Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Hardware name: empty
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Fix up all callers as they were before, with make one change: an
unsigned module taints the kernel, but doesn't turn off lockdep.
... and fix the race in updating unaligned control ones
Disintegrate asm/system.h for Alpha.
cc: linux-alpha@vger.kernel.org
All uses of the BKL on alpha are totally bogus, nothing
is really protected by this. Remove the remaining users
so we don't have to mark alpha as 'depends on BKL'.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: linux-alpha@vger.kernel.org
Signed-off-by: Matt Turner <mattst88@gmail.com>
Replace open-coded rate limiting logic with __ratelimit().
Convert alpha architecture to use u64 as unsigned long long. This is
being done so that (a) all arches use u64 as unsigned long long and (b)
printk of a u64 as %ll[ux] will not generate format warnings by gcc.
The only gcc cross-compiler that I have is 4.0.2, which generates errors
about miscompiling __weak references, so I have commented out that line in
compiler-gcc4.h so that most of these compile, but more builds and real
machine testing would be Real Good.
[akpm@linux-foundation.org: fix warning]
[akpm@linux-foundation.org: fix build]
pure noise - alpha doesn't have CPU hotplug
Vast majority of these build failures are gcc-4.3 warnings
about static functions and objects being referenced from
non-static (read: "extern inline") functions, in conjunction
with our -Werror.
We cannot just convert "extern inline" to "static inline",
as people keep suggesting all the time, because "extern inline"
logic is crucial for generic kernel build.
So
- just make sure that all callees of critical "extern inline"
functions are also "extern inline";
- use "static inline", wherever it's possible.
traps.c: work around gcc-4.3 being too smart about array
bounds-checking.
TODO: add "gnu_inline" attribute to all our "extern inline"
functions to ensure desired behaviour with future compilers.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
The functions time_before, time_before_eq, time_after, and time_after_eq are
more robust for comparing jiffies against other values.
So implement usage of the time_after() macro, defined in linux/jiffies.h,
which deals with wrapping correctly
Signed-off-by: S.Caglar Onur <caglar@pardus.org.tr>
One of the easiest things to isolate is the pid printed in kernel log.
There was a patch, that made this for arch-independent code, this one makes
so for arch/xxx files.
It took some time to cross-compile it, but hopefully these are all the
printks in arch code.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: <linux-arch@vger.kernel.org>
If the kernel OOPSed or BUGed then it probably should be considered as
tainted. Thus, all subsequent OOPSes and SysRq dumps will report the
tainted kernel. This saves a lot of time explaining oddities in the
calltraces.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
[ Added parisc patch from Matthew Wilson -Linus ]
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Pass in the pointer to the on-stack registers rather than using them
directly as the arguments.
Ivan noticed that I missed a spot when purging the registers as first
stack parameter idiom.
As usual, the reason of this breakage is quite silly: in do_entIF, we
are checking for PS == 0 to see whether it was a kernel BUG() or
userspace trap.
It works, unless BUG() happens in interrupt - PS is not 0 in kernel mode
due to non-zero IPL, and the things get messed up horribly then. In
this particular case it was BUG_ON(!irqs_disabled()) triggered in
run_posix_cpu_timers(), so we ended up shooting "current" with the
bursts of one SIGTRAP and three SIGILLs on every timer tick. ;-)
infrastructure for it.
Let it rip!
