path: root/MAINTAINERS
2012-04-11hwlatdetect.patchCarsten Emde
Jon Masters developed this wonderful SMI detector. For details please consult Documentation/hwlat_detector.txt. It could be ported to Linux 3.0 RT without any major change. Signed-off-by: Carsten Emde <C.Emde@osadl.org>
2012-04-06Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & Power Management patches from Len Brown: "Two fixes for cpuidle merge-window changes, plus a URL fix in MAINTAINERS" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: MAINTAINERS: Update git url for ACPI cpuidle: Fix panic in CPU off-lining with no idle driver ACPI processor: Use safe_halt() rather than halt() in acpi_idle_play_dead()
2012-04-06MAINTAINERS: Update git url for ACPIIgor Murzov
Signed-off-by: Igor Murzov <e-mail@date.by> Signed-off-by: Len Brown <len.brown@intel.com>
2012-04-06Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull arch/tile bug fixes from Chris Metcalf: "This includes Paul Gortmaker's change to fix the <asm/system.h> disintegration issues on tile, a fix to unbreak the tilepro ethernet driver, and a backlog of bugfix-only changes from internal Tilera development over the last few months. They have all been to LKML and on linux-next for the last few days. The EDAC change to MAINTAINERS is an oddity but discussion on the linux-edac list suggested I ask you to pull that change through my tree since they don't have a tree to pull edac changes from at the moment." * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (39 commits) drivers/net/ethernet/tile: fix netdev_alloc_skb() bombing MAINTAINERS: update EDAC information tilepro ethernet driver: fix a few minor issues tile-srom.c driver: minor code cleanup edac: say "TILEGx" not "TILEPro" for the tilegx edac driver arch/tile: avoid accidentally unmasking NMI-type interrupt accidentally arch/tile: remove bogus performance optimization arch/tile: return SIGBUS for addresses that are unaligned AND invalid arch/tile: fix finv_buffer_remote() for tilegx arch/tile: use atomic exchange in arch_write_unlock() arch/tile: stop mentioning the "kvm" subdirectory arch/tile: export the page_home() function. arch/tile: fix pointer cast in cacheflush.c arch/tile: fix single-stepping over swint1 instructions on tilegx arch/tile: implement panic_smp_self_stop() arch/tile: add "nop" after "nap" to help GX idle power draw arch/tile: use proper memparse() for "maxmem" options arch/tile: fix up locking in pgtable.c slightly arch/tile: don't leak kernel memory when we unload modules arch/tile: fix bug in delay_backoff() ...
2012-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix inaccuracies in network driver interface documentation, from Ben Hutchings. 2) Fix handling of negative offsets in BPF JITs, from Jan Seiffert. 3) Compile warning, locking, and refcounting fixes in netfilter's xt_CT, from Pablo Neira Ayuso. 4) phonet sendmsg needs to validate user length just like any other datagram protocol, fix from Sasha Levin. 5) Ipv6 multicast code uses wrong loop index, from RongQing Li. 6) Link handling and firmware fixes in bnx2x driver from Yaniv Rosner and Yuval Mintz. 7) mlx4 erroneously allocates 4 pages at a time, regardless of page size, fix from Thadeu Lima de Souza Cascardo. 8) SCTP socket option wasn't extended in a backwards compatible way, fix from Thomas Graf. 9) Add missing address change event emissions to bonding, from Shlomo Pongratz. 10) /proc/net/dev regressed because it uses a private offset to track where we are in the hash table, but this doesn't track the offset pullback that the seq_file code does resulting in some entries being missed in large dumps. Fix from Eric Dumazet. 11) do_tcp_sendpage() unloads the send queue way too fast, because it invokes tcp_push() when it shouldn't. Let the natural sequence generated by the splice paths, and the assosciated MSG_MORE settings, guide the tcp_push() calls. Otherwise what goes out of TCP is spaghetti and doesn't batch effectively into GSO/TSO clusters. From Eric Dumazet. 12) Once we put a SKB into either the netlink receiver's queue or a socket error queue, it can be consumed and freed up, therefore we cannot touch it after queueing it like that. Fixes from Eric Dumazet. 13) PPP has this annoying behavior in that for every transmit call it immediately stops the TX queue, then calls down into the next layer to transmit the PPP frame. But if that next layer can take it immediately, it just un-stops the TX queue right before returning from the transmit method. Besides being useless work, it makes several facilities unusable, in particular things like the equalizers. Well behaved devices should only stop the TX queue when they really are full, and in PPP's case when it gets backlogged to the downstream device. David Woodhouse therefore fixed PPP to not stop the TX queue until it's downstream can't take data any more. 14) IFF_UNICAST_FLT got accidently lost in some recent stmmac driver changes, re-add. From Marc Kleine-Budde. 15) Fix link flaps in ixgbe, from Eric W. Multanen. 16) Descriptor writeback fixes in e1000e from Matthew Vick. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) net: fix a race in sock_queue_err_skb() netlink: fix races after skb queueing doc, net: Update ndo_start_xmit return type and values doc, net: Remove instruction to set net_device::trans_start doc, net: Update netdev operation names doc, net: Update documentation of synchronisation for TX multiqueue doc, net: Remove obsolete reference to dev->poll ethtool: Remove exception to the requirement of holding RTNL lock MAINTAINERS: update for Marvell Ethernet drivers bonding: properly unset current_arp_slave on slave link up phonet: Check input from user before allocating tcp: tcp_sendpages() should call tcp_push() once ipv6: fix array index in ip6_mc_add_src() mlx4: allocate just enough pages instead of always 4 pages stmmac: re-add IFF_UNICAST_FLT for dwmac1000 bnx2x: Clear MDC/MDIO warning message bnx2x: Fix BCM57711+BCM84823 link issue bnx2x: Clear BCM84833 LED after fan failure bnx2x: Fix BCM84833 PHY FW version presentation bnx2x: Fix link issue for BCM8727 boards. ...
2012-04-05MAINTAINERS: update for Marvell Ethernet driversstephen hemminger
Marvell has agreed to do maintenance on the sky2 driver. * Add the developer to the maintainers file * Remove the old reference to the long gone (sk98lin) driver * Rearrange to fit current topic organization Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-05Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge batch of fixes from Andrew Morton: "The simple_open() cleanup was held back while I wanted for laggards to merge things. I still need to send a few checkpoint/restore patches. I've been wobbly about merging them because I'm wobbly about the overall prospects for success of the project. But after speaking with Pavel at the LSF conference, it sounds like they're further toward completion than I feared - apparently davem is at the "has stopped complaining" stage regarding the net changes. So I need to go back and re-review those patchs and their (lengthy) discussion." * emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches) memcg swap: use mem_cgroup_uncharge_swap fix backlight: add driver for DA9052/53 PMIC v1 C6X: use set_current_blocked() and block_sigmask() MAINTAINERS: add entry for sparse checker MAINTAINERS: fix REMOTEPROC F: typo alpha: use set_current_blocked() and block_sigmask() simple_open: automatically convert to simple_open() scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open() libfs: add simple_open() hugetlbfs: remove unregister_filesystem() when initializing module drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback fs/xattr.c:setxattr(): improve handling of allocation failures fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed fs/xattr.c: suppress page allocation failure warnings from sys_listxattr() sysrq: use SEND_SIG_FORCED instead of force_sig() proc: fix mount -t proc -o AAA
2012-04-05MAINTAINERS: add entry for sparse checkerChristopher Li
Signed-off-by: Christopher Li <sparse@chrisli.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-05MAINTAINERS: fix REMOTEPROC F: typoJoe Perches
remoteproc.txt should have been .h Signed-off-by: Joe Perches <joe@perches.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Provide device string properly for USB i2400m wimax devices, also don't OOPS when providing firmware string. From Phil Sutter. 2) Add support for sh_eth SH7734 chips, from Nobuhiro Iwamatsu. 3) Add another device ID to USB zaurus driver, from Guan Xin. 4) Loop index start in pool vector iterator is wrong causing MAC to not get configured in bnx2x driver, fix from Dmitry Kravkov. 5) EQL driver assumes HZ=100, fix from Eric Dumazet. 6) Now that skb_add_rx_frag() can specify the truesize increment separately, do so in f_phonet and cdc_phonet, also from Eric Dumazet. 7) virtio_net accidently uses net_ratelimit() not only on the kernel warning but also the statistic bump, fix from Rick Jones. 8) ip_route_input_mc() uses fixed init_net namespace, oops, use dev_net(dev) instead. Fix from Benjamin LaHaise. 9) dev_forward_skb() needs to clear the incoming interface index of the SKB so that it looks like a new incoming packet, also from Benjamin LaHaise. 10) iwlwifi mistakenly initializes a channel entry as 2GHZ instead of 5GHZ, fix from Stanislav Yakovlev. 11) Missing kmalloc() return value checks in orinoco, from Santosh Nayak. 12) ath9k doesn't check for HT capabilities in the right way, it is checking ht_supported instead of the ATH9K_HW_CAP_HT flag. Fix from Sujith Manoharan. 13) Fix x86 BPF JIT emission of 16-bit immediate field of AND instructions, from Feiran Zhuang. 14) Avoid infinite loop in GARP code when registering sysfs entries. From David Ward. 15) rose protocol uses memcpy instead of memcmp in a device address comparison, oops. Fix from Daniel Borkmann. 16) Fix build of lpc_eth due to dev_hw_addr_rancom() interface being renamed to eth_hw_addr_random(). From Roland Stigge. 17) Make ipv6 RTM_GETROUTE interpret RTA_IIF attribute the same way that ipv4 does. Fix from Shmulik Ladkani. 18) via-rhine has an inverted bit test, causing suspend/resume regressions. Fix from Andreas Mohr. 19) RIONET assumes 4K page size, fix from Akinobu Mita. 20) Initialization of imask register in sky2 is buggy, because bits are "or'd" into an uninitialized local variable. Fix from Lino Sanfilippo. 21) Fix FCOE checksum offload handling, from Yi Zou. 22) Fix VLAN processing regression in e1000, from Jiri Pirko. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits) sky2: dont overwrite settings for PHY Quick link tg3: Fix 5717 serdes powerdown problem net: usb: cdc_eem: fix mtu net: sh_eth: fix endian check for architecture independent usb/rtl8150 : Remove duplicated definitions rionet: fix page allocation order of rionet_active via-rhine: fix wait-bit inversion. ipv6: Fix RTM_GETROUTE's interpretation of RTA_IIF to be consistent with ipv4 net: lpc_eth: Fix rename of dev_hw_addr_random net/netfilter/nfnetlink_acct.c: use linux/atomic.h rose_dev: fix memcpy-bug in rose_set_mac_address Fix non TBI PHY access; a bad merge undid bug fix in a previous commit. net/garp: avoid infinite loop if attribute already exists x86 bpf_jit: fix a bug in emitting the 16-bit immediate operand of AND bonding: emit event when bonding changes MAC mac80211: fix oper channel timestamp updation ath9k: Use HW HT capabilites properly MAINTAINERS: adding maintainer for ipw2x00 net: orinoco: add error handling for failed kmalloc(). net/wireless: ipw2x00: fix a typo in wiphy struct initilization ...
2012-04-02MAINTAINERS: update EDAC informationChris Metcalf
The bluesmoke mailing list no longer works, so use linux-edac@vger.kernel.org. And, use a less restrictive pattern so all drivers/edac changes go to linux-edac as well. Borislav suggested I just push this through the tile tree since there is currently no core edac maintainer (emails to Doug Thompson bounce). Acked-by: Borislav Petkov <bp@amd64.org> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-04-01Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2012-03-29Merge branch 'for-3.4-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull urgent cgroup fix from Tejun Heo: "Commit 61d1d219c4c0 ('cgroup: remove extra calls to find_existing_css_set') which was part of the rc1 cgroup pull request made writes to the cgroup "tasks" file return an uninitialized retval on success which can cause boot failures with systemd. The change stayed in linux-next for quite some time but gcc interestingly failed to emit warning about using uninitialized variable and the problem seems to materialize only for certain build combinations (probably depends on register allocation). It's just missing local variable initialization and the fix is trivial & safe. As the problem is critical when it materializes, I'm fast-tracking it. Also included is Li's email address change in MAINTAINERS." * 'for-3.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: cgroup_attach_task() could return -errno after success cgroup: update MAINTAINERS entry
2012-03-29Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar. * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: cpusets: Remove an unused variable sched/rt: Improve pick_next_highest_task_rt() sched: Fix select_fallback_rq() vs cpu_active/cpu_online sched/x86/smp: Do not enable IRQs over calibrate_delay() sched: Fix compiler warning about declared inline after use MAINTAINERS: Update email address for SCHEDULER and PERF EVENTS
2012-03-29cgroup: update MAINTAINERS entryLi Zefan
Update my email address. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-03-28Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Some significant updates to samsung-laptop, additional hardware support for Toshibas, misc updates to various hardware and a new backlight driver for some Apple machines." Fix up trivial conflicts: geode Geos update happening next to net5501 support, and MSIC thermal platform support added twice. * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (77 commits) acer-wmi: add quirk table for video backlight vendor mode drivers/platform/x86/amilo-rfkill.c::amilo_rfkill_probe() avoid NULL deref samsung-laptop: unregister ACPI video module for some well known laptops acer-wmi: No wifi rfkill on Sony machines thinkpad-acpi: recognize Lenovo as version string in newer V-series BIOS asus-wmi: don't update power and brightness when using scalar eeepc-wmi: split et2012 specific hacks eeepc-wmi: refine quirks handling asus-nb-wmi: set panel_power correctly asus-wmi: move WAPF variable into quirks_entry asus-wmi: store backlight power status for AIO machine asus-wmi: add scalar board brightness adj. support samsung-laptop: cleanup return type: mode_t vs umode_t drivers, samsung-laptop: fix usage of isalnum drivers, samsung-laptop: fix initialization of sabi_data in sabi_set_commandb asus-wmi: on/off bit is not set when reading the value eeepc-wmi: add extra keymaps for EP121 asus-nb-wmi: ignore useless keys acer-wmi: support Lenovo ideapad S205 Brazos wifi switch acer-wmi: fix out of input parameter size when set ...
2012-03-28Merge tag 'dm-3.4-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper changes for 3.4 from Alasdair Kergon: - Update thin provisioning to support read-only external snapshot origins and discards. - A new target, dm verity, for device content validation. - Mark dm uevent and dm raid as no-longer-experimental. - Miscellaneous other fixes and clean-ups. * tag 'dm-3.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (27 commits) dm: add verity target dm bufio: prefetch dm thin: add pool target flags to control discard dm thin: support discards dm thin: prepare to support discard dm thin: use dm_target_offset dm thin: support read only external snapshot origins dm thin: relax hard limit on the maximum size of a metadata device dm persistent data: remove space map ref_count entries if redundant dm thin: commit outstanding data every second dm: reject trailing characters in sccanf input dm raid: handle failed devices during start up dm thin metadata: pass correct space map to dm_sm_root_size dm persistent data: remove redundant value_size arg from value_ptr dm mpath: detect invalid map_context dm: clear bi_end_io on remapping failure dm table: simplify call to free_devices dm thin: correct comments dm raid: no longer experimental dm uevent: no longer experimental ...
2012-03-28MAINTAINERS: adding maintainer for ipw2x00Stanislav Yakovlev
Add myself as maintainer as suggested by Stanislaw Gruszka. Signed-off-by: Stanislav Yakovlev <stas.yakovlev@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-28dm: add persistent data to MAINTAINERSAlasdair G Kergon
Update device-mapper MAINTAINERS entry to mention quilt working tree location and persistent-data subdirectory. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-27Merge branch 'master' of ↵David S. Miller
2012-03-27Merge tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "remoteproc/rpmsg: new subsystem" from Arnd Bergmann: "This new subsystem provides a common way to talk to secondary processors on an SoC, e.g. a DSP, GPU or service processor, using virtio as the transport. In the long run, it should replace a few dozen vendor specific ways to do the same thing, which all never made it into the upstream kernel. There is a broad agreement that rpmsg is the way to go here and several vendors have started working on replacing their own subsystems. Two branches each add one virtio protocol number. Fortunately the numbers were agreed upon in advance, so there are only context changes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial protocol number conflict due to the mentioned additions next to each other. * tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) remoteproc: cleanup resource table parsing paths remoteproc: remove the hardcoded vring alignment remoteproc/omap: remove the mbox_callback limitation remoteproc: remove the single rpmsg vdev limitation remoteproc: safer boot/shutdown order remoteproc: remoteproc_rpmsg -> remoteproc_virtio remoteproc: resource table overhaul rpmsg: fix build warning when dma_addr_t is 64-bit rpmsg: fix published buffer length in rpmsg_recv_done rpmsg: validate incoming message length before propagating rpmsg: fix name service endpoint leak remoteproc/omap: two Kconfig fixes remoteproc: make sure we're parsing a 32bit firmware remoteproc: s/big switch/lookup table/ remoteproc: bail out if firmware has different endianess remoteproc: don't use virtio's weak barriers rpmsg: rename virtqueue_add_buf_gfp to virtqueue_add_buf rpmsg: depend on EXPERIMENTAL remoteproc: depend on EXPERIMENTAL rpmsg: add Kconfig menu ... Conflicts: include/linux/virtio_ids.h
2012-03-27Merge tag 'maintainers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: subarch maintainer updates" from Arnd Bergmann: "This is a collection of updates to the MAINTAINERS file, separated out mostly to give an overview of what has changed regarding who does what. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" * tag 'maintainers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: tegra: update main repo and add patchwork MAINTAINERS: update MAINTAINERS email entry MAINTAINERS: update maintainer entry for pxa/hx4700 MAINTAINERS: ARM: tegra: update Stephen's email address MAINTAINERS: add TI DaVinci git tree information MAINTAINERS: mark TI DaVinci list as "moderated" MAINTAINERS: remove arch/arm/mach-mx*/ from IMX entry
2012-03-26ath5k: drop self from MAINTAINERSBob Copeland
I simply don't have any hobby hacking time after family time and non-kernel-related job time, so I resume status as part-time mailing list lurker. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-23Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge second batch of patches from Andrew Morton: - various misc things - core kernel changes to prctl, exit, exec, init, etc. - kernel/watchdog.c updates - get_maintainer - MAINTAINERS - the backlight driver queue - core bitops code cleanups - the led driver queue - some core prio_tree work - checkpatch udpates - largeish crc32 update - a new poll() feature for the v4l guys - the rtc driver queue - fatfs - ptrace - signals - kmod/usermodehelper updates - coredump - procfs updates * emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits) seq_file: add seq_set_overflow(), seq_overflow() proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate(). procfs: speed up /proc/pid/stat, statm procfs: add num_to_str() to speed up /proc/stat proc: speed up /proc/stat handling fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP coredump: remove VM_ALWAYSDUMP flag kmod: make __request_module() killable kmod: introduce call_modprobe() helper usermodehelper: ____call_usermodehelper() doesn't need do_exit() usermodehelper: kill umh_wait, renumber UMH_* constants usermodehelper: implement UMH_KILLABLE usermodehelper: introduce umh_complete(sub_info) usermodehelper: use UMH_WAIT_PROC consistently signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/ signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig() signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE Hexagon: use set_current_blocked() and block_sigmask() ...
2012-03-23MAINTAINERS: update maintainership of LTPWanlong Gao
The maintainership of LTP is out of date, so update it. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: Cyril Hrubis <chrubis@suse.cz> Signed-off-by: Caspar Zhang <caspar@casparzhang.com> Reviewed-by: Rishikesh K Rajak <rishikesh.rajak@hp.com> Acked-by: Subrata Modak <tosubrata@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: add "S: Maintained" to clkdev and clk sectionsJoe Perches
Russell King seems to be maintaining these. Might as well mark them with the appropriate S: entry Signed-off-by: Joe Perches <joe@perches.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: add status to ALPHA architectureJoe Perches
Add missing S: status line to ALPHA. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: update git urls for 2.6 deletionsJoe Perches
Update the various git urls for name changes from 2.6. Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: update MCA sectionJoe Perches
The MCA section included a file referring to Machine Check rather than Microchannel. Rename the section to spell out Microchannel and drop the bad file reference. Reported-by: Greg Pearson <greg.pearson@hp.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge tag 'iommu-updates-v3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "The IOMMU updates for this round are not very large patch-wise. But they contain two new IOMMU drivers for the ARM Tegra 2 and 3 platforms. Besides that there are also a few patches for the AMD IOMMU which prepare the driver for adding intr-remapping support and a couple of fixes." * tag 'iommu-updates-v3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/amd: Fix section mismatch iommu/amd: Move interrupt setup code into seperate function iommu/amd: Make sure IOMMU interrupts are re-enabled on resume iommu/amd: Fix section warning for prealloc_protection_domains iommu/amd: Don't initialize IOMMUv2 resources when not required iommu/amd: Update git-tree in MAINTAINERS iommu/tegra-gart: fix spin_unlock in map failure path iommu/amd: Fix double free of mem-region in error-path iommu/amd: Split amd_iommu_init function ARM: IOMMU: Tegra30: Add iommu_ops for SMMU driver ARM: IOMMU: Tegra20: Add iommu_ops for GART driver
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-23MAINTAINERS: Update email address for SCHEDULER and PERF EVENTSIngo Molnar
2012-03-22Merge tag 'fbdev-updates-for-3.4' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates for 3.4 from Florian Tobias Schandinat: - drivers for Samsung Exynos MIPI DSI and display port - i740fb to support those old Intel chips - large updates to OMAP, viafb and sh_mobile_lcdcfb - some updates to s3c-fb and udlfb, few patches to others Fix up conflicts in drivers/video/udlfb.c due to Key Sievers' fix making it in twice. * tag 'fbdev-updates-for-3.4' of git://github.com/schandinat/linux-2.6: (156 commits) Revert "video:uvesafb: Fix oops that uvesafb try to execute NX-protected page" OMAPDSS: register dss drivers in module init video: pxafb: add clk_prepare/clk_unprepare calls fbdev: bfin_adv7393fb: Drop needless include fbdev: sh_mipi_dsi: add extra phyctrl for sh_mipi_dsi_info fbdev: remove dependency of FB_SH_MOBILE_MERAM from FB_SH_MOBILE_LCDC Revert "MAINTAINERS: add entry for exynos mipi display drivers" fbdev: da8xx: add support for SP10Q010 display fbdev: da8xx:: fix reporting of the display timing info drivers/video/pvr2fb.c: ensure arguments to request_irq and free_irq are compatible OMAPDSS: APPLY: fix clearing shadow dirty flag with manual update fbdev: sh_mobile_meram: Implement system suspend/resume fbdev: sh_mobile_meram: Remove unneeded sanity checks fbdev: sh_mobile_meram: Don't perform update in register operation arm: mach-shmobile: Constify sh_mobile_meram_cfg structures fbdev: sh_mobile_lcdc: Don't store copy of platform data fbdev: sh_mobile_meram: Remove unused sh_mobile_meram_icb_cfg fields arm: mach-shmobile: Don't set MERAM ICB numbers in platform data fbdev: sh_mobile_meram: Allocate ICBs automatically fbdev: sh_mobile_meram: Use genalloc to manage MERAM allocation ...
2012-03-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "- we finally merged driver for USB version of Synaptics touchpads (I guess most commonly found in IBM/Lenovo keyboard/touchpad combo); - a bunch of new drivers for embedded platforms (Cypress touchscreens, DA9052 OnKey, MAX8997-haptic, Ilitek ILI210x touchscreens, TI touchscreen); - input core allows clients to specify desired clock source for timestamps on input events (EVIOCSCLOCKID ioctl); - input core allows querying state of all MT slots for given event code via EVIOCGMTSLOTS ioctl; - various driver fixes and improvements." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (45 commits) Input: ili210x - add support for Ilitek ILI210x based touchscreens Input: altera_ps2 - use of_match_ptr() Input: synaptics_usb - switch to module_usb_driver() Input: convert I2C drivers to use module_i2c_driver() Input: convert SPI drivers to use module_spi_driver() Input: omap4-keypad - move platform_data to <linux/platform_data> Input: kxtj9 - who_am_i check value and initial data rate fixes Input: add driver support for MAX8997-haptic Input: tegra-kbc - revise device tree support Input: of_keymap - add device tree bindings for simple key matrices Input: wacom - fix physical size calculation for 3rd-gen Bamboo Input: twl4030-vibra - really switch from #if to #ifdef Input: hp680_ts_input - ensure arguments to request_irq and free_irq are compatible Input: max8925_onkey - avoid accessing input device too early Input: max8925_onkey - allow to be used as a wakeup source Input: atmel-wm97xx - convert to dev_pm_ops Input: atmel-wm97xx - set driver owner Input: add cyttsp touchscreen maintainer entry Input: cyttsp - remove useless checks in cyttsp_probe() Input: usbtouchscreen - add support for Data Modul EasyTouch TP 72037 ...
2012-03-22Merge tag 'stable/for-linus-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull cleancache changes from Konrad Rzeszutek Wilk: "This has some patches for the cleancache API that should have been submitted a _long_ time ago. They are basically cleanups: - rename of flush to invalidate - moving reporting of statistics into debugfs - use __read_mostly as necessary. Oh, and also the MAINTAINERS file change. The files (except the MAINTAINERS file) have been in #linux-next for months now. The late addition of MAINTAINERS file is a brain-fart on my side - didn't realize I needed that just until I was typing this up - and I based that patch on v3.3 - so the tree is on top of v3.3." * tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: MAINTAINERS: Adding cleancache API to the list. mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-03-22Merge branches 'iommu/fixes', 'arm/tegra' and 'x86/amd' into nextJoerg Roedel
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc merge from Benjamin Herrenschmidt: "Here's the powerpc batch for this merge window. It is going to be a bit more nasty than usual as in touching things outside of arch/powerpc mostly due to the big iSeriesectomy :-) We finally got rid of the bugger (legacy iSeries support) which was a PITA to maintain and that nobody really used anymore. Here are some of the highlights: - Legacy iSeries is gone. Thanks Stephen ! There's still some bits and pieces remaining if you do a grep -ir series arch/powerpc but they are harmless and will be removed in the next few weeks hopefully. - The 'fadump' functionality (Firmware Assisted Dump) replaces the previous (equivalent) "pHyp assisted dump"... it's a rewrite of a mechanism to get the hypervisor to do crash dumps on pSeries, the new implementation hopefully being much more reliable. Thanks Mahesh Salgaonkar. - The "EEH" code (pSeries PCI error handling & recovery) got a big spring cleaning, motivated by the need to be able to implement a new backend for it on top of some new different type of firwmare. The work isn't complete yet, but a good chunk of the cleanups is there. Note that this adds a field to struct device_node which is not very nice and which Grant objects to. I will have a patch soon that moves that to a powerpc private data structure (hopefully before rc1) and we'll improve things further later on (hopefully getting rid of the need for that pointer completely). Thanks Gavin Shan. - I dug into our exception & interrupt handling code to improve the way we do lazy interrupt handling (and make it work properly with "edge" triggered interrupt sources), and while at it found & fixed a wagon of issues in those areas, including adding support for page fault retry & fatal signals on page faults. - Your usual random batch of small fixes & updates, including a bunch of new embedded boards, both Freescale and APM based ones, etc..." I fixed up some conflicts with the generalized irq-domain changes from Grant Likely, hopefully correctly. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits) powerpc/ps3: Do not adjust the wrapper load address powerpc: Remove the rest of the legacy iSeries include files powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces init: Remove CONFIG_PPC_ISERIES powerpc: Remove FW_FEATURE ISERIES from arch code tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable powerpc/spufs: Fix double unlocks powerpc/5200: convert mpc5200 to use of_platform_populate() powerpc/mpc5200: add options to mpc5200_defconfig powerpc/mpc52xx: add a4m072 board support powerpc/mpc5200: update mpc5200_defconfig to fit for charon board Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board MAINTAINERS: Update PowerPC 4xx tree powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board powerpc: document the FSL MPIC message register binding powerpc: add support for MPIC message register API powerpc/fsl: Added aliased MSIIR register address to MSI node in dts powerpc/85xx: mpc8548cds - add 36-bit dts ...
2012-03-21Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull irq_domain support for all architectures from Grant Likely: "Generialize powerpc's irq_host as irq_domain This branch takes the PowerPC irq_host infrastructure (reverse mapping from Linux IRQ numbers to hardware irq numbering), generalizes it, renames it to irq_domain, and makes it available to all architectures. Originally the plan has been to create an all-new irq_domain implementation which addresses some of the powerpc shortcomings such as not handling 1:1 mappings well, but doing that proved to be far more difficult and invasive than generalizing the working code and refactoring it in-place. So, this branch rips out the 'new' irq_domain and replaces it with the modified powerpc version (in a fully bisectable way of course). It converts all users over to the new API and makes irq_domain selectable on any architecture. No architecture is forced to enable irq_domain, but the infrastructure is required for doing OpenFirmware style irq translations. It will even work on SPARC even though SPARC has it's own mechanism for translating irqs at boot time. MIPS, microblaze, embedded x86 and c6x are converted too. The resulting irq_domain code is probably still too verbose and can be optimized more, but that can be done incrementally and is a task for follow-on patches." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: (31 commits) dt: fix twl4030 for non-dt compile on x86 mfd: twl-core: Add IRQ_DOMAIN dependency devicetree: Add empty of_platform_populate() for !CONFIG_OF_ADDRESS (sparc) irq_domain: Centralize definition of irq_dispose_mapping() irq_domain/mips: Allow irq_domain on MIPS irq_domain/x86: Convert x86 (embedded) to use common irq_domain ppc-6xx: fix build failure in flipper-pic.c and hlwd-pic.c irq_domain/microblaze: Convert microblaze to use irq_domains irq_domain/powerpc: Replace custom xlate functions with library functions irq_domain/powerpc: constify irq_domain_ops irq_domain/c6x: Use library of xlate functions irq_domain/c6x: constify irq_domain structures irq_domain/c6x: Convert c6x to use generic irq_domain support. irq_domain: constify irq_domain_ops irq_domain: Create common xlate functions that device drivers can use irq_domain: Remove irq_domain_add_simple() irq_domain: Remove 'new' irq_domain in favour of the ppc one mfd: twl-core.c: Fix the number of interrupts managed by twl4030 of/address: add empty static inlines for !CONFIG_OF irq_domain: Add support for base irq and hwirq in legacy mappings ...
2012-03-21PCI: Bjorn gets PCI hotplug tooJesse Barnes
Though we may as well just merge this entry with the main PCI one at this point. Unless Alex returns one day at least... Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-20Revert "MAINTAINERS: add entry for exynos mipi display drivers"Florian Tobias Schandinat
This reverts commit 5eb1eb4ea102c9aed8a791892a5b0431b058f20e. The commit above breaks alphabetical ordering and I have the same entry at the correct position in my tree. Not reverting this one would result in duplicated maintainer entries. Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-03-20Merge commit 'v3.3' into fbdev-nextFlorian Tobias Schandinat
2012-03-20PCI: hand PCI maintenance over to Bjorn HelgaasJesse Barnes
I find I have less and less time to manage PCI patches and so I've been looking for a replacement. Bjorn has been substitute maintainer several times, and acts as de-facto maintainer for certain portions anyway. He's kindly agreed to take over in my stead; this makes it official. Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org.
2012-03-20Merge tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/ttyLinus Torvalds
Pull TTY/serial patches from Greg KH: "tty and serial merge for 3.4-rc1 Here's the big serial and tty merge for the 3.4-rc1 tree. There's loads of fixes and reworks in here from Jiri for the tty layer, and a number of patches from Alan to help try to wrestle the vt layer into a sane model. Other than that, lots of driver updates and fixes, and other minor stuff, all detailed in the shortlog." * tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (132 commits) serial: pxa: add clk_prepare/clk_unprepare calls TTY: Wrong unicode value copied in con_set_unimap() serial: PL011: clear pending interrupts serial: bfin-uart: Don't access tty circular buffer in TX DMA interrupt after it is reset. vt: NULL dereference in vt_do_kdsk_ioctl() tty: serial: vt8500: fix annotations for probe/remove serial: remove back and forth conversions in serial_out_sync serial: use serial_port_in/out vs serial_in/out in 8250 serial: introduce generic port in/out helpers serial: reduce number of indirections in 8250 code serial: delete useless void casts in 8250.c serial: make 8250's serial_in shareable to other drivers. serial: delete last unused traces of pausing I/O in 8250 pch_uart: Add module parameter descriptions pch_uart: Use existing default_baud in setup_console pch_uart: Add user_uartclk parameter pch_uart: Add Fish River Island II uart clock quirks pch_uart: Use uartclk instead of base_baud mpc5200b/uart: select more tolerant uart prescaler on low baudrates tty: moxa: fix bit test in moxa_start() ...
2012-03-20Merge tag 'staging-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull big staging driver updates from Greg KH: "Here is the big drivers/staging/ merge for 3.4-rc1 Lots of new driver updates here, with the addition of a few new ones, and only one moving out of the staging tree to the "real" part of the kernel (the hyperv scsi driver, acked by the scsi maintainer). There are also loads of cleanups, fixes, and other minor things in here, all self-contained in the drivers/staging/ tree. Overall we reversed the recent trend by adding more lines than we removed: 379 files changed, 37952 insertions(+), 14153 deletions(-)" * tag 'staging-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (360 commits) staging/zmem: Use lockdep_assert_held instead of spin_is_locked Staging: rtl8187se: r8180_wx.c: Cleaned up comments Staging: rtl8187se: r8180_wx.c: Removed old comments Staging: rtl8187se: r8180_dm.c: Removed old comments Staging: android: ram_console.c: Staging: rtl8187se: r8180_dm.c: Fix comments Staging: rtl8187se: r8180_dm.c: Fix spacing issues Staging: rtl8187se: r8180_dm.c Fixed indentation issues Staging: rtl8187se: r8180_dm.c: Fix brackets Staging: rtl8187se: r8180_dm.c: Removed spaces before tab stop staging: vme: fix section mismatches in linux-next 20120314 Staging: rtl8187se: r8180_core.c: Fix some long line issues Staging: rtl8187se: r8180_core.c: Fix some spacing issues Staging: rtl8187se: r8180_core.c: Removed trailing spaces staging: mei: remove driver internal versioning Staging: rtl8187se: r8180_core.c: Cleaned up if statement staging: ozwpan depends on NET staging: ozwpan: added maintainer for ozwpan driver staging/mei: propagate error codes up in the write flow drivers:staging:mei Fix some typos in staging/mei ...
2012-03-20samsung-laptop: promote myself as maintainer of samsung-laptopCorentin Chary
Signed-off-by: Corentin Chary <corentincj@iksaif.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2012-03-19ARM: tegra: update main repo and add patchworkOlof Johansson
Stephen is taking over the main tegra repo, so change the entry to point at his tree on kernel.org Also, document the patchwork URL. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-19MAINTAINERS: Adding cleancache API to the list.Konrad Rzeszutek Wilk
.. and electing myself as the maintainer. Acked-by: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-03-17MAINTAINERS: Update PowerPC 4xx treeJosh Boyer
Move the powerpc-4xx.git tree back to kernel.org Signed-off-by: Josh Boyer <jwboyer@gmail.com>
