path: root/MAINTAINERS
2011-03-21efifb: check that the base address is plausible on pci systemsPeter Jones
commit 85a00d9bbfb4704fbf368944b1cb9fed8f1598c5 upstream. Some Apple machines have identical DMI data but different memory configurations for the video. Given that, check that the address in our table is actually within the range of a PCI BAR on a VGA device in the machine. This also fixes up the return value from set_system(), which has always been wrong, but never resulted in bad behavior since there's only ever been one matching entry in the dmi table. The patch 1) stops people's machines from crashing when we get their display wrong, which seems to be unfortunately inevitable, 2) allows us to support identical dmi data with differing video memory configurations This also adds me as the efifb maintainer, since I've effectively been acting as such for quite some time. Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: bug fix for vlan + gro issue tc35815: Remove a wrong netif_wake_queue() call which triggers BUG_ON cdc_ether: new PID for Ericsson C3607w to the whitelist (resubmit) IPv6: better document max_addresses parameter MAINTAINERS: update mv643xx_eth maintenance status e1000: Fix DMA mapping error handling on RX iwlwifi: sanity check before counting number of tfds can be free iwlwifi: error checking for number of tfds in queue iwlwifi: set HT flags after channel in rxon
2010-02-23MAINTAINERS: update mv643xx_eth maintenance statusLennert Buytenhek
I am no longer with Marvell. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-20Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: allow alignment fault mode to be configured at kernel boot ARM: Update mach-types ARM: 5951/1: ARM: fix documentation of the PrimeCell bus ARM: 5950/1: ARM: Fix build error for arm1026ej-s processor MAINTAINERS: fix my e-mail and status for Gemini and FA526 Gemini: wrong registers used to set reg_level in gpio_set_irq_type() ARM: 5944/1: scsi: fix timer setup in fas216.c ARM: 5938/1: ARM: L2: export outer_cache_fns
2010-02-18MAINTAINERS: fix my e-mail and status for Gemini and FA526Paulius Zaleckas
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com>
2010-02-18Orphan DECnetChristine Caulfield
Due to lack of time, space, motivation, hardware and probably expertise, I have reluctantly decided to orphan the DECnet code in the kernel. Judging by the deafening silence on the linux-decnet mailing list I suspect it's either not being used anyway, or the few people that are using it are happy with their older kernels. Signed-off-by: Christine Caulfield <christine.caulfield@googlemail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11MAINTAINERS: changed LTP maintainership responsibilitiesRishikesh
Change the LTP maintainer responsibities from 2010. Ref: http://marc.info/?l=ltp-list&m=126502242912536&w=2 Signed-off-by : Rishikesh K Rajak <risrajak@linux.vnet.ibm.com> Cc: Subrata Modak <subrata@linux.vnet.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Garrett Cooper <yanegomi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-08MAINTAINERS: networking drivers - Add git net-next treeJoe Perches
During the rc period, patches that are not bugfixes should be done using the net-next tree. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23MAINTAINERS: Add Intel igbvf maintainerJeff Kirsher
Add igbvf to the list of supported Intel drivers and Alex to the list of maintainers. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-22Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-01-17MAINTAINERS: ivtv-devel is moderatedJiri Slaby
Mark ivtv-devel@ivtvdriver.org as 'moderated for non-subscribers'. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-01-17MAINTAINERS: Andy Walls is the new ivtv maintainerHans Verkuil
Replaces Hans Verkuil by Andy Walls as the ivtv maintainer. After 4 1/2 years, Hans decided to hand over the ivtv driver to Andy. Andy was already doing more work on ivtv than him, so this just makes official what was happening in practice. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-01-15MAINTAINERS: transfer maintainership of I/OATDan Williams
Dan Williams takes over I/OAT from Maciej Sosnowski Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-14alpha: add myself as a maintainer, and drop mention of 2.4Matt Turner
CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: linux-alpha@vger.kernel.org Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-01-12Merge branch 'for-linus' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: OMAP: DSS2: OMAPFB: fix crash when panel driver was not loaded OMAP: DSS2: Reject scaling settings when they cannot be supported OMAP: DSS2: Make check-delay-loops consistent OMAP: DSS2: OMAPFB: fix omapfb_free_fbmem() video/omap: add __init/__exit macros to drivers/video/omap/lcd_htcherald.c OMAP: DSS2: Fix compile warning MAINTAINERS: Combine DSS2 and OMAPFB2 into one entry MAINTAINERS: change omapfb maintainer OMAP: OMAPFB: add dummy release function for omapdss OMAP: OMAPFB: fix clk_get for RFBI OMAP: DSS2: RFBI: convert to new kfifo API OMAP: DSS2: Fix crash when panel doesn't define enable_te() OMAP: DSS2: Collect interrupt statistics OMAP: DSS2: DSI: print debug DCS cmd in hex OMAP: DSS2: DSI: fix VC channels in send_short and send_null
2010-01-11MAINTAINERS: Combine DSS2 and OMAPFB2 into one entryTomi Valkeinen
There isn't really any reason to divide those. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2010-01-11MAINTAINERS: change omapfb maintainerTomi Valkeinen
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Acked-by: Imre Deak <imre.deak@nokia.com>
2010-01-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: update mailing list address nilfs2: Storage class should be before const qualifier nilfs2: trivial coding style fix
2010-01-02nilfs2: update mailing list addressRyusuke Konishi
This replaces the list address for nilfs discussion to linux-nilfs at vger.kernel.org from users at nilfs.org. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-12-29firewire, ieee1394: update MAINTAINERS entriesStefan Richter
Ben and Kristian have not been involved in maintenance of the IEEE 1394 drivers for quite some time; submitters are not required to Cc them on patches. The linux1394.org domain has been dead for a while and is no longer under control of a Linux developer. The current web site of the Linux 1394 project is http://ieee1394.wiki.kernel.org/. The classic drivers/ieee1394/ stack is now obsolete from the development point of view, though still a useful alternative in productive use. But nobody should attempt to submit style cleanup patches for it or to develop new drivers on top of this stack, hence mark its MAINTAINERS entry as Obsolete. drivers/ieee1394/raw1394*, like the rest of the old stack, does not receive bigger code changes anymore, hence shrink the MAINTAINERS database a bit by dropping raw1394's special entry. If something important and urgent is going to come up for raw1394, I will make sure that Dan will be notified of it besides via linux1394-devel. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Dan Dennedy <dan@dennedy.org> Cc: Ben Collins <ben.collins@ubuntu.com> Cc: Kristian Hoegsberg <krh@bitplanet.net>
2009-12-24Merge branch 'misc-2.6.33' into releaseLen Brown
2009-12-24Merge branch 'classmate' into releaseLen Brown
2009-12-24classmate-laptop: add support for Classmate PC ACPI devicesThadeu Lima de Souza Cascardo
This add supports for devices like keyboard, backlight, tablet and accelerometer. This work is supported by International Syst S/A. [randy.dunlap@oracle.com: cmpc_acpi: depends on ACPI] [akpm@linux-foundation.org: readability tweaks] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-23USB: musb: MAINTAINERS: Fix my tree's addressFelipe Balbi
The tree is now on a new address. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-23MAINTAINERS: add maintainer for msi-wmi driverAnisse Astier
Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-22MAINTAINERS: update entries for WUSB, UWB and WLP subsystemsDavid Vrabel
Update the file patterns for the WUSB, UWB and WLP subsystems and add netdev@vger as the list for the WLP subsystem. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (34 commits) HWPOISON: Remove stray phrase in a comment HWPOISON: Try to allocate migration page on the same node HWPOISON: Don't do early filtering if filter is disabled HWPOISON: Add a madvise() injector for soft page offlining HWPOISON: Add soft page offline support HWPOISON: Undefine short-hand macros after use to avoid namespace conflict HWPOISON: Use new shake_page in memory_failure HWPOISON: Use correct name for MADV_HWPOISON in documentation HWPOISON: mention HWPoison in Kconfig entry HWPOISON: Use get_user_page_fast in hwpoison madvise HWPOISON: add an interface to switch off/on all the page filters HWPOISON: add memory cgroup filter memcg: add accessor to mem_cgroup.css memcg: rename and export try_get_mem_cgroup_from_page() HWPOISON: add page flags filter mm: export stable page flags HWPOISON: limit hwpoison injector to known page types HWPOISON: add fs/device filters HWPOISON: return 0 to indicate success reliably HWPOISON: make semantics of IGNORED/DELAYED clear ...
2009-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits) net: sh_eth alignment fix for sh7724 using NET_IP_ALIGN V2 ixgbe: allow tx of pre-formatted vlan tagged packets ixgbe: Fix 82598 premature copper PHY link indicatation ixgbe: Fix tx_restart_queue/non_eop_desc statistics counters bcm63xx_enet: fix compilation failure after get_stats_count removal packet: dont call sleeping functions while holding rcu_read_lock() tcp: Revert per-route SACK/DSACK/TIMESTAMP changes. ipvs: zero usvc and udest netfilter: fix crashes in bridge netfilter caused by fragment jumps ipv6: reassembly: use seperate reassembly queues for conntrack and local delivery sky2: leave PCI config space writeable sky2: print Optima chip name x25: Update maintainer. ipvs: fix synchronization on connection close netfilter: xtables: document minimal required version drivers/net/bonding/: : use pr_fmt can: CAN_MCP251X should depend on HAS_DMA drivers/net/usb: Correct code taking the size of a pointer drivers/net/cpmac.c: Correct code taking the size of a pointer drivers/net/sfc: Correct code taking the size of a pointer ...
2009-12-16HWPOISON: Add Andi Kleen as hwpoison maintainer to MAINTAINERSAndi Kleen
2009-12-15MAINTAINERS: Update file patterns for WOLFSON MICROELECTRONICS PMIC DRIVERSJoe Perches
One of the includes pointed to a non-existent directory Add Documentation/hwmon/wm83?? Add sound/soc/codecs/wm(8350|8400).h files Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15MAINTAINERS: remove file pattern from KERNEL VIRTUAL MACHINE (KVM) FOR AMD-VJoe Perches
Commit 6c8166a77c98f473eb91e96a61c3cf78ac617278 ("KVM: SVM: Fold kvm_svm.h info svm.c") folded this file away. Signed-off-by: Joe Perches <joe@perches.com> Cc: Avi Kivity <avi@redhat.com> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15MAINTAINERS: rename PALM TREO section and file patternsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Tomas Cech <sleep_walker@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15MAINTAINERS: mark cifs mailing list as "moderated for non-subscribers"KOSAKI Motohiro
If non-subscribers post bug report to CIFS mailing list, they will get following messages. Your mail to 'linux-cifs-client' with the subject [PATCH x/x] cifs: xxxxxxxxxxxxx Is being held until the list moderator can review it for approval. The reason it is being held: Post by non-member to a members-only list Either the message will get posted to the list, or you will receive notification of the moderator's decision. If you would like to cancel this posting, please visit the following URL: members-only list should be written as so in MAINTAINERS file. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steve French <sfrench@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15MAINTAINERS: new kbuild maintainerMichal Marek
Sam was fine with handing over kbuild maintainership to me. The git trees are already in linux-next, a merge request will follow shortly. Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14x25: Update maintainer.Arnd Bergmann
On Monday 14 December 2009, andrew hendry wrote: > Thanks, I didn't know X.25 was actively maintained. I get bounces. > Is the the maintainers out of date? From looking at the posts on the x.25 mailing list and the changes that went into the kernel during the last three years in that area, I think it is safe to say that you are now the maintainer ;-). The last mail on this topic from Henner Eisen was around 2001. > AX.25 NETWORK LAYER > M: Ralf Baechle <ralf@linux-mips.org> > > X.25 NETWORK LAYER > M: Henner Eisen <eis@baty.hanse.de> How about this change? Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-14Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (23 commits) spi: fix probe/remove section markings Add OMAP spi100k driver spi-imx: don't access struct device directly but use dev_get_platdata spi-imx: Add mx25 support spi-imx: use positive logic to distinguish cpu variants spi-imx: correct check for platform_get_irq failing ARM: NUC900: Add spi driver support for nuc900 spi: SuperH MSIOF SPI Master driver V2 spi: fix spidev compilation failure when VERBOSE is defined spi/au1550_spi: fix setupxfer not to override cfg with zeros spi/mpc8xxx: don't use __exit_p to wrap plat_mpc8xxx_spi_remove spi/i.MX: fix broken error handling for gpio_request spi/i.mx: drain MXC SPI transfer buffer when probing device MAINTAINERS: add SPI co-maintainer. spi/xilinx_spi: fix incorrect casting spi/mpc52xx-spi: minor cleanups xilinx_spi: add a platform driver using the xilinx_spi common module. xilinx_spi: add support for the DS570 IP. xilinx_spi: Switch to iomem functions and support little endian. xilinx_spi: Split into of driver and generic part. ...
2009-12-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (151 commits) powerpc: Fix usage of 64-bit instruction in 32-bit altivec code MAINTAINERS: Add PowerPC patterns powerpc/pseries: Track previous CPPR values to correctly EOI interrupts powerpc/pseries: Correct pseries/dlpar.c build break without CONFIG_SMP powerpc: Make "intspec" pointers in irq_host->xlate() const powerpc/8xx: DTLB Miss cleanup powerpc/8xx: Remove DIRTY pte handling in DTLB Error. powerpc/8xx: Start using dcbX instructions in various copy routines powerpc/8xx: Restore _PAGE_WRITETHRU powerpc/8xx: Add missing Guarded setting in DTLB Error. powerpc/8xx: Fixup DAR from buggy dcbX instructions. powerpc/8xx: Tag DAR with 0x00f0 to catch buggy instructions. powerpc/8xx: Update TLB asm so it behaves as linux mm expects. powerpc/8xx: Invalidate non present TLBs powerpc/pseries: Serialize cpu hotplug operations during deactivate Vs deallocate pseries/pseries: Add code to online/offline CPUs of a DLPAR node powerpc: stop_this_cpu: remove the cpu from the online map. powerpc/pseries: Add kernel based CPU DLPAR handling sysfs/cpu: Add probe/release files powerpc/pseries: Kernel DLPAR Infrastructure ...
2009-12-12unifdef: update to upstream revision 1.190Tony Finch
Fix handling of input files (e.g. with no newline at EOF) that could make unifdef get into an unexpected state and call abort(). The new -B option compresses blank lines around a deleted section so that blank lines around "paragraphs" of code don't get doubled. The evaluator can now handle macros with arguments, and unbracketed arguments to the "defined" operator. Add myself to MAINTAINERS for unifdef. Signed-off-by: Tony Finch <dot@dotat.at> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (75 commits) net: Handle NETREG_UNINITIALIZED devices correctly can: add the driver for Analog Devices Blackfin on-chip CAN controllers xfrm: Fix truncation length of authentication algorithms installed via PF_KEY net: use compat helper functions in compat_sys_recvmmsg net: fix compat_sys_recvmmsg parameter type cxgb3: Fixing EEH handlers cnic: Zero out status block and Event Queue indices. cnic: Send delete command when shutting down iSCSI ring. net: smc91x: Fix up type mismatch in smc_drv_resume(). smc91x: fix unused flags warnings on UP systems MAINTAINERS: Transfering maintainership of cdc-ether net: Add missing TST_CFG_WRITE bits around sky2_pci_write net: Fix Yukon-2 Optima TCP offload setup net: niu uses crc32, so select CRC32 wireless: update old static regulatory domain rules mac80211: Revert 'Use correct sign for mesh active path refresh' mac80211: Fixed bug in mesh portal paths net/mac80211: Correct size given to memset b43: Remove reset after fatal DMA error rtl8187: add radio led and fix warnings on suspend ...
2009-12-11Merge branch 'for-linus' of git://codeaurora.org/quic/kernel/dwalker/linux-msmLinus Torvalds
* 'for-linus' of git://codeaurora.org/quic/kernel/dwalker/linux-msm: HTC Dream: mmc compilation fixes video: Allow selecting MSM framebuffer in Kconfig Add arm msm maintainer entry msm: Add memory map for HTC Dream msm: add minimal board file for HTC Dream device msm: make debugging UART (for DEBUG_LL) configurable
2009-12-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: include/net/tcp.h
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (122 commits) USB: mos7840: add device IDs for B&B electronics devices USB: ftdi_sio: add USB device ID's for B&B Electronics line USB: musb: musb_host: fix sparse warning USB: musb: musb_gadget: fix sparse warning USB: musb: omap2430: fix sparse warning USB: core: message: fix sparse warning USB: core: hub: fix sparse warning USB: core: fix sparse warning for static function USB: Added USB_ETH_RNDIS to use instead of CONFIG_USB_ETH_RNDIS USB: Check bandwidth when switching alt settings. USB: Refactor code to find alternate interface settings. USB: xhci: Fix command completion after a drop endpoint. USB: xhci: Make reverting an alt setting "unfailable". USB: usbtmc: Use usb_clear_halt() instead of custom code. USB: xhci: Add correct email and files to MAINTAINERS entry. USB: ehci-omap.c: introduce missing kfree USB: xhci-mem.c: introduce missing kfree USB: add remove_id sysfs attr for usb drivers USB: g_multi kconfig: fix depends and help text USB: option: add pid for ZTE ...
2009-12-11MAINTAINERS: Transfering maintainership of cdc-etherOliver Neukum
Oliver Neukum takes over from Greg KH Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <greg@kroah.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11USB: xhci: Add correct email and files to MAINTAINERS entry.Sarah Sharp
Add the xHCI driver files to its MAINTAINERS entry so that I'm Cc'd on cleanup patches. Update the email address to one I actually use for sending patches and responding to Linux mailing list emails. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-10Merge branch 'for-linus' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: MAINTAINERS: Add OMAP2/3 DSS and OMAPFB maintainer OMAP: SDP: Enable DSS2 for OMAP3 SDP board OMAP: DSS2: Taal DSI command mode panel driver OMAP: DSS2: Add generic and Sharp panel drivers OMAP: DSS2: omapfb driver OMAP: DSS2: DSI driver OMAP: DSS2: SDI driver OMAP: DSS2: RFBI driver OMAP: DSS2: Video encoder driver OMAP: DSS2: DPI driver OMAP: DSS2: DISPC OMAP: DSS2: Add more core files OMAP: DSS2: Display Subsystem Driver core OMAP: DSS2: Documentation for DSS2 OMAP: Add support for VRFB rotation engine OMAP: Add VRAM manager OMAP: OMAPFB: add omapdss device OMAP: OMAPFB: split omapfb.h OMAP2: Add funcs for writing SMS_ROT_* registers
2009-12-10Add arm msm maintainer entryDaniel Walker
This adds a maintainer entry for the arch/arm/mach-msm sub-architecture and all it's components in various locations. Signed-off-by: David Brown <davidb@codeaurora.org> Signed-off-by: Bryan Huntsman <bryanh@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2009-12-10Merge git://git.infradead.org/ubifs-2.6Linus Torvalds
* git://git.infradead.org/ubifs-2.6: UBIFS: fix return code in check_leaf UBI: flush wl before clearing update marker MAINTAINERS: change e-mail of Artem Bityutskiy UBIFS: remove manual O_SYNC handling UBIFS: support mounting of UBI volume character devices UBI: Add ubi_open_volume_path
2009-12-09Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (41 commits) hwmon: (adt7475) Add VID support for the ADT7476 hwmon: (adt7475) Add an entry in MAINTAINERS hwmon: (adt7475) Add support for the ADT7476 hwmon: (adt7475) Voltage attenuators can be bypassed hwmon: (adt7475) Print device information on probe hwmon: (adt7475) Handle alternative pin functions hwmon: (adt7475) Move sysfs files removal to a separate function hwmon: (adt7475) Add support for the ADT7490 hwmon: (adt7475) Improve device detection hwmon: (adt7475) Add missing static marker hwmon: (adt7475) Rework voltage inputs handling hwmon: (adt7475) Implement pwm_use_point2_pwm_at_crit hwmon: (adt7475) New documentation hwmon: (adt7475) Add support for the ADT7473 hwmon: (f71882fg) Add support for the f71889fg (version 2) hwmon: (f71882fg) Fix sysfs file removal hwmon: (f71882fg) Cleanup sysfs attr creation 2/2 hwmon: (f71882fg) Cleanup sysfs attr creation 1/2 hwmon: (thmc50) Stop using I2C_CLIENT_MODULE_PARM hwmon: Add Freescale MC13783 ADC driver ...
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (51 commits) Input: appletouch - give up maintainership Input: dm355evm_kbd - switch to using sparse keymap library Input: wistron_btns - switch to using sparse keymap library Input: add generic support for sparse keymaps Input: fix memory leak in force feedback core Input: wistron - remove identification strings from DMI table Input: psmouse - remove identification strings from DMI tables Input: atkbd - remove identification strings from DMI table Input: i8042 - remove identification strings from DMI tables DMI: allow omitting ident strings in DMI tables Input: psmouse - do not carry DMI data around Input: matrix-keypad - switch to using dev_pm_ops Input: keyboard - fix lack of locking when traversing handler->h_list Input: gpio_keys - scan gpio state at probe and resume time Input: keyboard - add locking around event handling Input: usbtouchscreen - add support for ET&T TC5UH touchscreen controller Input: xpad - add two new Xbox 360 devices Input: polled device - do not start polling if interval is zero Input: polled device - schedule first poll immediately Input: add S3C24XX touchscreen driver ...
