path: root/Makefile
2014-10-19Linux 3.18-rc1v3.18-rc1Linus Torvalds
2014-10-14Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - fix for handling dependencies of *-objs targets by Masahiro Yamada - lots of cleanups in the kbuild machinery, also by Masahiro - fixes for the kconfig build to use an UTF-8 capable ncurses library if possible and to build on not-so-standard installs - some more minor fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Do not reference *-n variables in the Makefile kbuild: simplify build, clean, modbuiltin shorthands kbuild: arm: Do not define "comma" twice kbuild: remove obj-n and lib-n handling kbuild: remove unnecessary variable initializaions kbuild: remove unnecessary "obj- := dummy.o" trick kbuild: handle C=... and M=... after entering into build directory kbuild: use $(Q) for sub-make target kbuild: fake the "Entering directory ..." message more simply kconfig/lxdialog: get ncurses CFLAGS with pkg-config kconfig: nconfig: fix multi-byte UTF handling kconfig: lxdialog: fix spelling kbuild: Make scripts executable kbuild: remove redundant clean-files from scripts/kconfig/Makefile kbuild: refactor script/kconfig/Makefile kbuild: handle the dependency of multi-objs hostprogs appropriately kbuild: handle multi-objs dependency appropriately
2014-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc Pull documentation updates from Jiri Kosina: "Updates to kernel documentation. I took this over (hopefully temporarily) from Randy who was not willing to maintain it any longer. This pile mostly is a relay of queue that Randy already had in his tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc: Documentation: fix broken v4l-utils URL Documentation: update include path for mpssd Documentation: correct parameter error for dma_mapping_error MAINTAINERS: update location of linux-doc tree Documentation: remove networking/.gitignore tools: add more endian.h macros Make Documenation depend on headers_install Docs: this_cpu_ops: remove redundant add forms Documentation: disable vdso_test to avoid breakage with old glibc Documentation: update vDSO makefile to build portable examples Documentation: update .gitignore files Documentation: support glibc versions without htole macros v4l2-pci-skeleton: Only build if PCI is available Documentation: fix misc. warnings Documentation: make functions static to avoid prototype warnings Documentation: add makefiles for more targets Documentation: use subdir-y to avoid unnecessary built-in.o files
2014-10-07Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing major: support for compressing modules, and auto-tainting params. PS. My virtio-next tree is empty: DaveM took the patches I had. There might be a virtio-rng starvation fix, but so far it's a bit voodoo so I will get to that in the next two days or it will wait" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: moduleparam: Resolve missing-field-initializer warning kbuild: handle module compression while running 'make modules_install'. modinst: wrap long lines in order to enhance cmd_modules_install modsign: lookup lines ending in .ko in .mod files modpost: simplify file name generation of *.mod.c files modpost: reduce visibility of symbols and constify r/o arrays param: check for tainting before calling set op. drm/i915: taint the kernel if unsafe module parameters are set module: add module_param_unsafe and module_param_named_unsafe module: make it possible to have unsafe, tainting module params module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
2014-10-05Linux 3.17v3.17Linus Torvalds
2014-10-02kbuild: Do not reference *-n variables in the MakefileMichal Marek
Kconfig options are either 'y', 'm', or undefined. Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-10-02kbuild: simplify build, clean, modbuiltin shorthandsMasahiro Yamada
$(if $(KBUILD_SRC),$(srctree)/) was a useful strategy to omit a long absolute path for in-source-tree build prior to commit 890676c65d699db3ad82e7dddd0cf8fb449031af (kbuild: Use relative path when building in the source tree). Now $(srctree) is "." when building in the source tree. It would not be annoying to add "$(srctree)/" all the time. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-10-01kbuild: handle C=... and M=... after entering into build directoryMasahiro Yamada
This commit avoids processing C=... and M=... twice when O=... is also given. Besides, we can also remove KBUILD_EXTMOD="$(KBUILD_EXTMOD)" in the sub-make target. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-10-01kbuild: use $(Q) for sub-make targetMasahiro Yamada
Since commit 066b7ed9558087a7957a1128f27d7a3462ff117f (kbuild: Do not print the build directory with make -s), "Q" is defined above the sub-make target. This commit takes advantage of that and replaces "$(if $(KBUILD_VERBOSE:1=),@)" with "$(Q)". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-10-01kbuild: fake the "Entering directory ..." message more simplyMasahiro Yamada
Commit c2e28dc975ea87feed84415006ae143424912ac7 (kbuild: Print the name of the build directory) added a gimmick to show the "Entering directory ...". Instead of echoing the hard-coded message (that is, we need to know the exact message), moving --no-print-directory would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-09-28Linux 3.17-rc7v3.17-rc7Linus Torvalds
2014-09-26Make Documenation depend on headers_installPeter Foley
Cc: rdunlap@infradead.org Cc: linux-doc@vger.kernel.org Cc: sudeep.dutt@intel.com Cc: nikhil.rao@intel.com Cc: ashutosh.dixit@intel.com Cc: akpm@linux-foundation.org Cc: gregkh@linuxfoundation.org Signed-off-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-09-21Linux 3.17-rc6v3.17-rc6Linus Torvalds
2014-09-14Linux 3.17-rc5v3.17-rc5Linus Torvalds
2014-09-07Linux 3.17-rc4v3.17-rc4Linus Torvalds
2014-08-31Linux 3.17-rc3v3.17-rc3Linus Torvalds
2014-08-27kbuild: handle module compression while running 'make modules_install'.Bertrand Jacquin
Since module-init-tools (gzip) and kmod (gzip and xz) support compressed modules, it could be useful to include a support for compressing modules right after having them installed. Doing this in kbuild instead of per distro can permit to make this kind of usage more generic. This patch add a Kconfig entry to "Enable loadable module support" menu and let you choose to compress using gzip (default) or xz. Both gzip and xz does not used any extra -[1-9] option since Andi Kleen and Rusty Russell prove no gain is made using them. gzip is called with -n argument to avoid storing original filename inside compressed file, that way we can save some more bytes. On a v3.16 kernel, 'make allmodconfig' generated 4680 modules for a total of 378MB (no strip, no sign, no compress), the following table shows observed disk space gain based on the allmodconfig .config : | time | +-------------+-----------------+ | manual .ko | make | size | percent | compression | modules_install | | gain +-------------+-----------------+------+-------- - | | 18.61s | 378M | GZIP | 3m16s | 3m37s | 102M | 73.41% XZ | 5m22s | 5m39s | 77M | 79.83% The gain for restricted environnement seems to be interesting while uncompress can be time consuming but happens only while loading a module, that is generally done only once. This is fully compatible with signed modules while the signed module is compressed. module-init-tools or kmod handles decompression and provide to other layer the uncompressed but signed payload. Reviewed-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Bertrand Jacquin <beber@meleeweb.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2014-08-25Linux 3.17-rc2v3.17-rc2Linus Torvalds
2014-08-16Linux 3.17-rc1v3.17-rc1Linus Torvalds
2014-08-14Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "This is the non-critical part of kbuild for 3.17-rc1: - make help hint to use make -s with make kernelrelease et al. - moved a kbuild document to Documentation/kbuild where it belongs - four new Coccinelle scripts, one dropped and one fixed - new make kselftest target to run various tests on the kernel" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: kselftest - new make target to build and run kernel selftests Coccinelle: Script to replace if and BUG with BUG_ON Coccinelle: Script to detect incorrect argument to sizeof Coccinelle: Script to use ARRAY_SIZE instead of division of two sizeofs Coccinelle: Script to detect cast after memory allocation coccinelle/null: solve parse error Documentation: headers_install.txt is part of kbuild kbuild: make -s should be used with kernelrelease/kernelversion/image_name
2014-08-14Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - make clean also considers $(extra-m) and $(extra-) to be consistent - cleanup and fixes in scripts/Makefile.host - allow to override the name of the Python 2 executable with make PYTHON=... (only needed for ia64 in practice) - option to split debugingo into *.dwo files to save disk space if the compiler supports it (CONFIG_DEBUG_INFO_SPLIT) - option to use dwarf4 debuginfo if the compiler supports it (CONFIG_DEBUG_INFO_DWARF4) - fix for disabling certain warnings with clang - fix for unneeded rebuild with dash when a command contains backslashes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix handling of backslashes in *.cmd files kbuild, LLVMLinux: Supress warnings unless W=1-3 Kbuild: Add a option to enable dwarf4 v2 kbuild: Support split debug info v4 kbuild: allow to override Python command name kbuild: clean-up and bug fix of scripts/Makefile.host kbuild: clean up scripts/Makefile.host kbuild: drop shared library support from Makefile.host kbuild: fix a bug of C++ host program handling kbuild: fix a typo in scripts/Makefile.host scripts/Makefile.clean: clean also $(extra-m) and $(extra-)
2014-08-07kbuild: kselftest - new make target to build and run kernel selftestsShuah Khan
Add a new make target "kselftest" to enable kernel testing. This new target builds and runs kernel selftests. Running as root is recommended for a complete test run as some tests don't run when run by non-root user. Build, install, and boot kernel before running kselftest on it. Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-08-06./Makefile: tell gcc optimizer to never introduce new data racesJiri Kosina
We have been chasing a memory corruption bug, which turned out to be caused by very old gcc (4.3.4), which happily turned conditional load into a non-conditional one, and that broke correctness (the condition was met only if lock was held) and corrupted memory. This particular problem with that particular code did not happen when never gccs were used. I've brought this up with our gcc folks, as I wanted to make sure that this can't really happen again, and it turns out it actually can. Quoting Martin Jambor <mjambor@suse.cz>: "More current GCCs are more careful when it comes to replacing a conditional load with a non-conditional one, most notably they check that a store happens in each iteration of _a_ loop but they assume loops are executed. They also perform a simple check whether the store cannot trap which currently passes only for non-const variables. A simple testcase demonstrating it on an x86_64 is for example the following: $ cat cond_store.c int g_1 = 1; int g_2[1024] __attribute__((section ("safe_section"), aligned (4096))); int c = 4; int __attribute__ ((noinline)) foo (void) { int l; for (l = 0; (l != 4); l++) { if (g_1) return l; for (g_2[0] = 0; (g_2[0] >= 26); ++g_2[0]) ; } return 2; } int main (int argc, char* argv[]) { if (mprotect (g_2, sizeof(g_2), PROT_READ) == -1) { int e = errno; error (e, e, "mprotect error %i", e); } foo (); __builtin_printf("OK\n"); return 0; } /* EOF */ $ ~/gcc/trunk/inst/bin/gcc cond_store.c -O2 --param allow-store-data-races=0 $ ./a.out OK $ ~/gcc/trunk/inst/bin/gcc cond_store.c -O2 --param allow-store-data-races=1 $ ./a.out Segmentation fault The testcase fails the same at least with 4.9, 4.8 and 4.7. Therefore I would suggest building kernels with this parameter set to zero. I also agree with Jikos that the default should be changed for -O2. I have run most of the SPEC 2k6 CPU benchmarks (gamess and dealII failed, at -O2, not sure why) compiled with and without this option and did not see any real difference between respective run-times" Hopefully the default will be changed in newer gccs, but let's force it for kernel builds so that we are on a safe side even when older gcc are used. The code in question was out-of-tree printk-in-NMI (yeah, surprise suprise, once again) patch written by Petr Mladek, let me quote his comment from our internal bugzilla: "I have spent few days investigating inconsistent state of kernel ring buffer. It went out that it was caused by speculative store generated by gcc-4.3.4. The problem is in assembly generated for make_free_space(). The functions is called the following way: + vprintk_emit(); + log = MAIN_LOG; // with logbuf_lock or log = NMI_LOG; // with nmi_logbuf_lock cont_add(log, ...); + cont_flush(log, ...); + log_store(log, ...); + log_make_free_space(log, ...); If called with log = NMI_LOG then only nmi_log_* global variables are safe to modify but the generated code does store also into (main_)log_* global variables: <log_make_free_space>: 55 push %rbp 89 f6 mov %esi,%esi 48 8b 05 03 99 51 01 mov 0x1519903(%rip),%rax # ffffffff82620868 <nmi_log_next_id> 44 8b 1d ec 98 51 01 mov 0x15198ec(%rip),%r11d # ffffffff82620858 <log_next_idx> 8b 35 36 60 14 01 mov 0x1146036(%rip),%esi # ffffffff8224cfa8 <log_buf_len> 44 8b 35 33 60 14 01 mov 0x1146033(%rip),%r14d # ffffffff8224cfac <nmi_log_buf_len> 4c 8b 2d d0 98 51 01 mov 0x15198d0(%rip),%r13 # ffffffff82620850 <log_next_seq> 4c 8b 25 11 61 14 01 mov 0x1146111(%rip),%r12 # ffffffff8224d098 <log_buf> 49 89 c2 mov %rax,%r10 48 21 c2 and %rax,%rdx 48 8b 1d 0c 99 55 01 mov 0x155990c(%rip),%rbx # ffffffff826608a0 <nmi_log_buf> 49 c1 ea 20 shr $0x20,%r10 48 89 55 d0 mov %rdx,-0x30(%rbp) 44 29 de sub %r11d,%esi 45 29 d6 sub %r10d,%r14d 4c 8b 0d 97 98 51 01 mov 0x1519897(%rip),%r9 # ffffffff82620840 <log_first_seq> eb 7e jmp ffffffff81107029 <log_make_free_space+0xe9> [...] 85 ff test %edi,%edi # edi = 1 for NMI_LOG 4c 89 e8 mov %r13,%rax 4c 89 ca mov %r9,%rdx 74 0a je ffffffff8110703d <log_make_free_space+0xfd> 8b 15 27 98 51 01 mov 0x1519827(%rip),%edx # ffffffff82620860 <nmi_log_first_id> 48 8b 45 d0 mov -0x30(%rbp),%rax 48 39 c2 cmp %rax,%rdx # end of loop 0f 84 da 00 00 00 je ffffffff81107120 <log_make_free_space+0x1e0> [...] 85 ff test %edi,%edi # edi = 1 for NMI_LOG 4c 89 0d 17 97 51 01 mov %r9,0x1519717(%rip) # ffffffff82620840 <log_first_seq> ^^^^^^^^^^^^^^^^^^^^^^^^^^ KABOOOM 74 35 je ffffffff81107160 <log_make_free_space+0x220> It stores log_first_seq when edi == NMI_LOG. This instructions are used also when edi == MAIN_LOG but the store is done speculatively before the condition is decided. It is unsafe because we do not have "logbuf_lock" in NMI context and some other process migh modify "log_first_seq" in parallel" I believe that the best course of action is both - building kernel (and anything multi-threaded, I guess) with that optimization turned off - persuade gcc folks to change the default for future releases Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Martin Jambor <mjambor@suse.cz> Cc: Petr Mladek <pmladek@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Marek Polacek <polacek@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Steven Noonan <steven@uplinklabs.net> Cc: Richard Biener <richard.guenther@gmail.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06./Makefile: explain stack-protector-strong CONFIG logicKees Cook
This adds a hopefully helpful comment above the (seemingly weird) compiler flag selection logic. Signed-off-by: Kees Cook <keescook@chromium.org> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-05kbuild, LLVMLinux: Supress warnings unless W=1-3Behan Webster
clang has more warnings enabled by default. Turn them off unless W is set. This patch fixes a logic bug where warnings in clang were disabled when W was set. Signed-off-by: Behan Webster <behanw@converseincode.com> Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de> Signed-off-by: Mark Charlebois <charlebm@gmail.com> Cc: bp@alien8.de Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-08-03Linux 3.16v3.16Linus Torvalds
2014-07-30Kbuild: Add a option to enable dwarf4 v2Andi Kleen
I found that a lot of unresolvable variables when using gdb on the kernel become resolvable when dwarf4 is enabled. So add a Kconfig flag to enable it. It definitely increases the debug information size, but on the other hand this isn't so bad when debug fusion is used. v2: Use cc-option Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-30kbuild: Support split debug info v4Andi Kleen
This is an alternative approach to lower the overhead of debug info (as we discussed a few days ago) gcc 4.7+ and newer binutils have a new "split debug info" debug info model where the debug info is only written once into central ".dwo" files. This avoids having to copy it around multiple times, from the object files to the final executable. It lowers the disk space requirements. In addition it defaults to compressed debug data. More details here: http://gcc.gnu.org/wiki/DebugFission This patch adds a new option to enable it. It has to be an option, because it'll undoubtedly break everyone's debuginfo packaging scheme. gdb/objdump/etc. all still work, if you have new enough versions. I don't see big compile wins (maybe a second or two faster or so), but the object dirs with debuginfo get significantly smaller. My standard kernel config (slightly bigger than defconfig) shrinks from 2.9G disk space to 1.1G objdir (with non reduced debuginfo). I presume if you are IO limited the compile time difference will be larger. Only problem I've seen so far is that it doesn't play well with older versions of ccache (apparently fixed, see https://bugzilla.samba.org/show_bug.cgi?id=10005) v2: various fixes from Dirk Gouders. Improve commit message slightly. v3: Fix clean rules and improve Kconfig slightly v4: Fix merge error in last version (Sam Ravnborg) Clarify description that it mainly helps disk size. Cc: Dirk Gouders <dirk@gouders.net> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-27Linux 3.16-rc7v3.16-rc7Linus Torvalds
2014-07-26Fix gcc-4.9.0 miscompilation of load_balance() in schedulerLinus Torvalds
Michel Dänzer and a couple of other people reported inexplicable random oopses in the scheduler, and the cause turns out to be gcc mis-compiling the load_balance() function when debugging is enabled. The gcc bug apparently goes back to gcc-4.5, but slight optimization changes means that it now showed up as a problem in 4.9.0 and 4.9.1. The instruction scheduling problem causes gcc to schedule a spill operation to before the stack frame has been created, which in turn can corrupt the spilled value if an interrupt comes in. There may be other effects of this bug too, but that's the code generation problem seen in Michel's case. This is fixed in current gcc HEAD, but the workaround as suggested by Markus Trippelsdorf is pretty simple: use -fno-var-tracking-assignments when compiling the kernel, which disables the gcc code that causes the problem. This can result in slightly worse debug information for variable accesses, but that is infinitely preferable to actual code generation problems. Doing this unconditionally (not just for CONFIG_DEBUG_INFO) also allows non-debug builds to verify that the debug build would be identical: we can do export GCC_COMPARE_DEBUG=1 to make gcc internally verify that the result of the build is independent of the "-g" flag (it will make the compiler build everything twice, toggling the debug flag, and compare the results). Without the "-fno-var-tracking-assignments" option, the build would fail (even with 4.8.3 that didn't show the actual stack frame bug) with a gcc compare failure. See also gcc bugzilla: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=61801 Reported-by: Michel Dänzer <michel@daenzer.net> Suggested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Jakub Jelinek <jakub@redhat.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-20Linux 3.16-rc6v3.16-rc6Linus Torvalds
2014-07-18kbuild: allow to override Python command nameMasahiro Yamada
The specification of Python 3 is largely different from that of Python 2. For example, arch/ia64/scripts/unwcheck.py seems to be written in Python 2, not compatible with Python 3. It is not a good idea to invoke python scripts with the hard-coded command name 'python'. The command 'python' could possibly be Python 3 on some systems. For that case, it is reasonable to allow to override the command name by giving 'PYTHON=python2' from the command line. The 'python' in arch/ia64/Makefile should be replaced with '$(PYTHON)'. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: linux-ia64@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-13Linux 3.16-rc5v3.16-rc5Linus Torvalds
2014-07-11kbuild: make -s should be used with kernelrelease/kernelversion/image_nameMichal Marek
If .config has been edited, there will be a silentoldconfig run: $ make defconfig ... $ make kernelrelease scripts/kconfig/conf --silentoldconfig Kconfig 3.16.0-rc1+ Recently, kbuild started to print the name of the build directory when using O= $ make O=build kernelrelease make[1]: Entering directory `/dev/shm/mmarek/linux-2.6/build' 3.16.0-rc1+ Since these targets are often used in scripts, add a hint to use make -s to the help text. Suggested-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-10Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fixes from Michal Marek: "Three more fixes for the relative build dir feature: - Shut up make -s again - Fix for rpm/deb/tar-pkg with O=<subdir> - Fix for CONFIG_EXTRA_FIRMWARE" * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: firmware: Create directories for external firmware kbuild: Fix packaging targets with relative $(srctree) kbuild: Do not print the build directory with make -s
2014-07-06Linux 3.16-rc4v3.16-rc4Linus Torvalds
2014-07-04kbuild: Fix packaging targets with relative $(srctree)Michal Marek
All other users of Makefile.build set $(obj) to the name of the subdirectory to build. Do the same for the packaging targets, otherwise the build fails if $(srctree) is a relative directory: $ make O=build tar-pkg make[1]: Entering directory `/home/mmarek/linux-2.6/build' CHK include/config/kernel.release ../scripts/Makefile.build:44: ../../scripts/package/Makefile: No such file or directory make[2]: *** No rule to make target `../../scripts/package/Makefile'. Stop. Fixes: 9da0763b ("kbuild: Use relative path when building in a subdir of the source tree") Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-04kbuild: Do not print the build directory with make -sMichal Marek
Commit c2e28dc9 (kbuild: Print the name of the build directory) prints the name of the build directory for O= builds, but we should not be doing this in make -s mode, so that commands like make -s O=<dir> kernelrelease can be used by scripts. This matches the behavior of make itself, where the -s option implies --no-print-directory. Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-03Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fix from Michal Marek: "There is one more fix for the relative paths series from -rc1: Print the path to the build directory at the start of the build, so that editors and IDEs can match the relative paths to source files" * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Print the name of the build directory
2014-07-03kbuild: Print the name of the build directoryMichal Marek
With commit 9da0763b (kbuild: Use relative path when building in a subdir of the source tree), the compiler messages include relative paths. These are however relative to the build directory, not the directory where make was started. Print the "Entering directory ..." message once, so that IDEs/editors can find the source files. Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-29Linux 3.16-rc3v3.16-rc3Linus Torvalds
2014-06-21Linux 3.16-rc2v3.16-rc2Linus Torvalds
2014-06-15Linux 3.16-rc1v3.16-rc1Linus Torvalds
2014-06-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: "Kbuild changes for v3.16-rc1: - cross-compilation fix so that cc-option is testing the right compiler - Fix for make defconfig all - Using relative paths to the object and source directory where possible, plus fixes for the fallout of the change - several cleanups in the Makefiles and scripts The powerpc fix is from today, because it was only discovered recently. The rest has been in linux-next for some time" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: powerpc: Avoid circular dependency with zImage.% kbuild: create include/config directory in scripts/kconfig/Makefile kbuild: do not create include/linux directory Makefile: Fix unrecognized cross-compiler command line options kbuild: do not add "selinux" to subdir- twice um: Fix for relative objtree when generating x86 headers kbuild: Use relative path when building in a subdir of the source tree kbuild: Use relative path when building in the source tree kbuild: Use relative path for $(objtree) firmware: Use $(quote) in the Makefile firmware: Simplify directory creation kbuild: trivial - fix comment block indent kbuild: trivial - remove trailing spaces kbuild: support simultaneous "make %config" and "make all" kbuild: move extra gcc checks to scripts/Makefile.extrawarn
2014-06-10kbuild: create include/config directory in scripts/kconfig/MakefileMasahiro Yamada
The directory include/config is used only for silentoldconfig, localmodconfig, localyesconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-10kbuild: do not create include/linux directoryMasahiro Yamada
There are no generated files under include/linux directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-09Makefile: Fix unrecognized cross-compiler command line optionsGeert Uytterhoeven
On architectures that setup CROSS_COMPILE in their arch/*/Makefile (arc, blackfin, m68k, mips, parisc, score, sh, tile, unicore32, xtensa), cc-option and cc-disable-warning may check against the wrong compiler, causing errors like cc1: error: unrecognized command line option "-Wno-maybe-uninitialized" if the host gcc supports a compiler option, while the cross compiler doesn't support that option. Move all logic using cc-option or cc-disable-warning below the inclusion of the arch's Makefile to fix this. Introduced by - commit e74fc973b6e531fef1fce8b101ffff05ecfb774c ("Turn off -Wmaybe-uninitialized when building with -Os"), - commit 61163efae02040f66a95c8ed17f4407951ba58fa ("kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang"). As -Wno-maybe-uninitialized requires a quite recent gcc (gcc 4.6.3 on Ubuntu 12.04 LTS doesn't support it), this only showed up recently (gcc 4.8.2 on Ubuntu 14.04 LTS does support it). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-08Merge tag 'llvmlinux-for-v3.16' of ↵Linus Torvalds
git://git.linuxfoundation.org/llvmlinux/kernel Pull LLVM patches from Behan Webster: "Next set of patches to support compiling the kernel with clang. They've been soaking in linux-next since the last merge window. More still in the works for the next merge window..." * tag 'llvmlinux-for-v3.16' of git://git.linuxfoundation.org/llvmlinux/kernel: arm, unwind, LLVMLinux: Enable clang to be used for unwinding the stack ARM: LLVMLinux: Change "extern inline" to "static inline" in glue-cache.h all: LLVMLinux: Change DWARF flag to support gcc and clang net: netfilter: LLVMLinux: vlais-netfilter crypto: LLVMLinux: aligned-attribute.patch
2014-06-08Linux 3.15v3.15Linus Torvalds
2014-06-07all: LLVMLinux: Change DWARF flag to support gcc and clangBehan Webster
Both gcc (well, actually gnu as) and clang support the "-Wa,-gdwarf-2" option (though clang does not support "-Wa,--gdwarf-2"). Since these flags are equivalent in meaning, this patch uses the one which is better supported across compilers. Signed-off-by: Behan Webster <behanw@converseincode.com>
