path: root/MAINTAINERS
2012-08-15MAINTAINERS: Theodore Ts'o is taking over the random driverTheodore Ts'o
commit 330e0a01d54c2b8606c56816f99af6ebc58ec92c upstream. Matt Mackall stepped down as the /dev/random driver maintainer last year, so Theodore Ts'o is taking back the /dev/random driver. Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-12MAINTAINERS: Add myself as the cpufreq maintainerRafael J. Wysocki
Since cpufreq has no official maintainer at the moment, I'm willing to maintain it along some other power management core code I've been maintaining already. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10MAINTAINERS: add maintainer for LED subsystemBryan Wu
Add Bryan Wu as the primary maintainer for drivers/leds Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-04CPU frequency drivers MAINTAINERS updateDave Jones
Remove myself as cpufreq maintainer. x86 driver changes can go through the regular x86/ACPI trees. ARM driver changes through the ARM trees. cpufreq core changes are rare these days, and can just go to lkml/direct. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-26MAINTAINERS: update sctp maintainer addressVlad Yasevich
Update my email address. Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix namespace init and cleanup in phonet to fix some oopses, from Eric W. Biederman. 2) Missing kfree_skb() in AF_KEY, from Julia Lawall. 3) Refcount leak and source address handling fix in l2tp from James Chapman. 4) Memory leak fix in CAIF from Tomasz Gregorek. 5) When routes are cloned from ipv6 addrconf routes, we don't process expirations properly. Fix from Gao Feng. 6) Fix panic on DMA errors in atl1 driver, from Tony Zelenoff. 7) Only enable interrupts in 8139cp driver after we've registered the IRQ handler. From Jason Wang. 8) Fix too many reads of KS_CIDER register in ks8851 during probe, fixing crashes on spurious interrupts. From Matt Renzelmann. 9) Missing include in ath5k driver and missing iounmap on probe failure, from Jonathan Bither. 10) Fix RX packet handling in smsc911x driver, from Will Deacon. 11) Fix ixgbe WoL on fiber by leaving the laser on during shutdown. 12) ks8851 needs MAX_RECV_FRAMES increased otherwise the internal MAC buffers are easily overflown. Fix from Davide Cimingahi. 13) Fix memory leaks in peak_usb CAN driver, from Jesper Juhl. 14) gred packet scheduler can dump in WRED more when doing a netlink dump. Fix from David Ward. 15) Fix MTU in USB smsc75xx driver, from Stephane Fillod. 16) Dummy device needs ->ndo_uninit handler to properly handle ->ndo_init failures. From Hiroaki SHIMODA. 17) Fix TX fragmentation in ath9k driver, from Sujith Manoharan. 18) Missing RTNL lock in ixgbe PM resume, from Benjamin Poirier. 19) Missing iounmap in farsync WAN driver, from Julia Lawall. 20) With LRO/GRO, tcp_grow_window() is easily tricked into not growing the receive window properly, and this hurts performance. Fix from Eric Dumazet. 21) Network namespace init failure can leak net_generic data, fix from Julian Anastasov. 22) Fix skb_over_panic due to mis-accounting in TCP for partially ACK'd SKBs. From Eric Dumazet. 23) New IDs for qmi_wwan driver, from Bjørn Mork. 24) Fix races in ax25_exit(), from Eric W. Biederman. 25) IPV6 TCP doesn't handle TCP_MAXSEG socket option properly, copy over logic from the IPV4 side. From Neal Cardwell. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (59 commits) tcp: fix TCP_MAXSEG for established IPv6 passive sockets drivers/net: Do not free an IRQ if its request failed drop_monitor: allow more events per second ks8851: Fix request_irq/free_irq mismatch net/hyperv: Adding cancellation to ensure rndis filter is closed ks8851: Fix mutex deadlock in ks8851_net_stop() net ax25: Reorder ax25_exit to remove races. icplus: fix interrupt for IC+ 101A/G and 1001LF net: qmi_wwan: support Sierra Wireless MC77xx devices in QMI mode bnx2x: off by one in bnx2x_ets_e3b0_sp_pri_to_cos_set() ksz884x: don't copy too much in netdev_set_mac_address() tcp: fix retransmit of partially acked frames netns: do not leak net_generic data on failed init net/sock.h: fix sk_peek_off kernel-doc warning tcp: fix tcp_grow_window() for large incoming frames drivers/net/wan/farsync.c: add missing iounmap davinci_mdio: Fix MDIO timeout check ipv6: clean up rt6_clean_expires ipv6: fix rt6_update_expires arcnet: rimi: Fix device name in debug output ...
2012-04-18Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2012-04-17MAINTAINERS: Add maintainer for iwlwifiWey-Yi Guy
Add Johannes Berg as the primary maintainer for iwlwifi driver Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-16Documentation: maintainer changeRandy Dunlap
I'm dropping off as Documentation/ maintainer. Rob Landley has agreed to take it over. Thanks, Rob. I'll still be around reviewing patches and testing. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-13drivers/net/ethernet/xilinx/axi ethernet: Correct CopyrightMichal Simek
Also fix MAINTAINERS file to reflect autorship. Daniel and Ariane changed coding style but not any functional changes in the driver itself. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-12Merge tag 'staging-3.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree fixes from Greg KH: "Here are a number of bugfixes for the drivers/staging/ portion of the kernel that have been reported recently. Nothing major here, with maybe the exception of the ramster code can now be built so it is enabled in the build again, and lots of memory leaks that people like to have fixed on their systems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'staging-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: android: fix mem leaks in __persistent_ram_init() staging: vt6656: Don't leak memory in drivers/staging/vt6656/ioctl.c::private_ioctl() staging: iio: hmc5843: Fix crash in probe function. staging/xgifb: fix display on XGI Volari Z11m cards Staging: android: timed_gpio: Fix resource leak in timed_gpio_probe error paths android: make persistent_ram based drivers depend on HAVE_MEMBLOCK staging: iio: ak8975: Remove i2c client data corruption staging: drm/omap: move where DMM driver is registered staging: zsmalloc: fix memory leak Staging: rts_pstor: off by one in for loop staging: ozwpan: Added new maintainer for ozwpan staging:rts_pstor:Avoid "Bad target number" message when probing driver staging:rts_pstor:Fix possible panic by NULL pointer dereference Staging: vt6655-6: check keysize before memcpy() staging/media/as102: Don't call release_firmware() on uninitialized variable staging:iio:core add missing increment of loop index in iio_map_array_unregister() staging: ramster: unbreak my heart staging/vme: Fix module parameters staging: sep: Fix sign of error
2012-04-12Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge fixes from Andrew Morton. * emailed from Andrew Morton <akpm@linux-foundation.org>: (14 patches) panic: fix stack dump print on direct call to panic() drivers/rtc/rtc-pl031.c: enable clock on all ST variants Revert "mm: vmscan: fix misused nr_reclaimed in shrink_mem_cgroup_zone()" hugetlb: fix race condition in hugetlb_fault() drivers/rtc/rtc-twl.c: use static register while reading time drivers/rtc/rtc-s3c.c: add placeholder for driver private data drivers/rtc/rtc-s3c.c: fix compilation error MAINTAINERS: add PCDP console maintainer memcg: do not open code accesses to res_counter members drivers/rtc/rtc-efi.c: fix section mismatch warning drivers/rtc/rtc-r9701.c: reset registers if invalid values are detected drivers/char/random.c: fix boot id uniqueness race memcg: fix broken boolen expression memcg: fix up documentation on global LRU
2012-04-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix bluetooth userland regression reported by Keith Packard, from Gustavo Padovan. 2) Revert ath9k PS idle change, from Sujith Manoharan. 3) Correct default TCP memory limits (again), from Eric Dumazet. 4) Fix tcp_rcv_rtt_update() accidental use of unscaled RTT, from Neal Cardwell. 5) We made a facility for layers like wireless to say how much tailroom they need in the SKB for link layer stuff such as wireless encryption etc., but TCP works hard to fill every SKB out to the end defeating this specification. This leads to every TCP packet getting reallocated by the wireless code in order to have the right amount of tailroom available. Fix TCP to only fill SKBs out to the real amount of data area it asked for during the allocation, this way it won't eat into the slack added for the device's tailroom needs. Reported by Marc Merlin and fixed by Eric Dumazet. 6) Leaks, endian bugs, and new device IDs in bluetooth from Santosh Nayak, João Paulo Rechi Vita, Cho, Yu-Chen, Andrei Emeltchenko, AceLan Kao, and Andrei Emeltchenko. 7) OOPS on tty_close fix in bluetooth's hci_ldisc from Johan Hovold. 8) netfilter erroneously scales TCP window twice, fix from Changli Gao. 9) Memleak fix in wext-core from Julia Lawall. 10) Consistently handle invalid TCP packets in ipv4 vs. ipv6 conntrack, from Jozsef Kadlecsik. 11) Validate IP header length properly in netfilter conntrack's ipv4_get_l4proto(). * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (39 commits) NFC: Fix the LLCP Tx fragmentation loop rtlwifi: Add missing DMA buffer unmapping for PCI drivers rtlwifi: Preallocate USB read buffers and eliminate kalloc in read routine tcp: avoid order-1 allocations on wifi and tx path net: allow pskb_expand_head() to get maximum tailroom bridge: Do not send queries on multicast group leaves MAINTAINERS: Mark NATSEMI driver as orphan'd. tcp: fix tcp_rcv_rtt_update() use of an unscaled RTT sample tcp: restore correct limit Revert "ath9k: fix going to full-sleep on PS idle" rt2x00: Fix rfkill_polling register function. bcma: fix build error on MIPS; implicit pcibios_enable_device netfilter: nf_conntrack: fix incorrect logic in nf_conntrack_init_net netfilter: nf_ct_ipv4: packets with wrong ihl are invalid netfilter: nf_ct_ipv4: handle invalid IPv4 and IPv6 packets consistently net/wireless/wext-core.c: add missing kfree rtlwifi: Fix oops on rate-control failure mac80211: Convert WARN_ON to WARN_ON_ONCE rtlwifi: rtl8192de: Fix firmware initialization nl80211: ensure interface is up in various APIs ...
2012-04-12MAINTAINERS: add PCDP console maintainerKhalid Aziz
Add missing maintainer info for PCDP console code. Signed-off-by: Khalid Aziz <khalid.aziz@hp.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12Merge branch 'master' of ↵John W. Linville
2012-04-11Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: - A series of fixes for Conexant 20549 HD-audio codec chip - A workaround for HDMI hotplug debug prints that annoyed people - A fix for the new support of platform DAPM contexts - Many driver-specific minor fixes * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - hide HDMI/ELD printks unless snd.debug=2 ALSA: sound/isa/sscape.c: add missing resource-release code sound: sound/oss/msnd_pinnacle.c: add vfrees ALSA: hda - clean up CX20549 test mixer setup ALSA: hda - CX20549 doesn't need pin_amp_workaround. ALSA: hda - Remove CD control from model=benq for CX20549 ALSA: hda - fix record volume controls of CX20459 ("Venice") ALSA: hda - Rename capture sources of CX20549 to match common conventions ALSA: hda - Fix proc output for ADC amp values of CX20549 ASoC: tegra: fix i2s compilation when !CONFIG_DEBUG_FS ASoC: set idle_bias_off=1 for all platform DAPM contexts ASoC: imx-audmux: Check for NULL pointer ASoC: imx-audmux: Fix ssi port numbers in sysfs ASoC: ak4642: fixup: mute needs +1 step MAINTAINERS: Don't list everyone working on Wolfson drivers MAINTAINERS: Add missing ASoC OMAP co-maintainer ASoC: pxa: pxa2xx-i2s: add io.h for IOMEM macro ASoC: tegra: ensure clocks are enabled when touching registers ASoC: sgtl5000: Enable VAG when DAC/ADC up ALSA: asihpi - fix return value of hpios_locked_mem_alloc()
2012-04-10MAINTAINERS: Mark NATSEMI driver as orphan'd.David S. Miller
After discussion with Tim Hockin. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10staging: ozwpan: Added new maintainer for ozwpanChris Kelly
Added Rupesh Gujare to MAINTAINERS file and contact in TODO file for ozwpan driver. Signed-off-by: Chris Kelly <ckelly@ozmodevices.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
2012-04-06Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & Power Management patches from Len Brown: "Two fixes for cpuidle merge-window changes, plus a URL fix in MAINTAINERS" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: MAINTAINERS: Update git url for ACPI cpuidle: Fix panic in CPU off-lining with no idle driver ACPI processor: Use safe_halt() rather than halt() in acpi_idle_play_dead()
2012-04-06MAINTAINERS: Update git url for ACPIIgor Murzov
Signed-off-by: Igor Murzov <e-mail@date.by> Signed-off-by: Len Brown <len.brown@intel.com>
2012-04-06Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull arch/tile bug fixes from Chris Metcalf: "This includes Paul Gortmaker's change to fix the <asm/system.h> disintegration issues on tile, a fix to unbreak the tilepro ethernet driver, and a backlog of bugfix-only changes from internal Tilera development over the last few months. They have all been to LKML and on linux-next for the last few days. The EDAC change to MAINTAINERS is an oddity but discussion on the linux-edac list suggested I ask you to pull that change through my tree since they don't have a tree to pull edac changes from at the moment." * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (39 commits) drivers/net/ethernet/tile: fix netdev_alloc_skb() bombing MAINTAINERS: update EDAC information tilepro ethernet driver: fix a few minor issues tile-srom.c driver: minor code cleanup edac: say "TILEGx" not "TILEPro" for the tilegx edac driver arch/tile: avoid accidentally unmasking NMI-type interrupt accidentally arch/tile: remove bogus performance optimization arch/tile: return SIGBUS for addresses that are unaligned AND invalid arch/tile: fix finv_buffer_remote() for tilegx arch/tile: use atomic exchange in arch_write_unlock() arch/tile: stop mentioning the "kvm" subdirectory arch/tile: export the page_home() function. arch/tile: fix pointer cast in cacheflush.c arch/tile: fix single-stepping over swint1 instructions on tilegx arch/tile: implement panic_smp_self_stop() arch/tile: add "nop" after "nap" to help GX idle power draw arch/tile: use proper memparse() for "maxmem" options arch/tile: fix up locking in pgtable.c slightly arch/tile: don't leak kernel memory when we unload modules arch/tile: fix bug in delay_backoff() ...
2012-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix inaccuracies in network driver interface documentation, from Ben Hutchings. 2) Fix handling of negative offsets in BPF JITs, from Jan Seiffert. 3) Compile warning, locking, and refcounting fixes in netfilter's xt_CT, from Pablo Neira Ayuso. 4) phonet sendmsg needs to validate user length just like any other datagram protocol, fix from Sasha Levin. 5) Ipv6 multicast code uses wrong loop index, from RongQing Li. 6) Link handling and firmware fixes in bnx2x driver from Yaniv Rosner and Yuval Mintz. 7) mlx4 erroneously allocates 4 pages at a time, regardless of page size, fix from Thadeu Lima de Souza Cascardo. 8) SCTP socket option wasn't extended in a backwards compatible way, fix from Thomas Graf. 9) Add missing address change event emissions to bonding, from Shlomo Pongratz. 10) /proc/net/dev regressed because it uses a private offset to track where we are in the hash table, but this doesn't track the offset pullback that the seq_file code does resulting in some entries being missed in large dumps. Fix from Eric Dumazet. 11) do_tcp_sendpage() unloads the send queue way too fast, because it invokes tcp_push() when it shouldn't. Let the natural sequence generated by the splice paths, and the assosciated MSG_MORE settings, guide the tcp_push() calls. Otherwise what goes out of TCP is spaghetti and doesn't batch effectively into GSO/TSO clusters. From Eric Dumazet. 12) Once we put a SKB into either the netlink receiver's queue or a socket error queue, it can be consumed and freed up, therefore we cannot touch it after queueing it like that. Fixes from Eric Dumazet. 13) PPP has this annoying behavior in that for every transmit call it immediately stops the TX queue, then calls down into the next layer to transmit the PPP frame. But if that next layer can take it immediately, it just un-stops the TX queue right before returning from the transmit method. Besides being useless work, it makes several facilities unusable, in particular things like the equalizers. Well behaved devices should only stop the TX queue when they really are full, and in PPP's case when it gets backlogged to the downstream device. David Woodhouse therefore fixed PPP to not stop the TX queue until it's downstream can't take data any more. 14) IFF_UNICAST_FLT got accidently lost in some recent stmmac driver changes, re-add. From Marc Kleine-Budde. 15) Fix link flaps in ixgbe, from Eric W. Multanen. 16) Descriptor writeback fixes in e1000e from Matthew Vick. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) net: fix a race in sock_queue_err_skb() netlink: fix races after skb queueing doc, net: Update ndo_start_xmit return type and values doc, net: Remove instruction to set net_device::trans_start doc, net: Update netdev operation names doc, net: Update documentation of synchronisation for TX multiqueue doc, net: Remove obsolete reference to dev->poll ethtool: Remove exception to the requirement of holding RTNL lock MAINTAINERS: update for Marvell Ethernet drivers bonding: properly unset current_arp_slave on slave link up phonet: Check input from user before allocating tcp: tcp_sendpages() should call tcp_push() once ipv6: fix array index in ip6_mc_add_src() mlx4: allocate just enough pages instead of always 4 pages stmmac: re-add IFF_UNICAST_FLT for dwmac1000 bnx2x: Clear MDC/MDIO warning message bnx2x: Fix BCM57711+BCM84823 link issue bnx2x: Clear BCM84833 LED after fan failure bnx2x: Fix BCM84833 PHY FW version presentation bnx2x: Fix link issue for BCM8727 boards. ...
2012-04-05MAINTAINERS: update for Marvell Ethernet driversstephen hemminger
Marvell has agreed to do maintenance on the sky2 driver. * Add the developer to the maintainers file * Remove the old reference to the long gone (sk98lin) driver * Rearrange to fit current topic organization Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-05Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge batch of fixes from Andrew Morton: "The simple_open() cleanup was held back while I wanted for laggards to merge things. I still need to send a few checkpoint/restore patches. I've been wobbly about merging them because I'm wobbly about the overall prospects for success of the project. But after speaking with Pavel at the LSF conference, it sounds like they're further toward completion than I feared - apparently davem is at the "has stopped complaining" stage regarding the net changes. So I need to go back and re-review those patchs and their (lengthy) discussion." * emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches) memcg swap: use mem_cgroup_uncharge_swap fix backlight: add driver for DA9052/53 PMIC v1 C6X: use set_current_blocked() and block_sigmask() MAINTAINERS: add entry for sparse checker MAINTAINERS: fix REMOTEPROC F: typo alpha: use set_current_blocked() and block_sigmask() simple_open: automatically convert to simple_open() scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open() libfs: add simple_open() hugetlbfs: remove unregister_filesystem() when initializing module drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback fs/xattr.c:setxattr(): improve handling of allocation failures fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed fs/xattr.c: suppress page allocation failure warnings from sys_listxattr() sysrq: use SEND_SIG_FORCED instead of force_sig() proc: fix mount -t proc -o AAA
2012-04-05MAINTAINERS: add entry for sparse checkerChristopher Li
Signed-off-by: Christopher Li <sparse@chrisli.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-05MAINTAINERS: fix REMOTEPROC F: typoJoe Perches
remoteproc.txt should have been .h Signed-off-by: Joe Perches <joe@perches.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-04MAINTAINERS: Don't list everyone working on Wolfson driversMark Brown
Rather than listing every single person who works on the drivers include the mailing list where they can all be found. Leave myself as a human contact. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-03MAINTAINERS: Add missing ASoC OMAP co-maintainerJarkko Nikula
Peter Ujfalusi has been co-maintaining sound/soc/omap/ for years but was missing from this MAINTAINERS entry. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Provide device string properly for USB i2400m wimax devices, also don't OOPS when providing firmware string. From Phil Sutter. 2) Add support for sh_eth SH7734 chips, from Nobuhiro Iwamatsu. 3) Add another device ID to USB zaurus driver, from Guan Xin. 4) Loop index start in pool vector iterator is wrong causing MAC to not get configured in bnx2x driver, fix from Dmitry Kravkov. 5) EQL driver assumes HZ=100, fix from Eric Dumazet. 6) Now that skb_add_rx_frag() can specify the truesize increment separately, do so in f_phonet and cdc_phonet, also from Eric Dumazet. 7) virtio_net accidently uses net_ratelimit() not only on the kernel warning but also the statistic bump, fix from Rick Jones. 8) ip_route_input_mc() uses fixed init_net namespace, oops, use dev_net(dev) instead. Fix from Benjamin LaHaise. 9) dev_forward_skb() needs to clear the incoming interface index of the SKB so that it looks like a new incoming packet, also from Benjamin LaHaise. 10) iwlwifi mistakenly initializes a channel entry as 2GHZ instead of 5GHZ, fix from Stanislav Yakovlev. 11) Missing kmalloc() return value checks in orinoco, from Santosh Nayak. 12) ath9k doesn't check for HT capabilities in the right way, it is checking ht_supported instead of the ATH9K_HW_CAP_HT flag. Fix from Sujith Manoharan. 13) Fix x86 BPF JIT emission of 16-bit immediate field of AND instructions, from Feiran Zhuang. 14) Avoid infinite loop in GARP code when registering sysfs entries. From David Ward. 15) rose protocol uses memcpy instead of memcmp in a device address comparison, oops. Fix from Daniel Borkmann. 16) Fix build of lpc_eth due to dev_hw_addr_rancom() interface being renamed to eth_hw_addr_random(). From Roland Stigge. 17) Make ipv6 RTM_GETROUTE interpret RTA_IIF attribute the same way that ipv4 does. Fix from Shmulik Ladkani. 18) via-rhine has an inverted bit test, causing suspend/resume regressions. Fix from Andreas Mohr. 19) RIONET assumes 4K page size, fix from Akinobu Mita. 20) Initialization of imask register in sky2 is buggy, because bits are "or'd" into an uninitialized local variable. Fix from Lino Sanfilippo. 21) Fix FCOE checksum offload handling, from Yi Zou. 22) Fix VLAN processing regression in e1000, from Jiri Pirko. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits) sky2: dont overwrite settings for PHY Quick link tg3: Fix 5717 serdes powerdown problem net: usb: cdc_eem: fix mtu net: sh_eth: fix endian check for architecture independent usb/rtl8150 : Remove duplicated definitions rionet: fix page allocation order of rionet_active via-rhine: fix wait-bit inversion. ipv6: Fix RTM_GETROUTE's interpretation of RTA_IIF to be consistent with ipv4 net: lpc_eth: Fix rename of dev_hw_addr_random net/netfilter/nfnetlink_acct.c: use linux/atomic.h rose_dev: fix memcpy-bug in rose_set_mac_address Fix non TBI PHY access; a bad merge undid bug fix in a previous commit. net/garp: avoid infinite loop if attribute already exists x86 bpf_jit: fix a bug in emitting the 16-bit immediate operand of AND bonding: emit event when bonding changes MAC mac80211: fix oper channel timestamp updation ath9k: Use HW HT capabilites properly MAINTAINERS: adding maintainer for ipw2x00 net: orinoco: add error handling for failed kmalloc(). net/wireless: ipw2x00: fix a typo in wiphy struct initilization ...
2012-04-02MAINTAINERS: update EDAC informationChris Metcalf
The bluesmoke mailing list no longer works, so use linux-edac@vger.kernel.org. And, use a less restrictive pattern so all drivers/edac changes go to linux-edac as well. Borislav suggested I just push this through the tile tree since there is currently no core edac maintainer (emails to Doug Thompson bounce). Acked-by: Borislav Petkov <bp@amd64.org> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-04-01Merge branch 'master' of ↵David S. Miller
2012-03-29Merge branch 'for-3.4-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull urgent cgroup fix from Tejun Heo: "Commit 61d1d219c4c0 ('cgroup: remove extra calls to find_existing_css_set') which was part of the rc1 cgroup pull request made writes to the cgroup "tasks" file return an uninitialized retval on success which can cause boot failures with systemd. The change stayed in linux-next for quite some time but gcc interestingly failed to emit warning about using uninitialized variable and the problem seems to materialize only for certain build combinations (probably depends on register allocation). It's just missing local variable initialization and the fix is trivial & safe. As the problem is critical when it materializes, I'm fast-tracking it. Also included is Li's email address change in MAINTAINERS." * 'for-3.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: cgroup_attach_task() could return -errno after success cgroup: update MAINTAINERS entry
2012-03-29Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar. * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: cpusets: Remove an unused variable sched/rt: Improve pick_next_highest_task_rt() sched: Fix select_fallback_rq() vs cpu_active/cpu_online sched/x86/smp: Do not enable IRQs over calibrate_delay() sched: Fix compiler warning about declared inline after use MAINTAINERS: Update email address for SCHEDULER and PERF EVENTS
2012-03-29cgroup: update MAINTAINERS entryLi Zefan
Update my email address. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-03-28Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Some significant updates to samsung-laptop, additional hardware support for Toshibas, misc updates to various hardware and a new backlight driver for some Apple machines." Fix up trivial conflicts: geode Geos update happening next to net5501 support, and MSIC thermal platform support added twice. * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (77 commits) acer-wmi: add quirk table for video backlight vendor mode drivers/platform/x86/amilo-rfkill.c::amilo_rfkill_probe() avoid NULL deref samsung-laptop: unregister ACPI video module for some well known laptops acer-wmi: No wifi rfkill on Sony machines thinkpad-acpi: recognize Lenovo as version string in newer V-series BIOS asus-wmi: don't update power and brightness when using scalar eeepc-wmi: split et2012 specific hacks eeepc-wmi: refine quirks handling asus-nb-wmi: set panel_power correctly asus-wmi: move WAPF variable into quirks_entry asus-wmi: store backlight power status for AIO machine asus-wmi: add scalar board brightness adj. support samsung-laptop: cleanup return type: mode_t vs umode_t drivers, samsung-laptop: fix usage of isalnum drivers, samsung-laptop: fix initialization of sabi_data in sabi_set_commandb asus-wmi: on/off bit is not set when reading the value eeepc-wmi: add extra keymaps for EP121 asus-nb-wmi: ignore useless keys acer-wmi: support Lenovo ideapad S205 Brazos wifi switch acer-wmi: fix out of input parameter size when set ...
2012-03-28Merge tag 'dm-3.4-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper changes for 3.4 from Alasdair Kergon: - Update thin provisioning to support read-only external snapshot origins and discards. - A new target, dm verity, for device content validation. - Mark dm uevent and dm raid as no-longer-experimental. - Miscellaneous other fixes and clean-ups. * tag 'dm-3.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (27 commits) dm: add verity target dm bufio: prefetch dm thin: add pool target flags to control discard dm thin: support discards dm thin: prepare to support discard dm thin: use dm_target_offset dm thin: support read only external snapshot origins dm thin: relax hard limit on the maximum size of a metadata device dm persistent data: remove space map ref_count entries if redundant dm thin: commit outstanding data every second dm: reject trailing characters in sccanf input dm raid: handle failed devices during start up dm thin metadata: pass correct space map to dm_sm_root_size dm persistent data: remove redundant value_size arg from value_ptr dm mpath: detect invalid map_context dm: clear bi_end_io on remapping failure dm table: simplify call to free_devices dm thin: correct comments dm raid: no longer experimental dm uevent: no longer experimental ...
2012-03-28MAINTAINERS: adding maintainer for ipw2x00Stanislav Yakovlev
Add myself as maintainer as suggested by Stanislaw Gruszka. Signed-off-by: Stanislav Yakovlev <stas.yakovlev@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-28dm: add persistent data to MAINTAINERSAlasdair G Kergon
Update device-mapper MAINTAINERS entry to mention quilt working tree location and persistent-data subdirectory. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-27Merge branch 'master' of ↵David S. Miller
2012-03-27Merge tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "remoteproc/rpmsg: new subsystem" from Arnd Bergmann: "This new subsystem provides a common way to talk to secondary processors on an SoC, e.g. a DSP, GPU or service processor, using virtio as the transport. In the long run, it should replace a few dozen vendor specific ways to do the same thing, which all never made it into the upstream kernel. There is a broad agreement that rpmsg is the way to go here and several vendors have started working on replacing their own subsystems. Two branches each add one virtio protocol number. Fortunately the numbers were agreed upon in advance, so there are only context changes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial protocol number conflict due to the mentioned additions next to each other. * tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) remoteproc: cleanup resource table parsing paths remoteproc: remove the hardcoded vring alignment remoteproc/omap: remove the mbox_callback limitation remoteproc: remove the single rpmsg vdev limitation remoteproc: safer boot/shutdown order remoteproc: remoteproc_rpmsg -> remoteproc_virtio remoteproc: resource table overhaul rpmsg: fix build warning when dma_addr_t is 64-bit rpmsg: fix published buffer length in rpmsg_recv_done rpmsg: validate incoming message length before propagating rpmsg: fix name service endpoint leak remoteproc/omap: two Kconfig fixes remoteproc: make sure we're parsing a 32bit firmware remoteproc: s/big switch/lookup table/ remoteproc: bail out if firmware has different endianess remoteproc: don't use virtio's weak barriers rpmsg: rename virtqueue_add_buf_gfp to virtqueue_add_buf rpmsg: depend on EXPERIMENTAL remoteproc: depend on EXPERIMENTAL rpmsg: add Kconfig menu ... Conflicts: include/linux/virtio_ids.h
2012-03-27Merge tag 'maintainers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: subarch maintainer updates" from Arnd Bergmann: "This is a collection of updates to the MAINTAINERS file, separated out mostly to give an overview of what has changed regarding who does what. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" * tag 'maintainers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: tegra: update main repo and add patchwork MAINTAINERS: update MAINTAINERS email entry MAINTAINERS: update maintainer entry for pxa/hx4700 MAINTAINERS: ARM: tegra: update Stephen's email address MAINTAINERS: add TI DaVinci git tree information MAINTAINERS: mark TI DaVinci list as "moderated" MAINTAINERS: remove arch/arm/mach-mx*/ from IMX entry
2012-03-27MAINTAINERS: update Bluetooth tree locationsMarcel Holtmann
Make use of a shared tree setup to limit the confusions on which tree is current. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo@padovan.org>
2012-03-26ath5k: drop self from MAINTAINERSBob Copeland
I simply don't have any hobby hacking time after family time and non-kernel-related job time, so I resume status as part-time mailing list lurker. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-23Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge second batch of patches from Andrew Morton: - various misc things - core kernel changes to prctl, exit, exec, init, etc. - kernel/watchdog.c updates - get_maintainer - MAINTAINERS - the backlight driver queue - core bitops code cleanups - the led driver queue - some core prio_tree work - checkpatch udpates - largeish crc32 update - a new poll() feature for the v4l guys - the rtc driver queue - fatfs - ptrace - signals - kmod/usermodehelper updates - coredump - procfs updates * emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits) seq_file: add seq_set_overflow(), seq_overflow() proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate(). procfs: speed up /proc/pid/stat, statm procfs: add num_to_str() to speed up /proc/stat proc: speed up /proc/stat handling fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP coredump: remove VM_ALWAYSDUMP flag kmod: make __request_module() killable kmod: introduce call_modprobe() helper usermodehelper: ____call_usermodehelper() doesn't need do_exit() usermodehelper: kill umh_wait, renumber UMH_* constants usermodehelper: implement UMH_KILLABLE usermodehelper: introduce umh_complete(sub_info) usermodehelper: use UMH_WAIT_PROC consistently signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/ signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig() signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE Hexagon: use set_current_blocked() and block_sigmask() ...
2012-03-23MAINTAINERS: update maintainership of LTPWanlong Gao
The maintainership of LTP is out of date, so update it. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: Cyril Hrubis <chrubis@suse.cz> Signed-off-by: Caspar Zhang <caspar@casparzhang.com> Reviewed-by: Rishikesh K Rajak <rishikesh.rajak@hp.com> Acked-by: Subrata Modak <tosubrata@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: add "S: Maintained" to clkdev and clk sectionsJoe Perches
Russell King seems to be maintaining these. Might as well mark them with the appropriate S: entry Signed-off-by: Joe Perches <joe@perches.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: add status to ALPHA architectureJoe Perches
Add missing S: status line to ALPHA. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: update git urls for 2.6 deletionsJoe Perches
Update the various git urls for name changes from 2.6. Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23MAINTAINERS: update MCA sectionJoe Perches
The MCA section included a file referring to Machine Check rather than Microchannel. Rename the section to spell out Microchannel and drop the bad file reference. Reported-by: Greg Pearson <greg.pearson@hp.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
