git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild updates from Michal Marek:
"Non-critical kbuild changes:
- make coccicheck improvements, but no new semantic patches this time
- make rpm improvements
- make tar-pkg change to include the architecture in the filename.
This is a deliberate incompatibility, but nobody has complained so
far and it is useful if you build for different architectures. It
also matches what the deb-pkg and rpm-pkg targets produce.
- kbuild documentation fix"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
rpm-pkg: Remove pointless set -e statements
rpm-pkg: Always regenerate the specfile
rpm-pkg: Do not write to the parent directory
rpm-pkg: Do not package the whole source directory
buildtar: Add ARCH to the archive name
Coccinelle: Fix patch output when coccicheck is used with M= and C=
Coccinelle: Add support to the SPFLAGS variable
Coccinelle: Cleanup the setting of the FLAGS and OPTIONS variables
Coccinelle: Restore coccicheck verbosity in ONLINE mode (C=1 or C=2)
scripts/package/Makefile: compare objtree with srctree instead of test KBUILD_OUTPUT
doc: change example to existing Makefile fragment
scripts/tags.sh: Add magic for OFFSET and DEFINE
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull mudule updates from Rusty Russell:
"We get rid of the general module prefix confusion with a binary config
option, fix a remove/insert race which Never Happens, and (my
favorite) handle the case when we have too many modules for a single
commandline. Seriously, the kernel is full, please go away!"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: fix unwanted VMLINUX_SYMBOL_STR expansion
X.509: Support parse long form of length octets in Authority Key Identifier
module: don't unlink the module until we've removed all exposure.
kernel: kallsyms: memory override issue, need check destination buffer length
MODSIGN: do not send garbage to stderr when enabling modules signature
modpost: handle huge numbers of modules.
modpost: add -T option to read module names from file/stdin.
modpost: minor cleanup.
genksyms: pass symbol-prefix instead of arch
module: fix symbol versioning with symbol prefixes
CONFIG_SYMBOL_PREFIX: cleanup.
Pull ARM SoC non-critical fixes from Olof Johansson:
"Here is a collection of fixes (and some intermixed cleanups) that were
considered less important and thus not included in the later parts of
the 3.9-rc cycle.
It's a bit all over the map, contents wise. A series of ux500 fixes
and cleanups, a bunch of various fixes for OMAP and tegra, and some
for Freescale i.MX and even Qualcomm MSM.
Note that there's also a patch on this branch to globally turn off
-Wmaybe-uninitialized when building with -Os. It's been posted
several times by Arnd and no dissent was raised, but nobody seemed
interested to pick it up. So here it is, as the topmost patch."
* tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
Turn off -Wmaybe-uninitialized when building with -Os
ARM: orion5x: include linux/cpu.h
ARM: tegra: call cpu_do_idle from C code
ARM: u300: fix ages old copy/paste bug
ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7
ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled
ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled
ARM: tegra: fix build error when THUMB2_KERNEL enabled
ARM: msm: Fix uncompess.h tx underrun check
ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms
ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro
ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS"
ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD"
ARM: mach-imx: mach-imx6q: Fix sparse warnings
ARM: mach-imx: src: Include "common.h
ARM: mach-imx: gpc: Include "common.h"
ARM: mach-imx: avic: Staticize *avic_base
ARM: mach-imx: tzic: Staticize *tzic_base
ARM: mach-imx: clk: Include "clk.h"
ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops
Pull perf updates from Ingo Molnar:
"Features:
- Add "uretprobes" - an optimization to uprobes, like kretprobes are
an optimization to kprobes. "perf probe -x file sym%return" now
works like kretprobes. By Oleg Nesterov.
- Introduce per core aggregation in 'perf stat', from Stephane
Eranian.
- Add memory profiling via PEBS, from Stephane Eranian.
- Event group view for 'annotate' in --stdio, --tui and --gtk, from
Namhyung Kim.
- Add support for AMD NB and L2I "uncore" counters, by Jacob Shin.
- Add Ivy Bridge-EP uncore support, by Zheng Yan
- IBM zEnterprise EC12 oprofile support patchlet from Robert Richter.
- Add perf test entries for checking breakpoint overflow signal
handler issues, from Jiri Olsa.
- Add perf test entry for for checking number of EXIT events, from
Namhyung Kim.
- Add perf test entries for checking --cpu in record and stat, from
Jiri Olsa.
- Introduce perf stat --repeat forever, from Frederik Deweerdt.
- Add --no-demangle to report/top, from Namhyung Kim.
- PowerPC fixes plus a couple of cleanups/optimizations in uprobes
and trace_uprobes, by Oleg Nesterov.
Various fixes and refactorings:
- Fix dependency of the python binding wrt libtraceevent, from
Naohiro Aota.
- Simplify some perf_evlist methods and to allow 'stat' to share code
with 'record' and 'trace', by Arnaldo Carvalho de Melo.
- Remove dead code in related to libtraceevent integration, from
Namhyung Kim.
- Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf
sched lat' back working, by Arnaldo Carvalho de Melo
- We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho
de Melo.
- Kill a bunch of die() calls, from Namhyung Kim.
- Fix build on non-glibc systems due to libio.h absence, from Cody P
Schafer.
- Remove some perf_session and tracing dead code, from David Ahern.
- Honor parallel jobs, fix from Borislav Petkov
- Introduce tools/lib/lk library, initially just removing duplication
among tools/perf and tools/vm. from Borislav Petkov
... and many more I missed to list, see the shortlog and git log for
more details."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits)
perf/x86/intel/P4: Robistify P4 PMU types
perf/x86/amd: Fix AMD NB and L2I "uncore" support
perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c
perf/x86: Check all MSRs before passing hw check
perf/x86/amd: Add support for AMD NB and L2I "uncore" counters
perf/x86/intel: Add Ivy Bridge-EP uncore support
perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management
perf/x86: Avoid kfree() in CPU_{STARTING,DYING}
uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty
uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit()
uprobes/tracing: Change create_trace_uprobe() to support uretprobes
uprobes/tracing: Make seq_printf() code uretprobe-friendly
uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly
uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly
uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher()
uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers
uprobes/tracing: Generalize struct uprobe_trace_entry_head
uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls
uprobes/tracing: Kill the pointless seq_print_ip_sym() call
uprobes/tracing: Kill the pointless task_pt_regs() calls
gcc-4.7 and higher add a lot of false positive warnings about
potential uses of uninitialized warnings, but only when optimizing
for size (-Os). This is the default when building allyesconfig,
which turns on CONFIG_CC_OPTIMIZE_FOR_SIZE.
In order to avoid getting a lot of patches that initialize such
variables and accidentally hide real errors along the way, let's
just turn off this warning on the respective gcc versions
when building with size optimizations. The -Wmaybe-uninitialized
option was introduced in the same gcc version (4.7) that is now
causing the false positives, so there is no effect on older compilers.
A side effect is that when building with CONFIG_CC_OPTIMIZE_FOR_SIZE,
we might now see /fewer/ warnings about possibly uninitialized
warnings than with -O2, but that is still much better than seeing
warnings known to be bogus.
arch/x86/kernel/cpu/perf_event_intel.c
Merge in the latest fixes before applying new patches, resolve the conflict.
The source tree can contain lots of uninteresting data like tag or
cscope files, packaging which slows down make rpm needlessly. It can
also break the build, if the tree contains an unrelated file named
*.spec. The downside of this change is that new subdirectories have to
be added to the KBUILD_ALLDIRS variable in the top-level Makefile. The
upside is that the behavior is more predictable.
Pull kbuild fix from Michal Marek:
"Fix for a missing dependency when generating scripts/mod/devicetable-offsets.h.
This dependency got introduced in v3.9-rc1."
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: generate generic headers before recursing into scripts
