commit bc7a2f3abc636d7cab84258a48e77b08fb5fd3d6 upstream.
The old address hasn't worked since the great intrusion of August 2011.
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit d00ebeac5f24f290636f7a895dafc124b2930a08 upstream.
Drop Chris Wright from STABLE maintainers. He hasn't done STABLE release
work for quite some time.
Acked-by: Chris Wright <chrisw@sous-sol.org>
commit 846557d3ceb6c7493e090921db5d6158ec237228 upstream
Replace all references to the old i2c mailing list.
This isn't a bug fix, but I would hate to miss bug reports because
they're sent to a dead mailing list.
Nowadays, man-pages has an associated mailing list. Mention that list
in MAINTAINERS.
Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com>
Remove myself from the kernel MAINTAINERS file for cpusets. I am leaving
SGI and probably will not be active in Linux kernel work. I can be
reached at <pj@usa.net>. Contact Derek Fults <dfults@sgi.com> for future
SGI+cpuset related issues. I'm off to the next chapter of this good life.
Signed-off-by: Paul Jackson <pj@sgi.com>
Cc: Paul Menage <menage@google.com>
Cc: Derek Fults <dfults@sgi.com>
Cc: John Hesterberg <jh@sgi.com>
Cc: Paul Jackson <pj@usa.net>
Two MAINTAINER entries (I2C/SMBUS STUB DRIVER and SIS 96X I2C/SMBUS
DRIVER) were improperly pointing to the lm-sensors mailing list
instead of the i2c mailing list. Fix them.
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: ASoC: maintainers - update email address for Liam Girdwood
This patch updates the maintainers email address for Liam Girdwood and
adds a URL for the ASoC website.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
* Normalize some S: entries to match the enumeration at the beginning
of the file.
* Change one mailing list entry from S: to L:.
* Drop trailing whitespace.
* Replace spaces and combinations of spaces and tabs by single tabs.
It should be linux-uvc-devel@lists.berlios.de.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Jie Yang at Atheros is getting more directly involved with upstream work
on the atl* drivers. This patch changes the ATL1 entry to ATLX (atl2
support posted to netdev today) and adds him as a maintainer.
... one entry lacked a colon which broke one of my scripts.
Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6
* 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6:
acer-wmi: remove debugfs entries upon unloading
ACPI: Avoid bogus timeout about SMbus check
fujitsu-laptop: fix regression for P8010 in 2.6.27-rc
ACPI: Make Len Brown the ACPI maintainer again
ACPI: thinkpad-acpi: wan radio control is not experimental
PNPACPI: ignore the producer/consumer bit for extended IRQ descriptors
acpi: add checking for NULL early param
ACPI: Fix typo in "Disable MWAIT via DMI on broken Compal board"
ACPI: Fix now signed module parameter.
ACPI: Change package length error to warning
Len is back!
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Cc: Dmitry Torokhov <dtor@mail.ru>
Update the location of the NTFS homepage in several files.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Jeff Garzik <jeff@garzik.org>
OMAP has now a list at vger.
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (94 commits)
pkt_sched: Prevent livelock in TX queue running.
Revert "pkt_sched: Add BH protection for qdisc_stab_lock."
Revert "pkt_sched: Protect gen estimators under est_lock."
pkt_sched: remove bogus block (cleanup)
nf_nat: use secure_ipv4_port_ephemeral() for NAT port randomization
netfilter: ctnetlink: sleepable allocation with spin lock bh
netfilter: ctnetlink: fix sleep in read-side lock section
netfilter: ctnetlink: fix double helper assignation for NAT'ed conntracks
netfilter: ipt_addrtype: Fix matching of inverted destination address type
dccp: Fix panic caused by too early termination of retransmission mechanism
pkt_sched: Don't hold qdisc lock over qdisc_destroy().
pkt_sched: Add lockdep annotation for qdisc locks
pkt_sched: Never schedule non-root qdiscs.
removed unused #include <version.h>
rt2x00: Fix txdone_entry_desc_flags
b43: Fix for another Bluetooth Coexistence SPROM Programming error for BCM4306
mac80211: remove kdoc references to IEEE80211_HW_HOST_GEN_BEACON_TEMPLATE
p54u: reset skb's data/tail pointer on requeue
p54: move p54_vdcf_init to the right place.
iwlwifi: fix printk newlines
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
The Bluetooth entries for the MAINTAINERS file are a little bit too
much. Consolidate them into two entries. One for Bluetooth drivers and
another one for the Bluetooth subsystem.
Also the MODULE_AUTHOR should indicate the current maintainer of the
module and actually not the original author. Fix all Bluetooth modules
to provide current maintainer information.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Add MAINTAINERS for GRU, XPNET, XPC and XP drivers.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Hans passed maintainership of the abituguru3 hwmon driver onto me. Add
a new entry to the MAINTAINERS file for the abituguru3 driver and assign
it to me. Also update the existing UGURU entry to indicate that Hans is
only responsible for the abituguru driver.
Signed-off-by: Alistair John Strachan <alistair@devzero.co.uk>
Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: "Mark M. Hoffman" <mhoffman@lightlink.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (47 commits)
usb: musb: pass configuration specifics via pdata
usb: musb: fix hanging when rmmod gadget driver
USB: Add MUSB and TUSB support
USB: serial: remove CONFIG_USB_DEBUG from sierra and option drivers
USB: Add vendor/product id of ZTE MF628 to option
USB: quirk PLL power down mode
USB: omap_udc: fix compilation with debug enabled
usb: cdc-acm: drain writes on close
usb: cdc-acm: stop dropping tx buffers
usb: cdc-acm: bugfix release()
usb gadget: issue notifications from ACM function
usb gadget: remove needless struct members
USB: sh: r8a66597-hcd: fix disconnect regression
USB: isp1301: fix compilation
USB: fix compiler warning fix
usb-storage: unusual_devs entry for Nokia 5300
USB: cdc-acm.c: Fix compile warnings
USB: BandRich BandLuxe C150/C250 HSPA Data Card Driver
USB: ftdi_sio: add support for PHI Fisco data cable (FT232BM based, VID/PID 0403:e40b)
usb: isp1760: don't be noisy about short packets.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits)
netns: Fix crash by making igmp per namespace
bnx2x: Version update
bnx2x: Checkpatch compliance
bnx2x: Spelling mistakes
bnx2x: Minor code improvements
bnx2x: Driver info
bnx2x: 1G LED does not turn off
bnx2x: 8073 PHY changes
bnx2x: Change GPIO for any port
bnx2x: Pause settings
bnx2x: Link order with external PHY
bnx2x: No LRO without Rx checksum
bnx2x: Wrong structure size
bnx2x: WoL capability
bnx2x: Clearing MAC addresses filters
bnx2x: Delay in while loops
bnx2x: PBA Table Page Alignment Workaround
bnx2x: Self-test false positive
bnx2x: Memory allocation
bnx2x: HW attention lock
This patch adds support for MUSB and TUSB controllers
integrated into omap2430 and davinci. It also adds support
for external tusb6010 controller.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com>
This patch removes the auerswald USB driver from the linux kernel
2.6.26.
This driver was included into the kernel mainly to connect to the ISDN
framework. This was done in linux 2.4.x. For 2.6.x, due to the fragile
and moving ISDN support, this connection was never realized, and the
only use of this driver was for device configuration. In the age of DSL,
the demand of ISDN support is getting very low.
Meanwhile, with the advent of libusb, an userspace driver was done for
the device configuration which works fine for linux and mac. (Thanks to
the libusb developers!). The userspace driver is downloadable from the
auerswald web site.
So this driver is obsolete now and has to be removed. Many thanks to all
developers which helped me to bring this driver up and working.
Signed-off-by: Wolfgang Muees <wolfgang@iksw-muees.de>
* 'for-2.6.27' of git://linux-nfs.org/~bfields/linux:
fs/nfsd/export.c: Adjust error handling code involving auth_domain_put
MAINTAINERS: mention lockd and sunrpc in nfs entries
lockd: trivial sparse endian annotations
Signed-off-by: Simon Horman <horms@verge.net.au>
- maintainer has not been active for years
- maintainer email bounces
- URL no longer exists
- covered by the WATCHDOG DEVICE DRIVERS entry
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ][2/2] preregister support for powernow-k8
[CPUFREQ][1/2] whitespace fix for powernow-k8
[CPUFREQ] Update MAINTAINERS to reflect new mailing list.
[CPUFREQ] Fix warning in elanfreq
[CPUFREQ] Fix -Wshadow warning in conservative governor.
[CPUFREQ] Remove EXPERIMENTAL annotation from VIA C7 powersaver kconfig.
Mailing list moved to vger.
Signed-off-by: Dave Jones <davej@redhat.com>
* 'for-linus-merged' of master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5177/1: arm/mach-sa1100/Makefile: remove CONFIG_SA1100_USB
[ARM] 5166/1: magician: add MAINTAINERS entry
[ARM] fix pnx4008 build errors
[ARM] Fix SMP booting with non-zero PHYS_OFFSET
[ARM] 5185/1: Fix spi num_chipselect for lubbock
[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/mach
[ARM] Add support for arch/arm/mach-*/include and arch/arm/plat-*/include
[ARM] Remove asm/hardware.h, use asm/arch/hardware.h instead
[ARM] Eliminate useless includes of asm/mach-types.h
[ARM] Fix circular include dependency with IRQ headers
avr32: Use <mach/foo.h> instead of <asm/arch/foo.h>
avr32: Introduce arch/avr32/mach-*/include/mach
avr32: Move include/asm-avr32 to arch/avr32/include/asm
[ARM] sa1100_wdt: use reset_status to remember watchdog reset status
[ARM] pxa: introduce reset_status and clear_reset_status for driver's usage
[ARM] pxa: introduce reset.h for reset specific header information
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Eric Miao <eric.miao@marvell.com>
This adds the new mac80211 11n ath9k Atheros driver. Only STA support
is currently enabled and tested.
Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Jack Howarth <howarth@bromo.msbb.uc.edu>
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Signed-off-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5182/1: pxa: Fix pcm990 compilation
[ARM] Fix explicit asm(-arm)?/arch-foo references
[ARM] move include/asm-arm to arch/arm/include/asm
[ARM] Remove explicit dependency for misc.o from compressed/Makefile
[ARM] initrd: claim initrd memory exclusively
[ARM] pxa: add support for L2 outer cache on XScale3 (attempt 2)
[ARM] 5180/1: at91: Fix at91_nand -> atmel_nand rename fallout
[ARM] add Sascha Hauer as Freescale i.MX Maintainer
[ARM] i.MX: add missing clock functions exports
[ARM] i.MX: remove set_imx_fb_info() export
[ARM] mx1ads: make mmc platform data available for modules
[ARM] mx2: add missing Kconfig dependency
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6:
hwmon: needs new maintainer
hwmon: (lm85) Simplify device initialization function
hwmon: (lm85) Misc cleanups
hwmon: (lm85) Don't write back cached values
hwmon: (lm85) Drop dead code
hwmon: (lm85) Coding-style cleanups
hwmon: (lm75) add new-style driver binding
hwmon: (lm75) cleanup/reorg
hwmon: (adt7473) clarify an awkward bit of code
hwmon: (adt7473) Remove unused defines
hwmon: (dme1737) fix voltage scaling
hwmon: (dme1737) probe all addresses
hwmon: (dme1737) demacrofy for readability
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'reg-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6:
regulator: TI bq24022 Li-Ion Charger driver
regulator: maintainers - add maintainers for regulator framework.
regulator: documentation - ABI
regulator: documentation - machine
regulator: documentation - regulator driver
regulator: documentation - consumer interface
regulator: documentation - overview
regulator: core kbuild files
regulator: regulator test harness
regulator: add support for fixed regulators.
regulator: regulator framework core
regulator: fixed regulator interface
regulator: machine driver interface
regulator: regulator driver interface
regulator: consumer device interface
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Adds Liam Girdwood and Mark Brown as regulator framework maintainers.
Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
Apparently the SH entry ought to be Supported instead of Maintained,
given the suble difference in terminology. Though it's been this way
for years now, thanks to Renesas.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Add the MAINTAINERS entry for OMFS.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
This adds the bt8xxgpio driver. The purpose of the bt8xxgpio driver is to
export all of the 24 GPIO pins available on Brooktree 8xx chips to the
kernel GPIO infrastructure.
This makes it possible to use a physically modified BT8xx card as
cheap digital GPIO card.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Cc: David Brownell <david-b@pacbell.net>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
MAINTAINERS: Remove Glenn Streiff from NetEffect entry
mlx4_core: Improve error message when not enough UAR pages are available
IB/mlx4: Add support for memory management extensions and local DMA L_Key
IB/mthca: Keep free count for MTT buddy allocator
mlx4_core: Keep free count for MTT buddy allocator
mlx4_code: Add missing FW status return code
IB/mlx4: Rename struct mlx4_lso_seg to mlx4_wqe_lso_seg
mlx4_core: Add module parameter to enable QoS support
RDMA/iwcm: Remove IB_ACCESS_LOCAL_WRITE from remote QP attributes
IPoIB: Include err code in trace message for ib_sa_path_rec_get() failures
IB/sa_query: Check if sm_ah is NULL in ib_sa_remove_one()
IB/ehca: Release mutex in error path of alloc_small_queue_page()
IB/ehca: Use default value for Local CA ACK Delay if FW returns 0
IB/ehca: Filter PATH_MIG events if QP was never armed
IB/iser: Add support for RDMA_CM_EVENT_ADDR_CHANGE event
RDMA/cma: Add RDMA_CM_EVENT_TIMEWAIT_EXIT event
RDMA/cma: Add RDMA_CM_EVENT_ADDR_CHANGE event
SOUND_TRIDENT was the last PCI OSS driver, and since there's already an
ALSA driver for the same hardware we can remove it.
[muli@il.ibm.com: update CREDITS]
Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com>
Trying to compile the v850 port brings many compile errors, one of them exists
since at least kernel 2.6.19.
There also seems to be noone willing to bring this port back into a usable
state.
This patch therefore removes the v850 port.
If anyone ever decides to revive the v850 port the code will still be
available from older kernels, and it wouldn't be impossible for the port to
reenter the kernel if it would become actively maintained again.
Acked-by: Greg Ungerer <gerg@uclinux.org>
The existing HPET maintainer entries are somewhat unclear about which one
applies to what part of the kernel.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
