path: root/arch/alpha/kernel/core_t2.c
2012-03-28Disintegrate asm/system.h for AlphaDavid Howells
Disintegrate asm/system.h for Alpha. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-alpha@vger.kernel.org
2010-10-26alpha: use single HAE window on T2 core logic (gamma, sable)Ivan Kokshaysky
T2 are the only alpha SMP systems that do HAE switching at runtime, which is fundamentally racy on SMP. This patch limits MMIO space on T2 to HAE0 only, like we did on MCPCIA (rawhide) long ago. This leaves us with only 112 Mb of PCI MMIO (128 Mb HAE aperture minus 16 Mb reserved for EISA), but since linux PCI allocations are reasonably tight, it should be enough for sane hardware configurations. Also, fix a typo in MCPCIA_FROB_MMIO macro which shouldn't call set_hae() if MCPCIA_ONE_HAE_WINDOW is defined. It's more for correctness, as set_hae() is a no-op anyway in that case. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14alpha: Fix fallout from locking changesThomas Gleixner
spin_* functions are mostly static inline now. That causes the alpha compile to fail: CC arch/alpha/kernel/sys_sable.o cc1: warnings being treated as errors In file included from arch/alpha/kernel/sys_sable.c:25: arch/alpha/include/asm/core_t2.h: In function 't2_readb': arch/alpha/include/asm/core_t2.h:451: error: 'spinlock_check' is static but \ used in inline function 't2_readb' which is not static arch/alpha/include/asm/core_t2.h:456: error: 'spin_unlock_irqrestore' is \ static but used in inline function 't2_readb' which is not static That's caused by the "extern inline" magic which is used for the subarch specific read/write[bwl] functions. I tried to distangle the uncountable macro onion layers, but failed miserably. Last resort solution: switch the t2_hae_lock to raw_spinlock_t so the lock functions are pure macros and function calls again. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Richard Henderson <rth@twiddle.net> Cc: linux-alpha@vger.kernel.org
2008-06-20alpha: fix compile failures with gcc-4.3 (bug #10438)Ivan Kokshaysky
Vast majority of these build failures are gcc-4.3 warnings about static functions and objects being referenced from non-static (read: "extern inline") functions, in conjunction with our -Werror. We cannot just convert "extern inline" to "static inline", as people keep suggesting all the time, because "extern inline" logic is crucial for generic kernel build. So - just make sure that all callees of critical "extern inline" functions are also "extern inline"; - use "static inline", wherever it's possible. traps.c: work around gcc-4.3 being too smart about array bounds-checking. TODO: add "gnu_inline" attribute to all our "extern inline" functions to ensure desired behaviour with future compilers. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28alpha: remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ The change in pci-iommu,c should be safe as arena has not been assigned when we get to this point. Some were within #if 0 blocks, have changed them and left the blocks as they appear to be debugging infrastructure. A #define FN __FUNCTION__ was removed and occurances of FN were replaced with __func__ as well. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-08[PATCH] alpha pt_regs cleanups: machine_check()Al Viro
do set_irq_regs() in caller, kill pt_regs argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
