path: root/MAINTAINERS
2009-01-15MAINTAINERS: add entry for freezerPavel Machek
Now that people are using freezer for non-suspend/hibernation stuff, it should have separate maintainers entry so that it is easier to find. Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15edac: add MAINTAINERS entry for i5400 EDAC driverMauro Carvalho Chehab
i5400 EDAC driver were added upstream by those changesets: - 920c8df6ac678fdb8c49a6ce2e47a98e62757d77 "edac: driver for i5400 MCH (Seaburg)" - 8375d4909aee4c18798f373ecf24a79f040f75fc "edac: driver for i5400 MCH (update)" Update MAINTAINERS entry for this file to correspond to the driver maintainer. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Ben Woodard <woodard@redhat.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into ↵Lachlan McIlroy
for-linus
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: MAINTAINERS: squashfs entry Squashfs: documentation Squashfs: initrd support Squashfs: Kconfig entry Squashfs: Makefiles Squashfs: header files Squashfs: block operations Squashfs: cache operations Squashfs: uid/gid lookup operations Squashfs: fragment block operations Squashfs: export operations Squashfs: super block operations Squashfs: symlink operations Squashfs: regular file operations Squashfs: directory readdir operations Squashfs: directory lookup operations Squashfs: inode operations
2009-01-09[XFS] Update maintainersLachlan McIlroy
New maintainer contact and new tree location. Reviewed-by: Bill O`Donnell <billodo@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2009-01-08Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (53 commits) serial: Add driver for the Cell Network Processor serial port NWP device powerpc: enable dynamic ftrace powerpc/cell: Fix the prototype of create_vma_map() powerpc/mm: Make clear_fixmap() actually work powerpc/kdump: Use ppc_save_regs() in crash_setup_regs() powerpc: Export cacheable_memzero as its now used in a driver powerpc: Fix missing semicolons in mmu_decl.h powerpc/pasemi: local_irq_save uses an unsigned long powerpc/cell: Fix some u64 vs. long types powerpc/cell: Use correct types in beat files powerpc: Use correct type in prom_init.c powerpc: Remove unnecessary casts mtd/ps3vram: Use _PAGE_NO_CACHE in memory ioremap mtd/ps3vram: Use msleep in waits mtd/ps3vram: Use proper kernel types mtd/ps3vram: Cleanup ps3vram driver messages mtd/ps3vram: Remove ps3vram debug routines mtd/ps3vram: Add modalias support to the ps3vram driver mtd/ps3vram: Add ps3vram driver for accessing video RAM as MTD powerpc: Fix iseries drivers build failure without CONFIG_VIOPATH ...
2009-01-08misc: add dell-laptop driverMatthew Garrett
Add a driver for controlling Dell-specific backlight and rfkill interfaces. This driver makes use of the dcdbas interface to the Dell firmware to allow the backlight and rfkill interfaces on Dell systems to be driven through the standardised sysfs interfaces. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Ivo van Doorn <ivdoorn@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08mtd/ps3vram: Add ps3vram driver for accessing video RAM as MTDJim Paris
Add ps3vram driver, which exposes unused video RAM on the PS3 as a MTD device suitable for storage or swap. Fast data transfer is achieved using a local cache in system RAM and DMA transfers via the GPU. Signed-off-by: Vivien Chappelier <vivien.chappelier@free.fr> Signed-off-by: Jim Paris <jim@jtan.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-07V4L/DVB (10191a): Update MAINTAINERS entries on media driversMauro Carvalho Chehab
This patch updates the MAINTAINERS entries for the media drivers. We are doing a few changes during 2009 to improve patch handling for drivers/media stuff. Currently, v4l-dvb-maintainer list at linuxtv.org were used to to be v4l/dvb driver maintainers ML, in order to keep track of patch merge requests and to receive bug fixes. This list allows posting for everybody, but, in order to avoid spam, the user subscribe/unsubscribe at the ML is moderated. Other development discussions and end-user forums happened on two separated ML (one for V4L and another for DVB). At the beginning of 2009, we've created linux-media@vger.kernel.org, meaning to be the main upstream development mailing list for drivers/media, including V4L and DVB core and drivers. The choice for vger.kernel.org were due to the fact that most of upstream lists are there. Also, its anti-spam filtering rules are better than what we currently have at linuxtv.org. For now, both video4linux-list and linux-dvb ML will remain active, but more focused on end users. It is expected that those lists will gradually be replaced also by linux-media@vger.kernel.org. This patch reflect those changes at linux MAINTAINERS file. Since the development and bug fix discussions will now happen at linux-media@vger.kernel.org, this patch does the following changes - replaces v4l-dvb-maintainer ML for the new linux-media@vger.kernel.org; - replaces video4linux ML for the new linux-media@vger.kernel.org; While here, it also: - Fixes the existing -git tree entries for drivers/media (since the repository name changed); - Adds the missing drivers/media -git tree entry on a few maintainers entries that don't point to a tree. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (123 commits) wimax/i2400m: add CREDITS and MAINTAINERS entries wimax: export linux/wimax.h and linux/wimax/i2400m.h with headers_install i2400m: Makefile and Kconfig i2400m/SDIO: TX and RX path backends i2400m/SDIO: firmware upload backend i2400m/SDIO: probe/disconnect, dev init/shutdown and reset backends i2400m/SDIO: header for the SDIO subdriver i2400m/USB: TX and RX path backends i2400m/USB: firmware upload backend i2400m/USB: probe/disconnect, dev init/shutdown and reset backends i2400m/USB: header for the USB bus driver i2400m: debugfs controls i2400m: various functions for device management i2400m: RX and TX data/control paths i2400m: firmware loading and bootrom initialization i2400m: linkage to the networking stack i2400m: Generic probe/disconnect, reset and message passing i2400m: host/device procotol and core driver definitions i2400m: documentation and instructions for usage wimax: Makefile, Kconfig and docbook linkage for the stack ...
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-07wimax/i2400m: add CREDITS and MAINTAINERS entriesInaky Perez-Gonzalez
This patch adds entries for the original developers of the i2400m drivers and up-to-date maintainer entries. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: musb: Add musb git tree to maintainers entryFelipe Balbi
Trivial patch adding musb's git tree to MAINTAINERS file. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06checkpatch: update MAINTAINERS entryAndy Whitcroft
Update my email address to my new work address. Also, as per our recent email conversation remove Randy and Joel from the maintainers list. Finally add LKML so that emails are recorded somewhere. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06Dmitry has been renamedDmitry Eremin-Solenikov
My surname has changed due to marriage. Change MAINTAINERS entry and add .mailmap entry to reflect that. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: Update MAINTAINERS entryJiri Kosina
I am taking over the trivial patch monkey tree from Jesper, as he doesn't have time for it any more. Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-05MAINTAINERS: squashfs entryPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-01-04MAINTAINERS: update sparc maintainerSam Ravnborg
Reflect the current situation where David Miller is the sparc maintainer. I have tried to contact Bill on following adresses: wli@holomorphy.com wlirwin@us.ibm.com with no success and Bill has not been active on the sparclinux mailing list for a long time. As sparc and sparc64 are unified I unified the two entries in the MAINTAINERS file too. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-02Merge branch 'kvm-updates/2.6.29' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates/2.6.29' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (140 commits) KVM: MMU: handle large host sptes on invlpg/resync KVM: Add locking to virtual i8259 interrupt controller KVM: MMU: Don't treat a global pte as such if cr4.pge is cleared MAINTAINERS: Maintainership changes for kvm/ia64 KVM: ia64: Fix kvm_arch_vcpu_ioctl_[gs]et_regs() KVM: x86: Rework user space NMI injection as KVM_CAP_USER_NMI KVM: VMX: Fix pending NMI-vs.-IRQ race for user space irqchip KVM: fix handling of ACK from shared guest IRQ KVM: MMU: check for present pdptr shadow page in walk_shadow KVM: Consolidate userspace memory capability reporting into common code KVM: Advertise the bug in memory region destruction as fixed KVM: use cpumask_var_t for cpus_hardware_enabled KVM: use modern cpumask primitives, no cpumask_t on stack KVM: Extract core of kvm_flush_remote_tlbs/kvm_reload_remote_mmus KVM: set owner of cpu and vm file operations anon_inodes: use fops->owner for module refcount x86: KVM guest: kvm_get_tsc_khz: return khz, not lpj KVM: MMU: prepopulate the shadow on invlpg KVM: MMU: skip global pgtables on sync due to cr3 switch KVM: MMU: collapse remote TLB flushes on root sync ...
2009-01-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (32 commits) ide-atapi: start dma in a drive-specific way ide-atapi: put the rest of non-ide-cd code into the else-clause of ide_transfer_pc ide-atapi: remove timeout arg to ide_issue_pc ide-cd: remove handler wrappers ide-cd: remove xferlen arg to cdrom_start_packet_command ide-atapi: split drive-specific functionality in ide_issue_pc ide-atapi: assign expiry and timeout based on device type ide-atapi: compute cmd_len based on device type in ide_transfer_pc ide: remove the last ide-scsi remnants ide-atapi: remove ide-scsi remnants from ide_pc_intr() ide-atapi: remove ide-scsi remnants from ide_transfer_pc() ide-atapi: remove ide-scsi remnants from ide_issue_pc ide-cd: move cdrom_timer_expiry to ide-atapi.c ide-atapi: teach ide atapi about drive->waiting_for_dma ide-atapi: accomodate transfer length calculation for ide-cd ide-atapi: setup dma for ide-cd ide-atapi: combine drive-specific assignments ide-atapi: add a dev_is_idecd-inline remove ide-scsi ide-floppy: allocate only toplevel packet commands ...
2009-01-02Update powerpc maintainersPaul Mackerras
Ben Herrenschmidt is taking over as the primary powerpc architecture maintainer. I'll still be around as his backup/deputy. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02hso maintainers update patchDenis Joseph Barrow
Added D.J. Barrow as maintainer of hso driver. Signed-off-by: Denis Joseph Barrow <D.Barow@option.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02remove ide-scsiFUJITA Tomonori
As planed, this removes ide-scsi. The 2.6 kernel supports direct writing to ide CD drives, which eliminates the need for ide-scsi. ide-scsi has been unmaintained and marked as deprecated. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James.Bottomley@HansenPartnership.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-31MAINTAINERS: Maintainership changes for kvm/ia64Xiantao Zhang
Anthony Xu no longer works on kvm. Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-25Merge branch 'topic/asoc' into to-pushTakashi Iwai
2008-12-24Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: V4L/DVB (9920): em28xx: fix NULL pointer dereference in call to VIDIOC_INT_RESET command V4L/DVB (9908a): MAINTAINERS: mark linux-uvc-devel as subscribers only V4L/DVB (9906): v4l2-compat: test for unlocked_ioctl as well. V4L/DVB (9885): drivers/media Kconfig's: fix bugzilla #12204 V4L/DVB (9875): gspca - main: Fix vidioc_s_jpegcomp locking. V4L/DVB (9781): [PATCH] Cablestar 2 I2C retries (fix CableStar2 support) V4L/DVB (9780): dib0700: Stop repeating after user stops pushing button
2008-12-22Update MAINTAINERS entries for IXP4xx and WAN network drivers.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2008-12-18Maintainer email fixes for inotifyJohn McCutchan
Update John McCutchan and Robert Love's email addresses for maintenance of inotify Signed-off-by: John McCutchan <john@johnmccutchan.com> Acked-by: Robert Love <rlove@rlove.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-17V4L/DVB (9908a): MAINTAINERS: mark linux-uvc-devel as subscribers onlyJiri Slaby
Posting to linux-uvc-devel is restricted to members. You can subscribe to the list at ... MAINTAINERS | 2 +- Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-16MAINTAINERS: Add myself as i.MX Framebuffer driver maintainerSascha Hauer
2008-12-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/ich8lan.c
2008-12-15eCryptfs: Update maintainersMichael Halcrow
Tyler Hicks and Dustin Kirkland are now the primary contact points for eCryptfs issues that may arise from this point forward. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Acked-by: Dustin Kirkland <kirkland@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-11smsc9420: SMSC LAN9420 10/100 PCI ethernet adapterSteve Glendinning
This patch adds a driver for the LAN9240 PCI ethernet adapter. Changes since initial submission: - debug msg_level has been changed to use standard definitions - convert to use net_device_ops Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03MAINTAINERS: Add security subsystem maintainerJames Morris
Add myself as overall maintainer of the security subsystem (generally, components under the top-level security directory). This addresses the lack of an official maintainer for the increasing number of security projects being incorporated into the kernel. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c drivers/net/smc91x.c
2008-12-02Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: UBIFS: pre-allocate bulk-read buffer UBIFS: do not allocate too much UBIFS: do not print scary memory allocation warnings UBIFS: allow for gaps when dirtying the LPT UBIFS: fix compilation warnings MAINTAINERS: change UBI/UBIFS git tree URLs UBIFS: endian handling fixes and annotations UBIFS: remove printk
2008-12-01Merge branch 'upstream' into topic/asocTakashi Iwai
2008-11-30MAINTAINERS: add netdev to ATMJiri Slaby
Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21Update of MAINTAINERS for RTL8187Larry Finger
As noted by John Linville, the RTL818X maintainers have "moved on", and the responsibilities for RTL8180 and RTL8187 have been split. This is the corresponding update of MAINTAINERS. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21MAINTAINERS: claim maintenance over rtl818x driversJohn W. Linville
Michael and Andrea have moved-on, so we shouldn't be bothering them about these drivers anymore. Actually, Herton Ronaldo Krzesinski, Hin-Tak Leung, and Larry Finger have been handling the rtl8187 stuff for a while. So, I would welcome a patch from one of them changing this to just RTL8180 and adding an RTL8187 entry with their names... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21ASoC: Add abbreviation to maintainers for searchabilityMark Brown
2008-11-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c include/net/mac80211.h net/phonet/af_phonet.c
2008-11-19MAINTAINERS: change email address for rostedtSteven Rostedt
I find that I answer my email quicker on my home email account, than I do on my work email. Not to mention that I never check my work email while traveling. Please change my email address in the MAINTAINERS file from srostedt@redhat.com to rostedt@goodmis.org. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-16MAINTAINERS: remove me as RAID maintainerIngo Molnar
Neil has been the maintainer of the RAID/MD code for a long time, remove me as a co-maintainer. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12LIS3LV02Dx Accelerometer driverPavel Machek
This adds a driver to the accelerometer sensor found in several HP laptops (under the commercial names of "HP Mobile Data Protection System 3D" and "HP 3D driveguard"). It tries to have more or less the same interfaces as the hdaps and other accelerometer drivers: in sysfs and as a joystick. This driver was first written by Yan Burman. Eric Piel has updated it and slimed it up (including the removal of an interface to access to the free-fall feature of the sensor because it is not reliable enough for now). Pavel Machek removed few more features and switched locking from semaphore to mutex. Several people have contributed to the database of the axes. [eric.piel@tremplin-utc.net: LIS3LV02D: Conform to the new ACPI API] Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (47 commits) ACPI: pci_link: remove acpi_irq_balance_set() interface fujitsu-laptop: Add DMI callback for Lifebook S6420 ACPI: EC: Don't do transaction from GPE handler in poll mode. ACPI: EC: lower interrupt storm treshold ACPICA: Use spinlock for acpi_{en|dis}able_gpe ACPI: EC: restart failed command ACPI: EC: wait for last write gpe ACPI: EC: make kernel messages more useful when GPE storm is detected ACPI: EC: revert msleep patch thinkpad_acpi: fingers off backlight if video.ko is serving this functionality sony-laptop: fingers off backlight if video.ko is serving this functionality msi-laptop: fingers off backlight if video.ko is serving this functionality fujitsu-laptop: fingers off backlight if video.ko is serving this functionality eeepc-laptop: fingers off backlight if video.ko is serving this functionality compal: fingers off backlight if video.ko is serving this functionality asus-acpi: fingers off backlight if video.ko is serving this functionality Acer-WMI: fingers off backlight if video.ko is serving this functionality ACPI video: if no ACPI backlight support, use vendor drivers ACPI: video: Ignore devices that aren't present in hardware Delete an unwanted return statement at evgpe.c ...
2008-11-11Merge branch 'misc' into releaseLen Brown
