We want the staging fixes in here as well.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging fixes from Greg KH:
"Here are some staging driver fixes, MAINTAINER updates, and a new
device id. All of these have been in the linux-next tree, and are
pretty simple patches"
* tag 'staging-3.12-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: r8188eu: Add new device ID
staging: imx-drm: Fix probe failure
staging: vt6656: [BUG] iwctl_siwencodeext return if device not open
staging: vt6656: [BUG] main_usb.c oops on device_close move flag earlier.
staging: vt6656: rxtx.c [BUG] s_vGetFreeContext dead lock on null apTD.
Staging: rtl8192u: r819xU_cmdpkt: checking NULL value after doing dev_alloc_skb
staging: usbip: Orphan usbip
staging: r8188eu: Add files for new drive: Cocci spatch "noderef"
staging: r8188eu: Cocci spatch "noderef"
staging: octeon-usb: Cocci spatch "noderef"
MAINTAINERS: staging: dgnc and dgap drivers: add maintainer
staging: lustre: Cocci spatch "noderef"
The domain of Matt Mooneey's email doesn't exist anymore.
Setting usbip to Oprhan.
Signed-off-by: Tobias Polzer <tobias.polzer@fau.de>
Signed-off-by: Dominik Paulus <dominik.paulus@fau.de>
This patch adds the staging/dgnc [DIGI NEO AND CLASSIC
PCI PRODUCTS] and staging/dgap [DIGI EPCA PCI PRODUCTS]
drivers to the MAINTAINERS file. I am listed as the
maintainer and the driverdev-devel list is the mailing
list for these drivers.
Signed-off-by: Lidza Louina <lidza.louina@gmail.com>
My old @it.uu.se email address is going away, so update relevant
files to point to my @gmail.com address instead. In sata_promise.c
just delete the address, people can get it from MAINTAINERS.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
Update email address on mach-bcm + drivers for Broadcom mobile SoCs.
Signed-off-by: Christian Daudt <csd@broadcom.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Stephen Warren <swarren@wwwdotorg.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of new drivers, functionality and cleanups for IIO in the 3.13 cycle
A number of new drivers and some new functionality + a lot of cleanups
all over IIO.
New Core Elements
1) New INT_TIME info_mask element for integration time, which may have
different effects on measurement noise and similar, than an amplifier
and hence is different from existing SCALE. Already existed in some
drivers as a custom attribute.
2) Introduce a iio_push_buffers_with_timestamp helper to cover the common
case of filling the last 64 bits of data to be passed to the buffer with
a timestamp. Applied to lots of drivers. Cuts down on repeated code and
moves a slightly fiddly bit of logic into a single location.
3) Introduce info_mask_[shared_by_dir/shared_by_all] elements to allow support
of elements such as sampling_frequency which is typically shared by all
input channels on a device. This reduces code and makes these controls
available from in kernel consumers of IIO devices.
New drivers
1) MCP3422/3/4 ADC
2) TSL4531 ambient light sensor
3) TCS3472/5 color light sensor
4) GP2AP020A00F ambient light / proximity sensor
5) LPS001WP support added to ST pressure sensor driver.
New driver functionality
1) ti_am335x_adc Add buffered sampling support.
This device has a hardware fifo that is fed directly into an IIO kfifo
buffer based on a watershed interrupt. Note this will act as an example
of how to handle this increasingly common type of device.
The only previous example - sca3000 - take a less than optimal approach
which is largely why it is still in staging.
A couple of little cleanups for that new functionality followed later.
Core cleanups:
1) MAINTAINERS - Sachin actually brought my email address up to date because
I said I'd do it and never got around to it :)
2) Assign buffer list elements as single element lists to simplify the
iio_buffer_is_active logic.
3) wake_up_interruptible_poll instead of wake_up_interruptible to only wake
up threads waiting for poll notifications.
4) Add O_CLOEXEC flag to anon_inode_get_fd call for IIO event interface.
5) Change iio_push_to_buffers to take a void * pointer so as to avoid some
annoying and unnecessary type casts.
6) iio_compute_scan_bytes incorrectly took a long rather than unsigned long.
7) Various minor tidy ups.
Driver cleanups (in no particular order)
1) Another set of devm_ allocations patches from Sachin Kamat.
2) tsl2x7x - 0 to NULL cleanup.
3) hmc5843 - fix missing > in MODULE_AUTHOR
4) Set of strict_strto* to kstrto* conversions.
5) mxs-lradc - fix ordering of resource removal to match creation
6) mxs-lradc - add MODULE_ALIAS
7) adc7606 - drop a work pending test duplicated in core functions.
8) hmc5843 - devm_ allocation patch
9) Series of redundant breaks removed.
10) ad2s1200 - pr_err -> dev_err
11) adjd_s311 - use INT_TIME
12) ST sensors - large set of cleanups from Lee Jones and removed restriction
to using only triggers provided by the st_sensors themselves from
Dennis Ciocca.
13) dummy and tmp006 provide sampling_frequency via info_mask_shared_by_all.
14) tcs3472 - fix incorrect buffer size and wrong device pointer used in
suspend / resume functions.
15) max1363 - use defaults for buffer setup ops as provided by the triggered
buffer helpers as they are the same as were specified in max1363 driver.
16) Trivial tidy ups in a number of other drivers.
Merge first patch-bomb from Andrew Morton:
- Some pidns/fork/exec tweaks
- OCFS2 updates
- Most of MM - there remain quite a few memcg parts which depend on
pending core cgroups changes. Which might have been already merged -
I'll check tomorrow...
- Various misc stuff all over the place
- A few block bits which I never got around to sending to Jens -
relatively minor things.
- MAINTAINERS maintenance
- A small number of lib/ updates
- checkpatch updates
- epoll
- firmware/dmi-scan
- Some kprobes work for S390
- drivers/rtc updates
- hfsplus feature work
- vmcore feature work
- rbtree upgrades
- AOE updates
- pktcdvd cleanups
- PPS
- memstick
- w1
- New "inittmpfs" feature, which does the obvious
- More IPC work from Davidlohr.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (303 commits)
lz4: fix compression/decompression signedness mismatch
ipc: drop ipc_lock_check
ipc, shm: drop shm_lock_check
ipc: drop ipc_lock_by_ptr
ipc, shm: guard against non-existant vma in shmdt(2)
ipc: document general ipc locking scheme
ipc,msg: drop msg_unlock
ipc: rename ids->rw_mutex
ipc,shm: shorten critical region for shmat
ipc,shm: cleanup do_shmat pasta
ipc,shm: shorten critical region for shmctl
ipc,shm: make shmctl_nolock lockless
ipc,shm: introduce shmctl_nolock
ipc: drop ipcctl_pre_down
ipc,shm: shorten critical region in shmctl_down
ipc,shm: introduce lockless functions to obtain the ipc object
initmpfs: use initramfs if rootfstype= or root= specified
initmpfs: make rootfs use tmpfs when CONFIG_TMPFS enabled
initmpfs: move rootfs code from fs/ramfs/ to init/
initmpfs: move bdi setup from init_rootfs to init_ramfs
Based partially on MS standard spec quotes from Alex Dubov.
As any code that works with user data this driver isn't recommended to use
to write cards that contain valuable data.
It tries its best though to avoid data corruption and possible damage to
the card.
Tested on MS DUO 64 MB card on Ricoh R592 card reader.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Tejun Heo <tj@kernel.org>
It's clearer to have patterns marked as directories.
Change the directory patterns without terminating slashes.
Add ownership to maintainers file for the mach-bcm related files,
including drivers that are used for the SoCs defined in mach-bcm.
Commit c50cd357887a ("net: gre: move GSO functions to gre_offload")
renamed and separated the file into multiple files. Update the
patterns.
Cc: Dmitry Kozlov <xeb@mail.ru>
Cc: Daniel Borkmann <dborkman@redhat.com>
Commit a0e631235a04 ("usb: phy: move all PHY drivers to
drivers/usb/phy/") deleted the files, remove the file pattern.
Acked-by: Felipe Balbi <balbi@ti.com>
Commit f3bc64d6d1f2 ("USB: EHCI: DT support for generic bus glue")
removed the ehci-vt8500.c file, update the file pattern to include
ehci-platform.c.
Commit 6659a20a76e0 ("ARC: MAINTAINERS update for ARC") typoed the file
pattern. Fix it.
Commit 45fcac1aad5d ("mfd: Move ssbi driver into drivers/mfd") move the
files, update the patterns.
Cc: Samuel Ortiz <sameo@linux.intel.com>
Commit d7104bffcfb7 ("[media] MAINTAINERS: add
drivers/media/tuners/it913x*") used the incorrect file patterns. Fix
it.
Acked-by: Antti Palosaari <crope@iki.fi>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Commit c937ca034a03 ("[media] MAINTAINERS: Add maintainer entry for
si4713 FM transmitter driver") typoed the pattern, fix it.
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Commit 786baecfe78f ("[media] dvb-usb: move it to
drivers/media/usb/dvb-usb") moved the files, update the pattern.
Commit 77c5f5d2f212 ("ghes_edac: Register at EDAC core the BIOS report")
typoed the file pattern. Fix it.
Commit 09ec1d7ea67f ("ARM: S3C24XX: Remove plat-s3c24xx directory in
arch/arm/") moved the files, remove the pattern.
Commit 694e33a7f42d ("ARM: plat-nomadik: move MTU, kill plat-nomadik")
moved the files, update the patterns.
Commit a7ed099ffc8e ("ARM: spear: move all files to mach-spear") moved
all the files into a single directory, delete the now unnecessary
duplicate sections and update the pattern.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Commit 85fd6d63bf29 ("ARM: S3C2410: move mach-s3c2410/* into
mach-s3c24xx/") moved the files, update the patterns.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Commit 498153995b9f ("ARM: OMAP2+: powerdomain/PRM: move the low-level
powerdomain") renamed the files, update the patterns.
Identical to a patch earlier sent by Cesar Eduardo Barros.
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Cesar Eduardo Barros <cesarb@cesarb.eti.br>
Commit 4bd5259e53ac ("ARM: OMAP2/3: clockdomain/PRM/CM: move the
low-level clockdomain functions into PRM/CM") deleted the files, update
the pattern.
Commit ca9143501c30 ("ARM: EXYNOS: Remove unused board files") removed
the files, remove the patterns too.
Cc: Tomasz Figa <t.figa@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Pull networking fixes from David Miller:
1) Brown paper bag fix in HTB scheduler, class options set incorrectly
due to a typoe. Fix from Vimalkumar.
2) It's possible for the ipv6 FIB garbage collector to run before all
the necessary datastructure are setup during init, defer the
notifier registry to avoid this problem. Fix from Michal Kubecek.
3) New i40e ethernet driver from the Intel folks.
4) Add new qmi wwan device IDs, from Bjørn Mork.
5) Doorbell lock in bnx2x driver is not initialized properly in some
configurations, fix from Ariel Elior.
6) Revert an ipv6 packet option padding change that broke standardized
ipv6 implementation test suites. From Jiri Pirko.
7) Fix synchronization of ARP information in bonding layer, from
Nikolay Aleksandrov.
8) Fix missing error return resulting in illegal memory accesses in
openvswitch, from Daniel Borkmann.
9) SCTP doesn't signal poll events properly due to mistaken operator
precedence, fix also from Daniel Borkmann.
10) __netdev_pick_tx() passes wrong index to sk_tx_queue_set() which
essentially disables caching of TX queue in sockets :-/ Fix from
Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (29 commits)
net_sched: htb: fix a typo in htb_change_class()
net: qmi_wwan: add new Qualcomm devices
ipv6: don't call fib6_run_gc() until routing is ready
net: tilegx driver: avoid compiler warning
fib6_rules: fix indentation
irda: vlsi_ir: Remove casting the return value which is a void pointer
irda: donauboe: Remove casting the return value which is a void pointer
net: fix multiqueue selection
net: sctp: fix smatch warning in sctp_send_asconf_del_ip
net: sctp: fix bug in sctp_poll for SOCK_SELECT_ERR_QUEUE
net: fib: fib6_add: fix potential NULL pointer dereference
net: ovs: flow: fix potential illegal memory access in __parse_flow_nlattrs
bcm63xx_enet: remove deprecated IRQF_DISABLED
net: korina: remove deprecated IRQF_DISABLED
macvlan: Move skb_clone check closer to call
qlcnic: Fix warning reported by kbuild test robot.
bonding: fix bond_arp_rcv setting and arp validate desync state
bonding: fix store_arp_validate race with mode change
ipv6/exthdrs: accept tlv which includes only padding
bnx2x: avoid atomic allocations during initialization
Updated with the current one.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch adds the changes for Kconfig, i40e.txt, MAINTAINERS, Kbuild
and new i40e/Makefile to build i40e with the kernel.
New driver build option is CONFIG_I40E
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
CC: PJ Waskiewicz <peter.p.waskiewicz.jr@intel.com>
CC: e1000-devel@lists.sourceforge.net
Tested-by: Kavindya Deegala <kavindya.s.deegala@intel.com>
Pull battery/power supply driver updates from Anton Vorontsov:
"New drivers:
- APM X-Gene system reboot driver by Feng Kan and Loc Ho (APM).
- Qualcomm MSM reboot/poweroff driver by Abhimanyu Kapur (Codeaurora).
- Texas Instruments BQ24190 charger driver by Mark A. Greer (Animal
Creek Technologies).
- Texas Instruments TWL4030 MADC battery driver by Lukas Märdian and
Marek Belisko (Golden Delicious Computers). The driver is used on
Freerunner GTA04 phones.
Highlighted fixes and improvements:
- Suspend/wakeup logic improvements: power supply objects will block
system suspend until all power supply events are processed. Thanks
to Zoran Markovic (Linaro), Arve Hjonnevag and Todd Poynor (Google)"
* tag 'for-v3.12' of git://git.infradead.org/battery-2.6:
rx51_battery: Fix channel number when reading adc value
power: Add twl4030_madc battery driver.
bq24190_charger: Workaround SS definition problem on i386 builds
power_supply: Prevent suspend until power supply events are processed
vexpress-poweroff: Should depend on the required infrastructure
twl4030-charger: Fix compiler warning with regulator_enable()
rx51_battery: Replace hardcoded channels values.
bq24190_charger: Add support for TI BQ24190 Battery Charger
ab8500-charger: We print an unintended error message
max8925_power: Fix missing of_node_put
power_supply: Replace strict_strtol() with kstrtol()
power: Add APM X-Gene system reboot driver
power_supply: tosa_battery: Get rid of irq_to_gpio usage
power supply: collie_battery: Convert to use dev_pm_ops
power_supply: Make goldfish_battery depend on GOLDFISH || COMPILE_TEST
power: reset: Add msm restart support
MAINTAINERS: drivers/power: add entry for SmartReflex AVS drivers
Pull slave-dmaengine updates from Vinod Koul:
"This pull brings:
- Andy's DW driver updates
- Guennadi's sh driver updates
- Pl08x driver fixes from Tomasz & Alban
- Improvements to mmp_pdma by Daniel
- TI EDMA fixes by Joel
- New drivers:
- Hisilicon k3dma driver
- Renesas rcar dma driver
- New API for publishing slave driver capablities
- Various fixes across the subsystem by Andy, Jingoo, Sachin etc..."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (94 commits)
dma: edma: Remove limits on number of slots
dma: edma: Leave linked to Null slot instead of DUMMY slot
dma: edma: Find missed events and issue them
ARM: edma: Add function to manually trigger an EDMA channel
dma: edma: Write out and handle MAX_NR_SG at a given time
dma: edma: Setup parameters to DMA MAX_NR_SG at a time
dmaengine: pl330: use dma_set_max_seg_size to set the sg limit
dmaengine: dma_slave_caps: remove sg entries
dma: replace devm_request_and_ioremap by devm_ioremap_resource
dma: ste_dma40: Fix potential null pointer dereference
dma: ste_dma40: Remove duplicate const
dma: imx-dma: Remove redundant NULL check
dma: dmagengine: fix function names in comments
dma: add driver for R-Car HPB-DMAC
dma: k3dma: use devm_ioremap_resource() instead of devm_request_and_ioremap()
dma: imx-sdma: Staticize sdma_driver_data structures
pch_dma: Add MODULE_DEVICE_TABLE
dmaengine: PL08x: Add cyclic transfer support
dmaengine: PL08x: Fix reading the byte count in cctl
dmaengine: PL08x: Add support for different maximum transfer size
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine update from Dan Williams:
"Collection of random updates to the core and some end-driver fixups
for ioatdma and mv_xor:
- NUMA aware channel allocation
- Cleanup dmatest debugfs interface
- ioat: make raid-support Atom only
- mv_xor: big endian
Aside from the top three commits these have all had some soak time in
-next. The top commit fixes a recent build breakage.
It has been a long while since my last pull request, hopefully it does
not show. Thanks to Vinod for keeping an eye on drivers/dma/ this
past year"
* tag 'dmaengine-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine:
dmaengine: dma_sync_wait and dma_find_channel undefined
MAINTAINERS: update email for Dan Williams
dma: mv_xor: Fix incorrect error path
ioatdma: silence GCC warnings
dmaengine: make dma_channel_rebalance() NUMA aware
dmaengine: make dma_submit_error() return an error code
ioatdma: disable RAID on non-Atom platforms and reenable unaligned copies
mv_xor: support big endian systems using descriptor swap feature
mv_xor: use {readl, writel}_relaxed instead of __raw_{readl, writel}
dmatest: print message on debug level in case of no error
dmatest: remove IS_ERR_OR_NULL checks of debugfs calls
dmatest: make module parameters writable
Pull ARM SoC driver update from Kevin Hilman:
"This contains the ARM SoC related driver updates for v3.12. The only
thing this cycle are core PM updates and CPUidle support for ARM's TC2
big.LITTLE development platform"
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
cpuidle: big.LITTLE: vexpress-TC2 CPU idle driver
ARM: vexpress: tc2: disable GIC CPU IF in tc2_pm_suspend
drivers: irq-chip: irq-gic: introduce gic_cpu_if_down()
Returned to intel.com
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Jon Mason <jon.mason@intel.com>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Shaohua Li <shli@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag
Pull metag architecture changes from James Hogan:
- Device tree updates for TZ1090 GPIO drivers merged via GPIO tree.
- Add driver for ImgTec PDC irqchip as found in TZ1090 SoC.
- Add linux-metag mailing list to MAINTAINERS file.
* tag 'metag-for-v3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag:
irq-imgpdc: add ImgTec PDC irqchip driver
MAINTAINERS: add linux-metag mailing list
metag: tz1090: instantiate gpio-tz1090-pdc
metag: tz1090: select and instantiate gpio-tz1090
metag: tz1090: select and instantiate irq-imgpdc
Pull NTB (non-transparent bridge) updates from Jon Mason:
"NTB driver bug fixes to address issues in NTB-RP enablement, spad,
debugfs, and USD/DSD identification.
Add a workaround on Xeon NTB devices for b2bdoorbell errata. Also,
add new NTB driver features to support 32bit x86, DMA engine support,
and NTB-RP support.
Finally, a few clean-ups and update to MAINTAINERS for the NTB git
tree and wiki location"
* tag 'ntb-3.12' of git://github.com/jonmason/ntb:
ntb: clean up unnecessary MSI/MSI-X capability find
MAINTAINERS: Add Website and Git Tree for NTB
NTB: Update Version
NTB: Comment Fix
NTB: Remove unused variable
NTB: Remove References of non-B2B BWD HW
NTB: NTB-RP support
NTB: Rename Variables for NTB-RP
NTB: Use DMA Engine to Transmit and Receive
NTB: Enable 32bit Support
NTB: Update Device IDs
NTB: BWD Link Recovery
NTB: Xeon Errata Workaround
NTB: Correct debugfs to work with more than 1 NTB Device
NTB: Correct USD/DSD Identification
NTB: Correct Number of Scratch Pad Registers
NTB: Add Error Handling in ntb_device_setup
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v3.12 series:
- A new driver for the TZ1090 PDC which is used on the metag
architecture.
- A new driver for the Kontron ETX or COMexpress GPIO block. This is
found on some ETX x86 devices.
- A new driver for the Fintek Super-I/O chips, used on some x86
boards.
- Added device tree probing on a few select GPIO blocks.
- Drop the Exynos support from the Samsung GPIO driver.
The Samsung maintainers have moved over to use the modernized pin
control driver to provide GPIO for the modern platforms instead.
- The usual bunch of non-critical fixes and cleanups"
* tag 'gpio-v3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (36 commits)
gpio: return -ENOTSUPP if debounce cannot be set
gpio: improve error path in gpiolib
gpio: add GPIO support for F71882FG and F71889F
of: add vendor prefix for Microchip Technology Inc
gpio: mcp23s08: rename the device tree property
gpio: samsung: Drop support for Exynos SoCs
gpio: pcf857x: Remove pdata argument to pcf857x_irq_domain_init()
gpio: pcf857x: Sort headers alphabetically
gpio: max7301: Reverting "Do not force SPI speed when using OF Platform"
gpio: Fix bit masking in Kontron PLD GPIO driver
gpio: pca953x: fix gpio input on gpio offsets >= 8
drivers/gpio: simplify use of devm_ioremap_resource
drivers/gpio/gpio-omap.c: convert comma to semicolon
gpio-lynxpoint: Fix warning about unbalanced pm_runtime_enable
gpio: Fix platform driver name in Kontron PLD GPIO driver
gpio: adnp: Fix segfault if request_threaded_irq fails
gpio: msm: Staticize local variable 'msm_gpio'
gpio: gpiolib-of.c: make error message more meaningful by adding the node name and index
gpio: use dev_get_platdata()
gpio/mxc: add chained_irq_enter/exit() to mx2_gpio_irq_handler
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"A new driver for slidebar on Ideapad laptops and a bunch of assorted
driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits)
Input: add SYN_MAX and SYN_CNT constants
Input: max11801_ts - convert to devm
Input: egalax-ts - fix typo and improve text
Input: MAINTAINERS - change maintainer for cyttsp driver
Input: cyttsp4 - kill 'defined but not used' compiler warnings
Input: add driver for slidebar on Lenovo IdeaPad laptops
Input: omap-keypad - set up irq type from DT
Input: omap-keypad - enable wakeup capability for keypad.
Input: omap-keypad - clear interrupts on open
Input: omap-keypad - convert to threaded IRQ
Input: omap-keypad - use bitfiled instead of hardcoded values
Input: cyttsp4 - remove useless NULL test from cyttsp4_watchdog_timer()
Input: wacom - fix error return code in wacom_probe()
Input: as5011 - fix error return code in as5011_probe()
Input: keyboard, serio - simplify use of devm_ioremap_resource
Input: tegra-kbc - simplify use of devm_ioremap_resource
Input: htcpen - fix incorrect placement of __initdata
Input: qt1070 - add power management ops
Input: wistron_btns - add MODULE_DEVICE_TABLE
Input: wistron_btns - mark the Medion MD96500 keymap as tested
Pull ARM SoC platform changes from Olof Johansson:
"This branch contains mostly additions and changes to platform
enablement and SoC-level drivers. Since there's sometimes a
dependency on device-tree changes, there's also a fair amount of
those in this branch.
Pieces worth mentioning are:
- Mbus driver for Marvell platforms, allowing kernel configuration
and resource allocation of on-chip peripherals.
- Enablement of the mbus infrastructure from Marvell PCI-e drivers.
- Preparation of MSI support for Marvell platforms.
- Addition of new PCI-e host controller driver for Tegra platforms
- Some churn caused by sharing of macro names between i.MX 6Q and 6DL
platforms in the device tree sources and header files.
- Various suspend/PM updates for Tegra, including LP1 support.
- Versatile Express support for MCPM, part of big little support.
- Allwinner platform support for A20 and A31 SoCs (dual and quad
Cortex-A7)
- OMAP2+ support for DRA7, a new Cortex-A15-based SoC.
The code that touches other architectures are patches moving MSI
arch-specific functions over to weak symbols and removal of
ARCH_SUPPORTS_MSI, acked by PCI maintainers"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits)
tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE
PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource
ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list
ARM: dts: vf610-twr: enable i2c0 device
ARM: dts: i.MX51: Add one more I2C2 pinmux entry
ARM: dts: i.MX51: Move pins configuration under "iomuxc" label
ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog
ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator
ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX
ARM: dts: i.MX27: Disable AUDMUX in the template
ARM: dts: wandboard: Add support for SDIO bcm4329
ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template
ARM: dts: imx53-qsb: Make USBH1 functional
ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module
ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module
ARM: dts: imx6qdl-sabresd: Add touchscreen support
ARM: imx: add ocram clock for imx53
ARM: dts: imx: ocram size is different between imx6q and imx6dl
ARM: dts: imx27-phytec-phycore-som: Fix regulator settings
ARM: dts: i.MX27: Remove clock name from CPU node
Pull Tile arch updates from Chris Metcalf:
"These changes bring in a bunch of new functionality that has been
maintained internally at Tilera over the last year, plus other stray
bits of work that I've taken into the tile tree from other folks.
The changes include some PCI root complex work, interrupt-driven
console support, support for performing fast-path unaligned data
fixups by kernel-based JIT code generation, CONFIG_PREEMPT support,
vDSO support for gettimeofday(), a serial driver for the tilegx
on-chip UART, KGDB support, more optimized string routines, support
for ftrace and kprobes, improved ASLR, and many bug fixes.
We also remove support for the old TILE64 chip, which is no longer
buildable"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (85 commits)
tile: refresh tile defconfig files
tile: rework <asm/cmpxchg.h>
tile PCI RC: make default consistent DMA mask 32-bit
tile: add null check for kzalloc in tile/kernel/setup.c
tile: make __write_once a synonym for __read_mostly
tile: remove support for TILE64
tile: use asm-generic/bitops/builtin-*.h
tile: eliminate no-op "noatomichash" boot argument
tile: use standard tile_bundle_bits type in traps.c
tile: simplify code referencing hypervisor API addresses
tile: change <asm/system.h> to <asm/switch_to.h> in comments
tile: mark pcibios_init() as __init
tile: check for correct compiler earlier in asm-offsets.c
tile: use standard 'generic-y' model for <asm/hw_irq.h>
tile: use asm-generic version of <asm/local64.h>
tile PCI RC: add comment about "PCI hole" problem
tile: remove DEBUG_EXTRA_FLAGS kernel config option
tile: add virt_to_kpte() API and clean up and document behavior
tile: support FRAME_POINTER
tile: support reporting Tilera hypervisor statistics
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
"Highlights:
- conversion of HID subsystem to use devm-based resource management,
from Benjamin Tissoires
- i2c-hid support for DT bindings, from Benjamin Tissoires
- much improved support for Win8-multitouch devices, from Benjamin
Tissoires
- cleanup of core code using common hidinput_input_event(), from
David Herrmann
- fix for bug in implement() access to the bit stream (causing oops)
that has been present in the code for ages, but devices that are
able to trigger it have started to appear only now, from Jiri
Kosina
- fixes for CVE-2013-2899, CVE-2013-2898, CVE-2013-2896,
CVE-2013-2892, CVE-2013-2888 (all triggerable only by specially
crafted malicious HW devices plugged into the system), from Kees
Cook
- hidraw oops fix, from Manoj Chourasia
- various smaller fixes here and there, support for a bunch of new
devices by various contributors"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (53 commits)
HID: MAINTAINERS: add roccat drivers
HID: hid-sensor-hub: change kmalloc + memcpy by kmemdup
HID: hid-sensor-hub: move to devm_kzalloc
HID: hid-sensor-hub: fix indentation accross the code
HID: move HID_REPORT_TYPES closer to the report-definitions
HID: check for NULL field when setting values
HID: picolcd_core: validate output report details
HID: sensor-hub: validate feature report details
HID: ntrig: validate feature report details
HID: pantherlord: validate output report details
HID: hid-wiimote: print small buffers via %*phC
HID: uhid: improve uhid example client
HID: Correct the USB IDs for the new Macbook Air 6
HID: wiimote: add support for Guitar-Hero guitars
HID: wiimote: add support for Guitar-Hero drums
Input: introduce BTN/ABS bits for drums and guitars
HID: battery: don't do DMA from stack
HID: roccat: add support for KonePureOptical v2
HID: picolcd: Prevent NULL pointer dereference on _remove()
HID: usbhid: quirk for N-Trig DuoSense Touch Screen
Pull networking changes from David Miller:
"Noteworthy changes this time around:
1) Multicast rejoin support for team driver, from Jiri Pirko.
2) Centralize and simplify TCP RTT measurement handling in order to
reduce the impact of bad RTO seeding from SYN/ACKs. Also, when
both timestamps and local RTT measurements are available prefer
the later because there are broken middleware devices which
scramble the timestamp.
From Yuchung Cheng.
3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel
memory consumed to queue up unsend user data. From Eric Dumazet.
4) Add a "physical port ID" abstraction for network devices, from
Jiri Pirko.
5) Add a "suppress" operation to influence fib_rules lookups, from
Stefan Tomanek.
6) Add a networking development FAQ, from Paul Gortmaker.
7) Extend the information provided by tcp_probe and add ipv6 support,
8) Use RCU locking more extensively in openvswitch data paths, from
Pravin B Shelar.
9) Add SCTP support to openvswitch, from Joe Stringer.
10) Add EF10 chip support to SFC driver, from Ben Hutchings.
11) Add new SYNPROXY netfilter target, from Patrick McHardy.
12) Compute a rate approximation for sending in TCP sockets, and use
this to more intelligently coalesce TSO frames. Furthermore, add
a new packet scheduler which takes advantage of this estimate when
available. From Eric Dumazet.
13) Allow AF_PACKET fanouts with random selection, from Daniel
Borkmann.
14) Add ipv6 support to vxlan driver, from Cong Wang"
Resolved conflicts as per discussion.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits)
openvswitch: Fix alignment of struct sw_flow_key.
netfilter: Fix build errors with xt_socket.c
tcp: Add missing braces to do_tcp_setsockopt
caif: Add missing braces to multiline if in cfctrl_linkup_request
bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize
vxlan: Fix kernel panic on device delete.
net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls
net: mvneta: properly disable HW PHY polling and ensure adjust_link() works
icplus: Use netif_running to determine device state
ethernet/arc/arc_emac: Fix huge delays in large file copies
tuntap: orphan frags before trying to set tx timestamp
tuntap: purge socket error queue on detach
qlcnic: use standard NAPI weights
ipv6:introduce function to find route for redirect
bnx2x: VF RSS support - VF side
bnx2x: VF RSS support - PF side
vxlan: Notify drivers for listening UDP port changes
net: usbnet: update addr_assign_type if appropriate
driver/net: enic: update enic maintainers and driver
driver/net: enic: Exposing symbols for Cisco's low latency driver
Pull x86 fixes from Ingo Molnar:
"Fix for the annoying paravirt.o build warning under allmodconfig, and
a MAINTAINERS file update"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, doc: Add an entry in MAINTAINERS for arch/x86/kernel/cpu/vmware.c
x86, paravirt: Remove duplicate definition for DEF_NATIVE
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
net/bridge/br_multicast.c
net/ipv6/sit.c
The conflicts were minor:
1) sit.c changes overlap with change to ip_tunnel_xmit() signature.
2) br_multicast.c had an overlap between computing max_delay using
msecs_to_jiffies and turning MLDV2_MRC() into an inline function
with a name using lowercase instead of uppercase letters.
3) stmmac had two overlapping changes, one which conditionally allocated
and hooked up a dma_cfg based upon the presence of the pbl OF property,
and another one handling store-and-forward DMA made. The latter of
which should not go into the new of_find_property() basic block.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"This series contains:
- Exynos s5p-mfc driver got support for VP8 encoder
- Some SoC drivers gained support for asynchronous registration
(needed for DT)
- The RC subsystem gained support for RC activity LED;
- New drivers added: a video decoder(adv7842), a video encoder
(adv7511), a new GSPCA driver (stk1135) and support for Renesas
R-Car (vsp1)
- the first SDR kernel driver: mirics msi3101. Due to some troubles
with the driver, and because the API is still under discussion, it
will be merged at staging for 3.12. Need to rework on it
- usual new boards additions, fixes, cleanups and driver
improvements"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (242 commits)
[media] cx88: Fix regression: CX88_AUDIO_WM8775 can't be 0
[media] exynos4-is: Fix entity unregistration on error path
[media] exynos-gsc: Register v4l2 device
[media] exynos4-is: Fix fimc-lite bayer formats
[media] em28xx: fix assignment of the eeprom data
[media] hdpvr: fix iteration over uninitialized lists in hdpvr_probe()
[media] usbtv: Throw corrupted frames away
[media] usbtv: Fix deinterlacing
[media] v4l2: added missing mutex.h include to v4l2-ctrls.h
[media] DocBook: upgrade media_api DocBook version to 4.2
[media] ml86v7667: fix compile warning: 'ret' set but not used
[media] s5p-g2d: Fix registration failure
[media] media: coda: Fix DT driver data pointer for i.MX27
[media] s5p-mfc: Fix input/output format reporting
[media] v4l: vsp1: Fix mutex double lock at streamon time
[media] v4l: vsp1: Add support for RT clock
[media] v4l: vsp1: Initialize media device bus_info field
[media] davinci: vpif_capture: fix error return code in vpif_probe()
[media] davinci: vpif_display: fix error return code in vpif_probe()
[media] MAINTAINERS: add entries for adv7511 and adv7842
Add website and git tree for the NTB entry in MAINTAINERS
Signed-off-by: Jon Mason <jon.mason@intel.com>
Signed-off-by: Govindarajulu Varadarajan <govindarajulu90@gmail.com>
Signed-off-by: Sujith Sankar <ssujith@cisco.com>
Signed-off-by: Nishank Trivedi <nistrive@cisco.com>
Signed-off-by: Christian Benvenuti <benve@cisco.com>
Adding maintainer for Roccat hid drivers
Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net>
Add an entry in MAINTAINERS file to reflect the maintainers of this
file.
Signed-off-by: Alok Kataria <akataria@vmware.com>
Link: http://lkml.kernel.org/r/1378284821.9739.7404.camel@akataria-dtop.eng.vmware.com
[ hpa: fixed tabs vs spaces ]
