path: root/Makefile
2012-03-04Linux 2.6.32.58v2.6.32.58Greg Kroah-Hartman
2012-02-13Linux 2.6.32.57v2.6.32.57Greg Kroah-Hartman
2012-02-03Linux 2.6.32.56v2.6.32.56Greg Kroah-Hartman
2012-01-25Linux 2.6.32.55v2.6.32.55Greg Kroah-Hartman
2012-01-12Linux 2.6.32.54v2.6.32.54Greg Kroah-Hartman
2012-01-06Linux 2.6.32.53v2.6.32.53Greg Kroah-Hartman
2012-01-03Linux 2.6.32.52v2.6.32.52Greg Kroah-Hartman
2011-12-21Linux 2.6.32.51v2.6.32.51Greg Kroah-Hartman
2011-12-09Linux 2.6.32.50v2.6.32.50Greg Kroah-Hartman
2011-11-26Linux 2.6.32.49v2.6.32.49Greg Kroah-Hartman
2011-11-26kbuild: Fix passing -Wno-* options to gcc 4.4+Michal Marek
commit 8417da6f2128008c431c7d130af6cd3d9079922e upstream. Starting with 4.4, gcc will happily accept -Wno-<anything> in the cc-option test and complain later when compiling a file that has some other warning. This rather unexpected behavior is intentional as per http://gcc.gnu.org/PR28322, so work around it by testing for support of the opposite option (without the no-). Introduce a new Makefile function cc-disable-warning that does this and update two uses of cc-option in the toplevel Makefile. Reported-and-tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0Dave Jones
commit af0e5d565d2fffcd97d1e2d89669d627cc04e8b8 upstream. Disable the new -Wunused-but-set-variable that was added in gcc 4.6.0 It produces more false positives than useful warnings. This can still be enabled using W=1 [gregkh - No it can not for 2.6.32, but we don't care] Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Tested-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-08Linux 2.6.32.48v2.6.32.48Greg Kroah-Hartman
2011-11-07Linux 2.6.32.47v2.6.32.47Greg Kroah-Hartman
2011-08-29Linux 2.6.32.46v2.6.32.46Greg Kroah-Hartman
2011-08-15Linux 2.6.32.45v2.6.32.45Greg Kroah-Hartman
2011-08-08Linux 2.6.32.44v2.6.32.44Greg Kroah-Hartman
2011-07-13Linux 2.6.32.43v2.6.32.43Greg Kroah-Hartman
2011-06-23Linux 2.6.32.42v2.6.32.42Greg Kroah-Hartman
2011-05-23Linux 2.6.32.41v2.6.32.41Greg Kroah-Hartman
2011-05-09Linux 2.6.32.40v2.6.32.40Greg Kroah-Hartman
2011-04-22Linux 2.6.32.39v2.6.32.39Greg Kroah-Hartman
2011-04-15Linux 2.6.32.38v2.6.32.38Greg Kroah-Hartman
2011-04-14Linux 2.6.32.37v2.6.32.37Greg Kroah-Hartman
2011-03-27Linux 2.6.32.36v2.6.32.36Greg Kroah-Hartman
2011-03-24Linux 2.6.32.35v2.6.32.35Greg Kroah-Hartman
2011-03-23Linux 2.6.32.34v2.6.32.34Greg Kroah-Hartman
2011-03-14Linux 2.6.32.33v2.6.32.33Greg Kroah-Hartman
2011-03-07Linux 2.6.32.32v2.6.32.32Greg Kroah-Hartman
2011-03-03Linux 2.6.32.31v2.6.32.31Greg Kroah-Hartman
2011-03-02Linux 2.6.32.30v2.6.32.30Greg Kroah-Hartman
2011-02-17Linux 2.6.32.29v2.6.32.29Greg Kroah-Hartman
2011-01-07Linux 2.6.32.28v2.6.32.28Greg Kroah-Hartman
2010-12-09Linux 2.6.32.27v2.6.32.27Greg Kroah-Hartman
2010-11-22Linux 2.6.32.26v2.6.32.26Greg Kroah-Hartman
2010-10-28Linux 2.6.32.25v2.6.32.25Greg Kroah-Hartman
2010-10-01Linux 2.6.32.24v2.6.32.24Greg Kroah-Hartman
2010-09-26Linux 2.6.32.23v2.6.32.23Greg Kroah-Hartman
2010-09-20Linux 2.6.32.22v2.6.32.22Greg Kroah-Hartman
2010-08-26Linux 2.6.32.21v2.6.32.21Greg Kroah-Hartman
2010-08-20Linux 2.6.32.20v2.6.32.20Greg Kroah-Hartman
2010-08-13Linux 2.6.32.19v2.6.32.19Greg Kroah-Hartman
2010-08-10Linux 2.6.32.18v2.6.32.18Greg Kroah-Hartman
2010-08-02Linux 2.6.32.17v2.6.32.17Greg Kroah-Hartman
2010-07-05Linux 2.6.32.16v2.6.32.16Greg Kroah-Hartman
2010-06-01Linux 2.6.32.15v2.6.32.15Greg Kroah-Hartman
2010-05-26Linux 2.6.32.14v2.6.32.14Greg Kroah-Hartman
2010-05-12Linux 2.6.32.13v2.6.32.13Greg Kroah-Hartman
2010-04-26Linux 2.6.32.12v2.6.32.12Greg Kroah-Hartman
2010-04-01Linux 2.6.32.11v2.6.32.11Greg Kroah-Hartman
