path: root/MAINTAINERS
2008-03-28kprobes: another MAINTAINERS updateAnanth N Mavinakayanahalli
Prasanna has taken a new job. Update the MAINTAINERS file Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-28afs: add a MAINTAINERS record for AFSDavid Howells
Add a MAINTAINERS record for AFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits) [IPSEC]: Fix BEET output [ICMP]: Dst entry leak in icmp_send host re-lookup code (v2). [AX25]: Remove obsolete references to BKL from TODO file. [NET]: Fix multicast device ioctl checks [IRDA]: Store irnet_socket termios properly. [UML]: uml-net: don't set IFF_ALLMULTI in set_multicast_list [VLAN]: Don't copy ALLMULTI/PROMISC flags from underlying device netxen, phy/marvell, skge: minor checkpatch fixes S2io: Handle TX completions on the same CPU as the sender for MIS-X interrupts b44: Truncate PHY address skge napi->poll() locking bug rndis_host: fix oops when query for OID_GEN_PHYSICAL_MEDIUM fails cxgb3: Fix lockdep problems with sge.reg_lock ehea: Fix IPv6 support dm9000: Support promisc and all-multi modes dm9601: configure MAC to drop invalid (crc/length) packets dm9601: add Hirose USB-100 device ID Marvell PHY m88e1111 driver fix netxen: fix rx dropped stats netxen: remove low level tx lock ...
2008-03-26kprobes: MAINTAINERS updateMasami Hiramatsu
Add Masami Hiramatsu to kprobes maintainers Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-24MAINTAINERS: update iwlwifi git urlReinette Chatre
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-21ocfs2: MAINTAINERS updateMark Fasheh
Change my e-mail address, add Joel as new co-maintainer. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-03-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (46 commits) [NET] ifb: set separate lockdep classes for queue locks [IPV6] KCONFIG: Fix description about IPV6_TUNNEL. [TCP]: Fix shrinking windows with window scaling netpoll: zap_completion_queue: adjust skb->users counter bridge: use time_before() in br_fdb_cleanup() [TG3]: Fix build warning on sparc32. MAINTAINERS: bluez-devel is subscribers-only audit: netlink socket can be auto-bound to pid other than current->pid (v2) [NET]: Fix permissions of /proc/net [SCTP]: Fix a race between module load and protosw access [NETFILTER]: ipt_recent: sanity check hit count [NETFILTER]: nf_conntrack_h323: logical-bitwise & confusion in process_setup() [RT2X00] drivers/net/wireless/rt2x00/rt2x00dev.c: remove dead code, fix warning [IPV4]: esp_output() misannotations [8021Q]: vlan_dev misannotations xfrm: ->eth_proto is __be16 [IPV4]: ipv4_is_lbcast() misannotations [SUNRPC]: net/* NULL noise [SCTP]: fix misannotated __sctp_rcv_asconf_lookup() [PKT_SCHED]: annotate cls_u32 ...
2008-03-20MAINTAINERS: bluez-devel is subscribers-onlyPavel Machek
Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-20[ARM] 4861/1: AT91: Update maintainer email address (again)Andrew Victor
Change email address of AT91 maintainer. This reverts the incorrect change in commit 6650e0a517bbfa1c47aa3da6b3562fcb1a066c63 Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-16Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: [PARISC] make ptr_to_pide() static [PARISC] head.S: section mismatch fixes [PARISC] add back Crestone Peak cpu [PARISC] futex: special case cmpxchg NULL in kernel space [PARISC] clean up show_stack [PARISC] add pa8900 CPUs to hardware inventory [PARISC] clean up include/asm-parisc/elf.h [PARISC] move defconfig to arch/parisc/configs/ [PARISC] add back AD1889 MAINTAINERS entry [PARISC] pdc_console: fix bizarre panic on boot [PARISC] dump_stack in show_regs [PARISC] pdc_stable: fix compile errors [PARISC] remove unused pdc_iodc_printf function [PARISC] bump __NR_syscalls [PARISC] unbreak pgalloc.h [PARISC] move VMALLOC_* definitions to fixmap.h [PARISC] wire up timerfd syscalls [PARISC] remove old timerfd syscall
2008-03-15[PARISC] add back AD1889 MAINTAINERS entryThibaut VARENE
Signed-off-by: Thibaut VARENE <T-Bone@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-03-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) [SCTP]: Fix local_addr deletions during list traversals. net: fix build with CONFIG_NET=n [TCP]: Prevent sending past receiver window with TSO (at last skb) rt2x00: Add new D-Link USB ID rt2x00: never disable multicast because it disables broadcast too libertas: fix the 'compare command with itself' properly drivers/net/Kconfig: fix whitespace for GELIC_WIRELESS entry [NETFILTER]: nf_queue: don't return error when unregistering a non-existant handler [NETFILTER]: nfnetlink_queue: fix EPERM when binding/unbinding and instance 0 exists [NETFILTER]: nfnetlink_log: fix EPERM when binding/unbinding and instance 0 exists [NETFILTER]: nf_conntrack: replace horrible hack with ksize() [NETFILTER]: nf_conntrack: add \n to "expectation table full" message [NETFILTER]: xt_time: fix failure to match on Sundays [NETFILTER]: nfnetlink_log: fix computation of netlink skb size [NETFILTER]: nfnetlink_queue: fix computation of allocated size for netlink skb. [NETFILTER]: nfnetlink: fix ifdef in nfnetlink_compat.h [NET]: include <linux/types.h> into linux/ethtool.h for __u* typedef [NET]: Make /proc/net a symlink on /proc/self/net (v3) RxRPC: fix rxrpc_recvmsg()'s returning of msg_name net/enc28j60: oops fix ...
2008-03-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/iwcm: Don't access a cm_id after dropping reference IB/iser: Handle iser_device allocation error gracefully IB/iser: Fix list iteration bug RDMA/cxgb3: Fix iwch_create_cq() off-by-one error RDMA/cxgb3: Return correct max_inline_data when creating a QP IB/fmr_pool: Flush all dirty FMRs from ib_fmr_pool_flush() Revert "IB/fmr_pool: ib_fmr_pool_flush() should flush all dirty FMRs" IB/cm: Flush workqueue when removing device MAINTAINERS: update ipath owner
2008-03-05Intel ethernet adapter: Update MAINTAINERSAuke Kok
Another team member unfortunately left: update MAINTAINERS. Condense the 3 lists down to a single list for all our drivers. Point to our new sourceforge index page which is slightly better navigateable than the sf.net project page. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-04Add memory resource controller maintainersakpm@linux-foundation.org
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Control Groups: add Paul Menage as maintainerPaul Menage
Control Groups: Add Paul Menage as maintainer Signed-off-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04dmaengine: add driver for Freescale MPC85xx DMA controllerZhang Wei
The driver implements DMA engine API for Freescale MPC85xx DMA controller, which could be used by devices in the silicon. The driver supports the Basic mode of Freescale MPC85xx DMA controller. The MPC85xx processors supported include MPC8540/60, MPC8555, MPC8548, MPC8641 and so on. The MPC83xx(MPC8349, MPC8360) are also supported. [kamalesh@linux.vnet.ibm.com: build fix] [dan.j.williams@intel.com: merge mm fixes, rebase on async_tx-2.6.25] Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com> Acked-by: Kumar Gala <galak@gate.crashing.org> Cc: Shannon Nelson <shannon.nelson@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-02-29MAINTAINERS: update ipath ownerArthur Jones
I'll be leaving QLogic soon for another job and Ralph has graciously offered to take over the IPath driver maintainership. Signed-off-by: Arthur Jones <arthur.jones@qlogic.com> Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: (35 commits) Blackfin Serial Driver: Fix bug - Only insert UART rx char in timer task. Blackfin Serial Driver: Fix bug - update tx dma buffer tail before wake up processes. Blackfin Serial Driver: Fix bug - Increase buffer tail immediately before starting tx dma. [Blackfin] serial driver: Add flow control support to bf54x [Blackfin] serial driver: Fix bug Poll RTS/CTS status in DMA mode as well [Blackfin] serial driver: ADSP-BF52x arch/mach support [Blackfin] serial driver: use simpler comment headers and strip out information that is maintained in the scm's log [Blackfin] serial driver: rework break flood anomaly handling to be more robust/realistic about what we can actually work around [Blackfin] serial driver: fix bug - cache the bits of the LSR on systems where the LSR is read-to-clear [Blackfin] serial driver: fix bug - should not wait for the TFI bit, just clear it when tx stop. [Blackfin] serial driver: Fix bug serial driver in DMA mode spams history to console on shell restart [Blackfin] serial driver: Fix bug Free rx dma buffer in shutdown. [Blackfin] serial driver: Clean up UART DMA code. Blackfin Serial driver: Fix bug - serial driver in PIO mode cant handle input very quickly [Blackfin] arch: kill section mismatch warnings [Blackfin] arch: handle the most common L1 shrinkage case (L1 does not exist for a part) so that any parts labeled for L1 instead get placed into external memory sections [Blackfin] arch: add bfin_clear_PPIx_STATUS() helper funcs like we have for other parts [Blackfin] arch: make sure we have proper description/copyright/license lines [Blackfin] arch: Fix CONFIG_PM support for BF561 [Blackfin] arch: Remove DPMC char driver option ...
2008-02-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (79 commits) [X25]: Use proc_create() to setup ->proc_fops first [WANROUTER]: Use proc_create() to setup ->proc_fops first [8021Q]: Use proc_create() to setup ->proc_fops first [IPV4]: Use proc_create() to setup ->proc_fops first [IPV6]: Use proc_create() to setup ->proc_fops first [SCTP]: Use proc_create() to setup ->proc_fops first [PKTGEN]: Use proc_create() to setup ->proc_fops first [NEIGHBOUR]: Use proc_create() to setup ->proc_fops first [LLC]: Use proc_create() to setup ->proc_fops first [IPX]: Use proc_create() to setup ->proc_fops first [SUNRPC]: Use proc_create() to setup ->proc_fops first [ATM]: Use proc_create() to setup ->proc_fops first [SCTP]: Update AUTH structures to match declarations in draft-16. [SCTP]: Incorrect length was used in SCTP_*_AUTH_CHUNKS socket option [SCTP]: Clean up naming conventions of sctp protocol/address family registration [APPLETALK]: Use proc_create() to setup ->proc_fops first [BNX2X]: add bnx2x to MAINTAINERS [BNX2X]: update version, remove CVS strings [BNX2X]: Fix Xmit bugs [BNX2X]: Prevent PCI queue overflow ...
2008-02-28[BNX2X]: add bnx2x to MAINTAINERSEliezer Tamir
Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-26MAINTAINERS: neteffect updateRoland Dreier
Adding Nishi to the maintainers list. Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-23update TULIP MAINTAINERSGrant Grundler
Kyle and I are co-maintaining tulip driver. Normally kyle will review my patchs and submit them. I'll deal with bugzilla.kernel.org bugs and try to resolve those bugs. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-23hwrng: remove Michael as HWRNG maintainerMichael Buesch
It turns out that I rewrote the HWRNG core once to make it pluggable, but I'm not a crypto-expert at all. So I'm certainly the wrong person for being a maintainer of the HWRNG core. Let's orphan it. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23MAINTAINERS: linux-fbdev is moderatedGeert Uytterhoeven
While linux-fbdev is subscribers-only, non-subscribers are not plainly rejected, but moderated, so the casual patch/comment/question comes through. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-21MAINTAINERS: ioatdma, dmaengine and async_tx maintainers changeMaciej Sosnowski
Shannon Nelson replaced by Maciej Sosnowski in maintanance of INTEL I/OAT DMA DRIVER, DMA GENERIC ENGINE SUBSYSTEM and ASYNCHRONOUS TRANSFERS/TRANSFORMS API. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-21Merge branch 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6Linus Torvalds
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6: hwmon: normal_i2c arrays should be const hwmon: New driver for Analog Devices ADT7473 sensor chip hwmon: (coretemp) Add Penryn CPU to coretemp hwmon: (coretemp) Add TjMax detection for mobile CPUs hwmon: (applesmc) sensors set for MacBook2 hwmon: (thmc50) Storage class should be before const qualifier hwmon: (coretemp) fix section mismatch warning hwmon: (coretemp) Add maximum cooling temperature readout hwmon: (adm1026) Properly terminate sysfs groups hwmon: (vt8231) Update maintainer email address hwmon: (vt8231) Add individual alarm files hwmon: (via686a) Add individual alarm files hwmon: (smsc47m1) Add individual alarm files hwmon: (max1619) Add individual alarm and fault files hwmon: (lm92) Add individual alarm files
2008-02-21dlm: update git tree in MAINTAINERSDavid Teigland
Signed-off-by: David Teigland <teigland@redhat.com>
2008-02-19MAINTAINERS: update ide-cd maintainer's email addressBorislav Petkov
Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-17hwmon: (vt8231) Update maintainer email addressRoger Lucas
Signed-off-by: Roger Lucas <vt8231@hiddenengine.co.uk> (modified MAINTAINERS entry also - MMH) Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-14MAINTAINERS: update decnet and DLM entriesChristine Caulfield
Change my name & email in MAINTAINERS Signed-off-by: Christine Caulfield <christine.caulfield@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14MAINTAINERS: add linux-fsdevel to VFS entryPaul Menage
Add linux-fsdevel to the VFS entry in MAINTAINERS Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11Add Matt to MAINTAINERS as a SLAB allocator maintainerPekka Enberg
Matt is already the maintainer of SLOB which is one of the "SLAB" allocators in the kernel so add him to MAINTAINERS. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: mmc: extend ricoh_mmc to support Ricoh RL5c476 at91_mci: use generic GPIO calls sdhci: add num index for multi controllers case MAINTAINERS: remove non-existant URLs mmc: remove sdhci and mmc_spi experimental markers mmc: Handle suspend/resume in Ricoh MMC disabler
2008-02-09memstick: initial commit for Sony MemoryStick supportAlex Dubov
Sony MemoryStick cards are used in many products manufactured by Sony. They are available both as storage and as IO expansion cards. Currently, only MemoryStick Pro storage cards are supported via TI FlashMedia MemoryStick interface. [mboton@gmail.com: biuld fix] [akpm@linux-foundation.org: build fix] Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Miguel Boton <mboton@gmail.co> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Merge branch 'cris' of git://www.jni.nu/crisLinus Torvalds
* 'cris' of git://www.jni.nu/cris: (158 commits) CRIS v32: Remove hwregs/timer_defs.h, it is now architecture specific. CRIS v32: Change drivers/i2c.c locking. CRIS v32: Rewrite ARTPEC-3 gpio driver to avoid volatiles and general cleanup. CRIS: Add new timerfd syscall entries. MAINTAINERS: Add my information for the CRIS port. CRIS v32: Correct spelling of bandwidth in function name. CRIS v32: Clean up nandflash.c for ARTPEC-3 and ETRAX FS. CRIS v10: Cleanup of drivers/gpio.c CRIS v10: drivers/net/cris/eth_v10.c rename LED defines to CRIS_LED to avoid name clash. CRIS: Make io_pwm_set_period members unsigned in etraxgpio.h CRIS: Move ETRAX_AXISFLASHMAP to common Kconfig file. CRIS: Drop regs parameter from call to profile_tick in kernel/time.c CRIS v32: Fix minor formatting issue in mach-a3/io.c CRIS v32: Initialize GIO even if we're rambooting in kernel/head.S CRIS v32: Remove kernel/arbiter.c, it now exists in machine dependent directory. CRIS v32: Minor changes to avoid errors in asm-cris/arch-v32/hwregs/reg_rdwr.h CRIS v32: arch-v32/hwregs/intr_vect_defs.h moved to machine dependent directory. CRIS v32: Correct offset for TASK_pid in asm-cris/arch-v32/offset.h CRIS v32: Move register map header to machine dependent directory. CRIS v32: Let compiler know that memory is clobbered after a break op. ...
2008-02-08MAINTAINERS: add Haavard as maintainer of the atmel_serial driverHaavard Skinnemoen
The following patchset cleans up the atmel_serial driver a bit, moves a significant portion of the interrupt handler into a tasklet, and adds DMA support. This is the result of a combined effort by Chip Coldwell, Remy Bohmer and me. The patches should apply cleanly onto Linus' latest git tree, and I've also tested it on -mm (with a couple of avr32 fixes applied to make the rest of the tree compile.) With DMA, I see transfer rates around 92 kbps when transferring a big file using ZModem (both directions are roughly the same.) I've also tested the same thing with a bunch of debug options enabled. The transfer rate is slightly lower, but no errors are reported. Note that break and error handling doesn't work too well with DMA enabled. This is a common problem with all the efforts I've seen adding DMA support to this driver (including my own). The PDC error handling also accesses icount without locking. I'm tempted to just ignore the problem for now and hopefully come up with a solution later. This patch: The atmel_serial driver never had a MAINTAINERS entry, although Andrew Victor has effectively been acting as a maintainer since he got the driver merged into mainline in the first place. I'll keep Cc'ing Andrew on all patches, but I'm going to take the main responsibility for getting things moving upstream from now on. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: change maintainerJan Kara
I've tried to contact Ben Fennema a few times but without success. Since I'm currently probably closest to being an UDF maintainer, I guess it's fine to also change the entry in MAINTAINERS. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <bfennema@falcon.csc.calpoly.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08rewrite rdNick Piggin
This is a rewrite of the ramdisk block device driver. The old one is really difficult because it effectively implements a block device which serves data out of its own buffer cache. It relies on the dirty bit being set, to pin its backing store in cache, however there are non trivial paths which can clear the dirty bit (eg. try_to_free_buffers()), which had recently lead to data corruption. And in general it is completely wrong for a block device driver to do this. The new one is more like a regular block device driver. It has no idea about vm/vfs stuff. It's backing store is similar to the buffer cache (a simple radix-tree of pages), but it doesn't know anything about page cache (the pages in the radix tree are not pagecache pages). There is one slight downside -- direct block device access and filesystem metadata access goes through an extra copy and gets stored in RAM twice. However, this downside is only slight, because the real buffercache of the device is now reclaimable (because we're not playing crazy games with it), so under memory intensive situations, footprint should effectively be the same -- maybe even a slight advantage to the new driver because it can also reclaim buffer heads. The fact that it now goes through all the regular vm/fs paths makes it much more useful for testing, too. text data bss dec hex filename 2837 849 384 4070 fe6 drivers/block/rd.o 3528 371 12 3911 f47 drivers/block/brd.o Text is larger, but data and bss are smaller, making total size smaller. A few other nice things about it: - Similar structure and layout to the new loop device handlinag. - Dynamic ramdisk creation. - Runtime flexible buffer head size (because it is no longer part of the ramdisk code). - Boot / load time flexible ramdisk size, which could easily be extended to a per-ramdisk runtime changeable size (eg. with an ioctl). - Can use highmem for the backing store. [akpm@linux-foundation.org: fix build] [byron.bbradley@gmail.com: make rd_size non-static] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Byron Bradley <byron.bbradley@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08MAINTAINERS: Add my information for the CRIS port.Jesper Nilsson
2008-02-08MAINTAINERS: remove non-existant URLsPierre Ossman
Remove references to web pages that are no longer up and running. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-02-07ipwireless: driver for PC Card 3G/UMTS modemDavid Sterba
The device is manufactured by IPWireless. In some countries (for example Czech Republic, T-Mobile ISP) this card is shipped for service called UMTS 4G. It's a piece of PCMCIA "4G" UMTS PPP networking hardware that presents itself as a serial character device (i.e. looks like usual modem to userspace, accepts AT commands, etc). Rewieved-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Ben Martel <benm@symmetric.co.nz> Signed-off-by: Stephen Blackheath <stephen@symmetric.co.nz> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (112 commits) ACPI: fix build warning Revert "cpuidle: build fix for non-x86" ACPI: update intrd DSDT override console messages ACPI: update DSDT override documentation ACPI: Add "acpi_no_initrd_override" kernel parameter ACPI: its a directory not a folder.... ACPI: misc cleanups ACPI: add missing prink prefix strings ACPI: cleanup acpi.h ACPICA: fix CONFIG_ACPI_DEBUG_FUNC_TRACE build ACPI: video: Ignore ACPI video devices that aren't present in hardware ACPI: video: reset brightness on resume ACPI: video: call ACPI notifier chain for ACPI video notifications ACPI: create notifier chain to get hotkey events to graphics driver ACPI: video: delete unused display switch on hotkey event code ACPI: video: create "brightness_switch_enabled" modparam cpuidle: Add a poll_idle method ACPI: cpuidle: Support C1 idle time accounting ACPI: enable MWAIT for C1 idle ACPI: idle: Fix acpi_safe_halt usages and interrupt enabling/disabling ...
2008-02-07MAINTAINERS: add self for the dz serial driverMaciej W. Rozycki
Now that I have got the necessary piece of hardware (thanks, Thiemo!), I may well offer myself as the maintainer for the dz serial driver. I hope nobody objects. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branches 'release' and 'wmi-2.6.25' into releaseLen Brown
2008-02-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: fix deadlock, make pgd_lock irq-safe virtio: fix trivial build bug x86: fix mttr trimming x86: delay CPA self-test and repeat it x86: fix 64-bit sections generic: add __FINITDATA x86: remove suprious ifdefs from pageattr.c x86: mark the .rodata section also NX x86: fix iret exception recovery on 64-bit cpuidle: dubious one-bit signed bitfield in cpuidle.h x86: fix sparse warnings in powernow-k8.c x86: fix sparse error in traps_32.c x86: trivial sparse/checkpatch in quirks.c x86 ptrace: disallow null cs/ss MAINTAINERS: RDC R-321x SoC maintainer brk randomization: introduce CONFIG_COMPAT_BRK brk: check the lower bound properly x86: remove X2 workaround x86: make spurious fault handler aware of large mappings x86: make traps on entry code be debuggable in user space, 64-bit
2008-02-06MAINTAINERS: RDC R-321x SoC maintainerFlorian Fainelli
Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06Claim maintainership for block2mtd and update email addressesJoern Engel
I have been prime author and maintainer of block2mtd from day one, but neither MAINTAINERS nor the module source makes this fact clear. And while I'm at it, update my email addresses tree-wide, as the old address currently bounces and change my name to "joern" as unicode will likely continue to cause trouble until the end of this century. Signed-off-by: Joern Engel <joern@lazybastard.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06MAINTAINERS, order AUERSWALD alphabeticallyJiri Slaby
MAINTAINERS, order AUERSWALD alphabetically Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Wolfgang Muees <wolfgang@iksw-muees.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
