commit 6520fe5564acf07ade7b18a1272db1184835c487 upstream.
A new option is added to the relocs tool called '--realmode'.
This option causes the generation of 16-bit segment relocations
and 32-bit linear relocations for the real-mode code. When
the real-mode code is moved to the low-memory during kernel
initialization, these relocation entries can be used to
relocate the code properly.
In the assembly code 16-bit segment relocations must be relative
to the 'real_mode_seg' absolute symbol. Linear relocations must be
relative to a symbol prefixed with 'pa_'.
16-bit segment relocation is used to load cs:ip in 16-bit code.
Linear relocations are used in the 32-bit code for relocatable
data references. They are declared in the linker script of the
real-mode code.
The relocs tool is moved to arch/x86/tools/relocs.c, and added new
target archscripts that can be used to build scripts needed building
an architecture. be compiled before building the arch/x86 tree.
[ hpa: accelerating this because it detects invalid absolute
relocations, a serious bug in binutils 2.22.52.0.x which currently
produces bad kernels. ]
Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
Cc: <stable@vger.kernel.org>
[bwh: Backported to 3.2:
- Adjust context (no archheaders; no insn_sanity)
- Expand put_unaligned_le32()]
.. with new name. Because nothing says "really solid kernel release"
like naming it after an extinct animal that just happened to be in the
news lately.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: append missing-syscalls to the default target list
genksyms: Regenerate lexer and parser
genksyms: Do not expand internal types
genksyms: Minor parser cleanup
Makefile: remove a duplicated line
fixdep: fix extraneous dependencies
scripts/Makefile.build: do not reference EXTRA_CFLAGS as CFLAGS replacement
kbuild: prevent make from deleting _shipped files
kbuild: Do not delete empty files in make distclean
This avoid an extra make invocation on `prepare0'.
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
There are two duplicated lines for 'make RECORDMCOUNT_WARN=1 [targets]'
in 'make help', remove the second one.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
