commit 7980dff398f86a618f502378fa27cf7e77449afa upstream.
Add a missing property to GMAC node so that multicast filtering works
correctly.
Fixes: 556cc1c5f528 ("ARC: [axs101] Add support for AXS101 SDP (software development platform)")
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Jose Abreu <Jose.Abreu@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
1. Remove "0x" prefix from unit-address of node names
----------------------->8------------------------
sed -i 's/@0x/@/g' arch/arc/boot/dts/*.dts*
2. Make all hex addresses lowercase:
sed -i 's/@\([0-9A-Za-z]*\)/@\L\1/g' arch/arc/boot/dts/*.dts*
sed -i 's/0x\([0-9A-Za-z]*\)/0x\L\1/g' arch/arc/boot/dts/*.dts*
Inspired by [1] and the like.
[1] http://kisskb.ellerman.id.au/kisskb/buildresult/13612017/
Reviewed-by: Rob Herring <robh+dt@kernel.org>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Otherwise kernel uses random MAC which is not very conveniet.
With that change in place use might set desired MAC in U-Boot
with "setenv ethaddr 11:22:33:44:55:66", save environment and
then from boot to boot the same MAC will be used by the kernel.
One other note for this to happen it's required to pass
board's .dtb in U-Boot's "bootm" command like that:
bootm 0x82000000 - 0x84000000
Here 0x82000000 is location of uImage while
0x80000000 is location of either axs10x.dtb or hsdk.dtb
previously loaded from SD-card, USB storage or TFTP server.
Cc: Rob Herring <robh+dt@kernel.org>
Cc: stable@vger.kernel.org # 4.14
Cc: devicetree@vger.kernel.org
Using compatible strings without the <manufacturer> part for at24 is
deprecated since commit 6da28acf745f ("dt-bindings: at24: consistently
document the compatible property"). Use a correct 'atmel,<model>'
value.
Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl>
DW ethernet controller on axs10x hangs sometimes after SW reset.
Invoke the newly aded driver (reset-axs10x.c) by adding the DT bits.
With this in place, we don't need the open-coded quirk in platform
code, so get rid of it as well !
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
DW sdio controller has external ciu clock divider controlled
via register in SDIO IP. It divides sdio_ref_clk
(which comes from CGU) by 16 for default. So default mmcclk
clock (which comes to sdk_in) is 25000000 Hz.
So fix wrong current value (50000000 Hz) to actual 25000000 Hz.
Note this is a preventive fix, in line with similar change for HSDK
where this was actually needed. see:
http://lists.infradead.org/pipermail/linux-snps-arc/2017-September/002924.html
dwmmc driver deprecated num-slots and plan to get rid
of it finally. Just move a step to cleanup it from DT.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
Acked-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Enable 64bit adressing, where it needed, to make possible
enabling PAE40 on axs103.
This patch doesn't affect on any functionality.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev-HKixBCOQz3hWk0Htik3J/w@public.gmane.org>
Default clock frequency for ARC PGU does not match any
existing HDMI mode, instead the default value matches a
DVI mode. Change the clock frequency to 74.25MHz so that
it matches HDMI mode 1280x720@60Hz
Signed-off-by: Jose Abreu <joabreu@synopsys.com>
Cc: Carlos Palminha <palminha@synopsys.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: linux-snps-arc@lists.infradead.org
This patch adds the necessary DT bindings to get HDMI audio
output in ARC AXS10x SDP. The bindings for I2S controller were
added as well as the bindings for simple audio card.
Pull drm updates from Dave Airlie:
"Here's the main drm pull request for 4.7, it's been a busy one, and
I've been a bit more distracted in real life this merge window. Lots
more ARM drivers, not sure if it'll ever end. I think I've at least
one more coming the next merge window.
But changes are all over the place, support for AMD Polaris GPUs is in
here, some missing GM108 support for nouveau (found in some Lenovos),
a bunch of MST and skylake fixes.
I've also noticed a few fixes from Arnd in my inbox, that I'll try and
get in asap, but I didn't think they should hold this up.
New drivers:
- Hisilicon kirin display driver
- Mediatek MT8173 display driver
- ARC PGU - bitstreamer on Synopsys ARC SDP boards
- Allwinner A13 initial RGB output driver
- Analogix driver for DisplayPort IP found in exynos and rockchip
DRM Core:
- UAPI headers fixes and C++ safety
- DRM connector reference counting
- DisplayID mode parsing for Dell 5K monitors
- Removal of struct_mutex from drivers
- Connector registration cleanups
- MST robustness fixes
- MAINTAINERS updates
- Lockless GEM object freeing
- Generic fbdev deferred IO support
panel:
- Support for a bunch of new panels
i915:
- VBT refactoring
- PLL computation cleanups
- DSI support for BXT
- Color manager support
- More atomic patches
- GEM improvements
- GuC fw loading fixes
- DP detection fixes
- SKL GPU hang fixes
- Lots of BXT fixes
radeon/amdgpu:
- Initial Polaris support
- GPUVM/Scheduler/Clock/Power improvements
- ASYNC pageflip support
- New mesa feature support
nouveau:
- GM108 support
- Power sensor support improvements
- GR init + ucode fixes.
- Use GPU provided topology information
vmwgfx:
- Add host messaging support
gma500:
- Some cleanups and fixes
atmel:
- Bridge support
- Async atomic commit support
fsl-dcu:
- Timing controller for LCD support
- Pixel clock polarity support
rcar-du:
- Misc fixes
exynos:
- Pipeline clock support
- Exynoss4533 SoC support
- HW trigger mode support
- export HDMI_PHY clock
- DECON5433 fixes
- Use generic prime functions
- use DMA mapping APIs
rockchip:
- Lots of little fixes
vc4:
- Render node support
- Gamma ramp support
- DPI output support
msm:
- Mostly cleanups and fixes
- Conversion to generic struct fence
etnaviv:
- Fix for prime buffer handling
- Allow hangcheck to be coalesced with other wakeups
tegra:
- Gamme table size fix"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (1050 commits)
drm/edid: add displayid detailed 1 timings to the modelist. (v1.1)
drm/edid: move displayid validation to it's own function.
drm/displayid: Iterate over all DisplayID blocks
drm/edid: move displayid tiled block parsing into separate function.
drm: Nuke ->vblank_disable_allowed
drm/vmwgfx: Report vmwgfx version to vmware.log
drm/vmwgfx: Add VMWare host messaging capability
drm/vmwgfx: Kill some lockdep warnings
drm/nouveau/gr/gf100-: fix race condition in fecs/gpccs ucode
drm/nouveau/core: recognise GM108 chipsets
drm/nouveau/gr/gm107-: fix touching non-existent ppcs in attrib cb setup
drm/nouveau/gr/gk104-: share implementation of ppc exception init
drm/nouveau/gr/gk104-: move rop_active_fbps init to nonctx
drm/nouveau/bios/pll: check BIT table version before trying to parse it
drm/nouveau/bios/pll: prevent oops when limits table can't be parsed
drm/nouveau/volt/gk104: round up in gk104_volt_set
drm/nouveau/fb/gm200: setup mmu debug buffer registers at init()
drm/nouveau/fb/gk20a,gm20b: setup mmu debug buffer registers at init()
drm/nouveau/fb/gf100-: allocate mmu debug buffers
drm/nouveau/fb: allow chipset-specific actions for oneinit()
https://github.com/foss-for-synopsys-dwc-arc-processors/linux into drm-next
Please pull this mini-series that allows ARC PGU to use
dedicated memory location as framebuffer backing storage.
* 'topic-arcpgu-updates' of https://github.com/foss-for-synopsys-dwc-arc-processors/linux:
ARC: [axs10x] Specify reserved memory for frame buffer
drm/arcpgu: use dedicated memory area for frame buffer
Add device tree bindings for AXS10X I2S PLL Clock driver.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Merge this back as we've built up a fair few conflicts, and I have
some newer trees to pull in.
Allocation of a frame buffer memory in a special memory region
allows bypassing of so-called IO Coherency aperture
which is typically set as a range 0x8z-0xAz.
I.e. all data traffic to PGU bypasses IO Coherency block
and saves its bandwidth for other peripherals.
Even though for AXS101 (which sorts ARC770 CPU) IOC is not
an option for a sake of keeping one DT description for the
base-board (axs10x_mb.dtsi) we're still defining reserved
memory location in the very end of DDR.
Synopsys DesignWare ARC SDP boards sport ARC SDP display
controller attached to ADV7511 HDMI encoder.
That change adds desctiption of both ARC PGU and ADV7511 in
ARC SDP'd base-board Device Tree.
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
This reverts commit 667a490bdb6e27db0887d2ca515b907d6aa87118.
This is needed to get ethernet(stmmac) working in 4.6-rc2 on axs103.
4.5 needed this fix, but apprently stmmac has gained some fixes which
warrant reversal of this.
Commit e34d65696d2e ("stmmac: create of compatible mdio bus for stmmac
driver") broke DW GMAC functionality on ARC AXS10x boards:
That's what happens on eth0 up:
--------------------------->8------------------------
| libphy: PHY stmmac-0:ffffffff not found
| eth0: Could not attach to PHY
| stmmac_open: Cannot attach to PHY (error: -19)
Simplest solution is to add PHY description in board's .dts.
And so we do here.
Cc: Rob Herring <robh@kernel.org>
Cc: Phil Reid <preid@electromag.com.au>
Cc: netdev@vger.kernel.org
Cc: stable@vger.kernel.org # 4.5
Reviewed-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Current ARC SDP boards cannot reliably handle 1Gbit
Ethernet connections due to limitations in hardware.
To make sure networking is stable on the board we're
limiting phy to 100 Mbit.
To avoid duplicating the MB DTS file, move the MB intc entry into cpu
card specific file
Cc: Grant Likely <grant.likely@linaro.org>
As DW Mobile Storage databook says it's required to use "Hold Register"
if card is enumerated in SDR12 or SDR25 modes.
It means we need to act in the same way as in Altera's Socfpga
implementation - set "use hold reg" bit in commad.
Note that for upstream proper solution would be to remove
dw_mci_pltfm_prepare_command() at all and set the bit right in
dw_mci_prepare_command() for all platforms.
The AXS10x platforms consist of a mainboard with peripherals,
on which several daughter cards can be placed. The daughter cards
typically contain a CPU and memory.
Signed-off-by: Mischa Jonker <mjonker@synopsys.com>
