Signed-off-by: Ley Foon Tan <lftan@altera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging drivers patches from Greg KH:
"Here's the big staging driver tree update for 3.20-rc1.
Lots of little things in here, adding up to lots of overall cleanups.
The IIO driver updates are also in here as they cross the staging tree
boundry a lot. I2O has moved into staging as well, as a plan to drop
it from the tree eventually as that's a dead subsystem.
All of this has been in linux-next with no reported issues for a
while"
* tag 'staging-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (740 commits)
staging: lustre: lustre: libcfs: define symbols as static
staging: rtl8712: Do coding style cleanup
staging: lustre: make obd_updatemax_lock static
staging: rtl8188eu: core: switch with redundant cases
staging: rtl8188eu: odm: conditional setting with no effect
staging: rtl8188eu: odm: condition with no effect
staging: ft1000: fix braces warning
staging: sm7xxfb: fix remaining CamelCase
staging: sm7xxfb: fix CamelCase
staging: rtl8723au: multiple condition with no effect - if identical to else
staging: sm7xxfb: make smtc_scr_info static
staging/lustre/mdc: Initialize req in mdc_enqueue for !it case
staging/lustre/clio: Do not allow group locks with gid 0
staging/lustre/llite: don't add to page cache upon failure
staging/lustre/llite: Add exception entry check after radix_tree
staging/lustre/libcfs: protect kkuc_groups from write access
staging/lustre/fld: refer to MDT0 for fld lookup in some cases
staging/lustre/llite: Solve a race to access lli_has_smd in read case
staging/lustre/ptlrpc: hold rq_lock when modify rq_flags
staging/lustre/lnet: portal spreading rotor should be unsigned
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char / misc patches from Greg KH:
"Here's the big char/misc driver update for 3.20-rc1.
Lots of little things in here, all described in the changelog.
Nothing major or unusual, except maybe the binder selinux stuff, which
was all acked by the proper selinux people and they thought it best to
come through this tree.
All of this has been in linux-next with no reported issues for a while"
* tag 'char-misc-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits)
coresight: fix function etm_writel_cp14() parameter order
coresight-etm: remove check for unknown Kconfig macro
coresight: fixing CPU hwid lookup in device tree
coresight: remove the unnecessary function coresight_is_bit_set()
coresight: fix the debug AMBA bus name
coresight: remove the extra spaces
coresight: fix the link between orphan connection and newly added device
coresight: remove the unnecessary replicator property
coresight: fix the replicator subtype value
pdfdocs: Fix 'make pdfdocs' failure for 'uio-howto.tmpl'
mcb: Fix error path of mcb_pci_probe
virtio/console: verify device has config space
ti-st: clean up data types (fix harmless memory corruption)
mei: me: release hw from reset only during the reset flow
mei: mask interrupt set bit on clean reset bit
extcon: max77693: Constify struct regmap_config
extcon: adc-jack: Release IIO channel on driver remove
extcon: Remove duplicated include from extcon-class.c
Drivers: hv: vmbus: hv_process_timer_expiration() can be static
Drivers: hv: vmbus: serialize Offer and Rescind offer
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg KH:
"Here's the big pull request for the USB driver tree for 3.20-rc1.
Nothing major happening here, just lots of gadget driver updates, new
device ids, and a bunch of cleanups.
All of these have been in linux-next for a while with no reported
issues"
* tag 'usb-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (299 commits)
usb: musb: fix device hotplug behind hub
usb: dwc2: Fix a bug in reading the endpoint directions from reg.
staging: emxx_udc: fix the build error
usb: Retry port status check on resume to work around RH bugs
Revert "usb: Reset USB-3 devices on USB-3 link bounce"
uhci-hub: use HUB_CHAR_*
usb: kconfig: replace PPC_OF with PPC
ehci-pci: disable for Intel MID platforms (update)
usb: gadget: Kconfig: use bool instead of boolean
usb: musb: blackfin: remove incorrect __exit_p()
USB: fix use-after-free bug in usb_hcd_unlink_urb()
usb: host: pci_quirks: joing string literals
USB: add flag for HCDs that can't receive wakeup requests (isp1760-hcd)
USB: usbfs: allow URBs to be reaped after disconnection
cdc-acm: kill unnecessary messages
cdc-acm: add sanity checks
usb: phy: phy-generic: Fix USB PHY gpio reset
usb: dwc2: fix USB core dependencies
usb: renesas_usbhs: fix NULL pointer dereference in dma_release_channel()
Pull UBI and UBIFS updates from Richard Weinberger:
- cleanups and bug fixes all over UBI and UBIFS
- block-mq support for UBI Block
- UBI volumes can now be renamed while they are in use
- security.* XATTR support for UBIFS
- a maintainer update
* 'for-linus-v3.20' of git://git.infradead.org/linux-ubifs:
UBI: block: Fix checking for NULL instead of IS_ERR()
UBI: block: Continue creating ubiblocks after an initialization error
UBIFS: return -EINVAL if log head is empty
UBI: Block: Explain usage of blk_rq_map_sg()
UBI: fix soft lockup in ubi_check_volume()
UBI: Fastmap: Care about the protection queue
UBIFS: add a couple of extra asserts
UBI: do propagate positive error codes up
UBI: clean-up printing helpers
UBI: extend UBI layer debug/messaging capabilities - cosmetics
UBIFS: add ubifs_err() to print error reason
UBIFS: Add security.* XATTR support for the UBIFS
UBIFS: Add xattr support for symlinks
UBI: Block: Add blk-mq support
UBI: Add initial support for scatter gather
UBI: rename_volumes: Use UBI_METAONLY
UBI: Implement UBI_METAONLY
Add myself as UBI co-maintainer
Pull crypto update from Herbert Xu:
"Here is the crypto update for 3.20:
- Added 192/256-bit key support to aesni GCM.
- Added MIPS OCTEON MD5 support.
- Fixed hwrng starvation and race conditions.
- Added note that memzero_explicit is not a subsitute for memset.
- Added user-space interface for crypto_rng.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits)
crypto: tcrypt - do not allocate iv on stack for aead speed tests
crypto: testmgr - limit IV copy length in aead tests
crypto: tcrypt - fix buflen reminder calculation
crypto: testmgr - mark rfc4106(gcm(aes)) as fips_allowed
crypto: caam - fix resource clean-up on error path for caam_jr_init
crypto: caam - pair irq map and dispose in the same function
crypto: ccp - terminate ccp_support array with empty element
crypto: caam - remove unused local variable
crypto: caam - remove dead code
crypto: caam - don't emit ICV check failures to dmesg
hwrng: virtio - drop extra empty line
crypto: replace scatterwalk_sg_next with sg_next
crypto: atmel - Free memory in error path
crypto: doc - remove colons in comments
crypto: seqiv - Ensure that IV size is at least 8 bytes
crypto: cts - Weed out non-CBC algorithms
MAINTAINERS: add linux-crypto to hw random
crypto: cts - Remove bogus use of seqiv
crypto: qat - don't need qat_auth_state struct
crypto: algif_rng - fix sparse non static symbol warning
Put it in the mvebu entry.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Arnaud Ebalard <arno@natisbad.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Boris BREZILLON <boris.brezillon@free-electrons.com>
Cc: Lior Amsalem <alior@marvell.com>
Cc: Tawfik Bayouk <tawfik@marvell.com>
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Pull arch/tile changes from Chris Metcalf:
"Not much in this batch, just some minor cleanups"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: change MAINTAINERS website from tilera.com to ezchip.com
tile: enable sparse checks for get/put_user
tile: fix put_user sparse errors
tile: default to little endian on older toolchains
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
The general documentation we have for pv_ops is currenty present
on the IA64 docs, but since this documentation covers IA64 xen
enablement and IA64 Xen support got ripped out a while ago
through commit d52eefb47 present since v3.14-rc1 lets just
simplify, generalize and move the pv_ops documentation to a
shared place.
Cc: Isaku Yamahata <yamahata@valinux.co.jp>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Alok Kataria <akataria@vmware.com>
Cc: virtualization@lists.linux-foundation.org
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: xen-devel@lists.xenproject.org
Cc: kvm@vger.kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Pull block driver changes from Jens Axboe:
"This contains:
- The 4k/partition fixes for brd from Boaz/Matthew.
- A few xen front/back block fixes from David Vrabel and Roger Pau
Monne.
- Floppy changes from Takashi, cleaning the device file creation.
- Switching libata to use the new blk-mq tagging policy, removing
code (and a suboptimal implementation) from libata. This will
throw you a merge conflict, since a bug in the original libata
tagging code was fixed since this code was branched. Trivial.
From Shaohua.
- Conversion of loop to blk-mq, from Ming Lei.
- Cleanup of the io_schedule() handling in bsg from Peter Zijlstra.
He claims it improves on unreadable code, which will cost him a
beer.
- Maintainer update or NDB, now handled by Markus Pargmann.
- NVMe:
- Optimization from me that avoids a kmalloc/kfree per IO for
smaller (<= 8KB) IO. This cuts about 1% of high IOPS CPU
overhead.
- Removal of (now) dead RCU code, a relic from before NVMe was
converted to blk-mq"
* 'for-3.20/drivers' of git://git.kernel.dk/linux-block:
xen-blkback: default to X86_32 ABI on x86
xen-blkfront: fix accounting of reqs when migrating
xen-blkback,xen-blkfront: add myself as maintainer
block: Simplify bsg complete all
floppy: Avoid manual call of device_create_file()
NVMe: avoid kmalloc/kfree for smaller IO
MAINTAINERS: Update NBD maintainer
libata: make sata_sil24 use fifo tag allocator
libata: move sas ata tag allocation to libata-scsi.c
libata: use blk taging
NVMe: within nvme_free_queues(), delete RCU sychro/deferred free
null_blk: suppress invalid partition info
brd: Request from fdisk 4k alignment
brd: Fix all partitions BUGs
axonram: Fix bug in direct_access
loop: add blk-mq.h include
block: loop: don't handle REQ_FUA explicitly
block: loop: introduce lo_discard() and lo_req_flush()
block: loop: say goodby to bio
block: loop: improve performance via blk-mq
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"This time with:
- Generic page-table framework for ARM IOMMUs using the LPAE
page-table format, ARM-SMMU and Renesas IPMMU make use of it
already.
- Break out the IO virtual address allocator from the Intel IOMMU so
that it can be used by other DMA-API implementations too. The
first user will be the ARM64 common DMA-API implementation for
IOMMUs
- Device tree support for Renesas IPMMU
- Various fixes and cleanups all over the place"
* tag 'iommu-updates-v3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (36 commits)
iommu/amd: Convert non-returned local variable to boolean when relevant
iommu: Update my email address
iommu/amd: Use wait_event in put_pasid_state_wait
iommu/amd: Fix amd_iommu_free_device()
iommu/arm-smmu: Avoid build warning
iommu/fsl: Various cleanups
iommu/fsl: Use %pa to print phys_addr_t
iommu/omap: Print phys_addr_t using %pa
iommu: Make more drivers depend on COMPILE_TEST
iommu/ipmmu-vmsa: Fix IOMMU lookup when multiple IOMMUs are registered
iommu: Disable on !MMU builds
iommu/fsl: Remove unused fsl_of_pamu_ids[]
iommu/fsl: Fix section mismatch
iommu/ipmmu-vmsa: Use the ARM LPAE page table allocator
iommu: Fix trace_map() to report original iova and original size
iommu/arm-smmu: add support for iova_to_phys through ATS1PR
iopoll: Introduce memory-mapped IO polling macros
iommu/arm-smmu: don't touch the secure STLBIALL register
iommu/arm-smmu: make use of generic LPAE allocator
iommu: io-pgtable-arm: add non-secure quirk
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"Highlights:
- Smack adds secmark support for Netfilter
- /proc/keys is now mandatory if CONFIG_KEYS=y
- TPM gets its own device class
- Added TPM 2.0 support
- Smack file hook rework (all Smack users should review this!)"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (64 commits)
cipso: don't use IPCB() to locate the CIPSO IP option
SELinux: fix error code in policydb_init()
selinux: add security in-core xattr support for pstore and debugfs
selinux: quiet the filesystem labeling behavior message
selinux: Remove unused function avc_sidcmp()
ima: /proc/keys is now mandatory
Smack: Repair netfilter dependency
X.509: silence asn1 compiler debug output
X.509: shut up about included cert for silent build
KEYS: Make /proc/keys unconditional if CONFIG_KEYS=y
MAINTAINERS: email update
tpm/tpm_tis: Add missing ifdef CONFIG_ACPI for pnp_acpi_device
smack: fix possible use after frees in task_security() callers
smack: Add missing logging in bidirectional UDS connect check
Smack: secmark support for netfilter
Smack: Rework file hooks
tpm: fix format string error in tpm-chip.c
char/tpm/tpm_crb: fix build error
smack: Fix a bidirectional UDS connect check typo
smack: introduce a special case for tmpfs in smack_d_instantiate()
Pull NFS client updates from Trond Myklebust:
"Highlights incluse:
Features:
- Removing the forced serialisation of open()/close() calls in
NFSv4.x (x>0) makes for a significant performance improvement in
metadata intensive workloads.
- Full support for the pNFS "flexible files" layout type
- Further RPC/RDMA client improvements from Chuck
Bugfixes:
- Stable fix: NFSv4.1 backchannel calls blocking operations with !TASK_RUNNING
- Stable fix: pnfs_generic_pg_init_read/write can be called with lseg == NULL
- Stable fix: Fix an Oopsable condition when nsm_mon_unmon is called
as part of the namespace cleanup,
- Stable fix: Ensure we reference the inode for return-on-close in
delegreturn
- Use SO_REUSEPORT to ensure that NFSv3 TCP connections can rebind to
the same source address/port combination during a disconnect/
reconnect event. This is a requirement imposed by most NFSv3
server duplicate reply cache implementations.
Optimisations:
- Ask for no NFSv4.1 delegations on OPEN if using O_DIRECT
Other:
- Add Anna Schumaker as co-maintainer for the NFS client"
* tag 'nfs-for-3.20-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (119 commits)
SUNRPC: Cleanup to remove xs_tcp_close()
pnfs: delete an unintended goto
pnfs/flexfiles: Do not dprintk after the free
SUNRPC: Fix stupid typo in xs_sock_set_reuseport
SUNRPC: Define xs_tcp_fin_timeout only if CONFIG_SUNRPC_DEBUG
SUNRPC: Handle connection reset more efficiently.
SUNRPC: Remove the redundant XPRT_CONNECTION_CLOSE flag
SUNRPC: Make xs_tcp_close() do a socket shutdown rather than a sock_release
SUNRPC: Ensure xs_tcp_shutdown() requests a full close of the connection
SUNRPC: Cleanup to remove remaining uses of XPRT_CONNECTION_ABORT
SUNRPC: Remove TCP socket linger code
SUNRPC: Remove TCP client connection reset hack
SUNRPC: TCP/UDP always close the old socket before reconnecting
SUNRPC: Add helpers to prevent socket create from racing
SUNRPC: Ensure xs_reset_transport() resets the close connection flags
SUNRPC: Do not clear the source port in xs_reset_transport
SUNRPC: Handle EADDRINUSE on connect
SUNRPC: Set SO_REUSEPORT socket option for TCP connections
NFSv4.1: Fix pnfs_put_lseg races
NFSv4.1: pnfs_send_layoutreturn should use GFP_NOFS
Pull documentation updates from Jonathan Corbet:
"Highlights this time around include:
- A thrashing of SubmittingPatches to bring it out of the "send
everything to Linus" era of kernel development.
- A new document on completions from Nicholas McGuire
- Lots of typo fixes, formatting improvements, corrections, build
fixes, and more"
* tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: (35 commits)
Documentation: Fix the wrong command `echo -1 > set_ftrace_pid` for cleaning the filter.
can-doc: Fixed a wrong filepath in can.txt
Documentation: Fix trivial typo in comment.
kgdb,docs: Fix typo and minor style issues
Documentation: add description for FTRACE probe status
doc: brief user documentation for completion
Documentation/misc-devices/mei: Fix indentation of embedded code.
Documentation/misc-devices/mei: Fix indentation of enumeration.
Documentation/misc-devices/mei: Fix spacing around parentheses.
Documentation/misc-devices/mei: Fix formatting of headings.
Documentation: devicetree: Fix double words in Doumentation/devicetree
Documentation: mm: Fix typo in vm.txt
lockstat: Add documentation on contention and contenting points
Documentation: fix blackfin gptimers-example build errors
Fixes column alignment in table of contents entry 1.9 in Documentation/filesystems/proc.txt
CodingStyle: enable emacs display of trailing whitespace
DocBook: Do not exceed argument list limit
gpio: board.txt: Fix the gpio name example
Documentation/SubmittingPatches: unify whitespace/tabs for the DCO
MAINTAINERS: Add the docs-next git tree to the maintainer entry
git://git.linaro.org/landing-teams/working/fujitsu/integration
Pull mailbox framework updates from Jassi Brar.
* 'mailbox-devel' of git://git.linaro.org/landing-teams/working/fujitsu/integration:
mailbox: Add Altera mailbox driver
mailbox: check for bit set before polling
Mailbox: Fix return value check in pcc_init()
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"The first round of updates for the input subsystem.
A few new drivers (power button handler for AXP20x PMIC, tps65218
power button driver, sun4i keys driver, regulator haptic driver, NI
Ettus Research USRP E3x0 button, Alwinner A10/A20 PS/2 controller).
Updates to Synaptics and ALPS touchpad drivers (with more to come
later), brand new Focaltech PS/2 support, update to Cypress driver to
handle Gen5 (in addition to Gen3) devices, and number of other fixups
to various drivers as well as input core"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (54 commits)
Input: elan_i2c - fix wrong %p extension
Input: evdev - do not queue SYN_DROPPED if queue is empty
Input: gscps2 - fix MODULE_DEVICE_TABLE invocation
Input: synaptics - use dmax in input_mt_assign_slots
Input: pxa27x_keypad - remove unnecessary ARM includes
Input: ti_am335x_tsc - replace delta filtering with median filtering
ARM: dts: AM335x: Make charge delay a DT parameter for TSC
Input: ti_am335x_tsc - read charge delay from DT
Input: ti_am335x_tsc - remove udelay in interrupt handler
Input: ti_am335x_tsc - interchange touchscreen and ADC steps
Input: MT - add support for balanced slot assignment
Input: drv2667 - remove wrong and unneeded drv2667-haptics modalias
Input: drv260x - remove wrong and unneeded drv260x-haptics modalias
Input: cap11xx - remove wrong and unneeded cap11xx modalias
Input: sun4i-ts - add support for touchpanel controller on A31
Input: serio - add support for Alwinner A10/A20 PS/2 controller
Input: gtco - use sign_extend32() for sign extension
Input: elan_i2c - verify firmware signature applying it
Input: elantech - remove stale comment from Kconfig
Input: cyapa - off by one in cyapa_update_fw_store()
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"In this batch, you can find lots of cleanups through the whole
subsystem, as our good New Year's resolution. Lots of LOCs and
commits are about LINE6 driver that was promoted finally from staging
tree, and as usual, there've been widely spread ASoC changes.
Here some highlights:
ALSA core changes
- Embedding struct device into ALSA core structures
- sequencer core cleanups / fixes
- PCM msbits constraints cleanups / fixes
- New SNDRV_PCM_TRIGGER_DRAIN command
- PCM kerneldoc fixes, header cleanups
- PCM code cleanups using more standard codes
- Control notification ID fixes
Driver cleanups
- Cleanups of PCI PM callbacks
- Timer helper usages cleanups
- Simplification (e.g. argument reduction) of many driver codes
HD-audio
- Hotkey and LED support on HP laptops with Realtek codecs
- Dock station support on HP laptops
- Toshiba Satellite S50D fixup
- Enhanced wallclock timestamp handling for HD-audio
- Componentization to simplify the linkage between i915 and hd-audio
drivers for Intel HDMI/DP
USB-audio
- Akai MPC Element support
- Enhanced timestamp handling
ASoC
- Lots of refactoringin ASoC core, moving drivers to more data driven
initialization and rationalizing a lot of DAPM usage
- Much improved handling of CDCLK clocks on Samsung I2S controllers
- Lots of driver specific cleanups and feature improvements
- CODEC support for TI PCM514x and TLV320AIC3104 devices
- Board support for Tegra systems with Realtek RT5677
- New driver for Maxim max98357a
- More enhancements / fixes for Intel SST driver
Others
- Promotion of LINE6 driver from staging along with lots of rewrites
and cleanups
- DT support for old non-ASoC atmel driver
- oxygen cleanups, XIO2001 init, Studio Evolution SE6x support
- Emu8000 DRAM size detection fix on ISA(!!) AWE64 boards
- A few more ak411x fixes for ice1724 boards"
* tag 'sound-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (542 commits)
ALSA: line6: toneport: Use explicit type for firmware version
ALSA: line6: Use explicit type for serial number
ALSA: line6: Return EIO if read/write not successful
ALSA: line6: Return error if device not responding
ALSA: line6: Add delay before reading status
ASoC: Intel: Clean data after SST fw fetch
ALSA: hda - Add docking station support for another HP machine
ALSA: control: fix failure to return new numerical ID in 'replace' event data
ALSA: usb: update trigger timestamp on first non-zero URB submitted
ALSA: hda: read trigger_timestamp immediately after starting DMA
ALSA: pcm: allow for trigger_tstamp snapshot in .trigger
ALSA: pcm: don't override timestamp unconditionally
ALSA: off by one bug in snd_riptide_joystick_probe()
ASoC: rt5670: Set use_single_rw flag for regmap
ASoC: rt286: Add rt288 codec support
ASoC: max98357a: Fix build in !CONFIG_OF case
ASoC: Intel: fix platform_no_drv_owner.cocci warnings
ARM: dts: Switch Odroid X2/U2 to simple-audio-card
ARM: dts: Exynos4 and Odroid X2/U3 sound device nodes update
ALSA: control: fix failure to return numerical ID in 'add' event
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Some documentation updates and a few new pixel formats
- Stop btcx-risc abuse by cx88 and move it to bt8xx driver
- New platform driver: am437x
- New webcam driver: toptek
- New remote controller hardware protocols added to img-ir driver
- Removal of a few very old drivers that relies on old kABIs and are
for very hard to find hardware: parallel port webcam drivers
(bw-qcam, c-cam, pms and w9966), tlg2300, Video In/Out for SGI (vino)
- Removal of the USB Telegent driver (tlg2300). The company that
developed this driver has long gone and the hardware is hard to find.
As it relies on a legacy set of kABI symbols and nobody seems to care
about it, remove it.
- several improvements at rtl2832 driver
- conversion on cx28521 and au0828 to use videobuf2 (VB2)
- several improvements, fixups and board additions
* tag 'media/v3.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (321 commits)
[media] dvb_net: Convert local hex dump to print_hex_dump_debug
[media] dvb_net: Use standard debugging facilities
[media] dvb_net: Use vsprintf %pM extension to print Ethernet addresses
[media] staging: lirc_serial: adjust boolean assignments
[media] stb0899: use sign_extend32() for sign extension
[media] si2168: add support for 1.7MHz bandwidth
[media] si2168: return error if set_frontend is called with invalid parameters
[media] lirc_dev: avoid potential null-dereference
[media] mn88472: simplify bandwidth registers setting code
[media] dvb: tc90522: re-add symbol-rate report
[media] lmedm04: add read snr, signal strength and ber call backs
[media] lmedm04: Create frontend call back for read status
[media] lmedm04: create frontend callbacks for signal/snr/ber/ucblocks
[media] lmedm04: Fix usb_submit_urb BOGUS urb xfer, pipe 1 != type 3 in interrupt urb
[media] lmedm04: Increase Interupt due time to 200 msec
[media] cx88-dvb: whitespace cleanup
[media] rtl28xxu: properly initialize pdata
[media] rtl2832: declare functions as static
[media] rtl2830: declare functions as static
[media] rtl2832_sdr: add kernel-doc comments for platform_data
Pull power supply and reset changes from Sebastian Reichel:
"New drivers:
- charger driver for Maxim 77693
- battery gauge driver for LTC 2941/2943
- battery gauge driver for RT5033
- reset driver for R-Mobile platforms
Convert drivers to restart handler framework:
- arm-versatile
- at91
- st-poweroff
Misc:
- remove deprecated sun6i reboot driver
- use alarmtimer instead of rtc in charger-manager
- misc fixes"
* tag 'for-v3.20' of git://git.infradead.org/battery-2.6: (48 commits)
power_supply: 88pm860x: Fix leaked power supply on probe fail
power/reset: restart-poweroff: Remove arm dependencies
power/reset: st-poweroff: Fix misleading Kconfig description
power/reset: st-poweroff: Register with kernel restart handler
power/reset: Remove sun6i reboot driver
power/reset: at91: Register with kernel restart handler
power/reset: arm-versatile: Register with kernel restart handler
power: test_power: Use enum as index for array of supplies
Add devicetree binding documentation for the LTC2941/LTC2943 driver
Add LTC2941/LTC2943 Battery Gauge Driver
power/reset: brcmstb: Add support for old 65nm chips
power/reset: brcmstb: Use the DT "compatible" string to indicate bit positions
power/reset: brcmstb: Make the driver buildable on MIPS
power: charger-manager: Use alarmtimer for battery monitoring in suspend.
power/reset: at91-poweroff: Fix error handling and other compiler warnings
bq27x00_battery: Call power_supply_changed only when capacity changed
bq27x00_battery: fix register offset for bq27425
power: max14577: Remove SYSFS dependency from Kconfig
power: bq24190_charger: suppress build warning
power: reset: Add reset driver for R-Mobile platforms
Pull networking updates from David Miller:
1) More iov_iter conversion work from Al Viro.
[ The "crypto: switch af_alg_make_sg() to iov_iter" commit was
wrong, and this pull actually adds an extra commit on top of the
branch I'm pulling to fix that up, so that the pre-merge state is
ok. - Linus ]
2) Various optimizations to the ipv4 forwarding information base trie
lookup implementation. From Alexander Duyck.
3) Remove sock_iocb altogether, from CHristoph Hellwig.
4) Allow congestion control algorithm selection via routing metrics.
From Daniel Borkmann.
5) Make ipv4 uncached route list per-cpu, from Eric Dumazet.
6) Handle rfs hash collisions more gracefully, also from Eric Dumazet.
7) Add xmit_more support to r8169, e1000, and e1000e drivers. From
Florian Westphal.
8) Transparent Ethernet Bridging support for GRO, from Jesse Gross.
9) Add BPF packet actions to packet scheduler, from Jiri Pirko.
10) Add support for uniqu flow IDs to openvswitch, from Joe Stringer.
11) New NetCP ethernet driver, from Muralidharan Karicheri and Wingman
Kwok.
12) More sanely handle out-of-window dupacks, which can result in
serious ACK storms. From Neal Cardwell.
13) Various rhashtable bug fixes and enhancements, from Herbert Xu,
Patrick McHardy, and Thomas Graf.
14) Support xmit_more in be2net, from Sathya Perla.
15) Group Policy extensions for vxlan, from Thomas Graf.
16) Remove Checksum Offload support for vxlan, from Tom Herbert.
17) Like ipv4, support lockless transmit over ipv6 UDP sockets. From
Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1494+1 commits)
crypto: fix af_alg_make_sg() conversion to iov_iter
ipv4: Namespecify TCP PMTU mechanism
i40e: Fix for stats init function call in Rx setup
tcp: don't include Fast Open option in SYN-ACK on pure SYN-data
openvswitch: Only set TUNNEL_VXLAN_OPT if VXLAN-GBP metadata is set
ipv6: Make __ipv6_select_ident static
ipv6: Fix fragment id assignment on LE arches.
bridge: Fix inability to add non-vlan fdb entry
net: Mellanox: Delete unnecessary checks before the function call "vunmap"
cxgb4: Add support in cxgb4 to get expansion rom version via ethtool
ethtool: rename reserved1 memeber in ethtool_drvinfo for expansion ROM version
net: dsa: Remove redundant phy_attach()
IB/mlx4: Reset flow support for IB kernel ULPs
IB/mlx4: Always use the correct port for mirrored multicast attachments
net/bonding: Fix potential bad memory access during bonding events
tipc: remove tipc_snprintf
tipc: nl compat add noop and remove legacy nl framework
tipc: convert legacy nl stats show to nl compat
tipc: convert legacy nl net id get to nl compat
tipc: convert legacy nl net id set to nl compat
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching
Pull live patching infrastructure from Jiri Kosina:
"Let me provide a bit of history first, before describing what is in
this pile.
Originally, there was kSplice as a standalone project that implemented
stop_machine()-based patching for the linux kernel. This project got
later acquired, and the current owner is providing live patching as a
proprietary service, without any intentions to have their
implementation merged.
Then, due to rising user/customer demand, both Red Hat and SUSE
started working on their own implementation (not knowing about each
other), and announced first versions roughly at the same time [1] [2].
The principle difference between the two solutions is how they are
making sure that the patching is performed in a consistent way when it
comes to different execution threads with respect to the semantic
nature of the change that is being introduced.
In a nutshell, kPatch is issuing stop_machine(), then looking at
stacks of all existing processess, and if it decides that the system
is in a state that can be patched safely, it proceeds insterting code
redirection machinery to the patched functions.
On the other hand, kGraft provides a per-thread consistency during one
single pass of a process through the kernel and performs a lazy
contignuous migration of threads from "unpatched" universe to the
"patched" one at safe checkpoints.
If interested in a more detailed discussion about the consistency
models and its possible combinations, please see the thread that
evolved around [3].
It pretty quickly became obvious to the interested parties that it's
absolutely impractical in this case to have several isolated solutions
for one task to co-exist in the kernel. During a dedicated Live
Kernel Patching track at LPC in Dusseldorf, all the interested parties
sat together and came up with a joint aproach that would work for both
distro vendors. Steven Rostedt took notes [4] from this meeting.
And the foundation for that aproach is what's present in this pull
request.
It provides a basic infrastructure for function "live patching" (i.e.
code redirection), including API for kernel modules containing the
actual patches, and API/ABI for userspace to be able to operate on the
patches (look up what patches are applied, enable/disable them, etc).
It's relatively simple and minimalistic, as it's making use of
existing kernel infrastructure (namely ftrace) as much as possible.
It's also self-contained, in a sense that it doesn't hook itself in
any other kernel subsystem (it doesn't even touch any other code).
It's now implemented for x86 only as a reference architecture, but
support for powerpc, s390 and arm is already in the works (adding
arch-specific support basically boils down to teaching ftrace about
regs-saving).
Once this common infrastructure gets merged, both Red Hat and SUSE
have agreed to immediately start porting their current solutions on
top of this, abandoning their out-of-tree code. The plan basically is
that each patch will be marked by flag(s) that would indicate which
consistency model it is willing to use (again, the details have been
sketched out already in the thread at [3]).
Before this happens, the current codebase can be used to patch a large
group of secruity/stability problems the patches for which are not too
complex (in a sense that they don't introduce non-trivial change of
function's return value semantics, they don't change layout of data
structures, etc) -- this corresponds to LEAVE_FUNCTION &&
SWITCH_FUNCTION semantics described at [3].
This tree has been in linux-next since December.
[1] https://lkml.org/lkml/2014/4/30/477
[2] https://lkml.org/lkml/2014/7/14/857
[3] https://lkml.org/lkml/2014/11/7/354
[4] http://linuxplumbersconf.org/2014/wp-content/uploads/2014/10/LPC2014_LivePatching.txt
[ The core code is introduced by the three commits authored by Seth
Jennings, which got a lot of changes incorporated during numerous
respins and reviews of the initial implementation. All the followup
commits have materialized only after public tree has been created,
so they were not folded into initial three commits so that the
public tree doesn't get rebased ]"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching:
livepatch: add missing newline to error message
livepatch: rename config to CONFIG_LIVEPATCH
livepatch: fix uninitialized return value
livepatch: support for repatching a function
livepatch: enforce patch stacking semantics
livepatch: change ARCH_HAVE_LIVE_PATCHING to HAVE_LIVE_PATCHING
livepatch: fix deferred module patching order
livepatch: handle ancient compilers with more grace
livepatch: kconfig: use bool instead of boolean
livepatch: samples: fix usage example comments
livepatch: MAINTAINERS: add git tree location
livepatch: use FTRACE_OPS_FL_IPMODIFY
livepatch: move x86 specific ftrace handler code to arch/x86
livepatch: samples: add sample live patching module
livepatch: kernel: add support for live patching
livepatch: kernel: add TAINT_LIVEPATCH
Pull ACPI and power management updates from Rafael Wysocki:
"We have a few new features this time, including a new SFI-based
cpufreq driver, a new devfreq driver for Tegra Activity Monitor, a new
devfreq class for providing its governors with raw utilization data
and a new ACPI driver for AMD SoCs.
Still, the majority of changes here are reworks of existing code to
make it more straightforward or to prepare it for implementing new
features on top of it. The primary example is the rework of ACPI
resources handling from Jiang Liu, Thomas Gleixner and Lv Zheng with
support for IOAPIC hotplug implemented on top of it, but there is
quite a number of changes of this kind in the cpufreq core, ACPICA,
ACPI EC driver, ACPI processor driver and the generic power domains
core code too.
The most active developer is Viresh Kumar with his cpufreq changes.
Specifics:
- Rework of the core ACPI resources parsing code to fix issues in it
and make using resource offsets more convenient and consolidation
of some resource-handing code in a couple of places that have grown
analagous data structures and code to cover the the same gap in the
core (Jiang Liu, Thomas Gleixner, Lv Zheng).
- ACPI-based IOAPIC hotplug support on top of the resources handling
rework (Jiang Liu, Yinghai Lu).
- ACPICA update to upstream release 20150204 including an interrupt
handling rework that allows drivers to install raw handlers for
ACPI GPEs which then become entirely responsible for the given GPE
and the ACPICA core code won't touch it (Lv Zheng, David E Box,
Octavian Purdila).
- ACPI EC driver rework to fix several concurrency issues and other
problems related to events handling on top of the ACPICA's new
support for raw GPE handlers (Lv Zheng).
- New ACPI driver for AMD SoCs analogous to the LPSS (Low-Power
Subsystem) driver for Intel chips (Ken Xue).
- Two minor fixes of the ACPI LPSS driver (Heikki Krogerus, Jarkko
Nikula).
- Two new blacklist entries for machines (Samsung 730U3E/740U3E and
510R) where the native backlight interface doesn't work correctly
while the ACPI one does (Hans de Goede).
- Rework of the ACPI processor driver's handling of idle states to
make the code more straightforward and less bloated overall (Rafael
J Wysocki).
- Assorted minor fixes related to ACPI and SFI (Andreas Ruprecht,
Andy Shevchenko, Hanjun Guo, Jan Beulich, Rafael J Wysocki, Yaowei
Bai).
- PCI core power management modification to avoid resuming (some)
runtime-suspended devices during system suspend if they are in the
right states already (Rafael J Wysocki).
- New SFI-based cpufreq driver for Intel platforms using SFI
(Srinidhi Kasagar).
- cpufreq core fixes, cleanups and simplifications (Viresh Kumar,
Doug Anderson, Wolfram Sang).
- SkyLake CPU support and other updates for the intel_pstate driver
(Kristen Carlson Accardi, Srinivas Pandruvada).
- cpufreq-dt driver cleanup (Markus Elfring).
- Init fix for the ARM big.LITTLE cpuidle driver (Sudeep Holla).
- Generic power domains core code fixes and cleanups (Ulf Hansson).
- Operating Performance Points (OPP) core code cleanups and kernel
documentation update (Nishanth Menon).
- New dabugfs interface to make the list of PM QoS constraints
available to user space (Nishanth Menon).
- New devfreq driver for Tegra Activity Monitor (Tomeu Vizoso).
- New devfreq class (devfreq_event) to provide raw utilization data
to devfreq governors (Chanwoo Choi).
- Assorted minor fixes and cleanups related to power management
(Andreas Ruprecht, Krzysztof Kozlowski, Rickard Strandqvist, Pavel
Machek, Todd E Brandt, Wonhong Kwon).
- turbostat updates (Len Brown) and cpupower Makefile improvement
(Sriram Raghunathan)"
* tag 'pm+acpi-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (151 commits)
tools/power turbostat: relax dependency on APERF_MSR
tools/power turbostat: relax dependency on invariant TSC
Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources
tools/power turbostat: decode MSR_*_PERF_LIMIT_REASONS
tools/power turbostat: relax dependency on root permission
ACPI / video: Add disable_native_backlight quirk for Samsung 510R
ACPI / PM: Remove unneeded nested #ifdef
USB / PM: Remove unneeded #ifdef and associated dead code
intel_pstate: provide option to only use intel_pstate with HWP
ACPI / EC: Add GPE reference counting debugging messages
ACPI / EC: Add query flushing support
ACPI / EC: Refine command storm prevention support
ACPI / EC: Add command flushing support.
ACPI / EC: Introduce STARTED/STOPPED flags to replace BLOCKED flag
ACPI: add AMD ACPI2Platform device support for x86 system
ACPI / table: remove duplicate NULL check for the handler of acpi_table_parse()
ACPI / EC: Update revision due to raw handler mode.
ACPI / EC: Reduce ec_poll() by referencing the last register access timestamp.
ACPI / EC: Fix several GPE handling issues by deploying ACPI_GPE_DISPATCH_RAW_HANDLER mode.
ACPICA: Events: Enable APIs to allow interrupt/polling adaptive request based GPE handling model
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Move domain assignment from arm64 to generic code (Lorenzo Pieralisi)
- ARM: Remove artificial dependency on pci_sys_data domain (Lorenzo Pieralisi)
- ARM: Move to generic PCI domains (Lorenzo Pieralisi)
- Generate uppercase hex for modalias var in uevent (Ricardo Ribalda Delgado)
- Add and use generic config accessors on ARM, PowerPC (Rob Herring)
Resource management
- Free resources on failure in of_pci_get_host_bridge_resources() (Lorenzo Pieralisi)
- Fix infinite loop with ROM image of size 0 (Michel Dänzer)
PCI device hotplug
- Handle surprise add even if surprise removal isn't supported (Bjorn Helgaas)
Virtualization
- Mark AMD/ATI VGA devices that don't reset on D3hot->D0 transition (Alex Williamson)
- Add DMA alias quirk for Adaptec 3405 (Alex Williamson)
- Add Wellsburg (X99) to Intel PCH root port ACS quirk (Alex Williamson)
- Add ACS quirk for Emulex NICs (Vasundhara Volam)
MSI
- Fail MSI-X mappings if there's no space assigned to MSI-X BAR (Yijing Wang)
Freescale Layerscape host bridge driver
- Fix platform_no_drv_owner.cocci warnings (Julia Lawall)
NVIDIA Tegra host bridge driver
- Remove unnecessary tegra_pcie_fixup_bridge() (Lucas Stach)
Renesas R-Car host bridge driver
- Fix error handling of irq_of_parse_and_map() (Dmitry Torokhov)
TI Keystone host bridge driver
- Fix misspelling of current function in debug output (Julia Lawall)
Xilinx AXI host bridge driver
- Fix harmless format string warning (Arnd Bergmann)
Miscellaneous
- Use standard parsing functions for ASPM sysfs setters (Chris J Arges)
- Add pci_device_to_OF_node() stub for !CONFIG_OF (Kevin Hao)
- Delete unnecessary NULL pointer checks (Markus Elfring)
- Add and use defines for PCIe Max_Read_Request_Size (Rafał Miłecki)
- Include clk.h instead of clk-private.h (Stephen Boyd)"
* tag 'pci-v3.20-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (48 commits)
PCI: Add pci_device_to_OF_node() stub for !CONFIG_OF
PCI: xilinx: Convert to use generic config accessors
PCI: xgene: Convert to use generic config accessors
PCI: tegra: Convert to use generic config accessors
PCI: rcar: Convert to use generic config accessors
PCI: generic: Convert to use generic config accessors
powerpc/powermac: Convert PCI to use generic config accessors
powerpc/fsl_pci: Convert PCI to use generic config accessors
ARM: ks8695: Convert PCI to use generic config accessors
ARM: sa1100: Convert PCI to use generic config accessors
ARM: integrator: Convert PCI to use generic config accessors
PCI: versatile: Add DT-based ARM Versatile PB PCIe host driver
ARM: dts: versatile: add PCI controller binding
of/pci: Free resources on failure in of_pci_get_host_bridge_resources()
PCI: versatile: Add DT docs for ARM Versatile PB PCIe driver
PCI: Fail MSI-X mappings if there's no space assigned to MSI-X BAR
r8169: use PCI define for Max_Read_Request_Size
[SCSI] esas2r: use PCI define for Max_Read_Request_Size
tile: use PCI define for Max_Read_Request_Size
rapidio/tsi721: use PCI define for Max_Read_Request_Size
Prepare first round of input updates for 3.20.
I've done quite a lot of work in blkfront/blkback, and I usually end up
looking at the patches, so add myself as maintainer together with Konrad.
Signed-off-by: Roger Pau Monné <roger.pau@citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
* acpi-doc:
MAINTAINERS / ACPI: add the necessary '/' according to entry rules
ACPI / Documentation: add a missing '='
* acpi-pm:
ACPI / sleep: mark acpi_sleep_dmi_check() __init
* acpi-pcc:
ACPI / PCC: Use pr_debug() for debug messages in pcc_init()
* acpi-tables:
Pull EDAC updates from Borislav Petkov:
- a new synopsys_edac.c driver for the Synopsys DDR controller, from
Punnaiah Choudary Kalluri.
- minor fixes/cleanups all around
- Mauro and I are adding the repo URLs to MAINTAINERS since people
asked for trees to base upcoming work on.
* tag 'edac_for_3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
EDAC: Add repo URLs to MAINTAINERS
EDAC, mv64x60_edac: Fix an error code in probe()
EDAC: edac_mc_sysfs: Make stuff static
EDAC: Fix the leak of mci->bus->name when bus_register fails
edac: i5100_edac: Remove unused i5100_recmema_dm_buf_id
EDAC, synps: Add EDAC support for zynq ddr ecc controller
mpc85xx_edac: Fix a typo in comments
EDAC, mce_amd_inj: Fix sparse non static symbol warning
... so that people can base new work ontop.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Pull sound fixes from Takashi Iwai:
"Hopefully the final pull request for 3.19: this ended up with a
slightly higher volume than wished, but I put them all as they are
either stable or 3.19 regression fixes.
Most of commits are from ASoC, and have been stewed for a while in
linux-next. The only change in the common code is the regression
fixes for ASoC AC97 stuff wrt device registrations. The rest are
device-specific, mostly small fixes in various ASoC drivers and ak411x
on ice1724 boards"
* tag 'sound-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: Intel: fix sst firmware path for cht-bsw-rt5672
ARM: dts: Fix I2S1, I2S2 compatible for exynos4 SoCs
ASoC: sgtl5000: add delay before first I2C access
MAINTAINERS: ASoC: add maintainer for Intel BDW/HSW ASoC driver
ASoC: atmel_ssc_dai: fix the setting for DSP mode
ASoC: sgtl5000: Use shift mask when setting codec mode
ASoC: tlv320aic3x: Fix data delay configuration
ALSA: ak411x: Fix stall in work callback
ASoC: Intel: Used lock version to update shim registers
ASoC: wm8731: init mutex in i2c init path
ASoC: atmel_ssc_dai: fix start event for I2S mode
ASoC: rt5640: Add RT5642 ACPI ID for Intel Baytrail
ASoC: wm97xx: Reset AC'97 device before registering it
ASoC: Add support for allocating AC'97 device before registering it
Acked-by: Vasu Dev <vasu.dev@intel.com>
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
The Altera mailbox allows for interprocessor communication. It supports
only one channel and work as either sender or receiver.
Add a maintainer entry for FREESCALE QUAD SPI driver and add myself as a
maintainer.
Signed-off-by: Han Xu <han.xu@freescale.com>
Acked-by: Huang Shijie <shijie.huang@intel.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
drivers/net/vxlan.c
drivers/vhost/net.c
include/linux/if_vlan.h
net/core/dev.c
The net/core/dev.c conflict was the overlap of one commit marking an
existing function static whilst another was adding a new function.
In the include/linux/if_vlan.h case, the type used for a local
variable was changed in 'net', whereas the function got rewritten
to fix a stacked vlan bug in 'net-next'.
In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next'
overlapped with an endainness fix for VHOST 1.0 in 'net'.
In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter
in 'net-next' whereas in 'net' there was a bug fix to pass in the
correct network namespace pointer in calls to this function.
The mentioned website only displays information about buying and selling
domains.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
'asoc/topic/xtfpga' into asoc-next
'asoc/fix/intel', 'asoc/fix/rt286', 'asoc/fix/rt5640', 'asoc/fix/sgtl5000', 'asoc/fix/sta32x', 'asoc/fix/tlv320aic3x' and 'asoc/fix/wm8731' into asoc-linus
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v3.20 merge window
Here's the big pull request for Gadgets and PHYs. It's
a total of 217 non-merge commits with pretty much everything
being touched.
The most important bits are a ton of new documentation for
almost all usb gadget functions, a new isp1760 UDC driver,
several improvements to the old net2280 UDC driver, and
some minor tracepoint improvements to dwc3.
Other than that, a big list of minor cleanups, smaller bugfixes
and new features all over the place.
Signed-off-by: Felipe Balbi <balbi@ti.com>
and 'core' into next
drivers/iommu/Kconfig
drivers/iommu/Makefile
Anna has essentially been performing the duties of co-maintainer for
the past several years. In recognition of those efforts, I'd like to
add her to the maintainers file.
Cc: Anna Schumaker <anna.schumaker@netapp.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
This is a follow up to the previously done changes in the layout of the driver
files. We now have an additional file include/linux/dma/dw.h which is missed in
the MAINTAINERS data base.
Fixes: 3d588f83e4d6 (dmaengine: dw: split dma-dw.h to platform and private parts)
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
We want those fixes in here for testing.
Add myself as the maintainer for the adv7180 video subdev driver.
Acked-by: Federico Vaga <federico.vaga@gmail.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Re-add Ismael Luceno as co-maintainer (with personal email address).
Signed-off-by: Ismael Luceno <ismael@iodev.co.uk>
Adding myself as the Intel BDW/HSW ASoC driver maintainer.
Signed-off-by: Jie Yang <yang.jie@intel.com>
Acked-by: Liam Girdwood <lgirdwood@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-testing
Jonathan writes:
Second round of IIO new drivers, functionality and cleanups for the 3.20 cycle.
New drivers and device support:
* Capella cm3232 ambient light sensor driver.
* Freescale MMA9553 pedometer and activity monitor. Note this involved a
refactor of the mma9551 driver to pull out shared elements.
* Samsung sensor hub (as used in the galaxy gear 2 watch) Core support
and initial drivers (gyro and accelerometer) more to follow.
An additional fix was applied on top of this for a build issue
thrown up by the autobuilders on some platforms.
* Cosmic Circuits 10001 ADC driver
* Qualcomm SPMI PMIC voltage ADC driver (current adc merged a while back).
* Add binding for AK8963 (in capitals) as unfortunately there are bios'
out there not using lower case.
New functionality
* Add newe operating mode to the core to allow for non triggered software
buffers. This is mostly semantics as previously drivers just claimed they
had a hardware buffer (when they didn't).
* Add distance channel type.
* Add energy channel type.
* Add velocity channel type and IIO_MOD_ROOT_SUM_SQUARED (i.e. speed when
our channel type is velocity).
* Add _debounce_count and _debounce_time filter attributes. Only really
make sense for counting types of measurements. First use is for avoiding
miss detection of steps prior to walking.
* Add change event type. This replaces the briefly present INSTANCE type
(which hadn't gained any users). It is more generic as it allows for
events say every 10 steps rather than every step.
* Add _calibweight attributes to the ABI (and core support). Used by
activity monitors to estimate energy use. Can imagine there will be
other uses for this one.
Driver new functionality
* mma9551 gains runtime pm support.
* hid-sensors gain PM support.
Cleanup
* Change calibheight unit to m from cm. As there are no prior users
and this was inconsistent with other distance units, it makes sense
to fix it before hte mma9553 driver which uses it.
* mpu6050 cleanups and devm_ use.
* as3935 switch over to PM ops.
* Fix a few format strings for signed vs unsigned.
* Fix tcs3414 missindentation
* Typo in industrialio-event
* Stop requiring IIO_TRIGGER for IIO_KFIFO_BUF as we have drivers that don't
need it. No one is quite sure why that dependency was there and it
seems to not matter.
Pull char/misc driver fixes from Greg KH:
"Here are two tiny patches, one fixing up the drivers/Kconfig file, and
one adding a MAINTAINERS entry for the UIO git tree"
* tag 'char-misc-3.19-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
drivers/Kconfig: remove duplicate entry for soc
MAINTAINERS: add git url entry for UIO
Pull staging tree fixes from Greg KH:
"Here are two tiny staging tree fixes. One for the nvec driver to
resolve a reported problem, and one to add a MAINTAINERS entry for the
Android drivers"
* tag 'staging-3.19-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
MAINTAINERS: add Android driver entries
staging: nvec: specify a platform-device base id
