path: root/Makefile
2013-06-29Linux 3.2.48v3.2.48Ben Hutchings
2013-06-19Linux 3.2.47v3.2.47Ben Hutchings
2013-05-30Linux 3.2.46v3.2.46Ben Hutchings
2013-05-13Linux 3.2.45v3.2.45Ben Hutchings
2013-04-25Linux 3.2.44v3.2.44Ben Hutchings
2013-04-10Linux 3.2.43v3.2.43Ben Hutchings
2013-03-27Linux 3.2.42v3.2.42Ben Hutchings
2013-03-20Linux 3.2.41v3.2.41Ben Hutchings
2013-03-06Linux 3.2.40v3.2.40Ben Hutchings
2013-02-20Linux 3.2.39v3.2.39Ben Hutchings
2013-02-06Linux 3.2.38v3.2.38Ben Hutchings
2013-01-16Linux 3.2.37v3.2.37Ben Hutchings
2013-01-03Linux 3.2.36v3.2.36Ben Hutchings
2012-12-06Linux 3.2.35v3.2.35Ben Hutchings
2012-11-16Linux 3.2.34v3.2.34Ben Hutchings
2012-10-30Linux 3.2.33v3.2.33Ben Hutchings
2012-10-17Linux 3.2.32v3.2.32Ben Hutchings
2012-10-10Linux 3.2.31v3.2.31Ben Hutchings
2012-09-19Linux 3.2.30v3.2.30Ben Hutchings
2012-09-12Linux 3.2.29v3.2.29Ben Hutchings
2012-08-19Linux 3.2.28v3.2.28Ben Hutchings
2012-08-10Linux 3.2.27v3.2.27Ben Hutchings
2012-08-04Linux 3.2.26v3.2.26Ben Hutchings
2012-08-02Linux 3.2.25v3.2.25Ben Hutchings
2012-07-25Linux 3.2.24v3.2.24Ben Hutchings
2012-07-12Linux 3.2.23v3.2.23Ben Hutchings
2012-07-04Linux 3.2.22v3.2.22Ben Hutchings
2012-06-19Linux 3.2.21v3.2.21Ben Hutchings
2012-06-10Linux 3.2.20v3.2.20Ben Hutchings
2012-05-31Linux 3.2.19v3.2.19Ben Hutchings
2012-05-31x86, realmode: 16-bit real-mode code support for relocs toolH. Peter Anvin
commit 6520fe5564acf07ade7b18a1272db1184835c487 upstream. A new option is added to the relocs tool called '--realmode'. This option causes the generation of 16-bit segment relocations and 32-bit linear relocations for the real-mode code. When the real-mode code is moved to the low-memory during kernel initialization, these relocation entries can be used to relocate the code properly. In the assembly code 16-bit segment relocations must be relative to the 'real_mode_seg' absolute symbol. Linear relocations must be relative to a symbol prefixed with 'pa_'. 16-bit segment relocation is used to load cs:ip in 16-bit code. Linear relocations are used in the 32-bit code for relocatable data references. They are declared in the linker script of the real-mode code. The relocs tool is moved to arch/x86/tools/relocs.c, and added new target archscripts that can be used to build scripts needed building an architecture. be compiled before building the arch/x86 tree. [ hpa: accelerating this because it detects invalid absolute relocations, a serious bug in binutils 2.22.52.0.x which currently produces bad kernels. ] Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org> [bwh: Backported to 3.2: - Adjust context (no archheaders; no insn_sanity) - Expand put_unaligned_le32()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-20Linux 3.2.18v3.2.18Ben Hutchings
2012-05-11Linux 3.2.17v3.2.17Ben Hutchings
2012-04-22Linux 3.2.16v3.2.16Greg Kroah-Hartman
2012-04-13Linux 3.2.15v3.2.15Greg Kroah-Hartman
2012-04-02Linux 3.2.14v3.2.14Greg Kroah-Hartman
2012-03-23Linux 3.2.13v3.2.13Greg Kroah-Hartman
2012-03-19Linux 3.2.12v3.2.12Greg Kroah-Hartman
2012-03-13Linux 3.2.11v3.2.11Greg Kroah-Hartman
2012-03-12Linux 3.2.10v3.2.10Greg Kroah-Hartman
2012-02-29Linux 3.2.9v3.2.9Greg Kroah-Hartman
2012-02-27Linux 3.2.8v3.2.8Greg Kroah-Hartman
2012-02-20Linux 3.2.7v3.2.7Greg Kroah-Hartman
2012-02-13Linux 3.2.6v3.2.6Greg Kroah-Hartman
2012-02-06Linux 3.2.5v3.2.5Greg Kroah-Hartman
2012-02-03Linux 3.2.4v3.2.4Greg Kroah-Hartman
2012-02-03Linux 3.2.3v3.2.3Greg Kroah-Hartman
2012-01-25Linux 3.2.2v3.2.2Greg Kroah-Hartman
2012-01-12Linux 3.2.1v3.2.1Greg Kroah-Hartman
2012-01-04Linux 3.2v3.2Linus Torvalds
