path: root/Makefile
2012-12-10Linux 3.7v3.7Linus Torvalds
2012-12-03Linux 3.7-rc8v3.7-rc8Linus Torvalds
2012-12-01Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "This is mostly about unbreaking architectures that took the UAPI changes in the v3.7 cycle, plus misc fixes." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf kvm: Fix building perf kvm on non x86 arches perf kvm: Rename perf_kvm to perf_kvm_stat perf: Make perf build for x86 with UAPI disintegration applied perf powerpc: Use uapi/unistd.h to fix build error tools: Pass the target in descend tools: Honour the O= flag when tool build called from a higher Makefile tools: Define a Makefile function to do subdir processing x86: Export asm/{svm.h,vmx.h,perf_regs.h} perf tools: Fix strbuf_addf() when the buffer needs to grow perf header: Fix numa topology printing perf, powerpc: Fix hw breakpoints returning -ENOSPC
2012-11-25Linux 3.7-rc7v3.7-rc7Linus Torvalds
2012-11-19tools: Honour the O= flag when tool build called from a higher MakefileDavid Howells
Honour the O= flag that was passed to a higher level Makefile and then passed down as part of a tool build. To make this work, the top-level Makefile passes the original O= flag and subdir=tools to the tools/Makefile, and that in turn passes subdir=$(O)/$(subdir)/foodir when building tool foo in directory $(O)/$(subdir)/foodir (where the intervening slashes aren't added if an element is missing). For example, take perf. This is found in tools/perf/. Assume we're building into directory ~/zebra/, so we pass O=~/zebra to make. Dependening on where we run the build from, we see: make run in dir $(OUTPUT) dir ======================= ================== linux ~/zebra/tools/perf/ linux/tools ~/zebra/perf/ linux/tools/perf ~/zebra/ and if O= is not set, we get: make run in dir $(OUTPUT) dir ======================= ================== linux linux/tools/perf/ linux/tools linux/tools/perf/ linux/tools/perf linux/tools/perf/ The output directories are created by the descend function if they don't already exist. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1378.1352379110@warthog.procyon.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-16Linux 3.7-rc6v3.7-rc6Linus Torvalds
2012-11-11Linux 3.7-rc5v3.7-rc5Linus Torvalds
2012-11-04Linux 3.7-rc4v3.7-rc4Linus Torvalds
2012-10-28Linux 3.7-rc3v3.7-rc3Linus Torvalds
2012-10-20Linux 3.7-rc2v3.7-rc2Linus Torvalds
2012-10-19MODSIGN: perlify sign-file and merge in x509keyidDavid Howells
Turn sign-file into perl and merge in x509keyid. The latter doesn't need to be a separate script as it doesn't actually need to work out the SHA1 sum of the X.509 certificate itself, since it can get that from the X.509 certificate. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-19kbuild: sign the modules at install timeRusty Russell
Linus deleted the old code and put signing on the install command, I fixed it to extract the keyid and signer-name within sign-file and cleaned up that script now it always signs in-place. Some enthusiast should convert sign-key to perl and pull x509keyid into it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-17uapi: Allow automatic generation of uapi/asm/ header filesCatalin Marinas
Several arch/*/include/uapi/asm/* header simply include the corresponding <asm-generic/*> file. This patch allows such files to be specified in uapi/asm/Kbuild via "generic-y += ..." to be automatically generated (similar to asm/Kbuild). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Arnd Bergmann <arnd@arndb.de>
2012-10-14Linux 3.7-rc1v3.7-rc1Linus Torvalds
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The main part of kbuild for v3.7 contains: - Fix for scripts/Makefile.modpost to not choke on a '.ko' substring in the build directory path - Two warning fixes (modpost and main Makefile) - __compiletime_error works also with gcc 4.3 - make tar{gz,bz2,xz}-pkg uses default compression settings instead of saving as many bytes as possible (this should actually be in the misc branch, I don't know why I applied it here)." * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: compiler-gcc4.h: correct verion check for __compiletime_error modpost: Permit .GCC.command.line sections Kbuild: use normal compression settings for tar*-pkg scripts/Makefile.modpost: error in finding modules from .mod files. kbuild: Remove useless warning while appending KCFLAGS
2012-10-10MODSIGN: Make mrproper should remove generated files.Rusty Russell
It doesn't, because the clean targets don't include kernel/Makefile, and because two files were missing from the list. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Provide gitignore and make clean rules for extra filesDavid Howells
Provide gitignore and make clean rules for extra files to hide and clean up the extra files produced by module signing stuff once it is added. Also add a clean up rule for the module content extractor program used to extract the data to be signed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-02UAPI: Plumb the UAPI Kbuilds into the user header installation and checkingDavid Howells
Plumb the UAPI Kbuilds into the user header installation and checking system. As the headers are split the entries will be transferred across from the old Kbuild files to the UAPI Kbuild files. The changes made in this commit are: (1) Exported generated files (of which there are currently four) are moved to uapi/ directories under the appropriate generated/ directory, thus we get: include/generated/uapi/linux/version.h arch/x86/include/generated/uapi/asm/unistd_32.h arch/x86/include/generated/uapi/asm/unistd_64.h arch/x86/include/generated/uapi/asm/unistd_x32.h These paths were added to the build as -I flags in a previous patch. (2) scripts/Makefile.headersinst is now given the UAPI path to install from rather than the old path. It then determines the old path from that and includes that Kbuild also if it exists, thus permitting the headers to exist in either directory during the changeover. I also renamed the "install" variable to "installdir" as it refers to a directory not the install program. (3) scripts/headers_install.pl is altered to take a list of source file paths instead of just their names so that the makefile can tell it exactly where to find each file. For the moment, files can be obtained from one of four places for each output directory: .../include/uapi/foo/ .../include/generated/uapi/foo/ .../include/foo/ .../include/generated/foo/ The non-UAPI paths will be dropped later. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: Move linux/version.hDavid Howells
Move include/linux/version.h to the include/generated/ header directory. A later patch will move it to include/uapi/generated/. This allows us to get rid of the objhdr-y list. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: Partition the header include path sets and add uapi/ header directoriesDavid Howells
Partition the header include path flags into two sets, one for kernelspace builds and one for userspace builds. Add the following directories to build after the ordinary include directories so that #include will pick up the UAPI header directly if the kernel header has been moved there. The userspace set (represented by the USERINCLUDE make variable) contains: -I $(srctree)/arch/$(hdr-arch)/include/uapi -I arch/$(hdr-arch)/include/generated/uapi -I $(srctree)/include/uapi -I include/generated/uapi -include $(srctree)/include/linux/kconfig.h and the kernelspace set (represented by the LINUXINCLUDE make variable) contains: -I $(srctree)/arch/$(hdr-arch)/include -I arch/$(hdr-arch)/include/generated -I $(srctree)/include -I include --- if not building in the source tree plus everything in the USERINCLUDE set. Then use USERINCLUDE in building the x86 boot code. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-01Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf update from Ingo Molnar: "Lots of changes in this cycle as well, with hundreds of commits from over 30 contributors. Most of the activity was on the tooling side. Higher level changes: - New 'perf kvm' analysis tool, from Xiao Guangrong. - New 'perf trace' system-wide tracing tool - uprobes fixes + cleanups from Oleg Nesterov. - Lots of patches to make perf build on Android out of box, from Irina Tirdea - Extend ftrace function tracing utility to be more dynamic for its users. It allows for data passing to the callback functions, as well as reading regs as if a breakpoint were to trigger at function entry. The main goal of this patch series was to allow kprobes to use ftrace as an optimized probe point when a probe is placed on an ftrace nop. With lots of help from Masami Hiramatsu, and going through lots of iterations, we finally came up with a good solution. - Add cpumask for uncore pmu, use it in 'stat', from Yan, Zheng. - Various tracing updates from Steve Rostedt - Clean up and improve 'perf sched' performance by elliminating lots of needless calls to libtraceevent. - Event group parsing support, from Jiri Olsa - UI/gtk refactorings and improvements from Namhyung Kim - Add support for non-tracepoint events in perf script python, from Feng Tang - Add --symbols to 'script', similar to the one in 'report', from Feng Tang. Infrastructure enhancements and fixes: - Convert the trace builtins to use the growing evsel/evlist tracepoint infrastructure, removing several open coded constructs like switch like series of strcmp to dispatch events, etc. Basically what had already been showcased in 'perf sched'. - Add evsel constructor for tracepoints, that uses libtraceevent just to parse the /format events file, use it in a new 'perf test' to make sure the libtraceevent format parsing regressions can be more readily caught. - Some strange errors were happening in some builds, but not on the next, reported by several people, problem was some parser related files, generated during the build, didn't had proper make deps, fix from Eric Sandeen. - Introduce struct and cache information about the environment where a perf.data file was captured, from Namhyung Kim. - Fix handling of unresolved samples when --symbols is used in 'report', from Feng Tang. - Add union member access support to 'probe', from Hyeoncheol Lee. - Fixups to die() removal, from Namhyung Kim. - Render fixes for the TUI, from Namhyung Kim. - Don't enable annotation in non symbolic view, from Namhyung Kim. - Fix pipe mode in 'report', from Namhyung Kim. - Move related stats code from stat to util/, will be used by the 'stat' kvm tool, from Xiao Guangrong. - Remove die()/exit() calls from several tools. - Resolve vdso callchains, from Jiri Olsa - Don't pass const char pointers to basename, so that we can unconditionally use libgen.h and thus avoid ifdef BIONIC lines, from David Ahern - Refactor hist formatting so that it can be reused with the GTK browser, From Namhyung Kim - Fix build for another rbtree.c change, from Adrian Hunter. - Make 'perf diff' command work with evsel hists, from Jiri Olsa. - Use the only field_sep var that is set up: symbol_conf.field_sep, fix from Jiri Olsa. - .gitignore compiled python binaries, from Namhyung Kim. - Get rid of die() in more libtraceevent places, from Namhyung Kim. - Rename libtraceevent 'private' struct member to 'priv' so that it works in C++, from Steven Rostedt - Remove lots of exit()/die() calls from tools so that the main perf exit routine can take place, from David Ahern - Fix x86 build on x86-64, from David Ahern. - {int,str,rb}list fixes from Suzuki K Poulose - perf.data header fixes from Namhyung Kim - Allow user to indicate objdump path, needed in cross environments, from Maciek Borzecki - Fix hardware cache event name generation, fix from Jiri Olsa - Add round trip test for sw, hw and cache event names, catching the problem Jiri fixed, after Jiri's patch, the test passes successfully. - Clean target should do clean for lib/traceevent too, fix from David Ahern - Check the right variable for allocation failure, fix from Namhyung Kim - Set up evsel->tp_format regardless of evsel->name being set already, fix from Namhyung Kim - Oprofile fixes from Robert Richter. - Remove perf_event_attr needless version inflation, from Jiri Olsa - Introduce libtraceevent strerror like error reporting facility, from Namhyung Kim - Add pmu mappings to perf.data header and use event names from cmd line, from Robert Richter - Fix include order for bison/flex-generated C files, from Ben Hutchings - Build fixes and documentation corrections from David Ahern - Assorted cleanups from Robert Richter - Let O= makes handle relative paths, from Steven Rostedt - perf script python fixes, from Feng Tang. - Initial bash completion support, from Frederic Weisbecker - Allow building without libelf, from Namhyung Kim. - Support DWARF CFI based unwind to have callchains when %bp based unwinding is not possible, from Jiri Olsa. - Symbol resolution fixes, while fixing support PPC64 files with an .opt ELF section was the end goal, several fixes for code that handles all architectures and cleanups are included, from Cody Schafer. - Assorted fixes for Documentation and build in 32 bit, from Robert Richter - Cache the libtraceevent event_format associated to each evsel early, so that we avoid relookups, i.e. calling pevent_find_event repeatedly when processing tracepoint events. [ This is to reduce the surface contact with libtraceevents and make clear what is that the perf tools needs from that lib: so far parsing the common and per event fields. ] - Don't stop the build if the audit libraries are not installed, fix from Namhyung Kim. - Fix bfd.h/libbfd detection with recent binutils, from Markus Trippelsdorf. - Improve warning message when libunwind devel packages not present, from Jiri Olsa" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits) perf trace: Add aliases for some syscalls perf probe: Print an enum type variable in "enum variable-name" format when showing accessible variables perf tools: Check libaudit availability for perf-trace builtin perf hists: Add missing period_* fields when collapsing a hist entry perf trace: New tool perf evsel: Export the event_format constructor perf evsel: Introduce rawptr() method perf tools: Use perf_evsel__newtp in the event parser perf evsel: The tracepoint constructor should store sys:name perf evlist: Introduce set_filter() method perf evlist: Renane set_filters method to apply_filters perf test: Add test to check we correctly parse and match syscall open parms perf evsel: Handle endianity in intval method perf evsel: Know if byte swap is needed perf tools: Allow handling a NULL cpu_map as meaning "all cpus" perf evsel: Improve tracepoint constructor setup tools lib traceevent: Fix error path on pevent_parse_event perf test: Fix build failure trace: Move trace event enable from fs_initcall to core_initcall tracing: Add an option for disabling markers ...
2012-09-30Linux 3.6v3.6Linus Torvalds
2012-09-23Linux 3.6-rc7v3.6-rc7Linus Torvalds
2012-09-16Linux 3.6-rc6v3.6-rc6Linus Torvalds
2012-09-13Merge branch 'core/rcu' into perf/coreIngo Molnar
Steve Rostedt asked for the merge of a single commit, into both the RCU and the perf/tracing tree: | Josh made a change to the tracing code that affects both the | work Paul McKenney and I are currently doing. At the last | Kernel Summit back in August, Linus said when such a case | exists, it is best to make a separate branch based off of his | tree and place the change there. This way, the repositories | that need to share the change can both pull them in and the | SHA1 will match for both. Whichever branch is pulled in first | by Linus will also pull in the necessary change for the other | branch as well. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-08Linux 3.6-rc5v3.6-rc5Linus Torvalds
2012-09-01Linux 3.6-rc4v3.6-rc4Linus Torvalds
2012-08-31kbuild: Remove useless warning while appending KCFLAGSOzan Çağlayan
This is a respin of an older patch sent by Sam Ravnborg: http://www.gossamer-threads.com/lists/linux/kernel/1530602 This patch removes the annoying warning: Makefile:708: "WARNING: Appending $KCFLAGS (-Wno-sign-compare) from command line to kernel $CFLAGS" which is printed every time I use KCFLAFS. The commit which introduced the warning: 69ee0b3 kbuild: do not pick up CFLAGS from the environment tells about the problems when people have CFLAGS in their environment, then switches to KCFLAFS which should be enough to solve the issue, but it anyway introduces a warning. Drop this warning. Signed-off-by: Ozan Çağlayan <ozancag@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-08-28Merge branch 'perf/urgent' into perf/coreIngo Molnar
Pick up the latest fixes because upcoming uprobes changes will rely on it. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-08-23ftrace: Add -mfentry to Makefile on function tracerSteven Rostedt
Thanks to Andi Kleen, gcc 4.6.0 now supports -mfentry for x86 (and hopefully soon for other archs). What this does is to have the function profiler start at the beginning of the function instead of after the stack is set up. As plain -pg (mcount) is called after the stack is set up, and in some cases can have issues with the function graph tracer. It also requires frame pointers to be enabled. The -mfentry now calls __fentry__ at the beginning of the function. This allows for compiling without frame pointers and even has the ability to access parameters if needed. If the architecture and the compiler both support -mfentry then use that instead. Link: http://lkml.kernel.org/r/20120807194059.392617243@goodmis.org Acked-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-08-22Linux 3.6-rc3v3.6-rc3Linus Torvalds
2012-08-16Linux 3.6-rc2v3.6-rc2Linus Torvalds
2012-08-02Linux 3.6-rc1v3.6-rc1Linus Torvalds
2012-07-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fix from Michal Marek: "The main kbuild branch ended up with a single commit this time, a fix to send errors to stderr" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Print errors to stderr
2012-07-21Linux 3.5v3.5Linus Torvalds
2012-07-14Linux 3.5-rc7v3.5-rc7Linus Torvalds
2012-07-07Linux 3.5-rc6v3.5-rc6Linus Torvalds
2012-07-07kbuild: Print errors to stderrMichal Marek
... at least in the top-level Makefile and scripts/link-vmlinux.sh. There are some more instances of the 'echo <error>; exit 1' pattern in some arch Makefiles and kconfig. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-30Linux 3.5-rc5v3.5-rc5Linus Torvalds
2012-06-24Linux 3.5-rc4v3.5-rc4Linus Torvalds
2012-06-18Makefile: fix up CROSS_COMPILE and READABLE_ASM interaction.Paul Mundt
When the READABLE_ASM cc-option tests were added they were done so prior to the arch Makefile include, resulting in cc-option being run on the host cc instead of the factoring in the cross prefix set up by the architecture. This bumps the include back up so that cc-option actually runs on the compiler that we're building with. Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-16Linux 3.5-rc3v3.5-rc3Linus Torvalds
2012-06-08Linux 3.5-rc2v3.5-rc2Linus Torvalds
2012-06-02Linux 3.5-rc1v3.5-rc1Linus Torvalds
2012-05-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek. Fixed up nontrivial merge conflict in Makefile as per Stephen Rothwell and linux-next (and trivial arch/sparc/Makefile changes due to removed sparc32 logic). * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: mips: Fix KBUILD_CPPFLAGS definition kbuild: fix ia64 link kbuild: document KBUILD_LDS, KBUILD_VMLINUX_{INIT,MAIN} and LDFLAGS_vmlinux kbuild: link of vmlinux moved to a script kbuild: refactor final link of sparc32 kbuild: drop unused KBUILD_VMLINUX_OBJS from top-level Makefile kbuild: Makefile: remove unnecessary check for m68knommu ARCH
2012-05-23Merge branch 'x86-extable-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull exception table generation updates from Ingo Molnar: "The biggest change here is to allow the build-time sorting of the exception table, to speed up booting. This is achieved by the architecture enabling BUILDTIME_EXTABLE_SORT. This option is enabled for x86 and MIPS currently. On x86 a number of fixes and changes were needed to allow build-time sorting of the exception table, in particular a relocation invariant exception table format was needed. This required the abstracting out of exception table protocol and the removal of 20 years of accumulated assumptions about the x86 exception table format. While at it, this tree also cleans up various other aspects of exception handling, such as early(er) exception handling for rdmsr_safe() et al. All in one, as the result of these changes the x86 exception code is now pretty nice and modern. As an added bonus any regressions in this code will be early and violent crashes, so if you see any of those, you'll know whom to blame!" Fix up trivial conflicts in arch/{mips,x86}/Kconfig files due to nearby modifications of other core architecture options. * 'x86-extable-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (35 commits) Revert "x86, extable: Disable presorted exception table for now" scripts/sortextable: Handle relative entries, and other cleanups x86, extable: Switch to relative exception table entries x86, extable: Disable presorted exception table for now x86, extable: Add _ASM_EXTABLE_EX() macro x86, extable: Remove open-coded exception table entries in arch/x86/ia32/ia32entry.S x86, extable: Remove open-coded exception table entries in arch/x86/include/asm/xsave.h x86, extable: Remove open-coded exception table entries in arch/x86/include/asm/kvm_host.h x86, extable: Remove the now-unused __ASM_EX_SEC macros x86, extable: Remove open-coded exception table entries in arch/x86/xen/xen-asm_32.S x86, extable: Remove open-coded exception table entries in arch/x86/um/checksum_32.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/usercopy_32.c x86, extable: Remove open-coded exception table entries in arch/x86/lib/putuser.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/getuser.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/csum-copy_64.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/copy_user_nocache_64.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/copy_user_64.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/checksum_32.S x86, extable: Remove open-coded exception table entries in arch/x86/kernel/test_rodata.c x86, extable: Remove open-coded exception table entries in arch/x86/kernel/entry_64.S ...
2012-05-23Merge branches 'x86-asm-for-linus', 'x86-cleanups-for-linus', ↵Linus Torvalds
'x86-cpu-for-linus', 'x86-debug-for-linus' and 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull initial trivial x86 stuff from Ingo Molnar. Various random cleanups and trivial fixes. * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86-64: Eliminate dead ia32 syscall handlers * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/pci-calgary_64.c: Remove obsoleted simple_strtoul() usage x86: Don't continue booting if we can't load the specified initrd x86: kernel/dumpstack.c simple_strtoul cleanup x86: kernel/check.c simple_strtoul cleanup debug: Add CONFIG_READABLE_ASM x86: spinlock.h: Remove REG_PTR_MODE * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/cache_info: Fix setup of l2/l3 ids * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Avoid double stack traces with show_regs() * 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode: microcode_core.c simple_strtoul cleanup
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-22Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Lots of changes: - (much) improved assembly annotation support in perf report, with jump visualization, searching, navigation, visual output improvements and more. - kernel support for AMD IBS PMU hardware features. Notably 'perf record -e cycles:p' and 'perf top -e cycles:p' should work without skid now, like PEBS does on the Intel side, because it takes advantage of IBS transparently. - the libtracevents library: it is the first step towards unifying tracing tooling and perf, and it also gives a tracing library for external tools like powertop to rely on. - infrastructure: various improvements and refactoring of the UI modules and related code - infrastructure: cleanup and simplification of the profiling targets code (--uid, --pid, --tid, --cpu, --all-cpus, etc.) - tons of robustness fixes all around - various ftrace updates: speedups, cleanups, robustness improvements. - typing 'make' in tools/ will now give you a menu of projects to build and a short help text to explain what each does. - ... and lots of other changes I forgot to list. The perf record make bzImage + perf report regression you reported should be fixed." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (166 commits) tracing: Remove kernel_lock annotations tracing: Fix initial buffer_size_kb state ring-buffer: Merge separate resize loops perf evsel: Create events initially disabled -- again perf tools: Split term type into value type and term type perf hists: Fix callchain ip printf format perf target: Add uses_mmap field ftrace: Remove selecting FRAME_POINTER with FUNCTION_TRACER ftrace/x86: Have x86 ftrace use the ftrace_modify_all_code() ftrace: Make ftrace_modify_all_code() global for archs to use ftrace: Return record ip addr for ftrace_location() ftrace: Consolidate ftrace_location() and ftrace_text_reserved() ftrace: Speed up search by skipping pages by address ftrace: Remove extra helper functions ftrace: Sort all function addresses, not just per page tracing: change CPU ring buffer state from tracing_cpumask tracing: Check return value of tracing_dentry_percpu() ring-buffer: Reset head page before running self test ring-buffer: Add integrity check at end of iter read ring-buffer: Make addition of pages in ring buffer atomic ...
