path: root/MAINTAINERS
2008-05-07[MAINTAINERS] New maintainer for Intel ethernet adaptersAuke Kok
I'm handing over maintainership to Jeff Kirsher and moving on to other Linux/Open Source work within Intel. Good luck to Jeff ;) Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-03[MAINTAINERS] PCI list movedJesse Barnes
Many thanks to Martin for his years of hosting. The pci list has moved to vger, along with what seems like the rest of the major Linux mailing lists. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02USB: add Cypress c67x00 OTG controller core driverPeter Korsgaard
This patch add the core driver for the c67x00 USB OTG controller. The core driver is responsible for the platform bus binding and creating either USB HCD or USB Gadget instances for each of the serial interface engines on the chip. This driver does not directly implement the HCD or gadget behaviours; it just controls access to the chip. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-01Embedded Maintainer(s), linux-embedded@vger listDavid Woodhouse
Add Paul and myself, and the linux-embedded list, to MAINTAINERS. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01cpusets: update maintainersPaul Jackson
Update CPUSETS MAINTAINERS to reflect the more active role of Paul Menage (secondary to his work on cgroups) and the retirement of the original author of cpusets, Simon Derr. Thanks, Simon! Best of luck to you. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Simon Derr <simon.derr@bull.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) tcp: Overflow bug in Vegas [IPv4] UFO: prevent generation of chained skb destined to UFO device iwlwifi: move the selects to the tristate drivers ipv4: annotate a few functions __init in ipconfig.c atm: ambassador: vcc_sf semaphore to mutex MAINTAINERS: The socketcan-core list is subscribers-only. netfilter: nf_conntrack: padding breaks conntrack hash on ARM ipv4: Update MTU to all related cache entries in ip_rt_frag_needed() sch_sfq: use del_timer_sync() in sfq_destroy() net: Add compat support for getsockopt (MCAST_MSFILTER) net: Several cleanups for the setsockopt compat support. ipvs: fix oops in backup for fwmark conn templates bridge: kernel panic when unloading bridge module bridge: fix error handling in br_add_if() netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval tcp: Limit cwnd growth when deferring for GSO tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled [netdrvr] gianfar: Determine TBIPA value dynamically ...
2008-04-30Char: moxa, update creditsJiri Slaby
- update version - update maintainers - copyright the stuff Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30MAINTAINERS: sort orderingAlan Cox
Seems we have various confused entries around S and T. Sort them all out and also add myself as tty maintainer (which is how I noticed it). Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Merge branch 'audit.b50' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b50' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] new predicate - AUDIT_FILETYPE [patch 2/2] Use find_task_by_vpid in audit code [patch 1/2] audit: let userspace fully control TTY input auditing [PATCH 2/2] audit: fix sparse shadowed variable warnings [PATCH 1/2] audit: move extern declarations to audit.h Audit: MAINTAINERS update Audit: increase the maximum length of the key field Audit: standardize string audit interfaces Audit: stop deadlock from signals under load Audit: save audit_backlog_limit audit messages in case auditd comes back Audit: collect sessionid in netlink messages Audit: end printk with newline
2008-04-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) pciehp: fix error message about getting hotplug control pci/irq: let pci_device_shutdown to call pci_msi_shutdown v2 pci/irq: restore mask_bits in msi shutdown -v3 doc: replace yet another dev with pdev for consistency in DMA-mapping.txt PCI: don't expose struct pci_vpd to userspace doc: fix an incorrect suggestion to pass NULL for PCI like buses Consistently use pdev as the variable of type struct pci_dev *. pciehp: Fix command write shpchp: fix slot name make pciehp_acpi_get_hp_hw_control_from_firmware() pciehp: Clean up pcie_init() pciehp: Mask hotplug interrupt at controller release pciehp: Remove useless hotplug interrupt enabling pciehp: Fix wrong slot capability check pciehp: Fix wrong slot control register access pciehp: Add missing memory barrier pciehp: Fix interrupt event handlig pciehp: fix slot name Update MAINTAINERS with location of PCI tree PCI: Add Intel SCH PCI IDs ...
2008-04-29MAINTAINERS: clarify status of MN10300 mailing list as moderatedRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29eeepc-laptop: add base driverEric Cooper
This patch is based on Eric Cooper's work to clean the original asus_acpi given by Asus. It's a platform driver (/sys/devices/platform/eeepc/) wich support: - hotkeys - wlan on/off - camera on/off - cardr on/off Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29MAINTAINERS: The socketcan-core list is subscribers-only.Pavel Emelyanov
When I posted a copy_to_user fixes, the list daemon refused to accept the Cc: <this-list>, because I was not a subscriber. I found, that other lists with such a feature are marked respectively in the MAINTAINERS file. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-28Audit: MAINTAINERS updateEric Paris
Change maintainers to include me and al viro Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-27KVM: Add MAINTAINERS entry for PowerPC KVMHollis Blanchard
Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: update maintainersChristian Borntraeger
This patch adds an entry for kvm on s390 to the MAINTAINERS file :-). We intend to push all patches regarding this via Avi's kvm.git. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-25Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (49 commits) [POWERPC] Add zImage.iseries to arch/powerpc/boot/.gitignore [POWERPC] bootwrapper: fix build error on virtex405-head.S [POWERPC] 4xx: Fix 460GT support to not enable FPU [POWERPC] 4xx: Add NOR FLASH entries to Canyonlands and Glacier dts [POWERPC] Xilinx: of_serial support for Xilinx uart 16550. [POWERPC] Xilinx: boot support for Xilinx uart 16550. [POWERPC] celleb: Add support for PCI Express [POWERPC] celleb: Move miscellaneous files for Beat [POWERPC] celleb: Move a file for SPU on Beat [POWERPC] celleb: Move files for Beat mmu and iommu [POWERPC] celleb: Move files for Beat hvcall interfaces [POWERPC] celleb: Move the SCC related code for celleb [POWERPC] celleb: Move the files for celleb base support [POWERPC] celleb: Consolidate io-workarounds code [POWERPC] cell: Generalize io-workarounds code [POWERPC] Add CONFIG_PPC_PSERIES_DEBUG to enable debugging for platforms/pseries [POWERPC] Convert from DBG() to pr_debug() in platforms/pseries/ [POWERPC] Register udbg console early on pseries LPAR [POWERPC] Mark udbg console as CON_ANYTIME, ie. callable early in boot [POWERPC] Set udbg_console index to 0 ...
2008-04-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: wacom - add support for Cintiq 20WSX Input: ucb1400_ts - IRQ probe fix Input: at32psif - update MODULE_AUTHOR with new email Input: mac_hid - add lockdep annotation to emumousebtn Input: i8042 - fix incorrect usage of strncpy and strncat Input: bf54x-keys - add infrastructure for keypad wakeups Input: add MODULE_ALIAS() to hotpluggable platform modules Input: drivers/char/keyboard.c - use time_after Input: fix ordering in joystick Makefile Input: wm97xx-core - support use as a wakeup source Input: wm97xx-core - use IRQF_SAMPLE_RANDOM Input: wm97xx-core - only schedule interrupt handler if not already scheduled Input: add Zhen Hua driver Input: aiptek - add support for Genius G-PEN 560 tablet Input: wacom - implement suspend and autosuspend Input: xpad - set proper buffer length for outgoing requests Input: omap-keypad - fix build warning Input: gpio_keys - irq handling cleanup Input: add PS/2 serio driver for AVR32 devices Input: put ledstate in the keyboard notifier ...
2008-04-25Update MAINTAINERS with location of PCI treeJesse Barnes
The PCI tree is now in git at kernel.org:/pub/scm/linux/kernel/git/jbarnes/pci-2.6.git; add that info to MAINTAINERS.
2008-04-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (22 commits) tun: Multicast handling in tun_chr_ioctl() needs proper locking. [NET]: Fix heavy stack usage in seq_file output routines. [AF_UNIX] Initialise UNIX sockets before general device initcalls [RTNETLINK]: Fix bogus ASSERT_RTNL warning iwlwifi: Fix built-in compilation of iwlcore (part 2) tun: Fix minor race in TUNSETLINK ioctl handling. ppp_generic: use stats from net_device structure iwlwifi: Don't unlock priv->mutex if it isn't locked wireless: rndis_wlan: modparam_workaround_interval is never below 0. prism54: prism54_get_encode() test below 0 on unsigned index mac80211: update mesh EID values b43: Workaround DMA quirks mac80211: fix use before check of Qdisc length net/mac80211/rx.c: fix off-by-one mac80211: Fix race between ieee80211_rx_bss_put and lookup routines. ath5k: Fix radio identification on AR5424/2424 ssb: Fix all-ones boardflags b43: Add more btcoexist workarounds b43: Fix HostFlags data types b43: Workaround invalid bluetooth settings ...
2008-04-24[POWERPC] Add Timur Tabi to the MAINTAINERS fileTimur Tabi
Add Timur Tabi as the maintainer for the Freescale QE library, the Freescale QE UART device driver, the Freescale SOC sound drivers, and the Crystal Semiconductor CS4270 device driver. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-23mac80211: MAINTAINERS updateJohannes Berg
This updates the mac80211 maintainers entry to  1) remove Jiri 2) put me first Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Michael Wu <flamingice@sourmilk.net> Cc: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: (42 commits) PCI: Change PCI subsystem MAINTAINER PCI: pci-iommu-iotlb-flushing-speedup PCI: pci_setup_bridge() mustn't be __devinit PCI: pci_bus_size_cardbus() mustn't be __devinit PCI: pci_scan_device() mustn't be __devinit PCI: pci_alloc_child_bus() mustn't be __devinit PCI: replace remaining __FUNCTION__ occurrences PCI: Hotplug: fakephp: Return success, not ENODEV, when bus rescan is triggered PCI: Hotplug: Fix leaks in IBM Hot Plug Controller Driver - ibmphp_init_devno() PCI: clean up resource alignment management PCI: aerdrv_acpi.c: remove unneeded NULL check PCI: Update VIA CX700 quirk PCI: Expose PCI VPD through sysfs PCI: iommu: iotlb flushing PCI: simplify quirk debug output PCI: iova RB tree setup tweak PCI: parisc: use generic pci_enable_resources() PCI: ppc: use generic pci_enable_resources() PCI: powerpc: use generic pci_enable_resources() PCI: ia64: use generic pci_enable_resources() ...
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) SCSI: convert struct class_device to struct device DRM: remove unused dev_class IB: rename "dev" to "srp_dev" in srp_host structure IB: convert struct class_device to struct device memstick: convert struct class_device to struct device driver core: replace remaining __FUNCTION__ occurrences sysfs: refill attribute buffer when reading from offset 0 PM: Remove destroy_suspended_device() Firmware: add iSCSI iBFT Support PM: Remove legacy PM (fix) Kobject: Replace list_for_each() with list_for_each_entry(). SYSFS: Explicitly include required header file slab.h. Driver core: make device_is_registered() work for class devices PM: Convert wakeup flag accessors to inline functions PM: Make wakeup flags available whenever CONFIG_PM is set PM: Fix misuse of wakeup flag accessors in serial core Driver core: Call device_pm_add() after bus_add_device() in device_add() PM: Handle device registrations during suspend/resume block: send disk "change" event for rescan_partitions() sysdev: detect multiple driver registrations ... Fixed trivial conflict in include/linux/memory.h due to semaphore header file change (made irrelevant by the change to mutex).
2008-04-21MAINTAINERS: Clarify access to OCFS2 development mailing list.Robert P. J. Day
The list is moderated for non-subscribers Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-21MAINTAINERS: Add ati_remote2 driverVille Syrjala
Add myself as the ati_remote2 driver maintainer. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-20PCI: Change PCI subsystem MAINTAINERGreg Kroah-Hartman
Jesse foolishly volunteered to handle PCI patches. Update MAINTAINERS to reflect this. Woho! Time to kick back and relax... Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19UIO: Implement a UIO interface for the SMX CryptengineBen Nizette
This patch implements a UIO interface for the SMX Cryptengine. The Cryptengine found on the Nias Digital SMX board is best suited for a UIO interface. It is not wired in to the cryptographic API as the engine handles it's own keys, algorithms, everything. All that we know about is that if there's room in the buffer, you can write data to it and when there's data ready, you read it out again. There isn't necessarily even any direct correlation between data going in and data coming out again, the engine may consume or generate data all on its own. This driver is for proprietary hardware but we're always told to submit the drivers anyway; here you are. :-) This is version 4 of this patch and addresses all issues raised by Hans-Jürgen Koch and Paul Mundt in their reviews. Slightly altered is Paul's suggestion to use DRV_NAME and DRV_VERSION as the UIO version and name. While at the moment they are the same, there is no reason for them to stay that way. Nevertheless we now at least provide a MODULE_VERSION macro to keep modinfo happy. Signed-off-by: Ben Nizette <bn@niasdigital.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Hans J Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19Merge branch 'merge-fixes' into develRussell King
2008-04-19Merge branch 'omap2-upstream' into develRussell King
2008-04-19[ARM] 4867/1: Adds flash, udc, mci support for gumstix F boardsJaya Kumar
This patch implements support for Gumstix-F flash, udc and mci. Fixes since the last time are: - Steve Sakoman as maintainer - cleanup for udc and mci setup Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-18Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: (64 commits) ocfs2/net: Add debug interface to o2net ocfs2: Only build ocfs2/dlm with the o2cb stack module ocfs2/cluster: Get rid of arguments to the timeout routines ocfs2: Put tree in MAINTAINERS ocfs2: Use BUG_ON ocfs2: Convert ocfs2 over to unlocked_ioctl ocfs2: Improve rename locking fs/ocfs2/aops.c: test for IS_ERR rather than 0 ocfs2: Add inode stealing for ocfs2_reserve_new_inode ocfs2: Add ac_alloc_slot in ocfs2_alloc_context ocfs2: Add a new parameter for ocfs2_reserve_suballoc_bits ocfs2: Enable cross extent block merge. ocfs2: Add support for cross extent block ocfs2: Move /sys/o2cb to /sys/fs/o2cb sysfs: Allow removal of symlinks in the sysfs root ocfs2: Reconnect after idle time out. ocfs2/dlm: Cleanup lockres print ocfs2/dlm: Fix lockname in lockres print function ocfs2/dlm: Move dlm_print_one_mle() from dlmmaster.c to dlmdebug.c ocfs2/dlm: Dumps the purgelist into a debugfs file ...
2008-04-18ocfs2: Put tree in MAINTAINERSJoel Becker
The ocfs2 MAINTAINERS entry should have the git tree URL. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-17kgdb: add documentationJason Wessel
Add in the kgdb documentation for kgdb. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-15Update rt2x00 MAINTAINERS entryIvo van Doorn
Add the tree entry for rt2x00 to inform people about the rt2x00.git tree. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15Add rfkill to MAINTAINERS fileIvo van Doorn
I have been acting as the maintainer since the rfkill introduction, so lets make it official by adding a rfkill entry in the MAINTAINERS file. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15MAINTAINERS: move to generic repository for iwlwifiReinette Chatre
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15MAINTAINERS: isdn4linux@listserv.isdn4linux.de is subscribers-onlyPaul Bolle
https://www.isdn4linux.de/mailman/listinfo/isdn4linux: "To prevent spamming, you have to subscribe first. Mails from non-members are silently ignored!" Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12MAINTAINERS: New sctp mailing listVlad Yasevich
Add a new sctp mailing list linux-sctp@vger.kernel.org. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03Merge branch 'master' of ↵David S. Miller
2008-04-02Input: add support for WM97xx familty touchscreensMark Brown
Add support for the touchscreen controllers provided by Wolfson Microelectronics WM97xx series chips in both polled and streaming modes. These drivers have been maintained out of tree since 2003. During that time the driver the primary maintainer was Liam Girdwood and a number of people have made contributions including Dmitry Baryshkov, Stanley Cai, Rodolfo Giometti, Russell King, Marc Kleine-Budde, Ian Molton, Vincent Sanders, Andrew Zabolotny, Graeme Gregory, Mike Arthur and myself. Apologies to anyone I have omitted. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Mike Arthur <mike.arthur@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-28kprobes: another MAINTAINERS updateAnanth N Mavinakayanahalli
Prasanna has taken a new job. Update the MAINTAINERS file Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-28afs: add a MAINTAINERS record for AFSDavid Howells
Add a MAINTAINERS record for AFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
2008-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits) [IPSEC]: Fix BEET output [ICMP]: Dst entry leak in icmp_send host re-lookup code (v2). [AX25]: Remove obsolete references to BKL from TODO file. [NET]: Fix multicast device ioctl checks [IRDA]: Store irnet_socket termios properly. [UML]: uml-net: don't set IFF_ALLMULTI in set_multicast_list [VLAN]: Don't copy ALLMULTI/PROMISC flags from underlying device netxen, phy/marvell, skge: minor checkpatch fixes S2io: Handle TX completions on the same CPU as the sender for MIS-X interrupts b44: Truncate PHY address skge napi->poll() locking bug rndis_host: fix oops when query for OID_GEN_PHYSICAL_MEDIUM fails cxgb3: Fix lockdep problems with sge.reg_lock ehea: Fix IPv6 support dm9000: Support promisc and all-multi modes dm9601: configure MAC to drop invalid (crc/length) packets dm9601: add Hirose USB-100 device ID Marvell PHY m88e1111 driver fix netxen: fix rx dropped stats netxen: remove low level tx lock ...
