Jon Masters developed this wonderful SMI detector. For details please
consult Documentation/hwlat_detector.txt. It could be ported to Linux
3.0 RT without any major change.
Signed-off-by: Carsten Emde <C.Emde@osadl.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull ACPI & Power Management patches from Len Brown:
"Two fixes for cpuidle merge-window changes, plus a URL fix in
MAINTAINERS"
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
MAINTAINERS: Update git url for ACPI
cpuidle: Fix panic in CPU off-lining with no idle driver
ACPI processor: Use safe_halt() rather than halt() in acpi_idle_play_dead()
Signed-off-by: Igor Murzov <e-mail@date.by>
Signed-off-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull arch/tile bug fixes from Chris Metcalf:
"This includes Paul Gortmaker's change to fix the <asm/system.h>
disintegration issues on tile, a fix to unbreak the tilepro ethernet
driver, and a backlog of bugfix-only changes from internal Tilera
development over the last few months.
They have all been to LKML and on linux-next for the last few days.
The EDAC change to MAINTAINERS is an oddity but discussion on the
linux-edac list suggested I ask you to pull that change through my
tree since they don't have a tree to pull edac changes from at the
moment."
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (39 commits)
drivers/net/ethernet/tile: fix netdev_alloc_skb() bombing
MAINTAINERS: update EDAC information
tilepro ethernet driver: fix a few minor issues
tile-srom.c driver: minor code cleanup
edac: say "TILEGx" not "TILEPro" for the tilegx edac driver
arch/tile: avoid accidentally unmasking NMI-type interrupt accidentally
arch/tile: remove bogus performance optimization
arch/tile: return SIGBUS for addresses that are unaligned AND invalid
arch/tile: fix finv_buffer_remote() for tilegx
arch/tile: use atomic exchange in arch_write_unlock()
arch/tile: stop mentioning the "kvm" subdirectory
arch/tile: export the page_home() function.
arch/tile: fix pointer cast in cacheflush.c
arch/tile: fix single-stepping over swint1 instructions on tilegx
arch/tile: implement panic_smp_self_stop()
arch/tile: add "nop" after "nap" to help GX idle power draw
arch/tile: use proper memparse() for "maxmem" options
arch/tile: fix up locking in pgtable.c slightly
arch/tile: don't leak kernel memory when we unload modules
arch/tile: fix bug in delay_backoff()
Pull networking updates from David Miller:
1) Fix inaccuracies in network driver interface documentation, from Ben
Hutchings.
2) Fix handling of negative offsets in BPF JITs, from Jan Seiffert.
3) Compile warning, locking, and refcounting fixes in netfilter's
xt_CT, from Pablo Neira Ayuso.
4) phonet sendmsg needs to validate user length just like any other
datagram protocol, fix from Sasha Levin.
5) Ipv6 multicast code uses wrong loop index, from RongQing Li.
6) Link handling and firmware fixes in bnx2x driver from Yaniv Rosner
and Yuval Mintz.
7) mlx4 erroneously allocates 4 pages at a time, regardless of page
size, fix from Thadeu Lima de Souza Cascardo.
8) SCTP socket option wasn't extended in a backwards compatible way,
fix from Thomas Graf.
9) Add missing address change event emissions to bonding, from Shlomo
Pongratz.
10) /proc/net/dev regressed because it uses a private offset to track
where we are in the hash table, but this doesn't track the offset
pullback that the seq_file code does resulting in some entries being
missed in large dumps.
Fix from Eric Dumazet.
11) do_tcp_sendpage() unloads the send queue way too fast, because it
invokes tcp_push() when it shouldn't. Let the natural sequence
generated by the splice paths, and the assosciated MSG_MORE
settings, guide the tcp_push() calls.
Otherwise what goes out of TCP is spaghetti and doesn't batch
effectively into GSO/TSO clusters.
From Eric Dumazet.
12) Once we put a SKB into either the netlink receiver's queue or a
socket error queue, it can be consumed and freed up, therefore we
cannot touch it after queueing it like that.
Fixes from Eric Dumazet.
13) PPP has this annoying behavior in that for every transmit call it
immediately stops the TX queue, then calls down into the next layer
to transmit the PPP frame.
But if that next layer can take it immediately, it just un-stops the
TX queue right before returning from the transmit method.
Besides being useless work, it makes several facilities unusable, in
particular things like the equalizers. Well behaved devices should
only stop the TX queue when they really are full, and in PPP's case
when it gets backlogged to the downstream device.
David Woodhouse therefore fixed PPP to not stop the TX queue until
it's downstream can't take data any more.
14) IFF_UNICAST_FLT got accidently lost in some recent stmmac driver
changes, re-add. From Marc Kleine-Budde.
15) Fix link flaps in ixgbe, from Eric W. Multanen.
16) Descriptor writeback fixes in e1000e from Matthew Vick.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits)
net: fix a race in sock_queue_err_skb()
netlink: fix races after skb queueing
doc, net: Update ndo_start_xmit return type and values
doc, net: Remove instruction to set net_device::trans_start
doc, net: Update netdev operation names
doc, net: Update documentation of synchronisation for TX multiqueue
doc, net: Remove obsolete reference to dev->poll
ethtool: Remove exception to the requirement of holding RTNL lock
MAINTAINERS: update for Marvell Ethernet drivers
bonding: properly unset current_arp_slave on slave link up
phonet: Check input from user before allocating
tcp: tcp_sendpages() should call tcp_push() once
ipv6: fix array index in ip6_mc_add_src()
mlx4: allocate just enough pages instead of always 4 pages
stmmac: re-add IFF_UNICAST_FLT for dwmac1000
bnx2x: Clear MDC/MDIO warning message
bnx2x: Fix BCM57711+BCM84823 link issue
bnx2x: Clear BCM84833 LED after fan failure
bnx2x: Fix BCM84833 PHY FW version presentation
bnx2x: Fix link issue for BCM8727 boards.
Marvell has agreed to do maintenance on the sky2 driver.
* Add the developer to the maintainers file
* Remove the old reference to the long gone (sk98lin) driver
* Rearrange to fit current topic organization
Merge batch of fixes from Andrew Morton:
"The simple_open() cleanup was held back while I wanted for laggards to
merge things.
I still need to send a few checkpoint/restore patches. I've been
wobbly about merging them because I'm wobbly about the overall
prospects for success of the project. But after speaking with Pavel
at the LSF conference, it sounds like they're further toward
completion than I feared - apparently davem is at the "has stopped
complaining" stage regarding the net changes. So I need to go back
and re-review those patchs and their (lengthy) discussion."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches)
memcg swap: use mem_cgroup_uncharge_swap fix
backlight: add driver for DA9052/53 PMIC v1
C6X: use set_current_blocked() and block_sigmask()
MAINTAINERS: add entry for sparse checker
MAINTAINERS: fix REMOTEPROC F: typo
alpha: use set_current_blocked() and block_sigmask()
simple_open: automatically convert to simple_open()
scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open()
libfs: add simple_open()
hugetlbfs: remove unregister_filesystem() when initializing module
drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback
fs/xattr.c:setxattr(): improve handling of allocation failures
fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed
fs/xattr.c: suppress page allocation failure warnings from sys_listxattr()
sysrq: use SEND_SIG_FORCED instead of force_sig()
proc: fix mount -t proc -o AAA
Signed-off-by: Christopher Li <sparse@chrisli.org>
remoteproc.txt should have been .h
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Pull networking fixes from David Miller:
1) Provide device string properly for USB i2400m wimax devices, also
don't OOPS when providing firmware string. From Phil Sutter.
2) Add support for sh_eth SH7734 chips, from Nobuhiro Iwamatsu.
3) Add another device ID to USB zaurus driver, from Guan Xin.
4) Loop index start in pool vector iterator is wrong causing MAC to not
get configured in bnx2x driver, fix from Dmitry Kravkov.
5) EQL driver assumes HZ=100, fix from Eric Dumazet.
6) Now that skb_add_rx_frag() can specify the truesize increment
separately, do so in f_phonet and cdc_phonet, also from Eric
Dumazet.
7) virtio_net accidently uses net_ratelimit() not only on the kernel
warning but also the statistic bump, fix from Rick Jones.
8) ip_route_input_mc() uses fixed init_net namespace, oops, use
dev_net(dev) instead. Fix from Benjamin LaHaise.
9) dev_forward_skb() needs to clear the incoming interface index of the
SKB so that it looks like a new incoming packet, also from Benjamin
LaHaise.
10) iwlwifi mistakenly initializes a channel entry as 2GHZ instead of
5GHZ, fix from Stanislav Yakovlev.
11) Missing kmalloc() return value checks in orinoco, from Santosh
Nayak.
12) ath9k doesn't check for HT capabilities in the right way, it is
checking ht_supported instead of the ATH9K_HW_CAP_HT flag. Fix from
Sujith Manoharan.
13) Fix x86 BPF JIT emission of 16-bit immediate field of AND
instructions, from Feiran Zhuang.
14) Avoid infinite loop in GARP code when registering sysfs entries.
From David Ward.
15) rose protocol uses memcpy instead of memcmp in a device address
comparison, oops. Fix from Daniel Borkmann.
16) Fix build of lpc_eth due to dev_hw_addr_rancom() interface being
renamed to eth_hw_addr_random(). From Roland Stigge.
17) Make ipv6 RTM_GETROUTE interpret RTA_IIF attribute the same way
that ipv4 does. Fix from Shmulik Ladkani.
18) via-rhine has an inverted bit test, causing suspend/resume
regressions. Fix from Andreas Mohr.
19) RIONET assumes 4K page size, fix from Akinobu Mita.
20) Initialization of imask register in sky2 is buggy, because bits are
"or'd" into an uninitialized local variable. Fix from Lino
Sanfilippo.
21) Fix FCOE checksum offload handling, from Yi Zou.
22) Fix VLAN processing regression in e1000, from Jiri Pirko.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits)
sky2: dont overwrite settings for PHY Quick link
tg3: Fix 5717 serdes powerdown problem
net: usb: cdc_eem: fix mtu
net: sh_eth: fix endian check for architecture independent
usb/rtl8150 : Remove duplicated definitions
rionet: fix page allocation order of rionet_active
via-rhine: fix wait-bit inversion.
ipv6: Fix RTM_GETROUTE's interpretation of RTA_IIF to be consistent with ipv4
net: lpc_eth: Fix rename of dev_hw_addr_random
net/netfilter/nfnetlink_acct.c: use linux/atomic.h
rose_dev: fix memcpy-bug in rose_set_mac_address
Fix non TBI PHY access; a bad merge undid bug fix in a previous commit.
net/garp: avoid infinite loop if attribute already exists
x86 bpf_jit: fix a bug in emitting the 16-bit immediate operand of AND
bonding: emit event when bonding changes MAC
mac80211: fix oper channel timestamp updation
ath9k: Use HW HT capabilites properly
MAINTAINERS: adding maintainer for ipw2x00
net: orinoco: add error handling for failed kmalloc().
net/wireless: ipw2x00: fix a typo in wiphy struct initilization
The bluesmoke mailing list no longer works, so use
linux-edac@vger.kernel.org. And, use a less restrictive pattern so all
drivers/edac changes go to linux-edac as well.
Borislav suggested I just push this through the tile tree since there
is currently no core edac maintainer (emails to Doug Thompson bounce).
Acked-by: Borislav Petkov <bp@amd64.org>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull urgent cgroup fix from Tejun Heo:
"Commit 61d1d219c4c0 ('cgroup: remove extra calls to
find_existing_css_set') which was part of the rc1 cgroup pull request
made writes to the cgroup "tasks" file return an uninitialized retval
on success which can cause boot failures with systemd.
The change stayed in linux-next for quite some time but gcc
interestingly failed to emit warning about using uninitialized
variable and the problem seems to materialize only for certain build
combinations (probably depends on register allocation).
It's just missing local variable initialization and the fix is trivial
& safe. As the problem is critical when it materializes, I'm
fast-tracking it. Also included is Li's email address change in
MAINTAINERS."
* 'for-3.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: cgroup_attach_task() could return -errno after success
cgroup: update MAINTAINERS entry
Pull scheduler fixes from Ingo Molnar.
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
cpusets: Remove an unused variable
sched/rt: Improve pick_next_highest_task_rt()
sched: Fix select_fallback_rq() vs cpu_active/cpu_online
sched/x86/smp: Do not enable IRQs over calibrate_delay()
sched: Fix compiler warning about declared inline after use
MAINTAINERS: Update email address for SCHEDULER and PERF EVENTS
Update my email address.
Signed-off-by: Li Zefan <lizefan@huawei.com>
Pull x86 platform driver updates from Matthew Garrett:
"Some significant updates to samsung-laptop, additional hardware
support for Toshibas, misc updates to various hardware and a new
backlight driver for some Apple machines."
Fix up trivial conflicts: geode Geos update happening next to net5501
support, and MSIC thermal platform support added twice.
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (77 commits)
acer-wmi: add quirk table for video backlight vendor mode
drivers/platform/x86/amilo-rfkill.c::amilo_rfkill_probe() avoid NULL deref
samsung-laptop: unregister ACPI video module for some well known laptops
acer-wmi: No wifi rfkill on Sony machines
thinkpad-acpi: recognize Lenovo as version string in newer V-series BIOS
asus-wmi: don't update power and brightness when using scalar
eeepc-wmi: split et2012 specific hacks
eeepc-wmi: refine quirks handling
asus-nb-wmi: set panel_power correctly
asus-wmi: move WAPF variable into quirks_entry
asus-wmi: store backlight power status for AIO machine
asus-wmi: add scalar board brightness adj. support
samsung-laptop: cleanup return type: mode_t vs umode_t
drivers, samsung-laptop: fix usage of isalnum
drivers, samsung-laptop: fix initialization of sabi_data in sabi_set_commandb
asus-wmi: on/off bit is not set when reading the value
eeepc-wmi: add extra keymaps for EP121
asus-nb-wmi: ignore useless keys
acer-wmi: support Lenovo ideapad S205 Brazos wifi switch
acer-wmi: fix out of input parameter size when set
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull device-mapper changes for 3.4 from Alasdair Kergon:
- Update thin provisioning to support read-only external snapshot
origins and discards.
- A new target, dm verity, for device content validation.
- Mark dm uevent and dm raid as no-longer-experimental.
- Miscellaneous other fixes and clean-ups.
* tag 'dm-3.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (27 commits)
dm: add verity target
dm bufio: prefetch
dm thin: add pool target flags to control discard
dm thin: support discards
dm thin: prepare to support discard
dm thin: use dm_target_offset
dm thin: support read only external snapshot origins
dm thin: relax hard limit on the maximum size of a metadata device
dm persistent data: remove space map ref_count entries if redundant
dm thin: commit outstanding data every second
dm: reject trailing characters in sccanf input
dm raid: handle failed devices during start up
dm thin metadata: pass correct space map to dm_sm_root_size
dm persistent data: remove redundant value_size arg from value_ptr
dm mpath: detect invalid map_context
dm: clear bi_end_io on remapping failure
dm table: simplify call to free_devices
dm thin: correct comments
dm raid: no longer experimental
dm uevent: no longer experimental
Add myself as maintainer as suggested by Stanislaw Gruszka.
Signed-off-by: Stanislav Yakovlev <stas.yakovlev@gmail.com>
Update device-mapper MAINTAINERS entry to mention quilt working tree location
and persistent-data subdirectory.
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Pull "remoteproc/rpmsg: new subsystem" from Arnd Bergmann:
"This new subsystem provides a common way to talk to secondary
processors on an SoC, e.g. a DSP, GPU or service processor, using
virtio as the transport. In the long run, it should replace a few
dozen vendor specific ways to do the same thing, which all never made
it into the upstream kernel. There is a broad agreement that rpmsg is
the way to go here and several vendors have started working on
replacing their own subsystems.
Two branches each add one virtio protocol number. Fortunately the
numbers were agreed upon in advance, so there are only context
changes.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up trivial protocol number conflict due to the mentioned additions
next to each other.
* tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits)
remoteproc: cleanup resource table parsing paths
remoteproc: remove the hardcoded vring alignment
remoteproc/omap: remove the mbox_callback limitation
remoteproc: remove the single rpmsg vdev limitation
remoteproc: safer boot/shutdown order
remoteproc: remoteproc_rpmsg -> remoteproc_virtio
remoteproc: resource table overhaul
rpmsg: fix build warning when dma_addr_t is 64-bit
rpmsg: fix published buffer length in rpmsg_recv_done
rpmsg: validate incoming message length before propagating
rpmsg: fix name service endpoint leak
remoteproc/omap: two Kconfig fixes
remoteproc: make sure we're parsing a 32bit firmware
remoteproc: s/big switch/lookup table/
remoteproc: bail out if firmware has different endianess
remoteproc: don't use virtio's weak barriers
rpmsg: rename virtqueue_add_buf_gfp to virtqueue_add_buf
rpmsg: depend on EXPERIMENTAL
remoteproc: depend on EXPERIMENTAL
rpmsg: add Kconfig menu
include/linux/virtio_ids.h
Pull "ARM: subarch maintainer updates" from Arnd Bergmann:
"This is a collection of updates to the MAINTAINERS file, separated out
mostly to give an overview of what has changed regarding who does
what.
* tag 'maintainers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: tegra: update main repo and add patchwork
MAINTAINERS: update MAINTAINERS email entry
MAINTAINERS: update maintainer entry for pxa/hx4700
MAINTAINERS: ARM: tegra: update Stephen's email address
MAINTAINERS: add TI DaVinci git tree information
MAINTAINERS: mark TI DaVinci list as "moderated"
MAINTAINERS: remove arch/arm/mach-mx*/ from IMX entry
I simply don't have any hobby hacking time after family time
and non-kernel-related job time, so I resume status as part-time
mailing list lurker.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Merge second batch of patches from Andrew Morton:
- various misc things
- core kernel changes to prctl, exit, exec, init, etc.
- kernel/watchdog.c updates
- get_maintainer
- MAINTAINERS
- the backlight driver queue
- core bitops code cleanups
- the led driver queue
- some core prio_tree work
- checkpatch udpates
- largeish crc32 update
- a new poll() feature for the v4l guys
- the rtc driver queue
- fatfs
- ptrace
- signals
- kmod/usermodehelper updates
- coredump
- procfs updates
* emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits)
seq_file: add seq_set_overflow(), seq_overflow()
proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate().
procfs: speed up /proc/pid/stat, statm
procfs: add num_to_str() to speed up /proc/stat
proc: speed up /proc/stat handling
fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static
coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP
coredump: remove VM_ALWAYSDUMP flag
kmod: make __request_module() killable
kmod: introduce call_modprobe() helper
usermodehelper: ____call_usermodehelper() doesn't need do_exit()
usermodehelper: kill umh_wait, renumber UMH_* constants
usermodehelper: implement UMH_KILLABLE
usermodehelper: introduce umh_complete(sub_info)
usermodehelper: use UMH_WAIT_PROC consistently
signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/
signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig()
signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths
signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE
Hexagon: use set_current_blocked() and block_sigmask()
The maintainership of LTP is out of date, so update it.
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Signed-off-by: Cyril Hrubis <chrubis@suse.cz>
Signed-off-by: Caspar Zhang <caspar@casparzhang.com>
Reviewed-by: Rishikesh K Rajak <rishikesh.rajak@hp.com>
Acked-by: Subrata Modak <tosubrata@gmail.com>
Russell King seems to be maintaining these. Might as well mark them with
the appropriate S: entry
Add missing S: status line to ALPHA.
Update the various git urls for name changes from 2.6.
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
The MCA section included a file referring to Machine Check rather than
Microchannel.
Rename the section to spell out Microchannel and drop the bad file
reference.
Reported-by: Greg Pearson <greg.pearson@hp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"The IOMMU updates for this round are not very large patch-wise. But
they contain two new IOMMU drivers for the ARM Tegra 2 and 3
platforms. Besides that there are also a few patches for the AMD
IOMMU which prepare the driver for adding intr-remapping support and a
couple of fixes."
* tag 'iommu-updates-v3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/amd: Fix section mismatch
iommu/amd: Move interrupt setup code into seperate function
iommu/amd: Make sure IOMMU interrupts are re-enabled on resume
iommu/amd: Fix section warning for prealloc_protection_domains
iommu/amd: Don't initialize IOMMUv2 resources when not required
iommu/amd: Update git-tree in MAINTAINERS
iommu/tegra-gart: fix spin_unlock in map failure path
iommu/amd: Fix double free of mem-region in error-path
iommu/amd: Split amd_iommu_init function
ARM: IOMMU: Tegra30: Add iommu_ops for SMMU driver
ARM: IOMMU: Tegra20: Add iommu_ops for GART driver
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
Pull PCI changes (including maintainer change) from Jesse Barnes:
"This pull has some good cleanups from Bjorn and Yinghai, as well as
some more code from Yinghai to better handle resource re-allocation
when enabled.
There's also a new initcall_debug feature from Arjan which will print
out quirk timing information to help identify slow quirks for fixing
or refinement (Yinghai sent in a few patches to do just that once the
new debug code landed).
Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas.
He's been a core PCI and Linux contributor for some time now, and has
kindly volunteered to take over. I just don't feel I have the time
for PCI review and work that it deserves lately (I've taken on some
other projects), and haven't been as responsive lately as I'd like, so
I approached Bjorn asking if he'd like to manage things. He's going
to give it a try, and I'm confident he'll do at least as well as I
have in keeping the tree managed, patches flowing, and keeping things
stable."
Fix up some fairly trivial conflicts due to other cleanups (mips device
resource fixup cleanups clashing with list handling cleanup, ppc iseries
removal clashing with pci_probe_only cleanup etc)
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits)
PCI: Bjorn gets PCI hotplug too
PCI: hand PCI maintenance over to Bjorn Helgaas
unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h
sparc/PCI: convert devtree and arch-probed bus addresses to resource
powerpc/PCI: allow reallocation on PA Semi
powerpc/PCI: convert devtree bus addresses to resource
powerpc/PCI: compute I/O space bus-to-resource offset consistently
arm/PCI: don't export pci_flags
PCI: fix bridge I/O window bus-to-resource conversion
x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()'
PCI / PCIe: Introduce command line option to disable ARI
PCI: make acpihp use __pci_remove_bus_device instead
PCI: export __pci_remove_bus_device
PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge
PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device
PCI: print out PCI device info along with duration
PCI: Move "pci reassigndev resource alignment" out of quirks.c
PCI: Use class for quirk for usb host controller fixup
PCI: Use class for quirk for ti816x class fixup
PCI: Use class for quirk for intel e100 interrupt fixup
Pull fbdev updates for 3.4 from Florian Tobias Schandinat:
- drivers for Samsung Exynos MIPI DSI and display port
- i740fb to support those old Intel chips
- large updates to OMAP, viafb and sh_mobile_lcdcfb
- some updates to s3c-fb and udlfb, few patches to others
Fix up conflicts in drivers/video/udlfb.c due to Key Sievers' fix making
it in twice.
* tag 'fbdev-updates-for-3.4' of git://github.com/schandinat/linux-2.6: (156 commits)
Revert "video:uvesafb: Fix oops that uvesafb try to execute NX-protected page"
OMAPDSS: register dss drivers in module init
video: pxafb: add clk_prepare/clk_unprepare calls
fbdev: bfin_adv7393fb: Drop needless include
fbdev: sh_mipi_dsi: add extra phyctrl for sh_mipi_dsi_info
fbdev: remove dependency of FB_SH_MOBILE_MERAM from FB_SH_MOBILE_LCDC
Revert "MAINTAINERS: add entry for exynos mipi display drivers"
fbdev: da8xx: add support for SP10Q010 display
fbdev: da8xx:: fix reporting of the display timing info
drivers/video/pvr2fb.c: ensure arguments to request_irq and free_irq are compatible
OMAPDSS: APPLY: fix clearing shadow dirty flag with manual update
fbdev: sh_mobile_meram: Implement system suspend/resume
fbdev: sh_mobile_meram: Remove unneeded sanity checks
fbdev: sh_mobile_meram: Don't perform update in register operation
arm: mach-shmobile: Constify sh_mobile_meram_cfg structures
fbdev: sh_mobile_lcdc: Don't store copy of platform data
fbdev: sh_mobile_meram: Remove unused sh_mobile_meram_icb_cfg fields
arm: mach-shmobile: Don't set MERAM ICB numbers in platform data
fbdev: sh_mobile_meram: Allocate ICBs automatically
fbdev: sh_mobile_meram: Use genalloc to manage MERAM allocation
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"- we finally merged driver for USB version of Synaptics touchpads
(I guess most commonly found in IBM/Lenovo keyboard/touchpad combo);
- a bunch of new drivers for embedded platforms (Cypress
touchscreens, DA9052 OnKey, MAX8997-haptic, Ilitek ILI210x
touchscreens, TI touchscreen);
- input core allows clients to specify desired clock source for
timestamps on input events (EVIOCSCLOCKID ioctl);
- input core allows querying state of all MT slots for given event
code via EVIOCGMTSLOTS ioctl;
- various driver fixes and improvements."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (45 commits)
Input: ili210x - add support for Ilitek ILI210x based touchscreens
Input: altera_ps2 - use of_match_ptr()
Input: synaptics_usb - switch to module_usb_driver()
Input: convert I2C drivers to use module_i2c_driver()
Input: convert SPI drivers to use module_spi_driver()
Input: omap4-keypad - move platform_data to <linux/platform_data>
Input: kxtj9 - who_am_i check value and initial data rate fixes
Input: add driver support for MAX8997-haptic
Input: tegra-kbc - revise device tree support
Input: of_keymap - add device tree bindings for simple key matrices
Input: wacom - fix physical size calculation for 3rd-gen Bamboo
Input: twl4030-vibra - really switch from #if to #ifdef
Input: hp680_ts_input - ensure arguments to request_irq and free_irq are compatible
Input: max8925_onkey - avoid accessing input device too early
Input: max8925_onkey - allow to be used as a wakeup source
Input: atmel-wm97xx - convert to dev_pm_ops
Input: atmel-wm97xx - set driver owner
Input: add cyttsp touchscreen maintainer entry
Input: cyttsp - remove useless checks in cyttsp_probe()
Input: usbtouchscreen - add support for Data Modul EasyTouch TP 72037
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm
Pull cleancache changes from Konrad Rzeszutek Wilk:
"This has some patches for the cleancache API that should have been
submitted a _long_ time ago. They are basically cleanups:
- rename of flush to invalidate
- moving reporting of statistics into debugfs
- use __read_mostly as necessary.
Oh, and also the MAINTAINERS file change. The files (except the
MAINTAINERS file) have been in #linux-next for months now. The late
addition of MAINTAINERS file is a brain-fart on my side - didn't
realize I needed that just until I was typing this up - and I based
that patch on v3.3 - so the tree is on top of v3.3."
* tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm:
MAINTAINERS: Adding cleancache API to the list.
mm: cleancache: Use __read_mostly as appropiate.
mm: cleancache: report statistics via debugfs instead of sysfs.
mm: zcache/tmem/cleancache: s/flush/invalidate/
mm: cleancache: s/flush/invalidate/
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc merge from Benjamin Herrenschmidt:
"Here's the powerpc batch for this merge window. It is going to be a
bit more nasty than usual as in touching things outside of
arch/powerpc mostly due to the big iSeriesectomy :-) We finally got
rid of the bugger (legacy iSeries support) which was a PITA to
maintain and that nobody really used anymore.
Here are some of the highlights:
- Legacy iSeries is gone. Thanks Stephen ! There's still some bits
and pieces remaining if you do a grep -ir series arch/powerpc but
they are harmless and will be removed in the next few weeks
hopefully.
- The 'fadump' functionality (Firmware Assisted Dump) replaces the
previous (equivalent) "pHyp assisted dump"... it's a rewrite of a
mechanism to get the hypervisor to do crash dumps on pSeries, the
new implementation hopefully being much more reliable. Thanks
Mahesh Salgaonkar.
- The "EEH" code (pSeries PCI error handling & recovery) got a big
spring cleaning, motivated by the need to be able to implement a
new backend for it on top of some new different type of firwmare.
The work isn't complete yet, but a good chunk of the cleanups is
there. Note that this adds a field to struct device_node which is
not very nice and which Grant objects to. I will have a patch soon
that moves that to a powerpc private data structure (hopefully
before rc1) and we'll improve things further later on (hopefully
getting rid of the need for that pointer completely). Thanks Gavin
Shan.
- I dug into our exception & interrupt handling code to improve the
way we do lazy interrupt handling (and make it work properly with
"edge" triggered interrupt sources), and while at it found & fixed
a wagon of issues in those areas, including adding support for page
fault retry & fatal signals on page faults.
- Your usual random batch of small fixes & updates, including a bunch
of new embedded boards, both Freescale and APM based ones, etc..."
I fixed up some conflicts with the generalized irq-domain changes from
Grant Likely, hopefully correctly.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits)
powerpc/ps3: Do not adjust the wrapper load address
powerpc: Remove the rest of the legacy iSeries include files
powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces
init: Remove CONFIG_PPC_ISERIES
powerpc: Remove FW_FEATURE ISERIES from arch code
tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable
powerpc/spufs: Fix double unlocks
powerpc/5200: convert mpc5200 to use of_platform_populate()
powerpc/mpc5200: add options to mpc5200_defconfig
powerpc/mpc52xx: add a4m072 board support
powerpc/mpc5200: update mpc5200_defconfig to fit for charon board
Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup
powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board
powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board
MAINTAINERS: Update PowerPC 4xx tree
powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board
powerpc: document the FSL MPIC message register binding
powerpc: add support for MPIC message register API
powerpc/fsl: Added aliased MSIIR register address to MSI node in dts
powerpc/85xx: mpc8548cds - add 36-bit dts
Pull irq_domain support for all architectures from Grant Likely:
"Generialize powerpc's irq_host as irq_domain
This branch takes the PowerPC irq_host infrastructure (reverse mapping
from Linux IRQ numbers to hardware irq numbering), generalizes it,
renames it to irq_domain, and makes it available to all architectures.
Originally the plan has been to create an all-new irq_domain
implementation which addresses some of the powerpc shortcomings such
as not handling 1:1 mappings well, but doing that proved to be far
more difficult and invasive than generalizing the working code and
refactoring it in-place. So, this branch rips out the 'new'
irq_domain and replaces it with the modified powerpc version (in a
fully bisectable way of course). It converts all users over to the
new API and makes irq_domain selectable on any architecture.
No architecture is forced to enable irq_domain, but the infrastructure
is required for doing OpenFirmware style irq translations. It will
even work on SPARC even though SPARC has it's own mechanism for
translating irqs at boot time. MIPS, microblaze, embedded x86 and c6x
are converted too.
The resulting irq_domain code is probably still too verbose and can be
optimized more, but that can be done incrementally and is a task for
follow-on patches."
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: (31 commits)
dt: fix twl4030 for non-dt compile on x86
mfd: twl-core: Add IRQ_DOMAIN dependency
devicetree: Add empty of_platform_populate() for !CONFIG_OF_ADDRESS (sparc)
irq_domain: Centralize definition of irq_dispose_mapping()
irq_domain/mips: Allow irq_domain on MIPS
irq_domain/x86: Convert x86 (embedded) to use common irq_domain
ppc-6xx: fix build failure in flipper-pic.c and hlwd-pic.c
irq_domain/microblaze: Convert microblaze to use irq_domains
irq_domain/powerpc: Replace custom xlate functions with library functions
irq_domain/powerpc: constify irq_domain_ops
irq_domain/c6x: Use library of xlate functions
irq_domain/c6x: constify irq_domain structures
irq_domain/c6x: Convert c6x to use generic irq_domain support.
irq_domain: constify irq_domain_ops
irq_domain: Create common xlate functions that device drivers can use
irq_domain: Remove irq_domain_add_simple()
irq_domain: Remove 'new' irq_domain in favour of the ppc one
mfd: twl-core.c: Fix the number of interrupts managed by twl4030
of/address: add empty static inlines for !CONFIG_OF
irq_domain: Add support for base irq and hwirq in legacy mappings
Though we may as well just merge this entry with the main PCI one at
this point. Unless Alex returns one day at least...
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
This reverts commit 5eb1eb4ea102c9aed8a791892a5b0431b058f20e.
The commit above breaks alphabetical ordering and I have the same
entry at the correct position in my tree. Not reverting this one
would result in duplicated maintainer entries.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
I find I have less and less time to manage PCI patches and so I've been
looking for a replacement. Bjorn has been substitute maintainer several
times, and acts as de-facto maintainer for certain portions anyway.
He's kindly agreed to take over in my stead; this makes it official.
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org.
Pull TTY/serial patches from Greg KH:
"tty and serial merge for 3.4-rc1
Here's the big serial and tty merge for the 3.4-rc1 tree.
There's loads of fixes and reworks in here from Jiri for the tty
layer, and a number of patches from Alan to help try to wrestle the vt
layer into a sane model.
Other than that, lots of driver updates and fixes, and other minor
stuff, all detailed in the shortlog."
* tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (132 commits)
serial: pxa: add clk_prepare/clk_unprepare calls
TTY: Wrong unicode value copied in con_set_unimap()
serial: PL011: clear pending interrupts
serial: bfin-uart: Don't access tty circular buffer in TX DMA interrupt after it is reset.
vt: NULL dereference in vt_do_kdsk_ioctl()
tty: serial: vt8500: fix annotations for probe/remove
serial: remove back and forth conversions in serial_out_sync
serial: use serial_port_in/out vs serial_in/out in 8250
serial: introduce generic port in/out helpers
serial: reduce number of indirections in 8250 code
serial: delete useless void casts in 8250.c
serial: make 8250's serial_in shareable to other drivers.
serial: delete last unused traces of pausing I/O in 8250
pch_uart: Add module parameter descriptions
pch_uart: Use existing default_baud in setup_console
pch_uart: Add user_uartclk parameter
pch_uart: Add Fish River Island II uart clock quirks
pch_uart: Use uartclk instead of base_baud
mpc5200b/uart: select more tolerant uart prescaler on low baudrates
tty: moxa: fix bit test in moxa_start()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull big staging driver updates from Greg KH:
"Here is the big drivers/staging/ merge for 3.4-rc1
Lots of new driver updates here, with the addition of a few new ones,
and only one moving out of the staging tree to the "real" part of the
kernel (the hyperv scsi driver, acked by the scsi maintainer).
There are also loads of cleanups, fixes, and other minor things in
here, all self-contained in the drivers/staging/ tree.
Overall we reversed the recent trend by adding more lines than we
removed:
379 files changed, 37952 insertions(+), 14153 deletions(-)"
* tag 'staging-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (360 commits)
staging/zmem: Use lockdep_assert_held instead of spin_is_locked
Staging: rtl8187se: r8180_wx.c: Cleaned up comments
Staging: rtl8187se: r8180_wx.c: Removed old comments
Staging: rtl8187se: r8180_dm.c: Removed old comments
Staging: android: ram_console.c:
Staging: rtl8187se: r8180_dm.c: Fix comments
Staging: rtl8187se: r8180_dm.c: Fix spacing issues
Staging: rtl8187se: r8180_dm.c Fixed indentation issues
Staging: rtl8187se: r8180_dm.c: Fix brackets
Staging: rtl8187se: r8180_dm.c: Removed spaces before tab stop
staging: vme: fix section mismatches in linux-next 20120314
Staging: rtl8187se: r8180_core.c: Fix some long line issues
Staging: rtl8187se: r8180_core.c: Fix some spacing issues
Staging: rtl8187se: r8180_core.c: Removed trailing spaces
staging: mei: remove driver internal versioning
Staging: rtl8187se: r8180_core.c: Cleaned up if statement
staging: ozwpan depends on NET
staging: ozwpan: added maintainer for ozwpan driver
staging/mei: propagate error codes up in the write flow
drivers:staging:mei Fix some typos in staging/mei
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
Stephen is taking over the main tegra repo, so change the entry to point at his tree on kernel.org
Also, document the patchwork URL.
.. and electing myself as the maintainer.
Acked-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Move the powerpc-4xx.git tree back to kernel.org
Signed-off-by: Josh Boyer <jwboyer@gmail.com>
