path: root/MAINTAINERS
2012-12-17MAINTAINERS: add LP855x backlight driver entryKim, Milo
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: adjust for UAPI: firewireStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Corentin has movedCorentin Chary
Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: remove include/linux/ext3*Cesar Eduardo Barros
Moved to fs/ext3/ext3.h by commit 4613ad180d19 ("ext3: move headers to fs/ext3/"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: CHINESE MAINTAINERS mailing list is subscribers onlyJoe Perches
Mark it so. Signed-off-by: Joe Perches <joe@perches.com> Cc: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull DRM updates from Dave Airlie: "This is the one and only next pull for 3.8, we had a regression we found last week, so I was waiting for that to resolve itself, and I ended up with some Intel fixes on top as well. Highlights: - new driver: nvidia tegra 20/30/hdmi support - radeon: add support for previously unused DMA engines, more HDMI regs, eviction speeds ups and fixes - i915: HSW support enable, agp removal on GEN6, seqno wrapping - exynos: IPP subsystem support (image post proc), HDMI - nouveau: display class reworking, nv20->40 z compression - ttm: start of locking fixes, rcu usage for lookups, - core: documentation updates, docbook integration, monotonic clock usage, move from connector to object properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (590 commits) drm/exynos: add gsc ipp driver drm/exynos: add rotator ipp driver drm/exynos: add fimc ipp driver drm/exynos: add iommu support for ipp drm/exynos: add ipp subsystem drm/exynos: support device tree for fimd radeon: fix regression with eviction since evict caching changes drm/radeon: add more pedantic checks in the CP DMA checker drm/radeon: bump version for CS ioctl support for async DMA drm/radeon: enable the async DMA rings in the CS ioctl drm/radeon: add VM CS parser support for async DMA on cayman/TN/SI drm/radeon/kms: add evergreen/cayman CS parser for async DMA (v2) drm/radeon/kms: add 6xx/7xx CS parser for async DMA (v2) drm/radeon: fix htile buffer size computation for command stream checker drm/radeon: fix fence locking in the pageflip callback drm/radeon: make indirect register access concurrency-safe drm/radeon: add W|RREG32_IDX for MM_INDEX|DATA based mmio accesss drm/exynos: support extended screen coordinate of fimd drm/exynos: fix x, y coordinates for right bottom pixel drm/exynos: fix fb offset calculation for plane ...
2012-12-16MAINTAINERS: Fix drivers/i2c/busses/i2c-stub.cCesar Eduardo Barros
This file was moved to drivers/i2c/i2c-stub.c by commit 31d178b (i2c-stub: Move to drivers/i2c). Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-12-15Merge tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
Pull fbdev changes from Tomi Valkeinen: "OMAPDSS changes, including: - use dynanic debug prints - OMAP platform dependency removals - Creation of compat-layer, helping us to improve omapdrm - Misc cleanups, aiming to make omadss more in line with the upcoming common display framework Exynos DP changes for the 3.8 merge window: - Device Tree support for Samsung Exynos DP - SW Link training is cleaned up. - HPD interrupt is supported. Samsung Framebuffer changes for the 3.8 merge window: - The bit definitions of header file are updated. - Some minor typos are fixed. - Some minor bugs of s3c_fb_check_var() are fixed. FB related changes for SH Mobile, Freescale DIU Add support for the Solomon SSD1307 OLED Controller" * tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linux: (191 commits) OMAPDSS: fix TV-out issue with DSI PLL Revert "OMAPFB: simplify locking" OMAPFB: remove silly loop in fb2display() OMAPFB: fix error handling in omapfb_find_best_mode() OMAPFB: use devm_kzalloc to allocate omapfb2_device OMAPDSS: DISPC: remove dispc fck uses OMAPDSS: DISPC: get dss clock rate from dss driver drivers/video/console/softcursor.c: remove redundant NULL check before kfree() drivers/video: add support for the Solomon SSD1307 OLED Controller OMAPDSS: use omapdss_compat_init() in other drivers OMAPDSS: export dispc functions OMAPDSS: export dss_feat functions OMAPDSS: export dss_mgr_ops functions OMAPDSS: separate compat files in the Makefile OMAPDSS: move display sysfs init to compat layer OMAPDSS: DPI: use dispc's check_timings OMAPDSS: DISPC: add dispc_ovl_check() OMAPDSS: move irq handling to dispc-compat OMAPDSS: move omap_dispc_wait_for_irq_interruptible_timeout to dispc-compat.c OMAPDSS: move blocking mgr enable/disable to compat layer ... Conflicts: arch/arm/mach-davinci/devices-da8xx.c arch/arm/plat-omap/common.c drivers/media/platform/omap/omap_vout.c
2012-12-14Merge tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson: "This is a branch with updates for Marvell's mvebu/kirkwood platforms. They came in late-ish, and were heavily interdependent such that it didn't make sense to split them up across the cross-platform topic branches. So here they are (for the second release in a row) in a branch on their own." * tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits) arm: l2x0: add aurora related properties to OF binding arm: mvebu: add Aurora L2 Cache Controller to the DT arm: mvebu: add L2 cache support dma: mv_xor: fix error handling path dma: mv_xor: fix error checking of irq_of_parse_and_map() dma: mv_xor: use request_irq() instead of devm_request_irq() dma: mv_xor: clear the window override control registers arm: mvebu: fix address decoding armada_cfg_base() function ARM: mvebu: update defconfig with I2C and RTC support ARM: mvebu: Add SATA support for OpenBlocks AX3-4 ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4 ARM: mvebu: Add support for I2C on OpenBlocks AX3-4 ARM: mvebu: Add support for I2C controllers in Armada 370/XP arm: mvebu: Add hardware I/O Coherency support arm: plat-orion: Add coherency attribute when setup mbus target arm: dma mapping: Export a dma ops function arm_dma_set_mask arm: mvebu: Add SMP support for Armada XP arm: mm: Add support for PJ4B cpu and init routines arm: mvebu: Add IPI support via doorbells arm: mvebu: Add initial support for power managmement service unit ...
2012-12-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The MIPS bits for 3.8. This also includes a bunch fixes that were sitting in the linux-mips.org git tree for a long time. This pull request contains updates to several OCTEON drivers and the board support code for BCM47XX, BCM63XX, XLP, XLR, XLS, lantiq, Loongson1B, updates to the SSB bus support, MIPS kexec code and adds support for kdump. When pulling this, there are two expected merge conflicts in include/linux/bcma/bcma_driver_chipcommon.h which are trivial to resolve, just remove the conflict markers and keep both alternatives." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (90 commits) MIPS: PMC-Sierra Yosemite: Remove support. VIDEO: Newport Fix console crashes MIPS: wrppmc: Fix build of PCI code. MIPS: IP22/IP28: Fix build of EISA code. MIPS: RB532: Fix build of prom code. MIPS: PowerTV: Fix build. MIPS: IP27: Correct fucked grammar in ops-bridge.c MIPS: Highmem: Fix build error if CONFIG_DEBUG_HIGHMEM is disabled MIPS: Fix potencial corruption MIPS: Fix for warning from FPU emulation code MIPS: Handle COP3 Unusable exception as COP1X for FP emulation MIPS: Fix poweroff failure when HOTPLUG_CPU configured. MIPS: MT: Fix build with CONFIG_UIDGID_STRICT_TYPE_CHECKS=y MIPS: Remove unused smvp.h MIPS/EDAC: Improve OCTEON EDAC support. MIPS: OCTEON: Add definitions for OCTEON memory contoller registers. MIPS: OCTEON: Add OCTEON family definitions to octeon-model.h ata: pata_octeon_cf: Use correct byte order for DMA in when built little-endian. MIPS/OCTEON/ata: Convert pata_octeon_cf.c to use device tree. MIPS: Remove usage of CEVT_R4K_LIB config option. ...
2012-12-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Missing MAINTAINERS entries were added for several drivers - Adds V4L2 support for DMABUF handling, allowing zero-copy buffer sharing between V4L2 devices and GPU - Got rid of all warnings when compiling with W=1 on x86 - Add a new driver for Exynos hardware (s3c-camif) - Several bug fixes, cleanups and driver improvements * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (243 commits) [media] omap3isp: Replace cpu_is_omap3630() with ISP revision check [media] omap3isp: Prepare/unprepare clocks before/after enable/disable [media] omap3isp: preview: Add support for 8-bit formats at the sink pad [media] omap3isp: Replace printk with dev_* [media] omap3isp: Find source pad from external entity [media] omap3isp: Configure CSI-2 phy based on platform data [media] omap3isp: Add PHY routing configuration [media] omap3isp: Add CSI configuration registers from control block to ISP resources [media] omap3isp: Remove unneeded module memory address definitions [media] omap3isp: Use monotonic timestamps for statistics buffers [media] uvcvideo: Fix control value clamping for unsigned integer controls [media] uvcvideo: Mark first output terminal as default video node [media] uvcvideo: Add VIDIOC_[GS]_PRIORITY support [media] uvcvideo: Return -ENOTTY for unsupported ioctls [media] uvcvideo: Set device_caps in VIDIOC_QUERYCAP [media] uvcvideo: Don't fail when an unsupported format is requested [media] uvcvideo: Return -EACCES when trying to access a read/write-only control [media] uvcvideo: Set error_idx properly for extended controls API failures [media] rtl28xxu: add NOXON DAB/DAB+ USB dongle rev 2 [media] fc2580: write some registers conditionally ...
2012-12-13Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "This patch set includes two large new drivers: mpt3sas (for the next gen fusion SAS hardware) and csiostor a FCoE offload driver for the Chelsio converged network cards (this includes some net changes which I've OK'd with DaveM). The rest of the patch is driver updates (qla2xxx, lpfc, hptiop, be2iscsi) plus a few assorted updates and bug fixes. We also have a Power Management rework in the Upper Layer Drivers preparatory to doing ACPI zero power optical devices, but the actual enabler is still being worked on. Signed-off-by: James Bottomley <JBottomley@Parallels.com>" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (72 commits) [SCSI] mpt3sas: add new driver supporting 12GB SAS [SCSI] scsi_transport_sas: add 12GB definitions for mpt3sas [SCSI] miscdevice: Adding support for MPT3SAS_MINOR(222) [SCSI] csiostor: remove unneeded memset() [SCSI] csiostor: Fix sparse warnings. [SCSI] qla2xxx: Display that driver is operating in legacy interrupt mode. [SCSI] qla2xxx: Dont clear drv active on iospace config failure. [SCSI] qla2xxx: Fix typo in qla2xxx driver. [SCSI] qla2xxx: Update ql2xextended_error_logging parameter description with new option. [SCSI] qla2xxx: Parameterize the link speed of hba rather than fcport. [SCSI] qla2xxx: Add 16Gb/s case to get port speed capability. [SCSI] qla2xxx: Move marking fcport online ahead of setting iiDMA speed. [SCSI] qla2xxx: Add acquiring of risc semaphore before doing ISP reset. [SCSI] qla2xxx: Ignore driver ack bit if corresponding presence bit is not set. [SCSI] qla2xxx: Fix typo in qla83xx_fw_dump function. [SCSI] qla2xxx: Add Gen3 PCIe speed 8GT/s to the log message. [SCSI] qla2xxx: Use correct Request-Q-Out register during bidirectional request processing [SCSI] qla2xxx: Move noisy Start scsi failed messages to verbose logging level. [SCSI] qla2xxx: Fix coccinelle warnings in qla2x00_relogin. [SCSI] qla2xxx: No fcport FC-4 type assignment in GA_NXT response. ...
2012-12-13Merge tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Marcelo Tosatti: "Considerable KVM/PPC work, x86 kvmclock vsyscall support, IA32_TSC_ADJUST MSR emulation, amongst others." Fix up trivial conflict in kernel/sched/core.c due to cross-cpu migration notifier added next to rq migration call-back. * tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits) KVM: emulator: fix real mode segment checks in address linearization VMX: remove unneeded enable_unrestricted_guest check KVM: VMX: fix DPL during entry to protected mode x86/kexec: crash_vmclear_local_vmcss needs __rcu kvm: Fix irqfd resampler list walk KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary KVM: MMU: optimize for set_spte KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation KVM: PPC: bookehv: Add guest computation mode for irq delivery KVM: PPC: Make EPCR a valid field for booke64 and bookehv KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation KVM: PPC: e500: Add emulation helper for getting instruction ea KVM: PPC: bookehv64: Add support for interrupt handling KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler KVM: PPC: booke: Fix get_tb() compile error on 64-bit KVM: PPC: e500: Silence bogus GCC warning in tlb code ...
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates from Olof Johansson: "This contains the bulk of new SoC development for this merge window. Two new platforms have been added, the sunxi platforms (Allwinner A1x SoCs) by Maxime Ripard, and a generic Broadcom platform for a new series of ARMv7 platforms from them, where the hope is that we can keep the platform code generic enough to have them all share one mach directory. The new Broadcom platform is contributed by Christian Daudt. Highbank has grown support for Calxeda's next generation of hardware, ECX-2000. clps711x has seen a lot of cleanup from Alexander Shiyan, and he's also taken on maintainership of the platform. Beyond this there has been a bunch of work from a number of people on converting more platforms to IRQ domains, pinctrl conversion, cleanup and general feature enablement across most of the active platforms." Fix up trivial conflicts as per Olof. * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (174 commits) mfd: vexpress-sysreg: Remove LEDs code irqchip: irq-sunxi: Add terminating entry for sunxi_irq_dt_ids clocksource: sunxi_timer: Add terminating entry for sunxi_timer_dt_ids irq: versatile: delete dangling variable ARM: sunxi: add missing include for mdelay() ARM: EXYNOS: Avoid early use of of_machine_is_compatible() ARM: dts: add node for PL330 MDMA1 controller for exynos4 ARM: EXYNOS: Add support for secondary CPU bring-up on Exynos4412 ARM: EXYNOS: add UART3 to DEBUG_LL ports ARM: S3C24XX: Add clkdev entry for camif-upll clock ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers ARM: sunxi: Add missing sun4i.dtsi file pinctrl: samsung: Do not initialise statics to 0 ARM i.MX6: remove gate_mask from pllv3 ARM i.MX6: Fix ethernet PLL clocks ARM i.MX6: rename PLLs according to datasheet ARM i.MX6: Add pwm support ARM i.MX51: Add pwm support ARM i.MX53: Add pwm support ARM: mx5: Replace clk_register_clkdev with clock DT lookup ...
2012-12-12Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson: "Cleanup patches for various ARM platforms and some of their associated drivers. There's also a branch in here that enables Freescale i.MX to be part of the multiplatform support -- the first "big" SoC that is moved over (more multiplatform work comes in a separate branch later during the merge window)." Conflicts fixed as per Olof, including a silent semantic one in arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to omap3xxx_restart(), and a new user of the old name was added). * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits) ARM: omap: fix typo on timer cleanup ARM: EXYNOS: Remove unused regs-mem.h file ARM: EXYNOS: Remove unused non-dt support for dwmci controller ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan ARM: OMAP3: cm-t3517: use GPTIMER for system clock ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER ARM: SAMSUNG: use devm_ functions for ADC driver ARM: EXYNOS: no duplicate mask/unmask in eint0_15 ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443 ARM: EXYNOS: Remove i2c0 resource information and setting of device names ARM: Kirkwood: checkpatch cleanups ARM: Kirkwood: Fix sparse warnings. ARM: Kirkwood: Remove unused includes ARM: kirkwood: cleanup lsxl board includes ARM: integrator: use BUG_ON where possible ARM: integrator: push down SC dependencies ARM: integrator: delete static UART1 mapping ARM: integrator: delete SC mapping on the CP ARM: integrator: remove static CP syscon mapping ARM: integrator: remove static AP syscon mapping ...
2012-12-12Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC Non-critical bug fixes from Olof Johansson: "Simple bug fixes that were not considered important enough for inclusion into 3.7, especially those that arrived late during the merge window. There's also a MAINTAINERS update for the Renesas platforms in here, marking Simon Horman as a maintainer and changing the git url to his tree." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: Update ARM/SHMOBILE section of MAINTAINERS ARM: Fix Kconfig symbols typo for LEDS ARM: pxa: add dummy SA1100 rtc clock in pxa25x ARM: pxa: fix pxa25x gpio wakeup setting ARM: OMAP4: PM: fix errata handling when CONFIG_PM=n ARM: cns3xxx: drop unnecessary symbol selection ARM: vexpress: fix ll debug code when building multiplatform ARM: OMAP4: retrigger localtimers after re-enabling gic ARM: OMAP4460: Workaround for ROM bug because of CA9 r2pX GIC control register change. ARM: OMAP4: PM: add errata support ARM: davinci: fix return value check by using IS_ERR in tnetv107x_devices_init() ARM: davinci: uncompress.h: bail out if uart not initialized ARM: davinci: serial.h: fix uart number in the comment ARM: davinci: dm644x evm: move pointer dereference below NULL check ARM: vexpress: Make the debug UART detection more specific
2012-12-12Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 updates from Catalin Marinas: - Generic execve, kernel_thread, fork/vfork/clone. - Preparatory patches for KVM support (initialising EL2 mode for later installing KVM support, hypervisor stub). - Signal handling corner case fix (alternative signal stack set up for a SEGV handler, which is raised in response to RLIMIT_STACK being reached). - Sub-nanosecond timer error fix. * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (30 commits) arm64: Update the MAINTAINERS entry arm64: compat for clock_adjtime(2) is miswired arm64: move FP-SIMD save/restore code to a macro arm64: hyp: initialize vttbr_el2 to zero arm64: add hypervisor stub arm64: record boot mode when entering the kernel arm64: move vector entry macro to assembler.h arm64: add AArch32 execution modes to ptrace.h arm64: expand register mapping between AArch32 and AArch64 arm64: generic timer: use virtual counter instead of physical at EL0 arm64: vdso: defer shifting of nanosecond component of timespec arm64: vdso: rework __do_get_tspec register allocation and return shift arm64: vdso: check sequence counter even for coarse realtime operations arm64: vdso: fix clocksource mask when extracting bottom 56 bits ARM64: Remove incorrect Kconfig symbol HAVE_SPARSE_IRQ Documentation: Fixes a word in Documentation/arm64/memory.txt arm64: Make !dirty ptes read-only arm64: Convert empty flush_cache_{mm,page} functions to static inline arm64: signal: let the compiler inline compat_get_sigframe arm64: signal: return struct rt_sigframe from get_sigframe ... Conflicts: arch/arm64/include/asm/unistd32.h
2012-12-12MIPS: Cavium: Add EDAC support.Ralf Baechle
Drivers for EDAC on Cavium. Supported subsystems are: o CPU primary caches. These are parity protected only, so only error reporting. o Second level cache - ECC protected, provides SECDED. o Memory: ECC / SECDEC if used with suitable DRAM modules. The driver will will only initialize if ECC is enabled on a system so is safe to run on non-ECC memory. o PCI: Parity error reporting Since it is very hard to test this sort of code the implementation is very conservative and uses polling where possible for now. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Borislav Petkov <borislav.petkov@amd.com>
2012-12-11Merge tag 'usb-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg Kroah-Hartman: "Here's the big set of USB patches for 3.8-rc1. Lots of USB host driver cleanups in here, and a bit of a reorg of the EHCI driver to make it easier for the different EHCI platform drivers to all work together nicer, which was a reduction in overall code. We also deleted some unused firmware files, and got rid of the very old file_storage usb gadget driver that had been broken for a long time. This means we ended up removing way more code than added, always a nice thing to see: 310 files changed, 3028 insertions(+), 10754 deletions(-) Other than that, the usual set of new device ids, driver fixes, gadget driver and controller updates and the like. All of these have been in the linux-next tree for a number of weeks. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (228 commits) USB: mark uas driver as BROKEN xhci: Add Lynx Point LP to list of Intel switchable hosts uwb: fix uwb_dev_unlock() missed at an error path in uwb_rc_cmd_async() USB: ftdi_sio: Add support for Newport AGILIS motor drivers MAINTAINERS: remove drivers/block/ub.c USB: chipidea: fix use after free bug ezusb: add dependency to USB usb: ftdi_sio: fixup BeagleBone A5+ quirk USB: cp210x: add Virtenio Preon32 device id usb: storage: remove redundant memset() in usb_probe_stor1() USB: option: blacklist network interface on Huawei E173 USB: OHCI: workaround for hardware bug: retired TDs not added to the Done Queue USB: add new zte 3g-dongle's pid to option.c USB: opticon: switch to generic read implementation USB: opticon: refactor reab-urb processing USB: opticon: use usb-serial bulk-in urb USB: opticon: increase bulk-in size USB: opticon: use port as urb context USB: opticon: pass port to get_serial_info USB: opticon: make private data port specific ...
2012-12-11Merge tag 'tty-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull TTY/Serial merge from Greg Kroah-Hartman: "Here's the big tty/serial tree set of changes for 3.8-rc1. Contained in here is a bunch more reworks of the tty port layer from Jiri and bugfixes from Alan, along with a number of other tty and serial driver updates by the various driver authors. Also, Jiri has been coerced^Wconvinced to be the co-maintainer of the TTY layer, which is much appreciated by me. All of these have been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up some trivial conflicts in the staging tree, due to the fwserial driver having come in both ways (but fixed up a bit in the serial tree), and the ioctl handling in the dgrp driver having been done slightly differently (staging tree got that one right, and removed both TIOCGSOFTCAR and TIOCSSOFTCAR). * tag 'tty-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (146 commits) staging: sb105x: fix potential NULL pointer dereference in mp_chars_in_buffer() staging/fwserial: Remove superfluous free staging/fwserial: Use WARN_ONCE when port table is corrupted staging/fwserial: Destruct embedded tty_port on teardown staging/fwserial: Fix build breakage when !CONFIG_BUG staging: fwserial: Add TTY-over-Firewire serial driver drivers/tty/serial/serial_core.c: clean up HIGH_BITS_OFFSET usage staging: dgrp: dgrp_tty.c: Audit the return values of get/put_user() staging: dgrp: dgrp_tty.c: Remove the TIOCSSOFTCAR ioctl handler from dgrp driver serial: ifx6x60: Add modem power off function in the platform reboot process serial: mxs-auart: unmap the scatter list before we copy the data serial: mxs-auart: disable the Receive Timeout Interrupt when DMA is enabled serial: max310x: Setup missing "can_sleep" field for GPIO tty/serial: fix ifx6x60.c declaration warning serial: samsung: add devicetree properties for non-Exynos SoCs serial: samsung: fix potential soft lockup during uart write tty: vt: Remove redundant null check before kfree. tty/8250 Add check for pci_ioremap_bar failure tty/8250 Add support for Commtech's Fastcom Async-335 and Fastcom Async-PCIe cards tty/8250 Add XR17D15x devices to the exar_handle_irq override ...
2012-12-11Merge tag 'staging-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver tree merge from Greg Kroah-Hartman: "Here's the big staging tree merge for 3.8-rc1 There's a lot of patches in here, the majority being the comedi rework/cleanup that has been ongoing and is causing a huge reduction in overall code size, which is amazing to watch. We also removed some older drivers (telephony and rts_pstor), and added a new one (fwserial which also came in through the tty tree due to tty api changes, take that one if you get merge conflicts.) The iio and ipack drivers are moving out of the staging area into their own part of the kernel as they have been cleaned up sufficiently and are working well. Overall, again a reduction of code: 768 files changed, 31887 insertions(+), 82166 deletions(-) All of this has been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'staging-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1298 commits) iio: imu: adis16480: remove duplicated include from adis16480.c iio: gyro: adis16136: remove duplicated include from adis16136.c iio:imu: adis16480: show_firmware() buffer too small iio:gyro: adis16136: divide by zero in write_frequency() iio: adc: Add Texas Instruments ADC081C021/027 support iio:ad7793: Add support for the ad7796 and ad7797 iio:ad7793: Add support for the ad7798 and ad7799 staging:iio: Move ad7793 driver out of staging staging:iio:ad7793: Implement stricter id checking staging:iio:ad7793: Move register definitions from header to source staging:iio:ad7793: Rework regulator handling staging:iio:ad7793: Rework platform data staging:iio:ad7793: Use kstrtol instead of strict_strtol staging:iio:ad7793: Use usleep_range instead of msleep staging:iio:ad7793: Fix temperature scale staging:iio:ad7793: Fix VDD monitor scale staging: gdm72xx: unlock on error in init_usb() staging: panel: pass correct lengths to keypad_send_key() staging: comedi: addi_apci_2032: fix interrupt support staging: comedi: addi_apci_2032: move i_APCI2032_ConfigDigitalOutput() ...
2012-12-11Merge tag 'char-misc-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull Char/Misc driver merge from Greg Kroah-Hartman: "Here is the "big" char/misc driver patches for 3.8-rc1. I'm starting to put random driver subsystems that I had previously sent you through the driver-core tree in this tree, as it makes more sense to do so. Nothing major here, the various __dev* removals, some mei driver updates, and other random driver-specific things from the different maintainers and developers. Note, some MFD drivers got added through this tree, and they are also coming in through the "real" MFD tree as well, due to some major mis-communication between me and the different developers. If you have any merge conflicts, take the ones from the MFD tree, not these ones, sorry about that. All of this has been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up trivial conflict in drivers/mmc/host/Kconfig due to new drivers having been added (both at the end, as usual..) * tag 'char-misc-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (84 commits) MAINTAINERS: remove drivers/staging/hv/ misc/st_kim: Free resources in the error path of probe() drivers/char: for hpet, add count checking, and ~0UL instead of -1 w1-gpio: Simplify & get rid of defines w1-gpio: Pinctrl-fy extcon: remove use of __devexit_p extcon: remove use of __devinit extcon: remove use of __devexit drivers: uio: Only allocate new private data when probing device tree node drivers: uio_dmem_genirq: Allow partial success when opening device drivers: uio_dmem_genirq: Don't use DMA_ERROR_CODE to indicate unmapped regions drivers: uio_dmem_genirq: Don't mix address spaces for dynamic region vaddr uio: remove use of __devexit uio: remove use of __devinitdata uio: remove use of __devinit uio: remove use of __devexit_p char: remove use of __devexit char: remove use of __devinitconst char: remove use of __devinitdata char: remove use of __devinit ...
2012-12-11Merge tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linuxLinus Torvalds
Pull clock framework changes from Mike Turquette: "The common clock framework changes for 3.8 are comprised of lots of fixes for existing platforms as well as new ports for some ARM platforms. In addition there are new clk drivers for audio devices and MFDs." Fix up trivial conflict in <linux/clk-provider.h> (removal of 'inline' clashing with return type fixes) * tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linux: (51 commits) MAINTAINERS: bad email address for Mike Turquette clk: introduce optional disable_unused callback clk: ux500: fix bit error clk: clock multiplexers may register out of order clk: ux500: Initial support for abx500 clock driver CLK: SPEAr: Remove unused dummy apb_pclk CLK: SPEAr: Correct index scanning done for clock synths CLK: SPEAr: Update clock rate table CLK: SPEAr: Add missing clocks CLK: SPEAr: Set CLK_SET_RATE_PARENT for few clocks CLK: SPEAr13xx: fix parent names of multiple clocks CLK: SPEAr13xx: Fix mux clock names CLK: SPEAr: Fix dev_id & con_id for multiple clocks clk: move IM-PD1 clocks to drivers/clk clk: make ICST driver handle the VCO registers clk: add GPLv2 headers to the Versatile clock files clk: mxs: Use a better name for the USB PHY clock clk: spear: Add stub functions for spear3[0|1|2]0_clk_init() CLK: clk-twl6040: fix return value check in twl6040_clk_probe() clk: ux500: Register nomadik keypad clock lookups for u8500 ...
2012-12-11Merge tag 'pinctrl-for-v3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl changes from Linus Walleij: "These are the first and major pinctrl changes for the v3.8 merge cycle. Some of this is used as merge base for other trees so I better be early on the trigger. As can be seen from the diffstat the major changes are: - A big conversion of the AT91 pinctrl driver and the associated ACKed platform changes under arch/arm/max-at91 and its device trees. This has been coordinated with the AT91 maintainers to go in through the pinctrl tree. - A larger chunk of changes to the SPEAr drivers and the addition of the "plgpio" driver for the SPEAr as well. - The removal of the remnants of the Nomadik driver from the arch/arm tree and fusion of that into the Nomadik driver and platform data header files. - Some local movement in the Marvell MVEBU drivers, these now have their own subdirectory. - The addition of a chunk of code to gpiolib under drivers/gpio to register gpio-to-pin range mappings from the GPIO side of things. This has been requested by Grant Likely and is now implemented, it is particularly useful for device tree work. Then we have incremental updates all over the place, many of these are cleanups and fixes from Axel Lin who has done a great job of removing minor mistakes and compilation annoyances." * tag 'pinctrl-for-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (114 commits) ARM: mmp: select PINCTRL for ARCH_MMP pinctrl: Drop selecting PINCONF for MMP2, PXA168 and PXA910 pinctrl: pinctrl-single: Fix error check condition pinctrl: SPEAr: Update error check for unsigned variables gpiolib: Fix use after free in gpiochip_add_pin_range gpiolib: rename pin range arguments pinctrl: single: support gpio request and free pinctrl: generic: add input schmitt disable parameter pinctrl/u300/coh901: stop spawning pinctrl from GPIO pinctrl/u300/coh901: let the gpio_chip register the range pinctrl: add function to retrieve range from pin gpiolib: return any error code from range creation pinctrl: make range registration defer properly gpiolib: rename find_pinctrl_* gpiolib: let gpiochip_add_pin_range() specify offset ARM: at91: pm9g45: add mmc support ARM: at91: Animeo IP: add mmc support ARM: at91: dt: add mmc pinctrl for Atmel reference boards ARM: at91: dt: at91sam9: add mmc pinctrl support ARM: at91/dts: add nodes for atmel hsmci controllers for atmel boards ...
2012-12-11Merge tag 'mmc-updates-for-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: "MMC highlights for 3.8: Core: - Expose access to the eMMC RPMB ("Replay Protected Memory Block") area by extending the existing mmc_block ioctl. - Add SDIO powered-suspend DT properties to the core MMC DT binding. - Add no-1-8-v DT flag for boards where the SD controller reports that it supports 1.8V but the board itself has no way to switch to 1.8V. - More work on switching to 1.8V UHS support using a vqmmc regulator. - Fix up a case where the slot-gpio helper may fail to reset the host controller properly if a card was removed during a transfer. - Fix several cases where a broken device could cause an infinite loop while we wait for a register to update. Drivers: - at91-mci: Remove obsolete driver, atmel-mci handles these devices now. - sdhci-dove: Allow using GPIOs for card-detect notifications. - sdhci-esdhc: Fix for recovering from ADMA errors on broken silicon. - sdhci-s3c: Add pinctrl support. - wmt-sdmmc: New driver for WonderMedia SD/MMC controllers." * tag 'mmc-updates-for-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (65 commits) mmc: sdhci: implement the .card_event() method mmc: extend the slot-gpio card-detection to use host's .card_event() method mmc: add a card-event host operation mmc: sdhci-s3c: Fix compilation warning mmc: sdhci-pci: Enable SDHCI_CAN_DO_HISPD for Ricoh SDHCI controller mmc: sdhci-dove: allow GPIOs to be used for card detection on Dove mmc: sdhci-dove: use two-stage initialization for sdhci-pltfm mmc: sdhci-dove: use devm_clk_get() mmc: eSDHC: Recover from ADMA errors mmc: dw_mmc: remove duplicated buswidth code mmc: dw_mmc: relocate where dw_mci_setup_bus() is called from mmc: Limit MMC speed to 52MHz if not HS200 mmc: dw_mmc: use devres functions in dw_mmc mmc: sh_mmcif: remove unneeded clock connection ID mmc: sh_mobile_sdhi: remove unneeded clock connection ID mmc: sh_mobile_sdhi: fix clock frequency printing mmc: Remove redundant null check before kfree in bus.c mmc: Remove redundant null check before kfree in sdio_bus.c mmc: sdhci-imx-esdhc: use more devm_* functions mmc: dt: add no-1-8-v device tree flag ...
2012-12-11arm64: Update the MAINTAINERS entryCatalin Marinas
Add a backup maintainer and include Documentation/arm64/. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2012-12-10MAINTAINERS: bad email address for Mike TurquetteMike Turquette
Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-12-10Merge branch 'drm-next-3.8' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-next Alex writes: Pretty minor -next pull request. We some additional new bits waiting internally for release. Hopefully Monday we can get at least some of them out. The others will probably take a few more weeks. Highlights of the current request: - ELD registers for passing audio information to the sound hardware - Handle GPUVM page faults more gracefully - Misc fixes Merge radeon test * 'drm-next-3.8' of git://people.freedesktop.org/~agd5f/linux: (483 commits) drm/radeon: bump driver version for new info ioctl requests drm/radeon: fix eDP clk and lane setup for scaled modes drm/radeon: add new INFO ioctl requests drm/radeon/dce32+: use fractional fb dividers for high clocks drm/radeon: use cached memory when evicting for vram on non agp drm/radeon: add a CS flag END_OF_FRAME drm/radeon: stop page faults from hanging the system (v2) drm/radeon/dce4/5: add registers for ELD handling drm/radeon/dce3.2: add registers for ELD handling radeon: fix pll/ctrc mapping on dce2 and dce3 hardware Linux 3.7-rc7 powerpc/eeh: Do not invalidate PE properly Revert "drm/i915: enable rc6 on ilk again" ALSA: hda - Fix build without CONFIG_PM of/address: sparc: Declare of_iomap as an extern function for sparc again PM / QoS: fix wrong error-checking condition bnx2x: remove redundant warning log vxlan: fix command usage in its doc 8139cp: revert "set ring address before enabling receiver" MPI: Fix compilation on MIPS with GCC 4.4 and newer ... Conflicts: drivers/gpu/drm/exynos/exynos_drm_encoder.c drivers/gpu/drm/exynos/exynos_drm_fbdev.c drivers/gpu/drm/nouveau/core/engine/disp/nv50.c
2012-12-07Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2012-12-06mmc: SD/MMC Host Controller for Wondermedia WM8505/WM8650Tony Prisk
This patch adds support for the SD/MMC host controller found on Wondermedia 8xxx series SoCs, currently supported under arm/arch-vt8500. A binding document is also included, based on mmc.txt with additional properties. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-12-06mmc: at91-mci: remove obsolete driverLudovic Desroches
The at91-mci driver is not needed anymore since the atmel-mci driver now supports all Atmel devices. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-12-06propagate name change to comments in kernel sourceNadia Yvette Chambers
I've legally changed my name with New York State, the US Social Security Administration, et al. This patch propagates the name change and change in initials and login to comments in the kernel source as well. Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-06MAINTAINERS: Add git tree link for PPC KVMMichael Ellerman
Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2012-12-02MAINTAINERS: Add Mellanox ethernet driver - mlx4_enAmir Vadai
Set mlx4_en maintainer to Amir Vadai instead of Yevgeny Petrilin. Signed-off-by: Amir Vadai <amirv@mellanox.com> Cc: Yevgeny Petrilin <yevgenyp@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-30brcm80211: update the MAINTAINERS fileArend van Spriel
Organizational changes need to be reflected in the MAINTAINERS file. The contact info on wireless.kernel.org has also been updated. Reviewed-by: Hante Meuleman <meuleman@broadcom.com> Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-11-30Merge branch 'next/cam-samsung' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc From Kukjin Kim: Just adding camif gpio setup and clkdev. * 'next/cam-samsung' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: S3C24XX: Add clkdev entry for camif-upll clock ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers + Linux 3.7-rc6 Conflicts due to the 3.7-rc6 sync: arch/arm/mach-highbank/system.c include/linux/clk-provider.h, resolved as in other branches. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-30MAINTAINERS: fix bouncing tun/tap entriesJiri Slaby
Delivery to the following recipient failed permanently: vtun@office.satix.net Technical details of permanent failure: DNS Error: Domain name not found Of course: $ host office.satix.net Host office.satix.net not found: 3(NXDOMAIN) =========== And "Change of Email Address Notification": Old Address New Address Email Subject ------------------------------------------------------ maxk@qualcomm.com maxk@qti.qualcomm.com "tuntap: multiqueue... Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Maxim Krasnyansky <maxk@qti.qualcomm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-30Merge tag 'mvebu_everything_for_3.8' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into late/mvebu From Jason Cooper. Unfortunately this is a combined branch with all mvebu code as one drop, something we normally try to avoid and instead slice vendor topics across our branches. Hopefully we can avoid doing this again for 3.9! mvebu everything for v3.8 - due to the complex interdependencies of the received pull requests I decided to keep this in one branch the way they recommended merging it - this was their first attempt at doing pull requests, we'll work on it with them - added SMP support for mvebu SoCs - added coherency fabric - added mdio and mvneta drivers - added mirabox board - added openblocks ax3-4 board - clock fixes and improvements - converted mv_xor driver to devicetree (extensive series in itself) * tag 'mvebu_everything_for_3.8' of git://git.infradead.org/users/jcooper/linux: (85 commits) dma: mv_xor: fix error handling path dma: mv_xor: fix error checking of irq_of_parse_and_map() dma: mv_xor: use request_irq() instead of devm_request_irq() dma: mv_xor: clear the window override control registers arm: mvebu: fix address decoding armada_cfg_base() function ARM: mvebu: update defconfig with I2C and RTC support ARM: mvebu: Add SATA support for OpenBlocks AX3-4 ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4 ARM: mvebu: Add support for I2C on OpenBlocks AX3-4 ARM: mvebu: Add support for I2C controllers in Armada 370/XP arm: mvebu: Add hardware I/O Coherency support arm: plat-orion: Add coherency attribute when setup mbus target arm: dma mapping: Export a dma ops function arm_dma_set_mask arm: mvebu: Add SMP support for Armada XP arm: mm: Add support for PJ4B cpu and init routines arm: mvebu: Add IPI support via doorbells arm: mvebu: Add initial support for power managmement service unit arm: mvebu: Add support for coherency fabric in mach-mvebu arm: mvebu: update defconfig to include XOR driver arm: mvebu: update defconfig to include network driver ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-30Merge branch 'maintainers' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/fixes-non-critical From Simon Horman: * 'maintainers' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: Update ARM/SHMOBILE section of MAINTAINERS Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-29drm: tegra: Add maintainers entryThierry Reding
Add myself as the maintainer of the NVIDIA Tegra DRM driver. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-11-28Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/pcie/tx.c
2012-11-28Merge remote-tracking branch 'linus/master' into staging/for_v3.8Mauro Carvalho Chehab
* linus/master: (1428 commits) futex: avoid wake_futex() for a PI futex_q watchdog: using u64 in get_sample_period() writeback: put unused inodes to LRU after writeback completion mm: vmscan: check for fatal signals iff the process was throttled Revert "mm: remove __GFP_NO_KSWAPD" proc: check vma->vm_file before dereferencing UAPI: strip the _UAPI prefix from header guards during header installation include/linux/bug.h: fix sparse warning related to BUILD_BUG_ON_INVALID Linux 3.7-rc7 powerpc/eeh: Do not invalidate PE properly ALSA: hda - Fix build without CONFIG_PM of/address: sparc: Declare of_iomap as an extern function for sparc again PM / QoS: fix wrong error-checking condition bnx2x: remove redundant warning log vxlan: fix command usage in its doc 8139cp: revert "set ring address before enabling receiver" MPI: Fix compilation on MIPS with GCC 4.4 and newer MIPS: Fix crash that occurs when function tracing is enabled MIPS: Merge overlapping bootmem ranges jbd: Fix lock ordering bug in journal_unmap_buffer() ...
2012-11-28Update ARM/SHMOBILE section of MAINTAINERSSimon Horman
I have been handling maintenance of shmobile for a little over a release-cycle now and it seems to appropriate to update the MAINTAINERS file accordingly. Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2012-11-27Merge branch 'fbdev-next' of github.com:timur-tabi/linux-2.6 into for-linusTomi Valkeinen
* 'fbdev-next' of github.com:timur-tabi/linux-2.6: drivers/video: fsl-diu-fb: store EDID data in the global object drivers/video: fsl-diu-fb: don't touch registers for unused features drivers/video: fsl-diu-fb: clean up reset of primary display drivers/video: fsl-diu-fb: remove unused 'cursor_reset' variable drivers/video: fsl-diu-fb: improve message displays drivers/video: fsl-diu-fb: streamline enabling of interrupts drivers/video: fsl-diu-fb: add support for set_gamma ioctls drivers/video: fsl-diu-fb: simplify platforms that have only one port MAINTAINERS: Make Timur Tabi the maintainer for the Freescale DIU driver
2012-11-27[SCSI] MAINTAINERS: update LSILOGIC MPT FUSION DRIVERS (FC/SAS/SPI) maintainerssreekanth.reddy@lsi.com
Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-11-26MAINTAINERS: remove drivers/staging/hv/Cesar Eduardo Barros
This directory was removed by commit 89ae7d7 (hv: storvsc: Move the storage driver out of the staging area). Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26MAINTAINERS: remove drivers/block/ub.cCesar Eduardo Barros
This driver was removed by commit 68a5059 (block: remove the deprecated ub driver). Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: linux-usb@vger.kernel.org Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26MAINTAINERS: Make Timur Tabi the maintainer for the Freescale DIU driverTimur Tabi
Timur has been cleaning up this driver, so just make it official. Signed-off-by: Timur Tabi <timur@freescale.com>
