anand)"
* tag 'pci-v4.1-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Preserve resource size during alignment reordering
PCI: Fix IOV resource sorting by alignment requirement
MAINTAINERS: Add Pratyush Anand as SPEAr13xx and DesignWare PCIe maintainer
OSDL has been gone for many years, looks like there still was
one reference to it.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Pull networking fixes from David Miller:
1) Various VTI tunnel (mark handling, PMTU) bug fixes from Alexander
Duyck and Steffen Klassert.
2) Revert ethtool PHY query change, it wasn't correct. The PHY address
selected by the driver running the PHY to MAC connection decides
what PHY address GET ethtool operations return information from.
3) Fix handling of sequence number bits for encryption IV generation in
ESP driver, from Herbert Xu.
4) UDP can return -EAGAIN when we hit a bad checksum on receive, even
when there are other packets in the receive queue which is wrong.
Just respect the error returned from the generic socket recv
datagram helper. From Eric Dumazet.
5) Fix BNA driver firmware loading on big-endian systems, from Ivan
Vecera.
6) Fix regression in that we were inheriting the congestion control of
the listening socket for new connections, the intended behavior
always was to use the default in this case. From Neal Cardwell.
7) Fix NULL deref in brcmfmac driver, from Arend van Spriel.
8) OTP parsing fix in iwlwifi from Liad Kaufman.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (26 commits)
vti6: Add pmtu handling to vti6_xmit.
Revert "net: core: 'ethtool' issue with querying phy settings"
bnx2x: Move statistics implementation into semaphores
xen: netback: read hotplug script once at start of day.
xen: netback: fix printf format string warning
Revert "netfilter: ensure number of counters is >0 in do_replace()"
net: dsa: Properly propagate errors from dsa_switch_setup_one
tcp: fix child sockets to use system default congestion control if not set
udp: fix behavior of wrong checksums
sfc: free multiple Rx buffers when required
bna: fix soft lock-up during firmware initialization failure
bna: remove unreasonable iocpf timer start
bna: fix firmware loading on big-endian machines
bridge: fix br_multicast_query_expired() bug
via-rhine: Resigning as maintainer
brcmfmac: avoid null pointer access when brcmf_msgbuf_get_pktid() fails
mac80211: Fix mac80211.h docbook comments
iwlwifi: nvm: fix otp parsing in 8000 hw family
iwlwifi: pcie: fix tracking of cmd_in_flight
ip_vti/ip6_vti: Preserve skb->mark after rcv_cb call
I don't have enough time to look after via-rhine anymore.
Signed-off-by: Roger Luethi <rl@hellgate.ch>
Commit 1ddd3b4e07a4 ("LSM: Remove unused capability.c") removed the
file, remove the file pattern.
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of five fixes: Two MAINTAINER email updates (urgent
because the non-avagotech emails will start bouncing) an lpfc big
endian oops fix, a 256 byte sector hang fix (to eliminate 256 byte
sectors) and a storvsc fix which could cause test unit ready failures
on bringup"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
MAINTAINERS: Revise lpfc maintainers for Avago Technologies ownership of Emulex
MAINTAINERS, be2iscsi: change email domain
sd: Disable support for 256 byte/sector disks
lpfc: Fix breakage on big endian kernels
storvsc: Set the SRB flags correctly when no data transfer is needed
This new location was supposed to be temporary, but a couple years
have elapsed and it's still there, so apparently it's there to stay.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
The old email addresses will go away very soon. Revising with new addresses.
Signed-off-by: Dick Kennedy <dick.kennedy@avagotech.com>
Signed-off-by: James Smart <james.smart@avagotech.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
be2iscsi change of ownership from Emulex to Avago Technologies recently. We
like to get the following updates in: changed "Emulex" to "Avago
Technologies", changed email addresses from "emulex.com" to "avagotech.com",
updated MAINTAINER list for be2iscsi driver.
Signed-off-by: Minh Tran <minh.tran@avagotech.com>
Signed-off-by: Jayamohan Kallickal <jayamohan.kallickal@avagotech.com>
Pull ARM SoC fixes from Arnd Bergmann:
"Nothing frightening this time, just smaller fixes in a number of
places.
The other changes contained here are:
MAINTAINERS file updates:
- The mach-gemini maintainer is back in action and has a new git tree
- Krzysztof Kozlowski has volunteered to be a new co-maintainer for
the samsung platforms
- updates to the files that belong to Marvell mvebu
Bug fixes:
- The largest changes are on omap2, but are only to avoid some
harmless warnings and to fix reset on omap4
- a small regression fix on tegra
- multiple fixes for incorrect IRQ affinity on vexpress
- the missing system controller on arm64 juno is added
- one revert of a patch that was accidentally applied twice for
mach-rockchip
- two clock related DT fixes for mvebu
- a workaround for suspend with old DT binaries on new exynos kernels
- Another fix for suspend on exynos, needs to be backported"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits)
MAINTAINERS: Add dts entries for some of the Marvell SoCs
MAINTAINERS: ARM: EXYNOS: Add Krzysztof Kozlowski as co-maintainer
ARM: EXYNOS: Use of_machine_is_compatible instead of soc_is_exynos4
ARM: EXYNOS: Fix failed second suspend on Exynos4
Revert "ARM: rockchip: fix undefined instruction of reset_ctrl_regs"
ARM: EXYNOS: Fix dereference of ERR_PTR returned by of_genpd_get_from_provider
ARM: EXYNOS: Don't try to initialize suspend on old DT
ARM: dts: Add keep-power-in-suspend to WiFi SDIO node for Peach Boards
ARM: gemini: fix compiler warning due wrong data type
ARM: vexpress/tc2: Add interrupt-affinity to the PMU node
ARM: vexpress/ca9: Add interrupt-affinity to the PMU node
ARM: vexpress/ca9: Add unified-cache property to l2 cache node
ARM64: juno: add sp810 support and fix sp804 clock frequency
ARM: Gemini: Maintainers update
ARM: OMAP2+: Remove bogus struct clk comparison for timer clock
ARM: dove: Add clock-names to CuBox Si5351 clk generator
ARM: AM33xx+: hwmod: re-use omap4 implementations for reset functionality
ARM: OMAP4+: PRM: add support for passing status register/bit info to reset
ARM: AM43xx: hwmod: add VPFE hwmod entries
ARM: mvebu: Fix the main PLL frequency on Armada 375, 38x and 39x SoCs
Didn't add myself as Maintainer earlier, as I was moving out of ST
and didn't had a board to test. But learnt recently that, it's fine being
in MAINTAINERS in such situations, at least I can review the patches.
So, let me add myself.
Signed-off-by: Pratyush Anand <pratyush.anand@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Jingoo Han <jingoohan1@gmail.com>
Merge "mvebu fixes for 4.1 (part 2)" from Gregory CLEMENT:
Add dts entries in the MAINTAINERS file
* tag 'mvebu-fixes-4.1-2' of git://git.infradead.org/linux-mvebu:
Since many releases, the modifications of the mvebu and berlin device
tree files are merged through the mvebu subsystem. This patch makes it
official in order to help the contributors using the get_maintainer.pl
to find the accurate peoples.
In the same time, updated the mvebu description which now includes the
kirkwood SoCs and new Armada SoCs.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Change my private email address.
Signed-off-by: Jingoo Han <jingoohan1@gmail.com>
Add Krzysztof Kozlowski as a co-maintainer of Samsung Exynos ARM
architecture to review the patches. Patches will go as usual - picked up
by Kukjin Kim.
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Kevin Hilman <khilman@kernel.org>
Cc: Olof Johansson <olof@lixom.net>
Cc: linux-samsung-soc@vger.kernel.org
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Acked-by: Tobias Jakobi <liquid.acid@gmx.net>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Kevin Hilman <khilman@linaro.org>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
1) Handle max TX power properly wrt VIFs and the MAC in iwlwifi, from
Avri Altman.
2) Use the correct FW API for scan completions in iwlwifi, from Avraham
Stern.
3) FW monitor in iwlwifi accidently uses unmapped memory, fix from Liad
Kaufman.
4) rhashtable conversion of mac80211 station table was buggy, the
virtual interface was not taken into account. Fix from Johannes
Berg.
5) Fix deadlock in rtlwifi by not using a zero timeout for
usb_control_msg(), from Larry Finger.
6) Update reordering state before calculating loss detection, from
Yuchung Cheng.
7) Fix off by one in bluetooth firmward parsing, from Dan Carpenter.
8) Fix extended frame handling in xiling_can driver, from Jeppe
Ledet-Pedersen.
9) Fix CODEL packet scheduler behavior in the presence of TSO packets,
from Eric Dumazet.
10) Fix NAPI budget testing in fm10k driver, from Alexander Duyck.
11) macvlan needs to propagate promisc settings down the the lower
device, from Vlad Yasevich.
12) igb driver can oops when changing number of rings, from Toshiaki
Makita.
13) Source specific default routes not handled properly in ipv6, from
Markus Stenberg.
14) Use after free in tc_ctl_tfilter(), from WANG Cong.
15) Use softirq spinlocking in netxen driver, from Tony Camuso.
16) Two ARM bpf JIT fixes from Nicolas Schichan.
17) Handle MSG_DONTWAIT properly in ring based AF_PACKET sends, from
Mathias Kretschmer.
18) Fix x86 bpf JIT implementation of FROM_{BE16,LE16,LE32}, from Alexei
Starovoitov.
19) ll_temac driver DMA maps TX packet header with incorrect length, fix
from Michal Simek.
20) We removed pm_qos bits from netdevice.h, but some indirect
references remained. Kill them. From David Ahern.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
net: Remove remaining remnants of pm_qos from netdevice.h
e1000e: Add pm_qos header
net: phy: micrel: Fix regression in kszphy_probe
net: ll_temac: Fix DMA map size bug
x86: bpf_jit: fix FROM_BE16 and FROM_LE16/32 instructions
netns: return RTM_NEWNSID instead of RTM_GETNSID on a get
Update be2net maintainers' email addresses
net_sched: gred: use correct backlog value in WRED mode
pppoe: drop pppoe device in pppoe_unbind_sock_work
net: qca_spi: Fix possible race during probe
net: mdio-gpio: Allow for unspecified bus id
af_packet / TX_RING not fully non-blocking (w/ MSG_DONTWAIT).
bnx2x: limit fw delay in kdump to 5s after boot
ARM: net: delegate filter to kernel interpreter when imm_offset() return value can't fit into 12bits.
ARM: net fix emit_udiv() for BPF_ALU | BPF_DIV | BPF_K intruction.
mpls: Change reserved label names to be consistent with netbsd
usbnet: avoid integer overflow in start_xmit
netxen_nic: use spin_[un]lock_bh around tx_clean_lock (2)
net: xgene_enet: Set hardware dependency
net: amd-xgbe: Add hardware dependency
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull rdma fixes from Doug Ledford:
- update MAINTAINERS git repo pointer
- printk garbage fix
- fix for qib and iw_cxgb4 bugs introduced in 4.1 window
- fix for an older iWARP netlink bug
- fix a memcpy issue in ehca driver
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma:
infiniband: Remove duplicated KERN_<LEVEL> from pr_<level> uses
IB/qib: fix test of unsigned variable
RDMA/core: Fix for parsing netlink string attribute
MAINTAINERS: update the official rdma git repo
iw_cxgb4: use wildcard mapping for getting remote addr info
IB/ehca: use correct destination for memcpy
Pull power supply and reset fixes from Sebastian Reichel:
"misc fixes"
* tag 'for-v4.1-rc' of git://git.infradead.org/battery-2.6:
power: bq27x00_battery: Add missing MODULE_ALIAS
power: reset: Add MFD_SYSCON depends for brcmstb
power: reset: ltc2952: Remove bogus hrtimer_start() return value checks
power_supply: fix oops in collie_battery driver
power/reset: at91: fix return value check in at91_reset_platform_probe()
MAINTAINERS: Add me as maintainer of Nokia N900 power supply drivers
axp288_fuel_gauge: Add original author details
Emulex developers' email addresses are now "@avagotech" instead of
"@emulex". I'm also replacing Subbu with Padmanabh and Sriharsha in the
maintainers list. The driver's heading was outdated and did not include
some of the chip types (BE3, Lancer and Skyhawk) that the driver has
been supporting for a longtime. I've updated this too.
Signed-off-by: Sathya Perla <sathya.perla@avagotech.com>
Back in business.
New place for my repo on github
Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Linus prefers kernel.org repos to github repos for security.
Signed-off-by: Doug Ledford <dledford@redhat.com>
"A few patches have come up since the merge window. The largest one is
a rewrite of the PXA lubbock/mainstone IRQ handling. This was already
broken in 2011 by a change to the GPIO code and only noticed now.
- Ray Jui and Scott Branden are now co-maintainers for some of the
mach-bcm chips, while Christian Daudt and Marc Carino have stepped
down.
- Andrew Victor is no longer maintaining at91. Instead, Alexandre
Belloni now becomes an official maintainer, after having done a
bulk of the work for a while.
- Baruch Siach, who added the mach-digicolor platform in 4.1 is now
listed as maintainer
- The git URL for mach-socfpga has changed
Bug fixes:
- Three bug fixes for new rockchip rk3288 code
- A regression fix to make SD card support work on certain ux500
boards
- multiple smaller dts fixes for imx, omap, mvebu, and shmobile
- a regression fiix for omap3 power consumption
- a fix for regression in the ARM CCI bus driver
Configuration changes:
- more imx platforms are now enabled in multi_v7_defconfig"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits)
MAINTAINERS: add Conexant Digicolor machines entry
MAINTAINERS: socfpga: update the git repo for SoCFPGA
ARM: multi_v7_defconfig: Select more FSL SoCs
MAINTAINERS: replace an AT91 maintainer
drivers: CCI: fix used_mask init in validate_group()
bus: omap_l3_noc: Fix master id address decoding for OMAP5
bus: omap_l3_noc: Fix offset for DRA7 CLK1_HOST_CLK1_2 instance
ARM: dts: dra7: Fix efuse register size for ABB
ARM: dts: am57xx-beagle-x15: Switch GPIO fan number
ARM: dts: am57xx-beagle-x15: Switch UART mux pins
ARM: dts: am437x-sk: reduce col-scan-delay-us
ARM: dts: am437x-sk: fix for new newhaven display module revision
ARM: dts: am57xx-beagle-x15: Fix RTC aliases
ARM: dts: am57xx-beagle-x15: Fix IRQ type for mcp7941x
ARM: dts: omap3: Add #iommu-cells to isp and iva iommu
ARM: omap2plus_defconfig: Enable EXTCON_USB_GPIO
ARM: dts: OMAP3-N900: Add microphone bias voltages
ARM: OMAP2+: Fix omap off idle power consumption creeping up
MAINTAINERS: Update brcmstb entry
MAINTAINERS: Remove Christian Daudt for mach-bcm
This adds Baruch as the maintainer for the Digicolor platform.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
The git tree at rocketboards.org is going away. Update the entry to reflect
the address of the new location. Also add an entry for all the socfpga_*
dts files.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
As some help is needed from an active maintainer, replace Andrew Victor
by Alexandre Belloni in the ARM/Atmel MAINTAINERS' entry (aka AT91).
Add an entry to the CREDITS file.
Thanks Andrew for the great role you played during the early days of this
product family.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
http://github.com/broadcom/stblinux into fixes
Merge "MAINTAINERS update for Broadcom SoCs for 4.1 #2" from Florian Fainelli:
This pull request contains 3 changes to the MAINTAINERS file for Broadcom SoCs:
- add Ray and Scott for mach-bcm
- remove Christian for mach-bcm
- remove Marc for brcmstb
* tag 'arm-soc/for-4.1/maintainers' of http://github.com/broadcom/stblinux:
MAINTAINERS: Update mach-bcm maintainers list
Pull infiniband updates from Doug Ledford:
"Minor updates for 4.1-rc
Most of the changes are fairly small and well confined. The iWARP
address reporting changes are the only ones that are a medium size. I
had these queued up prior to rc1, but due to the shuffle in
maintainers, they did not get submitted when I expected. My apologies
for that. I feel comfortable with them however due to the testing
they've received, so I left them in this submission"
* tag 'for-linus' of git://github.com/dledford/linux:
MAINTAINERS: Update InfiniBand subsystem maintainer
MAINTAINERS: add include/rdma/ to InfiniBand subsystem
IPoIB/CM: Fix indentation level
iw_cxgb4: Remove negative advice dmesg warnings
IB/core: Fix unaligned accesses
IB/core: change rdma_gid2ip into void function as it always return zero
IB/qib: use arch_phys_wc_add()
IB/qib: add acounting for MTRR
IB/core: dma unmap optimizations
IB/core: dma map/unmap locking optimizations
RDMA/cxgb4: Report the actual address of the remote connecting peer
RDMA/nes: Report the actual address of the remote connecting peer
RDMA/core: Enable the iWarp Port Mapper to provide the actual address of the connecting peer to its clients
iw_cxgb4: enforce qp/cq id requirements
iw_cxgb4: use BAR2 GTS register for T5 kernel mode CQs
iw_cxgb4: 32b platform fixes
iw_cxgb4: Cleanup register defines/MACROS
RDMA/CMA: Canonize IPv4 on IPV6 sockets properly
Add myself (Jacek Anaszewski) as a co-maintainer for the LED subsystem.
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
Acked-by: Bryan Wu <cooloney@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Sergey Senozhatsky has contributed/reviewed to zram for a long time. He
is really helpful for maintaining zram so I want for him to continue
helping me as Designated Reviewer unless he hates it.
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Since Roland stepped down, the community asked me to take his place, and
the nomination was followed by sufficient votes and no dissensions that
we can move forward with the change.
Most headers for InfiniBand/RDMA are located under
include/rdma/ and include/uapi/rdma.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
As German phone operators are discontinuing ISDN service, neither
Hansjörg nor I will be able to maintain the Gigaset ISDN drivers
any longer. Paul Bolle offered to step into the breach for odd
fixes.
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
Acked-by: Paul Bolle <pebolle@tiscali.nl>
Pull drm fixes from Dave Airlie:
"One intel fix, one rockchip fix, and a bunch of radeon fixes for some
regressions from audio rework and vm stability"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/i915/chv: Implement WaDisableShadowRegForCpd
drm/radeon: fix userptr return value checking (v2)
drm/radeon: check new address before removing old one
drm/radeon: reset BOs address after clearing it.
drm/radeon: fix lockup when BOs aren't part of the VM on release
drm/radeon: add SI DPM quirk for Sapphire R9 270 Dual-X 2G GDDR5
drm/radeon: adjust pll when audio is not enabled
drm/radeon: only enable audio streams if the monitor supports it
drm/radeon: only mark audio as connected if the monitor supports it (v3)
drm/radeon/audio: don't enable packets until the end
drm/radeon: drop dce6_dp_enable
drm/radeon: fix ordering of AVI packet setup
drm/radeon: Use drm_calloc_ab for CS relocs
drm/rockchip: fix error check when getting irq
MAINTAINERS: add entry for Rockchip drm drivers
https://github.com/markyzq/kernel-drm-rockchip into drm-fixes
one fix and maintainers update
* 'drm-next0420' of https://github.com/markyzq/kernel-drm-rockchip:
With my job change kernel work will be "own time"; I'm keeping lguest
and modules (and the virtio standards work), but virtio kernel has to
go.
This makes it clear that Michael is in charge. He's good, but having
me watch over his shoulder won't help.
Good luck Michael!
We have not heard back from Marc in a while, since we last asked him to
ack/nack this change here: https://lkml.org/lkml/2015/1/14/1004
This was back in January, we are in the 3.21^W4.1 merge window now, so,
as outlined in this email thread, remove him from the MAINTAINERS list
now.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Christian has not been responding to mach-bcm related emails since
around July 2013, and with Scott and Ray maintaining the platform, we
should have enough coverage to get that going now.
Add Ray Jui and Scott Branden for the mach-bcm/ entries.
I'm author of two of those drivers (bq2415x and rx51) and I added
more patches for other twos. Also I fished (proper) open source
power management software for Nokia N900 and those kernel drivers
are part of it.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
Pull more power management and ACPI updates from Rafael Wysocki:
"These are fixes mostly (intel_pstate, ACPI core, ACPI EC driver,
cpupower tool), a new CPU ID for the Intel RAPL driver and one
intel_pstate driver improvement that didn't make it to my previous
pull requests due to timing.
Specifics:
- Fix a build warning in the intel_pstate driver showing up in
non-SMP builds (Borislav Petkov)
- Change one of the intel_pstate's P-state selection parameters for
Baytrail and Cherrytrail CPUs to significantly improve performance
at the cost of a small increase in energy consumption (Kristen
Carlson Accardi)
- Fix a NULL pointer dereference in the ACPI EC driver due to an
unsafe list walk in the query handler removal routine (Chris
Bainbridge)
- Get rid of a false-positive lockdep warning in the ACPI container
hot-remove code (Rafael J Wysocki)
- Prevent the ACPI device enumeration code from creating device
objects of a wrong type in some cases (Rafael J Wysocki)
- Add Skylake processors support to the Intel RAPL power capping
driver (Brian Bian)
- Drop the stale MAINTAINERS entry for the ACPI dock driver that is
regarded as part of the ACPI core and maintained along with it now
(Chao Yu)
- Fix cpupower tool breakage caused by a library API change in libpci
3.3.0 (Lucas Stach)"
* tag 'pm+acpi-4.1-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / scan: Add a scan handler for PRP0001
ACPI / scan: Annotate physical_node_lock in acpi_scan_is_offline()
ACPI / EC: fix NULL pointer dereference in acpi_ec_remove_query_handler()
MAINTAINERS: remove maintainship entry of docking station driver
powercap / RAPL: Add support for Intel Skylake processors
cpufreq: intel_pstate: Fix an annoying !CONFIG_SMP warning
intel_pstate: Change the setpoint for Atom params
cpupower: fix breakage from libpci API change
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver updates from Darren Hart:
"This series includes significant updates to the toshiba_acpi driver
and the reintroduction of the dell-laptop keyboard backlight additions
I had to revert previously. Also included are various fixes for
typos, warnings, correctness, and minor bugs.
Specifics:
dell-laptop:
- add support for keyboard backlight.
toshiba_acpi:
- adaptive keyboard, hotkey, USB sleep and charge, and backlight
updates. Update sysfs documentation.
toshiba_bluetooth:
- fix enabling/disabling loop on recent devices
apple-gmux:
- lock iGP IO to protect from vgaarb changes
other:
- Fix typos, clear gcc warnings, clarify pr_* messages, correct
return types, update MAINTAINERS"
* tag 'platform-drivers-x86-v4.1-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (25 commits)
toshiba_acpi: Do not register vendor backlight when acpi_video bl is available
MAINTAINERS: Add me on list of Dell laptop drivers
platform: x86: dell-laptop: Add support for keyboard backlight
Documentation/ABI: Update sysfs-driver-toshiba_acpi entry
toshiba_acpi: Fix pr_* messages from USB Sleep Functions
toshiba_acpi: Update and fix USB Sleep and Charge modes
wmi: Use bool function return values of true/false not 1/0
toshiba_bluetooth: Fix enabling/disabling loop on recent devices
toshiba_bluetooth: Clean up *_add function and disable BT device at removal
toshiba_bluetooth: Add three new functions to the driver
toshiba_acpi: Fix the enabling of the Special Functions
toshiba_acpi: Use the Hotkey Event Type function for keymap choosing
toshiba_acpi: Add Hotkey Event Type function and definitions
x86/wmi: delete unused wmi_data_lock mutex causing gcc warning
apple-gmux: lock iGP IO to protect from vgaarb changes
MAINTAINERS: Add missing Toshiba devices and add myself as maintainer
toshiba_acpi: Update events in toshiba_acpi_notify
intel-oaktrail: Fix trivial typo in comment
thinkpad_acpi: off by one in adaptive_keyboard_hotkey_notify_hotkey()
thinkpad_acpi: signedness bugs getting current_mode
Pull slave-dmaengine updates from Vinod Koul:
- new drivers for:
- Ingenic JZ4780 controller
- APM X-Gene controller
- Freescale RaidEngine device
- Renesas USB Controller
- remove device_alloc_chan_resources dummy handlers
- sh driver cleanups for peri peri and related emmc and asoc patches
as well
- fixes and enhancements spread over the drivers
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits)
dmaengine: dw: don't prompt for DW_DMAC_CORE
dmaengine: shdmac: avoid unused variable warnings
dmaengine: fix platform_no_drv_owner.cocci warnings
dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe()
dmaengine: at_xdmac: unlock spin lock before return
dmaengine: xgene: devm_ioremap() returns NULL on error
dmaengine: xgene: buffer overflow in xgene_dma_init_channels()
dmaengine: usb-dmac: Fix dereferencing freed memory 'desc'
dmaengine: sa11x0: report slave capabilities to upper layers
dmaengine: vdma: Fix compilation warnings
dmaengine: fsl_raid: statify fsl_re_chan_probe
dmaengine: Driver support for FSL RaidEngine device.
dmaengine: xgene_dma_init_ring_mngr() can be static
Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding
arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes
dmaengine: Add support for APM X-Gene SoC DMA engine driver
dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver
dmaengine: renesas,usb-dmac: Add device tree bindings documentation
dmaengine: edma: fixed wrongly initialized data parameter to the edma callback
dmaengine: ste_dma40: fix implicit conversion
* acpi-dock:
* acpi-ec:
* acpi-scan:
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull InfiniBand/RDMA updates from Roland Dreier:
- IPoIB fixes from Doug Ledford and Erez Shitrit
- iSER updates from Sagi Grimberg
- mlx4 GUID handling changes from Yishai Hadas
- other misc fixes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (51 commits)
mlx5: wrong page mask if CONFIG_ARCH_DMA_ADDR_T_64BIT enabled for 32Bit architectures
IB/iser: Rewrite bounce buffer code path
IB/iser: Bump version to 1.6
IB/iser: Remove code duplication for a single DMA entry
IB/iser: Pass struct iser_mem_reg to iser_fast_reg_mr and iser_reg_sig_mr
IB/iser: Modify struct iser_mem_reg members
IB/iser: Make fastreg pool cache friendly
IB/iser: Move PI context alloc/free to routines
IB/iser: Move fastreg descriptor pool get/put to helper functions
IB/iser: Merge build page-vec into register page-vec
IB/iser: Get rid of struct iser_rdma_regd
IB/iser: Remove redundant assignments in iser_reg_page_vec
IB/iser: Move memory reg/dereg routines to iser_memory.c
IB/iser: Don't pass ib_device to fall_to_bounce_buff routine
IB/iser: Remove a redundant struct iser_data_buf
IB/iser: Remove redundant cmd_data_len calculation
IB/iser: Fix wrong calculation of protection buffer length
IB/iser: Handle fastreg/local_inv completion errors
IB/iser: Fix unload during ep_poll wrong dereference
ib_srpt: convert printk's to pr_* functions
"These fix an ia64 regression caused by tighter resource checking we
merged during the merge window and remove an invalid email address
from MAINTAINERS.
Resource management:
- ia64: Treat all Address Space Descriptors as windows (Bjorn Helgaas)
Miscellaneous:
- MAINTAINERS: Remove Mohit Kumar (email bounces) (Bjorn Helgaas)"
* tag 'pci-v4.1-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
ia64/PCI: Treat all host bridge Address Space Descriptors (even consumers) as windows
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Some virtio internal cleanups, a new virtio device "virtio input", and
a change to allow the legacy virtio balloon.
Most excitingly, some lguest work! No seriously, I got some cleanup
patches"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio: drop virtio_device_is_legacy_only
virtio_pci: support non-legacy balloon devices
virtio_mmio: support non-legacy balloon devices
virtio_ccw: support non-legacy balloon devices
virtio: balloon might not be a legacy device
virtio_balloon: transitional interface
virtio_ring: Update weak barriers to use dma_wmb/rmb
virtio_pci_modern: switch to type-safe io accessors
virtio_pci_modern: type-safe io accessors
lguest: handle traps on the "interrupt suppressed" iret instruction.
virtio: drop a useless config read
virtio_config: reorder functions
Add virtio-input driver.
lguest: suppress interrupts for single insn, not range.
lguest: simplify lguest_iret
lguest: rename i386_head.S in the comments
lguest: explicitly set miscdevice's private_data NULL
lguest: fix pending interrupt test.
Pull ARM SoC multiplatform code changes from Olof Johansson:
"The changes here belong to two main platforms:
- Atmel At91 is flipping the bit and going multiplatform. This
includes some cleanups and removal of code, and the final flip of
config dependencies
- Shmobile has several platforms that are going multiplatform, but
this branch also contains a bunch of cleanups that they weren't
able to keep separate in a good way. THere's also a removal of one
of their SoCs and the corresponding boards (sh7372 and mackerel)"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
ARM: at91/pm: move AT91_MEMCTRL_* to pm.h
ARM: at91/pm: move the standby functions to pm.c
ARM: at91: fix pm_suspend.S compilation when ARMv6 is selected
ARM: at91: add a Kconfig dependency on multi-platform
ARM: at91: drop AT91_TIMER_HZ
ARM: at91: remove hardware.h
ARM: at91: remove SoC headers
ARM: at91: remove useless mach/cpu.h
ARM: at91: remove unused headers
ARM: at91: switch at91_dt_defconfig to multiplatform
ARM: at91: switch to multiplatform
ARM: shmobile: r8a7778: enable multiplatform target
ARM: shmobile: bockw: add sound to DT
ARM: shmobile: r8a7778: add sound to DT
ARM: shmobile: bockw: add devices hooked up to i2c0 to DT
DT: i2c: add trivial binding for OKI ML86V7667 video decoder
ARM: shmobile: r8a7778: common clock framework CPG driver
ARM: shmobile: bockw dts: set extal clock frequency
ARM: shmobile: bockw dts: Move Ethernet node to BSC
ARM: shmobile: r8a73a4: Remove legacy code
Pull ARM SoC driver updates from Olof Johansson:
"Driver updates for v4.1. Some of these are for drivers/soc, where we
find more and more SoC-specific drivers these days. Some are for
other driver subsystems where we have received acks from the
appropriate maintainers.
The larger parts of this branch are:
- MediaTek support for their PMIC wrapper interface, a high-level
interface for talking to the system PMIC over a dedicated I2C
interface.
- Qualcomm SCM driver has been moved to drivers/firmware. It's used
for CPU up/down and needs to be in a shared location for arm/arm64
common code.
- cleanup of ARM-CCI PMU code.
- another set of cleanusp to the OMAP GPMC code"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits)
soc/mediatek: Remove unused variables
clocksource: atmel-st: select MFD_SYSCON
soc: mediatek: Add PMIC wrapper for MT8135 and MT8173 SoCs
arm-cci: Fix CCI PMU event validation
arm-cci: Split the code for PMU vs driver support
arm-cci: Get rid of secure transactions for PMU driver
arm-cci: Abstract the CCI400 PMU specific definitions
arm-cci: Rearrange code for splitting PMU vs driver code
drivers: cci: reject groups spanning multiple HW PMUs
ARM: at91: remove useless include
clocksource: atmel-st: remove mach/hardware dependency
clocksource: atmel-st: use syscon/regmap
ARM: at91: time: move the system timer driver to drivers/clocksource
ARM: at91: properly initialize timer
ARM: at91: at91rm9200: remove deprecated arm_pm_restart
watchdog: at91rm9200: implement restart handler
watchdog: at91rm9200: use the system timer syscon
mfd: syscon: Add atmel system timer registers definition
ARM: at91/dt: declare atmel,at91rm9200-st as a syscon
soc: qcom: gsbi: Add support for ADM CRCI muxing
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
