path: root/Makefile
2015-05-13Linux 3.10.78v3.10.78Greg Kroah-Hartman
2015-05-06Linux 3.10.77v3.10.77Greg Kroah-Hartman
2015-04-29Linux 3.10.76v3.10.76Greg Kroah-Hartman
2015-04-19Linux 3.10.75v3.10.75Greg Kroah-Hartman
2015-04-13Linux 3.10.74v3.10.74Greg Kroah-Hartman
2015-03-26Linux 3.10.73v3.10.73Greg Kroah-Hartman
2015-03-18Linux 3.10.72v3.10.72Greg Kroah-Hartman
2015-03-06Linux 3.10.71v3.10.71Greg Kroah-Hartman
2015-02-26Linux 3.10.70v3.10.70Greg Kroah-Hartman
2015-02-11Linux 3.10.69v3.10.69Greg Kroah-Hartman
2015-02-06Linux 3.10.68v3.10.68Greg Kroah-Hartman
2015-01-29Linux 3.10.67v3.10.67Greg Kroah-Hartman
2015-01-27Linux 3.10.66v3.10.66Greg Kroah-Hartman
2015-01-16Linux 3.10.65v3.10.65Greg Kroah-Hartman
2015-01-08Linux 3.10.64v3.10.64Greg Kroah-Hartman
2014-12-16Linux 3.10.63v3.10.63Greg Kroah-Hartman
2014-12-06Linux 3.10.62v3.10.62Greg Kroah-Hartman
2014-11-21Linux 3.10.61v3.10.61Greg Kroah-Hartman
2014-11-14Linux 3.10.60v3.10.60Greg Kroah-Hartman
2014-10-30Linux 3.10.59v3.10.59Greg Kroah-Hartman
2014-10-15Linux 3.10.58v3.10.58Greg Kroah-Hartman
2014-10-09Linux 3.10.57v3.10.57Greg Kroah-Hartman
2014-10-05Linux 3.10.56v3.10.56Greg Kroah-Hartman
2014-09-17Linux 3.10.55v3.10.55Greg Kroah-Hartman
2014-09-05Linux 3.10.54v3.10.54Greg Kroah-Hartman
2014-08-14Linux 3.10.53v3.10.53Greg Kroah-Hartman
2014-08-07Linux 3.10.52v3.10.52Greg Kroah-Hartman
2014-07-31Linux 3.10.51v3.10.51Greg Kroah-Hartman
2014-07-31Fix gcc-4.9.0 miscompilation of load_balance() in schedulerLinus Torvalds
commit 2062afb4f804afef61cbe62a30cac9a46e58e067 upstream. Michel Dänzer and a couple of other people reported inexplicable random oopses in the scheduler, and the cause turns out to be gcc mis-compiling the load_balance() function when debugging is enabled. The gcc bug apparently goes back to gcc-4.5, but slight optimization changes means that it now showed up as a problem in 4.9.0 and 4.9.1. The instruction scheduling problem causes gcc to schedule a spill operation to before the stack frame has been created, which in turn can corrupt the spilled value if an interrupt comes in. There may be other effects of this bug too, but that's the code generation problem seen in Michel's case. This is fixed in current gcc HEAD, but the workaround as suggested by Markus Trippelsdorf is pretty simple: use -fno-var-tracking-assignments when compiling the kernel, which disables the gcc code that causes the problem. This can result in slightly worse debug information for variable accesses, but that is infinitely preferable to actual code generation problems. Doing this unconditionally (not just for CONFIG_DEBUG_INFO) also allows non-debug builds to verify that the debug build would be identical: we can do export GCC_COMPARE_DEBUG=1 to make gcc internally verify that the result of the build is independent of the "-g" flag (it will make the compiler build everything twice, toggling the debug flag, and compare the results). Without the "-fno-var-tracking-assignments" option, the build would fail (even with 4.8.3 that didn't show the actual stack frame bug) with a gcc compare failure. See also gcc bugzilla: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=61801 Reported-by: Michel Dänzer <michel@daenzer.net> Suggested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-28Linux 3.10.50v3.10.50Greg Kroah-Hartman
2014-07-17Linux 3.10.49v3.10.49Greg Kroah-Hartman
2014-07-09Linux 3.10.48v3.10.48Greg Kroah-Hartman
2014-07-06Linux 3.10.47v3.10.47Greg Kroah-Hartman
2014-06-30Linux 3.10.46v3.10.46Greg Kroah-Hartman
2014-06-26Linux 3.10.45v3.10.45Greg Kroah-Hartman
2014-06-16Linux 3.10.44v3.10.44Greg Kroah-Hartman
2014-06-11Linux 3.10.43v3.10.43Greg Kroah-Hartman
2014-06-07Linux 3.10.42v3.10.42Greg Kroah-Hartman
2014-05-31Linux 3.10.41v3.10.41Greg Kroah-Hartman
2014-05-13Linux 3.10.40v3.10.40Greg Kroah-Hartman
2014-05-06Linux 3.10.39v3.10.39Greg Kroah-Hartman
2014-04-26Linux 3.10.38v3.10.38Greg Kroah-Hartman
2014-04-14Linux 3.10.37v3.10.37Greg Kroah-Hartman
2014-04-03Linux 3.10.36v3.10.36Greg Kroah-Hartman
2014-03-31Linux 3.10.35v3.10.35Greg Kroah-Hartman
2014-03-23Linux 3.10.34v3.10.34Greg Kroah-Hartman
2014-03-06Linux 3.10.33v3.10.33Greg Kroah-Hartman
2014-02-22Linux 3.10.32v3.10.32Greg Kroah-Hartman
2014-02-20Linux 3.10.31v3.10.31Greg Kroah-Hartman
2014-02-13Linux 3.10.30v3.10.30Greg Kroah-Hartman
