path: root/MAINTAINERS
2013-08-11MAINTAINERS: fix up stable_kernel_rules.txt locationGreg Kroah-Hartman
There was a mismerge of 7b175c46720f8e6b92801bb634c93d1016f80c62 for the 3.0 kernel, so this fixes it up. Also mark the stable stuff "Supported", as it is. Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-13MAINTAINERS: add stable_kernel_rules.txt to stable maintainer informationGreg Kroah-Hartman
commit 7b175c46720f8e6b92801bb634c93d1016f80c62 upstream. This hopefully will help point developers to the proper way that patches should be submitted for inclusion in the stable kernel releases. Reported-by: David Howells <dhowells@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14MAINTAINERS: Stephen Hemminger email changeStephen Hemminger
[ Upstream commit adbbf69d1a54abf424e91875746a610dcc80017d ] I changed my email because the vyatta.com mail server is now redirected to brocade.com; and the Brocade mail system is not friendly to Linux desktop users. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15MAINTAINERS: Theodore Ts'o is taking over the random driverTheodore Ts'o
commit 330e0a01d54c2b8606c56816f99af6ebc58ec92c upstream. Matt Mackall stepped down as the /dev/random driver maintainer last year, so Theodore Ts'o is taking back the /dev/random driver. Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-12MAINTAINERS: stable: Update addressJoe Perches
commit bc7a2f3abc636d7cab84258a48e77b08fb5fd3d6 upstream. The old address hasn't worked since the great intrusion of August 2011. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11MAINTANERS: update Qualcomm Atheros addressesLuis R. Rodriguez
commit fe8e084455f273b32cc57a5fbaf6c22ef984d657 upstream. Qualcomm ate up Atheros, all of the old e-mail addresses no longer work and e-mails sent to it will bounce. Update the addresses to the new shiny Qualcomm Atheros (QCA) ones. Cc: stable@kernel.org Cc: netdev@vger.kernel.org Cc: jouni@qca.qualcomm.com Cc: yangjie@qca.qualcomm.com Cc: vthiagar@qca.qualcomm.com Cc: senthilb@qca.qualcomm.com Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-10Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6994/1: smp_twd: Fix typo in 'twd_timer_rate' printing ARM: 6987/1: l2x0: fix disabling function to avoid deadlock ARM: 6966/1: ep93xx: fix inverted RTS/DTR signals on uart1 ARM: 6980/1: mmci: use StartBitErr to detect bad connections ARM: 6979/1: mach-vt8500: add forgotten irq_data conversion ARM: move memory layout sanity checking before meminfo initialization ARM: 6990/1: MAINTAINERS: add entry for ARM PMU profiling and debugging ARM: 6989/1: perf: do not start the PMU when no events are present ARM: dmabounce: fix map_single() error return value
2011-07-08MAINTAINERS: update Bjorn Helgaas's email addressBjorn Helgaas
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-06MAINTAINERS: move kernel-doc patches locationRandy Dunlap
Move location of quilt series for kernel-doc patches. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-06Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (46 commits) [media] rc: call input_sync after scancode reports [media] imon: allow either proto on unknown 0xffdc [media] imon: auto-config ffdc 7e device [media] saa7134: fix raw IR timeout value [media] rc: fix ghost keypresses with certain hw [media] [staging] lirc_serial: allocate irq at init time [media] lirc_zilog: fix spinning rx thread [media] keymaps: fix table for pinnacle pctv hd devices [media] ite-cir: 8709 needs to use pnp resource 2 [media] V4L: mx1-camera: fix uninitialized variable [media] omap_vout: Added check in reqbuf & mmap for buf_size allocation [media] OMAP_VOUT: Change hardcoded device node number to -1 [media] OMAP_VOUTLIB: Fix wrong resizer calculation [media] uvcvideo: Disable the queue when failing to start [media] uvcvideo: Remove buffers from the queues when freeing [media] uvcvideo: Ignore entities for terminals with no supported format [media] v4l: Don't access media entity after is has been destroyed [media] media: omap3isp: fix a potential NULL deref [media] media: vb2: fix allocation failure check [media] media: vb2: reset queued_count value during queue reinitialization ... Fix up trivial conflict in MAINTAINERS as per Mauro
2011-07-05ARM: 6990/1: MAINTAINERS: add entry for ARM PMU profiling and debuggingWill Deacon
Following a request from Russell King: http://lists.infradead.org/pipermail/linux-arm-kernel/2011-June/055031.html Add myself as the ARM PMU profiling and debugging maintainer. This covers the ARM implementations of perf, oprofile and hw_breakpoint along with the glue for this to work on different platforms. Cc: Jean Pihet <j-pihet@ti.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits) usbnet: Remove over-broad module alias from zaurus. MAINTAINERS: drop Michael from bfin_mac driver net/can: activate bit-timing calculation and netlink based drivers by default rionet: fix NULL pointer dereference in rionet_remove net+crypto: Use vmalloc for zlib inflate buffers. netfilter: Fix ip_route_me_harder triggering ip_rt_bug ipv4: Fix IPsec slowpath fragmentation problem ipv4: Fix packet size calculation in __ip_append_data cxgb3: skb_record_rx_queue now records the queue index relative to the net_device. bridge: Only flood unregistered groups to routers qlge: Add maintainer. MAINTAINERS: mark socketcan-core lists as subscribers-only MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCED r8169: fix wrong register use. net/usb/kalmia: signedness bug in kalmia_bind() net/usb: kalmia: Various fixes for better support of non-x86 architectures. rtl8192cu: Fix missing firmware load udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packet ipv6/udp: Use the correct variable to determine non-blocking condition netconsole: fix build when CONFIG_NETCONSOLE_DYNAMIC is turned on ...
2011-06-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6: MAINTAINERS: update AVR32 and AT32AP maintainers
2011-06-30MAINTAINERS: update AVR32 and AT32AP maintainersHans-Christian Egtvedt
This alters the maintenance of the AVR32 architecture and the AT32AP machine code to be shared between Haavard Skinnemoen and me. The status is also changed to maintained, as we no longer are being paid to look after this architecture. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Haavard Skinnemoen <hskinnemoen@gmail.com>
2011-06-29MAINTAINERS: drop Michael from bfin_mac driverMike Frysinger
We want people to just use the list now rather than hitting up people who are no longer responsible for it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-28Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: MAINTAINERS: add myself as maintainer of USB/IP usb: r8a66597-hcd: fix cannot detect low/full speed device USB: ehci-ath79: fix a NULL pointer dereference USB: Add new FT232H chip to drivers/usb/serial/ftdi_sio.c usb/isp1760: Fix bug preventing the unlinking of control urbs USB: Fix up URB error codes to reflect implementation. xhci: Always set urb->status to zero for isoc endpoints. xhci: Add reset on resume quirk for asrock p67 host xHCI 1.0: Incompatible Device Error USB: don't let errors prevent system sleep USB: don't let the hub driver prevent system sleep USB: change maintainership of ohci-hcd and ehci-hcd xHCI 1.0: Force Stopped Event(FSE) xhci: Don't warn about zeroed bMaxBurst descriptor field. USB: Free bandwidth when usb_disable_device is called. xhci: Reject double add of active endpoints. USB: TI 3410/5052 USB Serial Driver: Fix mem leak when firmware is too big. usb: musb: gadget: clear TXPKTRDY flag when set FLUSHFIFO usb: musb: host: compare status for negative error values
2011-06-27MAINTAINERS: add myself as maintainer of USB/IPmatt mooney
Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-24qlge: Add maintainer.Ron Mercer
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-24MAINTAINERS: mark socketcan-core lists as subscribers-onlyMike Frysinger
The socketcan-core lists require subscription, so mark them as such. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-24MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCEDSven Eckelmann
I cannot speak on behalf of the batman-adv developers due to conflicts in the opinion about the ongoing development. The batman-adv module is still maintained by Marek Lindner and Simon Wunderlich. Those are the main persons behind the visions of batman-adv. Therefore, the state of module hasn't changed. Signed-off-by: Sven Eckelmann <sven@narfation.org> Cc: b.a.t.m.a.n@lists.open-mesh.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) pxa168_eth: fix race in transmit path. ipv4, ping: Remove duplicate icmp.h include netxen: fix race in skb->len access sgi-xp: fix a use after free hp100: fix an skb->len race netpoll: copy dev name of slaves to struct netpoll ipv4: fix multicast losses r8169: fix static initializers. inet_diag: fix inet_diag_bc_audit() gigaset: call module_put before restart of if_open() farsync: add module_put to error path in fst_open() net: rfs: enable RFS before first data packet is received fs_enet: fix freescale FCC ethernet dp buffer alignment netdev: bfin_mac: fix memory leak when freeing dma descriptors vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan support caif: Bugfix - XOFF removed channel from caif-mux tun: teach the tun/tap driver to support netpoll dp83640: drop PHY status frames in the driver. dp83640: fix phy status frame event parsing phylib: Allow BCM63XX PHY to be selected only on BCM63XX. ...
2011-06-18x86, MAINTAINERS: Add x86 MCE peopleIngo Molnar
Announce the new x86 MCE infrastructure maintainers. Acked-by: Borislav Petkov <bp@amd64.org> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-8hs7yob6wib4vblmrmbpbav4@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: Revert "HID: magicmouse: ignore 'ivalid report id' while switching modes" HID: hid-multitouch: fix broken eGalax HID: MAINTAINERS: Update USB HID/HIDBP DRIVERS pattern HID: hid-multitouch: add support for Chunghwa multi-touch panel HID: hiddev: fix use after free in hiddev_release HID: add quirk for HyperPen 10000U HID: hiddev: fix potential use-after-free
2011-06-16MAINTAINERS: Update EBTABLES mailing listJoe Perches
It moved to netfilter-devel@vger.kernel.org. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-15MAINTAINERS: add entry for legacy eeprom driverJean Delvare
I shall maintain the legacy eeprom driver, until we finally get rid of it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15MAINTAINERS: add videobuf2 maintainersPawel Osciak
Add maintainers for the videobuf2 V4L2 driver framework. Signed-off-by: Pawel Osciak <pawel@osciak.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15MAINTAINERS: Balbir has movedBalbir Singh
Update my email address. Email will start to the old address bouncing soon Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15USB: change maintainership of ohci-hcd and ehci-hcdAlan Stern
Following the loss of David Brownell, I volunteer to maintain the ohci-hcd and ehci-hcd drivers. This patch (as1472) makes it official. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-14Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Remove cpufreq_stats sysfs entries on module unload. MAINTAINERS: Update CPU FREQUENCY patterns
2011-06-12MAINTAINERS: Update CPU FREQUENCY patternsJoe Perches
Commit bb0a56ecc4ba ("[CPUFREQ] Move x86 drivers to drivers/cpufreq/") moved the files, remove the old pattern. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (55 commits) ISDN, hfcsusb: Don't leak in hfcsusb_ph_info() netpoll: call dev_put() on error in netpoll_setup() net: ep93xx_eth: fix DMA API violations net: ep93xx_eth: drop GFP_DMA from call to dma_alloc_coherent() net: ep93xx_eth: allocate buffers using kmalloc() net: ep93xx_eth: pass struct device to DMA API functions ep93xx: set DMA masks for the ep93xx_eth vlan: Fix the ingress VLAN_FLAG_REORDER_HDR check dl2k: EEPROM CRC calculation wrong endianess on bigendian machine NET: am79c961: fix assembler warnings NET: am79c961: ensure multicast filter is correctly set at open NET: am79c961: ensure asm() statements are marked volatile ethtool.h: fix typos ep93xx_eth: Update MAINTAINERS ipv4: Fix packet size calculation for raw IPsec packets in __ip_append_data netpoll: prevent netpoll setup on slave devices net: pmtu_expires fixes gianfar:localized filer table iwlegacy: fix channel switch locking mac80211: fix IBSS teardown race ...
2011-06-11[media] MAINTAINERS: Add videobuf2 maintainersMarek Szyprowski
Add maintainers for the videobuf2 V4L2 driver framework. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-06-09ep93xx_eth: Update MAINTAINERSH Hartley Sweeten
Lennert stated that he has been short on time lately. Since I'm maintaining the ep93xx core stuff, I'm willing to also take over maintaining the Ethernet driver. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09unicore32: move rtc-puv3.c to drivers/rtc directoryGuan Xuetao
The patch moves rtc driver for PKUnity-v3 SoC from arch/unicore32/kernel/ to drivers/rtc/, with renaming it to rtc-puv3.c. Also, Kconfig, Makefile, and MAINTAINERS are modified correspondingly. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-08MAINTAINERS: add a maintainer to Gadget FrameworkFelipe Balbi
I'll be continuing the amazing work Dave has done with the Gadget Framework. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07MAINTAINERS: Saying goodbye to David BrownellGrant Likely
We had to say goodbye when David passed away recently. David had a huge impact on our community, both personally in the lives of the people he worked with, and technically in the design and maintenance of several subsystems. He is greatly missed. He also leaves behind a number of much loved subsystems now orphaned. This patch updates the MAINTAINERS file for the areas that David was responsible for and adds an entry for him to the CREDITS file. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07HID: MAINTAINERS: Update USB HID/HIDBP DRIVERS patternJoe Perches
It was moved by commit 1a978c50c6cf ("HID: Move hiddev.txt to the new Documentation/hid directory") so update the MAINTAINERS pattern too. cc: Jiri Kosina <jkosina@suse.cz> cc: Alan Ott <alan@signal11.us> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-29Merge branch 'x86-platform-next' into x86-platformMatthew Garrett
2011-05-28Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (33 commits) x86: poll waiting for I/OAT DMA channel status maintainers: add dma engine tree details dmaengine: add TODO items for future work on dma drivers dmaengine: Add API documentation for slave dma usage dmaengine/dw_dmac: Update maintainer-ship dmaengine: move link order dmaengine/dw_dmac: implement pause and resume in dwc_control dmaengine/dw_dmac: Replace spin_lock* with irqsave variants and enable submission from callback dmaengine/dw_dmac: Divide one sg to many desc, if sg len is greater than DWC_MAX_COUNT dmaengine/dw_dmac: set residue as total len in dwc_tx_status if status is !DMA_SUCCESS dmaengine/dw_dmac: don't call callback routine in case dmaengine_terminate_all() is called dmaengine: at_hdmac: pause: no need to wait for FIFO empty pch_dma: modify pci device table definition pch_dma: Support new device ML7223 IOH pch_dma: Support I2S for ML7213 IOH pch_dma: Fix DMA setting issue pch_dma: modify for checkpatch pch_dma: fix dma direction issue for ML7213 IOH video-in dmaengine: at_hdmac: use descriptor chaining help function dmaengine: at_hdmac: implement pause and resume in atc_control ... Fix up trivial conflict in drivers/dma/dw_dmac.c
2011-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits) [SCSI] lpfc 8.3.24: Extend BSG infrastructure and add link diagnostics [SCSI] lpfc 8.3.24: Add resource extent support [SCSI] lpfc 8.3.24: Add request-firmware support [SCSI] lpfc 8.3.24: Add SR-IOV control [SCSI] lpfc 8.3.24: Extended hardware support and support dump images [SCSI] lpfc 8.3.24: Miscellaneous Fixes and Corrections [SCSI] libsas: Add option for SATA soft reset [SCSI] libsas: check dev->gone before submitting sata i/o [SCSI] libsas: fix/amend device gone notification in sas_deform_port() [SCSI] MAINTAINERS update for SCSI (new email address) [SCSI] Fix Ultrastor asm snippet [SCSI] osst: fix warning [SCSI] osst: wrong index used in inner loop [SCSI] aic94xx: world-writable sysfs update_bios file [SCSI] MAINTAINERS: Add drivers/target/ entry [SCSI] target: Convert TASK_ATTR to scsi_tcq.h definitions [SCSI] target: Convert REPORT_LUNs to use int_to_scsilun [SCSI] target: Fix task->task_execute_queue=1 clear bug + LUN_RESET OOPs [SCSI] target: Fix bug with task_sg chained transport_free_dev_tasks release [SCSI] target: Fix interrupt context bug with stats_lock and core_tmr_alloc_req ...
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: MAINTAINERS: Update eCryptfs mailing list eCryptfs: Allow 2 scatterlist entries for encrypted filenames eCryptfs: Clear i_nlink in rmdir
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits) ASoC: Fix power down for widgetless per-card DAPM context case ASoC: wm1250-ev1: Define "WM1250 Output" with SND_SOC_DAPM_OUTPUT ASoC: Remove duplicate linux/delay.h inclusion. ASoC: sam9g20_wm8731: use the proper SYSCKL value ASoC: wm8731: fix wm8731_check_osc() connected condition ALSA: hda - Reorganize controller quriks with bit flags ALSA: hda - Use snd_printd() in snd_hda_parse_pin_def_config() ALSA: core: remove unused variables. ALSA: HDA: Increase MAX_HDMI_PINS ALSA: PCM - Don't check DMA time-out too shortly MAINTAINERS: add FireWire audio maintainer ALSA: usb-audio: more control quirks for M-Audio FastTrack devices ALSA: usb-audio: add new quirk type QUIRK_AUDIO_STANDARD_MIXER ALSA: usb-audio: export snd_usb_feature_unit_ctl ALSA: usb-audio: rework add_control_to_empty() ALSA: usb-audio: move assignment of chip->ctrl_intf ALSA: hda - Use model=auto for Lenovo G555 ALSA: HDA: Unify HDMI hotplug handling. ALSA: hda - Force AD1988_6STACK_DIG for Asus M3N-HT Deluxe ASoC: core - remove superfluous new line. ...
2011-05-27MAINTAINERS: Update eCryptfs mailing listTyler Hicks
The eCryptfs mailing list has moved from lists.launchpad.net to vger.kernel.org. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-05-27acer-wmi: Update MAINTAINERSCarlos Corbacho
I don't have the time or much interest these days in maintaining acer-wmi, as I don't have access to newer Acer hardware. As he's been doing most of the work these days anyway, Joey Lee has kindly agreed to take over. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Joey Lee <jlee@novell.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-27wmi: Orphan ACPI-WMI driverCarlos Corbacho
I no longer have the time to work on this, and haven't really been doing any work to this either. Time to let someone else take the reins. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-27tc1100-wmi: Orphan driverCarlos Corbacho
I've never owned the hardware, this was a port of an existing driver to prove that the ACPI-WMI code was useful to more than just acer-wmi. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: update email address Squashfs: add extra sanity checks at mount time Squashfs: add sanity checks to fragment reading at mount time Squashfs: add sanity checks to lookup table reading at mount time Squashfs: add sanity checks to id reading at mount time Squashfs: add sanity checks to xattr reading at mount time Squashfs: reverse order of filesystem table reading Squashfs: move table allocation into squashfs_read_table()
2011-05-26MAINTAINERS: add mm/page_cgroup.c into memcg subsystemNamhyung Kim
AFAICS mm/page_cgroup.c is for memcg subsystem, but it was directed only to generic cgroup maintainers. Fix it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26maintainers: add dma engine tree detailsVinod Koul
Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
