path: root/MAINTAINERS
2005-12-19[PATCH] V4L/DVB SCM Maintainers UpdateMauro Carvalho Chehab
- This patch updates MAINTAINERS file by replacing quilt to git SCM Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-12-13[PATCH] Dmitry Torokhov is input subsystem maintainerVojtech Pavlik
I haven't been very actively maintaining the input layer in past months, mostly because of my lack of time to concentrate on that. For that reason, I've decided to pass the maintainership of the Linux Input Layer to Dmitry Torokhov, whom I trust to do the job very well. Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Cc: Dmitry Torokhov <dtor_core@ameritech.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-02Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2005-12-01[PATCH] V4L/DVB: SCM updateMauro Carvalho Chehab
Add v4l/dvb quilt tree to MAINTAINERS file. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[SCSI] mptfusion: Add maintainersMoore, Eric Dean
Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-23[PATCH] Add more SCM trees to MAINTAINERSJosh Boyer
Greg requested a patch to update MAINTAINERS with more SCM entries. The patch below is what I've found so far. Signed-off-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] Clarify T: field in MAINTAINERSJody McIntyre
Pavel Machek points out that for git repos, what we include is not actually a URL. It is undesirable to use a URL since git repos can be accessed in many different ways. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] MTD git tree location added to MAINTAINERSJosh Boyer
Here's the MTD one. More later as I find them. Signed-off-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-20Input: add Wistron driverDmitry Torokhov
A driver for laptop buttons using an x86 BIOS interface that is apparently used on quite a few laptops and seems to be originating from Wistron. This driver currently "knows" only about Fujitsu-Siemens Amilo Pro V2000 (i.e. it can detect the laptop using DMI and it contains the keycode->key meaning mapping for this laptop) and Xeron SonicPro X 155G (probably can't be reliably autodetected, requires a module parameter), adding other laptops should be easy. In addition to reporting button presses to the input layer the driver also allows enabling/disabling the embedded wireless NIC (using the "Wifi" button); this is done using the same BIOS interface, so it seems only logical to keep the implementation together. Any flexibility possibly gained by allowing users to remap the function of the "Wifi" button is IMHO not worth it when weighted against the necessity to run an user-space daemon to convert button presses to wifi state changes. Signed-off-by: Miloslav Trmac <mitr@volny.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-18[PATCH] Add SCM info to MAINTAINERSJody McIntyre
Add tree information to MAINTAINERS file. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] New Omnikey Cardman 4000 driverHarald Welte
Add new Omnikey Cardman 4000 smartcard reader driver Signed-off-by: Harald Welte <laforge@gnumonks.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] New Omnikey Cardman 4040 driverHarald Welte
Add new Omnikey Cardman 4040 smartcard reader driver Signed-off-by: Harald Welte <laforge@gnumonks.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2005-11-10[DCCP]: Alter website for DCCP in MAINTAINERSIan McDonald
Website for DCCP is now hosted at OSDL Signed-off-by: Ian McDonald <imcdnzl@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09Merge rsync://bughost.org/repos/ipw-delta/Jeff Garzik
2005-11-08MAINTAINERS: PKTCDVD DRIVER: remove entry for a subscribers-only listAdrian Bunk
This patch was already ACK'ed by Peter Osterlund.
2005-11-07Updated READMEs and MAINTAINERS for the ipw2100 and ipw2200 drivers.James Ketrenos
Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] HPET, MaintainersBob Picco
This patch identifies the HPET Maintainers. Clemens in taking over as primary maintainer for the HPET driver. Clemens has i386 hardware with HPET and is a better choice than me because of this. I've shared this patch with all cc: recipients and there is agreement on ownership. Hopefully this eliminates future confusion in terms of where HPET maintenance is owned. Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: <clemens@ladisch.de> Cc: <venkatesh.pallipadi@intel.com> Cc: <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Merge with http://www.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitAdrian Bunk
2005-11-06Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-11-06I am the new monkey.Adrian Bunk
2005-11-06[ARM] 3088/1: PXA: Add machine support for the Sharp SL-6000x series of PDAsDirk Opfer
Patch from Dirk Opfer This patch adds basic machine support for the Sharp SL-6000x (Tosa) PDAs. Signed-off-by: Dirk Opfer Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-05Merge branch 'master'Jeff Garzik
2005-10-30[PATCH] Telecom Clock Driver for MPCBL0010 ATCA computer bladeMark Gross
Signed-off-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] Maintainers for fs_enetPantelis Antoniou
The following patch adds a MAINTAINERS entry for the fs_enet driver. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-29Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
2005-10-29We're no longer hosted on oss for ages ...Ralf Baechle
2005-10-29Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-10-28[PATCH] USB: delete the bluetty driverGreg Kroah-Hartman
We have a real Bluetooth system in Linux, lets finally delete this driver as no one is using it (and if they are, they are using a closed source bluetooth stack, which I can't support anyway.) Marcel, you owe me a beer :) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB: Buffer overflow patch for Yealink driverHenk
Just a small patch that fixes a small parameter validation bug. drivers/usb/input/map_to_7segment.h: This patch fixes the broken parameter validation in the char to seg7 conversion. This could cause out-of-bounds memory references. MAINTAINERS: Yealink maintainer info now in sorted order. Documentation/input/yealink.txt: Added a Q&A section that answers some common questions. Signed-off-by: Henk <Henk.Vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> 006491df1a13f85ad245d1039dfdf20e49c394fd
2005-10-28Merge branch 'master'Jeff Garzik
2005-10-28[PATCH] i2c-viapro: New maintainerJean Delvare
I am taking over the maintenance of the i2c-viapro SMBus driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> MAINTAINERS | 6 ++++++ 1 file changed, 6 insertions(+)
2005-10-28[PATCH] Add MAINTAINER entry for the new PowerPC 4xx on-chip ethernet ↵Eugene Surovegin
controller driver Add MAINTAINER entry for the new PPC4xx EMAC driver Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-21[PARISC] Update MAINTAINERS and CREDITSKyle McMartin
Add Kyle McMartin and Thibaut Varene as maintainers for ALSA ad1889 driver. Add myself to CREDITS. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-14[PATCH] megaraid maintainers entryKolli, Neela Syam
I am taking over all Megaraid SCSI drivers. Here is the patch for the MAINTENERS file. Signed-off-by: Neela Syam Kolli <Neela.Kolli@engenio.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-30[PATCH] MAINTAINERS: sbp2 driver is not orphaned.Jody McIntyre
Cc: Ben Collins <bcollins@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-29[IPVS]: Add netdev and me as maintainer contactsHorms
Signed-off-by: Horms <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[PATCH] cpuset maintainersPaul Jackson
Specify the cpuset maintainers. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] pktcdvd: MAINTAINERS recordPeter Osterlund
Add a MAINTAINERS entry for the pktcdvd driver. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] Update maintainers list with the kprobes maintainersPrasanna S Panchamukhi
This patch updates the maintainers list with kprobes maintainers. Signed-of-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] I2C: remove me from the MAINTAINERS file for i2cGreg Kroah-Hartman
Remove my name from the I2C maintainer, Jean is more than capable of handling it all now. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] skge: add maintainerStephen Hemminger
Add MAINTAINER record for Andrew ;-) Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[DCCP]: Add MAINTAINERS and CREDITS entriesArnaldo Carvalho de Melo
Also remove the SPX entry in MAINTAINERS, forgot to do that when I removed it. Signed-off-by: Ian McDonald <iam4@cs.waikato.ac.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/dwmw2/audit-2.6 Linus Torvalds
2005-09-12Merge ../torvalds-2.6/ Greg KH
2005-09-09[PATCH] updated hdaps driver.Robert Love
Driver for the IBM Hard Drive Active Protection System (HDAPS), an accelerometer found in most modern ThinkPads. Signed-off-by: Robert Love <rml@novell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] FUSE - MAINTAINERS, Kconfig and Makefile changesMiklos Szeredi
This patch adds FUSE filesystem to MAINTAINERS, fs/Kconfig and fs/Makefile. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
