path: root/MAINTAINERS
2007-08-31MAINTAINERS, order NETERION alphabeticallyJiri Slaby
MAINTAINERS, order NETERION alphabetically Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31MAINTAINERS: update DCO infoRandy Dunlap
Drop the URL for DCO (URL is invalid). Also, point to SubmittingPatches for the current DCO. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31Add MAINTAINERS entry for IOC3 serial driverRalf Baechle
The IOC3 is a multifunction device but not in sense of the PCI specification. Currently its ethernet and serial functionality are supported by two separate drivers authored and maintained by different people, so MAINTAINERS should reflect that. Cc: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-26[NET]: Mark Paul Moore as maintainer of labelled networking.James Morris
Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix bad error path in conversion routines 9p: remove deprecated v9fs_fid_lookup_remove() 9p: update maintainers and documentation 9p: fix use after free
2007-08-239p: update maintainers and documentationEric Van Hensbergen
Updates to the MAINTAINERS file and documentation for 9p to point to the swik wiki versus the outdated sf.net page. Also updated some email addresses and added pointers to papers which better describe the implementation and application of the Linux 9p client. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-08-22tpmdd maintainersKent Yoder
Fix up the maintainers info in the tpm drivers. Kylene will be out for some time, so copying the sourceforge list is the best way to get some attention. Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] Check return code on failed alloc [CIFS] Update CIFS project web site [CIFS] Fix hang in find_writable_file
2007-08-143c59x maintainerSteffen Klassert
Add 3c59x maintainer. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-13[CIFS] Update CIFS project web siteSteve French
Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-08-11Merge branch 'async-tx-fixes-for-linus' of ↵Linus Torvalds
git://lost.foo-projects.org/~dwillia2/git/iop * 'async-tx-fixes-for-linus' of git://lost.foo-projects.org/~dwillia2/git/iop: async_tx: update MAINTAINERS for async_tx and iop-adma
2007-08-11linux-audit list is subscribers-onlyGabriel C
Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09async_tx: update MAINTAINERS for async_tx and iop-admaDan Williams
Also, rename the dma engine entry since it is now a generic offload engine subsystem, not just memcpy. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
2007-08-02USB HID: update description of USBHID in MAINTAINERSJiri Kosina
Make it more clear to users what kinds of hardware USBHID handles, so that they can send reports and queries properly. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: (28 commits) [WATCHDOG] Fix pcwd_init_module crash [WATCHDOG] ICH9 support for iTCO_wdt [WATCHDOG] 631xESB/632xESB support for iTCO_wdt - add all LPC bridges [WATCHDOG] 631xESB/632xESB support for iTCO_wdt [WATCHDOG] omap_wdt.c - default error for IOCTL is -ENOTTY [WATCHDOG] Return value of nonseekable_open [WATCHDOG] mv64x60_wdt: Rework the timeout register manipulation [WATCHDOG] mv64x60_wdt: disable watchdog timer when driver is probed [WATCHDOG] mv64x60_wdt: Support the WDIOF_MAGICCLOSE feature [WATCHDOG] mv64x60_wdt: Add a module parameter to change nowayout setting [WATCHDOG] mv64x60_wdt: Add WDIOC_SETOPTIONS ioctl support [WATCHDOG] mv64x60_wdt: Support for WDIOC_SETTIMEOUT ioctl [WATCHDOG] mv64x60_wdt: Fix WDIOC_GETTIMEOUT return value [WATCHDOG] mv64x60_wdt: Check return value of nonseekable_open [WATCHDOG] mv64x60_wdt: Add arch/powerpc platform support [WATCHDOG] mv64x60_wdt: Get register address from platform data [WATCHDOG] mv64x60_wdt: set up platform_device in platform code [WATCHDOG] ensure mouse and keyboard ignored in w83627hf_wdt [WATCHDOG] s3c2410_wdt: fixup after arch include moves [WATCHDOG] git-watchdog-typo ...
2007-07-31Remove the arm26 portAdrian Bunk
The arm26 port has been in a state where it was far from even compiling for quite some time. Ian Molton agreed with the removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31Make Bruce Fields (co-)maintainer of kNFSDdNeil Brown
Make Bruce Fields (co-)maintainer of kNFSDd Signed-off-by: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-30tulip: Remove tulip maintainerValerie Henson
Remove Val Henson as tulip maintainer and let her roam free, FREE! Signed-off-by: Val Henson <val@nmt.edu> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-26Slab maintainer & Credits updateChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-23[WATCHDOG] Blackfin on-chip watchdog driverBryan Wu
This patch implements the driver necessary use the Analog Devices Blackfin processor's on-chip watchdog controller, supports BF53[123]/BF53[467]/BF54[2489]/BF561. Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-22Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (60 commits) [ARM] 4524/1: S3C: Move register out of include/asm-arm/arch-s3c2410 [ARM] 4523/1: S3C: Remove FIFO_MAX from uncompression headers [ARM] 4522/1: S3C: split include/asm-arm/arch/memory.h [ARM] 4521/2: S3C: Reorganise VA mapping headers [ARM] 4520/1: S3C: Remove old VA values from static map [ARM] 4519/1: S3C: split S3C2400 values out of S3C24XX map.h [ARM] 4518/1: S3C: Rename watchdog configuration options [ARM] 4517/1: S3C: Fix debug macros for ARM926 output [ARM] 4516/1: S3C: Fix uncompressor serial output for ARM926 [ARM] 4515/1: S3C: Move uncompress code to plat-s3c [ARM] 4514/1: S3C: Rename DEBUG_S3C2410_PORT and DEBUG_S3C_UART [ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT [ARM] 4512/1: S3C: rename the debug macros for per-cpu updates [ARM] 4511/1: S3C: updated LLSERIAL Kconfig defines for CPU support [ARM] 4510/1: S3C: split debug-macro support into plat-s3c [ARM] 4509/1: S3C: Create initial arch/arm/plat-s3c [ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3c [ARM] 4461/1: MXC platform and i.MX31ADS core support [ARM] 4507/1: pxa2xx clock_event_device [ARM] 4497/1: Only allow safe cache configurations on ARMv6 and later ...
2007-07-22Pull ec into release branchLen Brown
2007-07-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: sdhci: make sure to clear the error interrupt mmc: at91_mci: wakeup on card insertion (or removal) mmc: add maintainer for at91
2007-07-20mmc: add maintainer for at91Pierre Ossman
Nicolas Ferre has taken it upon himself to look after the AT91 MMC host driver. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-20[ARM] 4459/1: Changing email in MAINTAINERS fileKristoffer Ericson
Updating email adress in MAINTAINER file. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-19USB: MAINTAINERS entry for amd5536udcThomas Dahlmann
MAINTAINERS entry for amd5536udc driver. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19Merge branch 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6Linus Torvalds
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6: (44 commits) i2c: Delete the i2c-isa pseudo bus driver hwmon: refuse to load abituguru driver on non-Abit boards hwmon: fix Abit Uguru3 driver detection on some motherboards hwmon/w83627ehf: Be quiet when no chip is found hwmon/w83627ehf: No need to initialize fan_min hwmon/w83627ehf: Export the thermal sensor types hwmon/w83627ehf: Enable VBAT monitoring hwmon/w83627ehf: Add support for the VID inputs hwmon/w83627ehf: Fix timing issues hwmon/w83627ehf: Add error messages for two error cases hwmon/w83627ehf: Convert to a platform driver hwmon/w83627ehf: Update the Kconfig entry make coretemp_device_remove() static hwmon: Add LM93 support hwmon: Improve the pwmN_enable documentation hwmon/smsc47b397: Don't report missing fans as spinning at 82 RPM hwmon: Add support for newer uGuru's hwmon/f71805f: Add temperature-tracking fan control mode hwmon/w83627ehf: Preserve speed reading when changing fan min hwmon: fix detection of abituguru volt inputs ... Manual fixup of trivial conflict in MAINTAINERS file
2007-07-19hwmon/dme1737: Add documentationJuerg Haefliger
Add documentation for the new SMSC DME1737 driver. Signed-off-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-19hwmon: New maintainerMark M. Hoffman
Mark M. Hoffman is taking over for Jean Delvare as maintainer of the hwmon subsystem. He is also the author/maintainer for several existing drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-19drivers/edac: add to maintainers new infoDouglas Thompson
Update maintainer information on edac components Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: update MAINTAINERS files for EDACDouglas Thompson
Added new maintainers for the new EDAC drivers. Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19add POSIX clocks and timers maintainerIngo Molnar
Update the MAINTAINERS file: Thomas Gleixner has been the de-facto maintainer of POSIX timers and clocks for quite some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Suspend MAINTAINERS updatePavel Machek
I guess it is time to clarify that suspend and hibernation are separate things, and add Rafael as a maintainer. Plus, people blame us for suspend problems, anyway, I guess it is fair to mark us as suspend maintainers, too. Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18Blackfin ethernet driver: on chip ethernet MAC controller driverBryan Wu
This patch implements the driver necessary use the Analog Devices Blackfin processor's on-chip ethernet MAC controller. [try#2] - add timeout control - kill dma_config_reg bitfields - some trivial cleanup [try#3] - add endianess check - add DRV_NAME, DRV_VERSION... driver information string - add some comments for silicon anomaly and dma API confusion - some code trivial cleanup [try#4] - add Blackfin latest GPIO pin mux opertion with Michael Hennerich's help and Dan's review - rewrite the DMA descriptor list operation in a more readable way by Joe's review [try#5] - cleanup some coding style by Joe's review. [try#6] - 1.1 version fix a bug when set up multicast list pointed by Mr. yoshfuji - rearrange the desc_list_free function. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dan Williams <dcbw@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-18[x86 setup] MAINTAINERS: document x86 setup code git treeH. Peter Anvin
Document the existence of a published git tree for the x86 setup code. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-07-18Merge branch 'upstream' of git://git.infradead.org/~dedekind/ubi-2.6Linus Torvalds
* 'upstream' of git://git.infradead.org/~dedekind/ubi-2.6: (28 commits) UBI: fix compile warning UBI: fix error handling in erase worker UBI: fix comments UBI: remove unneeded error checks UBI: cleanup usage of try_module_get UBI: fix overflow bug UBI: bugfix in max_sqnum calculation UBI: bugfix in sqnum calculation UBI: fix signed-unsigned multiplication UBI: fix bug in atomic_leb_change() UBI: fix message UBI: fix debugging stuff UBI: bugfix in error path UBI: use is_power_of_2() UBI: fix freeing ubi->vtbl while unloading UBI: fix MAINTAINERS UBI: bugfix in ubi_leb_change() UBI: kill homegrown endian macros UBI: cleanup ioctl handling UBI: error path bugfix ...
2007-07-18zs: move to the serial subsystemMaciej W. Rozycki
This is a reimplementation of the zs driver for the serial subsystem. Any resemblance to the old driver is purely coincidential. ;-) I do hope I got the handling of modem lines right -- better do not tackle me about the issue unless you feel too good... Any users of the old driver: please note the numbers of the serial lines have now been swapped, i.e. ttyS0 <-> ttyS1 and ttyS2 <-> ttyS3. It has to do with the modem lines mentioned above; basically the port A in a given chip has to be initialised before the port B if you want to use the latter as the serial console (which is usually the case), as operations on modem lines of the serial line associated with the port B access both ports (see the comment at the top of the driver for the details of wiring used). Please update your scripts. This is also the reason each SCC now requests an IRQ once only (as seen in "/proc/interrupts") -- the handler takes care of both ports at once as the line associated with the port B has to take status update interrupts from both ports (and yet the line of the port A takes its own for itself too). The old driver never got it right... Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18UBI: fix MAINTAINERSArtem Bityutskiy
Fix UBI git tree URL. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2007-07-17bsg: mark FUJITA Tomonori as bsg maintainerJens Axboe
2007-07-16Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: splice: direct splicing updates ppos twice more ACSI removal umem: Fix match of pci_ids in umem driver umem: Remove references to dead CONFIG_MM_MAP_MEMORY variable remove the documentation for the legacy CDROM drivers
2007-07-16more scheduled OSS driver removalAdrian Bunk
This patch contains the scheduled removal of OSS drivers that: - have ALSA drivers for the same hardware without known regressions and - whose Kconfig options have been removed in 2.6.20. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16m32r: A MAINTAINERS entry for the M32R architectureHirokazu Takata
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Add entries to MAINTAINERS for I/OAT and DMAENGINENelson, Shannon
Add entries to MAINTAINERS for I/OAT and DMAENGINE Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Cc: Chris Leech <christopher.leech@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove the documentation for the legacy CDROM driversAdrian Bunk
This patch removes the documentation for the removed legacy CDROM drivers. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-15Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: git-battery vs git-acpi Power supply class and drivers: remove non obligatory return statements pda_power: clean up irq, timer MAINTAINERS: Add maintainers for power supply subsystem and drivers Fixed up trivial conflict in drivers/w1/slaves/w1_ds2760.c manually
2007-07-15MAINTAINERS: Add maintainers for power supply subsystem and driversAnton Vorontsov
Signed-off-by: Anton Vorontsov <cbou@mail.ru> Acked-by: David Woodhouse <dwmw2@infradead.org>
2007-07-14[NET]: Add macvlan driverPatrick McHardy
Add macvlan driver, which allows to create virtual ethernet devices based on MAC address. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (149 commits) USB: ohci-pnx4008: Remove unnecessary cast of return value of kzalloc USB: additions to the quirk list usb-storage: implement autosuspend USB: cdc-acm: add new device id to option driver USB: goku_udc trivial cleanups USB: usb gadget stack can now -DDEBUG with Kconfig usb gadget stack: remove usb_ep_*_buffer(), part 2 usb gadget stack: remove usb_ep_*_buffer(), part 1 USB: pxa2xx_udc -- cleanups, mostly removing dma hooks USB: pxa2xx_udc: use generic gpio layer USB: quirk for samsung printer USB: usb/dma doc updates USB: drivers/usb/storage/unusual_devs.h whitespace cleanup USB: remove Makefile reference to obsolete OHCI_AT91 USB: io_*: remove bogus termios no change checks USB: mos7720: remove bogus no termios change check USB: visor and whiteheat: remove bogus termios change checks USB: pl2303: remove bogus checks and fix speed support to use tty_get_baud_rate() USB: mos7840.c: turn this into a serial driver USB: make the usb_device numa_node get assigned from controller ...
2007-07-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (76 commits) IB: Update MAINTAINERS with Hal's new email address IB/mlx4: Implement query SRQ IB/mlx4: Implement query QP IB/cm: Send no match if a SIDR REQ does not match a listen IB/cm: Fix handling of duplicate SIDR REQs IB/cm: cm_msgs.h should include ib_cm.h IB/cm: Include HCA ACK delay in local ACK timeout IB/cm: Use spin_lock_irq() instead of spin_lock_irqsave() when possible IB/sa: Make sure SA queries use default P_Key IPoIB: Recycle loopback skbs instead of freeing and reallocating IB/mthca: Replace memset(<addr>, 0, PAGE_SIZE) with clear_page(<addr>) IPoIB/cm: Fix warning if IPV6 is not enabled IB/core: Take sizeof the correct pointer when calling kmalloc() IB/ehca: Improve latency by unlocking after triggering the hardware IB/ehca: Notify consumers of LID/PKEY/SM changes after nondisruptive events IB/ehca: Return QP pointer in poll_cq() IB/ehca: Change idr spinlocks into rwlocks IB/ehca: Refactor sync between completions and destroy_cq using atomic_t IB/ehca: Lock renaming, static initializers IB/ehca: Report RDMA atomic attributes in query_qp() ...
2007-07-12USB: Pete's taking over usblpPete Zaitcev
Vojtech agreed to pass usblp over to me, so if you find bugs don't bug him. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
