git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
- Update MAINTAINERS for Intel VMD driver filename
- Update Rockchip rk3399 host bridge driver DTS and resets
- Fix ROM shadow problem that made some video device initialization
fail
* tag 'pci-v4.9-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: VMD: Update filename to reflect move
arm64: dts: rockchip: add three new resets for rk3399 PCIe controller
PCI: rockchip: Add three new resets as required properties
PCI: Don't attempt to claim shadow copies of ROM
Updating MAINTAINERS to reflect the new location of the VMD driver.
Signed-off-by: Keith Busch <keith.busch@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Pull MTD fixes from Brian Norris:
- MAINTAINERS updates to reflect some new maintainers/submaintainers.
We have some great volunteers who've been developing and reviewing
already. We're going to try a group maintainership model, so
eventually you'll probably see pull requests from people besides me.
- NAND fixes from Boris:
"Three simple fixes:
- fix a non-critical bug in the gpmi driver
- fix a bug in the 'automatic NAND timings selection' feature
introduced in 4.9-rc1
- fix a false positive uninitialized-var warning"
* tag 'for-linus-20161104' of git://git.infradead.org/linux-mtd:
mtd: mtk: avoid warning in mtk_ecc_encode
mtd: nand: Fix data interface configuration logic
mtd: nand: gpmi: disable the clocks on errors
MAINTAINERS: add more people to the MTD maintainer team
MAINTAINERS: add a maintainer for the SPI NOR subsystem
Pull virtio updates from Michael Tsirkin:
"Tests, fixes and cleanups.
Just minor tweaks, there's nothing major in this cycle"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
virtio_ring: mark vring_dma_dev inline
virtio/vhost: add Jason to list of maintainers
virtio_blk: Delete an unnecessary initialisation in init_vq()
virtio_blk: Use kmalloc_array() in init_vq()
virtio: remove config.c
virtio: console: Unlock vqs while freeing buffers
ringtest: poll for new buffers once before updating event index
ringtest: commonize implementation of poll_avail/poll_used
ringtest: use link-time optimization
virtio: update balloon size in balloon "probe"
virtio_ring: Make interrupt suppression spec compliant
virtio_pci: Limit DMA mask to 44 bits for legacy virtio devices
Jason's been one of the mst active contributors
to virtio and vhost, it will help to formalize this
and list him as co-maintainer.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Pull networking fixes from David Miller:
"Lots of fixes, mostly drivers as is usually the case.
1) Don't treat zero DMA address as invalid in vmxnet3, from Alexey
Khoroshilov.
2) Fix element timeouts in netfilter's nft_dynset, from Anders K.
Pedersen.
3) Don't put aead_req crypto struct on the stack in mac80211, from
Ard Biesheuvel.
4) Several uninitialized variable warning fixes from Arnd Bergmann.
5) Fix memory leak in cxgb4, from Colin Ian King.
6) Fix bpf handling of VLAN header push/pop, from Daniel Borkmann.
7) Several VRF semantic fixes from David Ahern.
8) Set skb->protocol properly in ip6_tnl_xmit(), from Eli Cooper.
9) Socket needs to be locked in udp_disconnect(), from Eric Dumazet.
10) Div-by-zero on 32-bit fix in mlx4 driver, from Eugenia Emantayev.
11) Fix stale link state during failover in NCSCI driver, from Gavin
Shan.
12) Fix netdev lower adjacency list traversal, from Ido Schimmel.
13) Propvide proper handle when emitting notifications of filter
deletes, from Jamal Hadi Salim.
14) Memory leaks and big-endian issues in rtl8xxxu, from Jes Sorensen.
15) Fix DESYNC_FACTOR handling in ipv6, from Jiri Bohac.
16) Several routing offload fixes in mlxsw driver, from Jiri Pirko.
17) Fix broadcast sync problem in TIPC, from Jon Paul Maloy.
18) Validate chunk len before using it in SCTP, from Marcelo Ricardo
Leitner.
19) Revert a netns locking change that causes regressions, from Paul
Moore.
20) Add recursion limit to GRO handling, from Sabrina Dubroca.
21) GFP_KERNEL in irq context fix in ibmvnic, from Thomas Falcon.
22) Avoid accessing stale vxlan/geneve socket in data path, from
Pravin Shelar"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (189 commits)
geneve: avoid using stale geneve socket.
vxlan: avoid using stale vxlan socket.
qede: Fix out-of-bound fastpath memory access
net: phy: dp83848: add dp83822 PHY support
enic: fix rq disable
tipc: fix broadcast link synchronization problem
ibmvnic: Fix missing brackets in init_sub_crq_irqs
ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context
Revert "ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context"
arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofold
net/mlx4_en: Save slave ethtool stats command
net/mlx4_en: Fix potential deadlock in port statistics flow
net/mlx4: Fix firmware command timeout during interrupt test
net/mlx4_core: Do not access comm channel if it has not yet been initialized
net/mlx4_en: Fix panic during reboot
net/mlx4_en: Process all completions in RX rings after port goes up
net/mlx4_en: Resolve dividing by zero in 32-bit system
net/mlx4_core: Change the default value of enable_qos
net/mlx4_core: Avoid setting ports to auto when only one port type is supported
net/mlx4_core: Fix the resource-type enum in res tracker to conform to FW spec
Pull ARM SoC fixes from Olof Johansson:
"We haven't seen a whole lot of fixes for the first two weeks since the
merge window, but here is the batch that we have at the moment.
Nothing sticks out as particularly bad or scary, it's mostly a handful
of smaller fixes to several platforms. The Uniphier reset controller
changes could probably have been delayed to 4.10, but they're not
scary and just plumbing up driver changes that went in during the
merge window.
We're also adding another maintainer to Marvell Berlin platforms, to
help out when Sebastian is too busy. Yay teamwork!"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: imx: mach-imx6q: Fix the PHY ID mask for AR8031
ARM: dts: vf610: fix IRQ flag of global timer
ARM: imx: gpc: Fix the imx_gpc_genpd_init() error path
ARM: imx: gpc: Initialize all power domains
arm64: dts: Updated NAND DT properties for NS2 SVK
arm64: dts: uniphier: change MIO node to SD control node
ARM: dts: uniphier: change MIO node to SD control node
reset: uniphier: rename MIO reset to SD reset for Pro5, PXs2, LD20 SoCs
arm64: uniphier: select ARCH_HAS_RESET_CONTROLLER
ARM: uniphier: select ARCH_HAS_RESET_CONTROLLER
arm64: dts: Add timer erratum property for LS2080A and LS1043A
arm64: dts: rockchip: remove the abuse of keep-power-in-suspend
ARM: multi_v7_defconfig: Enable Intel e1000e driver
MAINTAINERS: add myself as Marvell berlin SoC maintainer
bus: qcom-ebi2: depend on ARCH_QCOM or COMPILE_TEST
ARM: dts: fix the SD card on the Snowball
arm64: dts: rockchip: remove always-on and boot-on from vcc_sd
arm64: dts: marvell: fix clocksource for CP110 master SPI0
ARM: mvebu: Select corediv clk for all mvebu v7 SoC
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are a few small char/misc driver fixes for reported issues.
The "biggest" are two binder fixes for reported issues that have been
shipping in Android phones for a while now, the others are various
fixes for reported problems.
And there's a MAINTAINERS update for good measure.
All have been in linux-next with no reported issues"
* tag 'char-misc-4.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
MAINTAINERS: Add entry for genwqe driver
VMCI: Doorbell create and destroy fixes
GenWQE: Fix bad page access during abort of resource allocation
vme: vme_get_size potentially returning incorrect value on failure
extcon: qcom-spmi-misc: Sync the extcon state on interrupt
hv: do not lose pending heartbeat vmbus packets
mei: txe: don't clean an unprocessed interrupt cause.
ANDROID: binder: Clear binder and cookie when setting handle in flat binder struct
ANDROID: binder: Add strong ref checks
From Boris:
Three simple fixes:
- the first one is fixing a non-critical bug in the gpmi driver
- the second one is fixing a bug in the 'automatic NAND timings
selection' feature introduced in 4.9-rc1
- the last one is fixing a false positive uninitialized-var warning
Frank and I maintain this
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: haver@linux.vnet.ibm.com
Acked-by: Frank Haverkamp <haver@linux.vnet.ibm.com>=
Brian has been maintaining the MTD subsystem alone for several years
now, and maintaining such a subsystem can really be time consuming.
Create a maintainer team formed of the most active MTD contributors
to help Brian with this task, which will hopefully improve the
subsystem reactivity.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Richard Weinberger <richard@nod.at>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
I would like to volunteer as a maintainer for the SPI NOR part of the MTD
subsystem.
Over the last months, a significant number of SPI NOR related patches have
been submitted, some of them have been reviewed, but very few have finally
been merged. Hence, the number of pending SPI NOR related patches continues
to increase over the time.
Through my work on SPI NOR memories from many manufacturers over the last
two years, I've gained a solid understanding of this technology.
I've already helped by reviewing patches from other contributors on the
mailing list, and would like to help getting those patches integrated by
volunteering as a maintainer for this specific area.
Boris Brezillon has already stepped up as a maintainer for the NAND
sub-subsystem in MTD, and the SPI NOR sub-subsystem could be handled in
the same way: I would be reviewing patches touching this area, collecting
them and sending pull requests to Brian Norris.
Also Marek Vasut has volunteered as well as maintainer for the SPI NOR
subsystem.
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Jagan Teki <jteki@openedev.com>
Following Cavium's acquisition of qlogic we need to update all the qlogic
drivers maintainer's entries to point to our new e-mail addresses,
as well as update some of the driver's maintainers as those are no longer
working for Cavium.
I would like to thank Sony Chacko and Rajesh Borundia for their support
and development of our various networking drivers.
Signed-off-by: Yuval Mintz <Yuval.Mintz@cavium.com>
Being a Linux kernel maintainer has been my proudest professional
accomplishment, spanning the last 19 years. But now we have a surfeit
of excellent hackers, and I can hand this over without regret.
I'll still be around as co-maintainer for another cycle, but Jessica
is now the one to convince if you want your patches applied. She
rocks, and is far more timely than me too!
Acked-by: Jessica Yu <jeyu@redhat.com>
Pull EFI fixes from Ingo Molnar:
"Add Ard Biesheuvel as EFI co-maintainer, plus fix an ARM build bug
with older toolchains"
* 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
efi/arm: Fix absolute relocation detection for older toolchains
MAINTAINERS: Add myself as EFI maintainer
"This includes:
- Fix for a Layerscape driver issue that causes a use-before-set
crash
- Maintainer update for the Synopsis prototyping device driver"
* tag 'pci-v4.9-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: designware-plat: Update author email address
PCI: layerscape: Fix drvdata usage before assignment
PCI: designware-plat: Change maintainer to Jose Abreu
git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc
Pull MMC fixes from Ulf Hansson:
"Here are some mmc fixes intended for v4.9 rc2.
This time I have also included a few changes for a memstick driver
which has a corresponding mmc driver. They use the same USB device as
parent, hence both needs to play nice with runtime PM, which they
didn't.
MMC core:
- Update MAINTAINERS as the mmc tree moved to kernel.org
- A few fixes for HS400es mode
- A few other minor fixes
MMC host:
- sdhci: Fix an issue when dealing with stop commands
- sdhci-pci: Fix a bus power failure issue
- sdhci-esdhc-imx: Correct two register accesses
- sdhci-of-arasan: Fix the 1.8V I/O signal switch behaviour
- rtsx_usb_sdmmc: Fix runtime PM issues
Other: (Because of no maintainer)
- memstick: rtsx_usb_ms: Fix runtime PM issues"
* tag 'mmc-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc:
MAINTAINERS: mmc: Move the mmc tree to kernel.org
memstick: rtsx_usb_ms: Manage runtime PM when accessing the device
memstick: rtsx_usb_ms: Runtime resume the device when polling for cards
mmc: rtsx_usb_sdmmc: Handle runtime PM while changing the led
mmc: rtsx_usb_sdmmc: Avoid keeping the device runtime resumed when unused
mmc: sdhci: cast unsigned int to unsigned long long to avoid unexpeted error
mmc: sdhci-esdhc-imx: Correct two register accesses
mmc: sdhci-pci: Fix bus power failing to enable for some Intel controllers
mmc: sdhci-pci: Let devices define their own sdhci_ops
mmc: sdhci: Rename sdhci_set_power() to sdhci_set_power_noreg()
mmc: sdhci: Fix SDHCI_QUIRK2_STOP_WITH_TC
mmc: core: Annotate cmd_hdr as __le32
mmc: sdhci-of-arasan: add sdhci_arasan_voltage_switch for arasan, 5.1
mmc: core: changes frequency to hs_max_dtr when selecting hs400es
mmc: core: switch to 1V8 or 1V2 for hs400es mode
mmc: block: add missing header dependencies
mmc: sdhci-of-arasan: Fix non static symbol warning
At the request of Matt, I am taking up co-maintainership of the EFI
subsystem. So add my name to the EFI section in MAINTAINERS, and
change the SCM tree reference to point to the new shared Git repo.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: linux-efi@vger.kernel.org
Link: http://lkml.kernel.org/r/20161018143318.15673-2-matt@codeblueprint.co.uk
I would like to take maintainership for Marvell berlin SoCs.
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Change designware-plat maintainer to Jose Abreu.
Signed-off-by: Joao Pinto <jpinto@synopsys.com>
Pull MIPS updates from Ralf Baechle:
"This is the main MIPS pull request for 4.9:
MIPS core arch code:
- traps: 64bit kernels should read CP0_EBase 64bit
- traps: Convert ebase to KSEG0
- c-r4k: Drop bc_wback_inv() from icache flush
- c-r4k: Split user/kernel flush_icache_range()
- cacheflush: Use __flush_icache_user_range()
- uprobes: Flush icache via kernel address
- KVM: Use __local_flush_icache_user_range()
- c-r4k: Fix flush_icache_range() for EVA
- Fix -mabi=64 build of vdso.lds
- VDSO: Drop duplicated -I*/-E* aflags
- tracing: move insn_has_delay_slot to a shared header
- tracing: disable uprobe/kprobe on compact branch instructions
- ptrace: Fix regs_return_value for kernel context
- Squash lines for simple wrapper functions
- Move identification of VP(E) into proc.c from smp-mt.c
- Add definitions of SYNC barrierstype values
- traps: Ensure full EBase is written
- tlb-r4k: If there are wired entries, don't use TLBINVF
- Sanitise coherentio semantics
- dma-default: Don't check hw_coherentio if device is non-coherent
- Support per-device DMA coherence
- Adjust MIPS64 CAC_BASE to reflect Config.K0
- Support generating Flattened Image Trees (.itb)
- generic: Introduce generic DT-based board support
- generic: Convert SEAD-3 to a generic board
- Enable hardened usercopy
- Don't specify STACKPROTECTOR in defconfigs
Octeon:
- Delete dead code and files across the platform.
- Change to use all memory into use by default.
- Rename upper case variables in setup code to lowercase.
- Delete legacy hack for broken bootloaders.
- Leave maintaining the link state to the actual ethernet/PHY drivers.
- Add DTS for D-Link DSR-500N.
- Fix PCI interrupt routing on D-Link DSR-500N.
Pistachio:
- Remove ANDROID_TIMED_OUTPUT from defconfig
TX39xx:
- Move GPIO setup from .mem_setup() to .arch_init()
- Convert to Common Clock Framework
TX49xx:
txx9wdt:
- Add missing clock (un)prepare calls for CCF
BMIPS:
- Add PW, GPIO SDHCI and NAND device node names
- Support APPENDED_DTB
- Add missing bcm97435svmb to DT_NONE
- Rename bcm96358nb4ser to bcm6358-neufbox4-sercom
- Add DT examples for BCM63268, BCM3368 and BCM6362
- Add support for BCM3368 and BCM6362
PCI
- Reduce stack frame usage
- Use struct list_head lists
- Support for CONFIG_PCI_DOMAINS_GENERIC
- Make pcibios_set_cache_line_size an initcall
- Inline pcibios_assign_all_busses
- Split pci.c into pci.c & pci-legacy.c
- Introduce CONFIG_PCI_DRIVERS_LEGACY
- Support generic drivers
CPC
- Convert bare 'unsigned' to 'unsigned int'
- Avoid lock when MIPS CM >= 3 is present
GIC:
- Delete unused file smp-gic.c
mt7620:
- Delete unnecessary assignment for the field "owner" from PCI
BCM63xx:
- Let clk_disable() return immediately if clk is NULL
pm-cps:
- Change FSB workaround to CPU blacklist
- Update comments on barrier instructions
- Use MIPS standard lightweight ordering barrier
- Use MIPS standard completion barrier
- Remove selection of sync types
- Add MIPSr6 CPU support
- Support CM3 changes to Coherence Enable Register
SMP:
- Wrap call to mips_cpc_lock_other in mips_cm_lock_other
- Introduce mechanism for freeing and allocating IPIs
cpuidle:
- cpuidle-cps: Enable use with MIPSr6 CPUs.
SEAD3:
- Rewrite to use DT and generic kernel feature.
USB:
- host: ehci-sead3: Remove SEAD-3 EHCI code
FBDEV:
- cobalt_lcdfb: Drop SEAD3 support
dt-bindings:
- Document a binding for simple ASCII LCDs
auxdisplay:
- img-ascii-lcd: driver for simple ASCII LCD displays
irqchip i8259:
- i8259: Add domain before mapping parent irq
- i8259: Allow platforms to override poll function
- i8259: Remove unused i8259A_irq_pending
Malta:
- Rewrite to use DT
of/platform:
- Probe "isa" busses by default
CM:
- Print CM error reports upon bus errors
Module:
- Migrate exception table users off module.h and onto extable.h
- Make various drivers explicitly non-modular:
- Audit and remove any unnecessary uses of module.h
mailmap:
- Canonicalize to Qais' current email address.
Documentation:
- MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
Loongson1C:
- Add CPU support for Loongson1C
- Add board support
- Add defconfig
- Add RTC support for Loongson1C board
All this except one Documentation fix has sat in linux-next and has
survived Imagination's automated build test system"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (127 commits)
Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
MIPS: ptrace: Fix regs_return_value for kernel context
MIPS: VDSO: Drop duplicated -I*/-E* aflags
MIPS: Fix -mabi=64 build of vdso.lds
MIPS: Enable hardened usercopy
MIPS: generic: Convert SEAD-3 to a generic board
MIPS: generic: Introduce generic DT-based board support
MIPS: Support generating Flattened Image Trees (.itb)
MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0
MIPS: Print CM error reports upon bus errors
MIPS: Support per-device DMA coherence
MIPS: dma-default: Don't check hw_coherentio if device is non-coherent
MIPS: Sanitise coherentio semantics
MIPS: PCI: Support generic drivers
MIPS: PCI: Introduce CONFIG_PCI_DRIVERS_LEGACY
MIPS: PCI: Split pci.c into pci.c & pci-legacy.c
MIPS: PCI: Inline pcibios_assign_all_busses
MIPS: PCI: Make pcibios_set_cache_line_size an initcall
MIPS: PCI: Support for CONFIG_PCI_DOMAINS_GENERIC
MIPS: PCI: Use struct list_head lists
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull kselftest updates from Shuah Khan:
"This update consists of:
- Fixes and improvements to existing tests
- Moving code from Documentation to selftests, samples, and tools:
* Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and
networking tests from Documentation to selftests.
* Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay,
and blackfin examples from Documentation to samples.
* Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from
Documentation to tools.
* Deletes BUILD_DOCSRC and its dependencies"
* tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits)
selftests/futex: Check ANSI terminal color support
Doc: update 00-INDEX files to reflect the runnable code move
samples: move blackfin gptimers-example from Documentation
tools: move pcmcia crc32hash tool from Documentation
tools: move laptops dslm tool from Documentation
tools: move accounting tool from Documentation
samples: move auxdisplay example code from Documentation
samples: move watchdog example code from Documentation
samples: move timers example code from Documentation
samples: move misc-devices/mei example code from Documentation
samples: move mic/mpssd example code from Documentation
selftests: Move networking/timestamping from Documentation
selftests: move watchdog tests from Documentation/watchdog
selftests: move ia64 tests from Documentation/ia64
selftests: move vDSO tests from Documentation/vDSO
selftests: move ptp tests from Documentation/ptp
selftests: move prctl tests from Documentation/prctl
selftests: move dnotify_test from Documentation/filesystems
selftests/timers: Add missing error code assignment before test
selftests/zram: replace ZRAM_LZ4_COMPRESS
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull some more input subsystem updates from Dmitry Torokhov:
"An update to the ALPS driver to support the V8 protocol with
touchstick, a change for i8042 to skip selftest on many Asus laptops
which helps to keep their touchpads working after resume, and a couple
other driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: i8042 - skip selftest on ASUS laptops
Input: melfas_mip4 - add ic_name sysfs attribute
Input: melfas_mip4 - add maintainer information
Input: melfas_mip4 - add devicetree binding documentations
Input: elantech - add Fujitsu Lifebook E556 to force crc_enabled
Input: synaptics-rmi4 - fix error handling in I2C transport driver
Input: synaptics-rmi4 - fix error handling in SPI transport driver
Input: ALPS - add V8 protocol documentation
Input: ALPS - set DualPoint flag for 74 03 28 devices
Input: ALPS - allow touchsticks to report pressure
Input: ALPS - handle 0-pressure 1F events
Input: ALPS - add touchstick support for SS5 hardware
Input: elantech - force needed quirks on Fujitsu H760
Input: elantech - fix Lenovo version typo
Pull more ACPI updates from Rafael Wysocki:
"This includes a couple of fixes needed after recent changes, two ACPI
driver fixes (fan and "Processor Aggregator"), an update of the ACPI
device properties handling code and a new MAINTAINERS entry for ACPI
on ARM64.
Specifics:
- Fix an unused function warning that started to appear after recent
changes in the ACPI EC driver (Eric Biggers).
- Fix the KERN_CONT usage in acpi_os_vprintf() that has become
(particularly) annoying recently (Joe Perches).
- Fix the fan status checking in the ACPI fan driver to avoid
returning incorrect error codes sometimes (Srinivas Pandruvada).
- Fix the ACPI Processor Aggregator driver (PAD) to always let the
special processor_aggregator driver from Xen take over when running
as Xen dom0 (Juergen Gross).
- Update the handling of reference device properties in ACPI by
allowing empty rows ("holes") to appear in reference property lists
(Mika Westerberg).
- Add a new MAINTAINERS entry for ACPI on ARM64 (Lorenzo Pieralisi)"
* tag 'acpi-extra-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
acpi_os_vprintf: Use printk_get_level() to avoid unnecessary KERN_CONT
ACPI / PAD: don't register acpi_pad driver if running as Xen dom0
ACPI / property: Allow holes in reference properties
MAINTAINERS: Add ARM64-specific ACPI maintainers entry
ACPI / EC: Fix unused function warning when CONFIG_PM_SLEEP=n
ACPI / fan: Fix error reading cur_state
Pull more SCSI updates from James Bottomley:
"This is just a set of minor updates and fixes which weren't quite
ready in time for the first pull request.
The only real thing of note is Mike Christie is stepping down as
Maintainer of iscsi to be replaced by Lee Duncan and Chris Leech"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi: ufs: Kconfig fix
scsi: g_NCR5380: Stop using scsi_module.c
scsi: g_NCR5380: Reduce overrides[] from array to struct
scsi: g_NCR5380: Remove deprecated __setup
scsi: ufs: Fix error return code in ufshcd_init()
scsi: ufs: Data Segment only needed for WRITE DESCRIPTOR
scsi: cxgb4i: Set completion bit in work request
MAINTAINERS: Update open-iscsi maintainers
scsi: ufs: Enable no vccq quirk for skhynix device
scsi: be2iscsi: mark symbols static where possible
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull more powerpc updates from Michael Ellerman:
"Some more powerpc updates for 4.9:
Freescale updates from Scott Wood:
- qbman support (a prerequisite for datapath drivers such as ethernet)
- a PCI DMA fix+improvement
- reset handler changes
- more 8xx optimizations
- some cleanups and fixes.'
Fixes:
- selftests/powerpc: Add missing binaries to .gitignores (Michael Ellerman)
- selftests/powerpc: Fix build break caused by EXPORT_SYMBOL changes (Michael Ellerman)
- powerpc/pseries: Fix stack corruption in htpe code (Laurent Dufour)
- powerpc/64s: Fix power4_fixup_nap placement (Nicholas Piggin)
- powerpc/64: Fix incorrect return value from __copy_tofrom_user (Paul Mackerras)
- powerpc/mm/hash64: Fix might_have_hea() check (Michael Ellerman)
Other:
- MAINTAINERS: Remove myself from PA Semi entries (Olof Johansson)
- MAINTAINERS: Drop separate pseries entry (Michael Ellerman)
- MAINTAINERS: Update powerpc website & add selftests (Michael Ellerman):
* tag 'powerpc-4.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (35 commits)
arch/powerpc: Add CONFIG_FSL_DPAA to corenetXX_smp_defconfig
soc/qman: Add self-test for QMan driver
soc/bman: Add self-test for BMan driver
soc/fsl: Introduce DPAA 1.x QMan device driver
soc/fsl: Introduce DPAA 1.x BMan device driver
powerpc/8xx: make user addr DTLB miss the short path
powerpc/8xx: Move additional DTLBMiss handlers out of exception area
powerpc/8xx: use r3 to scratch CR in ITLBmiss
soc/fsl/qe: fix gpio save_regs functions
powerpc/8xx: add dedicated machine check handler
powerpc/8xx: add system_reset_exception
* device-properties:
* acpi-misc:
PCI changes for the v4.9 merge window:
"Here are some more changes I'd like to have in v4.9. There's one
small Tegra bug fix in the PHY poweroff path, which is only used in
failure paths.
The rest is all strictly cleanup that should make host bridge drivers
more readable, but shouldn't actually change any behavior.
Summary:
- use local struct device pointers in many host bridge drivers for
clarity
- remove unused platform data
- use generic DesignWare accessors
- misc cleanups: remove redundant structure entries and re-order
structure members to put comon generic fields first etc"
* tag 'pci-v4.9-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (108 commits)
MAINTAINERS: Add maintainer for the PCIe Marvell Armada 8K driver
MAINTAINERS: Add DT binding to the Aardvark PCIe driver maintainer
PCI: rockchip: Indent "if" statement body
PCI: hisi: Reorder struct hisi_pcie
PCI: hisi: Pass device-specific struct to internal functions
PCI: hisi: Include register block base in PCIE_SYS_STATE4 address
PCI: dra7xx: Reorder struct dra7xx_pcie
PCI: xilinx-nwl: Remove unused platform data
PCI: xilinx-nwl: Add local struct device pointers
PCI: xilinx: Removed unused xilinx_pcie_assign_msi() argument
PCI: xilinx: Remove unused platform data
PCI: xilinx: Add local struct device pointers
PCI: xgene: Add register accessors
PCI: xgene: Pass struct xgene_pcie_port to setup functions
PCI: xgene: Remove unused platform data
PCI: tegra: Remove unused platform data
PCI: tegra: Add local struct device pointers
PCI: tegra: Fix argument order in tegra_pcie_phy_disable()
PCI: rockchip: Remove unused platform data
PCI: rcar-gen2: Add local struct device pointers
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
"Main changes:
- amba-cldc: DT backlight support, Nomadik support, Versatile
improvements, fixes
- efifb: fix fbcon RGB565 palette
- exynos: remove unused DSI driver"
* tag 'fbdev-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (42 commits)
video: smscufx: remove unused variable
matroxfb: fix size of memcpy
fbdev: ssd1307fb: fix a possible NULL dereference
fbdev: ssd1307fb: constify the device_info pointer
simplefb: Disable and release clocks and regulators in destroy callback
video: fbdev: constify fb_fix_screeninfo and fb_var_screeninfo structures
matroxfb: constify local structures
video: fbdev: i810: add in missing white space in error message text
video: fbdev: add missing \n at end of printk error message
ARM: exynos_defconfig: Remove old non-working MIPI driver
video: fbdev: exynos: Remove old non-working MIPI driver
omapfb: fix return value check in dsi_bind()
MAINTAINERS: update fbdev entries
video: fbdev: offb: Call pci_enable_device() before using the PCI VGA device
fbdev: vfb: simplify memory management
fbdev: vfb: add option for video mode
fbdev: vfb: add description to module parameters
video: fbdev: intelfb: remove impossible condition
fb: adv7393: off by one in probe function
video: fbdev: pxafb: add missing of_node_put() in of_get_pxafb_mode_info()
'pci/host-exynos', 'pci/host-hisi', 'pci/host-imx6', 'pci/host-keystone', 'pci/host-layerscape', 'pci/host-qcom' and 'pci/host-spear' into next
* pci/host-armada:
PCI: armada: Reorder struct armada8k_pcie
PCI: armada: Pass device-specific struct to internal functions
PCI: armada: Use generic DesignWare accessors
PCI: armada: Remove redundant struct armada8k_pcie.base
PCI: armada: Add local base pointer
PCI: armada: Remove unused platform data
* pci/host-artpec:
PCI: artpec6: Add resource name comments
PCI: artpec6: Pass device-specific struct to internal functions
PCI: artpec6: Remove unnecessary artpec6_pcie_link_up()
PCI: artpec6: Use generic DesignWare accessors
PCI: artpec6: Add register accessors
PCI: artpec6: Remove unused platform data
PCI: artpec6: Add local struct device pointers
* pci/host-dra7xx:
PCI: dra7xx: Move struct pcie_port setup to probe function
PCI: dra7xx: Pass device-specific struct to internal functions
PCI: dra7xx: Use generic DesignWare accessors
PCI: dra7xx: Set drvdata at end of probe function
PCI: dra7xx: Remove redundant struct device pointer from dra7xx_pcie
PCI: dra7xx: Add local struct device pointers
* pci/host-exynos:
PCI: exynos: Reorder struct exynos_pcie
PCI: exynos: Pass device-specific struct to internal functions
PCI: exynos: Name private struct pointer "exynos_pcie" consistently
PCI: exynos: Uninline register accessors
PCI: exynos: Add local struct device pointers
* pci/host-hisi:
PCI: hisi: Use generic DesignWare accessors
PCI: hisi: Remove redundant struct hisi_pcie.reg_base
PCI: hisi: Name private struct pointer "hisi_pcie" consistently
PCI: hisi: Remove unused platform data
PCI: hisi: Add local struct device pointers
* pci/host-imx6:
PCI: imx6: Remove unused return values
PCI: imx6: Reorder struct imx6_pcie
PCI: imx6: Use generic DesignWare accessors
PCI: imx6: Pass device-specific struct to internal functions
PCI: imx6: Pass struct imx6_pcie to PHY accessors
PCI: imx6: Removed unused struct imx6_pcie.mem_base
PCI: imx6: Remove redundant of_node pointer
PCI: imx6: Add local struct device pointers
* pci/host-keystone:
PCI: keystone: Reorder struct keystone_pcie
PCI: keystone: Add app register accessors
PCI: keystone: Pass keystone_pcie, not va_app_base, to DBI functions
PCI: keystone: Pass keystone_pcie, not address, to IRQ functions
PCI: keystone: Use generic DesignWare accessors
PCI: keystone: Add local struct device pointers
* pci/host-layerscape:
PCI: layerscape: Reorder struct ls_pcie
PCI: layerscape: Remove unused ls_add_pcie_port() platform_device arg
PCI: layerscape: Move struct pcie_port setup to probe function
PCI: layerscape: Pass device-specific struct to internal functions
PCI: layerscape: Remove redundant struct ls_pcie.dbi
PCI: layerscape: Remove unused platform data
PCI: layerscape: Add local struct device pointers
* pci/host-qcom:
PCI: qcom: Reorder struct qcom_pcie
PCI: qcom: Remove redundant struct qcom_pcie.dev
PCI: qcom: Remove redundant struct qcom_pcie.dbi
PCI: qcom: Remove unused platform data
* pci/host-spear:
PCI: spear: Clean up struct device usage
PCI: spear: Reorder struct spear13xx_pcie
PCI: spear: Pass device-specific struct to internal functions
PCI: spear: Remove unused constants
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Pull drm updates from Dave Airlie:
"Core:
- Fence destaging work
- DRIVER_LEGACY to split off legacy drm drivers
- drm_mm refactoring
- Splitting drm_crtc.c into chunks and documenting better
- Display info fixes
- rbtree support for prime buffer lookup
- Simple VGA DAC driver
Panel:
- Add Nexus 7 panel
- More simple panels
i915:
- Refactoring GEM naming
- Refactored vma/active tracking
- Lockless request lookups
- Better stolen memory support
- FBC fixes
- SKL watermark fixes
- VGPU improvements
- dma-buf fencing support
- Better DP dongle support
amdgpu:
- Powerplay for Iceland asics
- Improved GPU reset support
- UVD/VEC powergating support for CZ/ST
- Preinitialised VRAM buffer support
- Virtual display support
- Initial SI support
- GTT rework
- PCI shutdown callback support
- HPD IRQ storm fixes
amdkfd:
- bugfixes
tilcdc:
- Atomic modesetting support
mediatek:
- AAL + GAMMA engine support
- Hook up gamma LUT
- Temporal dithering support
imx:
- Pixel clock from devicetree
- drm bridge support for LVDS bridges
- active plane reconfiguration
- VDIC deinterlacer support
- Frame synchronisation unit support
- Color space conversion support
analogix:
- PSR support
- Better panel on/off support
rockchip:
- rk3399 vop/crtc support
- PSR support
vc4:
- Interlaced vblank timing
- 3D rendering CPU overhead reduction
- HDMI output fixes
tda998x:
- HDMI audio ASoC support
sunxi:
- Allwinner A33 support
- better TCON support
msm:
- DT binding cleanups
- Explicit fence-fd support
sti:
- remove sti415/416 support
etnaviv:
- MMUv2 refactoring
- GC3000 support
exynos:
- Refactoring HDMI DCC/PHY
- G2D pm regression fix
- Page fault issues with wait for vblank
There is no nouveau work in this tree, as Ben didn't get a pull
request in, and he was fighting moving to atomic and adding mst
support, so maybe best it waits for a cycle"
* tag 'drm-for-v4.9' of git://people.freedesktop.org/~airlied/linux: (1412 commits)
drm/crtc: constify drm_crtc_index parameter
drm/i915: Fix conflict resolution from backmerge of v4.8-rc8 to drm-next
drm/i915/guc: Unwind GuC workqueue reservation if request construction fails
drm/i915: Reset the breadcrumbs IRQ more carefully
drm/i915: Force relocations via cpu if we run out of idle aperture
drm/i915: Distinguish last emitted request from last submitted request
drm/i915: Allow DP to work w/o EDID
drm/i915: Move long hpd handling into the hotplug work
drm/i915/execlists: Reinitialise context image after GPU hang
drm/i915: Use correct index for backtracking HUNG semaphores
drm/i915: Unalias obj->phys_handle and obj->userptr
drm/i915: Just clear the mmiodebug before a register access
drm/i915/gen9: only add the planes actually affected by ddb changes
drm/i915: Allow PCH DPLL sharing regardless of DPLL_SDVO_HIGH_SPEED
drm/i915/bxt: Fix HDMI DPLL configuration
drm/i915/gen9: fix the watermark res_blocks value
drm/i915/gen9: fix plane_blocks_per_line on watermarks calculations
drm/i915/gen9: minimum scanlines for Y tile is not always 4
drm/i915/gen9: fix the WaWmMemoryReadLatency implementation
drm/i915/kbl: KBL also needs to run the SAGV code
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Documentation improvements: conversion of all non-DocBook documents
to Sphinx and lots of fixes to the uAPI media book
- New PCI driver for Techwell TW5864 media grabber boards
- New SoC driver for ATMEL Image Sensor Controller
- Removal of some obsolete SoC drivers (s5p-tv driver and soc_camera
drivers)
- Addition of ST CEC driver
- Lots of drivers fixes, improvements and additions
* tag 'media/v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (464 commits)
[media] ttusb_dec: avoid the risk of go past buffer
[media] cx23885: Fix some smatch warnings
[media] si2165: switch to regmap
[media] si2165: use i2c_client->dev instead of i2c_adapter->dev for logging
[media] si2165: Remove legacy attach
[media] cx231xx: attach si2165 driver via i2c_client
[media] cx231xx: Prepare for attaching new style i2c_client DVB demod drivers
[media] cx23885: attach si2165 driver via i2c_client
[media] si2165: support i2c_client attach
[media] si2165: avoid division by zero
[media] rcar-vin: add R-Car gen2 fallback compatibility string
[media] lgdt3306a: remove 20*50 msec unnecessary timeout
[media] cx25821: Remove deprecated create_singlethread_workqueue
[media] cx25821: Drop Freeing of Workqueue
[media] cxd2841er: force 8MHz bandwidth for DVB-C if specified bw not supported
[media] redrat3: hardware-specific parameters
[media] redrat3: remove hw_timeout member
[media] cxd2841er: BER and SNR reading for ISDB-T
[media] dvb-usb: avoid link error with dib3000m{b,c|
[media] dvb-usb: split out common parts of dibusb
1) Netfilter list handling fix, from Linus.
2) RXRPC/AFS bug fixes from David Howells (oops on call to serviceless
endpoints, build warnings, missing notifications, etc.) From David
Howells.
3) Kernel log message missing newlines, from Colin Ian King.
4) Don't enter direct reclaim in netlink dumps, the idea is to use a
high order allocation first and fallback quickly to a 0-order
allocation if such a high-order one cannot be done cheaply and
without reclaim. From Eric Dumazet.
5) Fix firmware download errors in btusb bluetooth driver, from Ethan
Hsieh.
6) Missing Kconfig deps for QCOM_EMAC, from Geert Uytterhoeven.
7) Fix MDIO_XGENE dup Kconfig entry. From Laura Abbott.
8) Constrain ipv6 rtr_solicits sysctl values properly, from Maciej
Żenczykowski.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits)
netfilter: Fix slab corruption.
be2net: Enable VF link state setting for BE3
be2net: Fix TX stats for TSO packets
be2net: Update Copyright string in be_hw.h
be2net: NCSI FW section should be properly updated with ethtool for BE3
be2net: Provide an alternate way to read pf_num for BEx chips
wan/fsl_ucc_hdlc: Fix size used in dma_free_coherent()
net: macb: NULL out phydev after removing mdio bus
xen-netback: make sure that hashes are not send to unaware frontends
Fixing a bug in team driver due to incorrect 'unsigned int' to 'int' conversion
MAINTAINERS: add myself as a maintainer of xen-netback
ipv6 addrconf: disallow rtr_solicits < -1
Bluetooth: btusb: Fix atheros firmware download error
drivers: net: phy: Correct duplicate MDIO_XGENE entry
ethernet: qualcomm: QCOM_EMAC should depend on HAS_DMA and HAS_IOMEM
net: ethernet: mediatek: remove hwlro property in the device tree
net: ethernet: mediatek: get hw lro capability by the chip id instead of by the dtsi
net: ethernet: mediatek: get the chip id by ETHDMASYS registers
net: bgmac: Fix errant feature flag check
netlink: do not enter direct reclaim from netlink_dump()
Pull MTD updates from Brian Norris:
"I've not been very active this cycle, so these are mostly from Boris,
for the NAND flash subsystem.
NAND:
- Add the infrastructure to automate NAND timings configuration
- Provide a generic DT property to maximize ECC strength
- Some refactoring in the core bad block table handling, to help with
improving some of the logic in error cases.
- Minor cleanups and fixes
MTD:
- Add APIs for handling page pairing; this is necessary for reliably
supporting MLC and TLC NAND flash, where paired-page disturbance
affects reliability. Upper layers (e.g., UBI) should make use of
these in the near future"
* tag 'for-linus-20161008' of git://git.infradead.org/linux-mtd: (35 commits)
mtd: nand: fix trivial spelling error
mtdpart: Propagate _get/put_device()
mtd: nand: Provide nand_cleanup() function to free NAND related resources
mtd: Kill the OF_MTD Kconfig option
mtd: nand: mxc: Test CONFIG_OF instead of CONFIG_OF_MTD
mtd: nand: Fix nand_command_lp() for 8bits opcodes
mtd: nand: sunxi: Support ECC maximization
mtd: nand: Support maximizing ECC when using software BCH
mtd: nand: Add an option to maximize the ECC strength
mtd: nand: mxc: Add timing setup for v2 controllers
mtd: nand: mxc: implement onfi get/set features
mtd: nand: sunxi: switch from manual to automated timing config
mtd: nand: automate NAND timings selection
mtd: nand: Expose data interface for ONFI mode 0
mtd: nand: Add function to convert ONFI mode to data_interface
mtd: nand: convert ONFI mode into data interface
mtd: nand: Introduce nand_data_interface
mtd: nand: Create a NAND reset function
mtd: nand: remove unnecessary 'extern' from function declarations
MAINTAINERS: Add maintainer entry for Ingenic JZ4780 NAND driver
The ARM64 architecture defines ARM64 specific ACPI bindings to
configure and set-up arch specific components. To simplify
code reviews/updates and streamline the maintainership structure
supporting the arch specific code, a new arm64 directory was created in
/drivers/acpi, to contain ACPI code that is specific to ARM64
architecture.
Add the ARM64-specific ACPI maintainers entry in MAINTAINERS for
the newly created subdirectory and respective code content.
Lorenzo Pieralisi will be in charge of submitting and managing
the pull requests on behalf of all maintainers listed.
Link: http://lkml.kernel.org/r/1603704.EGiVTcCxLR@vostro.rjw.lan
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull main rdma updates from Doug Ledford:
"This is the main pull request for the rdma stack this release. The
code has been through 0day and I had it tagged for linux-next testing
for a couple days.
Summary:
- updates to mlx5
- updates to mlx4 (two conflicts, both minor and easily resolved)
- updates to iw_cxgb4 (one conflict, not so obvious to resolve,
proper resolution is to keep the code in cxgb4_main.c as it is in
Linus' tree as attach_uld was refactored and moved into
cxgb4_uld.c)
- improvements to uAPI (moved vendor specific API elements to uAPI
area)
- add hns-roce driver and hns and hns-roce ACPI reset support
- conversion of all rdma code away from deprecated
- security improvement: remove unsafe ib_get_dma_mr (breaks lustre in
staging)"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (75 commits)
staging/lustre: Disable InfiniBand support
iw_cxgb4: add fast-path for small REG_MR operations
cxgb4: advertise support for FR_NSMR_TPTE_WR
IB/core: correctly handle rdma_rw_init_mrs() failure
IB/srp: Fix infinite loop when FMR sg[0].offset != 0
IB/srp: Remove an unused argument
IB/core: Improve ib_map_mr_sg() documentation
IB/mlx4: Fix possible vl/sl field mismatch in LRH header in QP1 packets
IB/mthca: Move user vendor structures
IB/nes: Move user vendor structures
IB/ocrdma: Move user vendor structures
IB/mlx4: Move user vendor structures
IB/cxgb4: Move user vendor structures
IB/cxgb3: Move user vendor structures
IB/mlx5: Move and decouple user vendor structures
IB/{core,hw}: Add constant for node_desc
ipoib: Make ipoib_warn ratelimited
IB/mlx4/alias_GUID: Remove deprecated create_singlethread_workqueue
IB/ipoib_verbs: Remove deprecated create_singlethread_workqueue
IB/ipoib: Remove deprecated create_singlethread_workqueue
Pull ARM DT updates from Arnd Bergmann:
"These are as usual a very large number of mostly boring updates to
enable devices in existing machines, or to fix minor bugs. Notably, an
ongoing treewide effort to fix warnings caused by an update to the
device tree compiler. These are enabled with "make W=1" at the moment
but can hopefully become the default once all issues have been
addressed.
No new SoC platform is added this time around (Armada 395 and Orion
mv88f5181 are slight variations of existing ones), but a significant
number of new dts files are added, which I list by platform:
- Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets,
Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite,
Olimex A33-Olinuxino, and Nano Pi Neo single-board computers
- ARM Realview: all supported machines (ported from board files)
- Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and
BCM958622hr reference boards for Northstar platform, Raspberry Pi
Zero single-board computer
- Marvell EBU: Netgear WNR854T router (ported from board file),
Armada 395 SoC platform and GP board Armada 390 DB development
board
- NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x
single-board computer, Technologic Systems TS-4900 and Engicam
IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board
- Qualcomm: LG Nexus 5 Phone
- Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards
- Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288
Reload platform
- ST Microelectronics STi: B2260 (96boards) single-board computer
- TI Davinci: OMAP-L138 LCDK Development kit
- TI OMAP: beagleboard-x15 rev B1 single-board computer"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits)
ARM: dts: sony-nsz-gs7: add missing unit name to /memory node
ARM: dts: chromecast: add missing unit name to /memory node
ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node
ARM: dts: berlin2: Add missing unit name to /soc node
ARM: dts: berlin2cd: Add missing unit name to /soc node
ARM: dts: berlin2q: Add missing unit name to /soc node
ARM: dts: berlin2: Remove skeleton.dtsi inclusion
ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion
ARM: dts: berlin2q: Remove skeleton.dtsi inclusion
arm: dts: berlin2q: enable all wdt nodes unconditionally
arm: dts: berlin2: enable all wdt nodes unconditionally
ARM: dts: omap5-igep0050.dts: Use tabs for indentation
ARM: dts: Fix igepv5 power button GPIO direction
ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node
ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes
ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- The Qualcomm external bus interface 2 (EBI2), used in some of their
mobile phone chips for connecting flash memory, LCD displays or
other peripherals
- Secure monitor firmware for Amlogic SoCs, and an NVMEM driver for
the EFUSE based on that firmware interface.
- Perf support for the AppliedMicro X-Gene performance monitor unit
- Reset driver for STMicroelectronics STM32
- Reset driver for SocioNext UniPhier SoCs
Aside from these, there are minor updates to SoC-specific bus,
clocksource, firmware, pinctrl, reset, rtc and pmic drivers"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
bus: qcom-ebi2: depend on HAS_IOMEM
pinctrl: mvebu: orion5x: Generalise mv88f5181l support for 88f5181
clk: mvebu: Add clk support for the orion5x SoC mv88f5181
dt-bindings: EXYNOS: Add Exynos5433 PMU compatible
clocksource: exynos_mct: Add the support for ARM64
perf: xgene: Add APM X-Gene SoC Performance Monitoring Unit driver
Documentation: Add documentation for APM X-Gene SoC PMU DTS binding
MAINTAINERS: Add entry for APM X-Gene SoC PMU driver
bus: qcom: add EBI2 driver
bus: qcom: add EBI2 device tree bindings
rtc: rtc-pm8xxx: Add support for pm8018 rtc
nvmem: amlogic: Add Amlogic Meson EFUSE driver
firmware: Amlogic: Add secure monitor driver
soc: qcom: smd: Reset rx tail rather than tx
memory: atmel-sdramc: fix a possible NULL dereference
reset: hi6220: allow to compile test driver on other architectures
reset: zynq: add driver Kconfig option
reset: sunxi: add driver Kconfig option
reset: stm32: add driver Kconfig option
reset: socfpga: add driver Kconfig option
Pull ARM SoC platform updates from Arnd Bergmann:
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- We get support for running in big-endian mode on two platforms:
sunxi (Allwinner) and s3c24xx (old Samsung).
- The recently added Uniphier platform now uses standard PSCI methods
for SMP booting and we remove support for old bootloader versions
that did not support it yet.
- In sunxi, we gain support for the "Nextthing GR8" SoC, which is a
close relative of the Allwinner A13 and R8 chips.
- PXA completes its move over to the generic dmaengine framework and
removes its old private API
- mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC
with integrated 802.11ac wireless networking"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
ARM: imx legacy: pca100: move peripheral initialization to .init_late
ARM: imx legacy: mx27ads: move peripheral initialization to .init_late
ARM: imx legacy: mx21ads: move peripheral initialization to .init_late
ARM: imx legacy: pcm043: move peripheral initialization to .init_late
ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late
ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late
ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late
ARM: imx legacy: vpr200: move peripheral initialization to .init_late
ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late
ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late
ARM: imx legacy: qong: move peripheral initialization to .init_late
ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late
ARM: imx legacy: pcm037: move peripheral initialization to .init_late
ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late
ARM: imx legacy: mx31ads: move peripheral initialization to .init_late
ARM: imx legacy: mx31lite: move peripheral initialization to .init_late
ARM: imx legacy: kzm: move peripheral initialization to .init_late
MAINTAINERS: update list of Oxnas maintainers
ARM: orion5x: remove extraneous NO_IRQ
ARM: orion: simplify orion_ge00_switch_init
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Major rework of Book3S 64-bit exception vectors (Nicholas Piggin)
- Use gas sections for arranging exception vectors et. al.
- Large set of TM cleanups and selftests (Cyril Bur)
- Enable transactional memory (TM) lazily for userspace (Cyril Bur)
- Support for XZ compression in the zImage wrapper (Oliver
O'Halloran)
- Add support for bpf constant blinding (Naveen N. Rao)
- Beginnings of upstream support for PA Semi Nemo motherboards
(Darren Stevens)
Fixes:
- Ensure .mem(init|exit).text are within _stext/_etext (Michael
Ellerman)
- xmon: Don't use ld on 32-bit (Michael Ellerman)
- vdso64: Use double word compare on pointers (Anton Blanchard)
- powerpc/nvram: Fix an incorrect partition merge (Pan Xinhui)
- powerpc: Fix usage of _PAGE_RO in hugepage (Christophe Leroy)
- powerpc/mm: Update FORCE_MAX_ZONEORDER range to allow hugetlb w/4K
(Aneesh Kumar K.V)
- Fix memory leak in queue_hotplug_event() error path (Andrew
Donnellan)
- Replay hypervisor maintenance interrupt first (Nicholas Piggin)
Various performance optimisations (Anton Blanchard):
- Align hot loops of memset() and backwards_memcpy()
- During context switch, check before setting mm_cpumask
- Remove static branch prediction in atomic{, 64}_add_unless
- Only disable HAVE_EFFICIENT_UNALIGNED_ACCESS on POWER7 little
endian
- Set default CPU type to POWER8 for little endian builds
Cleanups & features:
- Sparse fixes/cleanups (Daniel Axtens)
- Preserve CFAR value on SLB miss caused by access to bogus address
(Paul Mackerras)
- Radix MMU fixups for POWER9 (Aneesh Kumar K.V)
- Support for setting used_(vsr|vr|spe) in sigreturn path (for CRIU)
(Simon Guo)
- Optimise syscall entry for virtual, relocatable case (Nicholas
Piggin)
- Optimise MSR handling in exception handling (Nicholas Piggin)
- Support for kexec with Radix MMU (Benjamin Herrenschmidt)
- powernv EEH fixes (Russell Currey)
- Suprise PCI hotplug support for powernv (Gavin Shan)
- Endian/sparse fixes for powernv PCI (Gavin Shan)
- Defconfig updates (Anton Blanchard)
- KVM: PPC: Book3S HV: Migrate pinned pages out of CMA (Balbir Singh)
- cxl: Flush PSL cache before resetting the adapter (Frederic Barrat)
- cxl: replace loop with for_each_child_of_node(), remove unneeded
of_node_put() (Andrew Donnellan)
- Fix HV facility unavailable to use correct handler (Nicholas
Piggin)
- Remove unnecessary syscall trampoline (Nicholas Piggin)
- fadump: Fix build break when CONFIG_PROC_VMCORE=n (Michael
Ellerman)
- Quieten EEH message when no adapters are found (Anton Blanchard)
- powernv: Add PHB register dump debugfs handle (Russell Currey)
- Use kprobe blacklist for exception handlers & asm functions
(Nicholas Piggin)
- Document the syscall ABI (Nicholas Piggin)
- MAINTAINERS: Update cxl maintainers (Michael Neuling)
- powerpc: Remove all usages of NO_IRQ (Michael Ellerman)
Minor cleanups:
- Andrew Donnellan, Christophe Leroy, Colin Ian King, Cyril Bur,
Frederic Barrat, Pan Xinhui, PrasannaKumar Muralidharan, Rui Teng,
Simon Guo"
* tag 'powerpc-4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (156 commits)
powerpc/bpf: Add support for bpf constant blinding
powerpc/bpf: Implement support for tail calls
powerpc/bpf: Introduce accessors for using the tmp local stack space
powerpc/fadump: Fix build break when CONFIG_PROC_VMCORE=n
powerpc: tm: Enable transactional memory (TM) lazily for userspace
powerpc/tm: Add TM Unavailable Exception
powerpc: Remove do_load_up_transact_{fpu,altivec}
powerpc: tm: Rename transct_(*) to ck(\1)_state
powerpc: tm: Always use fp_state and vr_state to store live registers
selftests/powerpc: Add checks for transactional VSXs in signal contexts
selftests/powerpc: Add checks for transactional VMXs in signal contexts
selftests/powerpc: Add checks for transactional FPUs in signal contexts
selftests/powerpc: Add checks for transactional GPRs in signal contexts
selftests/powerpc: Check that signals always get delivered
selftests/powerpc: Add TM tcheck helpers in C
selftests/powerpc: Allow tests to extend their kill timeout
selftests/powerpc: Introduce GPR asm helper header file
selftests/powerpc: Move VMX stack frame macros to header file
selftests/powerpc: Rework FPU stack placement macros and move to header file
selftests/powerpc: Check for VSX preservation across userspace preemption
Add maintainer information.
Signed-off-by: Sangwon Jee <jeesw@melfas.com>
Pull block layer updates from Jens Axboe:
"This is the main pull request for block layer changes in 4.9.
As mentioned at the last merge window, I've changed things up and now
do just one branch for core block layer changes, and driver changes.
This avoids dependencies between the two branches. Outside of this
main pull request, there are two topical branches coming as well.
This pull request contains:
- A set of fixes, and a conversion to blk-mq, of nbd. From Josef.
- Set of fixes and updates for lightnvm from Matias, Simon, and Arnd.
Followup dependency fix from Geert.
- General fixes from Bart, Baoyou, Guoqing, and Linus W.
- CFQ async write starvation fix from Glauber.
- Add supprot for delayed kick of the requeue list, from Mike.
- Pull out the scalable bitmap code from blk-mq-tag.c and make it
generally available under the name of sbitmap. Only blk-mq-tag uses
it for now, but the blk-mq scheduling bits will use it as well.
From Omar.
- bdev thaw error progagation from Pierre.
- Improve the blk polling statistics, and allow the user to clear
them. From Stephen.
- Set of minor cleanups from Christoph in block/blk-mq.
- Set of cleanups and optimizations from me for block/blk-mq.
- Various nvme/nvmet/nvmeof fixes from the various folks"
* 'for-4.9/block' of git://git.kernel.dk/linux-block: (54 commits)
fs/block_dev.c: return the right error in thaw_bdev()
nvme: Pass pointers, not dma addresses, to nvme_get/set_features()
nvme/scsi: Remove power management support
nvmet: Make dsm number of ranges zero based
nvmet: Use direct IO for writes
admin-cmd: Added smart-log command support.
nvme-fabrics: Add host_traddr options field to host infrastructure
nvme-fabrics: revise host transport option descriptions
nvme-fabrics: rework nvmf_get_address() for variable options
nbd: use BLK_MQ_F_BLOCKING
blkcg: Annotate blkg_hint correctly
cfq: fix starvation of asynchronous writes
blk-mq: add flag for drivers wanting blocking ->queue_rq()
blk-mq: remove non-blocking pass in blk_mq_map_request
blk-mq: get rid of manual run of queue with __blk_mq_run_hw_queue()
block: export bio_free_pages to other modules
lightnvm: propagate device_add() error code
lightnvm: expose device geometry through sysfs
lightnvm: control life of nvm_dev in driver
blk-mq: register device instead of disk
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Here is the 4.9 pull request from I2C including:
- centralized error messages when registering to the core
- improved lockdep annotations to prevent false positives
- DT support for muxes, gates, and arbitrators
- bus speeds can now be obtained from ACPI
- i2c-octeon got refactored and now supports ThunderX SoCs, too
- i2c-tegra and i2c-designware got a bigger bunch of updates
- a couple of standard driver fixes and improvements"
* 'i2c/for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (71 commits)
i2c: axxia: disable clks in case of failure in probe
i2c: octeon: thunderx: Limit register access retries
i2c: uniphier-f: fix misdetection of incomplete STOP condition
gpio: pca953x: variable 'id' was used twice
i2c: i801: Add support for Kaby Lake PCH-H
gpio: pca953x: fix an incorrect lockdep warning
i2c: add a warning to i2c_adapter_depth()
lockdep: make MAX_LOCKDEP_SUBCLASSES unconditionally visible
i2c: export i2c_adapter_depth()
i2c: rk3x: Fix variable 'min_total_ns' unused warning
i2c: rk3x: Fix sparse warning
i2c / ACPI: Do not touch an I2C device if it belongs to another adapter
i2c: octeon: Fix high-level controller status check
i2c: octeon: Avoid sending STOP during recovery
i2c: octeon: Fix set SCL recovery function
i2c: rcar: add support for r8a7796 (R-Car M3-W)
i2c: imx: make bus recovery through pinctrl optional
i2c: meson: add gxbb compatible string
i2c: uniphier-f: set the adapter to master mode when probing
i2c: uniphier-f: avoid WARN_ON() of clk_disable() in failure path
This patch moves nes vendor's specific structures to
common UAPI folder which will be visible to all consumers.
These structures are used by user-space library driver
(libmlx4) and currently manually copied to that library.
This move will allow cross-compile against these files and
simplify introduction of vendor specific data.
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
This patch moves ocrdma vendor's specific structures to
In addition, it changes types to be __uXX instead of uXX.
Acked-By: Devesh Sharma <devesh.sharma@broadcom.com>
This patch moves mlx4 vendor's specific structures to
