commit c6a385539175ebc603da53aafb7753d39089f32e upstream.
So Sebastian turned off the PIE for kernel builds but that was too late
- Kbuild.include already uses KBUILD_CFLAGS and trying to disable gcc
options with, say cc-disable-warning, fails:
gcc -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs
-Wno-sign-compare -fno-asynchronous-unwind-tables -Wframe-address -c -x c /dev/null -o .31392.tmp
/dev/null:1:0: error: code model kernel does not support PIC mode
because that returns an error and we can't disable the warning. For
example in this case:
KBUILD_CFLAGS += $(call cc-disable-warning,frame-address,)
which leads to gcc issuing all those warnings again.
So let's turn off PIE/PIC at the earliest possible moment, when we
declare KBUILD_CFLAGS so that cc-disable-warning picks it up too.
Also, we need the $(call cc-option ...) because -fno-PIE is supported
since gcc v3.4 and our lowest supported gcc version is 3.2 right now.
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Michal Marek <mmarek@suse.com>
commit 8ae94224c9d72fc4d9aaac93b2d7833cf46d7141 upstream.
Debian started to build the gcc with -fPIE by default so the kernel
build ends before it starts properly with:
|kernel/bounds.c:1:0: error: code model kernel does not support PIC mode
Also add to KBUILD_AFLAGS due to:
|gcc -Wp,-MD,arch/x86/entry/vdso/vdso32/.note.o.d … -mfentry -DCC_USING_FENTRY … vdso/vdso32/note.S
|arch/x86/entry/vdso/vdso32/note.S:1:0: sorry, unimplemented: -mfentry isn’t supported for 32-bit in combination with -fpic
Tagging it stable so it is possible to compile recent stable kernels as
well.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 124a3d88fa20e1869fc229d7d8c740cc81944264 upstream.
Newer versions of gcc warn about the use of __builtin_return_address()
with a non-zero argument when "-Wall" is specified:
kernel/trace/trace_irqsoff.c: In function ‘stop_critical_timings’:
kernel/trace/trace_irqsoff.c:433:86: warning: calling ‘__builtin_return_address’ with a nonzero argument is unsafe [-Wframe-address]
stop_critical_timing(CALLER_ADDR0, CALLER_ADDR1);
[ .. repeats a few times for other similar cases .. ]
It is true that a non-zero argument is somewhat dangerous, and we do not
actually have very many uses of that in the kernel - but the ftrace code
does use it, and as Stephen Rostedt says:
"We are well aware of the danger of using __builtin_return_address() of
> 0. In fact that's part of the reason for having the "thunk" code in
x86 (See arch/x86/entry/thunk_{64,32}.S). [..] it adds extra frames
when tracking irqs off sections, to prevent __builtin_return_address()
from accessing bad areas. In fact the thunk_32.S states: 'Trampoline to
trace irqs off. (otherwise CALLER_ADDR1 might crash)'."
For now, __builtin_return_address() with a non-zero argument is the best
we can do, and the warning is not helpful and can end up making people
miss other warnings for real problems.
So disable the frame-address warning on compilers that need it.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
commit 377ccbb483738f84400ddf5840c7dd8825716985 upstream.
With the latest gcc compilers, they give a warning if
__builtin_return_address() parameter is greater than 0. That is because if
it is used by a function called by a top level function (or in the case of
the kernel, by assembly), it can try to access stack frames outside the
stack and crash the system.
The tracing system uses __builtin_return_address() of up to 2! But it is
well aware of the dangers that it may have, and has even added precautions
to protect against it (see the thunk code in arch/x86/entry/thunk*.S)
Linus originally added KBUILD_CFLAGS that would suppress the warning for the
entire kernel, as simply adding KBUILD_CFLAGS to the tracing directory
wouldn't work. The tracing directory plays a bit with the CFLAGS and
requires a little more logic.
This adds that special logic to only suppress the warning for the tracing
directory. If it is used anywhere else outside of tracing, the warning will
still be triggered.
Link: http://lkml.kernel.org/r/20160728223043.51996267@grimm.local.home
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 6e8d666e925333c55378e8d5540a8a9ee0eea9c5 upstream.
Several build configurations had already disabled this warning because
it generates a lot of false positives. But some had not, and it was
still enabled for "allmodconfig" builds, for example.
Looking at the warnings produced, every single one I looked at was a
false positive, and the warnings are frequent enough (and big enough)
that they can easily hide real problems that you don't notice in the
noise generated by -Wmaybe-uninitialized.
The warning is good in theory, but this is a classic case of a warning
that causes more problems than the warning can solve.
If gcc gets better at avoiding false positives, we may be able to
re-enable this warning. But as is, we're better off without it, and I
want to be able to see the *real* warnings.
commit e72e2dfe7c16ffbfbabf9cb24adc6d9f93a4fe37 upstream.
When gcov profiling is enabled, we see a lot of spurious warnings about
possibly uninitialized variables being used:
arch/arm/mm/dma-mapping.c: In function 'arm_coherent_iommu_map_page':
arch/arm/mm/dma-mapping.c:1085:16: warning: 'start' may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/clk/st/clk-flexgen.c: In function 'st_of_flexgen_setup':
drivers/clk/st/clk-flexgen.c:323:9: warning: 'num_parents' may be used uninitialized in this function [-Wmaybe-uninitialized]
kernel/cgroup.c: In function 'cgroup_mount':
kernel/cgroup.c:2119:11: warning: 'root' may be used uninitialized in this function [-Wmaybe-uninitialized]
All of these are false positives, so it seems better to just disable
the warnings whenever GCOV is enabled. Most users don't enable GCOV,
and based on a prior patch, it is now also disabled for 'allmodconfig'
builds, so there should be no downsides of doing this.
Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
commit 815eb71e7149ecce40db9dd0ad09c4dd9d33c60f upstream.
CONFIG_PROFILE_ALL_BRANCHES confuses gcc-5.x to the degree that it prints
incorrect warnings about a lot of variables that it thinks can be used
uninitialized, e.g.:
i2c/busses/i2c-diolan-u2c.c: In function 'diolan_usb_xfer':
i2c/busses/i2c-diolan-u2c.c:391:16: warning: 'byte' may be used uninitialized in this function
iio/gyro/itg3200_core.c: In function 'itg3200_probe':
iio/gyro/itg3200_core.c:213:6: warning: 'val' may be used uninitialized in this function
leds/leds-lp55xx-common.c: In function 'lp55xx_update_bits':
leds/leds-lp55xx-common.c:350:6: warning: 'tmp' may be used uninitialized in this function
misc/bmp085.c: In function 'show_pressure':
misc/bmp085.c:363:10: warning: 'pressure' may be used uninitialized in this function
power/ds2782_battery.c: In function 'ds2786_get_capacity':
power/ds2782_battery.c:214:17: warning: 'raw' may be used uninitialized in this function
These are all false positives that either rob someone's time when trying
to figure out whether they are real, or they get people to send wrong
patches to shut up the warnings.
Nobody normally wants to run a CONFIG_PROFILE_ALL_BRANCHES kernel in
production, so disabling the whole class of warnings for this configuration
has no serious downsides either.
Acked-by: Steven Rostedt <rostedtgoodmis.org>
commit 51193b76bfff5027cf96ba63effae808ad67cca7 upstream.
When the kernel path contains a space or a colon somewhere in the path
name, the modules_install target doesn't work anymore, as the path names
are not enclosed in double quotes. It is also supposed that and O= build
will suffer from the same weakness as modules_install.
Instead of checking and improving kbuild to resist to directories
including these characters, error out early to prevent any build if the
kernel's main directory contains a space.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit e17cf3a80d4ba0c4e40bf1a89deb1354c2e10e14 upstream.
Running "make O=foo" (with a relative directory path) fails with:
scripts/Makefile.include:3: *** O=foo does not exist. Stop.
/home/jpoimboe/git/linux/Makefile:1547: recipe for target 'tools/objtool' failed
The tools Makefile gets confused by the relative path and tries to build
objtool in tools/foo. Convert the output directory to an absolute path
before passing it to the tools Makefile.
Reported-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: linux-next@vger.kernel.org
Cc: linux@roeck-us.net
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/94a078c6c998fac9f01a14f574008bf7dff40191.1457016803.git.jpoimboe@redhat.com
partially
commit 40ab87a4003c7952976ce901a2b9ece5ed833168 upstream.
Commit 627189797807 ("Makefile: Document ability to make file.lst
and file.S") document ability to make file.S, but there isn't such
ability in kbuild, so revert it.
Signed-off-by: Wang YanQing <udknight@gmail.com>
commit a85a41ed69f27c4c667d8c418df14b4fb220c4ad upstream.
Based on a x86-only patch by Andy Lutomirski <luto@amacapital.net>
With modular kernels, 'make install' is going to need the installed
modules at some point to generate the initramfs.
