The bug was accidentally found by the following program:
#include <asm/sysinfo.h>
#include <asm/unistd.h>
#include <sys/syscall.h>
static int setsysinfo(unsigned long op, void *buffer, unsigned long size,
int *start, void *arg, unsigned long flag) {
return syscall(__NR_osf_setsysinfo, op, buffer, size, start, arg, flag);
int main(int argc, char **argv) {
short x[10];
unsigned int buf[2] = { SSIN_UACPROC, UAC_SIGBUS, };
setsysinfo(SSI_NVPAIRS, buf, 1, 0, 0, 0);
int *y = (int*) (x+1);
*y = 0;
return 0;
The program shoud fail on SIGBUS, but didn't.
The patch is a second part of userspace flag fix (commit 745dd2405e28
"Alpha: Rearrange thread info flags fixing two regressions").
Deleted outdated out-of-sync 'UAC_SHIFT' (the cause of bug) in favour of
'ALPHA_UAC_SHIFT'.
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
Acked-by: Michael Cree <mcree@orcon.net.nz>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Fix several security issues in Alpha-specific syscalls. Untested, but
mostly trivial.
1. Signedness issue in osf_getdomainname allows copying out-of-bounds
kernel memory to userland.
2. Signedness issue in osf_sysinfo allows copying large amounts of
3. Typo (?) in osf_getsysinfo bounds minimum instead of maximum copy
size, allowing copying large amounts of kernel memory to userland.
4. Usage of user pointer in osf_wait4 while under KERNEL_DS allows
privilege escalation via writing return value of sys_wait4 to kernel
memory.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
New helpers: user_statfs() and fd_statfs(), taking userland pathname and
descriptor resp. and filling struct kstatfs. Syscalls of statfs family
(native, compat and foreign - osf and hpux on alpha and parisc resp.)
switched to those. Removes some boilerplate code, simplifies cleanup
on errors...
Remove the leftover from the commit 14e2acd86865 ("select:
fix alpha OSF wrapper").
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
All uses of the BKL on alpha are totally bogus, nothing
is really protected by this. Remove the remaining users
so we don't have to mark alpha as 'depends on BKL'.
Cc: linux-alpha@vger.kernel.org
Acked-by: Richard Henderson <rth@twiddle.net>
Fix a comma that got accidentally deleted from sys_osf_statfs() leading to the
following warning:
arch/alpha/kernel/osf_sys.c: In function 'SYSC_osf_statfs':
arch/alpha/kernel/osf_sys.c:255: error: syntax error before 'buffer'
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
We'll need the path to implement the flags field for statvfs support.
We do have it available in all callers except:
- ecryptfs_statfs. This one doesn't actually need vfs_statfs but just
needs to do a caller to the lower filesystem statfs method.
- sys_ustat. Add a non-exported statfs_by_dentry helper for it which
doesn't won't be able to fill out the flags field later on.
In addition rename the helpers for statfs vs fstatfs to do_*statfs instead
of the misleading vfs prefix.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The initial -EINVAL value is overwritten by `retval = PTR_ERR(name)'. If
this isn't an error pointer and typenr is not 1, 6 or 9, then this retval,
a pointer cast to a long, is returned.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
New helper - sys_mmap_pgoff(); switch syscalls to using it.
The last user of do_pipe is in arch/alpha/, after replacing it with
do_pipe_flags, the do_pipe can be totally dropped.
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Convert OSF syscalls and add alpha specific SYSCALL_ALIAS() macro.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
* 'v28-range-hrtimers-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits)
hrtimers: add missing docbook comments to struct hrtimer
hrtimers: simplify hrtimer_peek_ahead_timers()
hrtimers: fix docbook comments
DECLARE_PER_CPU needs linux/percpu.h
hrtimers: fix typo
rangetimers: fix the bug reported by Ingo for real
rangetimer: fix BUG_ON reported by Ingo
rangetimer: fix x86 build failure for the !HRTIMERS case
select: fix alpha OSF wrapper
hrtimer: peek at the timer queue just before going idle
hrtimer: make the futex() system call use the per process slack value
hrtimer: make the nanosleep() syscall use the per process slack
hrtimer: fix signed/unsigned bug in slack estimator
hrtimer: show the timer ranges in /proc/timer_list
hrtimer: incorporate feedback from Peter Zijlstra
hrtimer: add a hrtimer_start_range() function
hrtimer: another build fix
hrtimer: fix build bug found by Ingo
hrtimer: make select() and poll() use the hrtimer range feature
It's not the final state, but it allows moving ->readdir() instances
to passing filldir return value to caller of vfs_readdir().
... alpha calls the core select code from inside it's architecture
code for emulating OSF; this patch makes it compile again
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Return value of filldir callback is just "should we stop here"; it's
not a usable channel for passing error values (i.e. ->readdir() will
forget anything except "is it non-zero").
* do not pass nameidata; struct path is all the callers want.
* switch to new helpers:
user_path_at(dfd, pathname, flags, &path)
user_path(pathname, &path)
user_lpath(pathname, &path)
user_path_dir(pathname, &path) (fail if not a directory)
The last 3 are trivial macro wrappers for the first one.
* remove nameidata in callers.
... instead of open-coding it
OSF/1 brk(2) was broken by following one-liner in sys_brk()
(commit 4cc6028d4040f95cdb590a87db478b42b8be0508):
- if (brk < mm->end_code)
+ if (brk < mm->start_brk)
goto out;
The problem is that osf_set_program_attributes()
does update mm->end_code, but not mm->start_brk,
which still contains inappropriate value left from
binary loader, so brk() always fails.
* Add path_put() functions for releasing a reference to the dentry and
vfsmount of a struct path in the right order
* Switch from path_release(nd) to path_put(&nd->path)
* Rename dput_path() to path_put_conditional()
[akpm@linux-foundation.org: fix cifs]
Signed-off-by: Jan Blunck <jblunck@suse.de>
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
Cc: <linux-fsdevel@vger.kernel.org>
Cc: Steven French <sfrench@us.ibm.com>
This is the central patch of a cleanup series. In most cases there is no good
reason why someone would want to use a dentry for itself. This series reflects
that fact and embeds a struct path into nameidata.
Together with the other patches of this series
- it enforced the correct order of getting/releasing the reference count on
<dentry,vfsmount> pairs
- it prepares the VFS for stacking support since it is essential to have a
struct path in every place where the stack can be traversed
- it reduces the overall code size:
without patch series:
5321639 858418 715768 6895825 6938d1 vmlinux
with patch series:
5320026 858418 715768 6894212 693284 vmlinux
This patch:
Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere.
[akpm@linux-foundation.org: fix smack]
Cc: Casey Schaufler <casey@schaufler-ca.com>
Remove now unnecessary inclusions of {asm,linux}/a.out.h.
[akpm@linux-foundation.org: fix alpha build]
Cc: <linux-arch@vger.kernel.org>
NR_OPEN (historically set to 1024*1024) actually forbids processes to open
more than 1024*1024 handles.
Unfortunatly some production servers hit the not so 'ridiculously high
value' of 1024*1024 file descriptors per process.
Changing NR_OPEN is not considered safe because of vmalloc space potential
exhaust.
This patch introduces a new sysctl (/proc/sys/fs/nr_open) wich defaults to
1024*1024, so that admins can decide to change this limit if their workload
needs it.
[akpm@linux-foundation.org: export it for sparc64]
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Spelling fixes in arch/alpha/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Implement utimensat(2) which is an extension to futimesat(2) in that it
a) supports nano-second resolution for the timestamps
b) allows to selectively ignore the atime/mtime value
c) allows to selectively use the current time for either atime or mtime
d) supports changing the atime/mtime of a symlink itself along the lines
of the BSD lutimes(3) functions
For this change the internally used do_utimes() functions was changed to
accept a timespec time value and an additional flags parameter.
Additionally the sys_utime function was changed to match compat_sys_utime
which already use do_utimes instead of duplicating the work.
Also, the completely missing futimensat() functionality is added. We have
such a function in glibc but we have to resort to using /proc/self/fd/* which
not everybody likes (chroot etc).
Test application (the syscall number will need per-arch editing):
#include <errno.h>
#include <fcntl.h>
#include <time.h>
#include <sys/time.h>
#include <stddef.h>
#include <syscall.h>
#define __NR_utimensat 280
#define UTIME_NOW ((1l << 30) - 1l)
#define UTIME_OMIT ((1l << 30) - 2l)
int
main(void)
int status = 0;
int fd = open("ttt", O_RDWR|O_CREAT|O_EXCL, 0666);
if (fd == -1)
error (1, errno, "failed to create test file \"ttt\"");
struct stat64 st1;
if (fstat64 (fd, &st1) != 0)
error (1, errno, "fstat failed");
struct timespec t[2];
t[0].tv_sec = 0;
t[0].tv_nsec = 0;
t[1].tv_sec = 0;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, AT_FDCWD, "ttt", t, 0) != 0)
error (1, errno, "utimensat failed");
struct stat64 st2;
if (fstat64 (fd, &st2) != 0)
if (st2.st_atim.tv_sec != 0 || st2.st_atim.tv_nsec != 0)
puts ("atim not reset to zero");
status = 1;
if (st2.st_mtim.tv_sec != 0 || st2.st_mtim.tv_nsec != 0)
puts ("mtim not reset to zero");
status = 1;
if (status != 0)
goto out;
t[0] = st1.st_atim;
t[1].tv_sec = 0;
t[1].tv_nsec = UTIME_OMIT;
if (st2.st_atim.tv_sec != st1.st_atim.tv_sec
|| st2.st_atim.tv_nsec != st1.st_atim.tv_nsec)
puts ("atim not set");
status = 1;
puts ("mtim changed from zero");
status = 1;
if (status != 0)
goto out;
t[0].tv_sec = 0;
t[0].tv_nsec = UTIME_OMIT;
t[1] = st1.st_mtim;
puts ("mtim changed from original time");
status = 1;
if (st2.st_mtim.tv_sec != st1.st_mtim.tv_sec
|| st2.st_mtim.tv_nsec != st1.st_mtim.tv_nsec)
puts ("mtim not set");
status = 1;
if (status != 0)
goto out;
sleep (2);
t[0].tv_sec = 0;
t[0].tv_nsec = UTIME_NOW;
t[1].tv_sec = 0;
t[1].tv_nsec = UTIME_NOW;
struct timeval tv;
gettimeofday(&tv,NULL);
if (st2.st_atim.tv_sec <= st1.st_atim.tv_sec
|| st2.st_atim.tv_sec > tv.tv_sec)
puts ("atim not set to NOW");
status = 1;
if (st2.st_mtim.tv_sec <= st1.st_mtim.tv_sec
|| st2.st_mtim.tv_sec > tv.tv_sec)
puts ("mtim not set to NOW");
status = 1;
if (symlink ("ttt", "tttsym") != 0)
error (1, errno, "cannot create symlink");
t[0].tv_sec = 0;
t[0].tv_nsec = 0;
t[1].tv_sec = 0;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, AT_FDCWD, "tttsym", t, AT_SYMLINK_NOFOLLOW) != 0)
if (lstat64 ("tttsym", &st2) != 0)
error (1, errno, "lstat failed");
puts ("symlink atim not reset to zero");
status = 1;
puts ("symlink mtim not reset to zero");
status = 1;
if (status != 0)
goto out;
t[0].tv_sec = 1;
t[0].tv_nsec = 0;
t[1].tv_sec = 1;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, fd, NULL, t, 0) != 0)
if (st2.st_atim.tv_sec != 1 || st2.st_atim.tv_nsec != 0)
puts ("atim not reset to one");
status = 1;
if (st2.st_mtim.tv_sec != 1 || st2.st_mtim.tv_nsec != 0)
puts ("mtim not reset to one");
status = 1;
if (status == 0)
puts ("all OK");
out:
close (fd);
unlink ("ttt");
unlink ("tttsym");
return status;
[akpm@linux-foundation.org: add missing i386 syscall table entry]
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Cc: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
ROUND_UP macro cleanup use ALIGN
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
Handle MAP_FIXED in alpha's arch_get_unmapped_area(), simple case, just return
the address as passed in
Currently, each fdtable supports three dynamically-sized arrays of data: the
fdarray and two fdsets. The code allows the number of fds supported by the
fdarray (fdtable->max_fds) to differ from the number of fds supported by each
of the fdsets (fdtable->max_fdset).
In practice, it is wasteful for these two sizes to differ: whenever we hit a
limit on the smaller-capacity structure, we will reallocate the entire fdtable
and all the dynamic arrays within it, so any delta in the memory used by the
larger-capacity structure will never be touched at all.
Rather than hogging this excess, we shouldn't even allocate it in the first
place, and keep the capacities of the fdarray and the fdsets equal. This
patch removes fdtable->max_fdset. As an added bonus, most of the supporting
code becomes simpler.
Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
These patches make the kernel pass 64-bit inode numbers internally when
communicating to userspace, even on a 32-bit system. They are required
because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS
for example. The 64-bit inode numbers are then propagated to userspace
automatically where the arch supports it.
Problems have been seen with userspace (eg: ld.so) using the 64-bit inode
number returned by stat64() or getdents64() to differentiate files, and
failing because the 64-bit inode number space was compressed to 32-bits, and
so overlaps occur.
This patch:
Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit
inode number so that 64-bit inode numbers can be passed back to userspace.
The stat functions then returns the full 64-bit inode number where
available and where possible. If it is not possible to represent the inode
number supplied by the filesystem in the field provided by userspace, then
error EOVERFLOW will be issued.
Similarly, the getdents/readdir functions now pass the full 64-bit inode
number to userspace where possible, returning EOVERFLOW instead when a
directory entry is encountered that can't be properly represented.
Note that this means that some inodes will not be stat'able on a 32-bit
system with old libraries where they were before - but it does mean that
there will be no ambiguity over what a 32-bit inode number refers to.
Note similarly that directory scans may be cut short with an error on a
32-bit system with old libraries where the scan would work before for the
same reasons.
It is judged unlikely that this situation will occur because modern glibc
uses 64-bit capable versions of stat and getdents class functions
exclusively, and that older systems are unlikely to encounter
unrepresentable inode numbers anyway.
[akpm: alpha build fix]
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Replace references to system_utsname to the per-process uts namespace
where appropriate. This includes things like uname.
Changes: Per Eric Biederman's comments, use the per-process uts namespace
for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c
[jdike@addtoit.com: UML fix]
[clg@fr.ibm.com: cleanup]
[akpm@osdl.org: build fix]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Andrey Savochkin <saw@sw.ru>
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Cc: Jeff Dike <jdike@addtoit.com>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a
duplicate of the macro. Also remove some trailing whitespaces and needless
braces.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Give the statfs superblock operation a dentry pointer rather than a superblock
pointer.
This complements the get_sb() patch. That reduced the significance of
sb->s_root, allowing NFS to place a fake root there. However, NFS does
require a dentry to use as a target for the statfs operation. This permits
the root in the vfsmount to be used instead.
linux/mount.h has been added where necessary to make allyesconfig build
successfully.
Interest has also been expressed for use with the FUSE and XFS filesystems.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
Create compat_sys_adjtimex and use it an all appropriate places.
Acked-by: Paul Mackerras <paulus@samba.org>
Here is a series of patches which introduce in total 13 new system calls
which take a file descriptor/filename pair instead of a single file
name. These functions, openat etc, have been discussed on numerous
occasions. They are needed to implement race-free filesystem traversal,
they are necessary to implement a virtual per-thread current working
directory (think multi-threaded backup software), etc.
We have in glibc today implementations of the interfaces which use the
/proc/self/fd magic. But this code is rather expensive. Here are some
results (similar to what Jim Meyering posted before).
The test creates a deep directory hierarchy on a tmpfs filesystem. Then
rm -fr is used to remove all directories. Without syscall support I get
this:
real 0m31.921s
user 0m0.688s
sys 0m31.234s
With syscall support the results are much better:
real 0m20.699s
user 0m0.536s
sys 0m20.149s
The interfaces are for obvious reasons currently not much used. But they'll
be used. coreutils (and Jeff's posixutils) are already using them.
Furthermore, code like ftw/fts in libc (maybe even glob) will also start using
them. I expect a patch to make follow soon. Every program which is walking
the filesystem tree will benefit.
Cc: Al Viro <viro@ftp.linux.org.uk>
With the new fdtable locking rules, you have to protect fdtable with either
->file_lock or rcu_read_lock/unlock(). There are some places where we
aren't doing either. This patch fixes those places.
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
Use schedule_timeout_interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
In order for the RCU to work, the file table array, sets and their sizes must
be updated atomically. Instead of ensuring this through too many memory
barriers, we put the arrays and their sizes in a separate structure. This
patch takes the first step of putting the file table elements in a separate
structure fdtable that is embedded withing files_struct. It also changes all
the users to refer to the file table using files_fdtable() macro. Subsequent
applciation of RCU becomes easier after this.
Signed-Off-By: David Howells <dhowells@redhat.com>
Use helper functions to convert between timeval structure and jiffies
rather than custom logic.
Signed-off-by: Domen Puncer <domen@coderock.org>
infrastructure for it.
Let it rip!
