path: root/Makefile
2008-12-05Linux 2.6.27.8v2.6.27.8Greg Kroah-Hartman
2008-11-20Linux 2.6.27.7v2.6.27.7Greg Kroah-Hartman
2008-11-13Linux 2.6.27.6v2.6.27.6Greg Kroah-Hartman
2008-11-07Linux 2.6.27.5v2.6.27.5Greg Kroah-Hartman
2008-10-25Linux 2.6.27.4v2.6.27.4Greg Kroah-Hartman
2008-10-22Linux 2.6.27.3v2.6.27.3Greg Kroah-Hartman
2008-10-18Linux 2.6.27.2v2.6.27.2Greg Kroah-Hartman
2008-10-15Linux 2.6.27.1v2.6.27.1Greg Kroah-Hartman
2008-10-09Linux 2.6.27v2.6.27Linus Torvalds
2008-10-06Linux 2.6.27-rc9v2.6.27-rc9Linus Torvalds
2008-09-29Linux 2.6.27-rc8v2.6.27-rc8Linus Torvalds
2008-09-21Linux 2.6.27-rc7v2.6.27-rc7Linus Torvalds
2008-09-09Linux 2.6.27-rc6v2.6.27-rc6Linus Torvalds
2008-08-28Linux 2.6.27-rc5v2.6.27-rc5Linus Torvalds
2008-08-20Linux v2.6.27-rc4v2.6.27-rc4Linus Torvalds
2008-08-12Linux 2.6.27-rc3v2.6.27-rc3Linus Torvalds
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-06kbuild: a better way to generate cscope database changeDenis ChengRq
It's a problem about cscope target of kernel Makefile, and the cscope plugin of emacs: 1. `make cscope` will generate cscope.files cscope.{in,po,}.out; 2. the cscope plugin expect a cscope.out.{in,po,}; 3. the default `cscope -b` would generate cscope.{in,po,}.out; There are three approach to solve it: 1. modify the cscope C code; 2. modify the cscope emacs plugin lisp code; 3. modify the Makefile; I have tried to communicate with the cscope upstream, but later I realize the third approach is most meaningful. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-08-06kbuild: fix O=.. build with armSam Ravnborg
With a make O=... build kbuild would only create the include2/asm symlink for archs that not yet had moved headers to include/$ARCH/include There is no longer any reason to avoid the symlink for archs that has moved their headers so create it unconditionally. This fixes arm because kbuild checked for include/asm-$ARCH/errno.h and that file was not present for arm but the platform files are not yet moved. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Russell King <rmk@arm.linux.org.uk>
2008-08-05Linux 2.6.27-rc2v2.6.27-rc2Linus Torvalds
2008-07-30kbuild: fix O=... build of umSam Ravnborg
We used include/asm-$ARCH/system.h to check if we should create a symlink in include2 directory with make O=... builds. But um does not have such a file thus build filed. Let's try anohter filename: $ ls -d include/asm-* | wc -l 21 $ ls -d include/asm-*/errno.h | wc -l 21 Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com>
2008-07-28Linux 2.6.27-rc1v2.6.27-rc1Linus Torvalds
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (25 commits) setlocalversion: do not describe if there is nothing to describe kconfig: fix typos: "Suport" -> "Support" kconfig: make defconfig is no longer chatty kconfig: make oldconfig is now less chatty kconfig: speed up all*config + randconfig kconfig: set all new symbols automatically kconfig: add diffconfig utility kbuild: remove Module.markers during mrproper kbuild: sparse needs CF not CHECKFLAGS kernel-doc: handle/strip __init vmlinux.lds: move __attribute__((__cold__)) functions back into final .text section init: fix URL of "The GNU Accounting Utilities" kbuild: add arch/$ARCH/include to search path kbuild: asm symlink support for arch/$ARCH/include kbuild: support arch/$ARCH/include for tags, cscope kbuild: prepare headers_* for arch/$ARCH/include kbuild: install all headers when arch is changed kbuild: make clean removes *.o.* as well kbuild: optimize headers_* targets kbuild: only one call for include/ in make headers_* ...
2008-07-25kbuild: remove Module.markers during mrproperAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: add arch/$ARCH/include to search pathSam Ravnborg
This patch conclude the support for arch/$ARCH/include Note: The individual architectures will most likely require a few minor patches to support locating header files in arch/$ARCH/include Testing shows that it worked out-of-the-box for sparc. x86 required a few trivial changes in the arch specific Makefile and a few include paths had to be adjusted. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: asm symlink support for arch/$ARCH/includeSam Ravnborg
Adjust the asm symlink support so we do not create the symlink unless really needed. We check the precense of include/asm-$ARCH by checking for the system.h file. We may end up with a stale directory so it is not enough to check if the directory is present. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: support arch/$ARCH/include for tags, cscopeSam Ravnborg
2008-07-25kbuild: prepare headers_* for arch/$ARCH/includeSam Ravnborg
Factor out the headers_*_all support to a seperate shell script and add support for arch specific header files can be located in either arch/$ARCH/include/asm or include/asm-$ARCH/ In "make help" always display the headers_* targets. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: make clean removes *.o.* as wellAlexey Dobriyan
Those are left presumably from aborted ccache(1) compilations: arch/x86/kernel/.tmp_io_apic_64.o.T5veul arch/x86/kvm/.tmp_x86.o.SZWn69 arch/x86/mm/.tmp_pgtable.o.sL1LTf drivers/ieee1394/.tmp_ieee1394_transactions.o.bUj6o1 drivers/infiniband/hw/mlx4/.tmp_main.o.vy0ep6 BTW, with git there is nice way to check for such nuisainces: make mrproper git-ls-files -o should give empty output. More precise wildcard spec from: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Jan Engelhardt <jengelh@medozas.de>
2008-07-25kbuild: only one call for include/ in make headers_*Sam Ravnborg
Move it to the top-level file to decide if we install/check the generic headers or the arch specific headers. This revealed a long standing bug where "make headers_check_all" relied on the files in asm/ for the current architecture. So make headers_check_all is now broken by this commit. In addition: o add a simpler way to detect if an arch support exporting header files. o add 'set -e;' so we error out early if make headers_check_all fails. o add sparc64 and cris to arch we do not process in make headers_*_all because: sparc64 - use sparc to export headers cris - is know seriously broken Includes suggestions from: David Woodhouse <dwmw2@infradead.org>. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2008-07-25kbuild: error out early in make headers_installSam Ravnborg
Fix the a.out.h case by setting SRCARCH and error out early in case of an error. The a.out.h case failed with the *_all targets. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: refactor headers_* targets in MakefileSam Ravnborg
o Use lower case for local variables o Add a helper target for common targets o Use $(hdr-inst)= ... to make Make invocations simpler o Add -rR to make invocations In total this adds more lines than it removes but the benefit is better readability Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2008-07-25firmware: create firmware binaries during 'make modules'.David Woodhouse
This means that we no longer need write access to the source tree while doing 'make modules_install'. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-22markers: fix duplicate modpost entryMathieu Desnoyers
When a kernel was rebuilt, the previous Module.markers was not cleared. It caused markers with different format strings to appear as duplicates when a markers was changed. This problem is present since scripts/mod/modpost.c started to generate Module.markers, commit b2e3e658b344c6bcfb8fb694100ab2f2b5b2edb0 It therefore applies to 2.6.25, 2.6.26 and linux-next. I merely merged the patches from Roland, Wenji and Takashi here. Credits to Roland McGrath <roland@redhat.com> Wenji Huang <wenji.huang@oracle.com> and Takashi Nishiie <t-nishiie@np.css.fujitsu.com> for providing the individual fixes. - Changelog : - Integrated Takashi's Makefile modification to clear Module.markers upon make clean. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Roland McGrath <roland@redhat.com> Cc: Wenji Huang <wenji.huang@oracle.com> Cc: Takashi Nishiie <t-nishiie@np.css.fujitsu.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-17Fix collateral damage to top level MakefileGrant Likely
The patch named "powerpc/mpc5121: Add clock driver", also contained an unrelated and bogus change to the top-level makefile. This patch backs out the bad bit. SHA1 of offending patch: 137e95906e294913fab02162e8a1948ade49acb5) Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Repented-by: John Rigby <jrigby@freescale.com> [ Heh. Normally I pick these out from the diffstats, but I guess I've grown to trust the ppc tree too much ;) - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16Fix MIPS cross-compile problemRalf Baechle
Crosscompiling on a Fedora 9 machine running gcc 4.3.0 as its host compiler and gcc 3.4.6 for the mips-linux target results in the following build error: $ make malta_defconfig $ make cc1: error: unrecognized command line option "-fno-stack-protector" scripts/kconfig/conf -s arch/mips/Kconfig cc1: error: unrecognized command line option "-fno-stack-protector" The arch Makefile is included too late so the host compiler is feature tested, not the crosscompiler as intended and thus the Makefile applies adds -fno-stack-protector to crosscompiler's flags which fails for gcc 3.4.6. The bug was introduced by e06b8b98da071f7dd78fb7822991694288047df0 in 2.6.25; 35bb5b1e0e84cfa1a8906f7e6a77f391ff315791 did add more flags testing before the arch Makefile inclusion. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16Merge commit 'origin/master'Benjamin Herrenschmidt
Manual merge of: arch/powerpc/Kconfig arch/powerpc/kernel/stacktrace.c arch/powerpc/mm/slice.c arch/ppc/kernel/smp.c
2008-07-15Merge commit '85082fd7cbe3173198aac0eb5e85ab1edcc6352c' into test-buildBenjamin Herrenschmidt
Manual fixup of: arch/powerpc/Kconfig
2008-07-15Merge commit 'gcl/gcl-next'Benjamin Herrenschmidt
2008-07-14Merge branch 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6Linus Torvalds
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits) firmware: convert sb16_csp driver to use firmware loader exclusively dsp56k: use request_firmware edgeport-ti: use request_firmware() edgeport: use request_firmware() vicam: use request_firmware() dabusb: use request_firmware() cpia2: use request_firmware() ip2: use request_firmware() firmware: convert Ambassador ATM driver to request_firmware() whiteheat: use request_firmware() ti_usb_3410_5052: use request_firmware() emi62: use request_firmware() emi26: use request_firmware() keyspan_pda: use request_firmware() keyspan: use request_firmware() ttusb-budget: use request_firmware() kaweth: use request_firmware() smctr: use request_firmware() firmware: convert ymfpci driver to use firmware loader exclusively firmware: convert maestro3 driver to use firmware loader exclusively ... Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and drivers/char/ip2/ip2main.c manually.
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-14Merge branch 'auto-ftrace-next' into tracing/for-linusIngo Molnar
Conflicts: arch/x86/kernel/entry_32.S arch/x86/kernel/process_32.c arch/x86/kernel/process_64.c arch/x86/lib/Makefile include/asm-x86/irqflags.h kernel/Makefile kernel/sched.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-13Linux 2.6.26v2.6.26Linus Torvalds
2008-07-12powerpc/mpc5121: Add clock driverJohn Rigby
Plugs into the generic powerpc clock driver in arch/powerpc/kernel/clock.c The following subset of clk_interface is implemented: clk_get, clk_put: get clock via name, release clock clk_enable, clk_disable: enable or disable clock clk_get_rate: get clock rate in Hz clk_set_rate: stubbed clk_round_rate: stubbed clk_set_parent: NULL clk_get_parent: NULL Signed-off-by: John Rigby <jrigby@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-10firmware: Add firmware installation to modules_install, add firmware_installDavid Woodhouse
For 'make modules_install', install any firmware required by the modules which are being installed. Also add a 'make firmware_install' target which doesn't depend on the configuration, but installs _all_ available in-kernel-tree firmware into $(INSTALL_FW_PATH), which defaults to /lib/firmware. This is intended for distributors to make arch-independent (and config-independent) packages containing firmware. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10firmware: Add CONFIG_EXTRA_FIRMWARE optionDavid Woodhouse
This allows arbitrary firmware files to be included in the static kernel where the firmware loader can find them without requiring userspace to be alive. (Updated and CONFIG_EXTRA_FIRMWARE_DIR added with lots of help from Johannes Berg). Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2008-07-10Merge branch 'tracing/ftrace' into auto-ftrace-nextIngo Molnar
2008-07-05Linux 2.6.26-rc9v2.6.26-rc9Linus Torvalds
2008-06-25Merge branch 'linus' into tracing/ftracetip-tracing-ftrace-2008-06-25_10.27_WedIngo Molnar
