This driver supports Freescale NFC (NAND flash controller) found on
Vybrid (VF610), MPC5125, MCF54418 and Kinetis K70.
Limitations:
- DMA and pipelining not used
- Pages larger than 2k are not supported
- No hardware ECC
The driver has only been tested on Vybrid (VF610).
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Pull x86 fixes from Ingo Molnar:
"Misc fixes: a SYSRET single-stepping fix, a dmi-scan robustization
fix, a reboot quirk and a kgdb fixlet"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
kgdb/x86: Fix reporting of 'si' in kgdb on x86_64
x86/asm/entry/64: Disable opportunistic SYSRET if regs->flags has TF set
x86/reboot: Add ASRock Q1900DC-ITX mainboard reboot quirk
MAINTAINERS: Change the x86 microcode loader maintainer
firmware: dmi_scan: Prevent dmi_num integer overflow
Pull networking fixes from David Miller:
1) Fix use-after-free with mac80211 RX A-MPDU reorder timer, from
Johannes Berg.
2) iwlwifi leaks memory every module load/unload cycles, fix from Larry
Finger.
3) Need to use for_each_netdev_safe() in rtnl_group_changelink()
otherwise we can crash, from WANG Cong.
4) mlx4 driver does register_netdev() too early in the probe sequence,
from Ido Shamay.
5) Don't allow router discovery hop limit to decrease the interface's
hop limit, from D.S. Ljungmark.
6) tx_packets and tx_bytes improperly accounted for certain classes of
USB network devices, fix from Ben Hutchings.
7) ip{6}mr_rules_init() mistakenly use plain kfree to release the ipmr
tables in the error path, they must instead use ip{6}mr_free_table().
Fix from WANG Cong.
8) cxgb4 doesn't properly quiesce all RX activity before unregistering
the netdevice. Fix from Hariprasad Shenai.
9) Fix hash corruptions in ipvlan driver, from Jiri Benc.
10) nla_memcpy(), like a real memcpy, should fully initialize the
destination buffer, even if the source attribute is smaller. Fix
from Jiri Benc.
11) Fix wrong error code returned from iucv_sock_sendmsg(). We should
use whatever sock_alloc_send_skb() put into 'err'. From Eugene
Crosser.
12) Fix slab object leak on module unload in TIPC, from Ying Xue.
13) Need a READ_ONCE() when reading the cached RX socket route in
tcp_v{4,6}_early_demux(). From Michal Kubecek.
14) Still too many problems with TPC support in the ath9k driver, so
disable it for now. From Felix Fietkau.
15) When in AP mode the rtlwifi driver can leak DMA mappings, fix from
Larry Finger.
16) Missing kzalloc() failure check in gs_usb CAN driver, from Colin Ian
King.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits)
cxgb4: Fix to dump devlog, even if FW is crashed
cxgb4: Firmware macro changes for fw verison 1.13.32.0
bnx2x: Fix kdump when iommu=on
bnx2x: Fix kdump on 4-port device
mac80211: fix RX A-MPDU session reorder timer deletion
MAINTAINERS: Update Intel Wired Ethernet Driver info
tipc: fix a slab object leak
net/usb/r8152: add device id for Lenovo TP USB 3.0 Ethernet
af_iucv: fix AF_IUCV sendmsg() errno
openvswitch: Return vport module ref before destruction
netlink: pad nla_memcpy dest buffer with zeroes
bonding: Bonding Overriding Configuration logic restored.
ipvlan: fix check for IP addresses in control path
ipvlan: do not use rcu operations for address list
ipvlan: protect against concurrent link removal
ipvlan: fix addr hash list corruption
net: fec: setup right value for mdio hold time
net: tcp6: fix double call of tcp_v6_fill_cb()
cxgb4vf: Fix sparse warnings
netns: don't clear nsid too early on removal
Update the git tree info with a recent change in tree names. Also
add our new mailing list created solely for Linux kernel patches
and kernel development, as well as the new patchwork project for
tracking patches. Lastly update the list of "reviewers" since a
couple of developers have moved on to different projects.
Made an update to the section header so that it is more manageable
going forward as we add new drivers.
Let's make it official - I've been doing this for a while now anyway.
Cc: Andreas Herrmann <herrmann.der.user@googlemail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Pull ARM SoC fixes from Olof Johansson:
"The latest and greatest fixes for ARM platform code. Worth pointing
out are:
- Lines-wise, largest is a PXA fix for dealing with interrupts on DT
that was quite broken. It's still newish code so while we could
have held this off, it seemed appropriate to include now
- Some GPIO fixes for OMAP platforms added a few lines. This was
also fixes for code recently added (this release).
- Small OMAP timer fix to behave better with partially upstreamed
platforms, which is quite welcome.
- Allwinner fixes about operating point control, reducing
overclocking in some cases for better stability.
plus a handful of other smaller fixes across the map"
* tag 'armsoc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: juno: Fix misleading name of UART reference clock
ARM: dts: sunxi: Remove overclocked/overvoltaged OPP
ARM: dts: sun4i: a10-lime: Override and remove 1008MHz OPP setting
ARM: socfpga: dts: fix spi1 interrupt
ARM: dts: Fix gpio interrupts for dm816x
ARM: dts: dra7: remove ti,hwmod property from pcie phy
ARM: OMAP: dmtimer: disable pm runtime on remove
ARM: OMAP: dmtimer: check for pm_runtime_get_sync() failure
ARM: OMAP2+: Fix socbus family info for AM33xx devices
ARM: dts: omap3: Add missing dmas for crypto
ARM: dts: rockchip: disable gmac by default in rk3288.dtsi
MAINTAINERS: add rockchip regexp to the ARM/Rockchip entry
ARM: pxa: fix pxa interrupts handling in DT
ARM: pxa: Fix typo in zeus.c
ARM: sunxi: Have ARCH_SUNXI select RESET_CONTROLLER for clock driver usage
I am familiar with these drivers and I care about them so let me add
myself as their maintainer.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Matt Fleming <matt.fleming@intel.com>
Commit c6a95dbee793 ("MAINTAINERS: add the RTC driver for the
Armada38x") typoed the pattern, fix it.
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The coraid.com email address is defunct. The old aoe support area hosted
at coraid.com is no longer up. These changes update the email and website
to current ones.
Signed-off-by: Ed Cashin <ed.cashin@acm.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB / PHY driver fixes from Greg KH:
"Here's a number of USB and PHY driver fixes for 4.0-rc5.
The largest thing here is a revert of a gadget function driver patch
that removes 500 lines of code. Other than that, it's a number of
reported bugs fixes and new quirk/id entries.
All have been in linux-next for a while"
* tag 'usb-4.0-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (33 commits)
usb: common: otg-fsm: only signal connect after switching to peripheral
uas: Add US_FL_NO_ATA_1X for Initio Corporation controllers / devices
USB: ehci-atmel: rework clk handling
MAINTAINERS: add entry for USB OTG FSM
usb: chipidea: otg: add a_alt_hnp_support response for B device
phy: omap-usb2: Fix missing clk_prepare call when using old dt name
phy: ti/omap: Fix modalias
phy: core: Fixup return value of phy_exit when !pm_runtime_enabled
phy: miphy28lp: Convert to devm_kcalloc and fix wrong sizof
phy: miphy365x: Convert to devm_kcalloc and fix wrong sizeof
phy: twl4030-usb: Remove redundant assignment for twl->linkstat
phy: exynos5-usbdrd: Fix off-by-one valid value checking for args->args[0]
phy: Find the right match in devm_phy_destroy()
phy: rockchip-usb: Fixup rockchip_usb_phy_power_on failure path
phy: ti-pipe3: Simplify ti_pipe3_dpll_wait_lock implementation
phy: samsung-usb2: Remove NULL terminating entry from phys array
phy: hix5hd2-sata: Check return value of platform_get_resource
phy: exynos-dp-video: Kill exynos_dp_video_phy_pwr_isol function
Revert "usb: gadget: zero: Add support for interrupt EP"
Revert "xhci: Clear the host side toggle manually when endpoint is 'soft reset'"
1) Fix packet header offset calculation in _decode_session6(), from
Hajime Tazaki.
2) Fix route leak in error paths of xfrm_lookup(), from Huaibin Wang.
3) Be sure to clear state properly when scans fail in iwlwifi mvm code,
from Luciano Coelho.
4) iwlwifi tries to stop scans that aren't actually running, also from
Luciano Coelho.
5) mac80211 should drop mesh frames that are not encrypted, fix from
Bob Copeland.
6) Add new device ID to b43 wireless driver for BCM432228 chips, from
Rafał Miłecki.
7) Fix accidental addition of members after variable sized array in
struct tc_u_hnode, from WANG Cong.
8) Don't re-enable interrupts until after we call napi_complete() in
ibmveth and WIZnet drivers, frm Yongbae Park.
9) Fix regression in vlan tag handling of fec driver, from Fugang Duan.
10) If a network namespace change fails during rtnl_newlink(), we don't
unwind the device registry properly.
11) Fix two TCP regressions, from Neal Cardwell:
- Don't allow snd_cwnd_cnt to accumulate huge values due to missing
test in tcp_cong_avoid_ai().
- Restore CUBIC back to advancing cwnd by 1.5x packets per RTT.
12) Fix performance regression in xne-netback involving push TX
notifications, from David Vrabel.
13) __skb_tstamp_tx() can be called with a NULL sk pointer, do not
dereference blindly. From Willem de Bruijn.
14) Fix potential stack overflow in RDS protocol stack, from Arnd
Bergmann.
15) VXLAN_VID_MASK used incorrectly in new remote checksum offload
support of VXLAN driver. Fix from Alexey Kodanev.
16) Fix too small netlink SKB allocation in inet_diag layer, from Eric
Dumazet.
17) ieee80211_check_combinations() does not count interfaces correctly,
from Andrei Otcheretianski.
18) Hardware feature determination in bxn2x driver references a piece of
software state that actually isn't initialized yet, fix from Michal
Schmidt.
19) inet_csk_wait_for_connect() needs a sched_annotate_sleep()
annoation, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (56 commits)
Revert "net: cx82310_eth: use common match macro"
net/mlx4_en: Set statistics bitmap at port init
IB/mlx4: Saturate RoCE port PMA counters in case of overflow
net/mlx4_en: Fix off-by-one in ethtool statistics display
IB/mlx4: Verify net device validity on port change event
act_bpf: allow non-default TC_ACT opcodes as BPF exec outcome
Revert "smc91x: retrieve IRQ and trigger flags in a modern way"
inet: Clean up inet_csk_wait_for_connect() vs. might_sleep()
ip6_tunnel: fix error code when tunnel exists
netdevice.h: fix ndo_bridge_* comments
bnx2x: fix encapsulation features on 57710/57711
mac80211: ignore CSA to same channel
nl80211: ignore HT/VHT capabilities without QoS/WMM
mac80211: ask for ECSA IE to be considered for beacon parse CRC
mac80211: count interfaces correctly for combination checks
isdn: icn: use strlcpy() when parsing setup options
rxrpc: bogus MSG_PEEK test in rxrpc_recvmsg()
caif: fix MSG_OOB test in caif_seqpkt_recvmsg()
bridge: reset bridge mtu after deleting an interface
can: kvaser_usb: Fix tx queue start/stop race conditions
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into fixes
Pull "ARM: rockchip: small fixes for 4.0-rc" from Heiko Stuebner:
Adding a default-disabled state to the new gmac node and an
update to the MAINTAINERS entry adding a rockchip regexp entry.
* tag 'v4.0-rockchip-armfixes1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
Pull ARM SoC fixes from Arnd Bergmann:
"This is a rather unpleasantly large set of bug fixes for arm-soc, Most
of them because of cross-tree dependencies for Exynos where we should
have figured out the right path to merge things before the merge
window, and then the maintainer being unable to sort things out in
time during a business trip.
The other changes contained here are the usual collection:
MAINTAINERS file updates
- Gregory Clement is now a co-maintainer for the legacy Marvell EBU
platforms
- A MAINTAINERS entry for the Freescale Vybrid platform that was
added last year
- Matt Porter no longer works as a maintainer on Broadcom SoCs
Build-time issues
- A compile-time error for at91
- Several minor DT fixes on at91, imx, exynos, socfpga, and omap
- The new digicolor platform was not correctly enabled at all
Configuration issues
- Two defconfig fix for regressions using USB on versatile express
and on OMAP3
- Enabling all 8 CPUs on Allwinner/SUNxi
- Enabling the new STiH410 platform to be usable
Bug fixes in platform code
- A missing barrier for socfpga
- Fixing LPDDR1 self-refresh mode on at91
- Fixing RTC interrupt numbers on Exynos3250
- Fixing a cache-coherency issues in CPU power-down on Exynos5
- Multiple small OMAP power management fixes"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (69 commits)
MAINTAINERS: Add myself as co-maintainer to the legacy support of the mvebu SoCs
ARM: at91: pm_slowclock: fix the compilation error
ARM: at91/dt: fix USB high-speed clock to select UTMI
ARM: at91/dt: fix at91 udc compatible strings
ARM: at91/dt: declare matrix node as a syscon device
ARM: vexpress: update CONFIG_USB_ISP1760 option
ARM: digicolor: add the machine directory to Makefile
ARM: STi: Add STiH410 SoC support
MAINTAINERS: add Freescale Vybrid SoC
MAINTAINERS: Remove self as ARM mach-bcm co-maintainer
ARM: imx6sl-evk: set swbst_reg as vbus's parent reg
ARM: imx6qdl-sabresd: set swbst_reg as vbus's parent reg
ARM: at91/dt: at91sam9261: fix clocks and clock-names in udc definition
ARM: OMAP2+: Fix wl12xx on dm3730-evm with mainline u-boot
ARM: OMAP: enable TWL4030_USB in omap2plus_defconfig
ARM: dts: dra7x-evm: avoid possible contention while muxing on CAN lines
ARM: dts: dra7x-evm: Don't use dcan1_rx.gpio1_15 in DCAN pinctrl
ARM: dts: am43xx: fix SLEWCTRL_FAST pinctrl binding
ARM: dts: am33xx: fix SLEWCTRL_FAST pinctrl binding
ARM: dts: OMAP5: fix polling intervals for thermal zones
Add MAINTAINER entry for USB OTG Finite State Machine
Cc: Felipe Balbi <balbi@ti.com>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
The regexp option is a nice way to catch even weirder paths like the current
drivers/gpu/drm/rockchip/* or others in the future.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
I will also take care of the legacy support(not fully converted to DT)
of the mvebu SoCs.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Changed to my private email address.
Signed-off-by: Chas Williams -- CONTRACTOR <chas@cmf.nrl.navy.mil>
Add Freescale Vybrid family as a own entry, along with an entry for
the so far orphan Vybrid device tree files. Also add myself as
a designated reviewer.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Removing myself as a co-maintainer.
Signed-off-by: Matt Porter <mporter@linaro.org>
1) nft_compat accidently truncates ethernet protocol to 8-bits, from
Arturo Borrero.
2) Memory leak in ip_vs_proc_conn(), from Julian Anastasov.
3) Don't allow the space required for nftables rules to exceed the
maximum value representable in the dlen field. From Patrick
McHardy.
4) bcm63xx_enet can accidently leave interrupts permanently disabled
due to errors in the NAPI polling exit logic. Fix from Nicolas
Schichan.
5) Fix OOPSes triggerable by the ping protocol module, due to missing
address family validations etc. From Lorenzo Colitti.
6) Don't use RCU locking in sleepable context in team driver, from Jiri
Pirko.
7) xen-netback miscalculates statistic offset pointers when reporting
the stats to userspace. From David Vrabel.
8) Fix a leak of up to 256 pages per VIF destroy in xen-netaback, also
from David Vrabel.
9) ip_check_defrag() cannot assume that skb_network_offset(),
particularly when it is used by the AF_PACKET fanout defrag code.
From Alexander Drozdov.
10) gianfar driver doesn't query OF node names properly when trying to
determine the number of hw queues available. Fix it to explicitly
check for OF nodes named queue-group. From Tobias Waldekranz.
11) MID field in macb driver should be 12 bits, not 16. From Punnaiah
Choudary Kalluri.
12) Fix unintentional regression in traceroute due to timestamp socket
option changes. Empty ICMP payloads should be allowed in
non-timestamp cases. From Willem de Bruijn.
13) When devices are unregistered, we have to get rid of AF_PACKET
multicast list entries that point to it via ifindex. Fix from
Francesco Ruggeri.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits)
tipc: fix bug in link failover handling
net: delete stale packet_mclist entries
net: macb: constify macb configuration data
MAINTAINERS: add Marc Kleine-Budde as co maintainer for CAN networking layer
MAINTAINERS: linux-can moved to github
can: kvaser_usb: Read all messages in a bulk-in URB buffer
can: kvaser_usb: Avoid double free on URB submission failures
can: peak_usb: fix missing ctrlmode_ init for every dev
can: add missing initialisations in CAN related skbuffs
ip: fix error queue empty skb handling
bgmac: Clean warning messages
tcp: align tcp_xmit_size_goal() on tcp_tso_autosize()
net: fec: fix unbalanced clk disable on driver unbind
net: macb: Correct the MID field length value
net: gianfar: correctly determine the number of queue groups
ipv4: ip_check_defrag should not assume that skb_network_offset is zero
net: bcmgenet: properly disable password matching
net: eth: xgene: fix booting with devicetree
bnx2x: Force fundamental reset for EEH recovery
xen-netback: refactor xenvif_handle_frag_list()
This patch adds Marc Kleine-Budde as a co maintainer for the CAN networking
layer.
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
As gitorious will shut down at the end of May 2015, the linux-can website moved
to github. This patch reflects this change.
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal
Pull thermal management fixes from Eduardo Valentin:
"Specifics:
- adding Lukasz as maintainer of samsung thermal driver.
- driver fixes: exynos and int430x.
- one fix in the exynos cpufreq driver related to cpu cooling (acked
by cpufreq maintainer).
- fix default sysfs attributes of cooling devices
Note: I am sending this pull on Rui's behalf while he fixes issues in his Linux box"
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal:
thermal: Make sysfs attributes of cooling devices default attributes
Thermal/int340x: Fix memleak for aux trip
MAINTAINERS: Add entry for SAMSUNG THERMAL DRIVER
cpufreq: exynos: Use simple approach to asses if cpu cooling can be used
thermal: exynos: Fix wrong control of power down detection mode for Exynos7
1) If an IPVS tunnel is created with a mixed-family destination
address, it cannot be removed. Fix from Alexey Andriyanov.
2) Fix module refcount underflow in netfilter's nft_compat, from Pablo
Neira Ayuso.
3) Generic statistics infrastructure can reference variables sitting on
a released function stack, therefore use dynamic allocation always.
Fix from Ignacy Gawędzki.
4) skb_copy_bits() return value test is inverted in ip_check_defrag().
5) Fix network namespace exit in openvswitch, we have to release all of
the per-net vports. From Pravin B Shelar.
6) Fix signedness bug in CAIF's cfpkt_iterate(), from Dan Carpenter.
7) Fix rhashtable grow/shrink behavior, only expand during inserts and
shrink during deletes. From Daniel Borkmann.
8) Netdevice names with semicolons should never be allowed, because
they serve as a separator. From Matthew Thode.
9) Use {,__}set_current_state() where appropriate, from Fabian
Frederick.
10) Revert byte queue limits support in r8169 driver, it's causing
regressions we can't figure out.
11) tcp_should_expand_sndbuf() erroneously uses tp->packets_out to
measure packets in flight, properly use tcp_packets_in_flight()
instead. From Neal Cardwell.
12) Fix accidental removal of support for bluetooth in CSR based Intel
wireless cards. From Marcel Holtmann.
13) We accidently added a behavioral change between native and compat
tasks, wrt testing the MSG_CMSG_COMPAT bit. Just ignore it if the
user happened to set it in a native binary as that was always the
behavior we had. From Catalin Marinas.
14) Check genlmsg_unicast() return valud in hwsim netlink tx frame
handling, from Bob Copeland.
15) Fix stale ->radar_required setting in mac80211 that can prevent
starting new scans, from Eliad Peller.
16) Fix memory leak in nl80211 monitor, from Johannes Berg.
17) Fix race in TX index handling in xen-netback, from David Vrabel.
18) Don't enable interrupts in amx-xgbe driver until all software et al.
state is ready for the interrupt handler to run. From Thomas
Lendacky.
19) Add missing netlink_ns_capable() checks to rtnl_newlink(), from Eric
W Biederman.
20) The amount of header space needed in macvtap was not calculated
properly, fix it otherwise we splat past the beginning of the
packet. From Eric Dumazet.
21) Fix bcmgenet TCP TX perf regression, from Jaedon Shin.
22) Don't raw initialize or mod timers, use setup_timer() and
mod_timer() instead. From Vaishali Thakkar.
23) Fix software maintained statistics in bcmgenet and systemport
drivers, from Florian Fainelli.
24) DMA descriptor updates in sh_eth need proper memory barriers, from
Ben Hutchings.
25) Don't do UDP Fragmentation Offload on RAW sockets, from Michal
Kubecek.
26) Openvswitch's non-masked set actions aren't constructed properly
into netlink messages, fix from Joe Stringer.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits)
openvswitch: Fix serialization of non-masked set actions.
gianfar: Reduce logging noise seen due to phy polling if link is down
ibmveth: Add function to enable live MAC address changes
net: bridge: add compile-time assert for cb struct size
udp: only allow UFO for packets from SOCK_DGRAM sockets
sh_eth: Really fix padding of short frames on TX
Revert "sh_eth: Enable Rx descriptor word 0 shift for r8a7790"
sh_eth: Fix RX recovery on R-Car in case of RX ring underrun
sh_eth: Ensure proper ordering of descriptor active bit write/read
net/mlx4_en: Disbale GRO for incoming loopback/selftest packets
net/mlx4_core: Fix wrong mask and error flow for the update-qp command
net: systemport: fix software maintained statistics
net: bcmgenet: fix software maintained statistics
rxrpc: don't multiply with HZ twice
rxrpc: terminate retrans loop when sending of skb fails
net/hsr: Fix NULL pointer dereference and refcnt bugs when deleting a HSR interface.
net: pasemi: Use setup_timer and mod_timer
net: stmmac: Use setup_timer and mod_timer
net: 8390: axnet_cs: Use setup_timer and mod_timer
net: 8390: pcnet_cs: Use setup_timer and mod_timer
work-fixes
Pull samsung thermal fixes from Lukasz Majewski:
"Changes:
- Exynos7 power down detection mode fix
- Fix for cpufreq cooling device regression
- Updating MAINTAINER's entry for Samsung Exynos Thermal"
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
This patch adds entry for SAMSUNG THERMAL DRIVER in the MAINTAINERS file.
It has been agreed, that pull request are going to be sent to Eduardo
Valentin.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
We (the Ocfs2 project) recently moved the location of our ocfs2-tools
git tree and project web page. The pertinent discussion can be seen
here:
https://oss.oracle.com/pipermail/ocfs2-devel/2015-February/010579.html
The following patch updates the Ocfs2 documentation in MAINTAINERS,
ocfs2.txt, and dlmfs.txt. I added our new official web page, changed
the location of our tools git tree and removed the link to Joel's
ancient kernel git tree - Andrew has handled our patches for a while
now.
Signed-off-by: Mark Fasheh <mfasheh@suse.de>
I have been signing off on patches with this address so I'll change it.
Signed-off-by: Andy Gospodarek <gospo@cumulusnetworks.com>
Pull misc SCSI patches from James Bottomley:
"This is a short patch set representing a couple of left overs from the
merge window (debug removal and MAINTAINER changes).
Plus one merge window regression (the local workqueue for hpsa) and a
set of bug fixes for several issues (two for scsi-mq and the rest an
assortment of long standing stuff, all cc'd to stable)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
sg: fix EWOULDBLOCK errors with scsi-mq
sg: fix unkillable I/O wait deadlock with scsi-mq
sg: fix read() error reporting
wd719x: add missing .module to wd719x_template
hpsa: correct compiler warnings introduced by hpsa-add-local-workqueue patch
fixed invalid assignment of 64bit mask to host dma_boundary for scatter gather segment boundary limit.
fcoe: Transition maintainership to Vasu
am53c974: remove left-over debugging code
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull InfiniBand/RDMA updates from Roland Dreier:
- Re-enable on-demand paging changes with stable ABI
- Fairly large set of ocrdma HW driver fixes
- Some qib HW driver fixes
- Other miscellaneous changes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (43 commits)
IB/qib: Add blank line after declaration
IB/qib: Fix checkpatch warnings
IB/mlx5: Enable the ODP capability query verb
IB/core: Add on demand paging caps to ib_uverbs_ex_query_device
IB/core: Add support for extended query device caps
RDMA/cxgb4: Don't hang threads forever waiting on WR replies
RDMA/ocrdma: Fix off by one in ocrdma_query_gid()
RDMA/ocrdma: Use unsigned for bit index
RDMA/ocrdma: Help gcc generate better code for ocrdma_srq_toggle_bit
RDMA/ocrdma: Update the ocrdma module version string
RDMA/ocrdma: set vlan present bit for user AH
RDMA/ocrdma: remove reference of ocrdma_dev out of ocrdma_qp structure
RDMA/ocrdma: Add support for interrupt moderation
RDMA/ocrdma: Honor return value of ocrdma_resolve_dmac
RDMA/ocrdma: Allow expansion of the SQ CQEs via buddy CQ expansion of the QP
RDMA/ocrdma: Discontinue support of RDMA-READ-WITH-INVALIDATE
RDMA/ocrdma: Host crash on destroying device resources
RDMA/ocrdma: Report correct state in ibv_query_qp
RDMA/ocrdma: Debugfs enhancments for ocrdma driver
RDMA/ocrdma: Report correct count of interrupt vectors while registering ocrdma device
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework updates from Mike Turquette:
"The clock framework changes contain the usual driver additions,
enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based
devices.
Additionally the framework core underwent a bit of surgery with two
major changes:
- The boundary between the clock core and clock providers (e.g clock
drivers) is now more well defined with dedicated provider helper
functions. struct clk no longer maps 1:1 with the hardware clock
but is a true per-user cookie which helps us tracker users of
hardware clocks and debug bad behavior.
- The addition of rate constraints for clocks. Rate ranges are now
supported which are analogous to the voltage ranges in the
regulator framework.
Unfortunately these changes to the core created some breakeage. We
think we fixed it all up but for this reason there are lots of last
minute commits trying to undo the damage"
* tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits)
clk: Only recalculate the rate if needed
Revert "clk: mxs: Fix invalid 32-bit access to frac registers"
clk: qoriq: Add support for the platform PLL
powerpc/corenet: Enable CLK_QORIQ
clk: Replace explicit clk assignment with __clk_hw_set_clk
clk: Add __clk_hw_set_clk helper function
clk: Don't dereference parent clock if is NULL
MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr
clkdev: Always allocate a struct clk and call __clk_get() w/ CCF
clk: shmobile: div6: Avoid division by zero in .round_rate()
clk: omap: compile legacy omap3 clocks conditionally
clkdev: Export clk_register_clkdev
clk: Add rate constraints to clocks
clk: remove clk-private.h
pci: xgene: do not use clk-private.h
arm: omap2+ remove dead clock code
clk: Make clk API return per-user struct clk instances
clk: tegra: Define PLLD_DSI and remove dsia(b)_mux
clk: tegra: Add support for the Tegra132 CAR IP block
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph changes from Sage Weil:
"On the RBD side, there is a conversion to blk-mq from Christoph,
several long-standing bug fixes from Ilya, and some cleanup from
Rickard Strandqvist.
On the CephFS side there is a long list of fixes from Zheng, including
improved session handling, a few IO path fixes, some dcache management
correctness fixes, and several blocking while !TASK_RUNNING fixes.
The core code gets a few cleanups and Chaitanya has added support for
TCP_NODELAY (which has been used on the server side for ages but we
somehow missed on the kernel client).
There is also an update to MAINTAINERS to fix up some email addresses
and reflect that Ilya and Zheng are doing most of the maintenance for
RBD and CephFS these days. Do not be surprised to see a pull request
come from one of them in the future if I am unavailable for some
reason"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (27 commits)
MAINTAINERS: update Ceph and RBD maintainers
libceph: kfree() in put_osd() shouldn't depend on authorizer
libceph: fix double __remove_osd() problem
rbd: convert to blk-mq
ceph: return error for traceless reply race
ceph: fix dentry leaks
ceph: re-send requests when MDS enters reconnecting stage
ceph: show nocephx_require_signatures and notcp_nodelay options
libceph: tcp_nodelay support
rbd: do not treat standalone as flatten
ceph: fix atomic_open snapdir
ceph: properly mark empty directory as complete
client: include kernel version in client metadata
ceph: provide seperate {inode,file}_operations for snapdir
ceph: fix request time stamp encoding
ceph: fix reading inline data when i_size > PAGE_SIZE
ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_close_sessions)
ceph: avoid block operation when !TASK_RUNNING (ceph_get_caps)
ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_sync)
rbd: fix error paths in rbd_dev_refresh()
- add Ilya, drop Yehuda as an RBD maintainer
- add Zheng as a Ceph maintainer
- update Yehuda and Sage's emails
Signed-off-by: Sage Weil <sage@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"OK, this has the big virtio 1.0 implementation, as specified by OASIS.
On top of tht is the major rework of lguest, to use PCI and virtio
1.0, to double-check the implementation.
Then comes the inevitable fixes and cleanups from that work"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (80 commits)
virtio: don't set VIRTIO_CONFIG_S_DRIVER_OK twice.
virtio_net: unconditionally define struct virtio_net_hdr_v1.
tools/lguest: don't use legacy definitions for net device in example launcher.
virtio: Don't expose legacy net features when VIRTIO_NET_NO_LEGACY defined.
tools/lguest: use common error macros in the example launcher.
tools/lguest: give virtqueues names for better error messages
tools/lguest: more documentation and checking of virtio 1.0 compliance.
lguest: don't look in console features to find emerg_wr.
tools/lguest: don't start devices until DRIVER_OK status set.
tools/lguest: handle indirect partway through chain.
tools/lguest: insert driver references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: insert device references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: rename virtio_pci_cfg_cap field to match spec.
tools/lguest: fix features_accepted logic in example launcher.
tools/lguest: handle device reset correctly in example launcher.
virtual: Documentation: simplify and generalize paravirt_ops.txt
lguest: remove NOTIFY call and eventfd facility.
lguest: remove NOTIFY facility from demonstration launcher.
lguest: use the PCI console device's emerg_wr for early boot messages.
lguest: always put console in PCI slot #1.
Pull dmaengine updates from Vinod Koul:
"This update brings:
- the big cleanup up by Maxime for device control and slave
capabilities. This makes the API much cleaner.
- new IMG MDC driver by Andrew
- new Renesas R-Car Gen2 DMA Controller driver by Laurent along with
bunch of fixes on rcar drivers
- odd fixes and updates spread over driver"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (130 commits)
dmaengine: pl330: add DMA_PAUSE feature
dmaengine: pl330: improve pl330_tx_status() function
dmaengine: rcar-dmac: Disable channel 0 when using IOMMU
dmaengine: rcar-dmac: Work around descriptor mode IOMMU errata
dmaengine: rcar-dmac: Allocate hardware descriptors with DMAC device
dmaengine: rcar-dmac: Fix oops due to unintialized list in error ISR
dmaengine: rcar-dmac: Fix spinlock issues in interrupt
dmaenegine: edma: fix sparse warnings
dmaengine: rcar-dmac: Fix uninitialized variable usage
dmaengine: shdmac: extend PM methods
dmaengine: shdmac: use SET_RUNTIME_PM_OPS()
dmaengine: pl330: fix bug that cause start the same descs in cyclic
dmaengine: at_xdmac: allow muliple dwidths when doing slave transfers
dmaengine: at_xdmac: simplify channel configuration stuff
dmaengine: at_xdmac: introduce save_cc field
dmaengine: at_xdmac: wait for in-progress transaction to complete after pausing a channel
ioat: fail self-test if wait_for_completion times out
dmaengine: dw: define DW_DMA_MAX_NR_MASTERS
dmaengine: dw: amend description of dma_dev field
dmatest: move src_off, dst_off, len inside loop
Pull MTD updates from Brian Norris:
"NAND:
- Add new Hisilicon NAND driver for Hip04
- Add default reboot handler, to ensure all outstanding erase
transactions complete in time
- jz4740: convert to use GPIO descriptor API
- Atmel: add support for sama5d4
- Change default bitflip threshold to 75% of correction strength
- Miscellaneous cleanups and bugfixes
SPI NOR:
- Freescale QuadSPI:
- Fix a few probe() and remove() issues
- Add a MAINTAINERS entry for this driver
- Tweak transfer size to increase read performance
- Add suspend/resume support
- Add Micron quad I/O support
- ST FSM SPI: miscellaneous fixes
JFFS2:
- gracefully handle corrupted 'offset' field found on flash
Other:
- bcm47xxpart: add tweaks for a few new devices
- mtdconcat: set return lengths properly for mtd_write_oob()
- map_ram: enable use with mtdoops
- maps: support fallback to ROM/UBI for write-protected NOR flash"
* tag 'for-linus-20150216' of git://git.infradead.org/linux-mtd: (46 commits)
mtd: hisilicon: && vs & typo
jffs2: fix handling of corrupted summary length
mtd: hisilicon: add device tree binding documentation
mtd: hisilicon: add a new NAND controller driver for hisilicon hip04 Soc
mtd: avoid registering reboot notifier twice
mtd: concat: set the return lengths properly
mtd: kconfig: replace PPC_OF with PPC
mtd: denali: remove unnecessary stubs
mtd: nand: remove redundant local variable
MAINTAINERS: add maintainer entry for FREESCALE QUAD SPI driver
mtd: fsl-quadspi: improve read performance by increase AHB transfer size
mtd: fsl-quadspi: Remove unnecessary 'map_failed' label
mtd: fsl-quadspi: Remove unneeded success/error messages
mtd: fsl-quadspi: Fix the error paths
mtd: nand: omap: drop condition with no effect
mtd: nand: jz4740: Convert to GPIO descriptor API
mtd: nand: Request strength instead of bytes for soft BCH
mtd: nand: default bitflip-reporting threshold to 75% of correction strength
mtd: atmel_nand: introduce a new compatible string for sama5d4 chip
mtd: atmel_nand: return max bitflips in all sectors in pmecc_correction()
Merge yet more updates from Andrew Morton:
- a pile of minor fs fixes and cleanups
- kexec updates
- random misc fixes in various places: vmcore, rbtree, eventfd, ipc, seccomp.
- a series of python-based kgdb helper scripts
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (58 commits)
seccomp: cap SECCOMP_RET_ERRNO data to MAX_ERRNO
samples/seccomp: improve label helper
ipc,sem: use current->state helpers
scripts/gdb: disable pagination while printing from breakpoint handler
scripts/gdb: define maintainer
scripts/gdb: convert CpuList to generator function
scripts/gdb: convert ModuleList to generator function
scripts/gdb: use a generator instead of iterator for task list
scripts/gdb: ignore byte-compiled python files
scripts/gdb: port to python3 / gdb7.7
scripts/gdb: add basic documentation
scripts/gdb: add lx-lsmod command
scripts/gdb: add class to iterate over CPU masks
scripts/gdb: add lx_current convenience function
scripts/gdb: add internal helper and convenience function for per-cpu lookup
scripts/gdb: add get_gdbserver_type helper
scripts/gdb: add internal helper and convenience function to retrieve thread_info
scripts/gdb: add is_target_arch helper
scripts/gdb: add helper and convenience function to look up tasks
scripts/gdb: add task iteration class
I'm proposing myself for keeping an eye on these scripts and integrating
contributions.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Ben Widawsky <ben@bwidawsk.net>
Cc: Borislav Petkov <bp@suse.de>
Pull arch/nios2 update from Ley Foon Tan:
"Here is the nios2 update for 3.20:
- add early printk support
- add kgdb support
- add compressed kernel support
- bugfixes"
* tag 'nios2-v3.20-rc1' of git://git.rocketboards.org/linux-socfpga-next:
nios2: add kgdb support
MAINTAINERS: update arch/nios2 git tree
nios2: default CONFIG_NIOS2_BOOT_LINK_OFFSET to 8MB
nios2: Add support for compressed kernel
nios2: add early printk support
nios2: Port OOM changes to do_page_fault()
nios2: Remove unused prepare_to_copy()
Pull ARM SoC platform changes from Olof Johansson:
"New and updated SoC support. Also included are some cleanups where
the platform maintainers hadn't separated cleanups from new developent
in separate branches.
Some of the larger things worth pointing out:
- A large set of changes from Alexandre Belloni and Nicolas Ferre
preparing at91 platforms for multiplatform and cleaning up quite a
bit in the process.
- Removal of CSR's "Marco" SoC platform that never made it out to the
market. We love seeing these since it means the vendor published
support before product was out, which is exactly what we want!
New platforms this release are:
- Conexant Digicolor (CX92755 SoC)
- Hisilicon HiP01 SoC
- CSR/sirf Atlas7 SoC
- ST STiH418 SoC
- Common code changes for Nvidia Tegra132 (64-bit SoC)
We're seeing more and more platforms having a harder time labelling
changes as cleanups vs new development -- which is a good sign that
we've come quite far on the cleanup effort. So over time we might
start combining the cleanup and new-development branches more"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits)
ARM: at91/trivial: unify functions and machine names
ARM: at91: remove at91_dt_initialize and machine init_early()
ARM: at91: change board files into SoC files
ARM: at91: remove at91_boot_soc
ARM: at91: move alternative initial mapping to board-dt-sama5.c
ARM: at91: merge all SOC_AT91SAM9xxx
ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init()
ARM: digicolor: select syscon and timer
ARM: zynq: Simplify SLCR initialization
ARM: zynq: PM: Fixed simple typo.
ARM: zynq: Setup default gpio number for Xilinx Zynq
ARM: digicolor: add low level debug support
ARM: initial support for Conexant Digicolor CX92755 SoC
ARM: OMAP2+: Add dm816x hwmod support
ARM: OMAP2+: Add clock domain support for dm816x
ARM: OMAP2+: Add board-generic.c entry for ti81xx
ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage
ARM: at91: remove unused mach/system_rev.h
ARM: at91: stop using HAVE_AT91_DBGUx
ARM: at91: fix ordering of SRAM and PM initialization
Pull ARM SoC cleanups from Olof Johansson:
"This is a good healthy set of various code removals. Total net delta
is 8100 lines removed.
Among the larger cleanups are:
- Removal of old Samsung S3C DMA infrastructure by Arnd
- Removal of the non-DT version of the 'lager' board by Magnus Damm
- General stale code removal on OMAP and Davinci by Rickard Strandqvist
- Removal of non-DT support on am3517 platforms by Tony Lindgren
... plus several other cleanups of various platforms across the board"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (47 commits)
ARM: sirf: drop redundant function and marco declaration
arm: omap: specify PMUs are for ARMv7 CPUs
arm: shmobile: specify PMUs are for ARMv7 CPUs
arm: iop: specify PMUs are for XScale CPUs
arm: pxa: specify PMUs are for XScale CPUs
arm: realview: specify PMU types
ARM: SAMSUNG: remove unused DMA infrastructure
ARM: OMAP3: Add back Kconfig option MACH_OMAP3517EVM for ASoC
ARM: davinci: Remove CDCE949 driver
ARM: at91: remove useless at91rm9200_set_type()
ARM: at91: remove useless at91rm9200_dt_initialize()
ARM: at91: move debug-macro.S into the common space
ARM: at91: remove useless at91_sysirq_mask_rtx
ARM: at91: remove useless config MACH_AT91SAM9_DT
ARM: at91: remove useless config MACH_AT91RM9200_DT
ARM: at91: remove unused mach/memory.h
ARM: at91: remove useless header file includes
ARM: at91: remove unneeded header file
rtc: at91/Kconfig: remove useless options
ARM: at91/Documentation: add a README for Atmel SoCs
Pull ARM SoC non-critical fixes from Olof Johansson:
"Here's a small collection of fixes accrued during the last release
that weren't considered severe enough to merge during the -rc series.
A few of these are around resurrecting TI81xx support that's been
broken for quite a while, the rest are smaller fixes -- most for PXA
but a few across the board.
There are also some updates to MAINTAINERS here, in particular for
Broadcom platforms"
* tag 'fixes-non-critical-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
MAINTAINERS: fix git repositories for Broadcom SoCs
ARM: pxa: fix broken isa interrupts for zeus and viper
ARM: DRA7: hwmod: Fix boot crash with DEBUG_LL enabled on UART3
ARM: OMAP: DRA7: hwmod: Make gpmc software supervised as the smart idle is broken
ARM: AM43xx: hwmod: set DSS submodule parent hwmods
ARM: OMAP2+: hwmod: print error if wait_target_ready() failed
MAINTAINERS: add maintainer for OMAP hwmod data
ARM: OMAP2+: Disable omap3 PM init for ti81xx
ARM: OMAP2+: Fix reboot for 81xx
ARM: OMAP2+: Fix dm814 and dm816 for clocks and timer init
ARM: OMAP2+: Fix ti81xx class type
ARM: OMAP2+: Fix ti81xx devtype
ARM: OMAP2+: Fix error handling for omap2_clk_enable_init_clocks
MAINTAINERS: add a git entry for BMIPS-based BCM7xxx SoCs
MAINTAINERS: add a git entry for BCM7xxx ARM-based SoCs
MAINTAINERS: update Broadcom Cygnus SoC git tree
MAINTAINERS: move BCM63xx ARM-based SoCs git tree
hx4700: regulator: declare full constraints
ARM: pxa: add regulator_has_full_constraints to spitz board file
ARM: pxa: add regulator_has_full_constraints to poodle board file
Merge fifth set of updates from Andrew Morton:
- A few things which were awaiting merges from linux-next:
- rtc
- ocfs2
- misc others
- Willy's "dax" feature: direct fs access to memory (mainly NV-DIMMs)
which isn't backed by pageframes.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (37 commits)
rtc: add driver for DS1685 family of real time clocks
MAINTAINERS: add entry for Maxim PMICs on Samsung boards
lib/Kconfig: use bool instead of boolean
powerpc: drop _PAGE_FILE and pte_file()-related helpers
ocfs2: set append dio as a ro compat feature
ocfs2: wait for orphan recovery first once append O_DIRECT write crash
ocfs2: complete the rest request through buffer io
ocfs2: do not fallback to buffer I/O write if appending
ocfs2: allocate blocks in ocfs2_direct_IO_get_blocks
ocfs2: implement ocfs2_direct_IO_write
ocfs2: add orphan recovery types in ocfs2_recover_orphans
ocfs2: add functions to add and remove inode in orphan dir
ocfs2: prepare some interfaces used in append direct io
MAINTAINERS: fix spelling mistake & remove trailing WS
dax: does not work correctly with virtual aliasing caches
brd: rename XIP to DAX
ext4: add DAX functionality
dax: add dax_zero_page_range
ext2: get rid of most mentions of XIP in ext2
ext2: remove ext2_aops_xip
This adds a driver for the Dallas/Maxim DS1685-family of RTC chips. It
supports the DS1685/DS1687, DS1688/DS1691, DS1689/DS1693, DS17285/DS17287,
DS17485/DS17487, and DS17885/DS17887 RTC chips. These chips are commonly
found in SGI O2 and SGI Octane systems. It was originally derived from a
driver patch submitted by Matthias Fuchs many years ago for use in
EPPC-405-UC modules, which also used these RTCs. In addition to the
time-keeping functions, this RTC also handles the shutdown mechanism of
the O2 and Octane and acts as a partial NVRAM for the boot PROMS in these
systems.
Verified on both an SGI O2 and an SGI Octane.
Signed-off-by: Joshua Kinard <kumba@gentoo.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Add myself and Chanwoo Choi as supporters to help in reviewing patches
for Maxim 77686 PMIC and Maxim 14577/77693 MUIC drivers:
- mfd (all of them),
- extcon (extcon-max14577.c, extcon-max77693.c),
- regulator (all of them),
- clock (clk-max77686.c),
- RTC (rtc-max77686.c).
Lately I am the author of contributors to them. These drivers are used
on Exynos-based boards (Trats 2, Gear 1 and Gear 2).
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: MyungJoo Ham <myungjoo.ham@samsung.com>
Cc: Chanwoo Choi <cw00.choi@samsung.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Mike Turquette <mturquette@linaro.org>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Akash Shende <akash0x53s@gmail.com>
Use the generic AIO infrastructure instead of custom read and write
methods. In addition to giving us support for AIO, this adds the missing
locking between read() and truncate().
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Andreas Dilger <andreas.dilger@intel.com>
Cc: Boaz Harrosh <boaz@plexistor.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Theodore Ts'o <tytso@mit.edu>
We have been asked to use our company e-mail address for open
source contributions. Hence this change from a personal e-mail
address into a company e-mail address.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Pull drm updates from Dave Airlie:
"This is the main drm pull, it has a shared branch with some alsa
crossover but everything should be acked by relevant people.
New drivers:
- ATMEL HLCDC driver
- designware HDMI core support (used in multiple SoCs).
core:
- lots more atomic modesetting work, properties and atomic ioctl
(hidden under option)
- bridge rework allows support for Samsung exynos chromebooks to
work finally.
- some more panels supported
i915:
- atomic plane update support
- DSI uses shared DSI infrastructure
- Skylake basic support is all merged now
- component framework used for i915/snd-hda interactions
- write-combine cpu memory mappings
- engine init code refactored
- full ppgtt enabled where execlists are enabled.
- cherryview rps/gpu turbo and pipe CRC support.
radeon:
- indirect draw support for evergreen/cayman
- SMC and manual fan control for SI/CI
- Displayport audio support
amdkfd:
- SDMA usermode queue support
- replace suballocator usage with more suitable one
- rework for allowing interfacing to more than radeon
nouveau:
- major renaming in prep for later splitting work
- merge arm platform driver into nouveau
- GK20A reclocking support
msm:
- conversion to atomic modesetting
- YUV support for mdp4/5
- eDP support
- hw cursor for mdp5
tegra:
- better suspend/resume support for child devices
rcar-du:
- interlaced support
imx:
- move to using dw_hdmi shared support
- mode_fixup support
sti:
- DVO support
- HDMI infoframe support
exynos:
- refactoring and cleanup, removed lots of internal unnecessary
abstraction
- exynos7 DECON display controller support
Along with the usual bunch of fixes, cleanups etc"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (724 commits)
drm/radeon: fix voltage setup on hawaii
drm/radeon/dp: Set EDP_CONFIGURATION_SET for bridge chips if necessary
drm/radeon: only enable kv/kb dpm interrupts once v3
drm/radeon: workaround for CP HW bug on CIK
drm/radeon: Don't try to enable write-combining without PAT
drm/radeon: use 0-255 rather than 0-100 for pwm fan range
drm/i915: Clamp efficient frequency to valid range
drm/i915: Really ignore long HPD pulses on eDP
drm/exynos: Add DECON driver
drm/i915: Correct the base value while updating LP_OUTPUT_HOLD in MIPI_PORT_CTRL
drm/i915: Insert a command barrier on BLT/BSD cache flushes
drm/i915: Drop vblank wait from intel_dp_link_down
drm/exynos: fix NULL pointer reference
drm/exynos: remove exynos_plane_dpms
drm/exynos: remove mode property of exynos crtc
drm/exynos: Remove exynos_plane_dpms() call with no effect
drm/i915: Squelch overzealous uncore reset WARN_ON
drm/i915: Take runtime pm reference on hangcheck_info
drm/i915: Correct the IOSF Dev_FN field for IOSF transfers
drm/exynos: fix DMA_ATTR_NO_KERNEL_MAPPING usage
Pull clocksource updates from Ingo Molnar:
"The main change in this tree is the addition of various new SoC
clocksource/clockevents drivers: Conexant Digicolor SoCs, rockchip
rk3288 board, asm9260 for MIPS and versatile AB/PB boards"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
dts: versatile: Add sysregs node
clocksource: versatile: Adapt for Versatile AB and PB boards
dt/bindings: Add binding for Versatile system registers
clocksource: Driver for Conexant Digicolor SoC timer
clocksource: devicetree: Document Conexant Digicolor timer binding
clockevents: rockchip: Add rockchip timer for rk3288
ARM: clocksource: Add asm9260_timer driver
clocksource: marco: Rename marco to atlas7
clocksource: sirf: Remove unused variable
