Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation this program is
distributed in the hope that it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not write to the free
software foundation inc 59 temple place suite 330 boston ma 02111
1307 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 136 file(s).
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190530000436.384967451@linutronix.de
1. Remove "0x" prefix from unit-address of node names
----------------------->8------------------------
sed -i 's/@0x/@/g' arch/arc/boot/dts/*.dts*
2. Make all hex addresses lowercase:
sed -i 's/@\([0-9A-Za-z]*\)/@\L\1/g' arch/arc/boot/dts/*.dts*
sed -i 's/0x\([0-9A-Za-z]*\)/0x\L\1/g' arch/arc/boot/dts/*.dts*
Inspired by [1] and the like.
[1] http://kisskb.ellerman.id.au/kisskb/buildresult/13612017/
Reviewed-by: Rob Herring <robh+dt@kernel.org>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
As it was discussed quite some time ago (see
https://lkml.org/lkml/2015/11/5/862) it's a good practice to add
"model" property in .dts. Moreover as per ePAPR "model" property is
required and should look like "manufacturer,model" so we do here.
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Jonas Gorski <jonas.gorski@gmail.com>
Cc: Rob Herring <robh@kernel.org>
Cc: Christian Ruppert <christian.ruppert@alitech.com>
Device tree and Kconfig updates for GPIO and pinctrl drivers.
Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com>
This patch makes the SDA hold time configurable through device tree.
Signed-off-by: Pierrick Hascoet <pierrick.hascoet@abilis.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com> for arch/arc bits
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The TB10x platform port includes a custom mechanism using to set up
default pin controller configurations using abilis,simple-default
pin configurations of nodes compatible with abilis,simple-pinctrl. This
mechanism is redundant with the Linux standard "default" pin
configuration, see commit ab78029ecc347debbd737f06688d788bd9d60c1d
"drivers/pinctrl: grab default handles from device core".
This patch removes the TB10x custom mechanism in favour of the Linux
standard.
These are the device tree files for the Abilis Systems TB100 and TB101 ICs and
their respective development kit PCBs. These files are committed in preparation
of the following patch set which adds support for these chips to the ARC
platform.
