commit c87bf431448b404a6ef5fbabd74c0e3e42157a7f upstream.
Enabling CONFIG_GCOV_PROFILE_ALL produces us a lot of warnings like
lib/lz4/lz4hc_compress.c: In function 'lz4_compresshcctx':
lib/lz4/lz4hc_compress.c:514:1: warning: the frame size of 1504 bytes is larger than 1024 bytes [-Wframe-larger-than=]
After some investigation, I found that this behavior started with gcc-4.9,
and opened https://gcc.gnu.org/bugzilla/show_bug.cgi?id=69702.
A suggested workaround for it is to use the -fno-tree-loop-im
flag that turns off one of the optimization stages in gcc, so the
code runs a little slower but does not use excessive amounts
of stack.
We could make this conditional on the gcc version, but I could not
find an easy way to do this in Kbuild and the benefit would be
fairly small, given that most of the gcc version in production are
affected now.
I'm marking this for 'stable' backports because it addresses a bug
with code generation in gcc that exists in all kernel versions
with the affected gcc releases.
Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
commit c9c6837d39311b0cc14cdbe7c18e815ab44aefb1 upstream.
gcc-6 started warning by default about variables that are not
used anywhere and that are marked 'const', generating many
false positives in an allmodconfig build, e.g.:
arch/arm/mach-davinci/board-da830-evm.c:282:20: warning: 'da830_evm_emif25_pins' defined but not used [-Wunused-const-variable=]
arch/arm/plat-omap/dmtimer.c:958:34: warning: 'omap_timer_match' defined but not used [-Wunused-const-variable=]
drivers/bluetooth/hci_bcm.c:625:39: warning: 'acpi_bcm_default_gpios' defined but not used [-Wunused-const-variable=]
drivers/char/hw_random/omap-rng.c:92:18: warning: 'reg_map_omap4' defined but not used [-Wunused-const-variable=]
drivers/devfreq/exynos/exynos5_bus.c:381:32: warning: 'exynos5_busfreq_int_pm' defined but not used [-Wunused-const-variable=]
drivers/dma/mv_xor.c:1139:34: warning: 'mv_xor_dt_ids' defined but not used [-Wunused-const-variable=]
This is similar to the existing -Wunused-but-set-variable warning
that was added in an earlier release and that we disable by default
now and only enable when W=1 is set, so it makes sense to do
the same here. Once we have eliminated the majority of the
warnings for both, we can put them back into the default list.
We probably want this in backport kernels as well, to allow building
them with gcc-6 without introducing extra warnings.
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Lee Jones <lee.jones@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild update from Michal Marek:
"The kbuild branch for v4.4-rc1 only has one commit: A new make
kselftest-clean target cleans tools/testing/selftests"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kselftest: add kselftest-clean rule
Pull KVM updates from Paolo Bonzini:
"First batch of KVM changes for 4.4.
s390:
A bunch of fixes and optimizations for interrupt and time handling.
PPC:
Mostly bug fixes.
ARM:
No big features, but many small fixes and prerequisites including:
- a number of fixes for the arch-timer
- introducing proper level-triggered semantics for the arch-timers
- a series of patches to synchronously halt a guest (prerequisite
for IRQ forwarding)
- some tracepoint improvements
- a tweak for the EL2 panic handlers
- some more VGIC cleanups getting rid of redundant state
x86:
Quite a few changes:
- support for VT-d posted interrupts (i.e. PCI devices can inject
interrupts directly into vCPUs). This introduces a new
component (in virt/lib/) that connects VFIO and KVM together.
The same infrastructure will be used for ARM interrupt
forwarding as well.
- more Hyper-V features, though the main one Hyper-V synthetic
interrupt controller will have to wait for 4.5. These will let
KVM expose Hyper-V devices.
- nested virtualization now supports VPID (same as PCID but for
vCPUs) which makes it quite a bit faster
- for future hardware that supports NVDIMM, there is support for
clflushopt, clwb, pcommit
- support for "split irqchip", i.e. LAPIC in kernel +
IOAPIC/PIC/PIT in userspace, which reduces the attack surface of
the hypervisor
- obligatory smattering of SMM fixes
- on the guest side, stable scheduler clock support was rewritten
to not require help from the hypervisor"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (123 commits)
KVM: VMX: Fix commit which broke PML
KVM: x86: obey KVM_X86_QUIRK_CD_NW_CLEARED in kvm_set_cr0()
KVM: x86: allow RSM from 64-bit mode
KVM: VMX: fix SMEP and SMAP without EPT
KVM: x86: move kvm_set_irq_inatomic to legacy device assignment
KVM: device assignment: remove pointless #ifdefs
KVM: x86: merge kvm_arch_set_irq with kvm_set_msi_inatomic
KVM: x86: zero apic_arb_prio on reset
drivers/hv: share Hyper-V SynIC constants with userspace
KVM: x86: handle SMBASE as physical address in RSM
KVM: x86: add read_phys to x86_emulate_ops
KVM: x86: removing unused variable
KVM: don't pointlessly leave KVM_COMPAT=y in non-KVM configs
KVM: arm/arm64: Merge vgic_set_lr() and vgic_sync_lr_elrsr()
KVM: arm/arm64: Clean up vgic_retire_lr() and surroundings
KVM: arm/arm64: Optimize away redundant LR tracking
KVM: s390: use simple switch statement as multiplexer
KVM: s390: drop useless newline in debugging data
KVM: s390: SCA must not cross page boundaries
KVM: arm: Do not indent the arguments of DECLARE_BITMAP
Pull documentation update from Jon Corbet:
"There is a nice new document from Neil on how pathname lookups work
and some new CAN driver documentation. Beyond that, we have
kernel-doc fixes, a bit more work to support reproducible builds, and
the usual collection of small fixes"
* tag 'docs-for-linus' of git://git.lwn.net/linux: (34 commits)
Documentation: add new description of path-name lookup.
Documentation/vm/slub.txt: document slabinfo-gnuplot.sh
Doc: ABI/stable: Fix typo in ABI/stable
doc: Clarify that nmi_watchdog param is for hardlockups
Typo correction for description in gpio document.
DocBook: Fix kernel-doc to be case-insensitive for private:
kernel-docs.txt: update kernelnewbies reference
Doc:kvm: Fix typo in Doc/virtual/kvm
Documentation/Changes: Add bc in "Current Minimal Requirements" section
Documentation/email-clients.txt: remove trailing whitespace
DocBook: Use a fixed encoding for output
MAINTAINERS: The docs tree has moved
Docs/kernel-parameters: Add earlycon devicetree usage
SubmittingPatches: make Subject examples match the de facto standard
Documentation: gpio: mention that <function>-gpio has been deprecated
Documentation: cgroups: just fix a few typos
Documentation: Update kselftest.txt
Documentation: DMA API: Be more explicit that nents is always the same
Documentation: Update the default value of crashkernel low
zram: update documentation
We use
$make TARGETS="size timers" kselftest
to build and run selftests. but there is no rule
for us to clean the kselftest generated files.
This patch add the rules, for example:
$ make TARGETS="size timers" kselftest-clean
can clean all kselftest generated files.
Signed-off-by: Wang Long <long.wanglong@huawei.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
We need to build files in virt/lib/, which are now used by
KVM and VFIO, so add virt directory to the top Makefile.
Signed-off-by: Feng Wu <feng.wu@intel.com>
Acked-by: Michal Marek <mmarek@suse.com>
Currently the encoding of documents generated by DocBook depends on
the current locale. Make the output reproducible independently of
the locale, by setting the encoding to UTF-8 (LC_CTYPE=C.UTF-8) by
preference, or ASCII (LC_CTYPE=C) as a fallback.
LC_CTYPE can normally be overridden by LC_ALL, but the top-level
Makefile unsets that.
[jc: added check-lc_ctype to .gitignore]
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Pull misc kbuild updates from Michal Marek:
- deb-pkg:
+ module signing fix
+ dtb files are added to the package
+ do not require `hostname -f` to work during build
+ make deb-pkg generates a source package, bindeb-pkg has been
added to only generate the binary package
- rpm-pkg packages /lib/modules as well
- new coccinelle patch and updates to existing ones
- new stackusage & stackdelta script to collect and compare stack usage
info (using gcc's -fstack-usage)
- make tags understands trace_*_rcuidle() macros
- .gitignore updates, misc cleanups
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (27 commits)
deb-pkg: add source package
package/Makefile: move source tar creation to a function
scripts: add stackdelta script
kbuild: remove *.su files generated by -fstack-usage
.gitignore: add *.su pattern
scripts: add stackusage script
kbuild: avoid listing /lib/modules in kernel spec file
fallback to hostname in scripts/package/builddeb
coccinelle: api: extend spatch for dropping unnecessary owner
deb-pkg: simplify directory creation
scripts/tags.sh: Include trace_*_rcuidle() in tags
scripts/package/Makefile: rpmbuild is needed for rpm targets
Kbuild: Add ID files to .gitignore
gitignore: Add MIPS vmlinux.32 to the list
coccinelle: simple_return: Add a blank line
coccinelle: irqf_oneshot.cocci: Improve the generated commit log
coccinelle: api: add vma_pages.cocci
scripts/coccinelle/misc/irqf_oneshot.cocci: Fix grammar
scripts/coccinelle/misc/semicolon.cocci: Use imperative mood
coccinelle: simple_open: Use imperative mood
Pull core kbuild updates from Michal Marek:
- modpost portability fix
- linker script fix
- genksyms segfault fix
- fixdep cleanup
- fix for clang detection
kbuild: Fix clang detection
kbuild: fixdep: drop meaningless hash table initialization
kbuild: fixdep: optimize code slightly
genksyms: Regenerate parser
genksyms: Duplicate function pointer type definitions segfault
kbuild: Fix .text.unlikely placement
Avoid conflict with host definitions when cross-compiling
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- PKCS#7 support added to support signed kexec, also utilized for
module signing. See comments in 3f1e1bea.
** NOTE: this requires linking against the OpenSSL library, which
must be installed, e.g. the openssl-devel on Fedora **
- Smack
- add IPv6 host labeling; ignore labels on kernel threads
- support smack labeling mounts which use binary mount data
- SELinux:
- add ioctl whitelisting (see
http://kernsec.org/files/lss2015/vanderstoep.pdf)
- fix mprotect PROT_EXEC regression caused by mm change
- Seccomp:
- add ptrace options for suspend/resume"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (57 commits)
PKCS#7: Add OIDs for sha224, sha284 and sha512 hash algos and use them
Documentation/Changes: Now need OpenSSL devel packages for module signing
scripts: add extract-cert and sign-file to .gitignore
modsign: Handle signing key in source tree
modsign: Use if_changed rule for extracting cert from module signing key
Move certificate handling to its own directory
sign-file: Fix warning about BIO_reset() return value
PKCS#7: Add MODULE_LICENSE() to test module
Smack - Fix build error with bringup unconfigured
sign-file: Document dependency on OpenSSL devel libraries
PKCS#7: Appropriately restrict authenticated attributes and content type
KEYS: Add a name for PKEY_ID_PKCS7
PKCS#7: Improve and export the X.509 ASN.1 time object decoder
modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYS
extract-cert: Cope with multiple X.509 certificates in a single file
sign-file: Generate CMS message as signature instead of PKCS#7
PKCS#7: Support CMS messages also [RFC5652]
X.509: Change recorded SKID & AKID to not include Subject or Issuer
PKCS#7: Check content type and versions
MAINTAINERS: The keyrings mailing list has moved
We cannot detect clang before including the arch Makefile, because that
can set the default cross compiler. We also cannot detect clang after
including the arch Makefile, because powerpc wants to know about clang.
Solve this by using an deferred variable. This costs us a few shell
invocations, but this is only a constant number.
Reported-by: Behan Webster <behanw@converseincode.com>
Reported-by: Anton Blanchard <anton@samba.org>
Make sure 'make clean' removes *.su files generated by the gcc option
-fstack-usage.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
