path: root/Makefile
2012-04-02Linux 3.0.27v3.0.27Greg Kroah-Hartman
2012-03-23Linux 3.0.26v3.0.26Greg Kroah-Hartman
2012-03-19Linux 3.0.25v3.0.25Greg Kroah-Hartman
2012-03-12Linux 3.0.24v3.0.24Greg Kroah-Hartman
2012-02-29Linux 3.0.23v3.0.23Greg Kroah-Hartman
2012-02-20Linux 3.0.22v3.0.22Greg Kroah-Hartman
2012-02-13Linux 3.0.21v3.0.21Greg Kroah-Hartman
2012-02-06Linux 3.0.20v3.0.20Greg Kroah-Hartman
2012-02-03Linux 3.0.19v3.0.19Greg Kroah-Hartman
2012-01-25Linux 3.0.18v3.0.18Greg Kroah-Hartman
2012-01-12Linux 3.0.17v3.0.17Greg Kroah-Hartman
2012-01-06Linux 3.0.16v3.0.16Greg Kroah-Hartman
2012-01-03Linux 3.0.15v3.0.15Greg Kroah-Hartman
2011-12-21Linux 3.0.14v3.0.14Greg Kroah-Hartman
2011-12-09Linux 3.0.13v3.0.13Greg Kroah-Hartman
2011-11-29Linux 3.0.12v3.0.12Greg Kroah-Hartman
2011-11-26Linux 3.0.11v3.0.11Greg Kroah-Hartman
2011-11-21Linux 3.0.10v3.0.10Greg Kroah-Hartman
2011-11-11Linux 3.0.9v3.0.9Greg Kroah-Hartman
2011-10-25Linux 3.0.8v3.0.8Greg Kroah-Hartman
2011-10-16Linux 3.0.7v3.0.7Greg Kroah-Hartman
2011-10-03Linux 3.0.6v3.0.6Greg Kroah-Hartman
2011-10-03Linux 3.0.5v3.0.5Greg Kroah-Hartman
2011-08-29Linux 3.0.4v3.0.4Greg Kroah-Hartman
2011-08-17Linux 3.0.3v3.0.3Greg Kroah-Hartman
2011-08-15Linux 3.0.2v3.0.2Greg Kroah-Hartman
2011-08-04Linux 3.0.1v3.0.1Greg Kroah-Hartman
2011-07-21Linux 3.0v3.0Linus Torvalds
2011-07-11Linux 3.0-rc7v3.0-rc7Linus Torvalds
2011-07-04Linux 3.0-rc6v3.0-rc6Linus Torvalds
2011-06-27Linux 3.0-rc5v3.0-rc5Linus Torvalds
2011-06-20Linux 3.0-rc4v3.0-rc4Linus Torvalds
2011-06-16Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Call depmod.sh via shell perf: clear out make flags when calling kernel make kernelver
2011-06-15kbuild: Call depmod.sh via shellMichal Marek
The script has the executable bit in git, but plain old patch(1) can't create executable files. Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-13Linux 3.0-rc3v3.0-rc3Linus Torvalds
2011-06-09Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: perf: Use make kernelversion instead of parsing the Makefile kbuild: Hack for depmod not handling X.Y versions kbuild: Move depmod call to a separate script kbuild: Fix <linux/version.h> for empty SUBLEVEL or PATCHLEVEL kbuild: Fix KERNELVERSION for empty SUBLEVEL or PATCHLEVEL kbuild: silence Nothing to be done for 'all' message
2011-06-09kbuild: Move depmod call to a separate scriptMichal Marek
Do not bloat the Makefile with multiline shell statements. No user-visible change intended. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09kbuild: Fix <linux/version.h> for empty SUBLEVEL or PATCHLEVELMichal Marek
expr treats all numbers as decimals, so prepending a zero is safe. Note that the KERNEL_VERSION() macro still takes three arguments, 3.0 has to be written as KERNEL_VERSION(3,0,0). Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09kbuild: Fix KERNELVERSION for empty SUBLEVEL or PATCHLEVELMichal Marek
Omit the second dot for releases without SUBLEVEL. If PATCHLEVEL is also empty, only display VERSION. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-06Linux 3.0-rc2v3.0-rc2Linus Torvalds
2011-05-29Linux 3.0-rc1v3.0-rc1Linus Torvalds
.. except there are various scripts that really know that there are three numbers, so it calls itself "3.0.0-rc1". Hopefully by the time the final 3.0 is out, we'll have that extra zero all figured out. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits) arch/tile: prefer "tilepro" as the name of the 32-bit architecture compat: include aio_abi.h for aio_context_t arch/tile: cleanups for tilegx compat mode arch/tile: allocate PCI IRQs later in boot arch/tile: support signal "exception-trace" hook arch/tile: use better definitions of xchg() and cmpxchg() include/linux/compat.h: coding-style fixes tile: add an RTC driver for the Tilera hypervisor arch/tile: finish enabling support for TILE-Gx 64-bit chip compat: fixes to allow working with tile arch arch/tile: update defconfig file to something more useful tile: do_hardwall_trap: do not play with task->sighand tile: replace mm->cpu_vm_mask with mm_cpumask() tile,mn10300: add device parameter to dma_cache_sync() audit: support the "standard" <asm-generic/unistd.h> arch/tile: clarify flush_buffer()/finv_buffer() function names arch/tile: kernel-related cleanups from removing static page size arch/tile: various header improvements for building drivers arch/tile: disable GX prefetcher during cache flush arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD ...
2011-05-25arch/tile: prefer "tilepro" as the name of the 32-bit architectureChris Metcalf
With this change, you can (and should) build with ARCH=tilepro for the current 32-bit chips. Building with ARCH=tile continues to work, but we've renamed the defconfig file to tilepro_defconfig for consistency. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-25Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: export_report: use warn() to issue WARNING, so they go to stderr export_report: sort SECTION 2 output export_report: do collectcfiles work in perl itself kbuild: make versioncheck work in KBUILD_OUTDIR kbuild: make includecheck work in KBUILD_OUTDIR kbuild: make headerdep work in KBUILD_OUTDIR kbuild: add targets to PHONY kbuild: don't warn about include/linux/version.h not including itself eradicate bashisms in scripts/patch-kernel
2011-05-24Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: make KBUILD_NOCMDDEP=1 handle empty built-in.o scripts/kallsyms.c: fix potential segfault scripts/gen_initramfs_list.sh: Convert to a /bin/sh script kbuild: Fix GNU make v3.80 compatibility kbuild: Fix passing -Wno-* options to gcc 4.4+ kbuild: move scripts/basic/docproc.c to scripts/docproc.c kbuild: Fix Makefile.asm-generic for um kbuild: Allow to combine multiple W= levels kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0 Fix handling of backlash character in LINUX_COMPILE_BY name kbuild: asm-generic support kbuild: implement several W= levels kbuild: Fix build with binutils <= 2.19 initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entries kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macros kbuild: Drop unused LINUX_COMPILE_TIME and LINUX_COMPILE_DOMAIN macros kbuild: Use the deterministic mode of ar kbuild: Call gzip with -n kbuild: move KALLSYMS_EXTRA_PASS from Kconfig to Makefile Kconfig: improve KALLSYMS_ALL documentation Fix up trivial conflict in Makefile
2011-05-19Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (107 commits) perf stat: Add more cache-miss percentage printouts perf stat: Add -d -d and -d -d -d options to show more CPU events ftrace/kbuild: Add recordmcount files to force full build ftrace: Add self-tests for multiple function trace users ftrace: Modify ftrace_set_filter/notrace to take ops ftrace: Allow dynamically allocated function tracers ftrace: Implement separate user function filtering ftrace: Free hash with call_rcu_sched() ftrace: Have global_ops store the functions that are to be traced ftrace: Add ops parameter to ftrace_startup/shutdown functions ftrace: Add enabled_functions file ftrace: Use counters to enable functions to trace ftrace: Separate hash allocation and assignment ftrace: Create a global_ops to hold the filter and notrace hashes ftrace: Use hash instead for FTRACE_FL_FILTER ftrace: Replace FTRACE_FL_NOTRACE flag with a hash of ignored functions perf bench, x86: Add alternatives-asm.h wrapper x86, 64-bit: Fix copy_[to/from]_user() checks for the userspace address limit x86, mem: memset_64.S: Optimize memset by enhanced REP MOVSB/STOSB x86, mem: memmove_64.S: Optimize memmove by enhanced REP MOVSB/STOSB ...
2011-05-18Linux 2.6.39v2.6.39Linus Torvalds
2011-05-16kbuild/recordmcount: Add RECORDMCOUNT_WARN to warn about mcount callersSteven Rostedt
When mcount is called in a section that ftrace will not modify it into a nop, we want to warn about this. But not warn about this always. Now if the user builds the kernel with the option RECORDMCOUNT_WARN=1 then the build will warn about mcount callers that are ignored and will just waste execution time. Acked-by: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Link: http://lkml.kernel.org/r/20110421023738.714956282@goodmis.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-12arch/tile: finish enabling support for TILE-Gx 64-bit chipChris Metcalf
This support was partially present in the existing code (look for "__tilegx__" ifdefs) but with this change you can build a working kernel using the TILE-Gx toolchain and ARCH=tilegx. Most of these files are new, generally adding a foo_64.c file where previously there was just a foo_32.c file. The ARCH=tilegx directive redirects to arch/tile, not arch/tilegx, using the existing SRCARCH mechanism in the top-level Makefile. Changes to existing files: - <asm/bitops.h> and <asm/bitops_32.h> changed to factor the include of <asm-generic/bitops/non-atomic.h> in the common header. - <asm/compat.h> and arch/tile/kernel/compat.c changed to remove the "const" markers I had put on compat_sys_execve() when trying to match some recent similar changes to the non-compat execve. It turns out the compat version wasn't "upgraded" to use const. - <asm/opcode-tile_64.h> and <asm/opcode_constants_64.h> were previously included accidentally, with the 32-bit contents. Now they have the proper 64-bit contents. Finally, I had to hack the existing hacky drivers/input/input-compat.h to add yet another "#ifdef" for INPUT_COMPAT_TEST (same as x86_64). Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [drivers/input]
2011-05-12kbuild: make versioncheck work in KBUILD_OUTDIRPeter Foley
This patch fixes the versioncheck target so it works when make is invoked in KBUILD_OUTDIR. Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
