path: root/Makefile
2015-06-21Linux 4.1v4.1Linus Torvalds
2015-06-14Linux 4.1-rc8v4.1-rc8Linus Torvalds
2015-06-07Linux 4.1-rc7v4.1-rc7Linus Torvalds
2015-05-31Linux 4.1-rc6v4.1-rc6Linus Torvalds
2015-05-24Linux 4.1-rc5v4.1-rc5Linus Torvalds
2015-05-18Linux 4.1-rc4v4.1-rc4Linus Torvalds
2015-05-10Linux 4.1-rc3v4.1-rc3Linus Torvalds
2015-05-03Linux 4.1-rc2v4.1-rc2Linus Torvalds
2015-04-26Linux 4.1-rc1v4.1-rc1Linus Torvalds
2015-04-15Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: "Here is the first round of kbuild changes for v4.1-rc1: - kallsyms fix for ARM and cleanup - make dep(end) removed (developers have no sense of nostalgia these days...) - include Makefiles by relative path - stop useless rebuilds of asm-offsets.h and bounds.h" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Kbuild: kallsyms: drop special handling of pre-3.0 GCC symbols Kbuild: kallsyms: ignore veneers emitted by the ARM linker kbuild: ia64: use $(src)/Makefile.gate rather than particular path kbuild: include $(src)/Makefile rather than $(obj)/Makefile kbuild: use relative path more to include Makefile kbuild: use relative path to include Makefile kbuild: do not add $(bounds-file) and $(offsets-file) to targets kbuild: remove warning about "make depend" kbuild: Don't reset timestamps in include/generated if not needed
2015-04-13Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "Main changes: - jump label asm preparatory work for PowerPC (Anton Blanchard) - rwsem optimizations and cleanups (Davidlohr Bueso) - mutex optimizations and cleanups (Jason Low) - futex fix (Oleg Nesterov) - remove broken atomicity checks from {READ,WRITE}_ONCE() (Peter Zijlstra)" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: powerpc, jump_label: Include linux/jump_label.h to get HAVE_JUMP_LABEL define jump_label: Allow jump labels to be used in assembly jump_label: Allow asm/jump_label.h to be included in assembly locking/mutex: Further simplify mutex_spin_on_owner() locking: Remove atomicy checks from {READ,WRITE}_ONCE locking/rtmutex: Rename argument in the rt_mutex_adjust_prio_chain() documentation as well locking/rwsem: Fix lock optimistic spinning when owner is not running locking: Remove ACCESS_ONCE() usage locking/rwsem: Check for active lock before bailing on spinning locking/rwsem: Avoid deceiving lock spinners locking/rwsem: Set lock ownership ASAP locking/rwsem: Document barrier need when waking tasks locking/futex: Check PF_KTHREAD rather than !p->mm to filter out kthreads locking/mutex: Refactor mutex_spin_on_owner() locking/mutex: In mutex_spin_on_owner(), return true when owner changes
2015-04-12Linux 4.0v4.0Linus Torvalds
2015-04-09jump_label: Allow jump labels to be used in assemblyAnton Blanchard
To use jump labels in assembly we need the HAVE_JUMP_LABEL define, so we select a fallback version if the toolchain does not support them. Modify linux/jump_label.h so it can be included by assembly files. We also need to add -DCC_HAVE_ASM_GOTO to KBUILD_AFLAGS. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: benh@kernel.crashing.org Cc: catalin.marinas@arm.com Cc: davem@davemloft.net Cc: heiko.carstens@de.ibm.com Cc: jbaron@akamai.com Cc: linux@arm.linux.org.uk Cc: linuxppc-dev@lists.ozlabs.org Cc: liuj97@gmail.com Cc: mgorman@suse.de Cc: mmarek@suse.cz Cc: mpe@ellerman.id.au Cc: paulus@samba.org Cc: ralf@linux-mips.org Cc: rostedt@goodmis.org Cc: schwidefsky@de.ibm.com Cc: will.deacon@arm.com Link: http://lkml.kernel.org/r/1428551492-21977-2-git-send-email-anton@samba.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-06Linux 4.0-rc7v4.0-rc7Linus Torvalds
2015-04-02kbuild: use relative path more to include MakefileMasahiro Yamada
Prior to this commit, it was impossible to use relative path to include Makefiles from the top level Makefile because the option "--include-dir=$(srctree)" becomes effective when Make enters into sub Makefiles. To use relative path in any places, this commit moves the option above the "sub-make" target. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-03-29Linux 4.0-rc6v4.0-rc6Linus Torvalds
2015-03-24kbuild: remove warning about "make depend"Masahiro Yamada
Enough time has passed since "make depend" was deprecated. Nobody would be in trouble without this hint. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-03-22Linux 4.0-rc5v4.0-rc5Linus Torvalds
2015-03-15Linux 4.0-rc4v4.0-rc4Linus Torvalds
2015-03-08Linux 4.0-rc3v4.0-rc3Linus Torvalds
2015-03-03Linux 4.0-rc2v4.0-rc2Linus Torvalds
2015-02-22Linux 4.0-rc1v4.0-rc1Linus Torvalds
.. after extensive statistical analysis of my G+ polling, I've come to the inescapable conclusion that internet polls are bad. Big surprise. But "Hurr durr I'ma sheep" trounced "I like online polls" by a 62-to-38% margin, in a poll that people weren't even supposed to participate in. Who can argue with solid numbers like that? 5,796 votes from people who can't even follow the most basic directions? In contrast, "v4.0" beat out "v3.20" by a slimmer margin of 56-to-44%, but with a total of 29,110 votes right now. Now, arguably, that vote spread is only about 3,200 votes, which is less than the almost six thousand votes that the "please ignore" poll got, so it could be considered noise. But hey, I asked, so I'll honor the votes.
2015-02-19Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - several cleanups in kbuild - serialize multiple *config targets so that 'make defconfig kvmconfig' works - The cc-ifversion macro got support for an else-branch * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild,gcov: simplify kernel/gcov/Makefile more kbuild: allow cc-ifversion to have the argument for false condition kbuild,gcov: simplify kernel/gcov/Makefile kbuild,gcov: remove unnecessary workaround kbuild: do not add $(call ...) to invoke cc-version or cc-fullversion kbuild: fix cc-ifversion macro kbuild: drop $(version_h) from MRPROPER_FILES kbuild: use mixed-targets when two or more config targets are given kbuild: remove redundant line from bounds.h/asm-offsets.h kbuild: merge bounds.h and asm-offsets.h rules kbuild: Drop support for clean-rule
2015-02-17scripts/gdb: add infrastructureJan Kiszka
This provides the basic infrastructure to load kernel-specific python helper scripts when debugging the kernel in gdb. The loading mechanism is based on gdb loading for <objfile>-gdb.py when opening <objfile>. Therefore, this places a corresponding link to the main helper script into the output directory that contains vmlinux. The main scripts will pull in submodules containing Linux specific gdb commands and functions. To avoid polluting the source directory with compiled python modules, we link to them from the object directory. Due to gdb.parse_and_eval and string redirection for gdb.execute, we depend on gdb >= 7.2. This feature is enabled via CONFIG_GDB_SCRIPTS. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Michal Marek <mmarek@suse.cz> [kbuild stuff] Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ben Widawsky <ben@bwidawsk.net> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13kasan: add kernel address sanitizer infrastructureAndrey Ryabinin
Kernel Address sanitizer (KASan) is a dynamic memory error detector. It provides fast and comprehensive solution for finding use-after-free and out-of-bounds bugs. KASAN uses compile-time instrumentation for checking every memory access, therefore GCC > v4.9.2 required. v4.9.2 almost works, but has issues with putting symbol aliases into the wrong section, which breaks kasan instrumentation of globals. This patch only adds infrastructure for kernel address sanitizer. It's not available for use yet. The idea and some code was borrowed from [1]. Basic idea: The main idea of KASAN is to use shadow memory to record whether each byte of memory is safe to access or not, and use compiler's instrumentation to check the shadow memory on each memory access. Address sanitizer uses 1/8 of the memory addressable in kernel for shadow memory and uses direct mapping with a scale and offset to translate a memory address to its corresponding shadow address. Here is function to translate address to corresponding shadow address: unsigned long kasan_mem_to_shadow(unsigned long addr) { return (addr >> KASAN_SHADOW_SCALE_SHIFT) + KASAN_SHADOW_OFFSET; } where KASAN_SHADOW_SCALE_SHIFT = 3. So for every 8 bytes there is one corresponding byte of shadow memory. The following encoding used for each shadow byte: 0 means that all 8 bytes of the corresponding memory region are valid for access; k (1 <= k <= 7) means that the first k bytes are valid for access, and other (8 - k) bytes are not; Any negative value indicates that the entire 8-bytes are inaccessible. Different negative values used to distinguish between different kinds of inaccessible memory (redzones, freed memory) (see mm/kasan/kasan.h). To be able to detect accesses to bad memory we need a special compiler. Such compiler inserts a specific function calls (__asan_load*(addr), __asan_store*(addr)) before each memory access of size 1, 2, 4, 8 or 16. These functions check whether memory region is valid to access or not by checking corresponding shadow memory. If access is not valid an error printed. Historical background of the address sanitizer from Dmitry Vyukov: "We've developed the set of tools, AddressSanitizer (Asan), ThreadSanitizer and MemorySanitizer, for user space. We actively use them for testing inside of Google (continuous testing, fuzzing, running prod services). To date the tools have found more than 10'000 scary bugs in Chromium, Google internal codebase and various open-source projects (Firefox, OpenSSL, gcc, clang, ffmpeg, MySQL and lots of others): [2] [3] [4]. The tools are part of both gcc and clang compilers. We have not yet done massive testing under the Kernel AddressSanitizer (it's kind of chicken and egg problem, you need it to be upstream to start applying it extensively). To date it has found about 50 bugs. Bugs that we've found in upstream kernel are listed in [5]. We've also found ~20 bugs in out internal version of the kernel. Also people from Samsung and Oracle have found some. [...] As others noted, the main feature of AddressSanitizer is its performance due to inline compiler instrumentation and simple linear shadow memory. User-space Asan has ~2x slowdown on computational programs and ~2x memory consumption increase. Taking into account that kernel usually consumes only small fraction of CPU and memory when running real user-space programs, I would expect that kernel Asan will have ~10-30% slowdown and similar memory consumption increase (when we finish all tuning). I agree that Asan can well replace kmemcheck. We have plans to start working on Kernel MemorySanitizer that finds uses of unitialized memory. Asan+Msan will provide feature-parity with kmemcheck. As others noted, Asan will unlikely replace debug slab and pagealloc that can be enabled at runtime. Asan uses compiler instrumentation, so even if it is disabled, it still incurs visible overheads. Asan technology is easily portable to other architectures. Compiler instrumentation is fully portable. Runtime has some arch-dependent parts like shadow mapping and atomic operation interception. They are relatively easy to port." Comparison with other debugging features: ======================================== KMEMCHECK: - KASan can do almost everything that kmemcheck can. KASan uses compile-time instrumentation, which makes it significantly faster than kmemcheck. The only advantage of kmemcheck over KASan is detection of uninitialized memory reads. Some brief performance testing showed that kasan could be x500-x600 times faster than kmemcheck: $ netperf -l 30 MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost (127.0.0.1) port 0 AF_INET Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec no debug: 87380 16384 16384 30.00 41624.72 kasan inline: 87380 16384 16384 30.00 12870.54 kasan outline: 87380 16384 16384 30.00 10586.39 kmemcheck: 87380 16384 16384 30.03 20.23 - Also kmemcheck couldn't work on several CPUs. It always sets number of CPUs to 1. KASan doesn't have such limitation. DEBUG_PAGEALLOC: - KASan is slower than DEBUG_PAGEALLOC, but KASan works on sub-page granularity level, so it able to find more bugs. SLUB_DEBUG (poisoning, redzones): - SLUB_DEBUG has lower overhead than KASan. - SLUB_DEBUG in most cases are not able to detect bad reads, KASan able to detect both reads and writes. - In some cases (e.g. redzone overwritten) SLUB_DEBUG detect bugs only on allocation/freeing of object. KASan catch bugs right before it will happen, so we always know exact place of first bad read/write. [1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel [2] https://code.google.com/p/address-sanitizer/wiki/FoundBugs [3] https://code.google.com/p/thread-sanitizer/wiki/FoundBugs [4] https://code.google.com/p/memory-sanitizer/wiki/FoundBugs [5] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel#Trophies Based on work by Andrey Konovalov. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: - The remaining patches for the z13 machine support: kernel build option for z13, the cache synonym avoidance, SMT support, compare-and-delay for spinloops and the CES5S crypto adapater. - The ftrace support for function tracing with the gcc hotpatch option. This touches common code Makefiles, Steven is ok with the changes. - The hypfs file system gets an extension to access diagnose 0x0c data in user space for performance analysis for Linux running under z/VM. - The iucv hvc console gets wildcard spport for the user id filtering. - The cacheinfo code is converted to use the generic infrastructure. - Cleanup and bug fixes. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/process: free vx save area when releasing tasks s390/hypfs: Eliminate hypfs interval s390/hypfs: Add diagnose 0c support s390/cacheinfo: don't use smp_processor_id() in preemptible context s390/zcrypt: fixed domain scanning problem (again) s390/smp: increase maximum value of NR_CPUS to 512 s390/jump label: use different nop instruction s390/jump label: add sanity checks s390/mm: correct missing space when reporting user process faults s390/dasd: cleanup profiling s390/dasd: add locking for global_profile access s390/ftrace: hotpatch support for function tracing ftrace: let notrace function attribute disable hotpatching if necessary ftrace: allow architectures to specify ftrace compile options s390: reintroduce diag 44 calls for cpu_relax() s390/zcrypt: Add support for new crypto express (CEX5S) adapter. s390/zcrypt: Number of supported ap domains is not retrievable. s390/spinlock: add compare-and-delay to lock wait loops s390/tape: remove redundant if statement s390/hvc_iucv: add simple wildcard matches to the iucv allow filter ...
2015-02-08Linux 3.19v3.19Linus Torvalds
2015-02-01Linux 3.19-rc7v3.19-rc7Linus Torvalds
2015-01-29ftrace: allow architectures to specify ftrace compile optionsHeiko Carstens
If the kernel is compiled with function tracer support the -pg compile option is passed to gcc to generate extra code into the prologue of each function. This patch replaces the "open-coded" -pg compile flag with a CC_FLAGS_FTRACE makefile variable which architectures can override if a different option should be used for code generation. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-01-25Linux 3.19-rc6v3.19-rc6Linus Torvalds
2015-01-18Linux 3.19-rc5v3.19-rc5Linus Torvalds
2015-01-11linux 3.19-rc4v3.19-rc4Linus Torvalds
2015-01-08Makefile: include arch/*/include/generated/uapi before .../generatedMichal Marek
The introduction of the uapi directories in v3.7-rc1 moved some of the generated headers from arch/*/include/generated to the uapi directory, keeping the #include directives intact. This creates a problem when bisecting, because the unversioned files are not cleaned automatically by git and the compiler might include stale headers as a result. Instead of cleaning them in the Makefiles, promote arch/*/include/generated/uapi in the search path. Under normal circumstances, there is no overlap between this uapi subdirectory and its parent, so the include choices remain the same. We keep arch/*/include/generated/uapi in the USERINCLUDE variable so that it is usable standalone. Note that we cannot completely swap the order of the uapi and kernel-only directories, since the headers in include/uapi/asm-generic are meant to be wrapped by their include/asm-generic counterparts when building kernel code. Reported-by: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Reported-by: David Drysdale <dmd@lurklurk.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-08kbuild: drop $(version_h) from MRPROPER_FILESMasahiro Yamada
Now $(version_h) is include/generated/uapi/linux/version.h. $(version_h) in MRPROPER_FILES is redundant because it is covered by include/generated in MRPROPER_DIRS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-01-08kbuild: use mixed-targets when two or more config targets are givenMasahiro Yamada
"make kvmconfig" expects that the .config has already been created, but some people might want to create the .config and run kvmconfig in one shot command, like this: $ make defconfig kvmconfig To make sure this command works correctly even if -j* option is set, we must handle them one by one. This commit turns on mixed-targets when $(MAKECMDGOALS) includes at least one config target and also includes another target. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-01-05Linux 3.19-rc3v3.19-rc3Linus Torvalds
2014-12-28Linux 3.19-rc2v3.19-rc2Linus Torvalds
2014-12-20Linux 3.19-rc1v3.19-rc1Linus Torvalds
2014-12-20Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: "Here are the kbuild changes for v3.19-rc1: - Cleanups and deduplication in the main Makefile and scripts/Makefile.* - Sort the output of *config targets in make help - Old <linux/version.h> is always removed to avoid a surprise during bisecting - Warning fix in kconfig" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: remove redundant -rR flag of hdr-inst kbuild: Fix make help-<board series> on powerpc kbuild: Automatically remove stale <linux/version.h> file kconfig: Fix warning "‘jump’ may be used uninitialized" Makefile: sort list of defconfig targets in make help output kbuild: Remove duplicate $(cmd) definition in Makefile.clean kbuild: collect shorthands into scripts/Kbuild.include
2014-12-07Linux 3.18v3.18Linus Torvalds
2014-11-30Linux 3.18-rc7v3.18-rc7Linus Torvalds
2014-11-28kbuild: Fix make help-<board series> on powerpcMichal Marek
make ARCH=powerpc help-<board series> should not require a cofigured source tree. Also, sort the boards in the output. Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-11-28kbuild: Automatically remove stale <linux/version.h> fileMichal Marek
In 3.7, the file moved from include/linux/ to include/generated/uapi/linux/. The path in the #include directive remained the same for compatibility reasons, but this created a problem when bisecting. Commit 9c8cdb71 (kbuild: unconditionally clobber include/linux/version.h on distclean) fixes this, provided the user does make distclean between builds. Better not rely on the user and delete the stale file each time make is invoked. Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-11-28Makefile: sort list of defconfig targets in make help outputKonstantin Khlebnikov
Without sorting this list is completely unreadable for ARCH=arm. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-11-26kbuild: collect shorthands into scripts/Kbuild.includeMasahiro Yamada
The shorthand "clean" is defined in both the top Makefile and scripts/Makefile.clean. Likewise, the "hdr-inst" is defined in both the top Makefile and scripts/Makefile.headersinst. To reduce code duplication, this commit collects them into scripts/Kbuild.include like the "build" and "modbuiltin" shorthands. It requires scripts/Makefile.clean to include scripts/Kbuild.include, but its impact on the performance of "make clean" should be negligible. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-11-23Linux 3.18-rc6v3.18-rc6Linus Torvalds
2014-11-16Linux 3.18-rc5v3.18-rc5Linus Torvalds
2014-11-15kernel: use the gnu89 standard explicitlyKirill A. Shutemov
Sasha Levin reports: "gcc5 changes the default standard to c11, which makes kernel build unhappy Explicitly define the kernel standard to be gnu89 which should keep everything working exactly like it was before gcc5" There are multiple small issues with the new default, but the biggest issue seems to be that the old - and very useful - GNU extension to allow a cast in front of an initializer has gone away. Patch updated by Kirill: "I'm pretty sure all gcc versions you can build kernel with supports -std=gnu89. cc-option is redunrant. We also need to adjust HOSTCFLAGS otherwise allmodconfig fails for me" Note by Andrew Pinski: "Yes it was reported and both problems relating to this extension has been added to gnu99 and gnu11. Though there are other issues with the kernel dealing with extern inline have different semantics between gnu89 and gnu99/11" End result: we may be able to move up to a newer stdc model eventually, but right now the newer models have some annoying deficiencies, so the traditional "gnu89" model ends up being the preferred one. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Singed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-09Linux 3.18-rc4v3.18-rc4Linus Torvalds
2014-11-02Linux 3.18-rc3v3.18-rc3Linus Torvalds
