path: root/Makefile
2009-02-22Linux 2.6.29-rc6v2.6.29-rc6Linus Torvalds
2009-02-15kbuild: create the source symlink earlier in the objdirAndi Kleen
It's useful to already have the source symlink in a objdir when one just runs make *config. Then one can do mkdir obj-allyes cd obj-allyes make -C ../sourcedir O=$(pwd) allyesconfig ./source/scripts/config --disable debug_info make CC=icecc -j18 without having to interrupt the make first just to get the source symlink. Signed-off-by: Andi Kleen <ak@linux.intel.com> [sam: deleted the other source symlink statement] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-13Linux 2.6.29-rc5v2.6.29-rc5Linus Torvalds
2009-02-08Linux 2.6.29-rc4v2.6.29-rc4Linus Torvalds
2009-01-28Linux 2.6.29-rc3v2.6.29-rc3Linus Torvalds
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: fix kbuild.txt typos kbuild: print usage with no arguments in scripts/config Revert "kbuild: strip generated symbols from *.ko"
2009-01-26Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68k,m68knommu: merge header files Resolve trivial conflict in arch/m68knommu/include/asm/Kbuild
2009-01-16Linux 2.6.29-rc2v2.6.29-rc2Linus Torvalds
2009-01-16m68k,m68knommu: merge header filesSam Ravnborg
Merge header files for m68k and m68knommu to the single location: arch/m68k/include/asm The majority of this patch was the result of the script that is included in the changelog below. The script was originally written by Arnd Bergman and exten by me to cover a few more files. When the header files differed the script uses the following: The original m68k file is named <file>_mm.h [mm for memory manager] The m68knommu file is named <file>_no.h [no for no memory manager] The files uses the following include guard: This include gaurd works as the m68knommu toolchain set the __uClinux__ symbol - so this should work in userspace too. Merging the header files for m68k and m68knommu exposes the (unexpected?) ABI differences thus it is easier to actually identify these and thus to fix them. The commit has been build tested with both a m68k and a m68knommu toolchain - with success. The commit has also been tested with "make headers_check" and this patch fixes make headers_check for m68knommu. The script used: TARGET=arch/m68k/include/asm SOURCE=arch/m68knommu/include/asm INCLUDE="cachectl.h errno.h fcntl.h hwtest.h ioctls.h ipcbuf.h \ linkage.h math-emu.h md.h mman.h movs.h msgbuf.h openprom.h \ oplib.h poll.h posix_types.h resource.h rtc.h sembuf.h shmbuf.h \ shm.h shmparam.h socket.h sockios.h spinlock.h statfs.h stat.h \ termbits.h termios.h tlb.h types.h user.h" EQUAL="auxvec.h cputime.h device.h emergency-restart.h futex.h \ ioctl.h irq_regs.h kdebug.h local.h mutex.h percpu.h \ sections.h topology.h" NOMUUFILES="anchor.h bootstd.h coldfire.h commproc.h dbg.h \ elia.h flat.h m5206sim.h m520xsim.h m523xsim.h m5249sim.h \ m5272sim.h m527xsim.h m528xsim.h m5307sim.h m532xsim.h \ m5407sim.h m68360_enet.h m68360.h m68360_pram.h m68360_quicc.h \ m68360_regs.h MC68328.h MC68332.h MC68EZ328.h MC68VZ328.h \ mcfcache.h mcfdma.h mcfmbus.h mcfne.h mcfpci.h mcfpit.h \ mcfsim.h mcfsmc.h mcftimer.h mcfuart.h mcfwdebug.h \ nettel.h quicc_simple.h smp.h" FILES="atomic.h bitops.h bootinfo.h bug.h bugs.h byteorder.h cache.h \ cacheflush.h checksum.h current.h delay.h div64.h \ dma-mapping.h dma.h elf.h entry.h fb.h fpu.h hardirq.h hw_irq.h io.h \ irq.h kmap_types.h machdep.h mc146818rtc.h mmu.h mmu_context.h \ module.h page.h page_offset.h param.h pci.h pgalloc.h \ pgtable.h processor.h ptrace.h scatterlist.h segment.h \ setup.h sigcontext.h siginfo.h signal.h string.h system.h swab.h \ thread_info.h timex.h tlbflush.h traps.h uaccess.h ucontext.h \ unaligned.h unistd.h" mergefile() { BASE=${1%.h} git mv ${SOURCE}/$1 ${TARGET}/${BASE}_no.h git mv ${TARGET}/$1 ${TARGET}/${BASE}_mm.h cat << EOF > ${TARGET}/$1 EOF git add ${TARGET}/$1 } set -e mkdir -p ${TARGET} git mv include/asm-m68k/* ${TARGET} rmdir include/asm-m68k git rm ${SOURCE}/Kbuild for F in $INCLUDE $EQUAL; do git rm ${SOURCE}/$F done for F in $NOMUUFILES; do git mv ${SOURCE}/$F ${TARGET}/$F done for F in $FILES ; do mergefile $F done rmdir arch/m68knommu/include/asm rmdir arch/m68knommu/include Cc: Arnd Bergmann <arnd@arndb.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-01-14Revert "kbuild: strip generated symbols from *.ko"Sam Ravnborg
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483. And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL") 9bb482476c6c9d1ae033306440c51ceac93ea80c These stripping patches has caused a set of issues: 1) People have reported compatibility issues with binutils due to lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2 Reported by: Wenji 2) ccache and distcc no longer works as expeced Reported by: Ted, Roland, + others 3) The installed modules increased a lot in size Reported by: Ted, Davej + others Reported-by: Wenji Huang <wenji.huang@oracle.com> Reported-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-10Linux 2.6.29-rc1v2.6.29-rc1Linus Torvalds
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: fix typos (s/bin_shipped/bin.o_shipped/) in Documentation kbuild: add a symlink to the source for separate objdirs kconfig: add script to manipulate .config files on the command line kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscope bootchart: improve output based on Dave Jones' feedback fix modules_install via NFS qnx: include <linux/types.h> for definitions of __[us]{8,16,32,64} types
2009-01-07kbuild: add a symlink to the source for separate objdirsAndi Kleen
I have some scripts which need to map back to the source directory from an objdir. This was so far done by parsing the Makefile, but the Makefile format changes occasionally and breaks my scripts then. To make this more reliable add a "source" symlink back. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-06trivial: chack -> check typo fix in main MakefileAnisse Astier
Trivial one letter spelling in main Makefile Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-02kbuild: disable sparse warning "returning void-valued expression"Hannes Eder
The sparse warning -Wreturn-void ("returning void-valued expression") is off by default, but it is enabled with -Wall, so add -Wno-return-void to CHECKFLAGS to disable it. Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/sparc64/kernel/idprom.c
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (25 commits) allow stripping of generated symbols under CONFIG_KALLSYMS_ALL kbuild: strip generated symbols from *.ko kbuild: simplify use of genksyms kernel-doc: check for extra kernel-doc notations kbuild: add headerdep used to detect inclusion cycles in header files kbuild: fix string equality testing in tags.sh kbuild: fix make tags/cscope kbuild: fix make incompatibility kbuild: remove TAR_IGNORE setlocalversion: add git-svn support setlocalversion: print correct subversion revision scripts: improve the decodecode script scripts/package: allow custom options to rpm genksyms: allow to ignore symbol checksum changes genksyms: track symbol checksum changes tags and cscope support really belongs in a shell script kconfig: fix options to check-lxdialog.sh kbuild: gen_init_cpio expands shell variables in file names remove bashisms from scripts/extract-ikconfig kbuild: teach mkmakfile to be silent ...
2008-12-24Linux 2.6.28v2.6.28Linus Torvalds
Happy holidays..
2008-12-19allow stripping of generated symbols under CONFIG_KALLSYMS_ALLJan Beulich
Building upon parts of the module stripping patch, this patch introduces similar stripping for vmlinux when CONFIG_KALLSYMS_ALL=y. Using CONFIG_KALLSYMS_STRIP_GENERATED reduces the overhead of CONFIG_KALLSYMS_ALL from 245k/310k to 65k/80k for the (i386/x86-64) kernels I tested with. The patch also does away with the need to special case the kallsyms- internal symbols by making them available even in the first linking stage. While it is a generated file, the patch includes the changes to scripts/genksyms/keywords.c_shipped, as I'm unsure what the procedure here is. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-19kbuild: strip generated symbols from *.koJan Beulich
This patch changes the way __crc_ symbols are being resolved from using ld to do so to using the assembler, thus allowing these symbols to be marked local (the linker creates then as global ones) and hence allow stripping (for modules) or ignoring (for vmlinux) them. While at this, also strip other generated symbols during module installation. One potentially debatable point is the handling of the flags passeed to gcc when translating the intermediate assembly file into an object: passing $(c_flags) unchanged doesn't work as gcc passes --gdwarf2 to gas whenever is sees any -g* option, even for -g0, and despite the fact that the compiler would have already produced all necessary debug info in the C->assembly translation phase. I took the approach of just filtering out all -g* options, but an alternative to such negative filtering might be to have a positive filter which might, in the ideal case allow just all the -Wa,* options to pass through. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-18Linux 2.6.28-rc9v2.6.28-rc9Linus Torvalds
2008-12-18kbuild: add headerdep used to detect inclusion cycles in header filesVegard Nossum
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-13kbuild: fix make incompatibilitySam Ravnborg
"Paul Smith" <psmith@gnu.org> reported that we would fail to build with a new check that may be enabled in an upcoming version of make. The error was: Makefile:442: *** mixed implicit and normal rules. Stop. The problem is that we did stuff like this: config %config: ... The solution was simple - the above was split into two with identical prerequisites and commands. With only three lines it was not worth to try to avoid the duplication. Cc: "Paul Smith" <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-10Linux 2.6.28-rc8v2.6.28-rc8Linus Torvalds
2008-12-04sparc,sparc64: unify MakefileSam Ravnborg
To unify Makefile for sparc and sparc64 a few other steps was needed: 1) separate defconfig files for sparc and sparc64 is required, so locate these in arch/sparc/configs 2) removoval of hack in toplevel Makefile to deal with that headers was in a separate directory compared to the rest The unification of the Makefile required usage of several foo-$(CONFIG_SPARCnn) += due to a few directories pending unification. This will be cleaned up when we unify the remaining directories. Included in this patch are the deletion of a few files in sparc64 as they are no longer needed: Makefile + Kconfig. arch/sparc64/ will after this patch is applied only have four directories (prom, lib, kernel, boot) Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03tags and cscope support really belongs in a shell scriptSam Ravnborg
as they do not benefit from the make functionality. Moving the support to a shell script has several benefits: - The readability of the code has increased a lot - More people is able to extend the tags support - We see less changes to the top-level Makefile The shell script version includes improvements from: Alexey Dobriyan <adobriyan@gmail.com> (jump to kconfig symbols) Alexey Dobriyan <adobriyan@gmail.com> (drop ./ in paths) Ian Campbell <ijc@hellion.org.uk> (simplified find algorithms) This version has a few caveats: => It does not support ALLSOURCE_ARCHS - it is easy to add if it is really used => It assumes all archs have moved to arch/$ARCH/include - until that happens we have a few additional hits in the archs Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Tested-by: Ian Campbell <ijc@hellion.org.uk>
2008-12-03kbuild: use KECHO convenience echoMike Frysinger
Convert a few echos in the build system to new $(kecho) so we get correct output according to build verbosity. Signed-off-by: Mike Frysinger <vapier@gentoo.org> [sam: added kecho in a few more places for O=... builds] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-03kbuild: expand -I in KBUILD_CPPFLAGSSam Ravnborg
kbuild failed to expand include flags in KBUILD_CPPFLAGS resulting in code like this in arch Makefiles: ifeq ($(KBUILD_SRC),) KBUILD_CPPFLAGS += -Iinclude/foo else KBUILD_CPPFLAGS += -I$(srctree)/include/foo endif Move use of LINUXINCLUDE into Makefile.lib to allow us to expand -I directives of KBUILD_CPPFLAGS so we can avoid the above code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-01Linux 2.6.28-rc7v2.6.28-rc7Linus Torvalds
2008-11-20Linux 2.6.28-rc6v2.6.28-rc6Linus Torvalds
2008-11-15Linux 2.6.28-rc5v2.6.28-rc5Linus Torvalds
2008-11-09Linux 2.6.28-rc4v2.6.28-rc4Linus Torvalds
2008-11-02Linux v2.6.28-rc3v2.6.28-rc3Linus Torvalds
2008-10-29kbuild: do not include arch/<ARCH>/include/asm in find-sources twice.Ian Campbell
Architectures which have moved their includes to arch/<ARCH>/include now list the headers twice in the source listing used by "make cscope" and friends, causing those tools to list symbols twice. Skipping these files in the ALLSOURCE_ARCHS pass rather than removing the ALLINCLUDE_ARCHS pass preserves the semantics of the later. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-10-29kbuild: improve check-symlinkSam Ravnborg
o if include/asm point to a nonexisting directory remove the asm symlink o if include/asm is a directory error out This fixes a situation where one could be left with a symlink to asm-x86 but that directory no longer exist and thus the build would error out. include/asm may be a directory if the kernel tree has been copied Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-10-27Merge commit 'v2.6.28-rc2' into tracing/urgentIngo Molnar
2008-10-26Linux 2.6.28-rc2v2.6.28-rc2Linus Torvalds
.. fix all the worst problems in -rc1
2008-10-23Linux 2.6.28-rc1v2.6.28-rc1Linus Torvalds
2008-10-22x86, um: get rid of arch/um/Kconfig.archAl Viro
Teach scripts/kconfig/Makefile and top-level Makefile that arch/*/Makefile is allowed to say Kconfig := <whatever I want instead of arch/blah/Kconfig>. Rewrite arch/um/Kconfig and arch/um/Kconfig.<subarch> so that the latter would be top-level one (and include the pieces of the former). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-20ftrace: rename FTRACE to FUNCTION_TRACERSteven Rostedt
Due to confusion between the ftrace infrastructure and the gcc profiling tracer "ftrace", this patch renames the config options from FTRACE to FUNCTION_TRACER. The other two names that are offspring from FTRACE DYNAMIC_FTRACE and FTRACE_MCOUNT_RECORD will stay the same. This patch was generated mostly by script, and partially by hand. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-09Linux 2.6.27v2.6.27Linus Torvalds
2008-10-06Linux 2.6.27-rc9v2.6.27-rc9Linus Torvalds
2008-09-29Linux 2.6.27-rc8v2.6.27-rc8Linus Torvalds
2008-09-21Linux 2.6.27-rc7v2.6.27-rc7Linus Torvalds
2008-09-09Linux 2.6.27-rc6v2.6.27-rc6Linus Torvalds
2008-08-28Linux 2.6.27-rc5v2.6.27-rc5Linus Torvalds
2008-08-20Linux v2.6.27-rc4v2.6.27-rc4Linus Torvalds
2008-08-12Linux 2.6.27-rc3v2.6.27-rc3Linus Torvalds
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-06kbuild: a better way to generate cscope database changeDenis ChengRq
It's a problem about cscope target of kernel Makefile, and the cscope plugin of emacs: 1. `make cscope` will generate cscope.files cscope.{in,po,}.out; 2. the cscope plugin expect a cscope.out.{in,po,}; 3. the default `cscope -b` would generate cscope.{in,po,}.out; There are three approach to solve it: 1. modify the cscope C code; 2. modify the cscope emacs plugin lisp code; 3. modify the Makefile; I have tried to communicate with the cscope upstream, but later I realize the third approach is most meaningful. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
