path: root/README
2006-01-16[PATCH] README updatedXose Vazquez Perez
Replace old information with newer from kernel.org Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] README: add info about -stable to README and point at ↵Jesper Juhl
applying-patches.txt Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] README doesn't mention bzip2 source tarballHorms
2005-09-22[PATCH] corrections to top-level READMERandy Dunlap
Corrections to the recent top-level README changes. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] README update from the stone agePaolo 'Blaisorblade' Giarrusso
We have no options which the user can set in the Makefile. Only the EXTRAVERSION, which is also useful in place of the "backup modules" suggestion. We don't have configuration options in the top Makefile. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] Add text for dealing with "dot releases" to READMEKurt Wall
The emergence of so-called "dot releases" that are non-incremental patches against a base kernel requires different handling of patches (revert previous patches before applying the newest one). This patch adds a paragrach to $TOPDIR/README explaining how to do deal with dot release patches. Signed-off-by: Kurt Wall <kwall@kurtwerks.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
