With a sufficiently new compiler and binutils, code which wasn't
previously generating .eh_frame sections has begun to. Certain
architectures (powerpc, in this case) may generate unexpected relocation
formats in response to this, preventing modules from loading.
While the new relocation types should probably be handled, revert to the
previous behaviour with regards to generation of .eh_frame sections.
(This was reported against Fedora, which appears to be the only distro
doing any building against gcc-4.4 at present: RH bz#486545.)
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Acked-by: Roland McGrath <roland@redhat.com>
Cc: Alexandre Oliva <aoliva@redhat.com>
Sam Ravnborg says:
"We have several architectures that plays strange games with $(CC) and
$(CROSS_COMPILE).
So we need to postpone any use of $(call cc-option..) until we have
included the arch specific Makefile so we try with the correct $(CC)
version."
Requested-by: Sam Ravnborg <sam@ravnborg.org>
This makes sure that gcc doesn't try to optimize away wrapping
arithmetic, which the kernel occasionally uses for overflow testing, ie
things like
if (ptr + offset < ptr)
which technically is undefined for non-unsigned types. See
http://bugzilla.kernel.org/show_bug.cgi?id=12597
for details.
Not all versions of gcc support it, so we need to make it conditional
(it looks like it was introduced in gcc-3.4).
Reminded-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Following a thread on busybox mailing list
depmod -r option is ignored by module-init-tools depmod
-r option break busybox depmod.
So the best solution look to remove -r from kernel Makefile
Signed-off-by: Gilles Espinasse <g.esp@free.fr>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Running 'make rpm' fails when CONFIG_LOCALVERSION_AUTO=y and using a kernel source
tree under SCM. This is due to KERNELRELEASE being different when the initial make
is run and when make is run from rpmbuild.
mkspec creates kernel.spec using KERNELRELEASE:
<mkspec>
echo "%files"
echo '%defattr (-, root, root)'
echo "%dir /lib/modules"
echo "/lib/modules/$KERNELRELEASE"
echo "/lib/firmware"
echo "/boot/*"
echo ""
</mkspec>
When CONFIG_LOCALVERSION_AUTO=y scripts/setlocalversion is called and grabs any
additional version info from SCM. Next, the srctree is tarred up and SCM
information is excluded.
rpmbuild reruns make and in the process generates a new include/config/kernel.release
and thus a new KERNELRELEASE. However this time the SCM information is gone so
KERNELRELEASE no longer has the additional version information. When "make modules_install"
runs, it uses the new KERNELRELEASE value to determine where to install the modules.
This conflicts with where the spec file assumes they are going because of the
mis-matching KERNELRELEASE versions.
<snippet>
+ INSTALL_MOD_PATH=/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root
+ make -j16 modules_install
INSTALL crypto/aead.ko
INSTALL crypto/cbc.ko
INSTALL crypto/chainiv.ko
INSTALL crypto/crc32c.ko
INSTALL crypto/crypto_algapi.ko
INSTALL crypto/crypto_blkcipher.ko
INSTALL crypto/crypto_hash.ko
INSTALL crypto/cryptomgr.ko
INSTALL crypto/ecb.ko
INSTALL crypto/eseqiv.ko
INSTALL crypto/krng.ko
INSTALL crypto/md5.ko
INSTALL crypto/pcbc.ko
INSTALL crypto/rng.ko
INSTALL drivers/block/cciss.ko
INSTALL drivers/hid/hid-dummy.ko
INSTALL drivers/scsi/iscsi_tcp.ko
INSTALL drivers/scsi/libiscsi.ko
INSTALL drivers/scsi/libiscsi_tcp.ko
INSTALL drivers/scsi/scsi_transport_iscsi.ko
INSTALL drivers/scsi/scsi_wait_scan.ko
INSTALL fs/lockd/lockd.ko
INSTALL fs/nfs/nfs.ko
INSTALL fs/nfsd/nfsd.ko
INSTALL lib/libcrc32c.ko
INSTALL net/sunrpc/sunrpc.ko
DEPMOD 2.6.29-rc4-tip
+ cp arch/x86/boot/bzImage
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/vmlinuz-2.6.29-rc4-tip-01479-g5d85422
+ cp System.map
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/System.map-2.6.29-rc4-tip-01479-g5d85422
+ cp .config
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/config-2.6.29-rc4-tip-01479-g5d85422
+ cp vmlinux vmlinux.orig
+ bzip2 -9 vmlinux
+ mv vmlinux.bz2
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/vmlinux-2.6.29-rc4-tip-01479-g5d85422.bz2
+ mv vmlinux.orig vmlinux
+ /usr/lib/rpm/brp-compress
Processing files: kernel-2.6.29rc4tip01479g5d85422-2
error: File not found:
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/lib/modules/2.6.29-rc4-tip-01479-g5d85422
RPM build errors:
File not found:
make[1]: *** [rpm] Error 1
make: *** [rpm] Error 2
</snippet>
I have tested this patch on git -tip, Linus' git tree, and the kernel.org tar files, both
with and without CONFIG_LOCALVERSION_AUTO=y.
Signed-off-by: Josh Hunt <josh@scalex86.org>
It's useful to already have the source symlink in a
objdir when one just runs make *config. Then one
can do
mkdir obj-allyes
cd obj-allyes
make -C ../sourcedir O=$(pwd) allyesconfig
./source/scripts/config --disable debug_info
make CC=icecc -j18
without having to interrupt the make first just to
get the source symlink.
[sam: deleted the other source symlink statement]
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
kbuild: fix kbuild.txt typos
kbuild: print usage with no arguments in scripts/config
Revert "kbuild: strip generated symbols from *.ko"
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k,m68knommu: merge header files
Resolve trivial conflict in arch/m68knommu/include/asm/Kbuild
Merge header files for m68k and m68knommu to the single location:
arch/m68k/include/asm
The majority of this patch was the result of the
script that is included in the changelog below.
The script was originally written by Arnd Bergman and
exten by me to cover a few more files.
When the header files differed the script uses the following:
The original m68k file is named <file>_mm.h [mm for memory manager]
The m68knommu file is named <file>_no.h [no for no memory manager]
The files uses the following include guard:
This include gaurd works as the m68knommu toolchain set
the __uClinux__ symbol - so this should work in userspace too.
Merging the header files for m68k and m68knommu exposes the
(unexpected?) ABI differences thus it is easier to actually
identify these and thus to fix them.
The commit has been build tested with both a m68k and
a m68knommu toolchain - with success.
The commit has also been tested with "make headers_check"
and this patch fixes make headers_check for m68knommu.
The script used:
TARGET=arch/m68k/include/asm
SOURCE=arch/m68knommu/include/asm
INCLUDE="cachectl.h errno.h fcntl.h hwtest.h ioctls.h ipcbuf.h \
linkage.h math-emu.h md.h mman.h movs.h msgbuf.h openprom.h \
oplib.h poll.h posix_types.h resource.h rtc.h sembuf.h shmbuf.h \
shm.h shmparam.h socket.h sockios.h spinlock.h statfs.h stat.h \
termbits.h termios.h tlb.h types.h user.h"
EQUAL="auxvec.h cputime.h device.h emergency-restart.h futex.h \
ioctl.h irq_regs.h kdebug.h local.h mutex.h percpu.h \
sections.h topology.h"
NOMUUFILES="anchor.h bootstd.h coldfire.h commproc.h dbg.h \
elia.h flat.h m5206sim.h m520xsim.h m523xsim.h m5249sim.h \
m5272sim.h m527xsim.h m528xsim.h m5307sim.h m532xsim.h \
m5407sim.h m68360_enet.h m68360.h m68360_pram.h m68360_quicc.h \
m68360_regs.h MC68328.h MC68332.h MC68EZ328.h MC68VZ328.h \
mcfcache.h mcfdma.h mcfmbus.h mcfne.h mcfpci.h mcfpit.h \
mcfsim.h mcfsmc.h mcftimer.h mcfuart.h mcfwdebug.h \
nettel.h quicc_simple.h smp.h"
FILES="atomic.h bitops.h bootinfo.h bug.h bugs.h byteorder.h cache.h \
cacheflush.h checksum.h current.h delay.h div64.h \
dma-mapping.h dma.h elf.h entry.h fb.h fpu.h hardirq.h hw_irq.h io.h \
irq.h kmap_types.h machdep.h mc146818rtc.h mmu.h mmu_context.h \
module.h page.h page_offset.h param.h pci.h pgalloc.h \
pgtable.h processor.h ptrace.h scatterlist.h segment.h \
setup.h sigcontext.h siginfo.h signal.h string.h system.h swab.h \
thread_info.h timex.h tlbflush.h traps.h uaccess.h ucontext.h \
unaligned.h unistd.h"
mergefile() {
BASE=${1%.h}
git mv ${SOURCE}/$1 ${TARGET}/${BASE}_no.h
git mv ${TARGET}/$1 ${TARGET}/${BASE}_mm.h
cat << EOF > ${TARGET}/$1
EOF
git add ${TARGET}/$1
set -e
mkdir -p ${TARGET}
git mv include/asm-m68k/* ${TARGET}
rmdir include/asm-m68k
git rm ${SOURCE}/Kbuild
for F in $INCLUDE $EQUAL; do
git rm ${SOURCE}/$F
done
for F in $NOMUUFILES; do
git mv ${SOURCE}/$F ${TARGET}/$F
done
for F in $FILES ; do
mergefile $F
done
rmdir arch/m68knommu/include/asm
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483.
And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL")
9bb482476c6c9d1ae033306440c51ceac93ea80c
These stripping patches has caused a set of issues:
1) People have reported compatibility issues with binutils due to
lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2
Reported by: Wenji
2) ccache and distcc no longer works as expeced
Reported by: Ted, Roland, + others
3) The installed modules increased a lot in size
Reported by: Ted, Davej + others
Reported-by: Wenji Huang <wenji.huang@oracle.com>
Reported-by: "Theodore Ts'o" <tytso@mit.edu>
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Roland McGrath <roland@redhat.com>
kbuild: fix typos (s/bin_shipped/bin.o_shipped/) in Documentation
kbuild: add a symlink to the source for separate objdirs
kconfig: add script to manipulate .config files on the command line
kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscope
bootchart: improve output based on Dave Jones' feedback
fix modules_install via NFS
qnx: include <linux/types.h> for definitions of __[us]{8,16,32,64} types
I have some scripts which need to map back to the source directory
from an objdir. This was so far done by parsing the Makefile,
but the Makefile format changes occasionally and breaks my scripts
then.
To make this more reliable add a "source" symlink back.
Trivial one letter spelling in main Makefile
Signed-off-by: Anisse Astier <anisse@astier.eu>
The sparse warning -Wreturn-void ("returning void-valued expression")
is off by default, but it is enabled with -Wall, so add
-Wno-return-void to CHECKFLAGS to disable it.
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
arch/sparc64/kernel/idprom.c
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (25 commits)
kbuild: simplify use of genksyms
kernel-doc: check for extra kernel-doc notations
kbuild: add headerdep used to detect inclusion cycles in header files
kbuild: fix string equality testing in tags.sh
kbuild: fix make tags/cscope
kbuild: fix make incompatibility
kbuild: remove TAR_IGNORE
setlocalversion: add git-svn support
setlocalversion: print correct subversion revision
scripts: improve the decodecode script
scripts/package: allow custom options to rpm
genksyms: allow to ignore symbol checksum changes
genksyms: track symbol checksum changes
tags and cscope support really belongs in a shell script
kconfig: fix options to check-lxdialog.sh
kbuild: gen_init_cpio expands shell variables in file names
remove bashisms from scripts/extract-ikconfig
kbuild: teach mkmakfile to be silent
Happy holidays..
Building upon parts of the module stripping patch, this patch
introduces similar stripping for vmlinux when CONFIG_KALLSYMS_ALL=y.
Using CONFIG_KALLSYMS_STRIP_GENERATED reduces the overhead of
CONFIG_KALLSYMS_ALL from 245k/310k to 65k/80k for the (i386/x86-64)
kernels I tested with.
The patch also does away with the need to special case the kallsyms-
internal symbols by making them available even in the first linking
stage.
While it is a generated file, the patch includes the changes to
scripts/genksyms/keywords.c_shipped, as I'm unsure what the procedure
here is.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
This patch changes the way __crc_ symbols are being resolved from
using ld to do so to using the assembler, thus allowing these symbols
to be marked local (the linker creates then as global ones) and hence
allow stripping (for modules) or ignoring (for vmlinux) them. While at
this, also strip other generated symbols during module installation.
One potentially debatable point is the handling of the flags passeed
to gcc when translating the intermediate assembly file into an object:
passing $(c_flags) unchanged doesn't work as gcc passes --gdwarf2 to
gas whenever is sees any -g* option, even for -g0, and despite the
fact that the compiler would have already produced all necessary debug
info in the C->assembly translation phase. I took the approach of just
filtering out all -g* options, but an alternative to such negative
filtering might be to have a positive filter which might, in the ideal
case allow just all the -Wa,* options to pass through.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
"Paul Smith" <psmith@gnu.org> reported that we would fail
to build with a new check that may be enabled in an
upcoming version of make.
The error was:
Makefile:442: *** mixed implicit and normal rules. Stop.
The problem is that we did stuff like this:
config %config: ...
The solution was simple - the above was split into two with identical
prerequisites and commands.
With only three lines it was not worth to try to avoid the duplication.
Cc: "Paul Smith" <psmith@gnu.org>
To unify Makefile for sparc and sparc64 a few other steps was needed:
1) separate defconfig files for sparc and sparc64 is required,
so locate these in arch/sparc/configs
2) removoval of hack in toplevel Makefile to deal with that
headers was in a separate directory compared to the rest
The unification of the Makefile required usage of several
foo-$(CONFIG_SPARCnn) +=
due to a few directories pending unification.
This will be cleaned up when we unify the remaining directories.
Included in this patch are the deletion of a few files in
sparc64 as they are no longer needed: Makefile + Kconfig.
arch/sparc64/ will after this patch is applied only
have four directories (prom, lib, kernel, boot)
as they do not benefit from the make functionality.
Moving the support to a shell script has several benefits:
- The readability of the code has increased a lot
- More people is able to extend the tags support
- We see less changes to the top-level Makefile
The shell script version includes improvements from:
Alexey Dobriyan <adobriyan@gmail.com> (jump to kconfig symbols)
Alexey Dobriyan <adobriyan@gmail.com> (drop ./ in paths)
Ian Campbell <ijc@hellion.org.uk> (simplified find algorithms)
This version has a few caveats:
=> It does not support ALLSOURCE_ARCHS
- it is easy to add if it is really used
=> It assumes all archs have moved to arch/$ARCH/include
- until that happens we have a few additional hits in the archs
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Tested-by: Ian Campbell <ijc@hellion.org.uk>
Convert a few echos in the build system to new $(kecho) so we get correct
output according to build verbosity.
[sam: added kecho in a few more places for O=... builds]
kbuild failed to expand include flags in KBUILD_CPPFLAGS
resulting in code like this in arch Makefiles:
ifeq ($(KBUILD_SRC),)
KBUILD_CPPFLAGS += -Iinclude/foo
else
KBUILD_CPPFLAGS += -I$(srctree)/include/foo
endif
Move use of LINUXINCLUDE into Makefile.lib to allow
us to expand -I directives of KBUILD_CPPFLAGS so
we can avoid the above code.
Architectures which have moved their includes to arch/<ARCH>/include
now list the headers twice in the source listing used by "make
cscope" and friends, causing those tools to list symbols twice.
Skipping these files in the ALLSOURCE_ARCHS pass rather than removing
the ALLINCLUDE_ARCHS pass preserves the semantics of the later.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
o if include/asm point to a nonexisting directory remove the asm symlink
o if include/asm is a directory error out
This fixes a situation where one could be left with a symlink
to asm-x86 but that directory no longer exist and thus the build
would error out.
include/asm may be a directory if the kernel tree has been copied
.. fix all the worst problems in -rc1
