commit d0115552cdb0b4d4146975889fee2e9355515c4b upstream.
Sam Ravnborg says:
"We have several architectures that plays strange games with $(CC) and
$(CROSS_COMPILE).
So we need to postpone any use of $(call cc-option..) until we have
included the arch specific Makefile so we try with the correct $(CC)
version."
Requested-by: Sam Ravnborg <sam@ravnborg.org>
commit 68df3755e383e6fecf2354a67b08f92f18536594 upstream.
This makes sure that gcc doesn't try to optimize away wrapping
arithmetic, which the kernel occasionally uses for overflow testing, ie
things like
if (ptr + offset < ptr)
which technically is undefined for non-unsigned types. See
http://bugzilla.kernel.org/show_bug.cgi?id=12597
for details.
Not all versions of gcc support it, so we need to make it conditional
(it looks like it was introduced in gcc-3.4).
Reminded-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Currently source files in the Documentation/ sub-dir can easily bit-rot
since they are not generally buildable, either because they are hidden in
text files or because there are no Makefile rules for them. This needs to
be fixed so that the source files remain usable and good examples of code
instead of bad examples.
Add the ability to build source files that are in the Documentation/ dir.
Add to Kconfig as "BUILD_DOCSRC" config symbol.
Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the
Documentation/ sources. Or enable BUILD_DOCSRC in the *config system.
However, this symbol depends on HEADERS_CHECK since the header files need
to be installed (for userspace builds).
Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32,
sparc64, powerpc, sh, m68k, & mips.
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
It's a problem about cscope target of kernel Makefile, and the cscope
plugin of emacs:
1. `make cscope` will generate cscope.files cscope.{in,po,}.out;
2. the cscope plugin expect a cscope.out.{in,po,};
3. the default `cscope -b` would generate cscope.{in,po,}.out;
There are three approach to solve it:
1. modify the cscope C code;
2. modify the cscope emacs plugin lisp code;
3. modify the Makefile;
I have tried to communicate with the cscope upstream, but later I
realize the third approach is most meaningful.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
With a make O=... build kbuild would only create
the include2/asm symlink for archs that not yet
had moved headers to include/$ARCH/include
There is no longer any reason to avoid the symlink
for archs that has moved their headers so create it
unconditionally.
This fixes arm because kbuild checked for include/asm-$ARCH/errno.h
and that file was not present for arm but the platform files
are not yet moved.
We used include/asm-$ARCH/system.h to check if
we should create a symlink in include2 directory with
make O=... builds.
But um does not have such a file thus build filed.
Let's try anohter filename:
$ ls -d include/asm-* | wc -l
21
$ ls -d include/asm-*/errno.h | wc -l
21
Cc: Jeff Dike <jdike@addtoit.com>
The majority of this patch was created by the following script:
ASM=arch/sparc/include/asm
mkdir -p $ASM
git mv include/asm-sparc64/ftrace.h $ASM
git rm include/asm-sparc64/*
git mv include/asm-sparc/* $ASM
sed -ie 's/asm-sparc64/asm/g' $ASM/*
sed -ie 's/asm-sparc/asm/g' $ASM/*
The rest was an update of the top-level Makefile to use sparc
for header files when sparc64 is being build.
And a small fixlet to pick up the correct unistd.h from
sparc64 code.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (25 commits)
setlocalversion: do not describe if there is nothing to describe
kconfig: fix typos: "Suport" -> "Support"
kconfig: make defconfig is no longer chatty
kconfig: make oldconfig is now less chatty
kconfig: speed up all*config + randconfig
kconfig: set all new symbols automatically
kconfig: add diffconfig utility
kbuild: remove Module.markers during mrproper
kbuild: sparse needs CF not CHECKFLAGS
kernel-doc: handle/strip __init
vmlinux.lds: move __attribute__((__cold__)) functions back into final .text section
init: fix URL of "The GNU Accounting Utilities"
kbuild: add arch/$ARCH/include to search path
kbuild: asm symlink support for arch/$ARCH/include
kbuild: support arch/$ARCH/include for tags, cscope
kbuild: prepare headers_* for arch/$ARCH/include
kbuild: install all headers when arch is changed
kbuild: make clean removes *.o.* as well
kbuild: optimize headers_* targets
kbuild: only one call for include/ in make headers_*
This patch conclude the support for
arch/$ARCH/include
Note: The individual architectures will most likely require
a few minor patches to support locating header files in
arch/$ARCH/include
Testing shows that it worked out-of-the-box for sparc.
x86 required a few trivial changes in the arch
specific Makefile and a few include paths had to be adjusted.
Adjust the asm symlink support so we do not create the
symlink unless really needed.
We check the precense of include/asm-$ARCH by checking
for the system.h file. We may end up with a stale directory
so it is not enough to check if the directory is present.
Factor out the headers_*_all support to a seperate
shell script and add support for arch specific
header files can be located in either
arch/$ARCH/include/asm
or
include/asm-$ARCH/
In "make help" always display the headers_* targets.
Those are left presumably from aborted ccache(1) compilations:
arch/x86/kernel/.tmp_io_apic_64.o.T5veul
arch/x86/kvm/.tmp_x86.o.SZWn69
arch/x86/mm/.tmp_pgtable.o.sL1LTf
drivers/ieee1394/.tmp_ieee1394_transactions.o.bUj6o1
drivers/infiniband/hw/mlx4/.tmp_main.o.vy0ep6
BTW, with git there is nice way to check for such nuisainces:
make mrproper
git-ls-files -o
should give empty output.
More precise wildcard spec from: Jan Engelhardt <jengelh@medozas.de>
Cc: Jan Engelhardt <jengelh@medozas.de>
