commit 61754c18752ffb78145671e94f053fb202fff041 upstream.
Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command
line options), the arch Makefile is included earlier by the main
Makefile, preventing the arc architecture to set its -O3 compiler
option. Since there might be more use cases for an arch Makefile to
fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and
ARCH_CFLAGS variables that are appended to the respective kbuild
variables. The user still has the final say via the KCPPFLAGS, KAFLAGS
and KCFLAGS variables.
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Here is the first round of kbuild changes for v4.1-rc1:
- kallsyms fix for ARM and cleanup
- make dep(end) removed (developers have no sense of nostalgia these
days...)
- include Makefiles by relative path
- stop useless rebuilds of asm-offsets.h and bounds.h"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: kallsyms: drop special handling of pre-3.0 GCC symbols
Kbuild: kallsyms: ignore veneers emitted by the ARM linker
kbuild: ia64: use $(src)/Makefile.gate rather than particular path
kbuild: include $(src)/Makefile rather than $(obj)/Makefile
kbuild: use relative path more to include Makefile
kbuild: use relative path to include Makefile
kbuild: do not add $(bounds-file) and $(offsets-file) to targets
kbuild: remove warning about "make depend"
kbuild: Don't reset timestamps in include/generated if not needed
Pull core locking changes from Ingo Molnar:
"Main changes:
- jump label asm preparatory work for PowerPC (Anton Blanchard)
- rwsem optimizations and cleanups (Davidlohr Bueso)
- mutex optimizations and cleanups (Jason Low)
- futex fix (Oleg Nesterov)
- remove broken atomicity checks from {READ,WRITE}_ONCE() (Peter
Zijlstra)"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
powerpc, jump_label: Include linux/jump_label.h to get HAVE_JUMP_LABEL define
jump_label: Allow jump labels to be used in assembly
jump_label: Allow asm/jump_label.h to be included in assembly
locking/mutex: Further simplify mutex_spin_on_owner()
locking: Remove atomicy checks from {READ,WRITE}_ONCE
locking/rtmutex: Rename argument in the rt_mutex_adjust_prio_chain() documentation as well
locking/rwsem: Fix lock optimistic spinning when owner is not running
locking: Remove ACCESS_ONCE() usage
locking/rwsem: Check for active lock before bailing on spinning
locking/rwsem: Avoid deceiving lock spinners
locking/rwsem: Set lock ownership ASAP
locking/rwsem: Document barrier need when waking tasks
locking/futex: Check PF_KTHREAD rather than !p->mm to filter out kthreads
locking/mutex: Refactor mutex_spin_on_owner()
locking/mutex: In mutex_spin_on_owner(), return true when owner changes
To use jump labels in assembly we need the HAVE_JUMP_LABEL
define, so we select a fallback version if the toolchain does
not support them.
Modify linux/jump_label.h so it can be included by assembly
files. We also need to add -DCC_HAVE_ASM_GOTO to KBUILD_AFLAGS.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: benh@kernel.crashing.org
Cc: catalin.marinas@arm.com
Cc: davem@davemloft.net
Cc: heiko.carstens@de.ibm.com
Cc: jbaron@akamai.com
Cc: linux@arm.linux.org.uk
Cc: linuxppc-dev@lists.ozlabs.org
Cc: liuj97@gmail.com
Cc: mgorman@suse.de
Cc: mmarek@suse.cz
Cc: mpe@ellerman.id.au
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: rostedt@goodmis.org
Cc: schwidefsky@de.ibm.com
Cc: will.deacon@arm.com
Link: http://lkml.kernel.org/r/1428551492-21977-2-git-send-email-anton@samba.org
Prior to this commit, it was impossible to use relative path to
include Makefiles from the top level Makefile because the option
"--include-dir=$(srctree)" becomes effective when Make enters into
sub Makefiles.
To use relative path in any places, this commit moves the option
above the "sub-make" target.
Enough time has passed since "make depend" was deprecated.
Nobody would be in trouble without this hint.
.. after extensive statistical analysis of my G+ polling, I've come to
the inescapable conclusion that internet polls are bad.
Big surprise.
But "Hurr durr I'ma sheep" trounced "I like online polls" by a 62-to-38%
margin, in a poll that people weren't even supposed to participate in.
Who can argue with solid numbers like that? 5,796 votes from people who
can't even follow the most basic directions?
In contrast, "v4.0" beat out "v3.20" by a slimmer margin of 56-to-44%,
but with a total of 29,110 votes right now.
Now, arguably, that vote spread is only about 3,200 votes, which is less
than the almost six thousand votes that the "please ignore" poll got, so
it could be considered noise.
But hey, I asked, so I'll honor the votes.
- several cleanups in kbuild
- serialize multiple *config targets so that 'make defconfig kvmconfig'
works
- The cc-ifversion macro got support for an else-branch
kbuild,gcov: simplify kernel/gcov/Makefile more
kbuild: allow cc-ifversion to have the argument for false condition
kbuild,gcov: remove unnecessary workaround
kbuild: do not add $(call ...) to invoke cc-version or cc-fullversion
kbuild: fix cc-ifversion macro
kbuild: drop $(version_h) from MRPROPER_FILES
kbuild: use mixed-targets when two or more config targets are given
kbuild: remove redundant line from bounds.h/asm-offsets.h
kbuild: merge bounds.h and asm-offsets.h rules
kbuild: Drop support for clean-rule
This provides the basic infrastructure to load kernel-specific python
helper scripts when debugging the kernel in gdb.
The loading mechanism is based on gdb loading for <objfile>-gdb.py when
opening <objfile>. Therefore, this places a corresponding link to the
main helper script into the output directory that contains vmlinux.
The main scripts will pull in submodules containing Linux specific gdb
commands and functions. To avoid polluting the source directory with
compiled python modules, we link to them from the object directory.
Due to gdb.parse_and_eval and string redirection for gdb.execute, we
depend on gdb >= 7.2.
This feature is enabled via CONFIG_GDB_SCRIPTS.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Acked-by: Michal Marek <mmarek@suse.cz> [kbuild stuff]
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Ben Widawsky <ben@bwidawsk.net>
Cc: Borislav Petkov <bp@suse.de>
Kernel Address sanitizer (KASan) is a dynamic memory error detector. It
provides fast and comprehensive solution for finding use-after-free and
out-of-bounds bugs.
KASAN uses compile-time instrumentation for checking every memory access,
therefore GCC > v4.9.2 required. v4.9.2 almost works, but has issues with
putting symbol aliases into the wrong section, which breaks kasan
instrumentation of globals.
This patch only adds infrastructure for kernel address sanitizer. It's
not available for use yet. The idea and some code was borrowed from [1].
Basic idea:
The main idea of KASAN is to use shadow memory to record whether each byte
of memory is safe to access or not, and use compiler's instrumentation to
check the shadow memory on each memory access.
Address sanitizer uses 1/8 of the memory addressable in kernel for shadow
memory and uses direct mapping with a scale and offset to translate a
memory address to its corresponding shadow address.
Here is function to translate address to corresponding shadow address:
unsigned long kasan_mem_to_shadow(unsigned long addr)
return (addr >> KASAN_SHADOW_SCALE_SHIFT) + KASAN_SHADOW_OFFSET;
where KASAN_SHADOW_SCALE_SHIFT = 3.
So for every 8 bytes there is one corresponding byte of shadow memory.
The following encoding used for each shadow byte: 0 means that all 8 bytes
of the corresponding memory region are valid for access; k (1 <= k <= 7)
means that the first k bytes are valid for access, and other (8 - k) bytes
are not; Any negative value indicates that the entire 8-bytes are
inaccessible. Different negative values used to distinguish between
different kinds of inaccessible memory (redzones, freed memory) (see
mm/kasan/kasan.h).
To be able to detect accesses to bad memory we need a special compiler.
Such compiler inserts a specific function calls (__asan_load*(addr),
__asan_store*(addr)) before each memory access of size 1, 2, 4, 8 or 16.
These functions check whether memory region is valid to access or not by
checking corresponding shadow memory. If access is not valid an error
printed.
Historical background of the address sanitizer from Dmitry Vyukov:
"We've developed the set of tools, AddressSanitizer (Asan),
ThreadSanitizer and MemorySanitizer, for user space. We actively use
them for testing inside of Google (continuous testing, fuzzing,
running prod services). To date the tools have found more than 10'000
scary bugs in Chromium, Google internal codebase and various
open-source projects (Firefox, OpenSSL, gcc, clang, ffmpeg, MySQL and
lots of others): [2] [3] [4].
The tools are part of both gcc and clang compilers.
We have not yet done massive testing under the Kernel AddressSanitizer
(it's kind of chicken and egg problem, you need it to be upstream to
start applying it extensively). To date it has found about 50 bugs.
Bugs that we've found in upstream kernel are listed in [5].
We've also found ~20 bugs in out internal version of the kernel. Also
people from Samsung and Oracle have found some.
As others noted, the main feature of AddressSanitizer is its
performance due to inline compiler instrumentation and simple linear
shadow memory. User-space Asan has ~2x slowdown on computational
programs and ~2x memory consumption increase. Taking into account that
kernel usually consumes only small fraction of CPU and memory when
running real user-space programs, I would expect that kernel Asan will
have ~10-30% slowdown and similar memory consumption increase (when we
finish all tuning).
I agree that Asan can well replace kmemcheck. We have plans to start
working on Kernel MemorySanitizer that finds uses of unitialized
memory. Asan+Msan will provide feature-parity with kmemcheck. As
others noted, Asan will unlikely replace debug slab and pagealloc that
can be enabled at runtime. Asan uses compiler instrumentation, so even
if it is disabled, it still incurs visible overheads.
Asan technology is easily portable to other architectures. Compiler
instrumentation is fully portable. Runtime has some arch-dependent
parts like shadow mapping and atomic operation interception. They are
relatively easy to port."
Comparison with other debugging features:
KMEMCHECK:
- KASan can do almost everything that kmemcheck can. KASan uses
compile-time instrumentation, which makes it significantly faster than
kmemcheck. The only advantage of kmemcheck over KASan is detection of
uninitialized memory reads.
Some brief performance testing showed that kasan could be
x500-x600 times faster than kmemcheck:
$ netperf -l 30
MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost (127.0.0.1) port 0 AF_INET
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
no debug: 87380 16384 16384 30.00 41624.72
kasan inline: 87380 16384 16384 30.00 12870.54
kasan outline: 87380 16384 16384 30.00 10586.39
kmemcheck: 87380 16384 16384 30.03 20.23
- Also kmemcheck couldn't work on several CPUs. It always sets
number of CPUs to 1. KASan doesn't have such limitation.
DEBUG_PAGEALLOC:
- KASan is slower than DEBUG_PAGEALLOC, but KASan works on sub-page
granularity level, so it able to find more bugs.
SLUB_DEBUG (poisoning, redzones):
- SLUB_DEBUG has lower overhead than KASan.
- SLUB_DEBUG in most cases are not able to detect bad reads,
KASan able to detect both reads and writes.
- In some cases (e.g. redzone overwritten) SLUB_DEBUG detect
bugs only on allocation/freeing of object. KASan catch
bugs right before it will happen, so we always know exact
place of first bad read/write.
[1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel
[2] https://code.google.com/p/address-sanitizer/wiki/FoundBugs
[3] https://code.google.com/p/thread-sanitizer/wiki/FoundBugs
[4] https://code.google.com/p/memory-sanitizer/wiki/FoundBugs
[5] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel#Trophies
Based on work by Andrey Konovalov.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Pekka Enberg <penberg@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
- The remaining patches for the z13 machine support: kernel build
option for z13, the cache synonym avoidance, SMT support,
compare-and-delay for spinloops and the CES5S crypto adapater.
- The ftrace support for function tracing with the gcc hotpatch option.
This touches common code Makefiles, Steven is ok with the changes.
- The hypfs file system gets an extension to access diagnose 0x0c data
in user space for performance analysis for Linux running under z/VM.
- The iucv hvc console gets wildcard spport for the user id filtering.
- The cacheinfo code is converted to use the generic infrastructure.
- Cleanup and bug fixes.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits)
s390/process: free vx save area when releasing tasks
s390/hypfs: Eliminate hypfs interval
s390/hypfs: Add diagnose 0c support
s390/cacheinfo: don't use smp_processor_id() in preemptible context
s390/zcrypt: fixed domain scanning problem (again)
s390/smp: increase maximum value of NR_CPUS to 512
s390/jump label: use different nop instruction
s390/jump label: add sanity checks
s390/mm: correct missing space when reporting user process faults
s390/dasd: cleanup profiling
s390/dasd: add locking for global_profile access
s390/ftrace: hotpatch support for function tracing
ftrace: let notrace function attribute disable hotpatching if necessary
ftrace: allow architectures to specify ftrace compile options
s390: reintroduce diag 44 calls for cpu_relax()
s390/zcrypt: Add support for new crypto express (CEX5S) adapter.
s390/zcrypt: Number of supported ap domains is not retrievable.
s390/spinlock: add compare-and-delay to lock wait loops
s390/tape: remove redundant if statement
s390/hvc_iucv: add simple wildcard matches to the iucv allow filter
If the kernel is compiled with function tracer support the -pg compile option
is passed to gcc to generate extra code into the prologue of each function.
This patch replaces the "open-coded" -pg compile flag with a CC_FLAGS_FTRACE
makefile variable which architectures can override if a different option
should be used for code generation.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
The introduction of the uapi directories in v3.7-rc1 moved some of the
generated headers from arch/*/include/generated to the uapi directory,
keeping the #include directives intact.
This creates a problem when bisecting, because the unversioned files are
not cleaned automatically by git and the compiler might include stale
headers as a result. Instead of cleaning them in the Makefiles, promote
arch/*/include/generated/uapi in the search path. Under normal
circumstances, there is no overlap between this uapi subdirectory and
its parent, so the include choices remain the same. We keep
arch/*/include/generated/uapi in the USERINCLUDE variable so that it is
usable standalone.
Note that we cannot completely swap the order of the uapi and
kernel-only directories, since the headers in include/uapi/asm-generic
are meant to be wrapped by their include/asm-generic counterparts when
building kernel code.
Reported-by: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Reported-by: David Drysdale <dmd@lurklurk.org>
Now $(version_h) is include/generated/uapi/linux/version.h.
$(version_h) in MRPROPER_FILES is redundant because it is covered
by include/generated in MRPROPER_DIRS.
"make kvmconfig" expects that the .config has already been created,
but some people might want to create the .config and run kvmconfig
in one shot command, like this:
$ make defconfig kvmconfig
To make sure this command works correctly even if -j* option is set,
we must handle them one by one.
This commit turns on mixed-targets when $(MAKECMDGOALS) includes
at least one config target and also includes another target.
"Here are the kbuild changes for v3.19-rc1:
- Cleanups and deduplication in the main Makefile and
scripts/Makefile.*
- Sort the output of *config targets in make help
- Old <linux/version.h> is always removed to avoid a surprise during
bisecting
- Warning fix in kconfig"
kbuild: remove redundant -rR flag of hdr-inst
kbuild: Fix make help-<board series> on powerpc
kbuild: Automatically remove stale <linux/version.h> file
kconfig: Fix warning "‘jump’ may be used uninitialized"
Makefile: sort list of defconfig targets in make help output
kbuild: Remove duplicate $(cmd) definition in Makefile.clean
kbuild: collect shorthands into scripts/Kbuild.include
make ARCH=powerpc help-<board series> should not require a cofigured
source tree. Also, sort the boards in the output.
