Setting LC_CTYPE=C breaks localized messages in some setups. With only
LC_COLLATE=C and LC_NUMERIC=C, we get almost all we need, except for not
so defined character classes and tolower()/toupper(). The former is not
a big issue, because we can assume that e.g. [:alpha:] will always
include a-zA-Z and we only ever process ASCII input. The latter seems
only affect arch/sh/tools/gen-mach-types, which we can handle separately.
So after this patch the meaning of ranges like [a-z], the behavior of
sort and join, etc. should be the same everywhere and at the same time
gcc should be able to print localized waring and error messages.
LC_NUMERIC=C might not be necessary, but setting it doesn't hurt.
Reported-by: Simon Horman <horms@verge.net.au>
Reported-by: Sergei Trofimovich <slyfox@inbox.ru>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Tested-by: Simon Horman <horms@verge.net.au>
Tested-by: Masami Hiramatsu <mhiramat@redhat.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system
Makefile: Unexport LC_ALL instead of clearing it
x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk
x86: Reenable TSC sync check at boot, even with NONSTOP_TSC
x86: Don't use POSIX character classes in gen-insn-attr-x86.awk
Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C
x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA
x86: Fix checking of SRAT when node 0 ram is not from 0
x86, cpuid: Add "volatile" to asm in native_cpuid()
x86, msr: msrs_alloc/free for CONFIG_SMP=n
x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space
x86: Add IA32_TSC_AUX MSR and use it
x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers
initramfs: add missing decompressor error check
bzip2: Add missing checks for malloc returning NULL
bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
Apparently not all versions of glibc and utilities treat an empty
LC_ALL as nonexistent, causing error messages to be garbled. Instead,
explicitly unexport it from the environment.
Reported-and-tested-by: Masami Hiramatsu <mhiramat@redhat.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
LKML-Reference: <4B2AC394.4030108@redhat.com>
Cc: Michal Marek <mmarek@sues.cz>
Cc: Roland Dreier <rdreier@cisco.com>
There are a number of common Unix constructs like character ranges in
grep/sed/awk which don't work as expected with LC_COLLATE set to other
than C. Similarly, set LC_CTYPE and LC_NUMERIC to C to avoid other
nasty surprises.
In order to make sure these actually take effect we also have to
clear LC_ALL.
Acked-by: Michal Marek <mmarek@sues.cz>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Roland Dreier <rdreier@cisco.com>
LKML-Reference: <4B2A1761.4070904@suse.cz>
Fix typo / thinko in commit bc081dd.
To make it easier for module-init-tools and scripts like mkinitrd to
distinguish builtin and missing modules, install a modules.builtin file
listing all builtin modules. This is done by generating an additional
config file (tristate.conf) with tristate options set to uppercase 'Y'
or 'M'. If we source that config file, the builtin modules appear in
obj-Y.
The toplevel Makefile creates the directory if it runs silentoldconfig
automatically, but if run manually, it fails:
$ make mrproper
$ make defconfig && make silentoldconfig
*** Default configuration is based on 'x86_64_defconfig'
# configuration written to .config
scripts/kconfig/conf -s arch/x86/Kconfig
*** Error during update of the kernel configuration.
Move the mkdir command to the silentoldconfig target to make it work.
Drop Module.markers from cleaning list since marker
is removed.
Signed-off-by: Wenji Huang <wenji.huang@oracle.com>
Fix up all users of utsrelease.h
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
We no longer use this directory for generated files and
all architectures has moved their header files so no
symlink tricks are needed either.
Drop the symlink and drop the ARCH check.
If we really need to check that the SRCARCH has not changed
when we build a kernel we can add this check back - but then we will
find a more convenient way to store the info.
No architectures uses include/asm-$ARCH now.
So drop check for location of include files
There is no longer any use of the include2/ directory.
The generated files has moved to include/generated.
Drop all references to said directory.
The simplest method was to add an extra asm-offsets.h
file in arch/$ARCH/include/asm that references the generated file.
We can now migrate the architectures one-by-one to reference
the generated file direct - and when done we can delete the
temporary arch/$ARCH/include/asm/asm-offsets.h file.
The namespace used in arch/$ARCH/include is different from
what is used in include/ except for the include/asm directory.
This patch gives the arch/$ARCH/include/asm directory priority
over include/asm.
When we add asm-offsets.h to arch/$ARCH/include/asm/ this
patch makes sure we pick up the arch specific version
and not the one we have in include/asm.
The situation with an asm-offsets.h file located in
both include/asm _and_ arch/$ARCH/include/asm will happen
when we move more files over to include/generated.
This happens because in some cases it is not practical
to rename all users so we simply add a file
in arch/$ARCH/include/asm that includes the generated version.
This is the solution we use for asm-offsets.h as an example.
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (40 commits)
tracing: Separate raw syscall from syscall tracer
ring-buffer-benchmark: Add parameters to set produce/consumer priorities
tracing, function tracer: Clean up strstrip() usage
ring-buffer benchmark: Run producer/consumer threads at nice +19
tracing: Remove the stale include/trace/power.h
tracing: Only print objcopy version warning once from recordmcount
tracing: Prevent build warning: 'ftrace_graph_buf' defined but not used
ring-buffer: Move access to commit_page up into function used
tracing: do not disable interrupts for trace_clock_local
ring-buffer: Add multiple iterations between benchmark timestamps
kprobes: Sanitize struct kretprobe_instance allocations
tracing: Fix to use __always_unused attribute
compiler: Introduce __always_unused
tracing: Exit with error if a weak function is used in recordmcount.pl
tracing: Move conditional into update_funcs() in recordmcount.pl
tracing: Add regex for weak functions in recordmcount.pl
tracing: Move mcount section search to front of loop in recordmcount.pl
tracing: Fix objcopy revision check in recordmcount.pl
tracing: Check absolute path of input file in recordmcount.pl
tracing: Correct the check for number of arguments in recordmcount.pl
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc
* 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc:
Makefile: Add -Wmising-prototypes to HOSTCFLAGS
oss: Mark loadhex static in hex2hex.c
dtc: Mark various internal functions static
dtc: Set "noinput" in the lexer to avoid an unused function
drm: radeon: Mark several functions static in mkregtable
arch/sparc/boot/*.c: Mark various internal functions static
arch/powerpc/boot/addRamDisk.c: Mark several internal functions static
arch/alpha/boot/tools/objstrip.c: Mark "usage" static
Documentation/vm/page-types.c: Declare checked_open static
genksyms: Mark is_reserved_word static
kconfig: Mark various internal functions static
kconfig: Make zconf.y work with current bison
If the user has an older version of objcopy, that can not handle
converting local symbols to global and vice versa, then some
functions will not be part of the dynamic function tracer. The current
code in recordmcount.pl will print a warning in this case. Unfortunately,
there exists lots of files that may have this issue with older objcopys
and this will cause a warning for every file compiled with this
issue.
This patch solves this overwhelming output by creating a
.tmp_quiet_recordmcount file on the first instance the warning is
encountered. The warning will not print if this file exists.
The temp file is deleted at the beginning of the compile to ensure that
the warning will happen once again on new compiles (because the issue
is still present).
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Now that all host programs use static for all private functions and
forward prototypes for all extern functions, add -Wmissing-prototypes to
HOSTCFLAGS in the hopes of keeping it that way.
All versions of GCC supported by the kernel handle -Wmissing-prototypes.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
kbuild: revert "save ARCH & CROSS_COMPILE ..."
warn about use of uninstalled kernel headers
kbuild: mkcompile_h: trivial cleanups
kbuild: fix warning when domainname is not available
kbuild: Fix size_append issue for bzip2/lzma kernel
kbuild,scripts: use non-builtin echo for '-e'
kbuild: fix the binrpm-pkg target to work with KBUILD_OUTPUT set
Revert commit 575543347b5baed0ca927cb90ba8807396fe9cc9
It caused following issues:
- On architectures where ARCH= setting is used to select between
32 and 64 bit this was no longer possible without "make mrproper"
- If ARCH was changed then kbuild refused to run "make mrproper"
because ARCH had changed
- When CROSS_COMPILE was changed people were asked to run "make mrproper"
but kbuild refused to run "make mrproper" because CROSS_COMPILE changed.
- Spaces in CROSS_COMPILE was not 'supported'
- If an non-existing ARCH= was used kbuild could get stuck
Lessons learned:
. Despite being simple and straghtforward people uses very different
approaches when building the kernel.
. CROSS_COMPILE is sometimes used for ccache despite cache being
only a CC frontend so one would have expected CC to be
used for this purpose.
. And obviously this was not tested widely enough.
Cc: Pavel Machek <pavel@ucw.cz>
I'm skipping -rc2 because the -rc1 Makefile mistakenly said -rc2, so in
order to avoid confusion, I'm jumping from -rc1 to -rc3. That way, when
'uname' (or an oops report) says 2.6.32-rc2, there's no confusion about
whether people perhaps meant -rc1 or -rc2.
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported:
Bash 4 filters out variables which contain a dot in them.
This happends to be the case of CPPFLAGS_vmlinux.lds.
This is rather unfortunate, as it now causes
build failures when using SHELL=/bin/bash to compile,
or when bash happens to be used by make (eg when it's /bin/sh)
Remove the common definition of CPPFLAGS_vmlinux.lds by
pushing relevant stuff to either Makefile.build or the
arch specific kernel/Makefile where we build the linker script.
This is also nice cleanup as we move the information out where
it is used.
Notes for the different architectures touched:
arm - we use an already exported symbol
cris - we use a config symbol aleady available
[Not build tested]
mips - the jiffies complexity has moved to vmlinux.lds.S where we need it.
Added a few variables to CPPFLAGS - they are only used by
the linker script.
[Not build tested]
powerpc - removed assignment that is not needed
[not build tested]
sparc - simplified it using $(BITS)
um - introduced a few new exported variables to deal with this
xtensa - added options to CPP invocation
[not build tested]
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Chris Zankel <chris@zankel.net>
