commit 3ce120b16cc548472f80cf8644f90eda958cf1b6 upstream.
It appears that hardened gentoo enables "-fstack-check" by default for
gcc.
That doesn't work _at_all_ for the kernel, because the kernel stack
doesn't act like a user stack at all: it's much smaller, and it doesn't
auto-expand on use. So the extra "probe one page below the stack" code
generated by -fstack-check just breaks the kernel in horrible ways,
causing infinite double faults etc.
[ I have to say, that the particular code gcc generates looks very
stupid even for user space where it works, but that's a separate
issue. ]
Reported-and-tested-by: Alexander Tsoy <alexander@tsoy.me>
Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de>
Cc: Jiri Kosina <jikos@kernel.org>
[ Upstream commit 433dc2ebe7d17dd21cba7ad5c362d37323592236 ]
Some $(call cc-option,...) are invoked very early, even before
KBUILD_CFLAGS, etc. are initialized.
The returned string from $(call cc-option,...) depends on
KBUILD_CPPFLAGS, KBUILD_CFLAGS, and GCC_PLUGINS_CFLAGS.
Since they are exported, they are not empty when the top Makefile
is recursively invoked.
The recursion occurs in several places. For example, the top
Makefile invokes itself for silentoldconfig. "make tinyconfig",
"make rpm-pkg" are the cases, too.
In those cases, the second call of cc-option from the same line
runs a different shell command due to non-pristine KBUILD_CFLAGS.
To get the same result all the time, KBUILD_* and GCC_PLUGINS_CFLAGS
must be initialized before any call of cc-option. This avoids
garbage data in the .cache.mk file.
Move all calls of cc-option below the config targets because target
compiler flags are unnecessary for Kconfig.
Reviewed-by: Douglas Anderson <dianders@chromium.org>
commit bd664f6b3e376a8ef4990f87d08271cc2d01ba9a upstream.
I made the mistake of upgrading my desktop to the new Fedora 26 that
comes with gcc-7.1.1.
There's nothing wrong per se that I've noticed, but I now have 1500
lines of warnings, mostly from the new format-truncation warning
triggering all over the tree.
We use 'snprintf()' and friends in a lot of places, and often know that
the numbers are fairly small (ie a controller index or similar), but gcc
doesn't know that, and sees an 'int', and thinks that it could be some
huge number. And then complains when our buffers are not able to fit
the name for the ten millionth controller.
These warnings aren't necessarily bad per se, and we probably want to
look through them subsystem by subsystem, but at least during the merge
window they just mean that I can't even see if somebody is introducing
any *real* problems when I pull.
So warnings disabled for now.
