path: root/Makefile
2010-08-29Linux 2.6.36-rc3v2.6.36-rc3Linus Torvalds
2010-08-23Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: setlocalversion: Ignote SCMs above the linux source tree makefile: not need to regenerate kernel.release file when make kernelrelease fixes for using make 3.82 kconfig: fix segfault when detecting recursive dependency kconfig: fix savedefconfig with choice marked optional
2010-08-22Linux 2.6.36-rc2v2.6.36-rc2Linus Torvalds
2010-08-20makefile: not need to regenerate kernel.release file when make kernelreleaseAmerigo Wang
Brice reported that 'kernelrelease' has a dependence on include/config/kernel.release, causes this file to be regenerated every time when invoke it. It doesn't have to. Reported-by: Brice Goglin <Brice.Goglin@inria.fr> Tested-by: Brice Goglin <Brice.Goglin@inria.fr> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-15Linux 2.6.36-rc1v2.6.36-rc1Linus Torvalds
2010-08-13Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: setlocalversion: fix version for untaged nontip mercurial revs Fix CONFIG_CROSS_COMPILE issue in .config
2010-08-10Fix CONFIG_CROSS_COMPILE issue in .configYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-05Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: scripts/dtc: Fix a resource leak Documentation: fix ubuntu distro name MAINTAINERS: Update kbuild git URLs Add support for the C variable in the coccicheck script Add scripts/coccinelle/deref_null.cocci Add scripts/coccinelle/err_cast.cocci Add scripts/coccinelle/resource_size.cocci Add scripts/coccinelle/alloc/kzalloc-simple.cocci Add scripts/coccinelle/alloc/drop_kmalloc_cast.cocci Add Documentation/coccinelle.txt Add a target to use the Coccinelle checker scripts: decodecode: remove bashisms Makefile: clarify a comment checkkconfigsymbols.sh: Kconfig symbols sometimes have lowercase letters scripts: add nconf into gitignore file
2010-08-04Merge commit 'v2.6.35' into kbuild/kbuildMichal Marek
Conflicts: arch/powerpc/Makefile
2010-08-03kbuild: allow assignment to {A,C}FLAGS_KERNEL on the command lineSam Ravnborg
It is now possible to assign options to AS and CC on the command line - which is only used for built-in code. {A,C}FLAGS_KERNEL was used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC without overriding the original value. Introduce a new set of variables KBUILD_{A,C}FLAGS_KERNEL that is used by arch specific files and free up {A,C}FLAGS_KERNEL so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-03kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command lineSam Ravnborg
It is now possible to assign options to AS, CC and LD on the command line - which is only used when building modules. {A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC, LD when building modules without overriding the original value. Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE that is used by arch specific files and free up {A,C,LD}FLAGS_MODULE so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Note: Previously we had a MODFLAGS variable for both AS and CC. But in favour of consistency this was dropped. So in some cases arch Makefile has one assignmnet replaced by two assignmnets. Note2: MODFLAGS was not documented and is dropped without any notice. I do not expect much/any breakage from this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-02Merge commit 'v2.6.35' into perf/coreIngo Molnar
Conflicts: tools/perf/Makefile tools/perf/util/hist.c Merge reason: Resolve the conflicts and update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-01Linux 2.6.35v2.6.35Linus Torvalds
2010-07-22Linux 2.6.35-rc6v2.6.35-rc6Linus Torvalds
2010-07-21Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: Pick up the latest perf fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-14Kbuild: Add option to set -femit-struct-debug-baseonlyAndi Kleen
Newer gcc has a -femit-struct-debug-baseonly option that dramatically reduces the size of object files with debug info. What it does is to only emit type information for structures when the structures are defined in the same file or in a header file. This means the type information for most headers are not included. This is not good when the type information is actually needed (e.g. with kgdb or systemtap) But often kernel hackers only care about line numbers and don't need all the type information anyways. In this case setting the option can be a big win: A build dir for a specific x86-64 configuration with gcc 4.5 shrunk from 2.3G to 1.2G. The compilation was also nearly a minute faster. Signed-off-by: Andi Kleen <ak@linux.intel.com> [mmarek: reformatted help text] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-07-12Linux 2.6.35-rc5v2.6.35-rc5Linus Torvalds
2010-07-06kbuild: Fix path to scripts/setlocalversionMichal Marek
Commit 0a564b2 broke LOCALVERSION for O=... builds. Ouch. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-and-tested-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Peter Anvin <hpa@zytor.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-05Merge commit 'v2.6.35-rc4' into perf/coreIngo Molnar
Merge reason: Pick up the latest perf fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-04Linux 2.6.35-rc4v2.6.35-rc4Linus Torvalds
2010-07-04Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Propagate LOCALVERSION= down to scripts/setlocalversion kbuild: Clean up and speed up the localversion logic
2010-07-02Merge branch 'setlocalversion-speedup' into kbuild/rc-fixesMichal Marek
Conflicts: Makefile
2010-06-30kbuild: Propagate LOCALVERSION= down to scripts/setlocalversionMichal Marek
Variables given on the make commandline are not exported to $(shell ...) commands, so run the setlocalversion script in the make rule directly. Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-29Makefile: "make kernelrelease" should show the correct full kernel versionAmerigo Wang
After commit 85a256d8e0116c8f5ad276730830f5d4d473344d, 'make kernelrelease' doesn't show the correct full kernel version. This patch fixes it, 'make kernelrelease' will show the same version name with the one you finally get. Cc: David Rientjes <rientjes@google.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Amerigo Wang <amwang@redhat.com> [mmarek: merged with 0915512 and added dependency on include/config/kernel.release] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-28Merge branch 'linus' into perf/coreThomas Gleixner
Reason: Further changes conflict with upstream fixes Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-27Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: fix LOCALVERSION handling to match description kbuild: Fix modpost segfault
2010-06-18kbuild: Clean up and speed up the localversion logicMichal Marek
Now that we run scripts/setlocalversion during every build, it makes sense to move all the localversion logic there. This cleans up the toplevel Makefile and also makes sure that the script is called only once in 'make prepare' (previously, it would be called every time due to a variable expansion in an ifneq statement). No user-visible change is intended, unless one runs the setlocalversion script directly. Reported-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Nico Schottelius <nico-linuxsetlocalversion@schottelius.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-18Merge commit 'v2.6.35-rc3' into perf/coreIngo Molnar
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
2010-06-15kbuild: fix LOCALVERSION handling to match descriptionAndy Whitcroft
In the commit below the version string handling was modified, adding a '+' where no other version information was supplied: commit 85a256d8e0116c8f5ad276730830f5d4d473344d Author: David Rientjes <rientjes@google.com> Date: Wed Jan 13 13:01:05 2010 -0800 From the commit the intent was as below: - when CONFIG_LOCALVERSION_AUTO is disabled, a `+' is appended if the repository has been revised beyond a tagged commit and LOCALVERSION= was not passed to "make". However if the user supplies an empty LOCALVERSION on the command line the plus suffix is still added. This form is useful in the case where the build environment knows that the version as specified is correct and complete but does not correspond to a specific tag. This patch changes the implementation to match the documentation such that specifying LOCALVERSION= on the build line is sufficient to suppress any suffix. Signed-off-by: Andy Whitcroft <apw@canonical.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-11Linux 2.6.35-rc3v2.6.35-rc3Linus Torvalds
2010-06-12Merge branch 'kbuild/coccinelle' into kbuild/miscMichal Marek
2010-06-12Add a target to use the Coccinelle checkerNicolas Palix
A 'coccicheck' target is added. It can be called with four different modes. Each one generates a different kind of output, i.e. context, patch, org, report, according to the corresponding mode to be activated. The new target calls the 'coccicheck' front-end in the 'scripts' directory with the MODE argument. Every SmPL file in the subdirectories of 'scripts/coccinelle' is then given to the front-end and applied to the entire source tree. The four modes behave as follows: 'report' generates a list in the following format: file:line:column-column: message 'patch' proposes a fix, when possible. 'context' highlights lines of interest and their context in a diff-like style. Lines of interest are indicated with '-'. 'org' generates a report in the Org mode format of Emacs. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-09kbuild: Generate modules.builtin in make modulesMichal Marek
Generating the file in make modules_install was broken as well, because it didn't work in a readonly filesystem and otherwise it generated a root-owned file which is not wanted. Reported-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-07perf tools: Allow building perf source tarballs on non-configured treeArnaldo Carvalho de Melo
So that we don't require that the kernel be configured first, and as we don't use KERNELRELEASE at all in the -src-pkg targets, we need o add a new wildcard for targets ending in src-pkg: On a make mrproper'ed kernel we get this without this patch: [linux-2.6-tip]$ LANG= make perf-tarbz2-src-pkg /bin/sh: include/config/kernel.release: No such file or directory make: *** [include/config/kernel.release] Error 1 [acme@emilia linux-2.6-tip]$ Acked-by: Michal Marek <mmarek@suse.cz> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michal Marek <mmarek@suse.cz> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20100604173552.GA875@ghostprotocols.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-05Linux 2.6.35-rc2v2.6.35-rc2Linus Torvalds
2010-06-05perf tools: Make target to generate self contained source tarballArnaldo Carvalho de Melo
Useful for when people want to try some version of the perf tools and don't wants to download the kernel tarball. Here is a session using this new target: [root@emilia linux-2.6-tip]# make help | grep -i perf perf-tar-src-pkg - Build perf-2.6.35-rc1.tar source tarball perf-targz-src-pkg - Build perf-2.6.35-rc1.tar.gz source tarball perf-tarbz2-src-pkg - Build perf-2.6.35-rc1.tar.bz2 source tarball [root@emilia linux-2.6-tip]# make perf-tarbz2-src-pkg TAR [root@emilia linux-2.6-tip]# ls -la perf-2.6.35-rc1.tar.bz2 -rw-r--r-- 1 root root 295731 May 31 11:18 perf-2.6.35-rc1.tar.bz2 [root@emilia linux-2.6-tip]# tar xf perf-2.6.35-rc1.tar.bz2 [root@emilia linux-2.6-tip]# cd perf-2.6.35-rc1 [root@emilia perf-2.6.35-rc1]# ls arch HEAD include lib tools [root@emilia perf-2.6.35-rc1]# cd tools/perf [root@emilia perf]# make -j9 2>&1 | tail CC arch/x86/util/dwarf-regs.o CC util/probe-finder.o CC util/newt.o CC util/scripting-engines/trace-event-perl.o CC scripts/perl/Perf-Trace-Util/Context.o CC perf.o CC builtin-help.o AR libperf.a LINK perf rm .perf.dev.null [root@emilia perf]# ./perf record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.262 MB perf.data (~11457 samples) ] [root@emilia perf]# ./perf report | head -12 # Events: 6K cycles # # Overhead Command Shared Object Symbol # ........ ............... .................. ...... # 4.73% perf [kernel.kallsyms] [k] format_decode 4.49% perf libc-2.12.so [.] _IO_file_underflow_internal 4.38% init [kernel.kallsyms] [k] mwait_idle 3.29% perf [kernel.kallsyms] [k] vsnprintf 2.38% init [kernel.kallsyms] [k] sched_clock_local 2.35% init [kernel.kallsyms] [k] apic_timer_interrupt 1.86% sirq-timer/5 [kernel.kallsyms] [k] find_busiest_group [root@emilia perf]# Acked-by: Michal Marek <mmarek@suse.cz> Acked-by: Sam Ravnborg <sam@ravnborg.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michal Marek <mmarek@suse.cz> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20100528185357.GA28009@ghostprotocols.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-03Makefile: clarify a commentMichal Marek
os user <gnusercn@gmail.com> writes: From the last comment, arch makefile will override vmlinux. It seems vmlinux will not be checked by `make'. But from my test, although `all:' will be re-defined in arch Makefile (ARM arch), vmlinux will still be checked and the commands associated will be executed. Should we use another word instead of "overridden"? Reported-by: os user <gnusercn@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-30Linux 2.6.35-rc1v2.6.35-rc1Linus Torvalds
.. and thus endeth the merge window.
2010-05-16Linus 2.6.34v2.6.34Linus Torvalds
2010-05-09Linux 2.6.34-rc7v2.6.34-rc7Linus Torvalds
2010-05-06kbuild: Fix checking of scm-identifier variableGreg Thelen
I'm looking Makefile in the -mm branch (dated 2010-04-28-16-53) and seeing what looks like a bug in the checking of scm-identifier. The "ifneq ($scm-identifier)" seems to always execute "ifeq ($(LOCALVERSION,)) ...". This patch fixes the checking of scm-identifier. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-04-29Linux 2.6.34-rc6v2.6.34-rc6Linus Torvalds
2010-04-19Linux 2.6.34-rc5v2.6.34-rc5Linus Torvalds
2010-04-12Linux 2.6.34-rc4v2.6.34-rc4Linus Torvalds
2010-03-30Linux 2.6.34-rc3v2.6.34-rc3Linus Torvalds
2010-03-19Linux 2.6.34-rc2v2.6.34-rc2Linus Torvalds
2010-03-10kbuild: Generate modules.builtin in make modules_installMichal Marek
The previous approach didn't work if one did make modules && make modules_install Add modules.builtin as dependency of _modinst_, which is the target that actually needs the file. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-03-08Linux 2.6.34-rc1v2.6.34-rc1Linus Torvalds
