path: root/Makefile
2018-07-28Linux 4.4.145v4.4.145Greg Kroah-Hartman
2018-07-28turn off -Wattribute-aliasArnd Bergmann
Starting with gcc-8.1, we get a warning about all system call definitions, which use an alias between functions with incompatible prototypes, e.g.: In file included from ../mm/process_vm_access.c:19: ../include/linux/syscalls.h:211:18: warning: 'sys_process_vm_readv' alias between functions of incompatible types 'long int(pid_t, const struct iovec *, long unsigned int, const struct iovec *, long unsigned int, long unsigned int)' {aka 'long int(int, const struct iovec *, long unsigned int, const struct iovec *, long unsigned int, long unsigned int)'} and 'long int(long int, long int, long int, long int, long int, long int)' [-Wattribute-alias] asmlinkage long sys##name(__MAP(x,__SC_DECL,__VA_ARGS__)) \ ^~~ ../include/linux/syscalls.h:207:2: note: in expansion of macro '__SYSCALL_DEFINEx' __SYSCALL_DEFINEx(x, sname, __VA_ARGS__) ^~~~~~~~~~~~~~~~~ ../include/linux/syscalls.h:201:36: note: in expansion of macro 'SYSCALL_DEFINEx' #define SYSCALL_DEFINE6(name, ...) SYSCALL_DEFINEx(6, _##name, __VA_ARGS__) ^~~~~~~~~~~~~~~ ../mm/process_vm_access.c:300:1: note: in expansion of macro 'SYSCALL_DEFINE6' SYSCALL_DEFINE6(process_vm_readv, pid_t, pid, const struct iovec __user *, lvec, ^~~~~~~~~~~~~~~ ../include/linux/syscalls.h:215:18: note: aliased declaration here asmlinkage long SyS##name(__MAP(x,__SC_LONG,__VA_ARGS__)) \ ^~~ ../include/linux/syscalls.h:207:2: note: in expansion of macro '__SYSCALL_DEFINEx' __SYSCALL_DEFINEx(x, sname, __VA_ARGS__) ^~~~~~~~~~~~~~~~~ ../include/linux/syscalls.h:201:36: note: in expansion of macro 'SYSCALL_DEFINEx' #define SYSCALL_DEFINE6(name, ...) SYSCALL_DEFINEx(6, _##name, __VA_ARGS__) ^~~~~~~~~~~~~~~ ../mm/process_vm_access.c:300:1: note: in expansion of macro 'SYSCALL_DEFINE6' SYSCALL_DEFINE6(process_vm_readv, pid_t, pid, const struct iovec __user *, lvec, This is really noisy and does not indicate a real problem. In the latest mainline kernel, this was addressed by commit bee20031772a ("disable -Wattribute-alias warning for SYSCALL_DEFINEx()"), which seems too invasive to backport. This takes a much simpler approach and just disables the warning across the kernel. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25Linux 4.4.144v4.4.144Greg Kroah-Hartman
2018-07-22Linux 4.4.143v4.4.143Greg Kroah-Hartman
2018-07-19Linux 4.4.142v4.4.142Greg Kroah-Hartman
2018-07-17Linux 4.4.141v4.4.141Greg Kroah-Hartman
2018-07-11Linux 4.4.140v4.4.140Greg Kroah-Hartman
2018-07-03Linux 4.4.139v4.4.139Greg Kroah-Hartman
2018-06-16Linux 4.4.138v4.4.138Greg Kroah-Hartman
2018-06-13Linux 4.4.137v4.4.137Greg Kroah-Hartman
2018-06-06Linux 4.4.136v4.4.136Greg Kroah-Hartman
2018-05-30Linux 4.4.135v4.4.135Greg Kroah-Hartman
2018-05-30Linux 4.4.134v4.4.134Greg Kroah-Hartman
2018-05-26Linux 4.4.133v4.4.133Greg Kroah-Hartman
2018-05-16Linux 4.4.132v4.4.132Greg Kroah-Hartman
2018-05-02Linux 4.4.131v4.4.131Greg Kroah-Hartman
2018-04-29Linux 4.4.130v4.4.130Greg Kroah-Hartman
2018-04-24Linux 4.4.129v4.4.129Greg Kroah-Hartman
2018-04-13Linux 4.4.128v4.4.128Greg Kroah-Hartman
2018-04-08Linux 4.4.127v4.4.127Greg Kroah-Hartman
2018-03-31Linux 4.4.126v4.4.126Greg Kroah-Hartman
2018-03-28Linux 4.4.125v4.4.125Greg Kroah-Hartman
2018-03-28kbuild: disable clang's default use of -fmerge-all-constantsDaniel Borkmann
commit 87e0d4f0f37fb0c8c4aeeac46fff5e957738df79 upstream. Prasad reported that he has seen crashes in BPF subsystem with netd on Android with arm64 in the form of (note, the taint is unrelated): [ 4134.721483] Unable to handle kernel paging request at virtual address 800000001 [ 4134.820925] Mem abort info: [ 4134.901283] Exception class = DABT (current EL), IL = 32 bits [ 4135.016736] SET = 0, FnV = 0 [ 4135.119820] EA = 0, S1PTW = 0 [ 4135.201431] Data abort info: [ 4135.301388] ISV = 0, ISS = 0x00000021 [ 4135.359599] CM = 0, WnR = 0 [ 4135.470873] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffe39b946000 [ 4135.499757] [0000000800000001] *pgd=0000000000000000, *pud=0000000000000000 [ 4135.660725] Internal error: Oops: 96000021 [#1] PREEMPT SMP [ 4135.674610] Modules linked in: [ 4135.682883] CPU: 5 PID: 1260 Comm: netd Tainted: G S W 4.14.19+ #1 [ 4135.716188] task: ffffffe39f4aa380 task.stack: ffffff801d4e0000 [ 4135.731599] PC is at bpf_prog_add+0x20/0x68 [ 4135.741746] LR is at bpf_prog_inc+0x20/0x2c [ 4135.751788] pc : [<ffffff94ab7ad584>] lr : [<ffffff94ab7ad638>] pstate: 60400145 [ 4135.769062] sp : ffffff801d4e3ce0 [...] [ 4136.258315] Process netd (pid: 1260, stack limit = 0xffffff801d4e0000) [ 4136.273746] Call trace: [...] [ 4136.442494] 3ca0: ffffff94ab7ad584 0000000060400145 ffffffe3a01bf8f8 0000000000000006 [ 4136.460936] 3cc0: 0000008000000000 ffffff94ab844204 ffffff801d4e3cf0 ffffff94ab7ad584 [ 4136.479241] [<ffffff94ab7ad584>] bpf_prog_add+0x20/0x68 [ 4136.491767] [<ffffff94ab7ad638>] bpf_prog_inc+0x20/0x2c [ 4136.504536] [<ffffff94ab7b5d08>] bpf_obj_get_user+0x204/0x22c [ 4136.518746] [<ffffff94ab7ade68>] SyS_bpf+0x5a8/0x1a88 Android's netd was basically pinning the uid cookie BPF map in BPF fs (/sys/fs/bpf/traffic_cookie_uid_map) and later on retrieving it again resulting in above panic. Issue is that the map was wrongly identified as a prog! Above kernel was compiled with clang 4.0, and it turns out that clang decided to merge the bpf_prog_iops and bpf_map_iops into a single memory location, such that the two i_ops could then not be distinguished anymore. Reason for this miscompilation is that clang has the more aggressive -fmerge-all-constants enabled by default. In fact, clang source code has a comment about it in lib/AST/ExprConstant.cpp on why it is okay to do so: Pointers with different bases cannot represent the same object. (Note that clang defaults to -fmerge-all-constants, which can lead to inconsistent results for comparisons involving the address of a constant; this generally doesn't matter in practice.) The issue never appeared with gcc however, since gcc does not enable -fmerge-all-constants by default and even *explicitly* states in it's option description that using this flag results in non-conforming behavior, quote from man gcc: Languages like C or C++ require each variable, including multiple instances of the same variable in recursive calls, to have distinct locations, so using this option results in non-conforming behavior. There are also various clang bug reports open on that matter [1], where clang developers acknowledge the non-conforming behavior, and refer to disabling it with -fno-merge-all-constants. But even if this gets fixed in clang today, there are already users out there that triggered this. Thus, fix this issue by explicitly adding -fno-merge-all-constants to the kernel's Makefile to generically disable this optimization, since potentially other places in the kernel could subtly break as well. Note, there is also a flag called -fmerge-constants (not supported by clang), which is more conservative and only applies to strings and it's enabled in gcc's -O/-O2/-O3/-Os optimization levels. In gcc's code, the two flags -fmerge-{all-,}constants share the same variable internally, so when disabling it via -fno-merge-all-constants, then we really don't merge any const data (e.g. strings), and text size increases with gcc (14,927,214 -> 14,942,646 for vmlinux.o). $ gcc -fverbose-asm -O2 foo.c -S -o foo.S -> foo.S lists -fmerge-constants under options enabled $ gcc -fverbose-asm -O2 -fno-merge-all-constants foo.c -S -o foo.S -> foo.S doesn't list -fmerge-constants under options enabled $ gcc -fverbose-asm -O2 -fno-merge-all-constants -fmerge-constants foo.c -S -o foo.S -> foo.S lists -fmerge-constants under options enabled Thus, as a workaround we need to set both -fno-merge-all-constants *and* -fmerge-constants in the Makefile in order for text size to stay as is. [1] https://bugs.llvm.org/show_bug.cgi?id=18538 Reported-by: Prasad Sodagudi <psodagud@codeaurora.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Chenbo Feng <fengc@google.com> Cc: Richard Smith <richard-llvm@metafoo.co.uk> Cc: Chandler Carruth <chandlerc@gmail.com> Cc: linux-kernel@vger.kernel.org Tested-by: Prasad Sodagudi <psodagud@codeaurora.org> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24Linux 4.4.124v4.4.124Greg Kroah-Hartman
2018-03-22Linux 4.4.123v4.4.123Greg Kroah-Hartman
2018-03-18Linux 4.4.122v4.4.122Greg Kroah-Hartman
2018-03-11Linux 4.4.121v4.4.121Greg Kroah-Hartman
2018-03-03Linux 4.4.120v4.4.120Greg Kroah-Hartman
2018-02-28Linux 4.4.119v4.4.119Greg Kroah-Hartman
2018-02-25Linux 4.4.118v4.4.118Greg Kroah-Hartman
2018-02-25tools build: Add tools tree support for 'make -s'Josh Poimboeuf
commit e572d0887137acfc53f18175522964ec19d88175 upstream. When doing a kernel build with 'make -s', everything is silenced except the objtool build. That's because the tools tree support for silent builds is some combination of missing and broken. Three changes are needed to fix it: - Makefile: propagate '-s' to the sub-make's MAKEFLAGS variable so the tools Makefiles can see it. - tools/scripts/Makefile.include: fix the tools Makefiles' ability to recognize '-s'. The MAKE_VERSION and MAKEFLAGS checks are copied from the top-level Makefile. This silences the "DESCEND objtool" message. - tools/build/Makefile.build: add support to the tools Build files for recognizing '-s'. Again the MAKE_VERSION and MAKEFLAGS checks are copied from the top-level Makefile. This silences all the object compile/link messages. Reported-and-Tested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Marek <mmarek@suse.com> Link: http://lkml.kernel.org/r/e8967562ef640c3ae9a76da4ae0f4e47df737c34.1484799200.git.jpoimboe@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22Linux 4.4.117v4.4.117Greg Kroah-Hartman
2018-02-16Linux 4.4.116v4.4.116Greg Kroah-Hartman
2018-02-03Linux 4.4.115v4.4.115Greg Kroah-Hartman
2018-01-31Linux 4.4.114v4.4.114Greg Kroah-Hartman
2018-01-23Linux 4.4.113v4.4.113Greg Kroah-Hartman
2018-01-17Linux 4.4.112v4.4.112Greg Kroah-Hartman
2018-01-10Linux 4.4.111v4.4.111Greg Kroah-Hartman
2018-01-05Linux 4.4.110v4.4.110Greg Kroah-Hartman
2018-01-02Linux 4.4.109v4.4.109Greg Kroah-Hartman
2018-01-02kbuild: add '-fno-stack-check' to kernel build optionsLinus Torvalds
commit 3ce120b16cc548472f80cf8644f90eda958cf1b6 upstream. It appears that hardened gentoo enables "-fstack-check" by default for gcc. That doesn't work _at_all_ for the kernel, because the kernel stack doesn't act like a user stack at all: it's much smaller, and it doesn't auto-expand on use. So the extra "probe one page below the stack" code generated by -fstack-check just breaks the kernel in horrible ways, causing infinite double faults etc. [ I have to say, that the particular code gcc generates looks very stupid even for user space where it works, but that's a separate issue. ] Reported-and-tested-by: Alexander Tsoy <alexander@tsoy.me> Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25Linux 4.4.108v4.4.108Greg Kroah-Hartman
2017-12-20Linux 4.4.107v4.4.107Greg Kroah-Hartman
2017-12-16Linux 4.4.106v4.4.106Greg Kroah-Hartman
2017-12-09Linux 4.4.105v4.4.105Greg Kroah-Hartman
2017-12-05Linux 4.4.104v4.4.104Greg Kroah-Hartman
2017-11-30Linux 4.4.103v4.4.103Greg Kroah-Hartman
2017-11-24Linux 4.4.102v4.4.102Greg Kroah-Hartman
2017-11-24Linux 4.4.101v4.4.101Greg Kroah-Hartman
2017-11-21Linux 4.4.100v4.4.100Greg Kroah-Hartman
