path: root/MAINTAINERS
2016-05-17MAINTAINERS: Remove asterisk from EFI directory namesMatt Fleming
[ Upstream commit e8dfe6d8f6762d515fcd4f30577f7bfcf7659887 ] Mark reported that having asterisks on the end of directory names confuses get_maintainer.pl when it encounters subdirectories, and that my name does not appear when run on drivers/firmware/efi/libstub. Reported-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: <stable@vger.kernel.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/1462303781-8686-2-git-send-email-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-11MAINTAINERS: return arch/sh to maintained state, with new maintainersRich Felker
[ Upstream commit 114bf37e04d839b555b3dc460b5e6ce156f49cf0 ] Add Yoshinori Sato and Rich Felker as maintainers for arch/sh (SUPERH). Signed-off-by: Rich Felker <dalias@libc.org> Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Acked-by: D. Jeff Dionne <jeff@uClinux.org> Acked-by: Rob Landley <rob@landley.net> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-05Merge tag 'pci-v4.1-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "Resource management - Fix IOV sorting by alignment (Wei Yang) - Preserve resource size during alignment reordering (Yinghai Lu) Miscellaneous - MAINTAINERS: Add Pratyush for SPEAr13xx and DesignWare PCIe (Pratyush Anand)" * tag 'pci-v4.1-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Preserve resource size during alignment reordering PCI: Fix IOV resource sorting by alignment requirement MAINTAINERS: Add Pratyush Anand as SPEAr13xx and DesignWare PCIe maintainer
2015-06-03MAINTAINERS - remove OSDL referenceStephen Hemminger
OSDL has been gone for many years, looks like there still was one reference to it. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Various VTI tunnel (mark handling, PMTU) bug fixes from Alexander Duyck and Steffen Klassert. 2) Revert ethtool PHY query change, it wasn't correct. The PHY address selected by the driver running the PHY to MAC connection decides what PHY address GET ethtool operations return information from. 3) Fix handling of sequence number bits for encryption IV generation in ESP driver, from Herbert Xu. 4) UDP can return -EAGAIN when we hit a bad checksum on receive, even when there are other packets in the receive queue which is wrong. Just respect the error returned from the generic socket recv datagram helper. From Eric Dumazet. 5) Fix BNA driver firmware loading on big-endian systems, from Ivan Vecera. 6) Fix regression in that we were inheriting the congestion control of the listening socket for new connections, the intended behavior always was to use the default in this case. From Neal Cardwell. 7) Fix NULL deref in brcmfmac driver, from Arend van Spriel. 8) OTP parsing fix in iwlwifi from Liad Kaufman. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (26 commits) vti6: Add pmtu handling to vti6_xmit. Revert "net: core: 'ethtool' issue with querying phy settings" bnx2x: Move statistics implementation into semaphores xen: netback: read hotplug script once at start of day. xen: netback: fix printf format string warning Revert "netfilter: ensure number of counters is >0 in do_replace()" net: dsa: Properly propagate errors from dsa_switch_setup_one tcp: fix child sockets to use system default congestion control if not set udp: fix behavior of wrong checksums sfc: free multiple Rx buffers when required bna: fix soft lock-up during firmware initialization failure bna: remove unreasonable iocpf timer start bna: fix firmware loading on big-endian machines bridge: fix br_multicast_query_expired() bug via-rhine: Resigning as maintainer brcmfmac: avoid null pointer access when brcmf_msgbuf_get_pktid() fails mac80211: Fix mac80211.h docbook comments iwlwifi: nvm: fix otp parsing in 8000 hw family iwlwifi: pcie: fix tracking of cmd_in_flight ip_vti/ip6_vti: Preserve skb->mark after rcv_cb call ...
2015-05-28via-rhine: Resigning as maintainerRoger Luethi
I don't have enough time to look after via-rhine anymore. Signed-off-by: Roger Luethi <rl@hellgate.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-28MAINTAINERS: update CAPABILITIES patternJoe Perches
Commit 1ddd3b4e07a4 ("LSM: Remove unused capability.c") removed the file, remove the file pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-24Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of five fixes: Two MAINTAINER email updates (urgent because the non-avagotech emails will start bouncing) an lpfc big endian oops fix, a 256 byte sector hang fix (to eliminate 256 byte sectors) and a storvsc fix which could cause test unit ready failures on bringup" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: MAINTAINERS: Revise lpfc maintainers for Avago Technologies ownership of Emulex MAINTAINERS, be2iscsi: change email domain sd: Disable support for 256 byte/sector disks lpfc: Fix breakage on big endian kernels storvsc: Set the SRB flags correctly when no data transfer is needed
2015-05-18hwmon: Update the location of my quilt treeJean Delvare
This new location was supposed to be temporary, but a couple years have elapsed and it's still there, so apparently it's there to stay. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-05-18MAINTAINERS: Revise lpfc maintainers for Avago Technologies ownership of EmulexJames Smart
The old email addresses will go away very soon. Revising with new addresses. Signed-off-by: Dick Kennedy <dick.kennedy@avagotech.com> Signed-off-by: James Smart <james.smart@avagotech.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-18MAINTAINERS, be2iscsi: change email domainMinh Tran
be2iscsi change of ownership from Emulex to Avago Technologies recently. We like to get the following updates in: changed "Emulex" to "Avago Technologies", changed email addresses from "emulex.com" to "avagotech.com", updated MAINTAINER list for be2iscsi driver. Signed-off-by: Minh Tran <minh.tran@avagotech.com> Signed-off-by: Jayamohan Kallickal <jayamohan.kallickal@avagotech.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-16Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "Nothing frightening this time, just smaller fixes in a number of places. The other changes contained here are: MAINTAINERS file updates: - The mach-gemini maintainer is back in action and has a new git tree - Krzysztof Kozlowski has volunteered to be a new co-maintainer for the samsung platforms - updates to the files that belong to Marvell mvebu Bug fixes: - The largest changes are on omap2, but are only to avoid some harmless warnings and to fix reset on omap4 - a small regression fix on tegra - multiple fixes for incorrect IRQ affinity on vexpress - the missing system controller on arm64 juno is added - one revert of a patch that was accidentally applied twice for mach-rockchip - two clock related DT fixes for mvebu - a workaround for suspend with old DT binaries on new exynos kernels - Another fix for suspend on exynos, needs to be backported" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits) MAINTAINERS: Add dts entries for some of the Marvell SoCs MAINTAINERS: ARM: EXYNOS: Add Krzysztof Kozlowski as co-maintainer ARM: EXYNOS: Use of_machine_is_compatible instead of soc_is_exynos4 ARM: EXYNOS: Fix failed second suspend on Exynos4 Revert "ARM: rockchip: fix undefined instruction of reset_ctrl_regs" ARM: EXYNOS: Fix dereference of ERR_PTR returned by of_genpd_get_from_provider ARM: EXYNOS: Don't try to initialize suspend on old DT ARM: dts: Add keep-power-in-suspend to WiFi SDIO node for Peach Boards ARM: gemini: fix compiler warning due wrong data type ARM: vexpress/tc2: Add interrupt-affinity to the PMU node ARM: vexpress/ca9: Add interrupt-affinity to the PMU node ARM: vexpress/ca9: Add unified-cache property to l2 cache node ARM64: juno: add sp810 support and fix sp804 clock frequency ARM: Gemini: Maintainers update ARM: OMAP2+: Remove bogus struct clk comparison for timer clock ARM: dove: Add clock-names to CuBox Si5351 clk generator ARM: AM33xx+: hwmod: re-use omap4 implementations for reset functionality ARM: OMAP4+: PRM: add support for passing status register/bit info to reset ARM: AM43xx: hwmod: add VPFE hwmod entries ARM: mvebu: Fix the main PLL frequency on Armada 375, 38x and 39x SoCs ...
2015-05-15MAINTAINERS: Add Pratyush Anand as SPEAr13xx and DesignWare PCIe maintainerPratyush Anand
Didn't add myself as Maintainer earlier, as I was moving out of ST and didn't had a board to test. But learnt recently that, it's fine being in MAINTAINERS in such situations, at least I can review the patches. So, let me add myself. Signed-off-by: Pratyush Anand <pratyush.anand@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Jingoo Han <jingoohan1@gmail.com>
2015-05-15Merge tag 'mvebu-fixes-4.1-2' of git://git.infradead.org/linux-mvebu into fixesArnd Bergmann
Merge "mvebu fixes for 4.1 (part 2)" from Gregory CLEMENT: Fix the main PLL frequency on Armada 375, 38x and 39x SoCs Add clock-names to CuBox Si5351 clk generator Add dts entries in the MAINTAINERS file * tag 'mvebu-fixes-4.1-2' of git://git.infradead.org/linux-mvebu: MAINTAINERS: Add dts entries for some of the Marvell SoCs ARM: dove: Add clock-names to CuBox Si5351 clk generator ARM: mvebu: Fix the main PLL frequency on Armada 375, 38x and 39x SoCs
2015-05-15MAINTAINERS: Add dts entries for some of the Marvell SoCsGregory CLEMENT
Since many releases, the modifications of the mvebu and berlin device tree files are merged through the mvebu subsystem. This patch makes it official in order to help the contributors using the get_maintainer.pl to find the accurate peoples. In the same time, updated the mvebu description which now includes the kirkwood SoCs and new Armada SoCs. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Andrew Lunn <andrew@lunn.ch>
2015-05-14MAINTAINERS: update Jingoo Han's email addressJingoo Han
Change my private email address. Signed-off-by: Jingoo Han <jingoohan1@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-14MAINTAINERS: ARM: EXYNOS: Add Krzysztof Kozlowski as co-maintainerKrzysztof Kozlowski
Add Krzysztof Kozlowski as a co-maintainer of Samsung Exynos ARM architecture to review the patches. Patches will go as usual - picked up by Kukjin Kim. Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene@kernel.org> Cc: Kevin Hilman <khilman@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Cc: linux-samsung-soc@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Tobias Jakobi <liquid.acid@gmx.net> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Handle max TX power properly wrt VIFs and the MAC in iwlwifi, from Avri Altman. 2) Use the correct FW API for scan completions in iwlwifi, from Avraham Stern. 3) FW monitor in iwlwifi accidently uses unmapped memory, fix from Liad Kaufman. 4) rhashtable conversion of mac80211 station table was buggy, the virtual interface was not taken into account. Fix from Johannes Berg. 5) Fix deadlock in rtlwifi by not using a zero timeout for usb_control_msg(), from Larry Finger. 6) Update reordering state before calculating loss detection, from Yuchung Cheng. 7) Fix off by one in bluetooth firmward parsing, from Dan Carpenter. 8) Fix extended frame handling in xiling_can driver, from Jeppe Ledet-Pedersen. 9) Fix CODEL packet scheduler behavior in the presence of TSO packets, from Eric Dumazet. 10) Fix NAPI budget testing in fm10k driver, from Alexander Duyck. 11) macvlan needs to propagate promisc settings down the the lower device, from Vlad Yasevich. 12) igb driver can oops when changing number of rings, from Toshiaki Makita. 13) Source specific default routes not handled properly in ipv6, from Markus Stenberg. 14) Use after free in tc_ctl_tfilter(), from WANG Cong. 15) Use softirq spinlocking in netxen driver, from Tony Camuso. 16) Two ARM bpf JIT fixes from Nicolas Schichan. 17) Handle MSG_DONTWAIT properly in ring based AF_PACKET sends, from Mathias Kretschmer. 18) Fix x86 bpf JIT implementation of FROM_{BE16,LE16,LE32}, from Alexei Starovoitov. 19) ll_temac driver DMA maps TX packet header with incorrect length, fix from Michal Simek. 20) We removed pm_qos bits from netdevice.h, but some indirect references remained. Kill them. From David Ahern. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits) net: Remove remaining remnants of pm_qos from netdevice.h e1000e: Add pm_qos header net: phy: micrel: Fix regression in kszphy_probe net: ll_temac: Fix DMA map size bug x86: bpf_jit: fix FROM_BE16 and FROM_LE16/32 instructions netns: return RTM_NEWNSID instead of RTM_GETNSID on a get Update be2net maintainers' email addresses net_sched: gred: use correct backlog value in WRED mode pppoe: drop pppoe device in pppoe_unbind_sock_work net: qca_spi: Fix possible race during probe net: mdio-gpio: Allow for unspecified bus id af_packet / TX_RING not fully non-blocking (w/ MSG_DONTWAIT). bnx2x: limit fw delay in kdump to 5s after boot ARM: net: delegate filter to kernel interpreter when imm_offset() return value can't fit into 12bits. ARM: net fix emit_udiv() for BPF_ALU | BPF_DIV | BPF_K intruction. mpls: Change reserved label names to be consistent with netbsd usbnet: avoid integer overflow in start_xmit netxen_nic: use spin_[un]lock_bh around tx_clean_lock (2) net: xgene_enet: Set hardware dependency net: amd-xgbe: Add hardware dependency ...
2015-05-12Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma fixes from Doug Ledford: - update MAINTAINERS git repo pointer - printk garbage fix - fix for qib and iw_cxgb4 bugs introduced in 4.1 window - fix for an older iWARP netlink bug - fix a memcpy issue in ehca driver * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: infiniband: Remove duplicated KERN_<LEVEL> from pr_<level> uses IB/qib: fix test of unsigned variable RDMA/core: Fix for parsing netlink string attribute MAINTAINERS: update the official rdma git repo iw_cxgb4: use wildcard mapping for getting remote addr info IB/ehca: use correct destination for memcpy
2015-05-12Merge tag 'for-v4.1-rc' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply and reset fixes from Sebastian Reichel: "misc fixes" * tag 'for-v4.1-rc' of git://git.infradead.org/battery-2.6: power: bq27x00_battery: Add missing MODULE_ALIAS power: reset: Add MFD_SYSCON depends for brcmstb power: reset: ltc2952: Remove bogus hrtimer_start() return value checks power_supply: fix oops in collie_battery driver power/reset: at91: fix return value check in at91_reset_platform_probe() MAINTAINERS: Add me as maintainer of Nokia N900 power supply drivers axp288_fuel_gauge: Add original author details
2015-05-12Update be2net maintainers' email addressesSathya Perla
Emulex developers' email addresses are now "@avagotech" instead of "@emulex". I'm also replacing Subbu with Padmanabh and Sriharsha in the maintainers list. The driver's heading was outdated and did not include some of the chip types (BE3, Lancer and Skyhawk) that the driver has been supporting for a longtime. I've updated this too. Signed-off-by: Sathya Perla <sathya.perla@avagotech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-12ARM: Gemini: Maintainers updateHans Ulli Kroll
Back in business. New place for my repo on github Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-11MAINTAINERS: update the official rdma git repoDoug Ledford
Linus prefers kernel.org repos to github repos for security. Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-09Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "A few patches have come up since the merge window. The largest one is a rewrite of the PXA lubbock/mainstone IRQ handling. This was already broken in 2011 by a change to the GPIO code and only noticed now. The other changes contained here are: MAINTAINERS file updates: - Ray Jui and Scott Branden are now co-maintainers for some of the mach-bcm chips, while Christian Daudt and Marc Carino have stepped down. - Andrew Victor is no longer maintaining at91. Instead, Alexandre Belloni now becomes an official maintainer, after having done a bulk of the work for a while. - Baruch Siach, who added the mach-digicolor platform in 4.1 is now listed as maintainer - The git URL for mach-socfpga has changed Bug fixes: - Three bug fixes for new rockchip rk3288 code - A regression fix to make SD card support work on certain ux500 boards - multiple smaller dts fixes for imx, omap, mvebu, and shmobile - a regression fiix for omap3 power consumption - a fix for regression in the ARM CCI bus driver Configuration changes: - more imx platforms are now enabled in multi_v7_defconfig" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits) MAINTAINERS: add Conexant Digicolor machines entry MAINTAINERS: socfpga: update the git repo for SoCFPGA ARM: multi_v7_defconfig: Select more FSL SoCs MAINTAINERS: replace an AT91 maintainer drivers: CCI: fix used_mask init in validate_group() bus: omap_l3_noc: Fix master id address decoding for OMAP5 bus: omap_l3_noc: Fix offset for DRA7 CLK1_HOST_CLK1_2 instance ARM: dts: dra7: Fix efuse register size for ABB ARM: dts: am57xx-beagle-x15: Switch GPIO fan number ARM: dts: am57xx-beagle-x15: Switch UART mux pins ARM: dts: am437x-sk: reduce col-scan-delay-us ARM: dts: am437x-sk: fix for new newhaven display module revision ARM: dts: am57xx-beagle-x15: Fix RTC aliases ARM: dts: am57xx-beagle-x15: Fix IRQ type for mcp7941x ARM: dts: omap3: Add #iommu-cells to isp and iva iommu ARM: omap2plus_defconfig: Enable EXTCON_USB_GPIO ARM: dts: OMAP3-N900: Add microphone bias voltages ARM: OMAP2+: Fix omap off idle power consumption creeping up MAINTAINERS: Update brcmstb entry MAINTAINERS: Remove Christian Daudt for mach-bcm ...
2015-05-08MAINTAINERS: add Conexant Digicolor machines entryBaruch Siach
This adds Baruch as the maintainer for the Digicolor platform. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-08MAINTAINERS: socfpga: update the git repo for SoCFPGADinh Nguyen
The git tree at rocketboards.org is going away. Update the entry to reflect the address of the new location. Also add an entry for all the socfpga_* dts files. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-07MAINTAINERS: replace an AT91 maintainerNicolas Ferre
As some help is needed from an active maintainer, replace Andrew Victor by Alexandre Belloni in the ARM/Atmel MAINTAINERS' entry (aka AT91). Add an entry to the CREDITS file. Thanks Andrew for the great role you played during the early days of this product family. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-07Merge tag 'arm-soc/for-4.1/maintainers' of ↵Arnd Bergmann
http://github.com/broadcom/stblinux into fixes Merge "MAINTAINERS update for Broadcom SoCs for 4.1 #2" from Florian Fainelli: This pull request contains 3 changes to the MAINTAINERS file for Broadcom SoCs: - add Ray and Scott for mach-bcm - remove Christian for mach-bcm - remove Marc for brcmstb * tag 'arm-soc/for-4.1/maintainers' of http://github.com/broadcom/stblinux: MAINTAINERS: Update brcmstb entry MAINTAINERS: Remove Christian Daudt for mach-bcm MAINTAINERS: Update mach-bcm maintainers list
2015-05-07Merge tag 'for-linus' of git://github.com/dledford/linuxLinus Torvalds
Pull infiniband updates from Doug Ledford: "Minor updates for 4.1-rc Most of the changes are fairly small and well confined. The iWARP address reporting changes are the only ones that are a medium size. I had these queued up prior to rc1, but due to the shuffle in maintainers, they did not get submitted when I expected. My apologies for that. I feel comfortable with them however due to the testing they've received, so I left them in this submission" * tag 'for-linus' of git://github.com/dledford/linux: MAINTAINERS: Update InfiniBand subsystem maintainer MAINTAINERS: add include/rdma/ to InfiniBand subsystem IPoIB/CM: Fix indentation level iw_cxgb4: Remove negative advice dmesg warnings IB/core: Fix unaligned accesses IB/core: change rdma_gid2ip into void function as it always return zero IB/qib: use arch_phys_wc_add() IB/qib: add acounting for MTRR IB/core: dma unmap optimizations IB/core: dma map/unmap locking optimizations RDMA/cxgb4: Report the actual address of the remote connecting peer RDMA/nes: Report the actual address of the remote connecting peer RDMA/core: Enable the iWarp Port Mapper to provide the actual address of the connecting peer to its clients iw_cxgb4: enforce qp/cq id requirements iw_cxgb4: use BAR2 GTS register for T5 kernel mode CQs iw_cxgb4: 32b platform fixes iw_cxgb4: Cleanup register defines/MACROS RDMA/CMA: Canonize IPv4 on IPV6 sockets properly
2015-05-05MAINTAINERS: add co-maintainer for LED subsystemAndrew Morton
Add myself (Jacek Anaszewski) as a co-maintainer for the LED subsystem. Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com> Acked-by: Bryan Wu <cooloney@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-05zram: add Designated Reviewer for zram in MAINTAINERSMinchan Kim
Sergey Senozhatsky has contributed/reviewed to zram for a long time. He is really helpful for maintaining zram so I want for him to continue helping me as Designated Reviewer unless he hates it. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-05MAINTAINERS: Update InfiniBand subsystem maintainerDoug Ledford
Since Roland stepped down, the community asked me to take his place, and the nomination was followed by sufficient votes and no dissensions that we can move forward with the change. Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-05MAINTAINERS: add include/rdma/ to InfiniBand subsystemYann Droneaud
Most headers for InfiniBand/RDMA are located under include/rdma/ and include/uapi/rdma. Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-04isdn/gigaset: cede maintainershipTilman Schmidt
As German phone operators are discontinuing ISDN service, neither Hansjörg nor I will be able to maintain the Gigaset ISDN drivers any longer. Paul Bolle offered to step into the breach for odd fixes. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Acked-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-03Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "One intel fix, one rockchip fix, and a bunch of radeon fixes for some regressions from audio rework and vm stability" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/i915/chv: Implement WaDisableShadowRegForCpd drm/radeon: fix userptr return value checking (v2) drm/radeon: check new address before removing old one drm/radeon: reset BOs address after clearing it. drm/radeon: fix lockup when BOs aren't part of the VM on release drm/radeon: add SI DPM quirk for Sapphire R9 270 Dual-X 2G GDDR5 drm/radeon: adjust pll when audio is not enabled drm/radeon: only enable audio streams if the monitor supports it drm/radeon: only mark audio as connected if the monitor supports it (v3) drm/radeon/audio: don't enable packets until the end drm/radeon: drop dce6_dp_enable drm/radeon: fix ordering of AVI packet setup drm/radeon: Use drm_calloc_ab for CS relocs drm/rockchip: fix error check when getting irq MAINTAINERS: add entry for Rockchip drm drivers
2015-05-04Merge branch 'drm-next0420' of ↵Dave Airlie
https://github.com/markyzq/kernel-drm-rockchip into drm-fixes one fix and maintainers update * 'drm-next0420' of https://github.com/markyzq/kernel-drm-rockchip: drm/rockchip: fix error check when getting irq MAINTAINERS: add entry for Rockchip drm drivers
2015-05-01virtio: pass baton to Michael TsirkinRusty Russell
With my job change kernel work will be "own time"; I'm keeping lguest and modules (and the virtio standards work), but virtio kernel has to go. This makes it clear that Michael is in charge. He's good, but having me watch over his shoulder won't help. Good luck Michael! Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-01MAINTAINERS: Update brcmstb entryFlorian Fainelli
We have not heard back from Marc in a while, since we last asked him to ack/nack this change here: https://lkml.org/lkml/2015/1/14/1004 This was back in January, we are in the 3.21^W4.1 merge window now, so, as outlined in this email thread, remove him from the MAINTAINERS list now. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-05-01MAINTAINERS: Remove Christian Daudt for mach-bcmFlorian Fainelli
Christian has not been responding to mach-bcm related emails since around July 2013, and with Scott and Ray maintaining the platform, we should have enough coverage to get that going now. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-05-01MAINTAINERS: Update mach-bcm maintainers listFlorian Fainelli
Add Ray Jui and Scott Branden for the mach-bcm/ entries. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-04-30MAINTAINERS: Add me as maintainer of Nokia N900 power supply driversPali Rohár
I'm author of two of those drivers (bq2415x and rx51) and I added more patches for other twos. Also I fished (proper) open source power management software for Nokia N900 and those kernel drivers are part of it. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-04-26Merge tag 'pm+acpi-4.1-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management and ACPI updates from Rafael Wysocki: "These are fixes mostly (intel_pstate, ACPI core, ACPI EC driver, cpupower tool), a new CPU ID for the Intel RAPL driver and one intel_pstate driver improvement that didn't make it to my previous pull requests due to timing. Specifics: - Fix a build warning in the intel_pstate driver showing up in non-SMP builds (Borislav Petkov) - Change one of the intel_pstate's P-state selection parameters for Baytrail and Cherrytrail CPUs to significantly improve performance at the cost of a small increase in energy consumption (Kristen Carlson Accardi) - Fix a NULL pointer dereference in the ACPI EC driver due to an unsafe list walk in the query handler removal routine (Chris Bainbridge) - Get rid of a false-positive lockdep warning in the ACPI container hot-remove code (Rafael J Wysocki) - Prevent the ACPI device enumeration code from creating device objects of a wrong type in some cases (Rafael J Wysocki) - Add Skylake processors support to the Intel RAPL power capping driver (Brian Bian) - Drop the stale MAINTAINERS entry for the ACPI dock driver that is regarded as part of the ACPI core and maintained along with it now (Chao Yu) - Fix cpupower tool breakage caused by a library API change in libpci 3.3.0 (Lucas Stach)" * tag 'pm+acpi-4.1-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / scan: Add a scan handler for PRP0001 ACPI / scan: Annotate physical_node_lock in acpi_scan_is_offline() ACPI / EC: fix NULL pointer dereference in acpi_ec_remove_query_handler() MAINTAINERS: remove maintainship entry of docking station driver powercap / RAPL: Add support for Intel Skylake processors cpufreq: intel_pstate: Fix an annoying !CONFIG_SMP warning intel_pstate: Change the setpoint for Atom params cpupower: fix breakage from libpci API change
2015-04-26Merge tag 'platform-drivers-x86-v4.1-1' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver updates from Darren Hart: "This series includes significant updates to the toshiba_acpi driver and the reintroduction of the dell-laptop keyboard backlight additions I had to revert previously. Also included are various fixes for typos, warnings, correctness, and minor bugs. Specifics: dell-laptop: - add support for keyboard backlight. toshiba_acpi: - adaptive keyboard, hotkey, USB sleep and charge, and backlight updates. Update sysfs documentation. toshiba_bluetooth: - fix enabling/disabling loop on recent devices apple-gmux: - lock iGP IO to protect from vgaarb changes other: - Fix typos, clear gcc warnings, clarify pr_* messages, correct return types, update MAINTAINERS" * tag 'platform-drivers-x86-v4.1-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (25 commits) toshiba_acpi: Do not register vendor backlight when acpi_video bl is available MAINTAINERS: Add me on list of Dell laptop drivers platform: x86: dell-laptop: Add support for keyboard backlight Documentation/ABI: Update sysfs-driver-toshiba_acpi entry toshiba_acpi: Fix pr_* messages from USB Sleep Functions toshiba_acpi: Update and fix USB Sleep and Charge modes wmi: Use bool function return values of true/false not 1/0 toshiba_bluetooth: Fix enabling/disabling loop on recent devices toshiba_bluetooth: Clean up *_add function and disable BT device at removal toshiba_bluetooth: Add three new functions to the driver toshiba_acpi: Fix the enabling of the Special Functions toshiba_acpi: Use the Hotkey Event Type function for keymap choosing toshiba_acpi: Add Hotkey Event Type function and definitions x86/wmi: delete unused wmi_data_lock mutex causing gcc warning apple-gmux: lock iGP IO to protect from vgaarb changes MAINTAINERS: Add missing Toshiba devices and add myself as maintainer toshiba_acpi: Update events in toshiba_acpi_notify intel-oaktrail: Fix trivial typo in comment thinkpad_acpi: off by one in adaptive_keyboard_hotkey_notify_hotkey() thinkpad_acpi: signedness bugs getting current_mode ...
2015-04-24Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: - new drivers for: - Ingenic JZ4780 controller - APM X-Gene controller - Freescale RaidEngine device - Renesas USB Controller - remove device_alloc_chan_resources dummy handlers - sh driver cleanups for peri peri and related emmc and asoc patches as well - fixes and enhancements spread over the drivers * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits) dmaengine: dw: don't prompt for DW_DMAC_CORE dmaengine: shdmac: avoid unused variable warnings dmaengine: fix platform_no_drv_owner.cocci warnings dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe() dmaengine: at_xdmac: unlock spin lock before return dmaengine: xgene: devm_ioremap() returns NULL on error dmaengine: xgene: buffer overflow in xgene_dma_init_channels() dmaengine: usb-dmac: Fix dereferencing freed memory 'desc' dmaengine: sa11x0: report slave capabilities to upper layers dmaengine: vdma: Fix compilation warnings dmaengine: fsl_raid: statify fsl_re_chan_probe dmaengine: Driver support for FSL RaidEngine device. dmaengine: xgene_dma_init_ring_mngr() can be static Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes dmaengine: Add support for APM X-Gene SoC DMA engine driver dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver dmaengine: renesas,usb-dmac: Add device tree bindings documentation dmaengine: edma: fixed wrongly initialized data parameter to the edma callback dmaengine: ste_dma40: fix implicit conversion ...
2015-04-24Merge branches 'acpi-dock', 'acpi-ec' and 'acpi-scan'Rafael J. Wysocki
* acpi-dock: MAINTAINERS: remove maintainship entry of docking station driver * acpi-ec: ACPI / EC: fix NULL pointer dereference in acpi_ec_remove_query_handler() * acpi-scan: ACPI / scan: Add a scan handler for PRP0001 ACPI / scan: Annotate physical_node_lock in acpi_scan_is_offline()
2015-04-22Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA updates from Roland Dreier: - IPoIB fixes from Doug Ledford and Erez Shitrit - iSER updates from Sagi Grimberg - mlx4 GUID handling changes from Yishai Hadas - other misc fixes * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (51 commits) mlx5: wrong page mask if CONFIG_ARCH_DMA_ADDR_T_64BIT enabled for 32Bit architectures IB/iser: Rewrite bounce buffer code path IB/iser: Bump version to 1.6 IB/iser: Remove code duplication for a single DMA entry IB/iser: Pass struct iser_mem_reg to iser_fast_reg_mr and iser_reg_sig_mr IB/iser: Modify struct iser_mem_reg members IB/iser: Make fastreg pool cache friendly IB/iser: Move PI context alloc/free to routines IB/iser: Move fastreg descriptor pool get/put to helper functions IB/iser: Merge build page-vec into register page-vec IB/iser: Get rid of struct iser_rdma_regd IB/iser: Remove redundant assignments in iser_reg_page_vec IB/iser: Move memory reg/dereg routines to iser_memory.c IB/iser: Don't pass ib_device to fall_to_bounce_buff routine IB/iser: Remove a redundant struct iser_data_buf IB/iser: Remove redundant cmd_data_len calculation IB/iser: Fix wrong calculation of protection buffer length IB/iser: Handle fastreg/local_inv completion errors IB/iser: Fix unload during ep_poll wrong dereference ib_srpt: convert printk's to pr_* functions ...
2015-04-22Merge tag 'pci-v4.1-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "These fix an ia64 regression caused by tighter resource checking we merged during the merge window and remove an invalid email address from MAINTAINERS. Resource management: - ia64: Treat all Address Space Descriptors as windows (Bjorn Helgaas) Miscellaneous: - MAINTAINERS: Remove Mohit Kumar (email bounces) (Bjorn Helgaas)" * tag 'pci-v4.1-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: ia64/PCI: Treat all host bridge Address Space Descriptors (even consumers) as windows MAINTAINERS: Remove Mohit Kumar (email bounces)
2015-04-22Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "Some virtio internal cleanups, a new virtio device "virtio input", and a change to allow the legacy virtio balloon. Most excitingly, some lguest work! No seriously, I got some cleanup patches" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio: drop virtio_device_is_legacy_only virtio_pci: support non-legacy balloon devices virtio_mmio: support non-legacy balloon devices virtio_ccw: support non-legacy balloon devices virtio: balloon might not be a legacy device virtio_balloon: transitional interface virtio_ring: Update weak barriers to use dma_wmb/rmb virtio_pci_modern: switch to type-safe io accessors virtio_pci_modern: type-safe io accessors lguest: handle traps on the "interrupt suppressed" iret instruction. virtio: drop a useless config read virtio_config: reorder functions Add virtio-input driver. lguest: suppress interrupts for single insn, not range. lguest: simplify lguest_iret lguest: rename i386_head.S in the comments lguest: explicitly set miscdevice's private_data NULL lguest: fix pending interrupt test.
2015-04-22Merge tag 'armsoc-multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform code changes from Olof Johansson: "The changes here belong to two main platforms: - Atmel At91 is flipping the bit and going multiplatform. This includes some cleanups and removal of code, and the final flip of config dependencies - Shmobile has several platforms that are going multiplatform, but this branch also contains a bunch of cleanups that they weren't able to keep separate in a good way. THere's also a removal of one of their SoCs and the corresponding boards (sh7372 and mackerel)" * tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) ARM: at91/pm: move AT91_MEMCTRL_* to pm.h ARM: at91/pm: move the standby functions to pm.c ARM: at91: fix pm_suspend.S compilation when ARMv6 is selected ARM: at91: add a Kconfig dependency on multi-platform ARM: at91: drop AT91_TIMER_HZ ARM: at91: remove hardware.h ARM: at91: remove SoC headers ARM: at91: remove useless mach/cpu.h ARM: at91: remove unused headers ARM: at91: switch at91_dt_defconfig to multiplatform ARM: at91: switch to multiplatform ARM: shmobile: r8a7778: enable multiplatform target ARM: shmobile: bockw: add sound to DT ARM: shmobile: r8a7778: add sound to DT ARM: shmobile: bockw: add devices hooked up to i2c0 to DT DT: i2c: add trivial binding for OKI ML86V7667 video decoder ARM: shmobile: r8a7778: common clock framework CPG driver ARM: shmobile: bockw dts: set extal clock frequency ARM: shmobile: bockw dts: Move Ethernet node to BSC ARM: shmobile: r8a73a4: Remove legacy code ...
2015-04-22Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "Driver updates for v4.1. Some of these are for drivers/soc, where we find more and more SoC-specific drivers these days. Some are for other driver subsystems where we have received acks from the appropriate maintainers. The larger parts of this branch are: - MediaTek support for their PMIC wrapper interface, a high-level interface for talking to the system PMIC over a dedicated I2C interface. - Qualcomm SCM driver has been moved to drivers/firmware. It's used for CPU up/down and needs to be in a shared location for arm/arm64 common code. - cleanup of ARM-CCI PMU code. - another set of cleanusp to the OMAP GPMC code" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) soc/mediatek: Remove unused variables clocksource: atmel-st: select MFD_SYSCON soc: mediatek: Add PMIC wrapper for MT8135 and MT8173 SoCs arm-cci: Fix CCI PMU event validation arm-cci: Split the code for PMU vs driver support arm-cci: Get rid of secure transactions for PMU driver arm-cci: Abstract the CCI400 PMU specific definitions arm-cci: Rearrange code for splitting PMU vs driver code drivers: cci: reject groups spanning multiple HW PMUs ARM: at91: remove useless include clocksource: atmel-st: remove mach/hardware dependency clocksource: atmel-st: use syscon/regmap ARM: at91: time: move the system timer driver to drivers/clocksource ARM: at91: properly initialize timer ARM: at91: at91rm9200: remove deprecated arm_pm_restart watchdog: at91rm9200: implement restart handler watchdog: at91rm9200: use the system timer syscon mfd: syscon: Add atmel system timer registers definition ARM: at91/dt: declare atmel,at91rm9200-st as a syscon soc: qcom: gsbi: Add support for ADM CRCI muxing ...
