Since commit 066b7ed9558087a7957a1128f27d7a3462ff117f
(kbuild: Do not print the build directory with make -s),
"Q" is defined above the sub-make target.
This commit takes advantage of that and replaces
"$(if $(KBUILD_VERBOSE:1=),@)" with "$(Q)".
Acked-by: Peter Foley <pefoley2@pefoley.com>
Commit c2e28dc975ea87feed84415006ae143424912ac7
(kbuild: Print the name of the build directory)
added a gimmick to show the "Entering directory ...".
Instead of echoing the hard-coded message (that is, we need to know
the exact message), moving --no-print-directory would be easier.
Cc: rdunlap@infradead.org
Cc: linux-doc@vger.kernel.org
Cc: sudeep.dutt@intel.com
Cc: nikhil.rao@intel.com
Cc: ashutosh.dixit@intel.com
Cc: akpm@linux-foundation.org
Cc: gregkh@linuxfoundation.org
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Since module-init-tools (gzip) and kmod (gzip and xz) support compressed
modules, it could be useful to include a support for compressing modules
right after having them installed. Doing this in kbuild instead of per
distro can permit to make this kind of usage more generic.
This patch add a Kconfig entry to "Enable loadable module support" menu
and let you choose to compress using gzip (default) or xz.
Both gzip and xz does not used any extra -[1-9] option since Andi Kleen
and Rusty Russell prove no gain is made using them. gzip is called with -n
argument to avoid storing original filename inside compressed file, that
way we can save some more bytes.
On a v3.16 kernel, 'make allmodconfig' generated 4680 modules for a
total of 378MB (no strip, no sign, no compress), the following table
shows observed disk space gain based on the allmodconfig .config :
| time |
| manual .ko | make | size | percent
| compression | modules_install | | gain
- | | 18.61s | 378M |
GZIP | 3m16s | 3m37s | 102M | 73.41%
XZ | 5m22s | 5m39s | 77M | 79.83%
The gain for restricted environnement seems to be interesting while
uncompress can be time consuming but happens only while loading a module,
that is generally done only once.
This is fully compatible with signed modules while the signed module is
compressed. module-init-tools or kmod handles decompression
and provide to other layer the uncompressed but signed payload.
Reviewed-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Bertrand Jacquin <beber@meleeweb.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild updates from Michal Marek:
"This is the non-critical part of kbuild for 3.17-rc1:
- make help hint to use make -s with make kernelrelease et al.
- moved a kbuild document to Documentation/kbuild where it belongs
- four new Coccinelle scripts, one dropped and one fixed
- new make kselftest target to run various tests on the kernel"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: kselftest - new make target to build and run kernel selftests
Coccinelle: Script to replace if and BUG with BUG_ON
Coccinelle: Script to detect incorrect argument to sizeof
Coccinelle: Script to use ARRAY_SIZE instead of division of two sizeofs
Coccinelle: Script to detect cast after memory allocation
coccinelle/null: solve parse error
Documentation: headers_install.txt is part of kbuild
kbuild: make -s should be used with kernelrelease/kernelversion/image_name
Pull kbuild updates from Michal Marek:
- make clean also considers $(extra-m) and $(extra-) to be consistent
- cleanup and fixes in scripts/Makefile.host
- allow to override the name of the Python 2 executable with make
PYTHON=... (only needed for ia64 in practice)
- option to split debugingo into *.dwo files to save disk space if the
compiler supports it (CONFIG_DEBUG_INFO_SPLIT)
- option to use dwarf4 debuginfo if the compiler supports it
(CONFIG_DEBUG_INFO_DWARF4)
- fix for disabling certain warnings with clang
- fix for unneeded rebuild with dash when a command contains
backslashes
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: Fix handling of backslashes in *.cmd files
kbuild, LLVMLinux: Supress warnings unless W=1-3
Kbuild: Add a option to enable dwarf4 v2
kbuild: Support split debug info v4
kbuild: allow to override Python command name
kbuild: clean-up and bug fix of scripts/Makefile.host
kbuild: clean up scripts/Makefile.host
kbuild: drop shared library support from Makefile.host
kbuild: fix a bug of C++ host program handling
kbuild: fix a typo in scripts/Makefile.host
scripts/Makefile.clean: clean also $(extra-m) and $(extra-)
Add a new make target "kselftest" to enable kernel testing. This
new target builds and runs kernel selftests. Running as root is
recommended for a complete test run as some tests don't run when
run by non-root user. Build, install, and boot kernel before
running kselftest on it.
Signed-off-by: Shuah Khan <shuah.kh@samsung.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
We have been chasing a memory corruption bug, which turned out to be
caused by very old gcc (4.3.4), which happily turned conditional load
into a non-conditional one, and that broke correctness (the condition
was met only if lock was held) and corrupted memory.
This particular problem with that particular code did not happen when
never gccs were used. I've brought this up with our gcc folks, as I
wanted to make sure that this can't really happen again, and it turns
out it actually can.
Quoting Martin Jambor <mjambor@suse.cz>:
"More current GCCs are more careful when it comes to replacing a
conditional load with a non-conditional one, most notably they check
that a store happens in each iteration of _a_ loop but they assume
loops are executed. They also perform a simple check whether the
store cannot trap which currently passes only for non-const
variables. A simple testcase demonstrating it on an x86_64 is for
example the following:
$ cat cond_store.c
int g_1 = 1;
int g_2[1024] __attribute__((section ("safe_section"), aligned (4096)));
int c = 4;
int __attribute__ ((noinline))
foo (void)
int l;
for (l = 0; (l != 4); l++) {
if (g_1)
return l;
for (g_2[0] = 0; (g_2[0] >= 26); ++g_2[0])
return 2;
int main (int argc, char* argv[])
if (mprotect (g_2, sizeof(g_2), PROT_READ) == -1)
int e = errno;
error (e, e, "mprotect error %i", e);
foo ();
__builtin_printf("OK\n");
return 0;
/* EOF */
$ ~/gcc/trunk/inst/bin/gcc cond_store.c -O2 --param allow-store-data-races=0
$ ./a.out
OK
$ ~/gcc/trunk/inst/bin/gcc cond_store.c -O2 --param allow-store-data-races=1
$ ./a.out
Segmentation fault
The testcase fails the same at least with 4.9, 4.8 and 4.7. Therefore
I would suggest building kernels with this parameter set to zero. I
also agree with Jikos that the default should be changed for -O2. I
have run most of the SPEC 2k6 CPU benchmarks (gamess and dealII
failed, at -O2, not sure why) compiled with and without this option
and did not see any real difference between respective run-times"
Hopefully the default will be changed in newer gccs, but let's force it
for kernel builds so that we are on a safe side even when older gcc are
used.
The code in question was out-of-tree printk-in-NMI (yeah, surprise
suprise, once again) patch written by Petr Mladek, let me quote his
comment from our internal bugzilla:
"I have spent few days investigating inconsistent state of kernel ring buffer.
It went out that it was caused by speculative store generated by
gcc-4.3.4.
The problem is in assembly generated for make_free_space(). The functions is
called the following way:
+ vprintk_emit();
+ log = MAIN_LOG; // with logbuf_lock
or
log = NMI_LOG; // with nmi_logbuf_lock
cont_add(log, ...);
+ cont_flush(log, ...);
+ log_store(log, ...);
+ log_make_free_space(log, ...);
If called with log = NMI_LOG then only nmi_log_* global variables are safe to
modify but the generated code does store also into (main_)log_* global
variables:
<log_make_free_space>:
55 push %rbp
89 f6 mov %esi,%esi
48 8b 05 03 99 51 01 mov 0x1519903(%rip),%rax # ffffffff82620868 <nmi_log_next_id>
44 8b 1d ec 98 51 01 mov 0x15198ec(%rip),%r11d # ffffffff82620858 <log_next_idx>
8b 35 36 60 14 01 mov 0x1146036(%rip),%esi # ffffffff8224cfa8 <log_buf_len>
44 8b 35 33 60 14 01 mov 0x1146033(%rip),%r14d # ffffffff8224cfac <nmi_log_buf_len>
4c 8b 2d d0 98 51 01 mov 0x15198d0(%rip),%r13 # ffffffff82620850 <log_next_seq>
4c 8b 25 11 61 14 01 mov 0x1146111(%rip),%r12 # ffffffff8224d098 <log_buf>
49 89 c2 mov %rax,%r10
48 21 c2 and %rax,%rdx
48 8b 1d 0c 99 55 01 mov 0x155990c(%rip),%rbx # ffffffff826608a0 <nmi_log_buf>
49 c1 ea 20 shr $0x20,%r10
48 89 55 d0 mov %rdx,-0x30(%rbp)
44 29 de sub %r11d,%esi
45 29 d6 sub %r10d,%r14d
4c 8b 0d 97 98 51 01 mov 0x1519897(%rip),%r9 # ffffffff82620840 <log_first_seq>
eb 7e jmp ffffffff81107029 <log_make_free_space+0xe9>
85 ff test %edi,%edi # edi = 1 for NMI_LOG
4c 89 e8 mov %r13,%rax
4c 89 ca mov %r9,%rdx
74 0a je ffffffff8110703d <log_make_free_space+0xfd>
8b 15 27 98 51 01 mov 0x1519827(%rip),%edx # ffffffff82620860 <nmi_log_first_id>
48 8b 45 d0 mov -0x30(%rbp),%rax
48 39 c2 cmp %rax,%rdx # end of loop
0f 84 da 00 00 00 je ffffffff81107120 <log_make_free_space+0x1e0>
4c 89 0d 17 97 51 01 mov %r9,0x1519717(%rip) # ffffffff82620840 <log_first_seq>
KABOOOM
74 35 je ffffffff81107160 <log_make_free_space+0x220>
It stores log_first_seq when edi == NMI_LOG. This instructions are used also
when edi == MAIN_LOG but the store is done speculatively before the condition
is decided. It is unsafe because we do not have "logbuf_lock" in NMI context
and some other process migh modify "log_first_seq" in parallel"
I believe that the best course of action is both
- building kernel (and anything multi-threaded, I guess) with that
optimization turned off
- persuade gcc folks to change the default for future releases
Cc: Martin Jambor <mjambor@suse.cz>
Cc: Petr Mladek <pmladek@suse.cz>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Marek Polacek <polacek@redhat.com>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Steven Noonan <steven@uplinklabs.net>
Cc: Richard Biener <richard.guenther@gmail.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
This adds a hopefully helpful comment above the (seemingly weird) compiler
flag selection logic.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Michal Marek <mmarek@suse.cz>
clang has more warnings enabled by default. Turn them off unless W is
set. This patch fixes a logic bug where warnings in clang were disabled
when W was set.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
Cc: bp@alien8.de
I found that a lot of unresolvable variables when using gdb on the
kernel become resolvable when dwarf4 is enabled. So add a Kconfig flag
to enable it.
It definitely increases the debug information size, but on the other
hand this isn't so bad when debug fusion is used.
v2: Use cc-option
This is an alternative approach to lower the overhead of debug info
(as we discussed a few days ago)
gcc 4.7+ and newer binutils have a new "split debug info" debug info
model where the debug info is only written once into central ".dwo" files.
This avoids having to copy it around multiple times, from the object
files to the final executable. It lowers the disk space
requirements. In addition it defaults to compressed debug data.
More details here: http://gcc.gnu.org/wiki/DebugFission
This patch adds a new option to enable it. It has to be an option,
because it'll undoubtedly break everyone's debuginfo packaging scheme.
gdb/objdump/etc. all still work, if you have new enough versions.
I don't see big compile wins (maybe a second or two faster or so), but the
object dirs with debuginfo get significantly smaller. My standard kernel
config (slightly bigger than defconfig) shrinks from 2.9G disk space
to 1.1G objdir (with non reduced debuginfo). I presume if you are IO limited
the compile time difference will be larger.
Only problem I've seen so far is that it doesn't play well with older
versions of ccache (apparently fixed, see
https://bugzilla.samba.org/show_bug.cgi?id=10005)
v2: various fixes from Dirk Gouders. Improve commit message slightly.
v3: Fix clean rules and improve Kconfig slightly
v4: Fix merge error in last version (Sam Ravnborg)
Clarify description that it mainly helps disk size.
Cc: Dirk Gouders <dirk@gouders.net>
Michel Dänzer and a couple of other people reported inexplicable random
oopses in the scheduler, and the cause turns out to be gcc mis-compiling
the load_balance() function when debugging is enabled. The gcc bug
apparently goes back to gcc-4.5, but slight optimization changes means
that it now showed up as a problem in 4.9.0 and 4.9.1.
The instruction scheduling problem causes gcc to schedule a spill
operation to before the stack frame has been created, which in turn can
corrupt the spilled value if an interrupt comes in. There may be other
effects of this bug too, but that's the code generation problem seen in
Michel's case.
This is fixed in current gcc HEAD, but the workaround as suggested by
Markus Trippelsdorf is pretty simple: use -fno-var-tracking-assignments
when compiling the kernel, which disables the gcc code that causes the
problem. This can result in slightly worse debug information for
variable accesses, but that is infinitely preferable to actual code
generation problems.
Doing this unconditionally (not just for CONFIG_DEBUG_INFO) also allows
non-debug builds to verify that the debug build would be identical: we
can do
export GCC_COMPARE_DEBUG=1
to make gcc internally verify that the result of the build is
independent of the "-g" flag (it will make the compiler build everything
twice, toggling the debug flag, and compare the results).
Without the "-fno-var-tracking-assignments" option, the build would fail
(even with 4.8.3 that didn't show the actual stack frame bug) with a gcc
compare failure.
See also gcc bugzilla:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=61801
Reported-by: Michel Dänzer <michel@daenzer.net>
Suggested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: stable@kernel.org
The specification of Python 3 is largely different from that of
Python 2.
For example, arch/ia64/scripts/unwcheck.py seems to be written
in Python 2, not compatible with Python 3.
It is not a good idea to invoke python scripts with the hard-coded
command name 'python'. The command 'python' could possibly be
Python 3 on some systems.
For that case, it is reasonable to allow to override the command name
by giving 'PYTHON=python2' from the command line.
The 'python' in arch/ia64/Makefile should be replaced with '$(PYTHON)'.
Cc: linux-ia64@vger.kernel.org
If .config has been edited, there will be a silentoldconfig run:
$ make defconfig
$ make kernelrelease
scripts/kconfig/conf --silentoldconfig Kconfig
3.16.0-rc1+
Recently, kbuild started to print the name of the build directory when
using O=
$ make O=build kernelrelease
make[1]: Entering directory `/dev/shm/mmarek/linux-2.6/build'
3.16.0-rc1+
Since these targets are often used in scripts, add a hint to use make -s
to the help text.
Suggested-by: Russell King <linux@arm.linux.org.uk>
Pull kbuild fixes from Michal Marek:
"Three more fixes for the relative build dir feature:
- Shut up make -s again
- Fix for rpm/deb/tar-pkg with O=<subdir>
- Fix for CONFIG_EXTRA_FIRMWARE"
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
firmware: Create directories for external firmware
kbuild: Fix packaging targets with relative $(srctree)
All other users of Makefile.build set $(obj) to the name of the
subdirectory to build. Do the same for the packaging targets, otherwise
the build fails if $(srctree) is a relative directory:
$ make O=build tar-pkg
make[1]: Entering directory `/home/mmarek/linux-2.6/build'
CHK include/config/kernel.release
../scripts/Makefile.build:44: ../../scripts/package/Makefile: No such file or directory
make[2]: *** No rule to make target `../../scripts/package/Makefile'. Stop.
Fixes: 9da0763b ("kbuild: Use relative path when building in a subdir of the source tree")
Commit c2e28dc9 (kbuild: Print the name of the build directory) prints
the name of the build directory for O= builds, but we should not be
doing this in make -s mode, so that commands like
make -s O=<dir> kernelrelease
can be used by scripts. This matches the behavior of make itself, where
the -s option implies --no-print-directory.
Pull kbuild fix from Michal Marek:
"There is one more fix for the relative paths series from -rc1: Print
the path to the build directory at the start of the build, so that
editors and IDEs can match the relative paths to source files"
With commit 9da0763b (kbuild: Use relative path when building in a
subdir of the source tree), the compiler messages include relative
paths. These are however relative to the build directory, not the
directory where make was started. Print the "Entering directory ..."
message once, so that IDEs/editors can find the source files.
"Kbuild changes for v3.16-rc1:
- cross-compilation fix so that cc-option is testing the right
compiler
- Fix for make defconfig all
- Using relative paths to the object and source directory where
possible, plus fixes for the fallout of the change
- several cleanups in the Makefiles and scripts
The powerpc fix is from today, because it was only discovered
recently. The rest has been in linux-next for some time"
powerpc: Avoid circular dependency with zImage.%
kbuild: create include/config directory in scripts/kconfig/Makefile
kbuild: do not create include/linux directory
Makefile: Fix unrecognized cross-compiler command line options
kbuild: do not add "selinux" to subdir- twice
um: Fix for relative objtree when generating x86 headers
kbuild: Use relative path when building in the source tree
kbuild: Use relative path for $(objtree)
firmware: Use $(quote) in the Makefile
firmware: Simplify directory creation
kbuild: trivial - fix comment block indent
kbuild: trivial - remove trailing spaces
kbuild: support simultaneous "make %config" and "make all"
kbuild: move extra gcc checks to scripts/Makefile.extrawarn
The directory include/config is used only for
silentoldconfig, localmodconfig, localyesconfig.
There are no generated files under include/linux directory.
On architectures that setup CROSS_COMPILE in their arch/*/Makefile
(arc, blackfin, m68k, mips, parisc, score, sh, tile, unicore32, xtensa),
cc-option and cc-disable-warning may check against the wrong compiler,
causing errors like
cc1: error: unrecognized command line option "-Wno-maybe-uninitialized"
if the host gcc supports a compiler option, while the cross compiler
doesn't support that option.
Move all logic using cc-option or cc-disable-warning below the inclusion
of the arch's Makefile to fix this.
Introduced by
- commit e74fc973b6e531fef1fce8b101ffff05ecfb774c ("Turn off
-Wmaybe-uninitialized when building with -Os"),
- commit 61163efae02040f66a95c8ed17f4407951ba58fa ("kbuild: LLVMLinux:
Add Kbuild support for building kernel with Clang").
As -Wno-maybe-uninitialized requires a quite recent gcc (gcc 4.6.3 on
Ubuntu 12.04 LTS doesn't support it), this only showed up recently (gcc
4.8.2 on Ubuntu 14.04 LTS does support it).
git://git.linuxfoundation.org/llvmlinux/kernel
Pull LLVM patches from Behan Webster:
"Next set of patches to support compiling the kernel with clang.
They've been soaking in linux-next since the last merge window.
More still in the works for the next merge window..."
* tag 'llvmlinux-for-v3.16' of git://git.linuxfoundation.org/llvmlinux/kernel:
arm, unwind, LLVMLinux: Enable clang to be used for unwinding the stack
ARM: LLVMLinux: Change "extern inline" to "static inline" in glue-cache.h
all: LLVMLinux: Change DWARF flag to support gcc and clang
net: netfilter: LLVMLinux: vlais-netfilter
crypto: LLVMLinux: aligned-attribute.patch
Both gcc (well, actually gnu as) and clang support the "-Wa,-gdwarf-2" option
(though clang does not support "-Wa,--gdwarf-2"). Since these flags are equivalent
in meaning, this patch uses the one which is better supported across compilers.
When doing make O=<subdir>, use '..' to refer to the source tree. This
allows for more readable compiler messages, and, more importantly, it
sets the VPATH to '..', so filenames in WARN_ON() etc. will be shorter.
When not using O=, $(srctree) refers to the same directory as
$(objtree), so we can set it to '.' as well. This makes the default
include path more compact and results in more readable messages from the
compiler. The only case where we need the absolute path is when creating
the 'source' symlink in /lib/modules.
The main Makefile sets its working directory to the object tree and
never changes it again. Therefore, we can use '.' instead of the
absolute path. The only case where we need the absolute path is when
creating the 'build' symlink in /lib/modules.
