commit 330e0a01d54c2b8606c56816f99af6ebc58ec92c upstream.
Matt Mackall stepped down as the /dev/random driver maintainer last
year, so Theodore Ts'o is taking back the /dev/random driver.
Cc: Matt Mackall <mpm@selenic.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit bc7a2f3abc636d7cab84258a48e77b08fb5fd3d6 upstream.
The old address hasn't worked since the great intrusion of August 2011.
As pointed out by Joe Perches the SCM tree type was missing in my patch.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
CC: Oliver Hartkopp <oliver.hartkopp@volkswagen.de>
CC: Urs Thuermann <urs.thuermann@volkswagen.de>
CC: Wolfgang Grandegger <wg@grandegger.com>
CC: Marc Kleine-Budde <mkl@pengutronix.de>
CC: linux-can@vger.kernel.org
Update the CAN MAINTAINERS section:
- point out active maintainers
- pull the CAN driver discussion away from netdev ML
- point to the new CAN web site on gitorious.org
- add CAN development git repository URL to submit patches
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394
post 3.2-rc7 pull request
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394:
MAINTAINERS: firewire git URL update
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (31 commits)
Revert "[media] af9015: limit I2C access to keep FW happy"
[media] s5p-fimc: Fix camera input configuration in subdev operations
[media] m5mols: Fix logic in sanity check
[media] ati_remote: switch to single-byte scancodes
[media] V4L: mt9m111: fix uninitialised mutex
[media] V4L: omap1_camera: fix missing <linux/module.h> include
[media] V4L: mt9t112: use after free in mt9t112_probe()
[media] V4L: soc-camera: fix compiler warnings on 64-bit platforms
[media] s5p_mfc_enc: fix s/H264/H263/ typo
[media] omap_vout: Fix compile error in 3.1
[media] au0828: add missing models 72101, 72201 & 72261 to the model matrix
[media] au0828: add missing USB ID 2040:7213
[media] au0828: add missing USB ID 2040:7260
[media] [trivial] omap24xxcam-dma: Fix logical test
[media] omap_vout: fix crash if no driver for a display
[media] media: video: s5p-tv: fix build break
[media] omap3isp: fix compilation of ispvideo.c
[media] m5mols: Fix set_fmt to return proper pixel format code
[media] s5p-fimc: Use correct fourcc for RGB565 colour format
[media] s5p-fimc: Fail driver probing when sensor configuration is wrong
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf events: Fix ring_buffer_wakeup() brown paperbag bug
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Fix select_idle_sibling() regression in selecting an idle SMT sibling
MAINTAINERS: Update tip.git related git trees
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
* 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
MAINTAINERS: Update amd-iommu F: patterns
iommu/amd: Fix typo in kernel-parameters.txt
iommu/msm: Fix compile error in mach-msm/devices-iommu.c
Fix comparison using wrong pointer variable in dma debug code
More players joined to memory cgroup developments and Johannes' great work
changed internal design of memory cgroup dramatically. And he will do
more works. Michal Hokko did many bug fixes and know memory cgroup very
well. Daisuke Nishimura helped us very much but he seems busy now.
Thanks to his works.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <bsingharora@gmail.com>
Commit 29b68415e335 ("x86: amd_iommu: move to drivers/iommu/")
moved the files, update the patterns.
CC: Ohad Ben-Cohen <ohad@wizery.com>
CC: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Update the six major subsystem trees hosted in the tip tree to
the new location (or add the location if it was missing).
Link: http://lkml.kernel.org/n/tip-w0z98as3kwy9bo1o3k2mmuvi@git.kernel.org
Help people find the overall architecture.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
There's a Samsung-specific mailing list but it's not advertised in
MAINTAINERS - add it to the overall architecture to make it more
discoverable.
[kgene.kim@samsung.com: added notice of 'moderated']
These days most Samsung stuff gets in the kernel through Kukjin Kim.
This patch changes MAINTAINERS to reflect this.
By adding Kukjin Kim to the maintainers for S3C2410, S3C244x and
S3C64xx alongside Ben Dooks the extra entries become identical to the
base ARM/SAMSUNG entry and can move into it.
Also the S3C2416 gets a maintainer through the s3c24* wildcard - as it
did not have one until now.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits)
ARM: ux500: update defconfig
ARM: u300: update defconfig
ARM: at91: enable additional boards in existing soc defconfig files
ARM: at91: refresh soc defconfig files for 3.2
ARM: at91: rename defconfig files appropriately
ARM: OMAP2+: Fix Compilation error when omap_l3_noc built as module
ARM: OMAP2+: Remove empty io.h
ARM: OMAP2: select ARM_AMBA if OMAP3_EMU is defined
ARM: OMAP: smartreflex: fix IRQ handling bug
ARM: OMAP: PM: only register TWL with voltage layer when device is present
ARM: OMAP: hwmod: Fix the addr space, irq, dma count APIs
arm: mx28: fix bit operation in clock setting
ARM: imx: export imx_ioremap
ARM: imx/mm-imx3: conditionally compile i.MX31 and i.MX35 code
ARM: mx5: Fix checkpatch warnings in cpu-imx5.c
MAINTAINERS: Add missing directory
ARM: imx: drop 'ARCH_MX31' and 'ARCH_MX35'
ARM: imx6q: move clock register map to machine_desc.map_io
ARM: pxa168/gplugd: add the correct SSP device
ARM: Update mach-types to fix mxs build breakage
git://git.linaro.org/people/triad/linux-stericsson into fixes
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (28 commits)
ALSA: hda - Fix jack-detection control of VT1708
ALSA: hda - cut and paste typo in cs420x_models[]
ALSA: hda/realtek - Minor cleanup
ALSA: hda/realtek - Fix missing inits of item indices for auto-mic
ALSA: hda - Fix invalid pin and GPIO for Apple laptops with CS codecs
ALSA: hda - Check subdevice mask in snd_hda_check_board_codec_sid_config()
ALSA: hda - fail ELD reading early
ALSA: lx6464es - fix device communication via command bus
ALSA: lx6464es - command buffer API cleanup
ALSA: hda - repoll ELD content for multiple times
ALSA: hdspm - Fix PCI ID for PCIe RME MADI cards
ASoC: Ensure WM8731 register cache is synced when resuming from disabled
ALSA: cs5535 - Fix an endianness conversion
ASoC: cs4271: Fix wrong mask parameter in some snd_soc_update_bits calls
ASoC: wm_hubs: fix DB_RANGE size
ASoC: wm9090: fix DB_RANGE size
ASoC: wm8993: fix DB_RANGE size
ASoC: wm8962: fix DB_RANGE size
ASoC: sgtl5000: fix DB_RANGE size
ASoC: rt5631: fix DB_RANGE size
Now that we've created a /drivers/staging/media, put it together with
/drivers/media. Also, added there a missing entry for the Media API spec.
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes
arch/arm/mach-imx/ is part of the i.MX support. Add it.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
TTY: ldisc, wait for ldisc infinitely in hangup
TTY: ldisc, move wait idle to caller
TTY: ldisc, allow waiting for ldisc arbitrarily long
Revert "tty/serial: Prevent drop of DCD on suspend for Tegra UARTs"
RS485: fix inconsistencies in the meaning of some variables
pch_uart: Fix DMA resource leak issue
serial,mfd: Fix CMSPAR setup
pch_uart: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor
pch_uart: Support new device LAPIS Semiconductor ML7831 IOH
pch_uart: Fix hw-flow control issue
tty: hvc_dcc: Fix duplicate character inputs
jsm: Change maintainership
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
* 'char-misc-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
misc: ad525x_dpot: Fix AD8400 spi transfer size.
pch_phub: Fix MAC address writing issue for LAPIS ML7831
pch_phub: Improve ADE(Address Decode Enable) control
pch_phub: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor
pch_phub: Support new device LAPIS Semiconductor ML7831 IOH
pcie-gadget-spear: Add "platform:" prefix for platform modalias
MAINTAINERS: add CHAR and MISC driver maintainers
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (86 commits)
ipv4: fix redirect handling
ping: dont increment ICMP_MIB_INERRORS
sky2: fix hang in napi_disable
sky2: enforce minimum ring size
bonding: Don't allow mode change via sysfs with slaves present
f_phonet: fix page offset of first received fragment
stmmac: fix pm functions avoiding sleep on spinlock
stmmac: remove spin_lock in stmmac_ioctl.
stmmac: parameters auto-tuning through HW cap reg
stmmac: fix advertising 1000Base capabilties for non GMII iface
stmmac: use mdelay on timeout of sw reset
sky2: version 1.30
sky2: used fixed RSS key
sky2: reduce default Tx ring size
sky2: rename up/down functions
sky2: pci posting issues
sky2: fix hang on shutdown (and other irq issues)
r6040: fix check against MCRO_HASHEN bit in r6040_multicast_list
MAINTAINERS: change email address for shemminger
pch_gbe: Move #include of module.h
No longer at Citrix, still interested in Xen.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
MAINTAINERS: update XFS maintainer entry
xfs: use doalloc flag in xfs_qm_dqattach_one()
As is probably painfully obvious, I don't have time to be a cgroups
maintainer. Rather than have me continue to hope that I'll magically
find more spare time, instead Tejun has kindly agreed to take over the
role, along with Li Zefan.
-tj: added cgroup tree URL to MAINTAINERS file
Signed-off-by: Paul Menage <paul@paulmenage.org>
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <1321320612-57855-1-git-send-email-paul@paulmenage.org>
I will no longer be maintaining XFS for SGI. Ben Myers
(bpm@sgi.com) has agreed to be the primary maintainer
for XFS in my place. I will continue to be able to push
commits to the SGI XFS tree if required. As such I will
continue to be a designated XFS maintainer, but plan to
serve in more of a backup role.
Signed-off-by: Alex Elder <aelder@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
My old email account at linux-foundation is no longer usable after
the LF breakin.
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: lantiq: use export.h in favour of module.h
MAINTAINERS: The MIPS git tree has moved.
MIPS: Fix build error due to missing inclusion of <linux/export.h>.
MIPS: ASID conflict after CPU hotplug
MIPS: Octeon: Fix compile error in arch/mips/cavium-octeon/flash_setup.c
MIPS: errloongson2_clock: Fix build error by including linux/module.h
STAGING: octeon-ethernet: Fix compile error caused by skb_frag_struct change
MIPS: Hook up process_vm_readv and process_vm_writev system calls.
MIPS: Kernel hangs occasionally during boot.
MIPS: Octeon: Mark SMP-IPI interrupt as IRQF_NO_THREAD
MIPS: BCM47xx: fix build with GENERIC_GPIO configuration
MIPS: NXP: Remove unused source files.
MIPS: Yosemite, Emma: Fix off-by-two in arcs_cmdline buffer size check
As discussed at Kernel Summit(2011), new cgroups mailing list is opened
by James. This list is for discussing general cgroup design and patches
including all subsystems and for getting more attentions to
cgroups/namespaces related issues by developpers.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Breno Leitao has passed the maintainership on to me.
Signed-off-by: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com>
Acked-by: Breno Leitao <brenohl@br.ibm.com>
Yes, we are fools, but humor us.
[media] v4l2-ctrl: Send change events to all fh for auto cluster slave controls
[media] v4l2-event: Don't set sev->fh to NULL on unsubscribe
[media] v4l2-event: Remove pending events from fh event queue when unsubscribing
[media] v4l2-event: Deny subscribing with a type of V4L2_EVENT_ALL
[media] MAINTAINERS: add a maintainer for s5p-mfc driver
[media] v4l: s5p-mfc: fix reported capabilities
[media] media: vb2: reset queued list on REQBUFS(0) call
[media] media: vb2: set buffer length correctly for all buffer types
[media] media: vb2: add a check for uninitialized buffer
[media] mxl111sf: fix build warning
[media] mxl111sf: remove pointless if condition in mxl111sf_config_spi
[media] mxl111sf: check for errors after mxl111sf_write_reg in mxl111sf_idac_config
[media] mxl111sf: fix return value of mxl111sf_idac_config
[media] uvcvideo: GET_RES should only be checked for BITMAP type menu controls
ALSA: usb-audio: Use kmemdup rather than duplicating its implementation
ALSA: hda - Re-enable the check NO_PRESENCE misc bit
ALSA: vmaster - Free slave-links when freeing the master element
ALSA: hda - Don't add elements of other codecs to vmaster slave
ALSA: intel8x0: improve virtual environment detection
ALSA: intel8x0: move virtual environment detection code into one place
ALSA: snd_usb_audio: add Logitech HD Webcam c510 to quirk-384
ALSA: hda - fix internal mic on Dell Vostro 3500 laptop
ALSA: HDA: Remove quirk for Toshiba T110
ALSA: usb-audio - Fix the missing volume quirks at delayed init
ALSA: hda - Mute unused capture sources for Realtek codecs
ALSA: intel8x0: Improve comments for VM optimization
ASoC: Ensure we get an impedence reported for WM8958 jack detect
ASoC: Don't use wm8994->control_data when requesting IRQs
ASoC: Don't use wm8994->control_data in wm8994_readable_register()
ASoC: Update git repository URL
As Exynos DRM is merged at mainline. Also update the maintainer entry.
Signed-off-by: Jassi Brar <jassisinghbrar@gmail.com>
Add a maintainer for s5p-mfc driver.
Signed-off-by: Jeongtae Park <jtp.park@samsung.com>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Kamil Debski <k.debski@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-3.2
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (31 commits)
ARM: OMAP: Fix export.h or module.h includes
ARM: OMAP: omap_device: Include linux/export.h
ARM: OMAP2: Fix H4 matrix keyboard warning
ARM: OMAP1: Remove unused omap-alsa.h
ARM: OMAP1: Fix warnings about enabling 32 KiHz timer
ARM: OMAP2+: timer: Remove omap_device_pm_latency
ARM: OMAP2+: clock data: Remove redundant timer clkdev
ARM: OMAP: Devkit8000: Remove double omap_mux_init_gpio
ARM: OMAP: usb: musb: OMAP: Delete unused function
MAINTAINERS: Update linux-omap git repository
ARM: OMAP: change get_context_loss_count ret value to int
ARM: OMAP4: hsmmc: configure SDMMC1_DR0 properly
ARM: OMAP4: hsmmc: Fix Pbias configuration on regulator OFF
ARM: OMAP3: hwmod: fix variant registration and remove SmartReflex from common list
ARM: OMAP: I2C: Fix omap_register_i2c_bus() return value on success
ARM: OMAP: dmtimer: Include linux/module.h
ARM: OMAP2+: l3-noc: Include linux/module.h
ARM: OMAP2+: devices: Fixes for McPDM
ARM: OMAP: Fix errors and warnings when building for one board
ARM: OMAP3: PM: restrict erratum i443 handling to OMAP3430 only
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits)
forcedeth: fix a few sparse warnings (variable shadowing)
forcedeth: Improve stats counters
forcedeth: remove unneeded stats updates
forcedeth: Acknowledge only interrupts that are being processed
forcedeth: fix race when unloading module
MAINTAINERS/rds: update maintainer
wanrouter: Remove kernel_lock annotations
usbnet: fix oops in usbnet_start_xmit
ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined
etherh: Add MAINTAINERS entry for etherh
bonding: comparing a u8 with -1 is always false
sky2: fix regression on Yukon Optima
netlink: clarify attribute length check documentation
netlink: validate NLA_MSECS length
i825xx:xscale:8390:freescale: Fix Kconfig dependancies
macvlan: receive multicast with local address
tg3: Update version to 3.121
tg3: Eliminate timer race with reset_task
tg3: Schedule at most one tg3_reset_task run
tg3: Obtain PCI function number from device
update for the actual maintainer
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Update my email address in MAINTAINERS.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
During the re-organization of Ethernet drivers, the MAINTAINERS
entry for etherh got dropped accidentally.
CC: Russell King <linux@arm.linux.org.uk>
CC: Joe Perches <joe@perches.com>
linux-omap is back at git.kernel.org. Path is the same than before except
-2.6 appendix.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits)
be2net: Add detect UE feature for Lancer
be2net: Prevent CQ full condition for Lancer
be2net: Fix disabling multicast promiscous mode
be2net: Fix endian issue in RX filter command
af_packet: de-inline some helper functions
MAINTAINERS: Add can-gw include to maintained files
net: Add back alignment for size for __alloc_skb
net: add missing bh_unlock_sock() calls
l2tp: fix race in l2tp_recv_dequeue()
ixgbevf: Update release version
ixgbe: DCB, return max for IEEE traffic classes
ixgbe: fix reading of the buffer returned by the firmware
ixgbe: Fix compiler warnings
ixgbe: fix smatch splat due to missing NULL check
ixgbe: fix disabling of Tx laser at probe
ixgbe: Fix link issues caused by a reset while interface is down
igb: Fix for I347AT4 PHY cable length unit detection
e100: make sure vlan support isn't advertised on old adapters
e1000e: demote a debugging WARN to a debug log message
net: fix typo in drivers/net/ethernet/xilinx/ll_temac_main.c
Commit c1aabdf379bc2feeb0df7057ed5bad96f492133e (can-gw: add netlink based
CAN routing) added a new include file that's neither referenced by any of
the CAN maintainers.
As suggested by Pengutronix, they want to get Sascha relieved from
the burden of maintaining MXS sub-architecture. Since I brought the
most of MXS core code to mainline (with the great help from
Pengutronix people, thanks!), I would like to step up for maintaining
MXS.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
