path: root/MAINTAINERS
2010-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits) ceph: update for write_inode API change ceph: reset osd after relevant messages timed out ceph: fix flush_dirty_caps race with caps migration ceph: include migrating caps in issued set ceph: fix osdmap decoding when pools include (removed) snaps ceph: return EBADF if waiting for caps on closed file ceph: set osd request message front length correctly ceph: reset front len on return to msgpool; BUG on mismatched front iov ceph: fix snaptrace decoding on cap migration between mds ceph: use single osd op reply msg ceph: reset bits on connection close ceph: remove bogus mds forward warning ceph: remove fragile __map_osds optimization ceph: fix connection fault STANDBY check ceph: invalidate_authorizer without con->mutex held ceph: don't clobber write return value when using O_SYNC ceph: fix client_request_forward decoding ceph: drop messages on unregistered mds sessions; cleanup ceph: fix comments, locking in destroy_inode ceph: move dereference after NULL test ... Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
2010-03-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sunxvr1000: Add missing FB=y depenency. MAINTAINERS: Add entry for sparc serial drivers. drivers/serial/sunsab.c: adjust the constant used to initialize the interrupt_mask0 fields
2010-03-16MAINTAINERS: Add entry for sparc serial drivers.David S. Miller
2010-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits) bridge: ensure to unlock in error path in br_multicast_query(). drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages sky2: Avoid rtnl_unlock without rtnl_lock ipv6: Send netlink notification when DAD fails drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant ipconfig: Handle devices which take some time to come up. mac80211: Fix memory leak in ieee80211_if_write() mac80211: Fix (dynamic) power save entry ipw2200: use kmalloc for large local variables ath5k: read eeprom IQ calibration values correctly for G mode ath5k: fix I/Q calibration (for real) ath5k: fix TSF reset ath5k: use fixed antenna for tx descriptors libipw: split ieee->networks into small pieces mac80211: Fix sta_mtx unlocking on insert STA failure path rt2x00: remove KSEG1ADDR define from rt2x00soc.h net: add ColdFire support to the smc91x driver asix: fix setting mac address for AX88772 ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}. net: Fix dev_mc_add() ...
2010-03-13Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Provide generic perf_sample_data initialization MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainer perf trace: Don't use pager if scripting perf trace/scripting: Remove extraneous header read perf, ARM: Modify kuser rmb() call to compile for Thumb-2 x86/stacktrace: Don't dereference bad frame pointers perf archive: Don't try to collect files without a build-id perf_events, x86: Fixup fixed counter constraints perf, x86: Restrict the ANY flag perf, x86: rename macro in ARCH_PERFMON_EVENTSEL_ENABLE perf, x86: add some IBS macros to perf_event.h perf, x86: make IBS macros available in perf_event.h hw-breakpoints: Remove stub unthrottle callback x86/hw-breakpoints: Remove the name field perf: Remove pointless breakpoint union perf lock: Drop the buffers multiplexing dependency perf lock: Fix and add misc documentally things percpu: Add __percpu sparse annotations to hw_breakpoint
2010-03-12Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (370 commits) ARM: S3C2443: Add set_rate and round_rate calls for armdiv clock ARM: S3C2443: Remove #if 0 for clk_mpll ARM: S3C2443: Update notes on MPLLREF clock ARM: S3C2443: Further clksrc-clk conversions ARM: S3C2443: Change to using plat-samsung clksrc-clk implementation USB: Fix s3c-hsotg build following Samsung platform header moves ARM: S3C64XX: Reintroduce unconditional build of audio device ARM: 5961/1: ux500: fix CLKRST addresses ARM: 5977/1: arm: Enable backtrace printing on oops when PC is corrupted ASoC: Fix S3C64xx IIS driver for Samsung header reorg ARM: S3C2440: Fix plat-s3c24xx move of s3c2440/s3c2442 support [ARM] pxa: fix typo in mxm8x10.h [ARM] pxa/raumfeld: set GPIO drive bits for LED pins [ARM] pxa/zeus: Add support for mcp2515 CAN bus [ARM] pxa/zeus: Add support for onboard max6369 watchdog [ARM] pxa/zeus: Add Eurotech as the manufacturer [ARM] pxa/zeus: Correct the USB host initialisation flags [ARM] pxa/zeus: Allow usage of 8250-compatible UART in uncompress [ARM] pxa: refactor uncompress.h for non-PXA uarts [ARM] mmp2: fix incorrect calling of chip->mask_ack() for 2nd level cascaded IRQs ...
2010-03-12memcg: update maintainer listKAMEZAWA Hiroyuki
Nishimura-san have been working for memcg very good. His review and tests give us much improvements and account migraiton which he is now challenging is really important. He is a stakeholder. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12intelfb: new maintainerMaik Broemme
It seems that Sylvain no longer maintain the intelfb driver. Two weeks ago I had a short mail conversation with Jean regarding who can replace him. Well I will do it, because I know the driver and use it very often. Attached is a patch which update the maintainer file to make bug reporting easier. Signed-off-by: Maik Broemme <mbroemme@plusserver.de> Sylvain Meyer <sylvain.meyer@worldonline.fr> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Dave Airlie <airlied@linux.ie> Cc: Eric Anholt <eric@anholt.net> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12MAINTAINERS: add bfin_sdh driverMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-09Merge commit 'v2.6.34-rc1' into perf/urgentIngo Molnar
Conflicts: tools/perf/util/probe-event.c Merge reason: Pick up -rc1 and resolve the conflict as well. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-09MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainerIngo Molnar
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-08MAINTAINERS: add netdev to CAN network layer and drivers entriesWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-08Merge branch 'origin' into devel-stableRussell King
Conflicts: arch/arm/mach-mx2/devices.c arch/arm/mach-mx2/devices.h sound/soc/pxa/pxa-ssp.c
2010-03-07MAINTAINER: Correct CAN Maintainer responsibilities and pathsOliver Hartkopp
Update the CAN Maintainer responsibilities and add source paths. Additional the SocketCAN core ML is not subscribers-only anymore. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Change magic number [LogFS] Remove h_version field [LogFS] Check feature flags [LogFS] Only write journal if dirty [LogFS] Fix bdev erases [LogFS] Silence gcc [LogFS] Prevent 64bit divisions in hash_index [LogFS] Plug memory leak on error paths [LogFS] Add MAINTAINERS entry [LogFS] add new flash file system Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in fs/logfs/inode.c introduced by write_inode() being changed to use writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d ("pass writeback_control to ->write_inode")
2010-03-06Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (23 commits) hwmon: Remove the deprecated adt7473 driver hwmon: Fix off-by-one kind values hwmon: (tmp421) Fix temperature conversions hwmon: (tmp421) Restore missing inputs hwmon: Driver for Andigilog aSC7621 family monitoring chips hwmon: (adt7411) Improve locking hwmon: Add driver for ADT7411 voltage and temperature sensor hwmon: (w83793) Add watchdog functionality hwmon: (g760a) Make rpm_from_cnt static hwmon: (it87) Validate auto pwm settings hwmon: (it87) Add support for old automatic fan speed control hwmon: (it87) Drop dead web links in documentation hwmon: (it87) Add an entry in MAINTAINERS hwmon: (it87) Use strict_strtol instead of simple_strtol hwmon: (it87) Fix many checkpatch errors and warnings hwmon: (it87) Add support for beep on alarm hwmon: (it87) Create vid attributes by group hwmon: (it87) Refactor attributes creation and removal hwmon: (it87) Expose the PWM/temperature mappings hwmon: (it87) Display fan outputs in automatic mode as such ...
2010-03-06MAINTAINERS: document and add "Q" patchwork queue entriesJoe Perches
Patchwork queues show the acceptance/rejection state of submitted patches for various MAINTAINER trees. Document their existence. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: WAVELAN moved to stagingJoe Perches
by commit 0234f84ebb00d36c48062befa5436eef36b71ccd Update patterns Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: STARMODE RADIO IP (STRIP) moved to stagingJoe Perches
by commit 955015bb0b42167d14f776ff5947ae2463a974dc Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: update PERFORMANCE EVENTS F: patternsJoe Perches
To match arch/*/kernel perf_event location changes Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: remove HAYES ESP SERIAL DRIVERJoe Perches
Commit f53a2ade0bb9f2a81f473e6469155172a96b7c38 ("tty: esp: remove broken driver") removed it Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: remove AMD GEODE F: arch/x86/kernel/geode_32.cJoe Perches
Commit c95d1e53ed89b75a4d7b68d1cbae4607b1479243 ("cs5535: drop the Geode-specific MFGPT/GPIO code") removed it. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-05hwmon: Driver for Andigilog aSC7621 family monitoring chipsGeorge Joseph
Hwmon driver for Andigilog aSC7621 family monitoring chips. Signed-off-by: George Joseph <george.joseph@fairview5.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (it87) Add an entry in MAINTAINERSJean Delvare
As I've just done a lot of changes to the it87 driver, I volunteer to maintain it for the year to come. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05Merge branch 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (145 commits) KVM: x86: Add KVM_CAP_X86_ROBUST_SINGLESTEP KVM: VMX: Update instruction length on intercepted BP KVM: Fix emulate_sys[call, enter, exit]()'s fault handling KVM: Fix segment descriptor loading KVM: Fix load_guest_segment_descriptor() to inject page fault KVM: x86 emulator: Forbid modifying CS segment register by mov instruction KVM: Convert kvm->requests_lock to raw_spinlock_t KVM: Convert i8254/i8259 locks to raw_spinlocks KVM: x86 emulator: disallow opcode 82 in 64-bit mode KVM: x86 emulator: code style cleanup KVM: Plan obsolescence of kernel allocated slots, paravirt mmu KVM: x86 emulator: Add LOCK prefix validity checking KVM: x86 emulator: Check CPL level during privilege instruction emulation KVM: x86 emulator: Fix popf emulation KVM: x86 emulator: Check IOPL level during io instruction emulation KVM: x86 emulator: fix memory access during x86 emulation KVM: x86 emulator: Add Virtual-8086 mode of emulation KVM: x86 emulator: Add group9 instruction decoding KVM: x86 emulator: Add group8 instruction decoding KVM: do not store wqh in irqfd ... Trivial conflicts in Documentation/feature-removal-schedule.txt
2010-03-04MAINTAINERS: Add netdev to bridge entry.David S. Miller
Noticed by Ingo Molnar. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-03Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (45 commits) compal-laptop: Make it depend on CONFIG_RFKILL classmate-laptop: Added some keys present in other devices MAINTAINERS: Add git tree to x86 Platform Drivers asus-acpi: remove duplicate comparison of asus_model strings toshiba-acpi: fix multimedia keys on some machines dell-laptop: Fix errors on failure and exit paths dell-laptop: Fix build error by making buffer_mutex static asus-laptop: fix style problems reported by checkpath.pl asus-laptop: use device_create_file() instead of platform_group asus-laptop: clean led code asus-laptop: add gps rfkill asus-laptop: set initial lcd state asus-laptop: leds, remove dead code and fix asus_led_exit()/asus_led_init() asus-laptop: add backlight changes notifications asus-laptop: add bluetooth keys found on M9V asus-laptop: switch to sparse keymap library asus-laptop: rename wireless_status to wlan_status to avoid confusion asus-laptop: add error check for write_acpi_int calls asus-laptop: stop using ASUS_HANDLE and use relative methods instead asus-laptop: rename function talking directly to acpi with asus_xxx scheme ...
2010-03-02Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/genesis-2.6 into ↵Russell King
devel-stable Conflicts: arch/arm/Kconfig
2010-03-02Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Russell King
devel-stable Conflicts: arch/arm/Makefile
2010-03-02MAINTAINERS: add maintainers for Marvell MMP2 (aka ARMADA610) supportEric Miao
Cc: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-03-01MAINTAINERS: Add git tree to x86 Platform DriversThadeu Lima de Souza Cascardo
Add the x86 platform driver git tree to MAINTAINERS. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
2010-03-01KVM: powerpc: Change maintainerAlexander Graf
Progress on KVM for Embedded PowerPC has stalled, but for Book3S there's quite a lot of work to do and going on. So in agreement with Hollis and Avi, we should switch maintainers for PowerPC. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hollis Blanchard <hollis@penguinppc.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/firmware/iscsi_ibft.c
2010-02-28Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits) rcu: Fix accelerated GPs for last non-dynticked CPU rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand boot rcu: Fix accelerated grace periods for last non-dynticked CPU rcu: Export rcu_scheduler_active rcu: Make rcu_read_lock_sched_held() take boot time into account rcu: Make lockdep_rcu_dereference() message less alarmist sched, cgroups: Fix module export rcu: Add RCU_CPU_STALL_VERBOSE to dump detailed per-task information rcu: Fix rcutorture mod_timer argument to delay one jiffy rcu: Fix deadlock in TREE_PREEMPT_RCU CPU stall detection rcu: Convert to raw_spinlocks rcu: Stop overflowing signed integers rcu: Use canonical URL for Mathieu's dissertation rcu: Accelerate grace period if last non-dynticked CPU rcu: Fix citation of Mathieu's dissertation rcu: Documentation update for CONFIG_PROVE_RCU security: Apply lockdep-based checking to rcu_dereference() uses idr: Apply lockdep-based diagnostics to rcu_dereference() uses radix-tree: Disable RCU lockdep checking in radix tree vfs: Abstract rcu_dereference_check for files-fdtable use ...
2010-02-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-02-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: toshiba_acpi: Add full hotkey support hp-wmi: Add support for tablet rotation key dell-laptop: Add another Dell laptop to the DMI whitelist classmate-laptop: use a single MODULE_DEVICE_TABLE to get correct aliases dell-laptop: Pay attention to which devices the hardware switch controls dell-laptop: Use buffer with 32-bit physical address dell-laptop: Blacklist machines not supporting dell-laptop dell-laptop: Block software state changes when rfkill hard blocked dell-laptop: Fix small memory leak dell-laptop: Fix platform device unregistration dell-laptop: Update rfkill state on kill switch compal-laptop: Replace sysfs support with rfkill support compal-laptop: Add support for known Compal made Dell laptops MAINTAINERS: update drivers/platform/x86 information
2010-02-26Merge branch 'ibft-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6 * 'ibft-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6: ibft: Update MAINTAINERS file. drivers/firmware/iscsi_ibft.c: remove NIPQUAD_FMT, use %pI4
2010-02-26Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (362 commits) V4L-DVB: cx88-dvb: remove extra attribution for core V4L/DVB: v4l: soc_camera: fix bound checking of mbus_fmt[] index V4L/DVB: Add support for SMT7020 to cx88 V4L/DVB: radio-si470x: Use UTF-8 encoding on a comment V4L/DVB: MAINTAINERS: Telegent tlg2300 section fix V4L/DVB: gspca_stv06xx: Add support for camera button V4L/DVB: gspca_ov519: add support for the button on ov511 based cams V4L/DVB: gspca_ov519: Add support for the button on ov518 based cams V4L/DVB: gspca_ov519: add support for the button on ov519 based cams V4L/DVB: gspca_main: Fix a compile error when CONFIG_INPUT is not set V4L/DVB: gspca_main: some input error handling fixes V4L/DVB: gspca_main: Allow use of input device creation code for non int. inputs V4L/DVB: gspca_pac7302: much improved exposure control V4L/DVB: gspca_sonixb: Make sonixb driver handle pas106 and pas202 cameras V4L/DVB: gspca_sonixb: pas106: fixup bright ctrl and add gain and exposure ctrls V4L/DVB: Documentation: gspca.txt: update known mr97310a cams V4L/DVB: gspca_mr97310a: add support for the Sakar 1638x CyberPix V4L/DVB: gscpa_sonixb: limit ov7630 max framerate at 640x480 V4L/DVB: gspca_sonixb: pas202: fixup brightness ctrl and add gain and exposure ctrls V4L/DVB: gscpa_sonixb: Differentiate between sensors with a coarse and fine expo ctrl ...
2010-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (158 commits) [SCSI] Fix printing of failed 32-byte commands [SCSI] Fix printing of variable length commands [SCSI] libsrp: fix bug in ADDITIONAL CDB LENGTH interpretation [SCSI] scsi_dh_alua: Add IBM Power Virtual SCSI ALUA device to dev list [SCSI] scsi_dh_alua: add netapp to dev list [SCSI] qla2xxx: Update version number to 8.03.02-k1. [SCSI] qla2xxx: EEH: Restore PCI saved state during pci slot reset. [SCSI] qla2xxx: Add firmware ETS burst support. [SCSI] qla2xxx: Correct loop-resync issues during SNS scans. [SCSI] qla2xxx: Correct use-after-free issue in terminate_rport_io callback. [SCSI] qla2xxx: Correct EH bus-reset handling. [SCSI] qla2xxx: Proper clean-up of BSG requests when request times out. [SCSI] qla2xxx: Initialize payload receive length in failure path of vendor commands [SCSI] fix duplicate removal on error path in scsi_sysfs_add_sdev [SCSI] fix refcounting bug in scsi_get_host_dev [SCSI] fix memory leak in scsi_report_lun_scan [SCSI] lpfc: correct PPC build failure [SCSI] raid_class: add raid1e [SCSI] mpt2sas: Do not call sas_is_tlr_enabled for RAID volumes. [SCSI] zfcp: Introduce header file for qdio structs and inline functions ...
2010-02-26MAINTAINERS: update mwl8k maintenance statusLennert Buytenhek
I am no longer with Marvell. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-26ibft: Update MAINTAINERS file.Konrad Rzeszutek Wilk
Provide the right e-mail and names for me and Peter. Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2010-02-26V4L/DVB: MAINTAINERS: Telegent tlg2300 section fixJoe Perches
linux-next commit 2ff8223957d901999bf76aaf2c6183e33a6ad14e exposes an infinite loop defect in scripts/get_maintainer.pl Fix the incorrect format of the MAINTAINERS "M:" entries. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: Add driver for Telegent tlg2300Huang Shijie
pd-common.h contains the common data structures, while vendorcmds.h contains the vendor commands for firmware. [mchehab@redhat.com: Folded the 10 patches with the driver] Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-25Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.h drivers/net/wireless/rt2x00/rt2800pci.c
2010-02-25MAINTAINERS: update drivers/platform/x86 informationMatthew Garrett
Many of the drivers/platform/x86 drivers have nothing to do with ACPI, so it's kind of inappropriate for them to be stuck under the ACPI mailing list. Add a new mailing list (platform-driver-x86@vger.kernel.org) and, with Len's blessing, add myself as subsystem maintainer. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Anisse Astier <anisse@astier.eu> Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Cezary Jackiewicz <cezary.jackiewicz@gmail.com> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Daniel Oliveira Nascimento <don@syst.com.br> Cc: Harald Welte <laforge@gnumonks.org> Cc: Henrique de Moraes Holschuh <ibm-acpi@hmh.eng.br> Cc: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Cc: Karol Kozimor <sziwan@users.sourceforge.net> Cc: Len Brown <lenb@kernel.org> Cc: Lennart Poettering <mzxreary@0pointer.de> Cc: Mattia Dongili <malattia@linux.it> Cc: Peter Feuerer <peter@piie.net> Cc: Sujith Thomas <sujith.thomas@intel.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
2010-02-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (44 commits) Add MAINTAINERS entry for virtio_console virtio: console: Fill ports' entire in_vq with buffers virtio: console: Error out if we can't allocate buffers for control queue virtio: console: Add ability to remove module virtio: console: Ensure no memleaks in case of unused buffers virtio: console: show error message if hvc_alloc fails for console ports virtio: console: Add debugfs files for each port to expose debug info virtio: console: Add ability to hot-unplug ports virtio: console: Handle port hot-plug virtio: console: Remove cached data on port close virtio: console: Register with sysfs and create a 'name' attribute for ports virtio: console: Ensure only one process can have a port open at a time virtio: console: Add file operations to ports for open/read/write/poll virtio: console: Associate each port with a char device virtio: console: Prepare for writing to userspace buffers virtio: console: Add a new MULTIPORT feature, support for generic ports virtio: console: Introduce a send_buf function for a common path for sending data to host virtio: console: Introduce function to hand off data from host to readers virtio: console: Separate out find_vqs operation into a different function virtio: console: Separate out console init into a new function ...
2010-02-25Merge commit 'v2.6.33' into core/rcuIngo Molnar
Merge reason: Update from -rc4 to -final. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-24Add MAINTAINERS entry for virtio_consoleAmit Shah
I'm taking ownership of the virtio_console module; but I'll continue feeding patches via Rusty. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: bug fix for vlan + gro issue tc35815: Remove a wrong netif_wake_queue() call which triggers BUG_ON cdc_ether: new PID for Ericsson C3607w to the whitelist (resubmit) IPv6: better document max_addresses parameter MAINTAINERS: update mv643xx_eth maintenance status e1000: Fix DMA mapping error handling on RX iwlwifi: sanity check before counting number of tfds can be free iwlwifi: error checking for number of tfds in queue iwlwifi: set HT flags after channel in rxon
