path: root/Makefile
2010-12-15Linux 2.6.37-rc6v2.6.37-rc6Linus Torvalds
2010-12-06Linux 2.6.37-rc5v2.6.37-rc5Linus Torvalds
2010-11-29Linux 2.6.37-rc4v2.6.37-rc4Linus Torvalds
2010-11-21Linux 2.6.37-rc3v2.6.37-rc3Linus Torvalds
2010-11-15Linux 2.6.37-rc2v2.6.37-rc2Linus Torvalds
2010-11-01Linux 2.6.37-rc1v2.6.37-rc1Linus Torvalds
2010-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: kbuild: add ARCH=sparc32 target sparc32: fix build failure on CONFIG_SPARC_LEON sparc: Fixed random SPARC/LEON SMP CPU Stuck problem. sparc32: remove CONFIG_HAVE_PERF_EVENTS option sparc: don't #include asm/system.h in asm/jump_label.h sparc32: Fix unaligned stack handling on trap return. sparc: keep calling do_signal() as long as pending signals remain
2010-10-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: initramfs: Fix build break on symbol-prefixed archs initramfs: fix initramfs size calculation initramfs: generalize initramfs_data.xxx.S variants scripts/kallsyms: Enable error messages while hush up unnecessary warnings scripts/setlocalversion: update comment kbuild: Use a single clean rule for kernel and external modules kbuild: Do not run make clean in $(srctree) scripts/mod/modpost.c: fix commentary accordingly to last changes kbuild: Really don't clean bounds.h and asm-offsets.h
2010-10-26kbuild: add ARCH=sparc32 targetNamhyung Kim
Add 'sparc32' ARCH target to test all{yes,mod}config for 32-bit build. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (278 commits) arm: remove machine_desc.io_pg_offst and .phys_io arm: use addruart macro to establish debug mappings arm: return both physical and virtual addresses from addruart arm/debug: consolidate addruart macros for CONFIG_DEBUG_ICEDCC ARM: make struct machine_desc definition coherent with its comment eukrea_mbimxsd-baseboard: Pass the correct GPIO to gpio_free cpuimx27: fix compile when ULPI is selected mach-pcm037_eet: fix compile errors Fixing ethernet driver compilation error for i.MX31 ADS board cpuimx51: update board support mx5: add cpuimx51sd module and its baseboard iomux-mx51: fix GPIO_1_xx 's IOMUX configuration imx-esdhc: update devices registration mx51: add resources for SD/MMC on i.MX51 iomux-mx51: fix SD1 and SD2's iomux configuration clock-mx51: rename CLOCK1 to CLOCK_CCGR for better readability clock-mx51: factorize clk_set_parent and clk_get_rate eukrea_mbimxsd: add support for DVI displays cpuimx25 & cpuimx35: fix OTG port registration in host mode i.MX31 and i.MX35 : fix errate TLSbo65953 and ENGcm09472 ...
2010-10-21Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits) tracing: Fix compile issue for trace_sched_wakeup.c [S390] hardirq: remove pointless header file includes [IA64] Move local_softirq_pending() definition perf, powerpc: Fix power_pmu_event_init to not use event->ctx ftrace: Remove recursion between recordmcount and scripts/mod/empty jump_label: Add COND_STMT(), reducer wrappery perf: Optimize sw events perf: Use jump_labels to optimize the scheduler hooks jump_label: Add atomic_t interface jump_label: Use more consistent naming perf, hw_breakpoint: Fix crash in hw_breakpoint creation perf: Find task before event alloc perf: Fix task refcount bugs perf: Fix group moving irq_work: Add generic hardirq context callbacks perf_events: Fix transaction recovery in group_sched_in() perf_events: Fix bogus AMD64 generic TLB events perf_events: Fix bogus context time tracking tracing: Remove parent recording in latency tracer graph options tracing: Use one prologue for the preempt irqs off tracer function tracers ...
2010-10-20Linux 2.6.36v2.6.36Linus Torvalds
2010-10-19Merge branch 'devel-stable' into develRussell King
2010-10-18Merge branches 'at91', 'dcache', 'ftrace', 'hwbpt', 'misc', 'mmci', 's3c', ↵Russell King
'st-ux' and 'unwind' into devel
2010-10-14ftrace: Rename config option HAVE_C_MCOUNT_RECORD to HAVE_C_RECORDMCOUNTSteven Rostedt
The config option used by archs to let the build system know that the C version of the recordmcount works for said arch is currently called HAVE_C_MCOUNT_RECORD which enables BUILD_C_RECORDMCOUNT. To be more consistent with the name that all archs may use, it has been renamed to HAVE_C_RECORDMCOUNT. This will be less confusing since we are building a C recordmcount and not a mcount_record. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: <linux-arch@vger.kernel.org> Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: John Reiser <jreiser@bitwagon.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-14Linux 2.6.36-rc8v2.6.36-rc8Linus Torvalds
2010-10-14ftrace/x86: Add support for C version of recordmcountSteven Rostedt
This patch adds the support for the C version of recordmcount and compile times show ~ 12% improvement. After verifying this works, other archs can add: HAVE_C_MCOUNT_RECORD in its Kconfig and it will use the C version of recordmcount instead of the perl version. Cc: <linux-arch@vger.kernel.org> Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: John Reiser <jreiser@bitwagon.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-08Merge commit 'v2.6.36-rc7' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/module.c Merge reason: Resolve the conflict, pick up fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-06Linux 2.6.36-rc7v2.6.36-rc7Linus Torvalds
2010-09-28Linux 2.6.36-rc6v2.6.36-rc6Linus Torvalds
2010-09-24Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-09-22jump label: Base patch for jump labelJason Baron
base patch to implement 'jump labeling'. Based on a new 'asm goto' inline assembly gcc mechanism, we can now branch to labels from an 'asm goto' statment. This allows us to create a 'no-op' fastpath, which can subsequently be patched with a jump to the slowpath code. This is useful for code which might be rarely used, but which we'd like to be able to call, if needed. Tracepoints are the current usecase that these are being implemented for. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <ee8b3595967989fdaf84e698dc7447d315ce972a.1284733808.git.jbaron@redhat.com> [ cleaned up some formating ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-09-20Linux 2.6.36-rc5v2.6.36-rc5Linus Torvalds
2010-09-13Merge branch 'kbuild/clean' into kbuild/kbuildMichal Marek
2010-09-12Linux 2.6.36-rc4v2.6.36-rc4Linus Torvalds
2010-09-06kbuild: Use a single clean rule for kernel and external modulesMichal Marek
The list of patterns for the external modules case was constantly lagging behind. Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-09-03kbuild: Do not run make clean in $(srctree)Michal Marek
2010-09-02ARM: 6312/1: ftrace: allow building without frame pointersRabin Vincent
With current gcc, compiling with both -pg and -fomit-frame-pointer is not allowed. However, -pg can be used to build without actually specifying -fno-omit-frame-pointer, upon which the default behaviour for the target will be used. On ARM, it is not possible to build a Thumb-2 kernel with -fno-omit-frame-pointer (FRAME_POINTERS depends on !THUMB2_KERNEL). In order to support ftrace for Thumb-2, we need to be able to allow a combination of FUNCTION_TRACER and !FRAME_POINTER. We do this by omitting -fomit-frame-pointer if ftrace is enabled. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-29Linux 2.6.36-rc3v2.6.36-rc3Linus Torvalds
2010-08-23Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: setlocalversion: Ignote SCMs above the linux source tree makefile: not need to regenerate kernel.release file when make kernelrelease fixes for using make 3.82 kconfig: fix segfault when detecting recursive dependency kconfig: fix savedefconfig with choice marked optional
2010-08-22Linux 2.6.36-rc2v2.6.36-rc2Linus Torvalds
2010-08-20makefile: not need to regenerate kernel.release file when make kernelreleaseAmerigo Wang
Brice reported that 'kernelrelease' has a dependence on include/config/kernel.release, causes this file to be regenerated every time when invoke it. It doesn't have to. Reported-by: Brice Goglin <Brice.Goglin@inria.fr> Tested-by: Brice Goglin <Brice.Goglin@inria.fr> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-15Linux 2.6.36-rc1v2.6.36-rc1Linus Torvalds
2010-08-13Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: setlocalversion: fix version for untaged nontip mercurial revs Fix CONFIG_CROSS_COMPILE issue in .config
2010-08-10Fix CONFIG_CROSS_COMPILE issue in .configYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-05Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: scripts/dtc: Fix a resource leak Documentation: fix ubuntu distro name MAINTAINERS: Update kbuild git URLs Add support for the C variable in the coccicheck script Add scripts/coccinelle/deref_null.cocci Add scripts/coccinelle/err_cast.cocci Add scripts/coccinelle/resource_size.cocci Add scripts/coccinelle/alloc/kzalloc-simple.cocci Add scripts/coccinelle/alloc/drop_kmalloc_cast.cocci Add Documentation/coccinelle.txt Add a target to use the Coccinelle checker scripts: decodecode: remove bashisms Makefile: clarify a comment checkkconfigsymbols.sh: Kconfig symbols sometimes have lowercase letters scripts: add nconf into gitignore file
2010-08-04Merge commit 'v2.6.35' into kbuild/kbuildMichal Marek
Conflicts: arch/powerpc/Makefile
2010-08-03kbuild: allow assignment to {A,C}FLAGS_KERNEL on the command lineSam Ravnborg
It is now possible to assign options to AS and CC on the command line - which is only used for built-in code. {A,C}FLAGS_KERNEL was used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC without overriding the original value. Introduce a new set of variables KBUILD_{A,C}FLAGS_KERNEL that is used by arch specific files and free up {A,C}FLAGS_KERNEL so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-03kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command lineSam Ravnborg
It is now possible to assign options to AS, CC and LD on the command line - which is only used when building modules. {A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC, LD when building modules without overriding the original value. Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE that is used by arch specific files and free up {A,C,LD}FLAGS_MODULE so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Note: Previously we had a MODFLAGS variable for both AS and CC. But in favour of consistency this was dropped. So in some cases arch Makefile has one assignmnet replaced by two assignmnets. Note2: MODFLAGS was not documented and is dropped without any notice. I do not expect much/any breakage from this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-02Merge commit 'v2.6.35' into perf/coreIngo Molnar
Conflicts: tools/perf/Makefile tools/perf/util/hist.c Merge reason: Resolve the conflicts and update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-01Linux 2.6.35v2.6.35Linus Torvalds
2010-07-22Linux 2.6.35-rc6v2.6.35-rc6Linus Torvalds
2010-07-21Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: Pick up the latest perf fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-14Kbuild: Add option to set -femit-struct-debug-baseonlyAndi Kleen
Newer gcc has a -femit-struct-debug-baseonly option that dramatically reduces the size of object files with debug info. What it does is to only emit type information for structures when the structures are defined in the same file or in a header file. This means the type information for most headers are not included. This is not good when the type information is actually needed (e.g. with kgdb or systemtap) But often kernel hackers only care about line numbers and don't need all the type information anyways. In this case setting the option can be a big win: A build dir for a specific x86-64 configuration with gcc 4.5 shrunk from 2.3G to 1.2G. The compilation was also nearly a minute faster. Signed-off-by: Andi Kleen <ak@linux.intel.com> [mmarek: reformatted help text] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-07-12Linux 2.6.35-rc5v2.6.35-rc5Linus Torvalds
2010-07-06kbuild: Fix path to scripts/setlocalversionMichal Marek
Commit 0a564b2 broke LOCALVERSION for O=... builds. Ouch. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-and-tested-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Peter Anvin <hpa@zytor.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-05Merge commit 'v2.6.35-rc4' into perf/coreIngo Molnar
Merge reason: Pick up the latest perf fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-04Linux 2.6.35-rc4v2.6.35-rc4Linus Torvalds
2010-07-04Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Propagate LOCALVERSION= down to scripts/setlocalversion kbuild: Clean up and speed up the localversion logic
